[154]HELLO! BOOT0 is starting!
[157]BOOT0 commit : 1417090655
[160]set pll start
[162]fix vccio detect value:0xc0
[169]periph0 has been enabled
[172]set pll end
[174][pmu]: bus read error
[176]board init ok
[179]enable_jtag
[180]get_pmu_exist() = -1
[183]DRAM BOOT DRIVE INFO: V0.33
[186]DRAM CLK = 792 MHz
[188]DRAM Type = 3 (2:DDR2,3:DDR3)
[191]DRAMC ZQ value: 0x7b7bfb
[194]DRAM ODT value: 0x42.
[197]ddr_efuse_type: 0x0
[200]DRAM SIZE =1024 M
[203]dram_tpr4:0x0
[204]PLL_DDR_CTRL_REG:0xf8004100
[208]DRAM_CLK_REG:0xc0000000
[210][TIMING DEBUG] MR2= 0x18
[218]DRAM simple test OK.
[221]rtc standby flag is 0x0, super standby flag is 0x0
[226]dram size =1024
[229]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
[234]block from 8 to 32
[364]Check is correct.
[366]dma 0x2ac4c int is not used yet
[370]dma 0x2ac4c int is free, you do not need to free it again
[376]Entry_name = u-boot
[383]Entry_name = optee
[387]Entry_name = dtb
[390]Jump to second Boot.
M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
U-Boot 2018.07-gd9e6718-dirty (Feb 02 2024 - 17:55:53 +0800) Allwinner Technology
[00.442]CPU: Allwinner Family
[00.445]Model: sun8iw20
[00.447]DRAM: 1 GiB
[00.450]Relocation Offset is: 3cec1000
[00.477]secure enable bit: 0
E/TC:0 fdt_getprop_u32:343 prop trace_level not found
[00.491]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.497]gic: sec monitor mode
sunxi flash map init
SPI ALL: ready
[00.504]flash init start
[00.507]workmode = 0,storage type = 0
[00.513]sunxi-spinand-phy: spinand sample_mode:2 sample_delay:2
device nand0 <nand>, # parts = 4
#: name size offset mask_flags
0: boot0 0x00100000 0x00000000 1
1: uboot 0x00300000 0x00100000 1
2: secure_storage 0x00100000 0x00400000 1
3: sys 0x0fb00000 0x00500000 0
active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000
defaults:
mtdids : nand0=nand
mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
[00.663]ubi0: attaching mtd4
[01.087]ubi0: scanning is finished
[01.097]ubi0: attached mtd4 (name "sys", size 251 MiB)
[01.101]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[01.108]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[01.114]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[01.120]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
[01.126]ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
[01.132]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[01.140]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
[01.149]sunxi flash init ok
[01.151]line:703 init_clocks
[01.154]drv_disp_init
[01.159]handle_num : 6
request pwm success, pwm2:pwm2:0x2000c00.
[01.170]drv_disp_init finish
[01.380]Loading Environment from SUNXI_FLASH... OK
[01.415]boot_gui_init:start
[01.417]set disp.dev2_output_type fail. using defval=0
[01.444]set disp.fb0_rot_used fail. using defval=0
[01.448]set disp.fb0_rot_degree fail. using defval=0
[01.617]boot_gui_init:finish
partno erro : can't find partition bootloader
[01.645]bmp_name=bootlogo.bmp size 38454
[01.658]Item0 (Map) magic is bad
secure storage read widevine fail
[01.664]secure storage read widevine fail with:-1
secure storage read ec_key fail
[01.671]secure storage read ec_key fail with:-1
secure stFDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
sunxi_pwm_pin_set_state, fdt_set_all_pin, ret=-1
[01.686]LCD open finish
orage read ec_cert1 fail
[01.690]secure storage read ec_cert1 fail with:-1
secure storage read ec_cert2 fail
[01.697]secure storage read ec_cert2 fail with:-1
secure storage read ec_cert3 fail
[01.705]secure storage read ec_cert3 fail with:-1
secure storage read rsa_key fail
[01.712]secure storage read rsa_key fail with:-1
secure storage read rsa_cert1 fail
[01.720]secure storage read rsa_cert1 fail with:-1
secure storage read rsa_cert2 fail
[01.727]secure storage read rsa_cert2 fail with:-1
secure storage read rsa_cert3 fail
[01.735]secure storage read rsa_cert3 fail with:-1
[01.740]usb burn from boot
delay time 0
weak:otg_phy_config
[01.751]usb prepare ok
[01.958]usb sof ok
[01.960]usb probe ok
[01.962]usb setup ok
set address 0x33
set address 0x33 ok
try to update
[02.366]do_burn_from_boot usb : have no handshake
List file under ULI/factory
** Unrecognized filesystem type **
[02.397]update bootcmd
[02.426]change working_fdt 0x7c880e70 to 0x7c860e70
[02.445]update dts
[03.007]no vendor_boot partition is found
Android's image name: sun8i_arm
ERROR: reserving fdt memory region failed (addr=41900000 size=200000)
ERROR: reserving fdt memory region failed (addr=41c00000 size=400000)
ERROR: reserving fdt memory region failed (addr=41b00000 size=100000)
ERROR: reserving fdt memory region failed (addr=7c91d000 size=3e8000)
ERROR: reserving fdt memory region failed (addr=42000000 size=100000)
ERROR: reserving fdt memory region failed (addr=42240000 size=2000)
ERROR: reserving fdt memory region failed (addr=42242000 size=2000)
ERROR: reserving fdt memory region failed (addr=42100000 size=10000)
[03.101]Starting kernel ...
[ 0.000000] Linux version 5.4.61 (whycan@ubuntu) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #3 SMP PREEMPT Tue Jan 30 12:03:56 CST 2024
[ 0.000000] OF: fdt: Machine model: sun8iw20
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] Reserved memory: created DMA memory pool at 0x42200000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0buffer@42200000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x42244000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node dsp0_rpbuf@42244000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 16 MiB at 0x7f000000
[ 0.000000] On node 0 totalpages: 261796
[ 0.000000] Normal zone: 1536 pages used for memmap
[ 0.000000] Normal zone: 196260 pages, LIFO batch:63
[ 0.000000] HighMem zone: 65536 pages, LIFO batch:15
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s30976 r8192 d22272 u61440
[ 0.000000] pcpu-alloc: s30976 r8192 d22272 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260260
[ 0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/init rdinit=/rdinit partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:recovery@ubi0_6:dsp0@ubi0_7:private@ubi0_8:UDISK@ubi0_9: cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07-gd9e6718-dirty(02/02/2024-17:55:53) mbr_offset=1032192 disp_reserve=4096000,0x7c91d000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=1024
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Memory: 998328K/1047184K available (7168K kernel code, 431K rwdata, 2544K rodata, 1024K init, 192K bss, 32472K reserved, 16384K cma-reserved, 241760K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] random: get_random_bytes called from start_kernel+0x250/0x3d0 with crng_init=0
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008000] Switching to timer-based delay loop, resolution 41ns
[ 0.014185] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023974] Console: colour dummy device 80x30
[ 0.028467] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038838] pid_max: default: 32768 minimum: 301
[ 0.043625] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.050949] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.059354] CPU: Testing write buffer coherency: ok
[ 0.064629] /cpus/cpu@0 missing clock-frequency property
[ 0.069957] /cpus/cpu@1 missing clock-frequency property
[ 0.075303] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081568] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088252] rcu: Hierarchical SRCU implementation.
[ 0.093364] BOOTEVENT: 93.355457: ON
[ 0.097751] smp: Bringing up secondary CPUs ...
[ 0.103574] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.103729] smp: Brought up 1 node, 2 CPUs
[ 0.113554] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.119734] CPU: All CPU(s) started in SVC mode.
[ 0.124938] devtmpfs: initialized
[ 0.142307] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.150523] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.160405] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.168085] pinctrl core: initialized pinctrl subsystem
[ 0.174826] NET: Registered protocol family 16
[ 0.181085] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.233417] rtc_ccu: sunxi ccu init OK
[ 0.239636] ccu: sunxi ccu init OK
[ 0.243584] r_ccu: sunxi ccu init OK
[ 0.289853] sun6i-dma 3002000.dma-controller: sunxi dma probed
[ 0.298047] iommu: Default domain type: Translated
[ 0.303273] sunxi iommu: irq = 24
[ 0.307862] SCSI subsystem initialized
[ 0.312008] usbcore: registered new interface driver usbfs
[ 0.317784] usbcore: registered new interface driver hub
[ 0.323214] usbcore: registered new device driver usb
[ 0.328534] mc: Linux media interface: v0.10
[ 0.332866] videodev: Linux video capture interface: v2.00
[ 0.340262] Advanced Linux Sound Architecture Driver Initialized.
[ 0.347108] Bluetooth: Core ver 2.22
[ 0.350828] NET: Registered protocol family 31
[ 0.355269] Bluetooth: HCI device and connection manager initialized
[ 0.361648] Bluetooth: HCI socket layer initialized
[ 0.366542] Bluetooth: L2CAP socket layer initialized
[ 0.371617] Bluetooth: SCO socket layer initialized
[ 0.376833] pwm module init!
[ 0.381410] g2d 5410000.g2d: Adding to iommu group 0
[ 0.386908] G2D: rcq version initialized.major:250
[ 0.392450] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.400295] clocksource: Switched to clocksource arch_sys_counter
[ 0.416414] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 0.438197] thermal_sys: Registered thermal governor 'step_wise'
[ 0.438204] thermal_sys: Registered thermal governor 'user_space'
[ 0.444488] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.451316] NET: Registered protocol family 2
[ 0.463031] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.471462] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.479293] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.486574] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.493097] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.499776] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.507089] NET: Registered protocol family 1
[ 0.512623] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[ 0.520948] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.527671] sunxi_spi_resource_get()2259 - [spi0] SPI MASTER MODE
[ 0.534048] sunxi_spi_resource_get()2306 - sample_mode:2 sample_delay:2
[ 0.540719] sunxi_spi_request_dma()988 - [spi0] Request DMA channel dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
[ 0.551559] sunxi_spi_clk_init()2356 - [spi0] mclk 100000000
[ 0.558052] spi spi0: chipselect 0 already in use
[ 0.562808] spi_master spi0: spi_device register error /soc@3000000/spi@4025000/spi_board@0
[ 0.571289] spi_master spi0: Failed to create SPI device for /soc@3000000/spi@4025000/spi_board@0
[ 0.580170] sunxi_spi_probe()2809 - [spi0]: driver probe succeed, base f0862000, irq 42
[ 0.590399] Initialise system trusted keyrings
[ 0.595039] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[ 0.612454] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.618572] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.623424] fuse: init (API version 7.31)
[ 0.658538] NET: Registered protocol family 38
[ 0.663040] Key type asymmetric registered
[ 0.667150] Asymmetric key parser 'x509' registered
[ 0.672203] bounce: pool size: 64 pages
[ 0.676116] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.683549] io scheduler mq-deadline registered
[ 0.688084] io scheduler kyber registered
[ 0.692211] atomic64_test: passed
[ 0.697162] [DISP]disp_module_init
[ 0.701277] disp 5000000.disp: Adding to iommu group 0
[ 0.707080] [DISP] disp_init,line:2331:
[ 0.707084] smooth display screen:0 type:1 mode:4
[ 0.732168] display_fb_request,fb_id:0
[ 0.752473] disp_al_manager_apply ouput_type:1
[ 0.757081] [DISP] lcd_clk_config,line:777:
[ 0.757092] disp 0, clk: pll(420000000),clk(420000000),dclk(70000000) dsi_rate(70000000)
[ 0.757092] clk real:pll(420000000),clk(420000000),dclk(105000000) dsi_rate(150000000)
[ 0.760975] [DISP]disp_module_init finish
[ 0.761689] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[ 0.779868] sunxi_sid_init()783 - insmod ok
[ 0.794762] pwm-regulator: supplied by regulator-dummy
[ 0.801711] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 0.809884] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.817206] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.825122] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
[ 0.833143] printk: console [ttyS0] enabled
[ 0.842064] printk: bootconsole [earlycon0] disabled
[ 0.853477] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 0.862604] uart uart1: uart1 supply uart not found, using dummy regulator
[ 0.870786] uart1: ttyS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
[ 0.880857] misc dump reg init
[ 0.884975] deinterlace 5400000.deinterlace: Adding to iommu group 0
[ 0.892719] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[ 0.901779] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 0.909030] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 0.916427] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 0.923876] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 0.930449] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 0.937414] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 0.945170] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 0.953055] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 0.961193] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 0.968898] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 0.975684] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 0.983264] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 0.991566] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[ 0.998859] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
[ 1.006704] [ADDR_MGT] addr_mgt_probe: success.
[ 1.012964] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
[ 1.020235] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.028124] sunxi-spinand-phy: not detect any munufacture from id table
[ 1.035631] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 1.042293] sunxi-spinand-phy: get phy info from fdt fail
[ 1.048360] sunxi-spinand-phy: not detect munufacture from fdt
[ 1.055022] sunxi-spinand-phy: detect munufacture from id table: Winbond
[ 1.062580] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[ 1.069608] sunxi-spinand-phy: ========== arch info ==========
[ 1.076162] sunxi-spinand-phy: Model: W25N01GVZEIG
[ 1.082918] sunxi-spinand-phy: Munufacture: Winbond
[ 1.089169] sunxi-spinand-phy: DieCntPerChip: 1
[ 1.094850] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 1.100817] sunxi-spinand-phy: PageCntPerBlk: 64
[ 1.106577] sunxi-spinand-phy: SectCntPerPage: 4
[ 1.112259] sunxi-spinand-phy: OobSizePerPage: 64
[ 1.118020] sunxi-spinand-phy: BadBlockFlag: 0x0
[ 1.123888] sunxi-spinand-phy: OperationOpt: 0x7
[ 1.129756] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 1.135828] sunxi-spinand-phy: EccFlag: 0x0
[ 1.141697] sunxi-spinand-phy: EccType: 2
[ 1.147371] sunxi-spinand-phy: EccProtectedType: 3
[ 1.153044] sunxi-spinand-phy: ========================================
[ 1.160533] sunxi-spinand-phy:
[ 1.164053] sunxi-spinand-phy: ========== physical info ==========
[ 1.171003] sunxi-spinand-phy: TotalSize: 128 M
[ 1.176384] sunxi-spinand-phy: SectorSize: 512 B
[ 1.181770] sunxi-spinand-phy: PageSize: 2 K
[ 1.186945] sunxi-spinand-phy: BlockSize: 128 K
[ 1.192371] sunxi-spinand-phy: OOBSize: 64 B
[ 1.193732] Freeing logo buffer memory: 4000K
[ 1.197647] sunxi-spinand-phy: ========================================
[ 1.209969] sunxi-spinand-phy:
[ 1.213499] sunxi-spinand-phy: ========== logical info ==========
[ 1.220343] sunxi-spinand-phy: TotalSize: 128 M
[ 1.225721] sunxi-spinand-phy: SectorSize: 512 B
[ 1.231111] sunxi-spinand-phy: PageSize: 4 K
[ 1.236287] sunxi-spinand-phy: BlockSize: 256 K
[ 1.241676] sunxi-spinand-phy: OOBSize: 128 B
[ 1.247049] sunxi-spinand-phy: ========================================
[ 1.254541] sunxi-spinand-phy: block lock register: 0x00
[ 1.260614] sunxi-spinand-phy: feature register: 0x19
[ 1.266284] sunxi-spinand-phy: sunxi physic nand init end
[ 1.272876] Creating 4 MTD partitions on "sunxi_mtd_nand":
[ 1.279064] 0x000000000000-0x000000100000 : "boot0"
[ 1.291470] 0x000000100000-0x000000400000 : "uboot"
[ 1.311482] 0x000000400000-0x000000500000 : "secure_storage"
[ 1.321491] 0x000000500000-0x000008000000 : "sys"
[ 1.328174] random: fast init done
[ 1.442144] libphy: Fixed MDIO Bus: probed
[ 1.446751] CAN device driver interface
[ 1.451664] sunxi-can can@0x0 (unnamed net_device) (uninitialized): request pinctrl handle fail!
[ 1.462259] sunxi-can can@0x0: can driver probe ok ...
[ 1.468365] sunxi-can can@0x1 (unnamed net_device) (uninitialized): request pinctrl handle fail!
[ 1.478952] sunxi-can can@0x1: can driver probe ok ...
[ 1.485693] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[ 1.494913] gmac-power0: NULL
[ 1.498243] gmac-power1: NULL
[ 1.501626] gmac-power2: NULL
[ 1.506186] Failed to alloc md5
[ 1.509720] eth0: Use random mac address
[ 1.514675] usbcore: registered new interface driver asix
[ 1.520907] usbcore: registered new interface driver ax88179_178a
[ 1.527812] usbcore: registered new interface driver cdc_ether
[ 1.534486] usbcore: registered new interface driver net1080
[ 1.540928] usbcore: registered new interface driver cdc_subset
[ 1.547632] usbcore: registered new interface driver zaurus
[ 1.554020] usbcore: registered new interface driver cdc_ncm
[ 1.560392] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.567728] sunxi-ehci: EHCI SUNXI driver
[ 1.572729] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.579691] sunxi-ohci: OHCI SUNXI driver
[ 1.584932] usbcore: registered new interface driver uas
[ 1.591059] usbcore: registered new interface driver usb-storage
[ 1.597862] usbcore: registered new interface driver ums-alauda
[ 1.604665] usbcore: registered new interface driver ums-cypress
[ 1.611496] usbcore: registered new interface driver ums-datafab
[ 1.618314] usbcore: registered new interface driver ums_eneub6250
[ 1.625330] usbcore: registered new interface driver ums-freecom
[ 1.632168] usbcore: registered new interface driver ums-isd200
[ 1.638864] usbcore: registered new interface driver ums-jumpshot
[ 1.645780] usbcore: registered new interface driver ums-karma
[ 1.652435] usbcore: registered new interface driver ums-onetouch
[ 1.659349] usbcore: registered new interface driver ums-realtek
[ 1.666188] usbcore: registered new interface driver ums-sddr09
[ 1.672910] usbcore: registered new interface driver ums-sddr55
[ 1.679616] usbcore: registered new interface driver ums-usbat
[ 1.687310] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 1.697332] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[ 1.709583] sunxi-rtc 7090000.rtc: registered as rtc0
[ 1.715475] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:05 UTC (5)
[ 1.724420] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 1.730550] i2c /dev entries driver
[ 1.734681] IR NEC protocol handler initialized
[ 1.739767] IR RC5(x/sz) protocol handler initialized
[ 1.746168] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
[ 1.756364] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
[ 1.766175] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
[ 1.775862] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
[ 1.787702] usbcore: registered new interface driver uvcvideo
[ 1.794215] USB Video Class driver (1.1.1)
[ 1.798810] gspca_main: v2.14.0 registered
[ 1.803418] sunxi cedar version 1.1
[ 1.807555] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.813938] VE: sunxi_cedar_probe power-domain init!!!
[ 1.819709] VE: install start!!!
[ 1.819709]
[ 1.825343] VE: cedar-ve the get irq is 43
[ 1.825343]
[ 1.831886] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 1.831886]
[ 1.841188] VE: install end!!!
[ 1.841188]
[ 1.846282] VE: sunxi_cedar_probe
[ 1.851603] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.860919] Bluetooth: HCI UART driver ver 2.3
[ 1.865911] Bluetooth: HCI UART protocol H4 registered
[ 1.871991] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 1.879273] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 1.885762] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 1.892357] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 1.892357]
[ 1.901102] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 1.910538] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 1.920536] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 1.926750] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 1.933126] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 1.939572] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 1.946041] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 1.952599] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 1.959145] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 1.965705] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 1.972758] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 1.978478] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.989729] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 2.009894] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.034159] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
[ 2.040244] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.051983] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 2.061922] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 2.068136] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 2.074607] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 2.081114] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 2.087561] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 2.094127] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 2.100687] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 2.107233] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 2.113814] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 2.123326] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.134520] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 2.154683] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.178940] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 2.186635] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 2.187012] usbcore: registered new interface driver usbhid
[ 2.199800] usbhid: USB HID core driver
[ 2.200607] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 2.204137] exFAT: Version 1.3.0
[ 2.214579] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.220935] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ...
[ 2.233934] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok...
[ 2.234832] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.242249] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver 2.1.2
[ 2.260097] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.266881] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.273689] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.280461] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 2.280490] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 2.287264] sunxi-rproc 3000008.dsp_rproc: failed to get firmware-name
[ 2.306228] remoteproc remoteproc0: dsp_rproc is available
[ 2.312522] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver probe ok
[ 2.320985] sunxi-rpbuf-controller rpbuf_controller@0: assigned reserved memory node dsp0_rpbuf@42244000
[ 2.332019] sunxi-rpbuf-controller rpbuf_controller@0: rpbuf_register_ctrl_dev:827
[ 2.344641] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 2.344641]
[ 2.361913] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 2.373373] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
[ 2.382835] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 2.392708] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 2.400002] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 2.411228] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input2
[ 2.423439] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 2.432402] NET: Registered protocol family 10
[ 2.438533] Segment Routing with IPv6
[ 2.442835] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.450354] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[ 2.451602] NET: Registered protocol family 17
[ 2.462813] NET: Registered protocol family 15
[ 2.467799] can: controller area network core (rev 20170425 abi 9)
[ 2.474862] NET: Registered protocol family 29
[ 2.479853] can: raw protocol (rev 20170425)
[ 2.484666] can: broadcast manager protocol (rev 20170425 t)
[ 2.491036] can: netlink gateway (rev 20190810) max_hops=1
[ 2.497680] Bluetooth: RFCOMM TTY layer initialized
[ 2.503218] Bluetooth: RFCOMM socket layer initialized
[ 2.509010] Bluetooth: RFCOMM ver 1.11
[ 2.514242] Registering SWP/SWPB emulation handler
[ 2.520019] Loading compiled-in X.509 certificates
[ 2.544332] sunxi-i2c 2502800.twi: 2502800.twi supply twi not found, using dummy regulator
[ 2.555116] sunxi-i2c 2502800.twi: probe success
[ 2.562336] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
[ 2.601760] get drvvbus-en is fail, 22
[ 2.605968] get ehci0-controller wakeup-source is fail.
[ 2.612027] sunxi ehci0-controller don't init wakeup source
[ 2.618279] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c91ca0, 0x:f18d3000, irq_no:3b
[ 2.630304] [sunxi-ehci0]: Not init ehci0
[ 2.635218] get drvvbus-en is fail, 22
[ 2.639424] get ohci0-controller wakeup-source is fail.
[ 2.645418] sunxi ohci0-controller don't init wakeup source
[ 2.651687] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c91f50
[ 2.661354] [sunxi-ohci0]: Not init ohci0
[ 2.666250] get drvvbus-en is fail, 22
[ 2.670483] get ehci1-controller wakeup-source is fail.
[ 2.676435] sunxi ehci1-controller don't init wakeup source
[ 2.682705] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c92200, 0x:f18dd000, irq_no:3d
[ 2.694978] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 2.708453] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 2.715747] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 2.725645] sunxi-ehci 4200000.ehci1-controller: irq 61, io mem 0x04200000
[ 2.760316] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 2.769030] hub 1-0:1.0: USB hub found
[ 2.773309] hub 1-0:1.0: 1 port detected
[ 2.778634] get drvvbus-en is fail, 22
[ 2.782868] get ohci1-controller wakeup-source is fail.
[ 2.788842] sunxi ohci1-controller don't init wakeup source
[ 2.795108] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c924b0
[ 2.805044] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 2.817365] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 2.824640] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 2.834514] sunxi-ohci 4200400.ohci1-controller: irq 62, io mem 0x04200400
[ 2.915182] hub 2-0:1.0: USB hub found
[ 2.919447] hub 2-0:1.0: 1 port detected
[ 2.925926] ubi0: attaching mtd3
[ 3.060350] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:3
[ 3.125481] ubi0: scanning is finished
[ 3.134497] ubi0 error: vtbl_check: too large reserved_pebs 594, good PEBs 492
[ 3.142629] ubi0 error: vtbl_check: volume table check failed: record 9, error 9
[ 3.150945] Volume table record 9 dump:
[ 3.155239] reserved_pebs 594
[ 3.158850] alignment 1
[ 3.162329] data_pad 0
[ 3.165747] vol_type 1
[ 3.169164] upd_marker 0
[ 3.172595] name_len 5
[ 3.176022] name UDISK
[ 3.179828] crc 0xbb9113be
[ 3.184391] ubi0 error: ubi_attach_mtd_dev: failed to attach mtd3, error -22
[ 3.192356] UBI error: cannot attach mtd3
[ 3.196853] UBI: block: can't open volume on ubi0_-1, err=-19
[ 3.203883] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
[ 3.220965] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
[ 3.228591] sunxi-vin-core 5809200.vinc: Adding to iommu group 0
[ 3.236810] sun8iw20-pinctrl pio: pin PE13 already requested by 4500000.eth; cannot claim for pio:141
[ 3.247228] sun8iw20-pinctrl pio: pin-141 (pio:141) status -22
[ 3.254102] [VIN_WARN]get csi isp clk fail
[ 3.258721] [VIN_WARN]get csi isp src clk fail
[ 3.263732] [VIN_WARN]get csi mipi clk fail
[ 3.268420] [VIN_WARN]get csi mipi src clk fail
[ 3.273549] [VIN_WARN]get csi isp mbus clk fail
[ 3.278637] [VIN_WARN]Get isp reset control fail
[ 3.284030] [VIN_ERR]n5 request i2c1 adapter failed!
[ 3.292802] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.303943] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 3.311492] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.320392] clk: Not disabling unused clocks
[ 3.321168] cfg80211: failed to load regulatory.db
[ 3.325931] ALSA device list:
[ 3.325937] #0: audiocodec
[ 3.337966] alloc_fd: slot 0 not NULL!
[ 3.342699] /dev/root: Can't open blockdev
[ 3.347299] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -6
[ 3.356215] Please append a correct "root=" boot option; here are the available partitions:
[ 3.365613] 1f00 1024 mtdblock0
[ 3.365616] (driver?)
[ 3.372952] 1f01 3072 mtdblock1
[ 3.372955] (driver?)
[ 3.380292] 1f02 1024 mtdblock2
[ 3.380295] (driver?)
[ 3.387616] 1f03 125952 mtdblock3
[ 3.387618] (driver?)
[ 3.394962] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 3.404227] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #3
[ 3.410857] Hardware name: Generic DT based system
[ 3.416244] [<c010e2f8>] (unwind_backtrace) from [<c010a8bc>] (show_stack+0x10/0x14)
[ 3.424927] [<c010a8bc>] (show_stack) from [<c0792170>] (dump_stack+0x7c/0x98)
[ 3.433027] [<c0792170>] (dump_stack) from [<c0119d2c>] (panic+0x104/0x3dc)
[ 3.440835] [<c0119d2c>] (panic) from [<c0b01278>] (mount_block_root+0x258/0x300)
[ 3.449225] [<c0b01278>] (mount_block_root) from [<c0b014bc>] (prepare_namespace+0x118/0x178)
[ 3.458785] [<c0b014bc>] (prepare_namespace) from [<c07a6854>] (kernel_init+0x8/0x118)
[ 3.467662] [<c07a6854>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 3.476144] Exception stack(0xef079fb0 to 0xef079ff8)
[ 3.481803] 9fa0: 00000000 00000000 00000000 00000000
[ 3.490969] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.500134] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 3.507552] CPU0: stopping
[ 3.510585] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #3
[ 3.517214] Hardware name: Generic DT based system
[ 3.522588] [<c010e2f8>] (unwind_backtrace) from [<c010a8bc>] (show_stack+0x10/0x14)
[ 3.531268] [<c010a8bc>] (show_stack) from [<c0792170>] (dump_stack+0x7c/0x98)
[ 3.539365] [<c0792170>] (dump_stack) from [<c010c6b0>] (handle_IPI+0xc0/0x168)
[ 3.547561] [<c010c6b0>] (handle_IPI) from [<c03a7134>] (gic_handle_irq+0x70/0x78)
[ 3.556048] [<c03a7134>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[ 3.564432] Exception stack(0xc0c01f40 to 0xc0c01f88)
[ 3.570093] 1f40: 000067c8 ef7b9574 00000000 c0115280 00000001 c0c00000 c0c03e28 c0c03e64
[ 3.579260] 1f60: 00000000 efffc3c0 c0b2f0c0 00000000 c0c76830 c0c01f90 c0107fd8 c0107fdc
[ 3.588423] 1f80: 60000113 ffffffff
[ 3.592334] [<c01021cc>] (__irq_svc) from [<c0107fdc>] (arch_cpu_idle+0x2c/0x38)
[ 3.600627] [<c0107fdc>] (arch_cpu_idle) from [<c013e920>] (do_idle+0xb8/0x120)
[ 3.608821] [<c013e920>] (do_idle) from [<c013ec24>] (cpu_startup_entry+0x18/0x1c)
[ 3.617307] [<c013ec24>] (cpu_startup_entry) from [<c0b00c68>] (start_kernel+0x340/0x3d0)
[ 3.626474] [<c0b00c68>] (start_kernel) from [<00000000>] (0x0)
[ 3.633118] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---这里不正常:
[ 3.196853] UBI: block: can't open volume on ubi0_-1, err=-19离线
正常的应该是这样:
[ 3.294163] ubi0: attaching mtd3
[ 3.655598] random: crng init done
[ 3.690415] ubi0: scanning is finished
[ 3.705125] ubi0 warning: ubi_eba_init: cannot reserve enough PEBs for bad PEB handling, reserved 16, need 20
[ 3.718936] ubi0: attached mtd3 (name "sys", size 122 MiB)
[ 3.725116] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[ 3.732855] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[ 3.740424] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 3.748250] ubi0: good PEBs: 488, bad PEBs: 0, corrupted PEBs: 0
[ 3.754995] ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
[ 3.763214] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[ 3.772556] ubi0: available PEBs: 0, total reserved PEBs: 488, PEBs reserved for bad PEB handling: 16
[ 3.782908] ubi0: background thread "ubi_bgt0d" started, PID 71
[ 3.791403] block ubiblock0_5: created from ubi0:5(rootfs)离线
T113-i SPI NAND W25N01GVZEIG 启动失败
[160]set pll start
[173]set pll end
[177]board init ok
[179]enable_jtag
[181]get_pmu_exist() = -1
[189]DRAM Type = 3 (2:DDR2,3:DDR3)
[192]DRAMC ZQ value: 0x7b7bfb
[195]DRAM ODT value: 0x42.
[198]ddr_efuse_type: 0x0
[201]DRAM SIZE =1024 M
[203]dram_tpr4:0x0
[205]PLL_DDR_CTRL_REG:0xf8004100
[211][TIMING DEBUG] MR2= 0x18
[219]DRAM simple test OK.
[379]Check is correct.
[381]dma 0x2ac4c int is not used yet
[384]dma 0x2ac4c int is free, you do not need to free it again
[390]Entry_name = u-boot
[397]Entry_name = optee
[401]Entry_name = dtb
[404]Jump to second Boot.
U-Boot 2018.07-gd9e6718-dirty (Feb 20 2024 - 22:40:19 +0800) Allwinner Technology
[00.456]CPU: Allwinner Family
[00.459]Model: sun8iw20
[00.461]DRAM: 1 GiB
[00.465]Relocation Offset is: 3cebc000
[00.492]secure enable bit: 0
[00.506]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.512]gic: sec monitor mode
SPI ALL: ready
[00.519]flash init start
[00.522]workmode = 0,storage type = 0
[00.528]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:1d
3: sys 0x07b00000 0x00500000 0
defaults:
mtdids : nand0=nand
[00.645]ubi0: attaching mtd4
[00.872]ubi0: scanning is finished
[00.881]ubi0: attached mtd4 (name "sys", size 123 MiB)
[00.886]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[00.892]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[00.898]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[00.905]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[00.910]ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
[00.917]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[00.924]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[00.933]sunxi flash init ok
[00.935]line:703 init_clocks
[00.938]drv_disp_init
[00.943]handle_num : 6
[00.954]drv_disp_init finish
[01.184]Loading Environment from SUNXI_FLASH... OK
[01.220]boot_gui_init:start
[01.223]set disp.dev2_output_type fail. using defval=0
[01.359]set disp.fb0_rot_used fail. using defval=0
[01.364]set disp.fb0_rot_degree fail. using defval=0
[01.369]smallwitpi lcd_panel_init 187 xxxxxxxxxxxxxxxxxx
[01.602]boot_gui_init:finish
[01.632]bmp_name=bootlogo.bmp size 38454
[01.645]Item0 (Map) magic is bad
[01.651]secure storage read widevine fail with:-1
[01.659]secure storage read ec_key FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
[01.671]LCD open finish
fail with:-1
[01.678]secure storage read ec_cert1 fail with:-1
[01.685]secure storage read ec_cert2 fail with:-1
[01.692]secure storage read ec_cert3 fail with:-1
[01.700]secure storage read rsa_key fail with:-1
[01.707]secure storage read rsa_cert1 fail with:-1
[01.715]secure storage read rsa_cert2 fail with:-1
[01.723]secure storage read rsa_cert3 fail with:-1
[01.727]usb burn from boot
delay time 0
weak:otg_phy_config
[01.738]usb prepare ok
[01.945]usb sof ok
[01.947]usb probe ok
[01.949]usb setup ok
set address 0x2f
set address 0x2f ok
set address 0x1d
set address 0x1d ok
try to update
[02.354]do_burn_from_boot usb : have no handshake
[02.387]update bootcmd
[02.418]change working_fdt 0x7c87be70 to 0x7c85be70
[02.438]update dts
[03.045]no vendor_boot partition is found
ERROR: reserving fdt memory region failed (addr=7c8ff000 size=342600)
[03.141]Starting kernel ...
[ 0.000000] Linux version 5.4.61 (whycan@ubuntu) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #14 SMP PREEMPT Tue Feb 20 16:55:57 CST 2024
[ 0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/init rdinit=/rdinit partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:recovery@ubi0_6:dsp0@ubi0_7:private@ubi0_8:UDISK@ubi0_9: cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07-gd9e6718-dirty(02/20/2024-22:40:19) mbr_offset=1032192 disp_reserve=3417600,0x7c8ff000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=1024
[ 0.000000] Memory: 998976K/1047184K available (7168K kernel code, 441K rwdata, 2544K rodata, 1024K init, 193K bss, 31824K reserved, 16384K cma-reserved, 242420K highmem)
[ 0.008017] Switching to timer-based delay loop, resolution 41ns
[ 0.014198] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023988] Console: colour dummy device 80x30
[ 0.028464] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038833] pid_max: default: 32768 minimum: 301
[ 0.043623] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.059368] CPU: Testing write buffer coherency: ok
[ 0.064640] /cpus/cpu@0 missing clock-frequency property
[ 0.069960] /cpus/cpu@1 missing clock-frequency property
[ 0.075298] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081555] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088249] rcu: Hierarchical SRCU implementation.
[ 0.093369] BOOTEVENT: 93.360207: ON
[ 0.097757] smp: Bringing up secondary CPUs ...
[ 0.103591] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.103747] smp: Brought up 1 node, 2 CPUs
[ 0.113564] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.119735] CPU: All CPU(s) started in SVC mode.
[ 0.124945] devtmpfs: initialized
[ 0.142322] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.150509] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.160390] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.168058] pinctrl core: initialized pinctrl subsystem
[ 0.174760] NET: Registered protocol family 16
[ 0.181025] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.232801] rtc_ccu: sunxi ccu init OK
[ 0.238982] ccu: sunxi ccu init OK
[ 0.242917] r_ccu: sunxi ccu init OK
[ 0.286357] sun6i-dma 3002000.dma-controller: sunxi dma probed
[ 0.294985] iommu: Default domain type: Translated
[ 0.300085] sunxi iommu: irq = 24
[ 0.306099] SCSI subsystem initialized
[ 0.310257] usbcore: registered new interface driver usbfs
[ 0.316263] usbcore: registered new interface driver hub
[ 0.321685] usbcore: registered new device driver usb
[ 0.327268] mc: Linux media interface: v0.10
[ 0.331602] videodev: Linux video capture interface: v2.00
[ 0.338442] Advanced Linux Sound Architecture Driver Initialized.
[ 0.345257] Bluetooth: Core ver 2.22
[ 0.348954] NET: Registered protocol family 31
[ 0.353393] Bluetooth: HCI device and connection manager initialized
[ 0.359768] Bluetooth: HCI socket layer initialized
[ 0.364653] Bluetooth: L2CAP socket layer initialized
[ 0.369723] Bluetooth: SCO socket layer initialized
[ 0.374922] pwm module init!
[ 0.379497] g2d 5410000.g2d: Adding to iommu group 0
[ 0.385013] G2D: rcq version initialized.major:250
[ 0.390560] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.398420] clocksource: Switched to clocksource arch_sys_counter
[ 0.414002] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 0.434292] thermal_sys: Registered thermal governor 'step_wise'
[ 0.434299] thermal_sys: Registered thermal governor 'user_space'
[ 0.440352] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.447044] NET: Registered protocol family 2
[ 0.458749] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.467120] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.474973] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.482229] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.488738] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.495407] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.502713] NET: Registered protocol family 1
[ 0.508247] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[ 0.516567] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.523363] sunxi_spi_resource_get()2259 - [spi0] SPI MASTER MODE
[ 0.529541] sunxi_spi_resource_get()2306 - sample_mode:1 sample_delay:29
[ 0.536268] sunxi_spi_request_dma()988 - [spi0] Request DMA channel dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
[ 0.547108] sunxi_spi_clk_init()2356 - [spi0] mclk 100000000
[ 0.553594] spi spi0: chipselect 0 already in use
[ 0.558318] spi_master spi0: spi_device register error /soc@3000000/spi@4025000/spi_board@0
[ 0.566722] spi_master spi0: Failed to create SPI device for /soc@3000000/spi@4025000/spi_board@0
[ 0.575640] sunxi_spi_probe()2809 - [spi0]: driver probe succeed, base f0862000, irq 42
[ 0.585767] Initialise system trusted keyrings
[ 0.590429] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[ 0.607542] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.613806] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.618578] fuse: init (API version 7.31)
[ 0.653292] NET: Registered protocol family 38
[ 0.657747] Key type asymmetric registered
[ 0.661893] Asymmetric key parser 'x509' registered
[ 0.666841] bounce: pool size: 64 pages
[ 0.670778] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.678176] io scheduler mq-deadline registered
[ 0.682722] io scheduler kyber registered
[ 0.686822] atomic64_test: passed
[ 0.691886] [DISP]disp_module_init
[ 0.695912] disp 5000000.disp: Adding to iommu group 0
[ 0.701733] [DISP] disp_init,line:2331:
[ 0.701739] smooth display screen:0 type:1 mode:4
[ 0.726812] display_fb_request,fb_id:0
[ 0.744264] disp_al_manager_apply ouput_type:1
[ 0.748941] [DISP] lcd_clk_config,line:777:
[ 0.748953] disp 0, clk: pll(360000000),clk(360000000),dclk(60000000) dsi_rate(60000000)
[ 0.748953] clk real:pll(360000000),clk(360000000),dclk(90000000) dsi_rate(150000000)
[ 0.749119] [DISP]disp_module_init finish
[ 0.753459] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[ 0.771772] sunxi_sid_init()783 - insmod ok
[ 0.783422] Freeing logo buffer memory: 3340K
[ 0.786543] pwm-regulator: supplied by regulator-dummy
[ 0.796911] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 0.805114] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.812350] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.820236] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
[ 0.828210] printk: console [ttyS0] enabled
[ 0.837122] printk: bootconsole [earlycon0] disabled
[ 0.848563] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 0.857670] uart uart1: uart1 supply uart not found, using dummy regulator
[ 0.865789] uart1: ttyS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
[ 0.875818] misc dump reg init
[ 0.879868] deinterlace 5400000.deinterlace: Adding to iommu group 0
[ 0.887560] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[ 0.896626] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 0.903943] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 0.911319] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 0.918775] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 0.925320] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 0.932290] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 0.940043] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 0.947903] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 0.956042] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 0.963748] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 0.970536] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 0.978079] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 0.986542] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[ 0.993837] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
[ 1.001728] [ADDR_MGT] addr_mgt_probe: success.
[ 1.008086] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
[ 1.015363] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.023343] sunxi-spinand-phy: not detect any munufacture from id table
[ 1.030793] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 1.037432] sunxi-spinand-phy: get phy info from fdt fail
[ 1.043500] sunxi-spinand-phy: not detect munufacture from fdt
[ 1.050168] sunxi-spinand-phy: detect munufacture from id table: Winbond
[ 1.057686] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[ 1.064737] sunxi-spinand-phy: ========== arch info ==========
[ 1.071292] sunxi-spinand-phy: Model: W25N01GVZEIG
[ 1.078030] sunxi-spinand-phy: Munufacture: Winbond
[ 1.084289] sunxi-spinand-phy: DieCntPerChip: 1
[ 1.089962] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 1.095917] sunxi-spinand-phy: PageCntPerBlk: 64
[ 1.101686] sunxi-spinand-phy: SectCntPerPage: 4
[ 1.107349] sunxi-spinand-phy: OobSizePerPage: 64
[ 1.113119] sunxi-spinand-phy: BadBlockFlag: 0x0
[ 1.118991] sunxi-spinand-phy: OperationOpt: 0x7
[ 1.124849] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 1.130912] sunxi-spinand-phy: EccFlag: 0x0
[ 1.136769] sunxi-spinand-phy: EccType: 2
[ 1.142441] sunxi-spinand-phy: EccProtectedType: 3
[ 1.148104] sunxi-spinand-phy: ========================================
[ 1.155530] sunxi-spinand-phy:
[ 1.159080] sunxi-spinand-phy: ========== physical info ==========
[ 1.166011] sunxi-spinand-phy: TotalSize: 128 M
[ 1.171405] sunxi-spinand-phy: SectorSize: 512 B
[ 1.176775] sunxi-spinand-phy: PageSize: 2 K
[ 1.181962] sunxi-spinand-phy: BlockSize: 128 K
[ 1.187333] sunxi-spinand-phy: OOBSize: 64 B
[ 1.192615] sunxi-spinand-phy: ========================================
[ 1.200041] sunxi-spinand-phy:
[ 1.203559] sunxi-spinand-phy: ========== logical info ==========
[ 1.210401] sunxi-spinand-phy: TotalSize: 128 M
[ 1.215771] sunxi-spinand-phy: SectorSize: 512 B
[ 1.221156] sunxi-spinand-phy: PageSize: 4 K
[ 1.226331] sunxi-spinand-phy: BlockSize: 256 K
[ 1.231712] sunxi-spinand-phy: OOBSize: 128 B
[ 1.237082] sunxi-spinand-phy: ========================================
[ 1.244594] sunxi-spinand-phy: block lock register: 0x00
[ 1.250671] sunxi-spinand-phy: feature register: 0x19
[ 1.256355] sunxi-spinand-phy: sunxi physic nand init end
[ 1.262922] Creating 4 MTD partitions on "sunxi_mtd_nand":
[ 1.269111] 0x000000000000-0x000000100000 : "boot0"
[ 1.279592] 0x000000100000-0x000000400000 : "uboot"
[ 1.285360] sunxi-spinand-phy: phy blk 9 is bad
[ 1.290817] sunxi-spinand-phy: phy blk 12 is bad
[ 1.296294] sunxi-spinand-phy: phy blk 16 is bad
[ 1.301753] sunxi-spinand-phy: phy blk 19 is bad
[ 1.307336] sunxi-spinand-phy: phy blk 23 is bad
[ 1.312960] sunxi-spinand-phy: phy blk 27 is bad
[ 1.318348] sunxi-spinand-phy: phy blk 29 is bad
[ 1.329573] 0x000000400000-0x000000500000 : "secure_storage"
[ 1.336171] sunxi-spinand-phy: phy blk 33 is bad
[ 1.349572] 0x000000500000-0x000008000000 : "sys"
[ 1.355078] sunxi-spinand-phy: phy blk 41 is bad
[ 1.360536] sunxi-spinand-phy: phy blk 43 is bad
[ 1.365911] sunxi-spinand-phy: phy blk 45 is bad
[ 1.371301] sunxi-spinand-phy: phy blk 47 is bad
[ 1.376665] sunxi-spinand-phy: phy blk 49 is bad
[ 1.382053] sunxi-spinand-phy: phy blk 51 is bad
[ 1.387255] random: fast init done
[ 1.391246] sunxi-spinand-phy: phy blk 53 is bad
[ 1.396611] sunxi-spinand-phy: phy blk 55 is bad
[ 1.402024] sunxi-spinand-phy: phy blk 57 is bad
[ 1.407390] sunxi-spinand-phy: phy blk 59 is bad
[ 1.412767] sunxi-spinand-phy: phy blk 61 is bad
[ 1.418132] sunxi-spinand-phy: phy blk 63 is bad
[ 1.423521] sunxi-spinand-phy: phy blk 65 is bad
[ 1.428906] sunxi-spinand-phy: phy blk 67 is bad
[ 1.434275] sunxi-spinand-phy: phy blk 69 is bad
[ 1.439674] sunxi-spinand-phy: phy blk 71 is bad
[ 1.445041] sunxi-spinand-phy: phy blk 73 is bad
[ 1.450464] sunxi-spinand-phy: phy blk 75 is bad
[ 1.455857] sunxi-spinand-phy: phy blk 77 is bad
[ 1.461289] sunxi-spinand-phy: phy blk 79 is bad
[ 1.466695] sunxi-spinand-phy: phy blk 81 is bad
[ 1.472122] sunxi-spinand-phy: phy blk 83 is bad
[ 1.477526] sunxi-spinand-phy: phy blk 85 is bad
[ 1.482952] sunxi-spinand-phy: phy blk 87 is bad
[ 1.488356] sunxi-spinand-phy: phy blk 89 is bad
[ 1.493780] sunxi-spinand-phy: phy blk 91 is bad
[ 1.499206] sunxi-spinand-phy: phy blk 93 is bad
[ 1.504611] sunxi-spinand-phy: phy blk 95 is bad
[ 1.510039] sunxi-spinand-phy: phy blk 97 is bad
[ 1.515445] sunxi-spinand-phy: phy blk 99 is bad
[ 1.520872] sunxi-spinand-phy: phy blk 101 is bad
[ 1.526374] sunxi-spinand-phy: phy blk 103 is bad
[ 1.531892] sunxi-spinand-phy: phy blk 105 is bad
[ 1.537394] sunxi-spinand-phy: phy blk 107 is bad
[ 1.542916] sunxi-spinand-phy: phy blk 109 is bad
[ 1.548434] sunxi-spinand-phy: phy blk 111 is bad
[ 1.553938] sunxi-spinand-phy: phy blk 113 is bad
[ 1.559459] sunxi-spinand-phy: phy blk 115 is bad
[ 1.564963] sunxi-spinand-phy: phy blk 117 is bad
[ 1.570487] sunxi-spinand-phy: phy blk 119 is bad
[ 1.575988] sunxi-spinand-phy: phy blk 121 is bad
[ 1.581513] sunxi-spinand-phy: phy blk 123 is bad
[ 1.587014] sunxi-spinand-phy: phy blk 125 is bad
[ 1.592538] sunxi-spinand-phy: phy blk 127 is bad
[ 1.598043] sunxi-spinand-phy: phy blk 129 is bad
[ 1.603566] sunxi-spinand-phy: phy blk 131 is bad
[ 1.609087] sunxi-spinand-phy: phy blk 133 is bad
[ 1.614591] sunxi-spinand-phy: phy blk 135 is bad
[ 1.620116] sunxi-spinand-phy: phy blk 137 is bad
[ 1.625618] sunxi-spinand-phy: phy blk 139 is bad
[ 1.631139] sunxi-spinand-phy: phy blk 141 is bad
[ 1.636641] sunxi-spinand-phy: phy blk 143 is bad
[ 1.642166] sunxi-spinand-phy: phy blk 145 is bad
[ 1.647671] sunxi-spinand-phy: phy blk 147 is bad
[ 1.653193] sunxi-spinand-phy: phy blk 149 is bad
[ 1.658716] sunxi-spinand-phy: phy blk 151 is bad
[ 1.664224] sunxi-spinand-phy: phy blk 153 is bad
[ 1.669746] sunxi-spinand-phy: phy blk 155 is bad
[ 1.675250] sunxi-spinand-phy: phy blk 157 is bad
[ 1.680773] sunxi-spinand-phy: phy blk 159 is bad
[ 1.686280] sunxi-spinand-phy: phy blk 161 is bad
[ 1.691804] sunxi-spinand-phy: phy blk 163 is bad
[ 1.697306] sunxi-spinand-phy: phy blk 165 is bad
[ 1.702830] sunxi-spinand-phy: phy blk 167 is bad
[ 1.708335] sunxi-spinand-phy: phy blk 169 is bad
[ 1.713853] sunxi-spinand-phy: phy blk 171 is bad
[ 1.719376] sunxi-spinand-phy: phy blk 173 is bad
[ 1.724877] sunxi-spinand-phy: phy blk 175 is bad
[ 1.730395] sunxi-spinand-phy: phy blk 177 is bad
[ 1.735897] sunxi-spinand-phy: phy blk 179 is bad
[ 1.741419] sunxi-spinand-phy: phy blk 181 is bad
[ 1.746919] sunxi-spinand-phy: phy blk 183 is bad
[ 1.752441] sunxi-spinand-phy: phy blk 185 is bad
[ 1.757943] sunxi-spinand-phy: phy blk 187 is bad
[ 1.763461] sunxi-spinand-phy: phy blk 189 is bad
[ 1.768983] sunxi-spinand-phy: phy blk 191 is bad
[ 1.774485] sunxi-spinand-phy: phy blk 193 is bad
[ 1.780009] sunxi-spinand-phy: phy blk 195 is bad
[ 1.785510] sunxi-spinand-phy: phy blk 197 is bad
[ 1.791033] sunxi-spinand-phy: phy blk 199 is bad
[ 1.796546] sunxi-spinand-phy: phy blk 201 is bad
[ 1.802069] sunxi-spinand-phy: phy blk 203 is bad
[ 1.807573] sunxi-spinand-phy: phy blk 205 is bad
[ 1.813098] sunxi-spinand-phy: phy blk 207 is bad
[ 1.818604] sunxi-spinand-phy: phy blk 209 is bad
[ 1.824107] sunxi-spinand-phy: phy blk 211 is bad
[ 1.829629] sunxi-spinand-phy: phy blk 213 is bad
[ 1.835135] sunxi-spinand-phy: phy blk 215 is bad
[ 1.840657] sunxi-spinand-phy: phy blk 217 is bad
[ 1.846161] sunxi-spinand-phy: phy blk 219 is bad
[ 1.851685] sunxi-spinand-phy: phy blk 221 is bad
[ 1.857187] sunxi-spinand-phy: phy blk 223 is bad
[ 1.862710] sunxi-spinand-phy: phy blk 225 is bad
[ 1.868213] sunxi-spinand-phy: phy blk 227 is bad
[ 1.873735] sunxi-spinand-phy: phy blk 229 is bad
[ 1.879260] sunxi-spinand-phy: phy blk 231 is bad
[ 1.884765] sunxi-spinand-phy: phy blk 233 is bad
[ 1.890288] sunxi-spinand-phy: phy blk 235 is bad
[ 1.895792] sunxi-spinand-phy: phy blk 237 is bad
[ 1.901317] sunxi-spinand-phy: phy blk 239 is bad
[ 1.906821] sunxi-spinand-phy: phy blk 241 is bad
[ 1.912345] sunxi-spinand-phy: phy blk 243 is bad
[ 1.917848] sunxi-spinand-phy: phy blk 245 is bad
[ 1.923371] sunxi-spinand-phy: phy blk 247 is bad
[ 1.928895] sunxi-spinand-phy: phy blk 249 is bad
[ 1.934399] sunxi-spinand-phy: phy blk 251 is bad
[ 1.939923] sunxi-spinand-phy: phy blk 253 is bad
[ 1.945427] sunxi-spinand-phy: phy blk 255 is bad
[ 1.950949] sunxi-spinand-phy: phy blk 257 is bad
[ 1.956450] sunxi-spinand-phy: phy blk 259 is bad
[ 1.961976] sunxi-spinand-phy: phy blk 261 is bad
[ 1.967480] sunxi-spinand-phy: phy blk 263 is bad
[ 1.973004] sunxi-spinand-phy: phy blk 265 is bad
[ 1.978532] sunxi-spinand-phy: phy blk 267 is bad
[ 1.984037] sunxi-spinand-phy: phy blk 269 is bad
[ 1.989561] sunxi-spinand-phy: phy blk 271 is bad
[ 1.995065] sunxi-spinand-phy: phy blk 273 is bad
[ 2.000589] sunxi-spinand-phy: phy blk 275 is bad
[ 2.006092] sunxi-spinand-phy: phy blk 277 is bad
[ 2.011613] sunxi-spinand-phy: phy blk 279 is bad
[ 2.017117] sunxi-spinand-phy: phy blk 281 is bad
[ 2.022639] sunxi-spinand-phy: phy blk 283 is bad
[ 2.028142] sunxi-spinand-phy: phy blk 285 is bad
[ 2.033663] sunxi-spinand-phy: phy blk 287 is bad
[ 2.039189] sunxi-spinand-phy: phy blk 289 is bad
[ 2.044691] sunxi-spinand-phy: phy blk 291 is bad
[ 2.050215] sunxi-spinand-phy: phy blk 293 is bad
[ 2.055718] sunxi-spinand-phy: phy blk 295 is bad
[ 2.061240] sunxi-spinand-phy: phy blk 297 is bad
[ 2.066742] sunxi-spinand-phy: phy blk 299 is bad
[ 2.072266] sunxi-spinand-phy: phy blk 301 is bad
[ 2.077769] sunxi-spinand-phy: phy blk 303 is bad
[ 2.083292] sunxi-spinand-phy: phy blk 305 is bad
[ 2.088818] sunxi-spinand-phy: phy blk 307 is bad
[ 2.094320] sunxi-spinand-phy: phy blk 309 is bad
[ 2.099841] sunxi-spinand-phy: phy blk 311 is bad
[ 2.105342] sunxi-spinand-phy: phy blk 313 is bad
[ 2.110864] sunxi-spinand-phy: phy blk 315 is bad
[ 2.116368] sunxi-spinand-phy: phy blk 317 is bad
[ 2.121925] sunxi-spinand-phy: phy blk 319 is bad
[ 2.127427] sunxi-spinand-phy: phy blk 321 is bad
[ 2.132950] sunxi-spinand-phy: phy blk 323 is bad
[ 2.138462] sunxi-spinand-phy: phy blk 325 is bad
[ 2.143967] sunxi-spinand-phy: phy blk 327 is bad
[ 2.149493] sunxi-spinand-phy: phy blk 329 is bad
[ 2.154996] sunxi-spinand-phy: phy blk 331 is bad
[ 2.160519] sunxi-spinand-phy: phy blk 333 is bad
[ 2.166022] sunxi-spinand-phy: phy blk 335 is bad
[ 2.171544] sunxi-spinand-phy: phy blk 337 is bad
[ 2.177046] sunxi-spinand-phy: phy blk 339 is bad
[ 2.182568] sunxi-spinand-phy: phy blk 341 is bad
[ 2.188072] sunxi-spinand-phy: phy blk 343 is bad
[ 2.193594] sunxi-spinand-phy: phy blk 345 is bad
[ 2.199118] sunxi-spinand-phy: phy blk 347 is bad
[ 2.204622] sunxi-spinand-phy: phy blk 349 is bad
[ 2.210145] sunxi-spinand-phy: phy blk 351 is bad
[ 2.215650] sunxi-spinand-phy: phy blk 353 is bad
[ 2.221175] sunxi-spinand-phy: phy blk 355 is bad
[ 2.226679] sunxi-spinand-phy: phy blk 357 is bad
[ 2.232199] sunxi-spinand-phy: phy blk 359 is bad
[ 2.237705] sunxi-spinand-phy: phy blk 361 is bad
[ 2.243228] sunxi-spinand-phy: phy blk 363 is bad
[ 2.248749] sunxi-spinand-phy: phy blk 365 is bad
[ 2.254252] sunxi-spinand-phy: phy blk 367 is bad
[ 2.259778] sunxi-spinand-phy: phy blk 369 is bad
[ 2.265282] sunxi-spinand-phy: phy blk 371 is bad
[ 2.270806] sunxi-spinand-phy: phy blk 373 is bad
[ 2.276307] sunxi-spinand-phy: phy blk 375 is bad
[ 2.281832] sunxi-spinand-phy: phy blk 377 is bad
[ 2.287337] sunxi-spinand-phy: phy blk 379 is bad
[ 2.292860] sunxi-spinand-phy: phy blk 381 is bad
[ 2.298364] sunxi-spinand-phy: phy blk 383 is bad
[ 2.303890] sunxi-spinand-phy: phy blk 385 is bad
[ 2.309411] sunxi-spinand-phy: phy blk 387 is bad
[ 2.314913] sunxi-spinand-phy: phy blk 389 is bad
[ 2.320435] sunxi-spinand-phy: phy blk 391 is bad
[ 2.325939] sunxi-spinand-phy: phy blk 393 is bad
[ 2.331457] sunxi-spinand-phy: phy blk 395 is bad
[ 2.336959] sunxi-spinand-phy: phy blk 397 is bad
[ 2.342483] sunxi-spinand-phy: phy blk 399 is bad
[ 2.347985] sunxi-spinand-phy: phy blk 401 is bad
[ 2.353508] sunxi-spinand-phy: phy blk 403 is bad
[ 2.359032] sunxi-spinand-phy: phy blk 405 is bad
[ 2.364534] sunxi-spinand-phy: phy blk 407 is bad
[ 2.370055] sunxi-spinand-phy: phy blk 409 is bad
[ 2.375556] sunxi-spinand-phy: phy blk 411 is bad
[ 2.381081] sunxi-spinand-phy: phy blk 413 is bad
[ 2.386582] sunxi-spinand-phy: phy blk 415 is bad
[ 2.392103] sunxi-spinand-phy: phy blk 417 is bad
[ 2.397605] sunxi-spinand-phy: phy blk 419 is bad
[ 2.403126] sunxi-spinand-phy: phy blk 421 is bad
[ 2.408649] sunxi-spinand-phy: phy blk 423 is bad
[ 2.414150] sunxi-spinand-phy: phy blk 425 is bad
[ 2.419672] sunxi-spinand-phy: phy blk 427 is bad
[ 2.425173] sunxi-spinand-phy: phy blk 429 is bad
[ 2.430697] sunxi-spinand-phy: phy blk 431 is bad
[ 2.436200] sunxi-spinand-phy: phy blk 433 is bad
[ 2.441722] sunxi-spinand-phy: phy blk 435 is bad
[ 2.447225] sunxi-spinand-phy: phy blk 437 is bad
[ 2.452748] sunxi-spinand-phy: phy blk 439 is bad
[ 2.458251] sunxi-spinand-phy: phy blk 441 is bad
[ 2.463770] sunxi-spinand-phy: phy blk 443 is bad
[ 2.469294] sunxi-spinand-phy: phy blk 445 is bad
[ 2.474796] sunxi-spinand-phy: phy blk 447 is bad
[ 2.480320] sunxi-spinand-phy: phy blk 449 is bad
[ 2.485823] sunxi-spinand-phy: phy blk 451 is bad
[ 2.491344] sunxi-spinand-phy: phy blk 453 is bad
[ 2.496848] sunxi-spinand-phy: phy blk 455 is bad
[ 2.502370] sunxi-spinand-phy: phy blk 457 is bad
[ 2.507873] sunxi-spinand-phy: phy blk 459 is bad
[ 2.513392] sunxi-spinand-phy: phy blk 461 is bad
[ 2.518914] sunxi-spinand-phy: phy blk 463 is bad
[ 2.524417] sunxi-spinand-phy: phy blk 465 is bad
[ 2.529940] sunxi-spinand-phy: phy blk 467 is bad
[ 2.535443] sunxi-spinand-phy: phy blk 469 is bad
[ 2.540964] sunxi-spinand-phy: phy blk 471 is bad
[ 2.546468] sunxi-spinand-phy: phy blk 473 is bad
[ 2.551990] sunxi-spinand-phy: phy blk 475 is bad
[ 2.557492] sunxi-spinand-phy: phy blk 477 is bad
[ 2.563013] sunxi-spinand-phy: phy blk 479 is bad
[ 2.568536] sunxi-spinand-phy: phy blk 481 is bad
[ 2.574038] sunxi-spinand-phy: phy blk 483 is bad
[ 2.579563] sunxi-spinand-phy: phy blk 485 is bad
[ 2.585065] sunxi-spinand-phy: phy blk 487 is bad
[ 2.590589] sunxi-spinand-phy: phy blk 489 is bad
[ 2.596092] sunxi-spinand-phy: phy blk 491 is bad
[ 2.601615] sunxi-spinand-phy: phy blk 493 is bad
[ 2.607117] sunxi-spinand-phy: phy blk 495 is bad
[ 2.612638] sunxi-spinand-phy: phy blk 497 is bad
[ 2.618140] sunxi-spinand-phy: phy blk 499 is bad
[ 2.623663] sunxi-spinand-phy: phy blk 501 is bad
[ 2.629187] sunxi-spinand-phy: phy blk 503 is bad
[ 2.634691] sunxi-spinand-phy: phy blk 505 is bad
[ 2.640215] sunxi-spinand-phy: phy blk 507 is bad
[ 2.645720] sunxi-spinand-phy: phy blk 509 is bad
[ 2.651242] sunxi-spinand-phy: phy blk 511 is bad
[ 2.656746] sunxi-spinand-phy: phy blk 513 is bad
[ 2.662267] sunxi-spinand-phy: phy blk 515 is bad
[ 2.667771] sunxi-spinand-phy: phy blk 517 is bad
[ 2.673292] sunxi-spinand-phy: phy blk 519 is bad
[ 2.678820] sunxi-spinand-phy: phy blk 521 is bad
[ 2.684323] sunxi-spinand-phy: phy blk 523 is bad
[ 2.689846] sunxi-spinand-phy: phy blk 525 is bad
[ 2.695350] sunxi-spinand-phy: phy blk 527 is bad
[ 2.700873] sunxi-spinand-phy: phy blk 529 is bad
[ 2.706378] sunxi-spinand-phy: phy blk 531 is bad
[ 2.711899] sunxi-spinand-phy: phy blk 533 is bad
[ 2.717402] sunxi-spinand-phy: phy blk 535 is bad
[ 2.722925] sunxi-spinand-phy: phy blk 537 is bad
[ 2.728447] sunxi-spinand-phy: phy blk 539 is bad
[ 2.733953] sunxi-spinand-phy: phy blk 541 is bad
[ 2.739478] sunxi-spinand-phy: phy blk 543 is bad
[ 2.744982] sunxi-spinand-phy: phy blk 545 is bad
[ 2.750508] sunxi-spinand-phy: phy blk 547 is bad
[ 2.756009] sunxi-spinand-phy: phy blk 549 is bad
[ 2.761530] sunxi-spinand-phy: phy blk 551 is bad
[ 2.767034] sunxi-spinand-phy: phy blk 553 is bad
[ 2.772558] sunxi-spinand-phy: phy blk 555 is bad
[ 2.778062] sunxi-spinand-phy: phy blk 557 is bad
[ 2.783590] sunxi-spinand-phy: phy blk 559 is bad
[ 2.789114] sunxi-spinand-phy: phy blk 561 is bad
[ 2.794619] sunxi-spinand-phy: phy blk 563 is bad
[ 2.800142] sunxi-spinand-phy: phy blk 565 is bad
[ 2.805646] sunxi-spinand-phy: phy blk 567 is bad
[ 2.811166] sunxi-spinand-phy: phy blk 569 is bad
[ 2.816671] sunxi-spinand-phy: phy blk 571 is bad
[ 2.822195] sunxi-spinand-phy: phy blk 573 is bad
[ 2.827698] sunxi-spinand-phy: phy blk 575 is bad
[ 2.833222] sunxi-spinand-phy: phy blk 577 is bad
[ 2.838744] sunxi-spinand-phy: phy blk 579 is bad
[ 2.844248] sunxi-spinand-phy: phy blk 581 is bad
[ 2.849772] sunxi-spinand-phy: phy blk 583 is bad
[ 2.855274] sunxi-spinand-phy: phy blk 585 is bad
[ 2.860793] sunxi-spinand-phy: phy blk 587 is bad
[ 2.866296] sunxi-spinand-phy: phy blk 589 is bad
[ 2.871820] sunxi-spinand-phy: phy blk 591 is bad
[ 2.877324] sunxi-spinand-phy: phy blk 593 is bad
[ 2.882850] sunxi-spinand-phy: phy blk 595 is bad
[ 2.888354] sunxi-spinand-phy: phy blk 597 is bad
[ 2.893877] sunxi-spinand-phy: phy blk 599 is bad
[ 2.899404] sunxi-spinand-phy: phy blk 601 is bad
[ 2.904906] sunxi-spinand-phy: phy blk 603 is bad
[ 2.910429] sunxi-spinand-phy: phy blk 605 is bad
[ 2.915933] sunxi-spinand-phy: phy blk 607 is bad
[ 2.921458] sunxi-spinand-phy: phy blk 609 is bad
[ 2.926961] sunxi-spinand-phy: phy blk 611 is bad
[ 2.932484] sunxi-spinand-phy: phy blk 613 is bad
[ 2.937985] sunxi-spinand-phy: phy blk 615 is bad
[ 2.943507] sunxi-spinand-phy: phy blk 617 is bad
[ 2.949027] sunxi-spinand-phy: phy blk 619 is bad
[ 2.954527] sunxi-spinand-phy: phy blk 621 is bad
[ 2.960048] sunxi-spinand-phy: phy blk 623 is bad
[ 2.965550] sunxi-spinand-phy: phy blk 625 is bad
[ 2.971073] sunxi-spinand-phy: phy blk 627 is bad
[ 2.976575] sunxi-spinand-phy: phy blk 629 is bad
[ 2.982102] sunxi-spinand-phy: phy blk 631 is bad
[ 2.987605] sunxi-spinand-phy: phy blk 633 is bad
[ 2.993128] sunxi-spinand-phy: phy blk 635 is bad
[ 2.998651] sunxi-spinand-phy: phy blk 637 is bad
[ 3.004152] sunxi-spinand-phy: phy blk 639 is bad
[ 3.009674] sunxi-spinand-phy: phy blk 641 is bad
[ 3.015176] sunxi-spinand-phy: phy blk 643 is bad
[ 3.020697] sunxi-spinand-phy: phy blk 645 is bad
[ 3.026200] sunxi-spinand-phy: phy blk 647 is bad
[ 3.031725] sunxi-spinand-phy: phy blk 649 is bad
[ 3.037226] sunxi-spinand-phy: phy blk 651 is bad
[ 3.042748] sunxi-spinand-phy: phy blk 653 is bad
[ 3.048250] sunxi-spinand-phy: phy blk 655 is bad
[ 3.053774] sunxi-spinand-phy: phy blk 657 is bad
[ 3.059295] sunxi-spinand-phy: phy blk 659 is bad
[ 3.064797] sunxi-spinand-phy: phy blk 661 is bad
[ 3.070318] sunxi-spinand-phy: phy blk 663 is bad
[ 3.075820] sunxi-spinand-phy: phy blk 665 is bad
[ 3.081367] sunxi-spinand-phy: phy blk 667 is bad
[ 3.086869] sunxi-spinand-phy: phy blk 669 is bad
[ 3.092393] sunxi-spinand-phy: phy blk 671 is bad
[ 3.097895] sunxi-spinand-phy: phy blk 673 is bad
[ 3.103418] sunxi-spinand-phy: phy blk 675 is bad
[ 3.108938] sunxi-spinand-phy: phy blk 677 is bad
[ 3.114440] sunxi-spinand-phy: phy blk 679 is bad
[ 3.119962] sunxi-spinand-phy: phy blk 681 is bad
[ 3.125464] sunxi-spinand-phy: phy blk 683 is bad
[ 3.130987] sunxi-spinand-phy: phy blk 685 is bad
[ 3.136488] sunxi-spinand-phy: phy blk 687 is bad
[ 3.142009] sunxi-spinand-phy: phy blk 689 is bad
[ 3.147510] sunxi-spinand-phy: phy blk 691 is bad
[ 3.153033] sunxi-spinand-phy: phy blk 693 is bad
[ 3.158534] sunxi-spinand-phy: phy blk 695 is bad
[ 3.164036] sunxi-spinand-phy: phy blk 697 is bad
[ 3.169559] sunxi-spinand-phy: phy blk 699 is bad
[ 3.175059] sunxi-spinand-phy: phy blk 701 is bad
[ 3.180586] sunxi-spinand-phy: phy blk 703 is bad
[ 3.186088] sunxi-spinand-phy: phy blk 705 is bad
[ 3.191608] sunxi-spinand-phy: phy blk 707 is bad
[ 3.197110] sunxi-spinand-phy: phy blk 709 is bad
[ 3.202632] sunxi-spinand-phy: phy blk 711 is bad
[ 3.208133] sunxi-spinand-phy: phy blk 713 is bad
[ 3.213652] sunxi-spinand-phy: phy blk 715 is bad
[ 3.219175] sunxi-spinand-phy: phy blk 717 is bad
[ 3.224676] sunxi-spinand-phy: phy blk 719 is bad
[ 3.230198] sunxi-spinand-phy: phy blk 721 is bad
[ 3.235700] sunxi-spinand-phy: phy blk 723 is bad
[ 3.241222] sunxi-spinand-phy: phy blk 725 is bad
[ 3.246724] sunxi-spinand-phy: phy blk 727 is bad
[ 3.252246] sunxi-spinand-phy: phy blk 729 is bad
[ 3.257747] sunxi-spinand-phy: phy blk 731 is bad
[ 3.263266] sunxi-spinand-phy: phy blk 733 is bad
[ 3.268788] sunxi-spinand-phy: phy blk 735 is bad
[ 3.274289] sunxi-spinand-phy: phy blk 737 is bad
[ 3.279814] sunxi-spinand-phy: phy blk 739 is bad
[ 3.285318] sunxi-spinand-phy: phy blk 741 is bad
[ 3.290840] sunxi-spinand-phy: phy blk 743 is bad
[ 3.296341] sunxi-spinand-phy: phy blk 745 is bad
[ 3.301863] sunxi-spinand-phy: phy blk 747 is bad
[ 3.307364] sunxi-spinand-phy: phy blk 749 is bad
[ 3.312884] sunxi-spinand-phy: phy blk 751 is bad
[ 3.318383] sunxi-spinand-phy: phy blk 753 is bad
[ 3.323904] sunxi-spinand-phy: phy blk 755 is bad
[ 3.329427] sunxi-spinand-phy: phy blk 757 is bad
[ 3.334927] sunxi-spinand-phy: phy blk 759 is bad
[ 3.340448] sunxi-spinand-phy: phy blk 761 is bad
[ 3.345950] sunxi-spinand-phy: phy blk 763 is bad
[ 3.351473] sunxi-spinand-phy: phy blk 765 is bad
[ 3.356974] sunxi-spinand-phy: phy blk 767 is bad
[ 3.362494] sunxi-spinand-phy: phy blk 769 is bad
[ 3.367996] sunxi-spinand-phy: phy blk 771 is bad
[ 3.373517] sunxi-spinand-phy: phy blk 773 is bad
[ 3.379041] sunxi-spinand-phy: phy blk 775 is bad
[ 3.384542] sunxi-spinand-phy: phy blk 777 is bad
[ 3.390065] sunxi-spinand-phy: phy blk 779 is bad
[ 3.395567] sunxi-spinand-phy: phy blk 781 is bad
[ 3.401089] sunxi-spinand-phy: phy blk 783 is bad
[ 3.406590] sunxi-spinand-phy: phy blk 785 is bad
[ 3.412109] sunxi-spinand-phy: phy blk 787 is bad
[ 3.417610] sunxi-spinand-phy: phy blk 789 is bad
[ 3.423131] sunxi-spinand-phy: phy blk 791 is bad
[ 3.428652] sunxi-spinand-phy: phy blk 793 is bad
[ 3.434155] sunxi-spinand-phy: phy blk 795 is bad
[ 3.439676] sunxi-spinand-phy: phy blk 797 is bad
[ 3.445176] sunxi-spinand-phy: phy blk 799 is bad
[ 3.450697] sunxi-spinand-phy: phy blk 801 is bad
[ 3.456200] sunxi-spinand-phy: phy blk 803 is bad
[ 3.461720] sunxi-spinand-phy: phy blk 805 is bad
[ 3.467221] sunxi-spinand-phy: phy blk 807 is bad
[ 3.472742] sunxi-spinand-phy: phy blk 809 is bad
[ 3.478244] sunxi-spinand-phy: phy blk 811 is bad
[ 3.483769] sunxi-spinand-phy: phy blk 813 is bad
[ 3.489291] sunxi-spinand-phy: phy blk 815 is bad
[ 3.494793] sunxi-spinand-phy: phy blk 817 is bad
[ 3.500316] sunxi-spinand-phy: phy blk 819 is bad
[ 3.505818] sunxi-spinand-phy: phy blk 821 is bad
[ 3.511336] sunxi-spinand-phy: phy blk 823 is bad
[ 3.516837] sunxi-spinand-phy: phy blk 825 is bad
[ 3.522359] sunxi-spinand-phy: phy blk 827 is bad
[ 3.527861] sunxi-spinand-phy: phy blk 829 is bad
[ 3.533383] sunxi-spinand-phy: phy blk 831 is bad
[ 3.538903] sunxi-spinand-phy: phy blk 833 is bad
[ 3.544404] sunxi-spinand-phy: phy blk 835 is bad
[ 3.549925] sunxi-spinand-phy: phy blk 837 is bad
[ 3.555428] sunxi-spinand-phy: phy blk 839 is bad
[ 3.560945] sunxi-spinand-phy: phy blk 841 is bad
[ 3.566447] sunxi-spinand-phy: phy blk 843 is bad
[ 3.571969] sunxi-spinand-phy: phy blk 845 is bad
[ 3.577470] sunxi-spinand-phy: phy blk 847 is bad
[ 3.582994] sunxi-spinand-phy: phy blk 849 is bad
[ 3.588519] sunxi-spinand-phy: phy blk 851 is bad
[ 3.594021] sunxi-spinand-phy: phy blk 853 is bad
[ 3.599540] sunxi-spinand-phy: phy blk 855 is bad
[ 3.605041] sunxi-spinand-phy: phy blk 857 is bad
[ 3.610560] sunxi-spinand-phy: phy blk 859 is bad
[ 3.616060] sunxi-spinand-phy: phy blk 861 is bad
[ 3.621582] sunxi-spinand-phy: phy blk 863 is bad
[ 3.627085] sunxi-spinand-phy: phy blk 865 is bad
[ 3.632606] sunxi-spinand-phy: phy blk 867 is bad
[ 3.638107] sunxi-spinand-phy: phy blk 869 is bad
[ 3.643625] sunxi-spinand-phy: phy blk 871 is bad
[ 3.649148] sunxi-spinand-phy: phy blk 873 is bad
[ 3.654650] sunxi-spinand-phy: phy blk 875 is bad
[ 3.660169] sunxi-spinand-phy: phy blk 877 is bad
[ 3.665669] sunxi-spinand-phy: phy blk 879 is bad
[ 3.671191] sunxi-spinand-phy: phy blk 881 is bad
[ 3.676694] sunxi-spinand-phy: phy blk 883 is bad
[ 3.682218] sunxi-spinand-phy: phy blk 885 is bad
[ 3.687718] sunxi-spinand-phy: phy blk 887 is bad
[ 3.693237] sunxi-spinand-phy: phy blk 889 is bad
[ 3.698758] sunxi-spinand-phy: phy blk 891 is bad
[ 3.704259] sunxi-spinand-phy: phy blk 893 is bad
[ 3.709780] sunxi-spinand-phy: phy blk 895 is bad
[ 3.715282] sunxi-spinand-phy: phy blk 897 is bad
[ 3.720803] sunxi-spinand-phy: phy blk 899 is bad
[ 3.726305] sunxi-spinand-phy: phy blk 901 is bad
[ 3.731827] sunxi-spinand-phy: phy blk 903 is bad
[ 3.737328] sunxi-spinand-phy: phy blk 905 is bad
[ 3.742844] sunxi-spinand-phy: phy blk 907 is bad
[ 3.748345] sunxi-spinand-phy: phy blk 909 is bad
[ 3.753864] sunxi-spinand-phy: phy blk 911 is bad
[ 3.759386] sunxi-spinand-phy: phy blk 913 is bad
[ 3.764887] sunxi-spinand-phy: phy blk 915 is bad
[ 3.770408] sunxi-spinand-phy: phy blk 917 is bad
[ 3.775910] sunxi-spinand-phy: phy blk 919 is bad
[ 3.781435] sunxi-spinand-phy: phy blk 921 is bad
[ 3.786935] sunxi-spinand-phy: phy blk 923 is bad
[ 3.792454] sunxi-spinand-phy: phy blk 925 is bad
[ 3.797956] sunxi-spinand-phy: phy blk 927 is bad
[ 3.803479] sunxi-spinand-phy: phy blk 929 is bad
[ 3.809001] sunxi-spinand-phy: phy blk 931 is bad
[ 3.814502] sunxi-spinand-phy: phy blk 933 is bad
[ 3.820024] sunxi-spinand-phy: phy blk 935 is bad
[ 3.825525] sunxi-spinand-phy: phy blk 937 is bad
[ 3.831046] sunxi-spinand-phy: phy blk 939 is bad
[ 3.836546] sunxi-spinand-phy: phy blk 941 is bad
[ 3.842066] sunxi-spinand-phy: phy blk 943 is bad
[ 3.847567] sunxi-spinand-phy: phy blk 945 is bad
[ 3.853089] sunxi-spinand-phy: phy blk 947 is bad
[ 3.858575] sunxi-spinand-phy: phy blk 949 is bad
[ 3.864079] sunxi-spinand-phy: phy blk 951 is bad
[ 3.869599] sunxi-spinand-phy: phy blk 953 is bad
[ 3.875100] sunxi-spinand-phy: phy blk 955 is bad
[ 3.880623] sunxi-spinand-phy: phy blk 957 is bad
[ 3.886127] sunxi-spinand-phy: phy blk 959 is bad
[ 3.891645] sunxi-spinand-phy: phy blk 961 is bad
[ 3.897145] sunxi-spinand-phy: phy blk 963 is bad
[ 3.902667] sunxi-spinand-phy: phy blk 965 is bad
[ 3.908170] sunxi-spinand-phy: phy blk 967 is bad
[ 3.913690] sunxi-spinand-phy: phy blk 969 is bad
[ 3.919212] sunxi-spinand-phy: phy blk 971 is bad
[ 3.924714] sunxi-spinand-phy: phy blk 973 is bad
[ 3.930237] sunxi-spinand-phy: phy blk 975 is bad
[ 3.935738] sunxi-spinand-phy: phy blk 977 is bad
[ 3.941279] sunxi-spinand-phy: phy blk 979 is bad
[ 3.946781] sunxi-spinand-phy: phy blk 981 is bad
[ 3.952304] sunxi-spinand-phy: phy blk 983 is bad
[ 3.957801] sunxi-spinand-phy: phy blk 985 is bad
[ 3.963325] sunxi-spinand-phy: phy blk 987 is bad
[ 3.968847] sunxi-spinand-phy: phy blk 989 is bad
[ 3.974348] sunxi-spinand-phy: phy blk 991 is bad
[ 3.979873] sunxi-spinand-phy: phy blk 993 is bad
[ 3.985374] sunxi-spinand-phy: phy blk 995 is bad
[ 3.990897] sunxi-spinand-phy: phy blk 997 is bad
[ 3.996401] sunxi-spinand-phy: phy blk 999 is bad
[ 4.001923] sunxi-spinand-phy: phy blk 1001 is bad
[ 4.007521] sunxi-spinand-phy: phy blk 1003 is bad
[ 4.013141] sunxi-spinand-phy: phy blk 1005 is bad
[ 4.018760] sunxi-spinand-phy: phy blk 1007 is bad
[ 4.024357] sunxi-spinand-phy: phy blk 1009 is bad
[ 4.029976] sunxi-spinand-phy: phy blk 1011 is bad
[ 4.035575] sunxi-spinand-phy: phy blk 1013 is bad
[ 4.041189] sunxi-spinand-phy: phy blk 1015 is bad
[ 4.046786] sunxi-spinand-phy: phy blk 1017 is bad
[ 4.052405] sunxi-spinand-phy: phy blk 1019 is bad
[ 4.058003] sunxi-spinand-phy: phy blk 1021 is bad
[ 4.063624] sunxi-spinand-phy: phy blk 1023 is bad
[ 4.080333] libphy: Fixed MDIO Bus: probed
[ 4.084941] CAN device driver interface
[ 4.089851] sunxi-can can@0x0 (unnamed net_device) (uninitialized): request pinctrl handle fail!
[ 4.100486] sunxi-can can@0x0: can driver probe ok ...
[ 4.106590] sunxi-can can@0x1 (unnamed net_device) (uninitialized): request pinctrl handle fail!
[ 4.117134] sunxi-can can@0x1: can driver probe ok ...
[ 4.123882] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[ 4.133125] gmac-power0: NULL
[ 4.136457] gmac-power1: NULL
[ 4.139814] gmac-power2: NULL
[ 4.144331] Failed to alloc md5
[ 4.147867] eth0: Use random mac address
[ 4.152925] usbcore: registered new interface driver asix
[ 4.159143] usbcore: registered new interface driver ax88179_178a
[ 4.166045] usbcore: registered new interface driver cdc_ether
[ 4.172696] usbcore: registered new interface driver net1080
[ 4.179138] usbcore: registered new interface driver cdc_subset
[ 4.185841] usbcore: registered new interface driver zaurus
[ 4.192223] usbcore: registered new interface driver cdc_ncm
[ 4.198597] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.205918] sunxi-ehci: EHCI SUNXI driver
[ 4.210931] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.217895] sunxi-ohci: OHCI SUNXI driver
[ 4.223113] usbcore: registered new interface driver uas
[ 4.229224] usbcore: registered new interface driver usb-storage
[ 4.236023] usbcore: registered new interface driver ums-alauda
[ 4.242889] usbcore: registered new interface driver ums-cypress
[ 4.249734] usbcore: registered new interface driver ums-datafab
[ 4.256547] usbcore: registered new interface driver ums_eneub6250
[ 4.263571] usbcore: registered new interface driver ums-freecom
[ 4.270392] usbcore: registered new interface driver ums-isd200
[ 4.277092] usbcore: registered new interface driver ums-jumpshot
[ 4.284022] usbcore: registered new interface driver ums-karma
[ 4.290650] usbcore: registered new interface driver ums-onetouch
[ 4.297579] usbcore: registered new interface driver ums-realtek
[ 4.304397] usbcore: registered new interface driver ums-sddr09
[ 4.311124] usbcore: registered new interface driver ums-sddr55
[ 4.317818] usbcore: registered new interface driver ums-usbat
[ 4.325481] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 4.335437] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[ 4.347673] sunxi-rtc 7090000.rtc: registered as rtc0
[ 4.353530] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:08 UTC (8)
[ 4.362479] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 4.368605] i2c /dev entries driver
[ 4.372802] IR NEC protocol handler initialized
[ 4.377887] IR RC5(x/sz) protocol handler initialized
[ 4.384269] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
[ 4.394463] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
[ 4.404248] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
[ 4.413935] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
[ 4.425791] usbcore: registered new interface driver uvcvideo
[ 4.432273] USB Video Class driver (1.1.1)
[ 4.436867] gspca_main: v2.14.0 registered
[ 4.441472] sunxi cedar version 1.1
[ 4.445608] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 4.451963] VE: sunxi_cedar_probe power-domain init!!!
[ 4.457725] VE: install start!!!
[ 4.457725]
[ 4.463331] VE: cedar-ve the get irq is 43
[ 4.463331]
[ 4.469850] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 4.469850]
[ 4.479157] VE: install end!!!
[ 4.479157]
[ 4.484238] VE: sunxi_cedar_probe
[ 4.489529] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 4.498823] Bluetooth: HCI UART driver ver 2.3
[ 4.503816] Bluetooth: HCI UART protocol H4 registered
[ 4.509892] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 4.517175] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 4.523697] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 4.530292] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 4.530292]
[ 4.539044] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 4.548479] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 4.558500] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 4.564718] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 4.571092] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 4.577555] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 4.584027] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 4.590597] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 4.597143] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 4.603701] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 4.610799] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 4.616517] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.627792] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 4.647966] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.672246] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
[ 4.678345] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 4.690081] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 4.700023] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 4.706238] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 4.712611] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 4.719070] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 4.725515] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 4.732068] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 4.738624] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 4.745169] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 4.751749] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 4.761261] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.772461] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 4.792625] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.816886] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 4.824586] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 4.824924] usbcore: registered new interface driver usbhid
[ 4.837747] usbhid: USB HID core driver
[ 4.838554] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 4.842082] exFAT: Version 1.3.0
[ 4.852527] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.859050] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ...
[ 4.871853] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok...
[ 4.872787] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.880172] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver 2.1.2
[ 4.898015] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.904808] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.911578] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.918372] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.918401] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 4.925195] sunxi-rproc 3000008.dsp_rproc: failed to get firmware-name
[ 4.944151] remoteproc remoteproc0: dsp_rproc is available
[ 4.950418] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver probe ok
[ 4.958891] sunxi-rpbuf-controller rpbuf_controller@0: assigned reserved memory node dsp0_rpbuf@42244000
[ 4.969826] sunxi-rpbuf-controller rpbuf_controller@0: rpbuf_register_ctrl_dev:827
[ 4.982409] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 4.982409]
[ 4.999667] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 5.011120] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
[ 5.020565] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 5.030459] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 5.037770] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 5.049008] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input2
[ 5.061223] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 5.070161] NET: Registered protocol family 10
[ 5.076364] Segment Routing with IPv6
[ 5.080706] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 5.088483] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[ 5.089431] NET: Registered protocol family 17
[ 5.100965] NET: Registered protocol family 15
[ 5.105951] can: controller area network core (rev 20170425 abi 9)
[ 5.113023] NET: Registered protocol family 29
[ 5.118016] can: raw protocol (rev 20170425)
[ 5.122830] can: broadcast manager protocol (rev 20170425 t)
[ 5.129201] can: netlink gateway (rev 20190810) max_hops=1
[ 5.135804] Bluetooth: RFCOMM TTY layer initialized
[ 5.141342] Bluetooth: RFCOMM socket layer initialized
[ 5.147135] Bluetooth: RFCOMM ver 1.11
[ 5.152355] Registering SWP/SWPB emulation handler
[ 5.158109] Loading compiled-in X.509 certificates
[ 5.182638] sunxi-i2c 2502800.twi: 2502800.twi supply twi not found, using dummy regulator
[ 5.193487] sunxi-i2c 2502800.twi: probe success
[ 5.200687] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
[ 5.239937] get drvvbus-en is fail, 22
[ 5.244145] get ehci0-controller wakeup-source is fail.
[ 5.250190] sunxi ehci0-controller don't init wakeup source
[ 5.256442] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c94ca0, 0x:f16e3000, irq_no:3b
[ 5.268469] [sunxi-ehci0]: Not init ehci0
[ 5.273380] get drvvbus-en is fail, 22
[ 5.277585] get ohci0-controller wakeup-source is fail.
[ 5.283591] sunxi ohci0-controller don't init wakeup source
[ 5.289863] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c94f50
[ 5.299528] [sunxi-ohci0]: Not init ohci0
[ 5.304421] get drvvbus-en is fail, 22
[ 5.308653] get ehci1-controller wakeup-source is fail.
[ 5.314608] sunxi ehci1-controller don't init wakeup source
[ 5.320878] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c95200, 0x:f16ed000, irq_no:3d
[ 5.333124] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 5.346583] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 5.353863] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 5.363776] sunxi-ehci 4200000.ehci1-controller: irq 61, io mem 0x04200000
[ 5.398439] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 5.407168] hub 1-0:1.0: USB hub found
[ 5.411445] hub 1-0:1.0: 1 port detected
[ 5.416708] get drvvbus-en is fail, 22
[ 5.420942] get ohci1-controller wakeup-source is fail.
[ 5.426915] sunxi ohci1-controller don't init wakeup source
[ 5.433180] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c954b0
[ 5.443092] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 5.455432] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 5.462705] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 5.472611] sunxi-ohci 4200400.ohci1-controller: irq 62, io mem 0x04200400
[ 5.553284] hub 2-0:1.0: USB hub found
[ 5.557532] hub 2-0:1.0: 1 port detected
[ 5.563985] ubi0: attaching mtd3
[ 5.568080] ubi0: scanning is finished
[ 5.572333] ubi0: empty MTD device detected
[ 5.577090] ubi0 error: ubi_early_get_peb: no free eraseblocks
[ 5.583707] ubi0 error: ubi_attach_mtd_dev: failed to attach mtd3, error -28
[ 5.591653] UBI error: cannot attach mtd3
[ 5.596150] UBI: block: can't open volume on ubi0_-1, err=-19
[ 5.603123] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
[ 5.620212] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
[ 5.627809] sunxi-vin-core 5809200.vinc: Adding to iommu group 0
[ 5.636014] sun8iw20-pinctrl pio: pin PE13 already requested by 4500000.eth; cannot claim for pio:141
[ 5.646393] sun8iw20-pinctrl pio: pin-141 (pio:141) status -22
[ 5.653290] [VIN_WARN]get csi isp clk fail
[ 5.657884] [VIN_WARN]get csi isp src clk fail
[ 5.662895] [VIN_WARN]get csi mipi clk fail
[ 5.667583] [VIN_WARN]get csi mipi src clk fail
[ 5.672848] [VIN_WARN]get csi isp mbus clk fail
[ 5.677939] [VIN_WARN]Get isp reset control fail
[ 5.683344] [VIN_ERR]n5 request i2c1 adapter failed!
[ 5.692014] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.700784] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:3
[ 5.710974] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.718482] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.728140] cfg80211: failed to load regulatory.db
[ 5.728567] clk: Not disabling unused clocks
[ 5.738392] ALSA device list:
[ 5.741789] #0: audiocodec
[ 5.745023] alloc_fd: slot 0 not NULL!
[ 5.749614] /dev/root: Can't open blockdev
[ 5.754234] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -6
[ 5.763131] Please append a correct "root=" boot option; here are the available partitions:
[ 5.772519] 1f00 1024 mtdblock0
[ 5.772522] (driver?)
[ 5.779858] 1f01 3072 mtdblock1
[ 5.779860] (driver?)
[ 5.787189] 1f02 1024 mtdblock2
[ 5.787192] (driver?)
[ 5.794518] 1f03 125952 mtdblock3
[ 5.794520] (driver?)
[ 5.801861] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 5.811126] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #14
[ 5.817853] Hardware name: Generic DT based system
[ 5.823240] [<c010e2f8>] (unwind_backtrace) from [<c010a8bc>] (show_stack+0x10/0x14)
[ 5.831924] [<c010a8bc>] (show_stack) from [<c0795ab0>] (dump_stack+0x7c/0x98)
[ 5.840024] [<c0795ab0>] (dump_stack) from [<c0119d2c>] (panic+0x104/0x3dc)
[ 5.847833] [<c0119d2c>] (panic) from [<c0b01278>] (mount_block_root+0x258/0x300)
[ 5.856224] [<c0b01278>] (mount_block_root) from [<c0b014bc>] (prepare_namespace+0x118/0x178)
[ 5.865782] [<c0b014bc>] (prepare_namespace) from [<c07aa194>] (kernel_init+0x8/0x118)
[ 5.874659] [<c07aa194>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 5.883140] Exception stack(0xef079fb0 to 0xef079ff8)
[ 5.888799] 9fa0: 00000000 00000000 00000000 00000000
[ 5.897965] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.907130] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 5.914548] CPU1: stopping
[ 5.917580] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #14
[ 5.924307] Hardware name: Generic DT based system
[ 5.929680] [<c010e2f8>] (unwind_backtrace) from [<c010a8bc>] (show_stack+0x10/0x14)
[ 5.938361] [<c010a8bc>] (show_stack) from [<c0795ab0>] (dump_stack+0x7c/0x98)
[ 5.946458] [<c0795ab0>] (dump_stack) from [<c010c6b0>] (handle_IPI+0xc0/0x168)
[ 5.954654] [<c010c6b0>] (handle_IPI) from [<c03a7134>] (gic_handle_irq+0x70/0x78)
[ 5.963141] [<c03a7134>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[ 5.971525] Exception stack(0xef09bf80 to 0xef09bfc8)
[ 5.977186] bf80: 00002f18 ef7c8574 00000000 c0115280 00000002 ef09a000 c0c03e28 c0c03e64
[ 5.986353] bfa0: 4000406a 410fc075 00000000 00000000 c0c79830 ef09bfd0 c0107fd8 c0107fdc
[ 5.995516] bfc0: 60000113 ffffffff
[ 5.999427] [<c01021cc>] (__irq_svc) from [<c0107fdc>] (arch_cpu_idle+0x2c/0x38)
[ 6.007720] [<c0107fdc>] (arch_cpu_idle) from [<c013e920>] (do_idle+0xb8/0x120)
[ 6.015914] [<c013e920>] (do_idle) from [<c013ec24>] (cpu_startup_entry+0x18/0x1c)
[ 6.024400] [<c013ec24>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
[ 6.032213] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---请问这个是为什么:
[ 5.596150] UBI: block: can't open volume on ubi0_-1, err=-19离线
重新又烧了一片新的 W25N01GVZEIG :
[1383]fes begin commit:1417090655
[1386]set pll start
[1388]fix vccio detect value:0xc0
[1395]periph0 has been enabled
[1398]set pll end
[1400][pmu]: bus read error
[1402]board init ok
[1404]beign to init dram
[1406]get_pmu_exist() = -1
[1409]ddr_efuse_type: 0x0
[1411]trefi:7.8ms
[1414][AUTO DEBUG] two rank and full DQ!
[1417]ddr_efuse_type: 0x0
[1420]trefi:7.8ms
[1422][AUTO DEBUG] rank 0 row = 15
[1425][AUTO DEBUG] rank 0 bank = 8
[1429][AUTO DEBUG] rank 0 page size = 2 KB
[1433][AUTO DEBUG] rank 1 row = 15
[1436][AUTO DEBUG] rank 1 bank = 8
[1439][AUTO DEBUG] rank 1 page size = 2 KB
[1443]rank1 config same as rank0
[1446]DRAM BOOT DRIVE INFO: V0.33
[1449]DRAM CLK = 792 MHz
[1451]DRAM Type = 3 (2:DDR2,3:DDR3)
[1455]DRAMC ZQ value: 0x7b7bfb
[1457]DRAM ODT value: 0x42.
[1460]ddr_efuse_type: 0x0
[1463]DRAM SIZE =1024 M
[1465]dram_tpr4:0x0
[1467]PLL_DDR_CTRL_REG:0xf8004100
[1470]DRAM_CLK_REG:0xc0000000
[1473][TIMING DEBUG] MR2= 0x18
[1477]DRAM simple test OK.
[1479]rtc standby flag is 0x0, super standby flag is 0x0
[1485]init dram ok
U-Boot 2018.07-gd9e6718-dirty (Feb 21 2024 - 10:47:19 +0800) Allwinner Technology
[03.911]CPU: Allwinner Family
[03.914]Model: sun8iw20
[03.916]DRAM: 512 MiB
[03.919]Relocation Offset is: 1cebc000
[03.947]secure enable bit: 0
[03.949]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[03.956]gic: normal mode
sunxi flash map init
SPI ALL: ready
[03.962]flash init start
[03.965]workmode = 16,storage type = 0
try card 0
set card number 0
get card number 0
[03.972][mmc]: mmc driver ver uboot2018:2022-12-07 18:56:00
[03.978][mmc]: get sdc_type fail and use default host:tm1.
[03.984][mmc]: can't find node "mmc0",will add new node
[03.989][mmc]: fdt err returned <no error>
[03.992][mmc]: Using default timing para
[03.996][mmc]: SUNXI SDMMC Controller Version:0x50310
[04.010][mmc]: mmc 0 cmd timeout 100 status 100
[04.014][mmc]: smc 0 err, cmd 8, RTO
[04.017][mmc]: mmc 0 close bus gating and reset
[04.023][mmc]: mmc 0 cmd timeout 100 status 100
[04.027][mmc]: smc 0 err, cmd 55, RTO
[04.030][mmc]: mmc 0 close bus gating and reset
[04.038][mmc]: mmc 0 cmd timeout 100 status 100
[04.043][mmc]: smc 0 err, cmd 1, RTO
[04.046][mmc]: mmc 0 close bus gating and reset
[04.050][mmc]: Card did not respond to voltage select!
[04.055][mmc]: mmc_init: -95, time 54
[04.058][mmc]: mmc_init: mmc init fail, err -95
MMC init failed
try emmc fail
[04.066]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
[04.071]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
[04.079]sunxi-spinand-phy: request spi0 gpio ok
[04.084]sunxi-spinand-phy: request general tx dma channel ok!
[04.089]sunxi-spinand-phy: request general rx dma channel ok!
[04.094]sunxi-spinand-phy: set spic0 clk to 20 Mhz
[04.099]sunxi-spinand-phy: init spic0 clk ok
[04.103]sunxi-spinand-phy: detect munufacture from id table: Winbond
[04.109]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[04.115]sunxi-spinand-phy: ========== arch info ==========
[04.120]sunxi-spinand-phy: Model: W25N01GVZEIG
[04.125]sunxi-spinand-phy: Munufacture: Winbond
[04.130]sunxi-spinand-phy: DieCntPerChip: 1
[04.135]sunxi-spinand-phy: BlkCntPerDie: 1024
[04.139]sunxi-spinand-phy: PageCntPerBlk: 64
[04.144]sunxi-spinand-phy: SectCntPerPage: 4
[04.148]sunxi-spinand-phy: OobSizePerPage: 64
[04.153]sunxi-spinand-phy: BadBlockFlag: 0x0
[04.157]sunxi-spinand-phy: OperationOpt: 0x7
[04.162]sunxi-spinand-phy: MaxEraseTimes: 65000
[04.167]sunxi-spinand-phy: EccFlag: 0x0
[04.171]sunxi-spinand-phy: EccType: 2
[04.176]sunxi-spinand-phy: EccProtectedType: 3
[04.180]sunxi-spinand-phy: ========================================
[04.186]sunxi-spinand-phy:
[04.189]sunxi-spinand-phy: ========== physical info ==========
[04.194]sunxi-spinand-phy: TotalSize: 128 M
[04.198]sunxi-spinand-phy: SectorSize: 512 B
[04.202]sunxi-spinand-phy: PageSize: 2 K
[04.206]sunxi-spinand-phy: BlockSize: 128 K
[04.211]sunxi-spinand-phy: OOBSize: 64 B
[04.215]sunxi-spinand-phy: ========================================
[04.221]sunxi-spinand-phy:
[04.223]sunxi-spinand-phy: ========== logical info ==========
[04.229]sunxi-spinand-phy: TotalSize: 128 M
[04.233]sunxi-spinand-phy: SectorSize: 512 B
[04.237]sunxi-spinand-phy: PageSize: 4 K
[04.241]sunxi-spinand-phy: BlockSize: 256 K
[04.245]sunxi-spinand-phy: OOBSize: 128 B
[04.249]sunxi-spinand-phy: ========================================
[04.256]sunxi-spinand-phy: W25N01GVZEIG reset rx bit width to 1
[04.261]sunxi-spinand-phy: W25N01GVZEIG reset tx bit width to 1
[04.267]sunxi-spinand-phy: block lock register: 0x00
[04.271]sunxi-spinand-phy: feature register: 0x19
[04.276]sunxi-spinand-phy: sunxi physic nand init end
[04.685]sunxi-spinand-phy: set spic0 clk to 100 Mhz
[05.802]sunxi-spinand-phy: Sample mode:1 min_delay:5000 max_delay:14760 right_delay:1e)
[05.963]line:703 init_clocks
[05.966]init_clocks:finish
[05.968]Loading Environment from SUNXI_FLASH... OK
[05.973]try to burn key
[05.975]out of usb burn from boot: not boot mode
sunxi work mode=0x10
run usb efex
delay time 2500
weak:otg_phy_config
usb init ok
set address 0x34
set address 0x34 ok
set address 0x1b
set address 0x1b ok
SUNXI_EFEX_ERASE_TAG
erase_flag = 0x12
origin_erase_flag = 0x1
FEX_CMD_fes_verify_status
FEX_CMD_fes_verify last err=0
the 0 mbr table is ok
the 1 mbr table is ok
the 2 mbr table is ok
the 3 mbr table is ok
*************MBR DUMP***************
total mbr part 9
part[0] name :boot-resource
part[0] classname :DISK
part[0] addrlo :0x8000
part[0] lenlo :0x3fcc
part[0] user_type :32768
part[0] keydata :0
part[0] ro :0
part[1] name :env
part[1] classname :DISK
part[1] addrlo :0xbfcc
part[1] lenlo :0x800
part[1] user_type :32768
part[1] keydata :0
part[1] ro :0
part[2] name :env-redund
part[2] classname :DISK
part[2] addrlo :0xc7cc
part[2] lenlo :0x800
part[2] user_type :32768
part[2] keydata :0
part[2] ro :0
part[3] name :boot
part[3] classname :DISK
part[3] addrlo :0xcfcc
part[3] lenlo :0x8980
part[3] user_type :32768
part[3] keydata :0
part[3] ro :0
part[4] name :rootfs
part[4] classname :DISK
part[4] addrlo :0x1594c
part[4] lenlo :0xbe80
part[4] user_type :32768
part[4] keydata :0
part[4] ro :0
part[5] name :recovery
part[5] classname :DISK
part[5] addrlo :0x217cc
part[5] lenlo :0xa000
part[5] user_type :32768
part[5] keydata :0
part[5] ro :0
part[6] name :dsp0
part[6] classname :DISK
part[6] addrlo :0x2b7cc
part[6] lenlo :0x800
part[6] user_type :32768
part[6] keydata :0
part[6] ro :0
part[7] name :private
part[7] classname :DISK
part[7] addrlo :0x2bfcc
part[7] lenlo :0x400
part[7] user_type :32768
part[7] keydata :0
part[7] ro :0
part[8] name :UDISK
part[8] classname :DISK
part[8] addrlo :0x2c3cc
part[8] lenlo :0x0
part[8] user_type :33024
part[8] keydata :0
part[8] ro :0
total part: 10
mbr 0, 8000, 8000
boot-resource 1, 3fcc, 8000
env 2, 800, 8000
env-redund 3, 800, 8000
boot 4, 8980, 8000
rootfs 5, be80, 8000
recovery 6, a000, 8000
dsp0 7, 800, 8000
private 8, 400, 8000
UDISK 9, 0, 8100
[09.220]erase blk 0 to blk 32
[09.223]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
[09.229]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
[09.234]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
[09.240]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
[09.245]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
[09.251]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
[09.256]sunxi-spinand-phy: [SPINAND]: ecc error 0x2
need erase flash: 18
[09.289]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
device nand0 <nand>, # parts = 4
#: name size offset mask_flags
0: boot0 0x00100000 0x00000000 1
1: uboot 0x00300000 0x00100000 1
2: secure_storage 0x00100000 0x00400000 1
3: sys 0x07b00000 0x00500000 0
active partition: nand0,0 - (boot0) 0x00100000 @ 0x00000000
defaults:
mtdids : nand0=nand
[09.340]MTD info (4)
[09.341]pagesize: 0x1000
[09.344]blksize: 0x40000
[09.346]num offset bytes name
[09.349]0 0x00000000 0x00100000 boot0
[09.353]1 0x00100000 0x00300000 uboot
[09.357]2 0x00400000 0x00100000 secure_storage
[09.361]3 0x00500000 0x07b00000 sys
[09.365]ubi attach the last part of mtd device: NO.3
[09.437]ubi0: attaching mtd4
[09.662]ubi0: scanning is finished
[09.672]ubi0: attached mtd4 (name "sys", size 123 MiB)
[09.676]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[09.683]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[09.689]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[09.695]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[09.700]ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
[09.707]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[09.715]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[09.723]erase blk 0 to blk 32
[09.743]erase blk 40 to blk 1024
[10.450]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
[10.458]Item0 (Map) magic is bad
[10.461]the secure storage map is empty
[10.552]sunxi-spinand: write secure storage itme 0 ok
[10.557]erase secure storage: 0 ok
SUNXI_EFEX_MBR_TAG
mbr size = 0x10000
force mbr
defaults:
mtdids : nand0=nand
[10.605]MTD info (4)
[10.607]pagesize: 0x1000
[10.609]blksize: 0x40000
[10.612]num offset bytes name
[10.615]0 0x00000000 0x00100000 boot0
[10.619]1 0x00100000 0x00300000 uboot
[10.622]2 0x00400000 0x00100000 secure_storage
[10.627]3 0x00500000 0x07b00000 sys
[10.630]MBR info (unalign):
[10.633]partno addr sects type name
[10.638]0 0x00000000 0x00008000 0x00000001 mbr
[10.642]1 0x00008000 0x00003fcc 0x00008000 boot-resource
[10.648]2 0x0000bfcc 0x00000800 0x00008000 env
[10.653]3 0x0000c7cc 0x00000800 0x00008000 env-redund
[10.658]4 0x0000cfcc 0x00008980 0x00008000 boot
[10.663]5 0x0001594c 0x0000be80 0x00008000 rootfs
[10.668]6 0x000217cc 0x0000a000 0x00008000 recovery
[10.673]7 0x0002b7cc 0x00000800 0x00008000 dsp0
[10.678]8 0x0002bfcc 0x00000400 0x00008000 private
[10.683]9 0x0002c3cc 0x00000000 0x00008100 UDISK
[10.688]ubi attach the last part of mtd device: NO.3
[10.693]MBR info (align):
[10.695]partno addr sects type name
[10.700]0 0x00002800 0x000081f0 0x00000001 mbr
[10.705]1 0x0000a9f0 0x000040f8 0x00008000 boot-resource
[10.710]2 0x0000eae8 0x000009d8 0x00008000 env
[10.715]3 0x0000f4c0 0x000009d8 0x00008000 env-redund
[10.721]4 0x0000fe98 0x000089d0 0x00008000 boot
[10.725]5 0x00018868 0x0000bef8 0x00008000 rootfs
[10.730]6 0x00024760 0x0000a170 0x00008000 recovery
[10.736]7 0x0002e8d0 0x000009d8 0x00008000 dsp0
[10.741]8 0x0002f2a8 0x000005e8 0x00008000 private
[10.746]9 0x0002f890 0x00000000 0x00008100 UDISK
[10.751]ubi attach the last part of mtd device: NO.3
[10.755]ubi attatch mtd, name: sys
[10.759]ubi0: detaching mtd4
[10.761]ubi0: mtd4 is detached
[10.764]ubi0: attaching mtd4
[10.878]ubi0: scanning is finished
[10.881]ubi0: empty MTD device detected
[10.900]ubi0: attached mtd4 (name "sys", size 123 MiB)
[10.905]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[10.911]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[10.917]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[10.924]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[10.929]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
[10.936]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
[10.943]ubi0: available PEBs: 468, total reserved PEBs: 24, PEBs reserved for bad PEB handling: 20
Creating static volume mbr of size 17031168
Creating dynamic volume boot-resource of size 8515584
Creating dynamic volume env of size 1290240
Creating dynamic volume env-redund of size 1290240
Creating dynamic volume boot of size 18063360
Creating dynamic volume rootfs of size 25030656
Creating dynamic volume recovery of size 21159936
Creating dynamic volume dsp0 of size 1290240
Creating dynamic volume private of size 774144
No size specified -> Using max size (26320896)
[11.889]reset last volume size to 0xc8d0
Creating dynamic volume UDISK of size 26320896
[11.914]existed volume UDISK size is 51408(sects) , inside ubi part size is 0(sects),existed volume size to update inside ubi part size
[11.926]existed volume UDISK size is 51408(sects) , inside ubi part size is 0(sects),existed volume size to update inside ubi part size
[11.955]fill gap start: volume mbr sects 0x7f80
[17.700]fill gap end: volume mbr
[17.703]update partition map
[17.705]logical area info: 468 258048 last_lba: 235871
[17.718]logical area info: 468 258048 last_lba: 235871
[17.730]logical area info: 468 258048 last_lba: 235871
[17.742]logical area info: 468 258048 last_lba: 235871
[17.754]logical area info: 468 258048 last_lba: 235871
[17.766]logical area info: 468 258048 last_lba: 235871
[17.778]logical area info: 468 258048 last_lba: 235871
[17.790]logical area info: 468 258048 last_lba: 235871
[17.802]logical area info: 468 258048 last_lba: 235871
[17.814]logical area info: 468 258048 last_lba: 235871
[17.827]logical area info: 468 258048 last_lba: 235871
[17.839]logical area info: 468 258048 last_lba: 235871
[17.851]logical area info: 468 258048 last_lba: 235871
[17.863]logical area info: 468 258048 last_lba: 235871
[17.875]logical area info: 468 258048 last_lba: 235871
[17.887]logical area info: 468 258048 last_lba: 235871
[17.899]logical area info: 468 258048 last_lba: 235871
[17.911]logical area info: 468 258048 last_lba: 235871
[17.923]logical area info: 468 258048 last_lba: 235871
[17.935]logical area info: 468 258048 last_lba: 235871
[17.947]logical area info: 468 258048 last_lba: 235871
[17.960]logical area info: 468 258048 last_lba: 235871
[17.972]logical area info: 468 258048 last_lba: 235871
[17.984]logical area info: 468 258048 last_lba: 235871
[17.996]logical area info: 468 258048 last_lba: 235871
[18.008]logical area info: 468 258048 last_lba: 235871
[18.020]logical area info: 468 258048 last_lba: 235871
[18.032]logical area info: 468 258048 last_lba: 235871
[18.044]logical area info: 468 258048 last_lba: 235871
[18.056]logical area info: 468 258048 last_lba: 235871
[18.068]logical area info: 468 258048 last_lba: 235871
[18.104]fill gap start: volume boot-resource sects 0x3f2c
[18.241]fill gap end: volume boot-resource
FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x14000
FEX_CMD_fes_verify_value 0xe6f75b5c
[18.287]fill gap start: volume env sects 0x700
[18.374]fill gap end: volume env
FEX_CMD_fes_verify_value, start 0xbfcc, size high 0x0:low 0x20000
FEX_CMD_fes_verify_value 0xcf8ab069
[18.424]fill gap start: volume env-redund sects 0x700
[18.511]fill gap end: volume env-redund
FEX_CMD_fes_verify_value, start 0xc7cc, size high 0x0:low 0x20000
[19.889]fill gap start: volume boot sects 0x61ac
[20.056]fill gap end: volume boot
FEX_CMD_fes_verify_value, start 0xcfcc, size high 0x0:low 0x4fa800
FEX_CMD_fes_verify_value 0x2db1f660
[27.010]fill gap start: volume rootfs sects 0x280
[27.093]fill gap end: volume rootfs
FEX_CMD_fes_verify_value, start 0x1594c, size high 0x0:low 0x1780000
FEX_CMD_fes_verify_value 0xc9c223e1
[29.953]fill gap start: volume dsp0 sects 0x601
[30.038]fill gap end: volume dsp0
FEX_CMD_fes_verify_value, start 0x2b7cc, size high 0x0:low 0x3fc78
FEX_CMD_fes_verify_value 0xb80b7e41
bootfile_mode=4
SUNXI_EFEX_BOOT1_TAG
boot1 size = 0x150000, max size = 0x200000
uboot size = 0x150000
storage type = 0
[30.127]uboot blk range [8-32)
[30.130]download uboot to block 8 (11 blocks) len 1344K
[30.460]download uboot to block 19 (11 blocks) len 1344K
bootfile_mode=4
SUNXI_EFEX_BOOT0_TAG
boot0 size = 0xb000
dram para[0] = 318
dram para[1] = 3
dram para[2] = 7b7bfb
dram para[3] = 1
dram para[4] = 10f210f2
dram para[5] = 4001000
dram para[6] = 1c70
dram para[7] = 42
dram para[8] = 18
dram para[9] = 0
dram para[10] = 4a2195
dram para[11] = 2423190
dram para[12] = 8b061
dram para[13] = b4787896
dram para[14] = 0
dram para[15] = 48484848
dram para[16] = 48
dram para[17] = 1620121e
dram para[18] = 0
dram para[19] = 0
dram para[20] = 0
dram para[21] = 770000
dram para[22] = 2
dram para[23] = b4056103
dram para[24] = 0
dram para[25] = 0
dram para[26] = 0
dram para[27] = 0
dram para[28] = 0
dram para[29] = 0
dram para[30] = 0
dram para[31] = 0
storage type = 0
[30.869]download boot0 to block 0 len 44K
[30.884]download boot0 to block 1 len 44K
[30.898]download boot0 to block 2 len 44K
[30.913]download boot0 to block 3 len 44K
[30.927]download boot0 to block 4 len 44K
[30.942]download boot0 to block 5 len 44K
[30.956]download boot0 to block 6 len 44K
[30.971]download boot0 to block 7 len 44K
sunxi_efex_next_action=2
exit usb
next work 2启动
▒[138]HELLO! BOOT0 is starting!
[141]BOOT0 commit : 1417090655
[144]set pll start
[150]periph0 has been enabled
[153]set pll end
[155][pmu]: bus read error
[157]board init ok
[159]enable_jtag
[161]get_pmu_exist() = -1
[164]DRAM BOOT DRIVE INFO: V0.33
[167]DRAM CLK = 792 MHz
[169]DRAM Type = 3 (2:DDR2,3:DDR3)
[172]DRAMC ZQ value: 0x7b7bfb
[175]DRAM ODT value: 0x42.
[178]ddr_efuse_type: 0x0
[181]DRAM SIZE =1024 M
[183]dram_tpr4:0x0
[185]PLL_DDR_CTRL_REG:0xf8004100
[188]DRAM_CLK_REG:0xc0000000
[191][TIMING DEBUG] MR2= 0x18
[199]DRAM simple test OK.
[201]rtc standby flag is 0x0, super standby flag is 0x0
[207]dram size =1024
[210]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
[215]block from 8 to 32
[359]Check is correct.
[361]dma 0x2ac4c int is not used yet
[365]dma 0x2ac4c int is free, you do not need to free it again
[370]Entry_name = u-boot
[378]Entry_name = optee
[382]Entry_name = dtb
[385]Jump to second Boot.
M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
[00.437]CPU: Allwinner Family
[00.440]Model: sun8iw20
[00.442]DRAM: 1 GiB
[00.445]Relocation Offset is: 3cebc000
[00.473]secure enable bit: 0
E/TC:0 fdt_getprop_u32:343 prop trace_level not found
[00.487]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
[00.493]gic: sec monitor mode
SPI ALL: ready
[00.500]flash init start
[00.502]workmode = 0,storage type = 0
[00.509]sunxi-spinand-phy: spinand sample_mode:1 sample_delay:1e
defaults:
mtdids : nand0=nand
[00.624]ubi0: attaching mtd4
[00.850]ubi0: scanning is finished
[00.859]ubi0: attached mtd4 (name "sys", size 123 MiB)
[00.864]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[00.870]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[00.876]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[00.882]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[00.888]ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
[00.894]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[00.902]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[00.911]sunxi flash init ok
[00.913]line:703 init_clocks
[00.916]drv_disp_init
[00.921]handle_num : 6
request pwm success, pwm2:pwm2:0x2000c00.
[00.932]drv_disp_init finish
[01.160]Loading Environment from SUNXI_FLASH... OK
[01.197]boot_gui_init:start
[01.199]set disp.dev2_output_type fail. using defval=0
[01.336]set disp.fb0_rot_used fail. using defval=0
[01.340]set disp.fb0_rot_degree fail. using defval=0
[01.346]smallwitpi lcd_panel_init 187 xxxxxxxxxxxxxxxxxx
[01.579]boot_gui_init:finish
partno erro : can't find partition bootloader
[01.608]bmp_name=bootlogo.bmp size 38454
[01.622]Item0 (Map) magic is bad
secure storage read widevine fail
[01.628]secure storage read widevine fail with:-1
secure storage read ec_key fail
[01.635]secure storage read ec_key fFDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
sunxi_pwm_pin_set_state, fdt_set_all_pin, ret=-1
[01.648]LCD open finish
ail with:-1
secure storage read ec_cert1 fail
[01.654]secure storage read ec_cert1 fail with:-1
secure storage read ec_cert2 fail
[01.661]secure storage read ec_cert2 fail with:-1
secure storage read ec_cert3 fail
[01.669]secure storage read ec_cert3 fail with:-1
secure storage read rsa_key fail
[01.676]secure storage read rsa_key fail with:-1
secure storage read rsa_cert1 fail
[01.684]secure storage read rsa_cert1 fail with:-1
secure storage read rsa_cert2 fail
[01.691]secure storage read rsa_cert2 fail with:-1
secure storage read rsa_cert3 fail
[01.699]secure storage read rsa_cert3 fail with:-1
[01.704]usb burn from boot
delay time 0
weak:otg_phy_config
[01.715]usb prepare ok
[01.921]usb sof ok
[01.923]usb probe ok
[01.925]usb setup ok
set address 0x18
set address 0x18 ok
set address 0x1e
set address 0x1e ok
try to update
[02.330]do_burn_from_boot usb : have no handshake
List file under ULI/factory
** Unrecognized filesystem type **
[02.363]update bootcmd
[02.394]change working_fdt 0x7c87be70 to 0x7c85be70
[02.413]update dts
[03.020]no vendor_boot partition is found
Android's image name: sun8i_arm
ERROR: reserving fdt memory region failed (addr=41900000 size=200000)
ERROR: reserving fdt memory region failed (addr=41c00000 size=400000)
ERROR: reserving fdt memory region failed (addr=41b00000 size=100000)
ERROR: reserving fdt memory region failed (addr=7c8ff000 size=342600)
ERROR: reserving fdt memory region failed (addr=42000000 size=100000)
ERROR: reserving fdt memory region failed (addr=42240000 size=2000)
ERROR: reserving fdt memory region failed (addr=42242000 size=2000)
ERROR: reserving fdt memory region failed (addr=42100000 size=10000)
[03.116]Starting kernel ...
[ 0.000000] Linux version 5.4.61 (whycan@ubuntu) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #14 SMP PREEMPT Tue Feb 20 16:55:57 CST 2024
[ 0.000000] OF: fdt: Machine model: sun8iw20
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] Reserved memory: created DMA memory pool at 0x42200000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vdev0buffer@42200000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x42244000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node dsp0_rpbuf@42244000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 16 MiB at 0x7f000000
[ 0.000000] On node 0 totalpages: 261796
[ 0.000000] Normal zone: 1536 pages used for memmap
[ 0.000000] Normal zone: 196260 pages, LIFO batch:63
[ 0.000000] HighMem zone: 65536 pages, LIFO batch:15
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s30976 r8192 d22272 u61440
[ 0.000000] pcpu-alloc: s30976 r8192 d22272 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260260
[ 0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/init rdinit=/rdinit partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:recovery@ubi0_6:dsp0@ubi0_7:private@ubi0_8:UDISK@ubi0_9: cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.07-gd9e6718-dirty(02/21/2024-10:47:19) mbr_offset=1032192 disp_reserve=3417600,0x7c8ff000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=1024
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Memory: 998976K/1047184K available (7168K kernel code, 441K rwdata, 2544K rodata, 1024K init, 193K bss, 31824K reserved, 16384K cma-reserved, 242420K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] random: get_random_bytes called from start_kernel+0x250/0x3d0 with crng_init=0
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008009] Switching to timer-based delay loop, resolution 41ns
[ 0.014208] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.024014] Console: colour dummy device 80x30
[ 0.028516] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038886] pid_max: default: 32768 minimum: 301
[ 0.043665] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.050997] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.059414] CPU: Testing write buffer coherency: ok
[ 0.064681] /cpus/cpu@0 missing clock-frequency property
[ 0.070034] /cpus/cpu@1 missing clock-frequency property
[ 0.075399] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081649] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088358] rcu: Hierarchical SRCU implementation.
[ 0.093473] BOOTEVENT: 93.463832: ON
[ 0.097873] smp: Bringing up secondary CPUs ...
[ 0.103702] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.103856] smp: Brought up 1 node, 2 CPUs
[ 0.113661] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.119840] CPU: All CPU(s) started in SVC mode.
[ 0.125048] devtmpfs: initialized
[ 0.142413] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.150630] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.160515] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.168174] pinctrl core: initialized pinctrl subsystem
[ 0.174878] NET: Registered protocol family 16
[ 0.181145] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.233052] rtc_ccu: sunxi ccu init OK
[ 0.239223] ccu: sunxi ccu init OK
[ 0.243159] r_ccu: sunxi ccu init OK
[ 0.287633] sun6i-dma 3002000.dma-controller: sunxi dma probed
[ 0.297212] iommu: Default domain type: Translated
[ 0.302370] sunxi iommu: irq = 24
[ 0.307037] SCSI subsystem initialized
[ 0.311195] usbcore: registered new interface driver usbfs
[ 0.317007] usbcore: registered new interface driver hub
[ 0.322497] usbcore: registered new device driver usb
[ 0.327856] mc: Linux media interface: v0.10
[ 0.332223] videodev: Linux video capture interface: v2.00
[ 0.339003] Advanced Linux Sound Architecture Driver Initialized.
[ 0.345816] Bluetooth: Core ver 2.22
[ 0.349555] NET: Registered protocol family 31
[ 0.354021] Bluetooth: HCI device and connection manager initialized
[ 0.360626] Bluetooth: HCI socket layer initialized
[ 0.365522] Bluetooth: L2CAP socket layer initialized
[ 0.370720] Bluetooth: SCO socket layer initialized
[ 0.375917] pwm module init!
[ 0.380497] g2d 5410000.g2d: Adding to iommu group 0
[ 0.385993] G2D: rcq version initialized.major:250
[ 0.391544] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.399439] clocksource: Switched to clocksource arch_sys_counter
[ 0.415102] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 0.435546] thermal_sys: Registered thermal governor 'step_wise'
[ 0.435552] thermal_sys: Registered thermal governor 'user_space'
[ 0.441638] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.448308] NET: Registered protocol family 2
[ 0.460029] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.468410] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.476282] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.483573] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.490107] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.496767] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.504092] NET: Registered protocol family 1
[ 0.509645] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
[ 0.517922] spi spi0: spi0 supply spi not found, using dummy regulator
[ 0.524762] sunxi_spi_resource_get()2259 - [spi0] SPI MASTER MODE
[ 0.530959] sunxi_spi_resource_get()2306 - sample_mode:1 sample_delay:30
[ 0.537688] sunxi_spi_request_dma()988 - [spi0] Request DMA channel dma0chan0 (tx) and dma0chan1 (rx) for DMA transfers
[ 0.548523] sunxi_spi_clk_init()2356 - [spi0] mclk 100000000
[ 0.555062] spi spi0: chipselect 0 already in use
[ 0.559815] spi_master spi0: spi_device register error /soc@3000000/spi@4025000/spi_board@0
[ 0.568172] spi_master spi0: Failed to create SPI device for /soc@3000000/spi@4025000/spi_board@0
[ 0.577091] sunxi_spi_probe()2809 - [spi0]: driver probe succeed, base f0862000, irq 42
[ 0.587198] Initialise system trusted keyrings
[ 0.591838] workingset: timestamp_bits=30 max_order=18 bucket_order=0
[ 0.609026] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.615335] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.620215] fuse: init (API version 7.31)
[ 0.653104] NET: Registered protocol family 38
[ 0.657562] Key type asymmetric registered
[ 0.661740] Asymmetric key parser 'x509' registered
[ 0.666703] bounce: pool size: 64 pages
[ 0.670630] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.678027] io scheduler mq-deadline registered
[ 0.682599] io scheduler kyber registered
[ 0.686718] atomic64_test: passed
[ 0.691787] [DISP]disp_module_init
[ 0.695814] disp 5000000.disp: Adding to iommu group 0
[ 0.701644] [DISP] disp_init,line:2331:
[ 0.701650] smooth display screen:0 type:1 mode:4
[ 0.726709] display_fb_request,fb_id:0
[ 0.744367] disp_al_manager_apply ouput_type:1
[ 0.749001] [DISP] lcd_clk_config,line:777:
[ 0.749013] disp 0, clk: pll(360000000),clk(360000000),dclk(60000000) dsi_rate(60000000)
[ 0.749013] clk real:pll(360000000),clk(360000000),dclk(90000000) dsi_rate(150000000)
[ 0.750065] [DISP]disp_module_init finish
[ 0.753644] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[ 0.771616] sunxi_sid_init()783 - insmod ok
[ 0.786803] pwm-regulator: supplied by regulator-dummy
[ 0.793725] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 0.801950] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.809155] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.817057] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
[ 0.825069] printk: console [ttyS0] enabled
[ 0.833941] printk: bootconsole [earlycon0] disabled
[ 0.845307] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 0.854413] uart uart1: uart1 supply uart not found, using dummy regulator
[ 0.862434] uart1: ttyS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
[ 0.872374] misc dump reg init
[ 0.876397] deinterlace 5400000.deinterlace: Adding to iommu group 0
[ 0.884142] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
[ 0.893213] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
[ 0.900478] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
[ 0.907756] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
[ 0.915146] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
[ 0.921663] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
[ 0.928559] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
[ 0.936260] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
[ 0.944070] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
[ 0.952139] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
[ 0.959764] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
[ 0.966488] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
[ 0.974006] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
[ 0.982355] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
[ 0.989627] [ADDR_MGT] addr_init: Failed to get type_def_bt, use default: 0
[ 0.997383] [ADDR_MGT] addr_mgt_probe: success.
[ 1.003809] sunxi-spinand: AW SPINand MTD Layer Version: 2.3 20211223
[ 1.011026] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.018851] sunxi-spinand-phy: not detect any munufacture from id table
[ 1.026270] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 1.032893] sunxi-spinand-phy: get phy info from fdt fail
[ 1.038896] sunxi-spinand-phy: not detect munufacture from fdt
[ 1.045477] sunxi-spinand-phy: detect munufacture from id table: Winbond
[ 1.052971] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[ 1.059955] sunxi-spinand-phy: ========== arch info ==========
[ 1.066451] sunxi-spinand-phy: Model: W25N01GVZEIG
[ 1.073144] sunxi-spinand-phy: Munufacture: Winbond
[ 1.079341] sunxi-spinand-phy: DieCntPerChip: 1
[ 1.084975] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 1.090894] sunxi-spinand-phy: PageCntPerBlk: 64
[ 1.096608] sunxi-spinand-phy: SectCntPerPage: 4
[ 1.102243] sunxi-spinand-phy: OobSizePerPage: 64
[ 1.107957] sunxi-spinand-phy: BadBlockFlag: 0x0
[ 1.113778] sunxi-spinand-phy: OperationOpt: 0x7
[ 1.119610] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 1.125619] sunxi-spinand-phy: EccFlag: 0x0
[ 1.131441] sunxi-spinand-phy: EccType: 2
[ 1.137062] sunxi-spinand-phy: EccProtectedType: 3
[ 1.142689] sunxi-spinand-phy: ========================================
[ 1.150062] sunxi-spinand-phy:
[ 1.153551] sunxi-spinand-phy: ========== physical info ==========
[ 1.160436] sunxi-spinand-phy: TotalSize: 128 M
[ 1.165762] sunxi-spinand-phy: SectorSize: 512 B
[ 1.171157] sunxi-spinand-phy: PageSize: 2 K
[ 1.176291] sunxi-spinand-phy: BlockSize: 128 K
[ 1.181637] sunxi-spinand-phy: OOBSize: 64 B
[ 1.186876] sunxi-spinand-phy: ========================================
[ 1.194246] sunxi-spinand-phy:
[ 1.197737] sunxi-spinand-phy: ========== logical info ==========
[ 1.204527] sunxi-spinand-phy: TotalSize: 128 M
[ 1.209867] sunxi-spinand-phy: SectorSize: 512 B
[ 1.215193] sunxi-spinand-phy: PageSize: 4 K
[ 1.220348] sunxi-spinand-phy: BlockSize: 256 K
[ 1.225668] sunxi-spinand-phy: OOBSize: 128 B
[ 1.231004] sunxi-spinand-phy: ========================================
[ 1.238447] sunxi-spinand-phy: block lock register: 0x00
[ 1.244437] sunxi-spinand-phy: feature register: 0x19
[ 1.250080] sunxi-spinand-phy: sunxi physic nand init end
[ 1.256569] Creating 4 MTD partitions on "sunxi_mtd_nand":
[ 1.262716] 0x000000000000-0x000000100000 : "boot0"
[ 1.280537] 0x000000100000-0x000000400000 : "uboot"
[ 1.286247] sunxi-spinand-phy: phy blk 9 is bad
[ 1.291658] sunxi-spinand-phy: phy blk 12 is bad
[ 1.297111] sunxi-spinand-phy: phy blk 16 is bad
[ 1.302491] sunxi-spinand-phy: phy blk 19 is bad
[ 1.308041] sunxi-spinand-phy: phy blk 23 is bad
[ 1.313629] sunxi-spinand-phy: phy blk 27 is bad
[ 1.318972] sunxi-spinand-phy: phy blk 29 is bad
[ 1.330632] 0x000000400000-0x000000500000 : "secure_storage"
[ 1.338080] Freeing logo buffer memory: 3340K
[ 1.339685] sunxi-spinand-phy: phy blk 33 is bad
[ 1.360598] 0x000000500000-0x000008000000 : "sys"
[ 1.366097] sunxi-spinand-phy: phy blk 41 is bad
[ 1.371474] sunxi-spinand-phy: phy blk 43 is bad
[ 1.376815] sunxi-spinand-phy: phy blk 45 is bad
[ 1.382202] sunxi-spinand-phy: phy blk 47 is bad
[ 1.387523] sunxi-spinand-phy: phy blk 49 is bad
[ 1.392862] random: fast init done
[ 1.396665] sunxi-spinand-phy: phy blk 51 is bad
[ 1.402022] sunxi-spinand-phy: phy blk 53 is bad
[ 1.407353] sunxi-spinand-phy: phy blk 55 is bad
[ 1.412716] sunxi-spinand-phy: phy blk 57 is bad
[ 1.418048] sunxi-spinand-phy: phy blk 59 is bad
[ 1.423390] sunxi-spinand-phy: phy blk 61 is bad
[ 1.428710] sunxi-spinand-phy: phy blk 63 is bad
[ 1.434075] sunxi-spinand-phy: phy blk 65 is bad
[ 1.439404] sunxi-spinand-phy: phy blk 67 is bad
[ 1.444743] sunxi-spinand-phy: phy blk 69 is bad
[ 1.450123] sunxi-spinand-phy: phy blk 71 is bad
[ 1.455474] sunxi-spinand-phy: phy blk 73 is bad
[ 1.460814] sunxi-spinand-phy: phy blk 75 is bad
[ 1.466133] sunxi-spinand-phy: phy blk 77 is bad
[ 1.471467] sunxi-spinand-phy: phy blk 79 is bad
[ 1.476770] sunxi-spinand-phy: phy blk 81 is bad
[ 1.482113] sunxi-spinand-phy: phy blk 83 is bad
[ 1.487424] sunxi-spinand-phy: phy blk 85 is bad
[ 1.492757] sunxi-spinand-phy: phy blk 87 is bad
[ 1.498062] sunxi-spinand-phy: phy blk 89 is bad
[ 1.503406] sunxi-spinand-phy: phy blk 91 is bad
[ 1.508711] sunxi-spinand-phy: phy blk 93 is bad
[ 1.514033] sunxi-spinand-phy: phy blk 95 is bad
[ 1.519355] sunxi-spinand-phy: phy blk 97 is bad
[ 1.524692] sunxi-spinand-phy: phy blk 99 is bad
[ 1.530022] sunxi-spinand-phy: phy blk 101 is bad
[ 1.535440] sunxi-spinand-phy: phy blk 103 is bad
[ 1.540869] sunxi-spinand-phy: phy blk 105 is bad
[ 1.546280] sunxi-spinand-phy: phy blk 107 is bad
[ 1.551712] sunxi-spinand-phy: phy blk 109 is bad
[ 1.557117] sunxi-spinand-phy: phy blk 111 is bad
[ 1.562548] sunxi-spinand-phy: phy blk 113 is bad
[ 1.567969] sunxi-spinand-phy: phy blk 115 is bad
[ 1.573400] sunxi-spinand-phy: phy blk 117 is bad
[ 1.578799] sunxi-spinand-phy: phy blk 119 is bad
[ 1.584231] sunxi-spinand-phy: phy blk 121 is bad
[ 1.589655] sunxi-spinand-phy: phy blk 123 is bad
[ 1.595055] sunxi-spinand-phy: phy blk 125 is bad
[ 1.600487] sunxi-spinand-phy: phy blk 127 is bad
[ 1.605899] sunxi-spinand-phy: phy blk 129 is bad
[ 1.611326] sunxi-spinand-phy: phy blk 131 is bad
[ 1.616743] sunxi-spinand-phy: phy blk 133 is bad
[ 1.622174] sunxi-spinand-phy: phy blk 135 is bad
[ 1.627582] sunxi-spinand-phy: phy blk 137 is bad
[ 1.633019] sunxi-spinand-phy: phy blk 139 is bad
[ 1.638419] sunxi-spinand-phy: phy blk 141 is bad
[ 1.643842] sunxi-spinand-phy: phy blk 143 is bad
[ 1.649261] sunxi-spinand-phy: phy blk 145 is bad
[ 1.654691] sunxi-spinand-phy: phy blk 147 is bad
[ 1.660120] sunxi-spinand-phy: phy blk 149 is bad
[ 1.665541] sunxi-spinand-phy: phy blk 151 is bad
[ 1.670971] sunxi-spinand-phy: phy blk 153 is bad
[ 1.676373] sunxi-spinand-phy: phy blk 155 is bad
[ 1.681809] sunxi-spinand-phy: phy blk 157 is bad
[ 1.687217] sunxi-spinand-phy: phy blk 159 is bad
[ 1.692641] sunxi-spinand-phy: phy blk 161 is bad
[ 1.698072] sunxi-spinand-phy: phy blk 163 is bad
[ 1.703504] sunxi-spinand-phy: phy blk 165 is bad
[ 1.708910] sunxi-spinand-phy: phy blk 167 is bad
[ 1.714339] sunxi-spinand-phy: phy blk 169 is bad
[ 1.719773] sunxi-spinand-phy: phy blk 171 is bad
[ 1.725180] sunxi-spinand-phy: phy blk 173 is bad
[ 1.730615] sunxi-spinand-phy: phy blk 175 is bad
[ 1.736026] sunxi-spinand-phy: phy blk 177 is bad
[ 1.741456] sunxi-spinand-phy: phy blk 179 is bad
[ 1.746856] sunxi-spinand-phy: phy blk 181 is bad
[ 1.752281] sunxi-spinand-phy: phy blk 183 is bad
[ 1.757683] sunxi-spinand-phy: phy blk 185 is bad
[ 1.763116] sunxi-spinand-phy: phy blk 187 is bad
[ 1.768525] sunxi-spinand-phy: phy blk 189 is bad
[ 1.773955] sunxi-spinand-phy: phy blk 191 is bad
[ 1.779360] sunxi-spinand-phy: phy blk 193 is bad
[ 1.784794] sunxi-spinand-phy: phy blk 195 is bad
[ 1.790221] sunxi-spinand-phy: phy blk 197 is bad
[ 1.795625] sunxi-spinand-phy: phy blk 199 is bad
[ 1.801064] sunxi-spinand-phy: phy blk 201 is bad
[ 1.806471] sunxi-spinand-phy: phy blk 203 is bad
[ 1.811903] sunxi-spinand-phy: phy blk 205 is bad
[ 1.817323] sunxi-spinand-phy: phy blk 207 is bad
[ 1.822753] sunxi-spinand-phy: phy blk 209 is bad
[ 1.828161] sunxi-spinand-phy: phy blk 211 is bad
[ 1.833593] sunxi-spinand-phy: phy blk 213 is bad
[ 1.838997] sunxi-spinand-phy: phy blk 215 is bad
[ 1.844420] sunxi-spinand-phy: phy blk 217 is bad
[ 1.849853] sunxi-spinand-phy: phy blk 219 is bad
[ 1.855266] sunxi-spinand-phy: phy blk 221 is bad
[ 1.860696] sunxi-spinand-phy: phy blk 223 is bad
[ 1.866105] sunxi-spinand-phy: phy blk 225 is bad
[ 1.871531] sunxi-spinand-phy: phy blk 227 is bad
[ 1.876930] sunxi-spinand-phy: phy blk 229 is bad
[ 1.882364] sunxi-spinand-phy: phy blk 231 is bad
[ 1.887780] sunxi-spinand-phy: phy blk 233 is bad
[ 1.893210] sunxi-spinand-phy: phy blk 235 is bad
[ 1.898619] sunxi-spinand-phy: phy blk 237 is bad
[ 1.904045] sunxi-spinand-phy: phy blk 239 is bad
[ 1.909466] sunxi-spinand-phy: phy blk 241 is bad
[ 1.914877] sunxi-spinand-phy: phy blk 243 is bad
[ 1.920301] sunxi-spinand-phy: phy blk 245 is bad
[ 1.925708] sunxi-spinand-phy: phy blk 247 is bad
[ 1.931150] sunxi-spinand-phy: phy blk 249 is bad
[ 1.936555] sunxi-spinand-phy: phy blk 251 is bad
[ 1.941982] sunxi-spinand-phy: phy blk 253 is bad
[ 1.947390] sunxi-spinand-phy: phy blk 255 is bad
[ 1.952811] sunxi-spinand-phy: phy blk 257 is bad
[ 1.958219] sunxi-spinand-phy: phy blk 259 is bad
[ 1.963654] sunxi-spinand-phy: phy blk 261 is bad
[ 1.969066] sunxi-spinand-phy: phy blk 263 is bad
[ 1.974496] sunxi-spinand-phy: phy blk 265 is bad
[ 1.979920] sunxi-spinand-phy: phy blk 267 is bad
[ 1.985333] sunxi-spinand-phy: phy blk 269 is bad
[ 1.990758] sunxi-spinand-phy: phy blk 271 is bad
[ 1.996167] sunxi-spinand-phy: phy blk 273 is bad
[ 2.001601] sunxi-spinand-phy: phy blk 275 is bad
[ 2.007008] sunxi-spinand-phy: phy blk 277 is bad
[ 2.012438] sunxi-spinand-phy: phy blk 279 is bad
[ 2.017854] sunxi-spinand-phy: phy blk 281 is bad
[ 2.023291] sunxi-spinand-phy: phy blk 283 is bad
[ 2.028697] sunxi-spinand-phy: phy blk 285 is bad
[ 2.034131] sunxi-spinand-phy: phy blk 287 is bad
[ 2.039547] sunxi-spinand-phy: phy blk 289 is bad
[ 2.044946] sunxi-spinand-phy: phy blk 291 is bad
[ 2.050382] sunxi-spinand-phy: phy blk 293 is bad
[ 2.055796] sunxi-spinand-phy: phy blk 295 is bad
[ 2.061233] sunxi-spinand-phy: phy blk 297 is bad
[ 2.066653] sunxi-spinand-phy: phy blk 299 is bad
[ 2.072080] sunxi-spinand-phy: phy blk 301 is bad
[ 2.077492] sunxi-spinand-phy: phy blk 303 is bad
[ 2.082925] sunxi-spinand-phy: phy blk 305 is bad
[ 2.088338] sunxi-spinand-phy: phy blk 307 is bad
[ 2.093770] sunxi-spinand-phy: phy blk 309 is bad
[ 2.099186] sunxi-spinand-phy: phy blk 311 is bad
[ 2.104608] sunxi-spinand-phy: phy blk 313 is bad
[ 2.110036] sunxi-spinand-phy: phy blk 315 is bad
[ 2.115452] sunxi-spinand-phy: phy blk 317 is bad
[ 2.120881] sunxi-spinand-phy: phy blk 319 is bad
[ 2.126291] sunxi-spinand-phy: phy blk 321 is bad
[ 2.131781] sunxi-spinand-phy: phy blk 323 is bad
[ 2.137185] sunxi-spinand-phy: phy blk 325 is bad
[ 2.142607] sunxi-spinand-phy: phy blk 327 is bad
[ 2.148020] sunxi-spinand-phy: phy blk 329 is bad
[ 2.153437] sunxi-spinand-phy: phy blk 331 is bad
[ 2.158850] sunxi-spinand-phy: phy blk 333 is bad
[ 2.164289] sunxi-spinand-phy: phy blk 335 is bad
[ 2.169711] sunxi-spinand-phy: phy blk 337 is bad
[ 2.175120] sunxi-spinand-phy: phy blk 339 is bad
[ 2.180552] sunxi-spinand-phy: phy blk 341 is bad
[ 2.185953] sunxi-spinand-phy: phy blk 343 is bad
[ 2.191378] sunxi-spinand-phy: phy blk 345 is bad
[ 2.196789] sunxi-spinand-phy: phy blk 347 is bad
[ 2.202223] sunxi-spinand-phy: phy blk 349 is bad
[ 2.207639] sunxi-spinand-phy: phy blk 351 is bad
[ 2.213068] sunxi-spinand-phy: phy blk 353 is bad
[ 2.218486] sunxi-spinand-phy: phy blk 355 is bad
[ 2.223910] sunxi-spinand-phy: phy blk 357 is bad
[ 2.229319] sunxi-spinand-phy: phy blk 359 is bad
[ 2.234751] sunxi-spinand-phy: phy blk 361 is bad
[ 2.240180] sunxi-spinand-phy: phy blk 363 is bad
[ 2.245588] sunxi-spinand-phy: phy blk 365 is bad
[ 2.251027] sunxi-spinand-phy: phy blk 367 is bad
[ 2.256441] sunxi-spinand-phy: phy blk 369 is bad
[ 2.261864] sunxi-spinand-phy: phy blk 371 is bad
[ 2.267275] sunxi-spinand-phy: phy blk 373 is bad
[ 2.272705] sunxi-spinand-phy: phy blk 375 is bad
[ 2.278111] sunxi-spinand-phy: phy blk 377 is bad
[ 2.283542] sunxi-spinand-phy: phy blk 379 is bad
[ 2.288948] sunxi-spinand-phy: phy blk 381 is bad
[ 2.294373] sunxi-spinand-phy: phy blk 383 is bad
[ 2.299801] sunxi-spinand-phy: phy blk 385 is bad
[ 2.305210] sunxi-spinand-phy: phy blk 387 is bad
[ 2.310637] sunxi-spinand-phy: phy blk 389 is bad
[ 2.316058] sunxi-spinand-phy: phy blk 391 is bad
[ 2.321478] sunxi-spinand-phy: phy blk 393 is bad
[ 2.326886] sunxi-spinand-phy: phy blk 395 is bad
[ 2.332316] sunxi-spinand-phy: phy blk 397 is bad
[ 2.337730] sunxi-spinand-phy: phy blk 399 is bad
[ 2.343161] sunxi-spinand-phy: phy blk 401 is bad
[ 2.348582] sunxi-spinand-phy: phy blk 403 is bad
[ 2.354012] sunxi-spinand-phy: phy blk 405 is bad
[ 2.359446] sunxi-spinand-phy: phy blk 407 is bad
[ 2.364865] sunxi-spinand-phy: phy blk 409 is bad
[ 2.370293] sunxi-spinand-phy: phy blk 411 is bad
[ 2.375703] sunxi-spinand-phy: phy blk 413 is bad
[ 2.381138] sunxi-spinand-phy: phy blk 415 is bad
[ 2.386548] sunxi-spinand-phy: phy blk 417 is bad
[ 2.391973] sunxi-spinand-phy: phy blk 419 is bad
[ 2.397402] sunxi-spinand-phy: phy blk 421 is bad
[ 2.402834] sunxi-spinand-phy: phy blk 423 is bad
[ 2.408235] sunxi-spinand-phy: phy blk 425 is bad
[ 2.413674] sunxi-spinand-phy: phy blk 427 is bad
[ 2.419074] sunxi-spinand-phy: phy blk 429 is bad
[ 2.424503] sunxi-spinand-phy: phy blk 431 is bad
[ 2.429938] sunxi-spinand-phy: phy blk 433 is bad
[ 2.435345] sunxi-spinand-phy: phy blk 435 is bad
[ 2.440773] sunxi-spinand-phy: phy blk 437 is bad
[ 2.446177] sunxi-spinand-phy: phy blk 439 is bad
[ 2.451599] sunxi-spinand-phy: phy blk 441 is bad
[ 2.457016] sunxi-spinand-phy: phy blk 443 is bad
[ 2.462440] sunxi-spinand-phy: phy blk 445 is bad
[ 2.467857] sunxi-spinand-phy: phy blk 447 is bad
[ 2.473285] sunxi-spinand-phy: phy blk 449 is bad
[ 2.478693] sunxi-spinand-phy: phy blk 451 is bad
[ 2.484121] sunxi-spinand-phy: phy blk 453 is bad
[ 2.489545] sunxi-spinand-phy: phy blk 455 is bad
[ 2.494953] sunxi-spinand-phy: phy blk 457 is bad
[ 2.500383] sunxi-spinand-phy: phy blk 459 is bad
[ 2.505790] sunxi-spinand-phy: phy blk 461 is bad
[ 2.511216] sunxi-spinand-phy: phy blk 463 is bad
[ 2.516626] sunxi-spinand-phy: phy blk 465 is bad
[ 2.522057] sunxi-spinand-phy: phy blk 467 is bad
[ 2.527459] sunxi-spinand-phy: phy blk 469 is bad
[ 2.532895] sunxi-spinand-phy: phy blk 471 is bad
[ 2.538300] sunxi-spinand-phy: phy blk 473 is bad
[ 2.543720] sunxi-spinand-phy: phy blk 475 is bad
[ 2.549129] sunxi-spinand-phy: phy blk 477 is bad
[ 2.554552] sunxi-spinand-phy: phy blk 479 is bad
[ 2.559981] sunxi-spinand-phy: phy blk 481 is bad
[ 2.565402] sunxi-spinand-phy: phy blk 483 is bad
[ 2.570825] sunxi-spinand-phy: phy blk 485 is bad
[ 2.576235] sunxi-spinand-phy: phy blk 487 is bad
[ 2.581663] sunxi-spinand-phy: phy blk 489 is bad
[ 2.587068] sunxi-spinand-phy: phy blk 491 is bad
[ 2.592494] sunxi-spinand-phy: phy blk 493 is bad
[ 2.597916] sunxi-spinand-phy: phy blk 495 is bad
[ 2.603347] sunxi-spinand-phy: phy blk 497 is bad
[ 2.608760] sunxi-spinand-phy: phy blk 499 is bad
[ 2.614196] sunxi-spinand-phy: phy blk 501 is bad
[ 2.619620] sunxi-spinand-phy: phy blk 503 is bad
[ 2.625030] sunxi-spinand-phy: phy blk 505 is bad
[ 2.630456] sunxi-spinand-phy: phy blk 507 is bad
[ 2.635868] sunxi-spinand-phy: phy blk 509 is bad
[ 2.641298] sunxi-spinand-phy: phy blk 511 is bad
[ 2.646710] sunxi-spinand-phy: phy blk 513 is bad
[ 2.652131] sunxi-spinand-phy: phy blk 515 is bad
[ 2.657538] sunxi-spinand-phy: phy blk 517 is bad
[ 2.662972] sunxi-spinand-phy: phy blk 519 is bad
[ 2.668380] sunxi-spinand-phy: phy blk 521 is bad
[ 2.673807] sunxi-spinand-phy: phy blk 523 is bad
[ 2.679225] sunxi-spinand-phy: phy blk 525 is bad
[ 2.684658] sunxi-spinand-phy: phy blk 527 is bad
[ 2.690091] sunxi-spinand-phy: phy blk 529 is bad
[ 2.695523] sunxi-spinand-phy: phy blk 531 is bad
[ 2.700956] sunxi-spinand-phy: phy blk 533 is bad
[ 2.706365] sunxi-spinand-phy: phy blk 535 is bad
[ 2.711796] sunxi-spinand-phy: phy blk 537 is bad
[ 2.717209] sunxi-spinand-phy: phy blk 539 is bad
[ 2.722634] sunxi-spinand-phy: phy blk 541 is bad
[ 2.728042] sunxi-spinand-phy: phy blk 543 is bad
[ 2.733476] sunxi-spinand-phy: phy blk 545 is bad
[ 2.738885] sunxi-spinand-phy: phy blk 547 is bad
[ 2.744302] sunxi-spinand-phy: phy blk 549 is bad
[ 2.749734] sunxi-spinand-phy: phy blk 551 is bad
[ 2.755139] sunxi-spinand-phy: phy blk 553 is bad
[ 2.760559] sunxi-spinand-phy: phy blk 555 is bad
[ 2.765977] sunxi-spinand-phy: phy blk 557 is bad
[ 2.771406] sunxi-spinand-phy: phy blk 559 is bad
[ 2.776811] sunxi-spinand-phy: phy blk 561 is bad
[ 2.782244] sunxi-spinand-phy: phy blk 563 is bad
[ 2.787646] sunxi-spinand-phy: phy blk 565 is bad
[ 2.793073] sunxi-spinand-phy: phy blk 567 is bad
[ 2.798492] sunxi-spinand-phy: phy blk 569 is bad
[ 2.803925] sunxi-spinand-phy: phy blk 571 is bad
[ 2.809335] sunxi-spinand-phy: phy blk 573 is bad
[ 2.814772] sunxi-spinand-phy: phy blk 575 is bad
[ 2.820205] sunxi-spinand-phy: phy blk 577 is bad
[ 2.825613] sunxi-spinand-phy: phy blk 579 is bad
[ 2.831053] sunxi-spinand-phy: phy blk 581 is bad
[ 2.836458] sunxi-spinand-phy: phy blk 583 is bad
[ 2.841882] sunxi-spinand-phy: phy blk 585 is bad
[ 2.847298] sunxi-spinand-phy: phy blk 587 is bad
[ 2.852728] sunxi-spinand-phy: phy blk 589 is bad
[ 2.858137] sunxi-spinand-phy: phy blk 591 is bad
[ 2.863565] sunxi-spinand-phy: phy blk 593 is bad
[ 2.868980] sunxi-spinand-phy: phy blk 595 is bad
[ 2.874402] sunxi-spinand-phy: phy blk 597 is bad
[ 2.879837] sunxi-spinand-phy: phy blk 599 is bad
[ 2.885251] sunxi-spinand-phy: phy blk 601 is bad
[ 2.890683] sunxi-spinand-phy: phy blk 603 is bad
[ 2.896097] sunxi-spinand-phy: phy blk 605 is bad
[ 2.901535] sunxi-spinand-phy: phy blk 607 is bad
[ 2.906942] sunxi-spinand-phy: phy blk 609 is bad
[ 2.912380] sunxi-spinand-phy: phy blk 611 is bad
[ 2.917787] sunxi-spinand-phy: phy blk 613 is bad
[ 2.923219] sunxi-spinand-phy: phy blk 615 is bad
[ 2.928630] sunxi-spinand-phy: phy blk 617 is bad
[ 2.934055] sunxi-spinand-phy: phy blk 619 is bad
[ 2.939477] sunxi-spinand-phy: phy blk 621 is bad
[ 2.944911] sunxi-spinand-phy: phy blk 623 is bad
[ 2.950336] sunxi-spinand-phy: phy blk 625 is bad
[ 2.955748] sunxi-spinand-phy: phy blk 627 is bad
[ 2.961178] sunxi-spinand-phy: phy blk 629 is bad
[ 2.966597] sunxi-spinand-phy: phy blk 631 is bad
[ 2.972024] sunxi-spinand-phy: phy blk 633 is bad
[ 2.977432] sunxi-spinand-phy: phy blk 635 is bad
[ 2.982865] sunxi-spinand-phy: phy blk 637 is bad
[ 2.988269] sunxi-spinand-phy: phy blk 639 is bad
[ 2.993698] sunxi-spinand-phy: phy blk 641 is bad
[ 2.999112] sunxi-spinand-phy: phy blk 643 is bad
[ 3.004548] sunxi-spinand-phy: phy blk 645 is bad
[ 3.009978] sunxi-spinand-phy: phy blk 647 is bad
[ 3.015395] sunxi-spinand-phy: phy blk 649 is bad
[ 3.020818] sunxi-spinand-phy: phy blk 651 is bad
[ 3.026232] sunxi-spinand-phy: phy blk 653 is bad
[ 3.031663] sunxi-spinand-phy: phy blk 655 is bad
[ 3.037075] sunxi-spinand-phy: phy blk 657 is bad
[ 3.042507] sunxi-spinand-phy: phy blk 659 is bad
[ 3.047920] sunxi-spinand-phy: phy blk 661 is bad
[ 3.053351] sunxi-spinand-phy: phy blk 663 is bad
[ 3.058754] sunxi-spinand-phy: phy blk 665 is bad
[ 3.064190] sunxi-spinand-phy: phy blk 667 is bad
[ 3.069624] sunxi-spinand-phy: phy blk 669 is bad
[ 3.075033] sunxi-spinand-phy: phy blk 671 is bad
[ 3.080472] sunxi-spinand-phy: phy blk 673 is bad
[ 3.085877] sunxi-spinand-phy: phy blk 675 is bad
[ 3.091304] sunxi-spinand-phy: phy blk 677 is bad
[ 3.096713] sunxi-spinand-phy: phy blk 679 is bad
[ 3.102144] sunxi-spinand-phy: phy blk 681 is bad
[ 3.107554] sunxi-spinand-phy: phy blk 683 is bad
[ 3.112978] sunxi-spinand-phy: phy blk 685 is bad
[ 3.118383] sunxi-spinand-phy: phy blk 687 is bad
[ 3.123814] sunxi-spinand-phy: phy blk 689 is bad
[ 3.129224] sunxi-spinand-phy: phy blk 691 is bad
[ 3.134649] sunxi-spinand-phy: phy blk 693 is bad
[ 3.140072] sunxi-spinand-phy: phy blk 695 is bad
[ 3.145489] sunxi-spinand-phy: phy blk 697 is bad
[ 3.150924] sunxi-spinand-phy: phy blk 699 is bad
[ 3.156323] sunxi-spinand-phy: phy blk 701 is bad
[ 3.161748] sunxi-spinand-phy: phy blk 703 is bad
[ 3.167158] sunxi-spinand-phy: phy blk 705 is bad
[ 3.172612] sunxi-spinand-phy: phy blk 707 is bad
[ 3.178030] sunxi-spinand-phy: phy blk 709 is bad
[ 3.183460] sunxi-spinand-phy: phy blk 711 is bad
[ 3.188870] sunxi-spinand-phy: phy blk 713 is bad
[ 3.194316] sunxi-spinand-phy: phy blk 715 is bad
[ 3.199746] sunxi-spinand-phy: phy blk 717 is bad
[ 3.205156] sunxi-spinand-phy: phy blk 719 is bad
[ 3.210589] sunxi-spinand-phy: phy blk 721 is bad
[ 3.216012] sunxi-spinand-phy: phy blk 723 is bad
[ 3.221441] sunxi-spinand-phy: phy blk 725 is bad
[ 3.226846] sunxi-spinand-phy: phy blk 727 is bad
[ 3.232280] sunxi-spinand-phy: phy blk 729 is bad
[ 3.237682] sunxi-spinand-phy: phy blk 731 is bad
[ 3.243115] sunxi-spinand-phy: phy blk 733 is bad
[ 3.248538] sunxi-spinand-phy: phy blk 735 is bad
[ 3.253955] sunxi-spinand-phy: phy blk 737 is bad
[ 3.259362] sunxi-spinand-phy: phy blk 739 is bad
[ 3.264794] sunxi-spinand-phy: phy blk 741 is bad
[ 3.270223] sunxi-spinand-phy: phy blk 743 is bad
[ 3.275632] sunxi-spinand-phy: phy blk 745 is bad
[ 3.281066] sunxi-spinand-phy: phy blk 747 is bad
[ 3.286474] sunxi-spinand-phy: phy blk 749 is bad
[ 3.291893] sunxi-spinand-phy: phy blk 751 is bad
[ 3.297312] sunxi-spinand-phy: phy blk 753 is bad
[ 3.302746] sunxi-spinand-phy: phy blk 755 is bad
[ 3.308156] sunxi-spinand-phy: phy blk 757 is bad
[ 3.313590] sunxi-spinand-phy: phy blk 759 is bad
[ 3.319001] sunxi-spinand-phy: phy blk 761 is bad
[ 3.324424] sunxi-spinand-phy: phy blk 763 is bad
[ 3.329850] sunxi-spinand-phy: phy blk 765 is bad
[ 3.335259] sunxi-spinand-phy: phy blk 767 is bad
[ 3.340683] sunxi-spinand-phy: phy blk 769 is bad
[ 3.346104] sunxi-spinand-phy: phy blk 771 is bad
[ 3.351533] sunxi-spinand-phy: phy blk 773 is bad
[ 3.356943] sunxi-spinand-phy: phy blk 775 is bad
[ 3.362375] sunxi-spinand-phy: phy blk 777 is bad
[ 3.367788] sunxi-spinand-phy: phy blk 779 is bad
[ 3.373221] sunxi-spinand-phy: phy blk 781 is bad
[ 3.378638] sunxi-spinand-phy: phy blk 783 is bad
[ 3.384062] sunxi-spinand-phy: phy blk 785 is bad
[ 3.389487] sunxi-spinand-phy: phy blk 787 is bad
[ 3.394897] sunxi-spinand-phy: phy blk 789 is bad
[ 3.400336] sunxi-spinand-phy: phy blk 791 is bad
[ 3.405745] sunxi-spinand-phy: phy blk 793 is bad
[ 3.411176] sunxi-spinand-phy: phy blk 795 is bad
[ 3.416585] sunxi-spinand-phy: phy blk 797 is bad
[ 3.422015] sunxi-spinand-phy: phy blk 799 is bad
[ 3.427433] sunxi-spinand-phy: phy blk 801 is bad
[ 3.432866] sunxi-spinand-phy: phy blk 803 is bad
[ 3.438274] sunxi-spinand-phy: phy blk 805 is bad
[ 3.443705] sunxi-spinand-phy: phy blk 807 is bad
[ 3.449113] sunxi-spinand-phy: phy blk 809 is bad
[ 3.454534] sunxi-spinand-phy: phy blk 811 is bad
[ 3.459963] sunxi-spinand-phy: phy blk 813 is bad
[ 3.465370] sunxi-spinand-phy: phy blk 815 is bad
[ 3.470801] sunxi-spinand-phy: phy blk 817 is bad
[ 3.476210] sunxi-spinand-phy: phy blk 819 is bad
[ 3.481645] sunxi-spinand-phy: phy blk 821 is bad
[ 3.487060] sunxi-spinand-phy: phy blk 823 is bad
[ 3.492488] sunxi-spinand-phy: phy blk 825 is bad
[ 3.497897] sunxi-spinand-phy: phy blk 827 is bad
[ 3.503334] sunxi-spinand-phy: phy blk 829 is bad
[ 3.508741] sunxi-spinand-phy: phy blk 831 is bad
[ 3.514174] sunxi-spinand-phy: phy blk 833 is bad
[ 3.519581] sunxi-spinand-phy: phy blk 835 is bad
[ 3.524992] sunxi-spinand-phy: phy blk 837 is bad
[ 3.530425] sunxi-spinand-phy: phy blk 839 is bad
[ 3.535839] sunxi-spinand-phy: phy blk 841 is bad
[ 3.541268] sunxi-spinand-phy: phy blk 843 is bad
[ 3.546671] sunxi-spinand-phy: phy blk 845 is bad
[ 3.552100] sunxi-spinand-phy: phy blk 847 is bad
[ 3.557508] sunxi-spinand-phy: phy blk 849 is bad
[ 3.562936] sunxi-spinand-phy: phy blk 851 is bad
[ 3.568346] sunxi-spinand-phy: phy blk 853 is bad
[ 3.573772] sunxi-spinand-phy: phy blk 855 is bad
[ 3.579189] sunxi-spinand-phy: phy blk 857 is bad
[ 3.584621] sunxi-spinand-phy: phy blk 859 is bad
[ 3.590038] sunxi-spinand-phy: phy blk 861 is bad
[ 3.595446] sunxi-spinand-phy: phy blk 863 is bad
[ 3.600876] sunxi-spinand-phy: phy blk 865 is bad
[ 3.606289] sunxi-spinand-phy: phy blk 867 is bad
[ 3.611723] sunxi-spinand-phy: phy blk 869 is bad
[ 3.617133] sunxi-spinand-phy: phy blk 871 is bad
[ 3.622560] sunxi-spinand-phy: phy blk 873 is bad
[ 3.627977] sunxi-spinand-phy: phy blk 875 is bad
[ 3.633405] sunxi-spinand-phy: phy blk 877 is bad
[ 3.638817] sunxi-spinand-phy: phy blk 879 is bad
[ 3.644249] sunxi-spinand-phy: phy blk 881 is bad
[ 3.649685] sunxi-spinand-phy: phy blk 883 is bad
[ 3.655091] sunxi-spinand-phy: phy blk 885 is bad
[ 3.660519] sunxi-spinand-phy: phy blk 887 is bad
[ 3.665929] sunxi-spinand-phy: phy blk 889 is bad
[ 3.671359] sunxi-spinand-phy: phy blk 891 is bad
[ 3.676775] sunxi-spinand-phy: phy blk 893 is bad
[ 3.682193] sunxi-spinand-phy: phy blk 895 is bad
[ 3.687597] sunxi-spinand-phy: phy blk 897 is bad
[ 3.693039] sunxi-spinand-phy: phy blk 899 is bad
[ 3.698450] sunxi-spinand-phy: phy blk 901 is bad
[ 3.703885] sunxi-spinand-phy: phy blk 903 is bad
[ 3.709298] sunxi-spinand-phy: phy blk 905 is bad
[ 3.714735] sunxi-spinand-phy: phy blk 907 is bad
[ 3.720167] sunxi-spinand-phy: phy blk 909 is bad
[ 3.725572] sunxi-spinand-phy: phy blk 911 is bad
[ 3.731004] sunxi-spinand-phy: phy blk 913 is bad
[ 3.736412] sunxi-spinand-phy: phy blk 915 is bad
[ 3.741834] sunxi-spinand-phy: phy blk 917 is bad
[ 3.747251] sunxi-spinand-phy: phy blk 919 is bad
[ 3.752682] sunxi-spinand-phy: phy blk 921 is bad
[ 3.758084] sunxi-spinand-phy: phy blk 923 is bad
[ 3.763518] sunxi-spinand-phy: phy blk 925 is bad
[ 3.768927] sunxi-spinand-phy: phy blk 927 is bad
[ 3.774353] sunxi-spinand-phy: phy blk 929 is bad
[ 3.779786] sunxi-spinand-phy: phy blk 931 is bad
[ 3.785187] sunxi-spinand-phy: phy blk 933 is bad
[ 3.790611] sunxi-spinand-phy: phy blk 935 is bad
[ 3.796028] sunxi-spinand-phy: phy blk 937 is bad
[ 3.801458] sunxi-spinand-phy: phy blk 939 is bad
[ 3.806864] sunxi-spinand-phy: phy blk 941 is bad
[ 3.812293] sunxi-spinand-phy: phy blk 943 is bad
[ 3.817710] sunxi-spinand-phy: phy blk 945 is bad
[ 3.823131] sunxi-spinand-phy: phy blk 947 is bad
[ 3.828549] sunxi-spinand-phy: phy blk 949 is bad
[ 3.833981] sunxi-spinand-phy: phy blk 951 is bad
[ 3.839392] sunxi-spinand-phy: phy blk 953 is bad
[ 3.844827] sunxi-spinand-phy: phy blk 955 is bad
[ 3.850258] sunxi-spinand-phy: phy blk 957 is bad
[ 3.855668] sunxi-spinand-phy: phy blk 959 is bad
[ 3.861098] sunxi-spinand-phy: phy blk 961 is bad
[ 3.866501] sunxi-spinand-phy: phy blk 963 is bad
[ 3.871932] sunxi-spinand-phy: phy blk 965 is bad
[ 3.877344] sunxi-spinand-phy: phy blk 967 is bad
[ 3.882770] sunxi-spinand-phy: phy blk 969 is bad
[ 3.888172] sunxi-spinand-phy: phy blk 971 is bad
[ 3.893604] sunxi-spinand-phy: phy blk 973 is bad
[ 3.899016] sunxi-spinand-phy: phy blk 975 is bad
[ 3.904443] sunxi-spinand-phy: phy blk 977 is bad
[ 3.909875] sunxi-spinand-phy: phy blk 979 is bad
[ 3.915291] sunxi-spinand-phy: phy blk 981 is bad
[ 3.920718] sunxi-spinand-phy: phy blk 983 is bad
[ 3.926135] sunxi-spinand-phy: phy blk 985 is bad
[ 3.931560] sunxi-spinand-phy: phy blk 987 is bad
[ 3.936971] sunxi-spinand-phy: phy blk 989 is bad
[ 3.942411] sunxi-spinand-phy: phy blk 991 is bad
[ 3.947821] sunxi-spinand-phy: phy blk 993 is bad
[ 3.953252] sunxi-spinand-phy: phy blk 995 is bad
[ 3.958660] sunxi-spinand-phy: phy blk 997 is bad
[ 3.964097] sunxi-spinand-phy: phy blk 999 is bad
[ 3.969521] sunxi-spinand-phy: phy blk 1001 is bad
[ 3.975026] sunxi-spinand-phy: phy blk 1003 is bad
[ 3.980554] sunxi-spinand-phy: phy blk 1005 is bad
[ 3.986052] sunxi-spinand-phy: phy blk 1007 is bad
[ 3.991576] sunxi-spinand-phy: phy blk 1009 is bad
[ 3.997085] sunxi-spinand-phy: phy blk 1011 is bad
[ 4.002612] sunxi-spinand-phy: phy blk 1013 is bad
[ 4.008116] sunxi-spinand-phy: phy blk 1015 is bad
[ 4.013640] sunxi-spinand-phy: phy blk 1017 is bad
[ 4.019141] sunxi-spinand-phy: phy blk 1019 is bad
[ 4.024667] sunxi-spinand-phy: phy blk 1021 is bad
[ 4.030192] sunxi-spinand-phy: phy blk 1023 is bad
[ 4.041404] libphy: Fixed MDIO Bus: probed
[ 4.045970] CAN device driver interface
[ 4.050868] sunxi-can can@0x0 (unnamed net_device) (uninitialized): request pinctrl handle fail!
[ 4.061389] sunxi-can can@0x0: can driver probe ok ...
[ 4.067455] sunxi-can can@0x1 (unnamed net_device) (uninitialized): request pinctrl handle fail!
[ 4.077893] sunxi-can can@0x1: can driver probe ok ...
[ 4.084534] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[ 4.093673] gmac-power0: NULL
[ 4.096976] gmac-power1: NULL
[ 4.100300] gmac-power2: NULL
[ 4.104759] Failed to alloc md5
[ 4.108267] eth0: Use random mac address
[ 4.113309] usbcore: registered new interface driver asix
[ 4.119405] usbcore: registered new interface driver ax88179_178a
[ 4.126356] usbcore: registered new interface driver cdc_ether
[ 4.132988] usbcore: registered new interface driver net1080
[ 4.139347] usbcore: registered new interface driver cdc_subset
[ 4.146109] usbcore: registered new interface driver zaurus
[ 4.152436] usbcore: registered new interface driver cdc_ncm
[ 4.158758] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 4.166046] sunxi-ehci: EHCI SUNXI driver
[ 4.171031] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.177956] sunxi-ohci: OHCI SUNXI driver
[ 4.183145] usbcore: registered new interface driver uas
[ 4.189138] usbcore: registered new interface driver usb-storage
[ 4.195957] usbcore: registered new interface driver ums-alauda
[ 4.202758] usbcore: registered new interface driver ums-cypress
[ 4.209550] usbcore: registered new interface driver ums-datafab
[ 4.216299] usbcore: registered new interface driver ums_eneub6250
[ 4.223258] usbcore: registered new interface driver ums-freecom
[ 4.230036] usbcore: registered new interface driver ums-isd200
[ 4.236677] usbcore: registered new interface driver ums-jumpshot
[ 4.243545] usbcore: registered new interface driver ums-karma
[ 4.250113] usbcore: registered new interface driver ums-onetouch
[ 4.256967] usbcore: registered new interface driver ums-realtek
[ 4.263749] usbcore: registered new interface driver ums-sddr09
[ 4.270423] usbcore: registered new interface driver ums-sddr55
[ 4.277089] usbcore: registered new interface driver ums-usbat
[ 4.284679] input: sunxi-ts as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 4.294584] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[ 4.306728] sunxi-rtc 7090000.rtc: registered as rtc0
[ 4.312569] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:37 UTC (37)
[ 4.321552] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 4.327601] i2c /dev entries driver
[ 4.331752] IR NEC protocol handler initialized
[ 4.336794] IR RC5(x/sz) protocol handler initialized
[ 4.343218] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
[ 4.353338] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
[ 4.363066] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
[ 4.372680] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
[ 4.384424] usbcore: registered new interface driver uvcvideo
[ 4.390859] USB Video Class driver (1.1.1)
[ 4.395445] gspca_main: v2.14.0 registered
[ 4.400014] sunxi cedar version 1.1
[ 4.404109] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 4.410429] VE: sunxi_cedar_probe power-domain init!!!
[ 4.416155] VE: install start!!!
[ 4.416155]
[ 4.421721] VE: cedar-ve the get irq is 43
[ 4.421721]
[ 4.428186] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 4.428186]
[ 4.437417] VE: install end!!!
[ 4.437417]
[ 4.442487] VE: sunxi_cedar_probe
[ 4.447694] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 4.456908] Bluetooth: HCI UART driver ver 2.3
[ 4.461913] Bluetooth: HCI UART protocol H4 registered
[ 4.467939] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 4.475226] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 4.481610] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 4.488116] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 4.488116]
[ 4.496834] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 4.506196] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 4.516065] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 4.522297] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 4.528597] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 4.535019] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 4.541425] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 4.547910] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 4.554418] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 4.560922] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 4.567905] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 4.573626] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.584745] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 4.604832] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.628990] sunxi-mmc 4020000.sdmmc: detmode:gpio polling
[ 4.635058] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 4.646710] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
[ 4.656563] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 4.662782] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 4.669078] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 4.675498] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 4.681904] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 4.688394] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 4.694900] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 4.701401] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 4.707916] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 4.717364] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.728499] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 4.748617] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.772793] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 4.780449] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 4.787765] usbcore: registered new interface driver usbhid
[ 4.794000] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
[ 4.800870] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.809465] usbhid: USB HID core driver
[ 4.815479] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 4.816669] exFAT: Version 1.3.0
[ 4.830270] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.832365] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ...
[ 4.839451] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.846130] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok...
[ 4.853471] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.860485] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver 2.1.2
[ 4.867527] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
[ 4.873512] sunxi-rproc 3000008.dsp_rproc: failed to get firmware-name
[ 4.880220] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 4.887964] remoteproc remoteproc0: dsp_rproc is available
[ 4.904717] sunxi-rproc 3000008.dsp_rproc: sunxi rproc driver probe ok
[ 4.912858] sunxi-rpbuf-controller rpbuf_controller@0: assigned reserved memory node dsp0_rpbuf@42244000
[ 4.923722] sunxi-rpbuf-controller rpbuf_controller@0: rpbuf_register_ctrl_dev:827
[ 4.936217] [AUDIOCODEC][sunxi_codec_parse_params][2437]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 4.936217]
[ 4.953318] [AUDIOCODEC][sunxi_codec_parse_params][2473]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 4.964686] [AUDIOCODEC][sunxi_internal_codec_probe][2634]:codec probe finished
[ 4.974029] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 4.983815] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 4.991104] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 5.002205] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input2
[ 5.014306] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 5.023173] NET: Registered protocol family 10
[ 5.029282] Segment Routing with IPv6
[ 5.029516] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[ 5.033518] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 5.049077] NET: Registered protocol family 17
[ 5.054158] NET: Registered protocol family 15
[ 5.059132] can: controller area network core (rev 20170425 abi 9)
[ 5.066133] NET: Registered protocol family 29
[ 5.071099] can: raw protocol (rev 20170425)
[ 5.075863] can: broadcast manager protocol (rev 20170425 t)
[ 5.082188] can: netlink gateway (rev 20190810) max_hops=1
[ 5.088742] Bluetooth: RFCOMM TTY layer initialized
[ 5.094238] Bluetooth: RFCOMM socket layer initialized
[ 5.100079] Bluetooth: RFCOMM ver 1.11
[ 5.105090] Registering SWP/SWPB emulation handler
[ 5.110979] Loading compiled-in X.509 certificates
[ 5.135460] sunxi-i2c 2502800.twi: 2502800.twi supply twi not found, using dummy regulator
[ 5.146172] sunxi-i2c 2502800.twi: probe success
[ 5.153395] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
[ 5.190903] get drvvbus-en is fail, 22
[ 5.195111] get ehci0-controller wakeup-source is fail.
[ 5.201159] sunxi ehci0-controller don't init wakeup source
[ 5.207438] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c94ca0, 0x:f16e3000, irq_no:3b
[ 5.219453] [sunxi-ehci0]: Not init ehci0
[ 5.224379] get drvvbus-en is fail, 22
[ 5.228584] get ohci0-controller wakeup-source is fail.
[ 5.234565] sunxi ohci0-controller don't init wakeup source
[ 5.240853] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c94f50
[ 5.250515] [sunxi-ohci0]: Not init ohci0
[ 5.255420] get drvvbus-en is fail, 22
[ 5.259667] get ehci1-controller wakeup-source is fail.
[ 5.265622] sunxi ehci1-controller don't init wakeup source
[ 5.271888] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c95200, 0x:f16ed000, irq_no:3d
[ 5.284142] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 5.297611] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 5.304890] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 5.314804] sunxi-ehci 4200000.ehci1-controller: irq 61, io mem 0x04200000
[ 5.349461] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 5.358167] hub 1-0:1.0: USB hub found
[ 5.362444] hub 1-0:1.0: 1 port detected
[ 5.367691] get drvvbus-en is fail, 22
[ 5.371923] get ohci1-controller wakeup-source is fail.
[ 5.377941] sunxi ohci1-controller don't init wakeup source
[ 5.384208] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c954b0
[ 5.394149] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 5.406521] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 5.413793] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 5.423675] sunxi-ohci 4200400.ohci1-controller: irq 62, io mem 0x04200400
[ 5.504330] hub 2-0:1.0: USB hub found
[ 5.508601] hub 2-0:1.0: 1 port detected
[ 5.515026] ubi0: attaching mtd3
[ 5.519130] ubi0: scanning is finished
[ 5.523415] ubi0: empty MTD device detected
[ 5.528169] ubi0 error: ubi_early_get_peb: no free eraseblocks
[ 5.534754] ubi0 error: ubi_attach_mtd_dev: failed to attach mtd3, error -28
[ 5.542712] UBI error: cannot attach mtd3
[ 5.547209] UBI: block: can't open volume on ubi0_-1, err=-19
[ 5.554204] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
[ 5.571321] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
[ 5.578960] sunxi-vin-core 5809200.vinc: Adding to iommu group 0
[ 5.587153] sun8iw20-pinctrl pio: pin PE13 already requested by 4500000.eth; cannot claim for pio:141
[ 5.597562] sun8iw20-pinctrl pio: pin-141 (pio:141) status -22
[ 5.604467] [VIN_WARN]get csi isp clk fail
[ 5.609088] [VIN_WARN]get csi isp src clk fail
[ 5.614096] [VIN_WARN]get csi mipi clk fail
[ 5.618784] [VIN_WARN]get csi mipi src clk fail
[ 5.624064] [VIN_WARN]get csi isp mbus clk fail
[ 5.629157] [VIN_WARN]Get isp reset control fail
[ 5.634561] [VIN_ERR]n5 request i2c1 adapter failed!
[ 5.643237] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.649600] [SNDCODEC][sunxi_check_hs_detect_status][191]:plugin --> switch:3
[ 5.654483] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.667472] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.669454] clk: Not disabling unused clocks
[ 5.677192] cfg80211: failed to load regulatory.db
[ 5.681965] ALSA device list:
[ 5.690656] #0: audiocodec
[ 5.693890] alloc_fd: slot 0 not NULL!
[ 5.698463] /dev/root: Can't open blockdev
[ 5.703114] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -6
[ 5.712017] Please append a correct "root=" boot option; here are the available partitions:
[ 5.721420] 1f00 1024 mtdblock0
[ 5.721423] (driver?)
[ 5.728746] 1f01 3072 mtdblock1
[ 5.728748] (driver?)
[ 5.736089] 1f02 1024 mtdblock2
[ 5.736092] (driver?)
[ 5.743433] 1f03 125952 mtdblock3
[ 5.743436] (driver?)
[ 5.750768] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 5.760033] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #14
[ 5.766760] Hardware name: Generic DT based system
[ 5.772149] [<c010e2f8>] (unwind_backtrace) from [<c010a8bc>] (show_stack+0x10/0x14)
[ 5.780833] [<c010a8bc>] (show_stack) from [<c0795ab0>] (dump_stack+0x7c/0x98)
[ 5.788933] [<c0795ab0>] (dump_stack) from [<c0119d2c>] (panic+0x104/0x3dc)
[ 5.796743] [<c0119d2c>] (panic) from [<c0b01278>] (mount_block_root+0x258/0x300)
[ 5.805133] [<c0b01278>] (mount_block_root) from [<c0b014bc>] (prepare_namespace+0x118/0x178)
[ 5.814692] [<c0b014bc>] (prepare_namespace) from [<c07aa194>] (kernel_init+0x8/0x118)
[ 5.823569] [<c07aa194>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 5.832041] Exception stack(0xef079fb0 to 0xef079ff8)
[ 5.837701] 9fa0: 00000000 00000000 00000000 00000000
[ 5.846867] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.856032] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 5.863451] CPU1: stopping
[ 5.866483] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #14
[ 5.873211] Hardware name: Generic DT based system
[ 5.878583] [<c010e2f8>] (unwind_backtrace) from [<c010a8bc>] (show_stack+0x10/0x14)
[ 5.887264] [<c010a8bc>] (show_stack) from [<c0795ab0>] (dump_stack+0x7c/0x98)
[ 5.895361] [<c0795ab0>] (dump_stack) from [<c010c6b0>] (handle_IPI+0xc0/0x168)
[ 5.903557] [<c010c6b0>] (handle_IPI) from [<c03a7134>] (gic_handle_irq+0x70/0x78)
[ 5.912044] [<c03a7134>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[ 5.920428] Exception stack(0xef09bf80 to 0xef09bfc8)
[ 5.926089] bf80: 00004dc0 ef7c8574 00000000 c0115280 00000002 ef09a000 c0c03e28 c0c03e64
[ 5.935256] bfa0: 4000406a 410fc075 00000000 00000000 c0c79830 ef09bfd0 c0107fd8 c0107fdc
[ 5.944419] bfc0: 60000113 ffffffff
[ 5.948331] [<c01021cc>] (__irq_svc) from [<c0107fdc>] (arch_cpu_idle+0x2c/0x38)
[ 5.956624] [<c0107fdc>] (arch_cpu_idle) from [<c013e920>] (do_idle+0xb8/0x120)
[ 5.964818] [<c013e920>] (do_idle) from [<c013ec24>] (cpu_startup_entry+0x18/0x1c)
[ 5.973303] [<c013ec24>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
[ 5.981124] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---最近编辑记录 memory (2024-02-21 21:16:27)
怎么那么多坏的?
请问楼主这个问题解决了吗?我遇到了类似的问题,附件为启动日志,请专家指导一下。
最近编辑记录 zx2132 (2024-10-27 20:08:43)
@zx2132
[ 2.397788] 0x000000500000-0x000008000000 : "sys"
[ 2.465305] sunxi-spinand-phy: phy blk 245 is bad
[ 2.528048] sunxi-spinand-phy: phy blk 440 is bad
[ 2.589057] sunxi-spinand-phy: phy blk 635 is bad
[ 2.648875] sunxi-spinand-phy: phy blk 830 is bad
[ 6.117168] VFS: Cannot open root device "ubi0_3" or unknown-block(0,0): error -19
[ 6.125666] Please append a correct "root=" boot option; here are the available partitions:
[ 6.135105] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)换片 flash 试一试
问题已解决,需要把内核设备树中spi-nand节点下的是spi-rx-bus-width及spi-tx-bus-width改成1。
