近来用国产的ARM起来越多了,想着把TRACE32利用起来,调试、抓取数据非常的方便,花了一周的时间找资料,验证算法,终于搞定了。
// Ver 1.0
// 2022.04.02 1、新建文件。
//#include "stdio.h"
//参数块定义
typedef struct{
unsigned int flashaddr; //0x800,芯片起始地址
unsigned int flashwidth; //0x804,1=8bit,2=16bit,4=32bit
unsigned int width; //0x808,数据总线位宽
unsigned int offset; //0x80c,
unsigned int addr; //0x810,FLASH操作地址
unsigned int size; //0x814,擦除、写入字节数
unsigned int reserved; //0x818,
unsigned int status; //0x81c,in: 1=program, 2=erase, 5=chip erase, out: 0=o.k., 0x100=fail
unsigned char data[4096]; //0x820,缓冲区起始地址
}FlashParameter_Str;
//关键地址,TRACE32的数据交互都在这个结构体里面
static FlashParameter_Str FlashParameter __attribute__((at(0x20000800)));
#define FLASH_PAGE_SIZE 512
enum{
FLASH_PROGRAM = 0x01,
FLASH_ERASE = 0x02,
FLASH_CHIP_ERASE = 0x05,
#define FMC_FLPROT *(unsigned int *)(0x40020000UL + 0x20)
#define FMC_FLOPMD1 *(unsigned int *)(0x40020000UL + 0x04)
#define FMC_FLOPMD2 *(unsigned int *)(0x40020000UL + 0x08)
#define FMC_FLSTS *(unsigned int *)(0x40020000UL + 0x00)
#define FMC_FLERMD *(unsigned int *)(0x40020000UL + 0x0c)
#define FMC_FLSTS_OVF_Msk 0x01
#define SCB_VTOR *(unsigned int *)(0xE000E000UL + 0x0D00UL + 0x08)
//关键行,把main函数放到RAM首地址,找到这个问题花了不少时间。
#pragma arm section code = ".ARM.__at_0x20000000"
int main(void)
unsigned int errCnt = 65535;
unsigned int tMs;
unsigned int i;
unsigned char *ptr,*buf;
while(1)
switch(FlashParameter.status)
case FLASH_PROGRAM:
ptr = (unsigned char *)FlashParameter.addr;
buf = &FlashParameter.data[0];
if(FlashParameter.size > 0xffff)
FlashParameter.size = 0xffff;
FMC_FLPROT = 0xF1;
for(i=0; i<FLASH_PAGE_SIZE; i++)
FMC_FLOPMD1 = 0xAA;
FMC_FLOPMD2 = 0x55;
*ptr++ = *buf++;
// polling OVER Flag
while((FMC_FLSTS & FMC_FLSTS_OVF_Msk) == 0);
FMC_FLSTS |= FMC_FLSTS_OVF_Msk;
FMC_FLPROT = 0x00;
FlashParameter.status = 0;
return(0);
break;
case FLASH_ERASE:
FMC_FLERMD = 0x10;
FMC_FLPROT = 0xF1;
FMC_FLOPMD1 = 0x55;
FMC_FLOPMD2 = 0xAA;
// Write data to start address of sector to trigger Erase Operation
*(unsigned int *) FlashParameter.addr = 0xFFFFFFFF;
// polling Erase Over Flag
FMC_FLERMD = 0x00;
FMC_FLPROT = 0x00;
return(0);
break;
case FLASH_CHIP_ERASE:
FMC_FLERMD = 0x08;
FMC_FLPROT = 0xF1;
FMC_FLOPMD1 = 0x55;
FMC_FLOPMD2 = 0xAA;
*(unsigned char *) FlashParameter.addr = 0xff;
FMC_FLPROT = 0x00;
return(0);
break;
default:
tMs = 65535;
while(tMs--);
break;
if(errCnt > 0) errCnt--;
else return(1);
#pragma arm section离线
土豪,问一下,用这个算法可以把调试Tricore的变成调试Arm核的吗?
trace32调试什么芯片,换对应的头子就可以了,楼上有Tricore的头子?我没有用过tricore的芯片不太清楚,手上还有两个支持arm的头子,也许可以交换一下
哦,我这是公司的工具,个人用不起,确实好用。
个人可以弄个山寨的,原装货价格确实高了点
用trace32来调试mcu有点奢侈啊
trace32的特点:
贵
支持CPU多
逼格高
但调试MCU,真没jlink之流方便.
楼主太厉害了!请问下下载算法的资料能分享下吗?
搞MCU开发JLINK是比较方便。很多都是拿来做逆向的,IDA+TRACE32,直接修改完调试,没更方便的了
大神接受我的膝盖
大佬,问一下相关资料,或者官方的模板在哪能找到
官方没有提供模板,从网上查找的文档自己写的
我去把公司的头子拿来拆开看看?
mysteryli wrote:
这东西还有山寨版的?我们大量需要
山寨版的只有二手的了,那家公司已经被抓了。手上还有几个,挂咸鱼上了。
