楼主 # 2026-01-30 12:10:44
xuuu
已发帖子: 20
为什么全志的mipi屏幕读到设备id了 却不亮屏是怎么回事
设备树:
lcd0_1: lcd0_1@01c0c00f {
			lcd_used            = <1>;
			lcd_driver_name     = "NV3052_BV055HDL_NB6_720X1280";
			lcd_backlight       = <50>;
			lcd_if              = <4>;
			lcd_x               = <720>;
			lcd_y               = <1280>;
			lcd_width           = <108>;
			lcd_height          = <172>;
			lcd_dclk_freq       = <64>;
			lcd_pwm_used        = <0>;
			lcd_pwm_ch          = <0>;
			lcd_pwm_freq        = <50000>;
			lcd_pwm_pol         = <1>;
			lcd_pwm_max_limit   = <255>;
			lcd_hbp             = <44>;
			lcd_ht              = <814>;
			lcd_hspw            = <4>;
			lcd_vbp             = <14>;
			lcd_vt              = <1314>;
			lcd_vspw            = <4>;
			lcd_frm             = <0>;
			lcd_gamma_en        = <0>;
			lcd_bright_curve_en = <0>;
			lcd_cmap_en         = <0>;
			deu_mode            = <0>;
			lcdgamma4iep        = <22>;
			smart_color         = <90>;
			lcd_dsi_if          = <0>;
			lcd_dsi_lane        = <4>;
			lcd_dsi_format      = <0>;
			lcd_dsi_te          = <0>;
			lcd_dsi_eotp        = <0>;
			//lcd_pin_power = "dcdc1";
			lcd_power = "cldo4";
			lcd_power1 = "cldo3";
			lcd_power2 = "cldo1";
			lcd_gpio_0 = <&pio PD 22 1 0 3 1>; /* RESET - gpio_index=0 */
			lcd_gpio_1 = <&pio PB 7 1 0 3 1>;  /* 1.8V  - gpio_index=1 */
			lcd_gpio_2 = <&pio PB 5 1 0 3 1>;  /* 3.3V  - gpio_index=2 */
			lcd_gpio_3 = <&pio PB 6 1 0 3 1>;  /* VSP/VSN - gpio_index=3 */
			pinctrl-0           = <&dsi4lane_pins_a>;
			pinctrl-1           = <&dsi4lane_pins_b>;
			//lcd_bl_en 			= <&pio PD 23 1 0 3 1>;
			lcd_bl_0_percent    = <15>;
			lcd_bl_100_percent  = <100>;
kerne的驱动:
 * Allwinner SoCs display driver.
 * Copyright (c) 2020 Allwinnertech Co., Ltd.
 * Author: libairong <libairong@allwinnertech.com>
 * NV3052_BV055HDL_NB6_720X1280 panel driver
 * This file is licensed under the terms of the GNU General Public
 * License version 2.  This program is licensed "as is" without any
 * warranty of any kind, whether express or implied.
#include "NV3052_BV055HDL_NB6_720X1280.h"
#include "panels.h"
static void LCD_power_on(u32 sel);
static void LCD_power_off(u32 sel);
static void LCD_bl_open(u32 sel);
static void LCD_bl_close(u32 sel);
static void LCD_panel_init(u32 sel);
static void LCD_panel_exit(u32 sel);
#define panel_reset(val)     sunxi_lcd_gpio_set_value(sel, 0, val)  /* PD22 - RESET */
#define power_1v8(val)       sunxi_lcd_gpio_set_value(sel, 1, val)  /* PB7  - 1.8V */
#define power_3v3(val)       sunxi_lcd_gpio_set_value(sel, 2, val)  /* PB5  - 3.3V */
#define power_vspvsn(val)    sunxi_lcd_gpio_set_value(sel, 3, val)  /* PB6  - VSP/VSN */
static void
LCD_cfg_panel_info(struct panel_extend_para *info)
    printk("[LCD] %s: enter\n", __func__);
	u32 i = 0, j = 0;
	u32 items;
	u8 lcd_gamma_tbl[][2] = {
		{0, 0},
		{15, 15},
		{30, 30},
		{45, 45},
		{60, 60},
		{75, 75},
		{90, 90},
		{105, 105},
		{120, 120},
		{135, 135},
		{150, 150},
		{165, 165},
		{180, 180},
		{195, 195},
		{210, 210},
		{225, 225},
		{240, 240},
		{255, 255},
	u32 lcd_cmap_tbl[2][3][4] = {
			{LCD_CMAP_G0, LCD_CMAP_B1, LCD_CMAP_G2, LCD_CMAP_B3},
			{LCD_CMAP_B0, LCD_CMAP_R1, LCD_CMAP_B2, LCD_CMAP_R3},
			{LCD_CMAP_R0, LCD_CMAP_G1, LCD_CMAP_R2, LCD_CMAP_G3},
			{LCD_CMAP_B3, LCD_CMAP_G2, LCD_CMAP_B1, LCD_CMAP_G0},
			{LCD_CMAP_R3, LCD_CMAP_B2, LCD_CMAP_R1, LCD_CMAP_B0},
			{LCD_CMAP_G3, LCD_CMAP_R2, LCD_CMAP_G1, LCD_CMAP_R0},
	items = sizeof(lcd_gamma_tbl) / 2;
	for (i = 0; i < items - 1; i++) {
		u32 num = lcd_gamma_tbl[i + 1][0] - lcd_gamma_tbl[0];
		for (j = 0; j < num; j++) {
			u32 value = 0;
			value = lcd_gamma_tbl[1] + ((lcd_gamma_tbl[i + 1][1]
						- lcd_gamma_tbl[1]) * j) / num;
			info->lcd_gamma_tbl[lcd_gamma_tbl[0] + j] =
									(value << 16) + (value << 8) + value;
	info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16)
								+ (lcd_gamma_tbl[items - 1][1] << 8)
								+ lcd_gamma_tbl[items - 1][1];
	memcpy(info->lcd_cmap_tbl, lcd_cmap_tbl, sizeof(lcd_cmap_tbl));
    printk("[LCD] %s: exit\n", __func__);
static s32 LCD_open_flow(u32 sel)
    printk("[LCD] %s: sel=%d\n", __func__, sel);
	LCD_OPEN_FUNC(sel, LCD_power_on, 100); // open lcd power, and delay 50ms
	LCD_OPEN_FUNC(sel, LCD_panel_init, 200); // open lcd power, than delay 200ms
	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 50); // open lcd controller, and delay 100ms
	LCD_OPEN_FUNC(sel, LCD_bl_open, 0); // open lcd backlight, and delay 0ms
static s32 LCD_close_flow(u32 sel)
    printk("LCD_close_flow\n");
	LCD_CLOSE_FUNC(sel, LCD_bl_close, 200); // close lcd backlight, and delay 0ms
	LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 20); // close lcd controller, and delay 0ms
	LCD_CLOSE_FUNC(sel, LCD_panel_exit, 10); // open lcd power, than delay 200ms
	LCD_CLOSE_FUNC(sel, LCD_power_off, 500); // close lcd power, and delay 500ms
    printk("LCD_power_on\n");
	panel_reset(0);
	sunxi_lcd_delay_ms(5);
	sunxi_lcd_power_enable(sel, 0); // config lcd_power pin to open lcd power
	sunxi_lcd_power_enable(sel, 1); // config lcd_power pin to open lcd power1
	sunxi_lcd_power_enable(sel, 2); // config lcd_power pin to open lcd power2
	panel_reset(0);
	power_vspvsn(0);
	power_1v8(0);
	sunxi_lcd_delay_ms(50);
	power_3v3(1);
	power_1v8(1);
	sunxi_lcd_delay_ms(10);
	power_vspvsn(1);
	panel_reset(1);
	panel_reset(0);
	panel_reset(1);
	sunxi_lcd_pin_cfg(sel, 1);
    printk("LCD_power_off\n");
	sunxi_lcd_pin_cfg(sel, 0);
	power_vspvsn(0);
	power_1v8(0);
	power_3v3(0);
	sunxi_lcd_delay_ms(20);
	panel_reset(0);
	sunxi_lcd_power_disable(sel, 2); // config lcd_power pin to close lcd power2
	sunxi_lcd_power_disable(sel, 1); // config lcd_power pin to close lcd power1
	sunxi_lcd_power_disable(sel, 0); // config lcd_power pin to close lcd power
    printk("[LCD] %s: PWM enable\n", __func__);
	sunxi_lcd_pwm_enable(sel);
	sunxi_lcd_backlight_enable(sel); // config lcd_bl_en pin to open lcd backlight
    printk("LCD_bl_close\n");
	sunxi_lcd_backlight_disable(sel); // config lcd_bl_en pin to close lcd backlight
	sunxi_lcd_pwm_disable(sel);
#define REGFLAG_DELAY						0XFE
#define REGFLAG_END_OF_TABLE				0xFD   // END OF REGISTERS MARKER
struct LCM_setting_table {
	u8 cmd;
	u32 count;
	u8 para_list[64];
/* add panel initialization below */
static struct LCM_setting_table lcm_initialization_setting[] = {
//----------NV305F+BOE5.5(BV055HDL-NB6) Initial------------------
    {REGFLAG_DELAY, REGFLAG_DELAY, {120}},
    {0xFF,0x01,{0x30}},
    {0xFF,0x01,{0x52}},
    {0xFF,0x01,{0x01}},
    {0xE3,0x01,{0x04}},
    {0x08,0x01,{0x0e}},
    {0x25,0x01,{0x10}},
    {0x28,0x01,{0x5F}},
    {0x2C,0x01,{0x22}},
    {0x30,0x01,{0x58}},
    {0x45,0x01,{0x91}},
    {0x37,0x01,{0x9C}},
    {0x38,0x01,{0xA7}},
    {0x39,0x01,{0x27}},
    {0x44,0x01,{0x00}},
    {0x49,0x01,{0x1C}},
    {0x59,0x01,{0xFE}},
    {0x5C,0x01,{0x00}},
    {0x91,0x01,{0x77}},
    {0x92,0x01,{0x77}},
    {0xA0,0x01,{0x55}},
    {0xA1,0x01,{0x50}},
    {0xA3,0x01,{0x58}},
    {0xA4,0x01,{0x9C}},
    {0xA7,0x01,{0x02}},
    {0xA8,0x01,{0x01}},
    {0xA9,0x01,{0x01}},
    {0xAA,0x01,{0xFC}},
    {0xAB,0x01,{0x28}},
    {0xAC,0x01,{0x06}},
    {0xAD,0x01,{0x06}},
    {0xAE,0x01,{0x06}},
    {0xAF,0x01,{0x03}},
    {0xB0,0x01,{0x08}},
    {0xB1,0x01,{0x26}},
    {0xB2,0x01,{0x28}},
    {0xB3,0x01,{0x28}},
    {0xB4,0x01,{0x03}},
    {0xB5,0x01,{0x08}},
    {0xB6,0x01,{0x26}},
    {0xB7,0x01,{0x08}},
    {0xB8,0x01,{0x26}},
    {0xc0,0x01,{0x00}},
    {0xc1,0x01,{0x00}},
    {0xc3,0x01,{0x0F}},
    {0xFF,0x01,{0x30}},
    {0xFF,0x01,{0x52}},
    {0xFF,0x01,{0x02}},
    {0xB0,0x01,{0x00}},
    {0xB1,0x01,{0x05}},
    {0xB2,0x01,{0x02}},
    {0xB3,0x01,{0x24}},
    {0xB4,0x01,{0x25}},
    {0xB5,0x01,{0x30}},
    {0xB6,0x01,{0x0C}},
    {0xB7,0x01,{0x27}},
    {0xB8,0x01,{0x0F}},
    {0xB9,0x01,{0x05}},
    {0xBA,0x01,{0x11}},
    {0xBB,0x01,{0x10}},
    {0xBC,0x01,{0x11}},
    {0xBD,0x01,{0x12}},
    {0xBE,0x01,{0x17}},
    {0xBF,0x01,{0x0C}},
    {0xC0,0x01,{0x14}},
    {0xC1,0x01,{0x0A}},
    {0xD0,0x01,{0x08}},
    {0xD1,0x01,{0x0F}},
    {0xD2,0x01,{0x09}},
    {0xD3,0x01,{0x35}},
    {0xD4,0x01,{0x38}},
    {0xD5,0x01,{0x3D}},
    {0xD6,0x01,{0x1B}},
    {0xD7,0x01,{0x3B}},
    {0xD8,0x01,{0x0F}},
    {0xD9,0x01,{0x05}},
    {0xDA,0x01,{0x11}},
    {0xDB,0x01,{0x10}},
    {0xDC,0x01,{0x11}},
    {0xDD,0x01,{0x14}},
    {0xDE,0x01,{0x19}},
    {0xDF,0x01,{0x11}},
    {0xE0,0x01,{0x19}},
    {0xE1,0x01,{0x09}},
    {0xFF,0x01,{0x30}},
    {0xFF,0x01,{0x52}},
    {0xFF,0x01,{0x03}},
    {0x08,0x01,{0x8B}},
    {0x09,0x01,{0x8A}},
    {0x0A,0x01,{0x89}},
    {0x0B,0x01,{0x88}},
    {0x34,0x01,{0x61}},
    {0x35,0x01,{0xD4}},
    {0x36,0x01,{0x24}},
    {0x37,0x01,{0x03}},
    {0x40,0x01,{0x8B}},
    {0x41,0x01,{0x8A}},
    {0x42,0x01,{0x89}},
    {0x43,0x01,{0x88}},
    {0x45,0x01,{0x01}},
    {0x46,0x01,{0x02}},
    {0x48,0x01,{0x03}},
    {0x49,0x01,{0x04}},
    {0x50,0x01,{0x87}},
    {0x51,0x01,{0x86}},
    {0x52,0x01,{0x85}},
    {0x53,0x01,{0x84}},
    {0x55,0x01,{0x05}},
    {0x56,0x01,{0x06}},
    {0x58,0x01,{0x07}},
    {0x59,0x01,{0x08}},
    {0x80,0x01,{0x0F}},
    {0x81,0x01,{0x0E}},
    {0x82,0x01,{0x07}},
    {0x83,0x01,{0x06}},
    {0x84,0x01,{0x05}},
    {0x85,0x01,{0x04}},
    {0x92,0x01,{0x0E}},
    {0x93,0x01,{0x0F}},
    {0x94,0x01,{0x01}},
    {0x95,0x01,{0x00}},
    {0x96,0x01,{0x0F}},
    {0x97,0x01,{0x0E}},
    {0x98,0x01,{0x07}},
    {0x99,0x01,{0x06}},
    {0x9A,0x01,{0x05}},
    {0x9B,0x01,{0x04}},
    {0xA8,0x01,{0x0E}},
    {0xA9,0x01,{0x0F}},
    {0xAA,0x01,{0x01}},
    {0xAB,0x01,{0x00}},
    {0xE0,0x01,{0x02}},
    {0xE1,0x01,{0x52}},
    {0xFF,0x01,{0x30}},
    {0xFF,0x01,{0x52}},
    {0xFF,0x01,{0x00}},
    {0x35,0x01,{0x00}},
    {0x36,0x01,{0x02}},
    {0x53,0x01,{0x2C}},
	{0x11, 0, {0x00}},
	{REGFLAG_DELAY, REGFLAG_DELAY, {200}},
	{0x29, 0, {0x00}},
	{REGFLAG_DELAY, REGFLAG_DELAY, {100}},
	{REGFLAG_END_OF_TABLE, REGFLAG_END_OF_TABLE, {0x00}}
    printk("[LCD] %s: uboot, first cmd=0x%02X\n", __func__,
           lcm_initialization_setting[0].cmd);
	__u32 i;
	char model_name[25];
	disp_sys_script_get_item("lcd0", "lcd_model_name", (int *) model_name, 25);
	sunxi_lcd_dsi_clk_enable(sel);
    sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_SOFT_RESET);
	for (i = 0; ; i++) {
		if (lcm_initialization_setting.count == REGFLAG_END_OF_TABLE)
			break;
		else if (lcm_initialization_setting.count == REGFLAG_DELAY)
			sunxi_lcd_delay_ms(lcm_initialization_setting.para_list[0]);
#ifdef SUPPORT_DSI
			dsi_dcs_wr(sel, lcm_initialization_setting.cmd,
						lcm_initialization_setting.para_list,
						lcm_initialization_setting.count);
		//break;
    printk("[LCD] %s: finish\n", __func__);
	return;
	sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_SET_DISPLAY_OFF);
	sunxi_lcd_dsi_dcs_write_0para(sel, DSI_DCS_ENTER_SLEEP_MODE);
    sunxi_lcd_delay_ms(80);
    return ;
// sel: 0:lcd0; 1:lcd1
static s32 LCD_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
 * static s32 LCD_set_bright(u32 sel, u32 bright)
 *	sunxi_lcd_dsi_dcs_write_1para(sel, 0x51, bright);
 *	return 0;
struct __lcd_panel NV3052_BV055HDL_NB6_720X1280_mipi_panel = {
	/* panel driver name, must mach the name of lcd_drv_name in sys_config.fex */
	.name = "NV3052_BV055HDL_NB6_720X1280",
	.func = {
		.cfg_panel_info = LCD_cfg_panel_info,
		.cfg_open_flow = LCD_open_flow,
		.cfg_close_flow = LCD_close_flow,
		.lcd_user_defined_func = LCD_user_defined_func,
		// .set_bright = LCD_set_bright,
uboot的驱动:
#include "panels.h"
static void
LCD_cfg_panel_info(panel_extend_para *info)
    printf("[LCD] %s: enter\n", __func__);
	u32 i = 0, j = 0;
	u32 items;
		{0, 0},
		{15, 15},
		{30, 30},
		{45, 45},
		{60, 60},
		{75, 75},
		{90, 90},
		{105, 105},
		{120, 120},
		{135, 135},
		{150, 150},
		{165, 165},
		{180, 180},
		{195, 195},
		{210, 210},
		{225, 225},
		{240, 240},
		{255, 255},
			u32 value = 0;
    printf("[LCD] %s: exit\n", __func__);
    printf("[LCD] %s: sel=%d\n", __func__, sel);
	LCD_OPEN_FUNC(sel, LCD_power_on, 0);
	// LCD_OPEN_FUNC(sel, LCD_panel_init1, 20);
    printf("LCD_close_flow\n");
    printf("LCD_power_on\n");
	// panel_reset(0);
	// sunxi_lcd_delay_ms(5);
	panel_reset(0);
	power_vspvsn(0);
	power_1v8(0);
	power_3v3(1);
	power_1v8(1);
	power_vspvsn(1);
	panel_reset(1);
	panel_reset(0);
	panel_reset(1);
    printf("LCD_power_off\n");
	power_vspvsn(0);
	power_1v8(0);
	power_3v3(0);
	panel_reset(0);
    printf("[LCD] %s: PWM enable\n", __func__);
    printf("LCD_bl_close\n");
	u8 cmd;
	u32 count;
	u8 para_list[64];
    {0xFF,0x01,{0x30}},
    {0xFF,0x01,{0x52}},
    {0xFF,0x01,{0x01}},
    {0xE3,0x01,{0x04}},
    {0x08,0x01,{0x0e}},
    {0x25,0x01,{0x10}},
    {0x28,0x01,{0x5F}},
    {0x2C,0x01,{0x22}},
    {0x30,0x01,{0x58}},
    {0x45,0x01,{0x91}},
    {0x37,0x01,{0x9C}},
    {0x38,0x01,{0xA7}},
    {0x39,0x01,{0x27}},
    {0x44,0x01,{0x00}},
    {0x49,0x01,{0x1C}},
    {0x59,0x01,{0xFE}},
    {0x5C,0x01,{0x00}},
    {0x91,0x01,{0x77}},
    {0x92,0x01,{0x77}},
    {0xA0,0x01,{0x55}},
    {0xA1,0x01,{0x50}},
    {0xA3,0x01,{0x58}},
    {0xA4,0x01,{0x9C}},
    {0xA7,0x01,{0x02}},
    {0xA8,0x01,{0x01}},
    {0xA9,0x01,{0x01}},
    {0xAA,0x01,{0xFC}},
    {0xAB,0x01,{0x28}},
    {0xAC,0x01,{0x06}},
    {0xAD,0x01,{0x06}},
    {0xAE,0x01,{0x06}},
    {0xAF,0x01,{0x03}},
    {0xB0,0x01,{0x08}},
    {0xB1,0x01,{0x26}},
    {0xB2,0x01,{0x28}},
    {0xB3,0x01,{0x28}},
    {0xB4,0x01,{0x03}},
    {0xB5,0x01,{0x08}},
    {0xB6,0x01,{0x26}},
    {0xB7,0x01,{0x08}},
    {0xB8,0x01,{0x26}},
    {0xc0,0x01,{0x00}},
    {0xc1,0x01,{0x00}},
    {0xc3,0x01,{0x0F}},
    {0xFF,0x01,{0x30}},
    {0xFF,0x01,{0x52}},
    {0xFF,0x01,{0x02}},
    {0xB0,0x01,{0x00}},
    {0xB1,0x01,{0x05}},
    {0xB2,0x01,{0x02}},
    {0xB3,0x01,{0x24}},
    {0xB4,0x01,{0x25}},
    {0xB5,0x01,{0x30}},
    {0xB6,0x01,{0x0C}},
    {0xB7,0x01,{0x27}},
    {0xB8,0x01,{0x0F}},
    {0xB9,0x01,{0x05}},
    {0xBA,0x01,{0x11}},
    {0xBB,0x01,{0x10}},
    {0xBC,0x01,{0x11}},
    {0xBD,0x01,{0x12}},
    {0xBE,0x01,{0x17}},
    {0xBF,0x01,{0x0C}},
    {0xC0,0x01,{0x14}},
    {0xC1,0x01,{0x0A}},
    {0xD0,0x01,{0x08}},
    {0xD1,0x01,{0x0F}},
    {0xD2,0x01,{0x09}},
    {0xD3,0x01,{0x35}},
    {0xD4,0x01,{0x38}},
    {0xD5,0x01,{0x3D}},
    {0xD6,0x01,{0x1B}},
    {0xD7,0x01,{0x3B}},
    {0xD8,0x01,{0x0F}},
    {0xD9,0x01,{0x05}},
    {0xDA,0x01,{0x11}},
    {0xDB,0x01,{0x10}},
    {0xDC,0x01,{0x11}},
    {0xDD,0x01,{0x14}},
    {0xDE,0x01,{0x19}},
    {0xDF,0x01,{0x11}},
    {0xE0,0x01,{0x19}},
    {0xE1,0x01,{0x09}},
    {0xFF,0x01,{0x30}},
    {0xFF,0x01,{0x52}},
    {0xFF,0x01,{0x03}},
    {0x08,0x01,{0x8B}},
    {0x09,0x01,{0x8A}},
    {0x0A,0x01,{0x89}},
    {0x0B,0x01,{0x88}},
    {0x34,0x01,{0x61}},
    {0x35,0x01,{0xD4}},
    {0x36,0x01,{0x24}},
    {0x37,0x01,{0x03}},
    {0x40,0x01,{0x8B}},
    {0x41,0x01,{0x8A}},
    {0x42,0x01,{0x89}},
    {0x43,0x01,{0x88}},
    {0x45,0x01,{0x01}},
    {0x46,0x01,{0x02}},
    {0x48,0x01,{0x03}},
    {0x49,0x01,{0x04}},
    {0x50,0x01,{0x87}},
    {0x51,0x01,{0x86}},
    {0x52,0x01,{0x85}},
    {0x53,0x01,{0x84}},
    {0x55,0x01,{0x05}},
    {0x56,0x01,{0x06}},
    {0x58,0x01,{0x07}},
    {0x59,0x01,{0x08}},
    {0x80,0x01,{0x0F}},
    {0x81,0x01,{0x0E}},
    {0x82,0x01,{0x07}},
    {0x83,0x01,{0x06}},
    {0x84,0x01,{0x05}},
    {0x85,0x01,{0x04}},
    {0x92,0x01,{0x0E}},
    {0x93,0x01,{0x0F}},
    {0x94,0x01,{0x01}},
    {0x95,0x01,{0x00}},
    {0x96,0x01,{0x0F}},
    {0x97,0x01,{0x0E}},
    {0x98,0x01,{0x07}},
    {0x99,0x01,{0x06}},
    {0x9A,0x01,{0x05}},
    {0x9B,0x01,{0x04}},
    {0xA8,0x01,{0x0E}},
    {0xA9,0x01,{0x0F}},
    {0xAA,0x01,{0x01}},
    {0xAB,0x01,{0x00}},
    {0xE0,0x01,{0x02}},
    {0xE1,0x01,{0x52}},
    {0xFF,0x01,{0x30}},
    {0xFF,0x01,{0x52}},
    {0xFF,0x01,{0x00}},
    {0x35,0x01,{0x00}},
    {0x36,0x01,{0x02}},
    {0x53,0x01,{0x2C}},
	{0x11, 0, {0x00}},
	{0x29, 0, {0x00}},
    printf("[LCD] %s: uboot, first cmd=0x%02X\n", __func__,
	__u32 i;
			break;
#ifdef SUPPORT_DSI
		//break;
    printf("[LCD] %s: finish\n", __func__);
	return;
    return ;
 *	return 0;
__lcd_panel_t NV3052_BV055HDL_NB6_720X1280_mipi_panel = {
	.func = {
日志打印:
Line 154: [LCD] LCD_open_flow: sel=0
	Line 155: [LCD] LCD_cfg_panel_info: enter
	Line 156: [LCD] LCD_cfg_panel_info: exit
	Line 159: [LCD] LCD_open_flow: sel=0
	Line 160: LCD_power_on
	Line 164: [LCD] LCD_open_flow: sel=0
	Line 165: [LCD] LCD_panel_try_switch: screen 0 - reading panel ID via DCS
	Line 166: [LCD] LCD_panel_try_switch: ID bytes = 18 32 41 (0x183241)
	Line 167: [LCD] LCD_open_flow: sel=0
	Line 168: [LCD] LCD_panel_init: uboot, first cmd=0xBB
	Line 169: [LCD] LCD_panel_init: finish
	Line 200: [LCD] LCD_open_flow: sel=0
	Line 204: [LCD] LCD_open_flow: sel=0
	Line 205: [LCD] LCD_bl_open: PWM enable
	Line 206: [LCD] LCD_open_flow: sel=0
	Line 207: [LCD] LCD_open_flow: sel=0
	Line 208: [06.652]LCD open finish
	Line 466: [    1.405376] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.smartbl_low_limit fail
	Line 467: [    1.414568] [DISP] disp_init_lcd,line:3243:disp_init_lcd
	Line 468: [    1.419837] [DISP] disp_init_lcd,line:3317:total number of clk in dsi:1
	Line 469: [    1.426242] [DISP] disp_init_lcd,line:3320:lcd 0, irq_no=362, irq_no_dsi=364
	Line 470: [    1.433263] [DISP] disp_lcd_init,line:2710:lcd 0
	Line 471: [    1.437845] [DISP] lcd_get_sys_config,line:360:lcd0 get sys config begin
	Line 472: [    1.444879] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_bl_en gpio=119,mul_sel=1,data:1
	Line 473: [    1.453190] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_bl_en_power fail
	Line 474: [    1.462462] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power fail
	Line 475: [    1.471564] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power1 fail
	Line 476: [    1.480749] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power2 fail
	Line 477: [    1.489936] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power3 fail
	Line 478: [    1.499637] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_power3 fail
	Line 479: [    1.507972] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_0 gpio=118,mul_sel=1,data:1
	Line 480: [    1.516553] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_1 gpio=39,mul_sel=1,data:1
	Line 481: [    1.525046] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_2 gpio=37,mul_sel=1,data:1
	Line 482: [    1.533539] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_3 gpio=38,mul_sel=1,data:1
	Line 483: [    1.542705] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power0 fail
	Line 484: [    1.551295] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power1 fail
	Line 485: [    1.560569] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power2 fail
	Line 486: [    1.569844] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power fail
	Line 487: [    1.578943] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power1 fail
	Line 488: [    1.588129] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power2 fail
	Line 489: [    1.597490] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_1_percent fail
	Line 490: [    1.606935] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_2_percent fail
	Line 491: [    1.616556] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_3_percent fail
	Line 492: [    1.626176] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_4_percent fail
	Line 493: [    1.635795] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_5_percent fail
	Line 494: [    1.645415] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_6_percent fail
	Line 495: [    1.655036] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_7_percent fail
	Line 496: [    1.664655] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_8_percent fail
	Line 497: [    1.674277] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_9_percent fail
	Line 498: [    1.683896] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_10_percent fail
	Line 499: [    1.693603] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_11_percent fail
	Line 500: [    1.703312] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_12_percent fail
	Line 501: [    1.713014] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_13_percent fail
	Line 502: [    1.722735] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_14_percent fail
	Line 503: [    1.732429] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_15_percent fail
	Line 504: [    1.742136] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_16_percent fail
	Line 505: [    1.751842] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_17_percent fail
	Line 506: [    1.761550] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_18_percent fail
	Line 507: [    1.771259] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_19_percent fail
	Line 508: [    1.780964] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_20_percent fail
	Line 509: [    1.790669] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_21_percent fail
	Line 510: [    1.800377] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_22_percent fail
	Line 511: [    1.810082] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_23_percent fail
	Line 512: [    1.819788] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_24_percent fail
	Line 513: [    1.829497] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_25_percent fail
	Line 514: [    1.839202] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_26_percent fail
	Line 515: [    1.848909] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_27_percent fail
	Line 516: [    1.858620] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_28_percent fail
	Line 517: [    1.868325] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_29_percent fail
	Line 518: [    1.878028] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_30_percent fail
	Line 519: [    1.887736] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_31_percent fail
	Line 520: [    1.897442] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_32_percent fail
	Line 521: [    1.907148] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_33_percent fail
	Line 522: [    1.916856] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_34_percent fail
	Line 523: [    1.926564] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_35_percent fail
	Line 524: [    1.936269] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_36_percent fail
	Line 525: [    1.945986] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_37_percent fail
	Line 526: [    1.955683] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_38_percent fail
	Line 527: [    1.965389] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_39_percent fail
	Line 528: [    1.975096] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_40_percent fail
	Line 529: [    1.984802] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_41_percent fail
	Line 530: [    1.994510] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_42_percent fail
	Line 531: [    2.004216] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_43_percent fail
	Line 532: [    2.013922] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_44_percent fail
	Line 533: [    2.023632] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_45_percent fail
	Line 534: [    2.033335] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_46_percent fail
	Line 535: [    2.043041] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_47_percent fail
	Line 536: [    2.052760] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_48_percent fail
	Line 537: [    2.062456] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_49_percent fail
	Line 538: [    2.072163] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_50_percent fail
	Line 539: [    2.081868] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_51_percent fail
	Line 540: [    2.091576] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_52_percent fail
	Line 541: [    2.101282] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_53_percent fail
	Line 542: [    2.110994] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_54_percent fail
	Line 543: [    2.120697] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_55_percent fail
	Line 544: [    2.130403] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_56_percent fail
	Line 545: [    2.140108] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_57_percent fail
	Line 546: [    2.149817] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_58_percent fail
	Line 547: [    2.159522] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_59_percent fail
	Line 548: [    2.169228] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_60_percent fail
	Line 549: [    2.178935] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_61_percent fail
	Line 550: [    2.188644] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_62_percent fail
	Line 551: [    2.198349] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_63_percent fail
	Line 552: [    2.208058] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_64_percent fail
	Line 553: [    2.217762] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_65_percent fail
	Line 554: [    2.227470] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_66_percent fail
	Line 555: [    2.237175] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_67_percent fail
	Line 556: [    2.246885] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_68_percent fail
	Line 557: [    2.256588] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_69_percent fail
	Line 558: [    2.266296] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_70_percent fail
	Line 559: [    2.276015] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_71_percent fail
	Line 560: [    2.285708] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_72_percent fail
	Line 561: [    2.295417] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_73_percent fail
	Line 562: [    2.305121] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_74_percent fail
	Line 563: [    2.314832] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_75_percent fail
	Line 564: [    2.324536] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_76_percent fail
	Line 565: [    2.334243] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_77_percent fail
	Line 566: [    2.343950] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_78_percent fail
	Line 567: [    2.353656] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_79_percent fail
	Line 568: [    2.363363] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_80_percent fail
	Line 569: [    2.373094] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_81_percent fail
	Line 570: [    2.382794] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_82_percent fail
	Line 571: [    2.392485] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_83_percent fail
	Line 572: [    2.402190] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_84_percent fail
	Line 573: [    2.411895] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_85_percent fail
	Line 574: [    2.421603] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_86_percent fail
	Line 575: [    2.431309] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_87_percent fail
	Line 576: [    2.441015] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_88_percent fail
	Line 577: [    2.450723] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_89_percent fail
	Line 578: [    2.460430] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_90_percent fail
	Line 579: [    2.470135] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_91_percent fail
	Line 580: [    2.479842] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_92_percent fail
	Line 581: [    2.489550] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_93_percent fail
	Line 582: [    2.499255] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_94_percent fail
	Line 583: [    2.508963] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_95_percent fail
	Line 584: [    2.518669] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_96_percent fail
	Line 585: [    2.528377] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_97_percent fail
	Line 586: [    2.538084] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_98_percent fail
	Line 587: [    2.547790] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_99_percent fail
	Line 588: [    2.557660] [DISP] lcd_get_sys_config,line:490:lcd0 sys config: used=1, bl_en_used=1, bl_en_power=, backlight=50
	Line 589: [    2.567468] [DISP] lcd_get_sys_config,line:496:lcd0 power[0]: used=1 name=cldo4, fix_used=0 fix=
	Line 590: [    2.576222] [DISP] lcd_get_sys_config,line:496:lcd0 power[1]: used=1 name=cldo3, fix_used=0 fix=
	Line 591: [    2.584974] [DISP] lcd_get_sys_config,line:496:lcd0 power[2]: used=1 name=cldo1, fix_used=0 fix=
	Line 592: [    2.593728] [DISP] lcd_get_sys_config,line:496:lcd0 power[3]: used=0 name=, fix_used=0 fix=
	Line 593: [    2.602048] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[0] used=1
	Line 594: [    2.608190] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[1] used=1
	Line 595: [    2.614354] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[2] used=1
	Line 596: [    2.620508] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[3] used=1
	Line 597: [    2.626662] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[4] used=0
	Line 598: [    2.632814] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[5] used=0
	Line 599: [    2.638957] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[6] used=0
	Line 600: [    2.645110] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[7] used=0
	Line 601: [    2.651264] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[0]= pin_power[0]=
	Line 602: [    2.658641] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[1]= pin_power[1]=
	Line 603: [    2.666008] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[2]= pin_power[2]=
	Line 604: [    2.675194] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_div fail
	Line 605: [    2.683480] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_if fail
	Line 606: [    2.692160] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_if fail
	Line 607: [    2.701020] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_mode fail
	Line 608: [    2.710375] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_colordepth fail
	Line 609: [    2.720254] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_io_polarity fail
	Line 610: [    2.730222] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_if fail
	Line 611: [    2.739334] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_te fail
	Line 612: [    2.748421] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_mode fail
	Line 613: [    2.758691] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_dsi_port_num fail
	Line 614: [    2.767315] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_mode fail
	Line 615: [    2.776675] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_slave_tcon_num fail
	Line 616: [    2.786468] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_slave_stop_pos fail
	Line 617: [    2.796262] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_sync_pixel_num fail
	Line 618: [    2.806067] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_sync_line_num fail
	Line 619: [    2.815763] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_en_odd_even_div fail
	Line 620: [    2.826086] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_en fail
	Line 621: [    2.835348] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_act_time fail
	Line 622: [    2.845143] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_dis_time fail
	Line 623: [    2.854935] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_pol fail
	Line 624: [    2.864297] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_clk_phase fail
	Line 625: [    2.873917] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_sync_polarity fail
	Line 626: [    2.883888] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_srgb_seq fail
	Line 627: [    2.893415] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_rb_swap fail
	Line 628: [    2.902602] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_syuv_seq fail
	Line 629: [    2.912134] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_syuv_fdly fail
	Line 630: [    2.922086] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_xtal_freq fail
	Line 631: [    2.931118] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_size fail
	Line 632: [    2.939782] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_model_name fail
	Line 635: [    2.965362] [DISP] lcd_clk_init,line:521:lcd 0 clk init
	Line 636: [    2.970728] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd1.lcd_used fail
	Line 676: [    3.211911] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name default_lcd
	Line 677: [    3.222839] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name lt070me05000
	Line 678: [    3.233841] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name wtq05027d01
	Line 679: [    3.244762] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name t27p06
	Line 680: [    3.255248] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name dx0960be40a1
	Line 681: [    3.266256] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name tft720x1280
	Line 682: [    3.277176] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name S6D7AA0X01
	Line 683: [    3.288008] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name gg1p4062utsw
	Line 684: [    3.299016] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name ls029b3sx02
	Line 685: [    3.309936] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name he0801a068
	Line 686: [    3.320768] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name inet_dsi_panel
	Line 687: [    3.331947] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name lq101r1sx03
	Line 688: [    3.342868] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name WilliamLcd
	Line 689: [    3.353704] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name fx070
	Line 690: [    3.364100] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name FX070_DHM18BOEL2_1024X600
	Line 691: [    3.376235] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name bp101wx1
	Line 692: [    3.386895] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name m133x56
	Line 693: [    3.397475] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name m133x56_two
	Line 694: [    3.408388] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name k101im2qa04
	Line 695: [    3.419318] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name k101im2byl02l
	Line 696: [    3.430401] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name lt8911ex
	Line 697: [    3.441060] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name K101_IM2BYL02_L_800X1280
	Line 698: [    3.453107] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name kd080d24
	Line 699: [    3.463769] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name k080_im2b801_h
	Line 700: [    3.474948] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name K080_IM2HYL802R_800X1280
	Line 701: [    3.486994] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name CC08021801_310_800X1280
	Line 702: [    3.498954] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name AXS1832_055FS01_720X1280
	Line 703: [    3.510836] [LCD] LCD_cfg_panel_info: enter
	Line 704: [    3.514998] [LCD] LCD_cfg_panel_info: exit
	Line 705: [    3.519069] [DISP] bsp_disp_lcd_set_panel_funs,line:1565:panel driver AXS1832_055FS01_720X1280 register
	Line 827: [    3.934899] [DISP] lcd_clk_config,line:684:clk_set_rate:dsi's 0 th clk with 150000000
	Line 828: [    3.934909] [DISP] lcd_clk_config,line:699:
	Line 831: [    3.934958] [DISP] cal_real_frame_period,line:605:lcd frame period:16770250
	Line 836: [    3.943448] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_0, gpio=118, <1,0,3,1>ret=0
	Line 837: [    3.943501] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_1, gpio=39, <1,0,3,1>ret=0
	Line 838: [    3.943527] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_2, gpio=37, <1,0,3,1>ret=0
	Line 839: [    3.943551] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_3, gpio=38, <1,0,3,1>ret=0
	Line 840: [    3.943577] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_bl_en, gpio=119, <1,0,3,1>ret=0
	Line 26851: [LCD] LCD_open_flow: sel=0
	Line 26852: [LCD] LCD_cfg_panel_info: enter
	Line 26853: [LCD] LCD_cfg_panel_info: exit
	Line 26856: [LCD] LCD_open_flow: sel=0
	Line 26857: LCD_power_on
	Line 26861: [LCD] LCD_open_flow: sel=0
	Line 26862: [LCD] LCD_panel_try_switch: screen 0 - reading panel ID via DCS
	Line 26863: [LCD] LCD_panel_try_switch: ID bytes = 18 32 41 (0x183241)
	Line 26864: [LCD] LCD_open_flow: sel=0
	Line 26865: [LCD] LCD_panel_init: uboot, first cmd=0xBB
	Line 26866: [LCD] LCD_panel_init: finish
	Line 26897: [05.488]update[LCD] LCD_open_flow: sel=0
	Line 26903: [LCD] LCD_open_flow: sel=0
	Line 26904: [LCD] LCD_bl_open: PWM enable
	Line 26905: [LCD] LCD_open_flow: sel=0
	Line 26906: [LCD] LCD_open_flow: sel=0
	Line 26907: [05.612]LCD open finish
	Line 27165: [    1.424442] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.smartbl_low_limit fail
	Line 27166: [    1.433662] [DISP] disp_init_lcd,line:3243:disp_init_lcd
	Line 27167: [    1.438937] [DISP] disp_init_lcd,line:3317:total number of clk in dsi:1
	Line 27168: [    1.445340] [DISP] disp_init_lcd,line:3320:lcd 0, irq_no=362, irq_no_dsi=364
	Line 27169: [    1.452361] [DISP] disp_lcd_init,line:2710:lcd 0
	Line 27170: [    1.456942] [DISP] lcd_get_sys_config,line:360:lcd0 get sys config begin
	Line 27171: [    1.463980] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_bl_en gpio=119,mul_sel=1,data:1
	Line 27172: [    1.472289] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_bl_en_power fail
	Line 27173: [    1.481573] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power fail
	Line 27174: [    1.490660] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power1 fail
	Line 27175: [    1.499847] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power2 fail
	Line 27176: [    1.509033] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_fix_power3 fail
	Line 27177: [    1.518734] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_power3 fail
	Line 27178: [    1.527072] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_0 gpio=118,mul_sel=1,data:1
	Line 27179: [    1.535649] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_1 gpio=39,mul_sel=1,data:1
	Line 27180: [    1.544144] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_2 gpio=37,mul_sel=1,data:1
	Line 27181: [    1.552637] [DISP] disp_sys_script_get_item,line:237:lcd0.lcd_gpio_3 gpio=38,mul_sel=1,data:1
	Line 27182: [    1.561802] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power0 fail
	Line 27183: [    1.570394] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power1 fail
	Line 27184: [    1.579667] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_gpio_power2 fail
	Line 27185: [    1.588938] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power fail
	Line 27186: [    1.598041] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power1 fail
	Line 27187: [    1.607227] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_pin_power2 fail
	Line 27188: [    1.616585] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_1_percent fail
	Line 27189: [    1.626034] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_2_percent fail
	Line 27190: [    1.635656] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_3_percent fail
	Line 27191: [    1.645275] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_4_percent fail
	Line 27192: [    1.654904] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_5_percent fail
	Line 27193: [    1.664513] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_6_percent fail
	Line 27194: [    1.674136] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_7_percent fail
	Line 27195: [    1.683754] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_8_percent fail
	Line 27196: [    1.693373] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_9_percent fail
	Line 27197: [    1.702994] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_10_percent fail
	Line 27198: [    1.712701] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_11_percent fail
	Line 27199: [    1.722409] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_12_percent fail
	Line 27200: [    1.732115] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_13_percent fail
	Line 27201: [    1.741821] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_14_percent fail
	Line 27202: [    1.751526] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_15_percent fail
	Line 27203: [    1.761234] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_16_percent fail
	Line 27204: [    1.770941] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_17_percent fail
	Line 27205: [    1.780648] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_18_percent fail
	Line 27206: [    1.790355] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_19_percent fail
	Line 27207: [    1.800061] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_20_percent fail
	Line 27208: [    1.809767] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_21_percent fail
	Line 27209: [    1.819474] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_22_percent fail
	Line 27210: [    1.829180] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_23_percent fail
	Line 27211: [    1.838888] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_24_percent fail
	Line 27212: [    1.848594] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_25_percent fail
	Line 27213: [    1.858313] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_26_percent fail
	Line 27214: [    1.868006] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_27_percent fail
	Line 27215: [    1.877714] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_28_percent fail
	Line 27216: [    1.887422] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_29_percent fail
	Line 27217: [    1.897133] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_30_percent fail
	Line 27218: [    1.906835] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_31_percent fail
	Line 27219: [    1.916540] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_32_percent fail
	Line 27220: [    1.926247] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_33_percent fail
	Line 27221: [    1.935955] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_34_percent fail
	Line 27222: [    1.945661] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_35_percent fail
	Line 27223: [    1.955366] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_36_percent fail
	Line 27224: [    1.965074] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_37_percent fail
	Line 27225: [    1.974778] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_38_percent fail
	Line 27226: [    1.984487] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_39_percent fail
	Line 27227: [    1.994196] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_40_percent fail
	Line 27228: [    2.003900] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_41_percent fail
	Line 27229: [    2.013608] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_42_percent fail
	Line 27230: [    2.023314] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_43_percent fail
	Line 27231: [    2.033021] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_44_percent fail
	Line 27232: [    2.042729] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_45_percent fail
	Line 27233: [    2.052435] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_46_percent fail
	Line 27234: [    2.062141] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_47_percent fail
	Line 27235: [    2.071848] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_48_percent fail
	Line 27236: [    2.081566] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_49_percent fail
	Line 27237: [    2.091259] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_50_percent fail
	Line 27238: [    2.100969] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_51_percent fail
	Line 27239: [    2.110674] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_52_percent fail
	Line 27240: [    2.120381] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_53_percent fail
	Line 27241: [    2.130087] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_54_percent fail
	Line 27242: [    2.139794] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_55_percent fail
	Line 27243: [    2.149500] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_56_percent fail
	Line 27244: [    2.159207] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_57_percent fail
	Line 27245: [    2.168914] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_58_percent fail
	Line 27246: [    2.178620] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_59_percent fail
	Line 27247: [    2.188340] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_60_percent fail
	Line 27248: [    2.198032] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_61_percent fail
	Line 27249: [    2.207740] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_62_percent fail
	Line 27250: [    2.217447] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_63_percent fail
	Line 27251: [    2.227154] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_64_percent fail
	Line 27252: [    2.236860] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_65_percent fail
	Line 27253: [    2.246568] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_66_percent fail
	Line 27254: [    2.256274] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_67_percent fail
	Line 27255: [    2.265981] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_68_percent fail
	Line 27256: [    2.275687] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_69_percent fail
	Line 27257: [    2.285394] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_70_percent fail
	Line 27258: [    2.295107] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_71_percent fail
	Line 27259: [    2.304808] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_72_percent fail
	Line 27260: [    2.314516] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_73_percent fail
	Line 27261: [    2.324220] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_74_percent fail
	Line 27262: [    2.333928] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_75_percent fail
	Line 27263: [    2.343633] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_76_percent fail
	Line 27264: [    2.353340] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_77_percent fail
	Line 27265: [    2.363050] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_78_percent fail
	Line 27266: [    2.372754] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_79_percent fail
	Line 27267: [    2.382462] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_80_percent fail
	Line 27268: [    2.392168] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_81_percent fail
	Line 27269: [    2.401875] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_82_percent fail
	Line 27270: [    2.411592] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_83_percent fail
	Line 27271: [    2.421287] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_84_percent fail
	Line 27272: [    2.430996] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_85_percent fail
	Line 27273: [    2.440700] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_86_percent fail
	Line 27274: [    2.450408] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_87_percent fail
	Line 27275: [    2.460112] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_88_percent fail
	Line 27276: [    2.469821] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_89_percent fail
	Line 27277: [    2.479528] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_90_percent fail
	Line 27278: [    2.489236] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_91_percent fail
	Line 27279: [    2.498940] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_92_percent fail
	Line 27280: [    2.508647] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_93_percent fail
	Line 27281: [    2.518365] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_94_percent fail
	Line 27282: [    2.528060] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_95_percent fail
	Line 27283: [    2.537768] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_96_percent fail
	Line 27284: [    2.547474] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_97_percent fail
	Line 27285: [    2.557179] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_98_percent fail
	Line 27286: [    2.566888] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_bl_99_percent fail
	Line 27287: [    2.576763] [DISP] lcd_get_sys_config,line:490:lcd0 sys config: used=1, bl_en_used=1, bl_en_power=, backlight=50
	Line 27288: [    2.586566] [DISP] lcd_get_sys_config,line:496:lcd0 power[0]: used=1 name=cldo4, fix_used=0 fix=
	Line 27289: [    2.595319] [DISP] lcd_get_sys_config,line:496:lcd0 power[1]: used=1 name=cldo3, fix_used=0 fix=
	Line 27290: [    2.604072] [DISP] lcd_get_sys_config,line:496:lcd0 power[2]: used=1 name=cldo1, fix_used=0 fix=
	Line 27291: [    2.612826] [DISP] lcd_get_sys_config,line:496:lcd0 power[3]: used=0 name=, fix_used=0 fix=
	Line 27292: [    2.621146] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[0] used=1
	Line 27293: [    2.627288] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[1] used=1
	Line 27294: [    2.633442] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[2] used=1
	Line 27295: [    2.639606] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[3] used=1
	Line 27296: [    2.645759] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[4] used=0
	Line 27297: [    2.651912] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[5] used=0
	Line 27298: [    2.658055] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[6] used=0
	Line 27299: [    2.664208] [DISP] lcd_get_sys_config,line:501:lcd0 gpio[7] used=0
	Line 27300: [    2.670361] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[0]= pin_power[0]=
	Line 27301: [    2.677739] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[1]= pin_power[1]=
	Line 27302: [    2.685106] [DISP] lcd_get_sys_config,line:507:lcd0 gpio_power[2]= pin_power[2]=
	Line 27303: [    2.694294] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_div fail
	Line 27304: [    2.702576] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_if fail
	Line 27305: [    2.711254] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_if fail
	Line 27306: [    2.720112] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_mode fail
	Line 27307: [    2.729472] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_colordepth fail
	Line 27308: [    2.739353] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_lvds_io_polarity fail
	Line 27309: [    2.749319] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_if fail
	Line 27310: [    2.758420] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_te fail
	Line 27311: [    2.767519] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_cpu_mode fail
	Line 27312: [    2.777791] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_dsi_port_num fail
	Line 27313: [    2.786416] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_mode fail
	Line 27314: [    2.795774] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_slave_tcon_num fail
	Line 27315: [    2.805565] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_slave_stop_pos fail
	Line 27316: [    2.815360] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_sync_pixel_num fail
	Line 27317: [    2.825152] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_sync_line_num fail
	Line 27318: [    2.834860] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_tcon_en_odd_even_div fail
	Line 27319: [    2.845174] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_en fail
	Line 27320: [    2.854446] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_act_time fail
	Line 27321: [    2.864239] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_dis_time fail
	Line 27322: [    2.874033] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_fsync_pol fail
	Line 27323: [    2.883393] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_clk_phase fail
	Line 27324: [    2.893014] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_sync_polarity fail
	Line 27325: [    2.902980] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_srgb_seq fail
	Line 27326: [    2.912513] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_rb_swap fail
	Line 27327: [    2.921710] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_syuv_seq fail
	Line 27328: [    2.931234] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_hv_syuv_fdly fail
	Line 27329: [    2.941184] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd0.lcd_xtal_freq fail
	Line 27330: [    2.950214] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_size fail
	Line 27331: [    2.958878] [DISP] disp_sys_script_get_item,line:214:of_property_read_string lcd0.lcd_model_name fail
	Line 27334: [    2.984460] [DISP] lcd_clk_init,line:521:lcd 0 clk init
	Line 27335: [    2.989816] [DISP] disp_sys_script_get_item,line:206:of_property_read_u32_array lcd1.lcd_used fail
	Line 27375: [    3.231010] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name default_lcd
	Line 27376: [    3.241935] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name lt070me05000
	Line 27377: [    3.252940] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name wtq05027d01
	Line 27378: [    3.263859] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name t27p06
	Line 27379: [    3.274346] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name dx0960be40a1
	Line 27380: [    3.285353] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name tft720x1280
	Line 27381: [    3.296274] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name S6D7AA0X01
	Line 27382: [    3.307105] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name gg1p4062utsw
	Line 27383: [    3.318112] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name ls029b3sx02
	Line 27384: [    3.329032] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name he0801a068
	Line 27385: [    3.339867] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name inet_dsi_panel
	Line 27386: [    3.351046] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name lq101r1sx03
	Line 27387: [    3.361965] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name WilliamLcd
	Line 27388: [    3.372799] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name fx070
	Line 27389: [    3.383201] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name FX070_DHM18BOEL2_1024X600
	Line 27390: [    3.395332] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name bp101wx1
	Line 27391: [    3.405994] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name m133x56
	Line 27392: [    3.416566] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name m133x56_two
	Line 27393: [    3.427487] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name k101im2qa04
	Line 27394: [    3.438407] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name k101im2byl02l
	Line 27395: [    3.449500] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name lt8911ex
	Line 27396: [    3.460159] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name K101_IM2BYL02_L_800X1280
	Line 27397: [    3.472206] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name kd080d24
	Line 27398: [    3.482868] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name k080_im2b801_h
	Line 27399: [    3.494045] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name K080_IM2HYL802R_800X1280
	Line 27400: [    3.506094] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name CC08021801_310_800X1280
	Line 27401: [    3.518053] [DISP] disp_lcd_set_panel_funs,line:2328:lcd 0, driver_name AXS1832_055FS01_720X1280,  panel_name AXS1832_055FS01_720X1280
	Line 27402: [    3.529933] [LCD] LCD_cfg_panel_info: enter
	Line 27403: [    3.534096] [LCD] LCD_cfg_panel_info: exit
	Line 27404: [    3.538167] [DISP] bsp_disp_lcd_set_panel_funs,line:1565:panel driver AXS1832_055FS01_720X1280 register
	Line 27525: [    3.957207] [DISP] lcd_clk_config,line:684:clk_set_rate:dsi's 0 th clk with 150000000
	Line 27526: [    3.957214] [DISP] lcd_clk_config,line:699:[    3.957221] disp 0, clk: pll(384000000),clk(384000000),dclk(64000000) dsi_rate(64000000)
	Line 27528: [    3.957265] [DISP] cal_real_frame_period,line:605:lcd frame period:16770250
	Line 27533: [    3.962337] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_0, gpio=118, <1,0,3,1>ret=0
	Line 27534: [    3.962391] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_1, gpio=39, <1,0,3,1>ret=0
	Line 27535: [    3.962416] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_2, gpio=37, <1,0,3,1>ret=0
	Line 27536: [    3.962440] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_3, gpio=38, <1,0,3,1>ret=0
	Line 27537: [    3.962466] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_bl_en, gpio=119, <1,0,3,1>ret=0
	Line 43967: [  264.585556] [DISP] disp_lcd_disable,line:2042:lcd 0
	Line 43968: [  264.591138] LCD_close_flow
	Line 43969: [  264.594251] LCD_bl_close
	Line 43972: [  264.637362] [DISP] disp_lcd_panel_close,line:1754:close flow:step 0 finish, to delay 200
	Line 43973: [  264.915205] [DISP] disp_lcd_panel_close,line:1754:close flow:step 1 finish, to delay 20
	Line 43974: [  265.051867] [DISP] disp_lcd_panel_close,line:1754:close flow:step 2 finish, to delay 10
	Line 43975: [  265.071857] LCD_power_off
	Line 43976: [  265.074908] [DISP] disp_lcd_pin_cfg,line:1004:lcd 0 pin config, state off, 0
	Line 43999: [  265.238754] [DISP] disp_lcd_panel_close,line:1754:close flow:step 3 finish, to delay 500
	Line 44041: [  265.755115] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_0, gpio=118, <7,0,3,1>ret=0
	Line 44042: [  265.755250] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_1, gpio=39, <7,0,3,1>ret=0
	Line 44043: [  265.755338] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_2, gpio=37, <7,0,3,1>ret=0
	Line 44044: [  265.755424] [DISP] disp_sys_gpio_request,line:280:disp_sys_gpio_request, gpio_name=lcd_gpio_3, gpio=38, <7,0,3,1>ret=0
屏幕是mipi的720*1280的NV3052_BV055HDL_NB6型号
楼主 #1 2026-02-05 13:44:01
xuuu
已发帖子: 20
Re: 为什么全志的mipi屏幕读到设备id了 却不亮屏是怎么回事
求助
#2 2026-02-06 12:52:48
hameyou
已发帖子: 259
还没解决吗?这种光看log也定位不到问题在哪里
楼主 #3 2026-02-06 18:44:59
xuuu
已发帖子: 20
那怎么解决 硬件没有问题 就是全志的a133的mipi屏幕710*1280的 我设置这个lcd_vspw和lcd_hspw 这两个值 我按规格书调的是2 但是改成4才不会卡 流程是正常 改成4之后 但是只有背光不亮屏 没有看见错误是怎么回事
#4 2026-02-09 01:44:39
grantho
已发帖子: 71
点亮了通知一下,这芯片我之前用A33也没点亮
楼主 #5 2026-02-09 20:32:21
xuuu
已发帖子: 20
我也没 我是这款型号的NV3052_BV055HDL_NB6 分辨率720*1280的
