char buffern[500];
TCPSocket *tcpsocketn;
rtos::Thread tcp_recv_thread,i2s_rx_thread;
void rx_thread(void)
while (true) {
printf("录音中..\r\n");
void tcp_recv(TCPSocket tcpsockets,char buffer, int Len)
{ uint16_t size=1;
int ret;
while(true){
do {
size = tcpsockets->recv(buffer,Len);
if (buffer <= 0) {
printf("ERROR: TCP recv erropr, len is %d !\r\n", size);
break;
printf("TCP send len is %s !\r\n",buffer);
}while (size > 0);
void tcp_connect(TCPSocket tcpsockets,char addressn, uint16_t port,NetworkInterface *net_iface)
{ int ret,size;
//tcpsocketn =new TCPSocket(net_iface);
SocketAddress address(addressn,port);
if (!address) {
printf("地址错误\r\n");
return;
ret = (int)tcpsockets->connect(address);
if(ret != 0){
printf("连接错误 = %d\r\n", ret);
return;
printf("连接成功!%d\r\n", ret);
void tcp_send(TCPSocket tcpsockets,char buffern,uint16_t Len)
int size=0;
size = tcpsockets->send("kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk",strlen("kkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkkk"));// - 1
if (size <= 0) {
printf("ERROR: TCP send error, len is %d !\r\n", size);
//break;
}else{
printf("TCP send len is %d !\r\n", size);
int main()
tcpsocketn =new TCPSocket(&wifi);
tcp_connect(tcpsocketn,"192.168.1.104",8090,&wifi);
tcp_send(tcpsocketn,"hhhhhhhhhh",500);
i2s_rx_thread.start(rx_thread);
tcp_recv_thread.start(tcp_recv,tcpsocketn,buffern,500);
while (true) {
aplay_wav("/sdc/mydir/14_00.wav");
rtos::Thread::wait(osWaitForever);
以上
tcp_recv_thread.start(tcp_recv,tcpsocketn,buffern,500);这行代码出错
"TESTS/TARGET_RDA/tcp/main.cpp", line 207: Error: #304: no instance of overload
ed function "rtos::Thread::start" matches the argument list
argument types are: (void (TCPSocket , char , int), TCPSocket *, c
har [500], int)
object type is: rtos::Thread
"TESTS/TARGET_RDA/tcp/main.cpp", line 221: Warning: #111-D: statement is unreac
hable
TESTS/TARGET_RDA/tcp/main.cpp: 5 warnings, 1 error
如果这样就i2s_rx_thread.start(rx_thread);就没出错,大神们这个是什么问题,
最近编辑记录 zhuacai (2018-12-06 11:19:37)
这两个函数定义分别是什么?
tcp_recv_thread.start(tcp_recv,tcpsocketn,buffern,500);这两个函数定义分别是什么?
上面两个代码都是启动一个线程,rx_thread是自己写没带参数的函数
,tcp_recv是自己写的带三个参数的函数
最近编辑记录 zhuacai (2018-12-06 17:05:43)
把 start 函数的定义贴出来,肯定是你传参数的类型不匹配。
晕哥,start 函数
osStatus Thread::start(Callback<void()> task) {
_mutex.lock();
if (_tid != 0) {
_mutex.unlock();
return osErrorParameter;
.start不能传有参数的函数么
以下是Thread类代码
#include "Thread.h"
#include "mbed.h"
#include "rtos_idle.h"
#undef NULL
#include "rt_TypeDef.h"
extern "C" P_TCB rt_tid2ptcb(osThreadId thread_id);
namespace rtos {
void Thread::constructor(osPriority priority,
uint32_t stack_size, unsigned char *stack_pointer) {
_tid = 0;
_dynamic_stack = (stack_pointer == NULL);
#if defined(__MBED_CMSIS_RTOS_CA9) || defined(__MBED_CMSIS_RTOS_CM)
_thread_def.tpriority = priority;
_thread_def.stacksize = stack_size;
_thread_def.stack_pointer = (uint32_t*)stack_pointer;
void Thread::constructor(Callback<void()> task,
osPriority priority, uint32_t stack_size, unsigned char *stack_pointer) {
constructor(priority, stack_size, stack_pointer);
switch (start(task)) {
case osErrorResource:
error("OS ran out of threads!");
break;
case osErrorParameter:
error("Thread already running!");
break;
case osErrorNoMemory:
error("Error allocating the stack memory");
default:
break;
_mutex.lock();
if (_tid != 0) {
_mutex.unlock();
_thread_def.pthread = Thread::_thunk;
if (_thread_def.stack_pointer == NULL) {
_thread_def.stack_pointer = new uint32_t[_thread_def.stacksize/sizeof(uint32_t)];
_mutex.unlock();
return osErrorNoMemory;
for (uint32_t i = 0; i < (_thread_def.stacksize / sizeof(uint32_t)); i++) {
_thread_def.stack_pointer = 0xE25A2EA5;
_task = task;
_tid = osThreadCreate(&_thread_def, this);
if (_tid == NULL) {
if (_dynamic_stack) delete[] (_thread_def.stack_pointer);
_mutex.unlock();
return osErrorResource;
_mutex.unlock();
return osOK;
osStatus Thread::terminate() {
osStatus ret;
_mutex.lock();
osThreadId local_id = _tid;
_join_sem.release();
_tid = (osThreadId)NULL;
ret = osThreadTerminate(local_id);
_mutex.unlock();
return ret;
osStatus Thread::join() {
int32_t ret = _join_sem.wait();
if (ret < 0) {
return osErrorOS;
_mutex.lock();
MBED_ASSERT(NULL == _tid);
_mutex.unlock();
return osOK;
osStatus Thread::set_priority(osPriority priority) {
osStatus ret;
_mutex.lock();
ret = osThreadSetPriority(_tid, priority);
_mutex.unlock();
return ret;
osPriority Thread::get_priority() {
osPriority ret;
_mutex.lock();
ret = osThreadGetPriority(_tid);
_mutex.unlock();
return ret;
int32_t Thread::signal_set(int32_t signals) {
return osSignalSet(_tid, signals);
int32_t Thread::signal_clr(int32_t signals) {
return osSignalClear(_tid, signals);
Thread::State Thread::get_state() {
#if !defined(__MBED_CMSIS_RTOS_CA9) && !defined(__MBED_CMSIS_RTOS_CM)
#ifdef CMSIS_OS_RTX
State status = Deleted;
_mutex.lock();
if (_tid != NULL) {
status = (State)_thread_def.tcb.state;
_mutex.unlock();
return status;
#else
_mutex.lock();
if (_tid != NULL) {
status = (State)osThreadGetState(_tid);
_mutex.unlock();
return status;
uint32_t Thread::stack_size() {
#ifndef __MBED_CMSIS_RTOS_CA9
#if defined(CMSIS_OS_RTX) && !defined(__MBED_CMSIS_RTOS_CM)
uint32_t size = 0;
_mutex.lock();
if (_tid != NULL) {
size = _thread_def.tcb.priv_stack;
_mutex.unlock();
return size;
#else
uint32_t size = 0;
_mutex.lock();
if (_tid != NULL) {
P_TCB tcb = rt_tid2ptcb(_tid);
size = tcb->priv_stack;
_mutex.unlock();
return size;
#else
uint32_t Thread::free_stack() {
uint32_t size = 0;
_mutex.lock();
if (_tid != NULL) {
uint32_t bottom = (uint32_t)_thread_def.tcb.stack;
size = _thread_def.tcb.tsk_stack - bottom;
_mutex.unlock();
return size;
#else
uint32_t size = 0;
_mutex.lock();
if (_tid != NULL) {
uint32_t bottom = (uint32_t)tcb->stack;
size = tcb->tsk_stack - bottom;
_mutex.unlock();
return size;
#else
uint32_t Thread::used_stack() {
uint32_t size = 0;
_mutex.lock();
if (_tid != NULL) {
uint32_t top = (uint32_t)_thread_def.tcb.stack + _thread_def.tcb.priv_stack;
size = top - _thread_def.tcb.tsk_stack;
_mutex.unlock();
return size;
#else
uint32_t size = 0;
_mutex.lock();
if (_tid != NULL) {
uint32_t top = (uint32_t)tcb->stack + tcb->priv_stack;
size = top - tcb->tsk_stack;
_mutex.unlock();
return size;
#else
uint32_t Thread::max_stack() {
uint32_t size = 0;
_mutex.lock();
if (_tid != NULL) {
uint32_t high_mark = 0;
while (_thread_def.tcb.stack[high_mark] == 0xE25A2EA5)
high_mark++;
size = _thread_def.tcb.priv_stack - (high_mark * 4);
_mutex.unlock();
return size;
#else
uint32_t size = 0;
_mutex.lock();
if (_tid != NULL) {
while (tcb->stack[high_mark] == 0xE25A2EA5)
high_mark++;
size = tcb->priv_stack - (high_mark * 4);
_mutex.unlock();
return size;
#else
osEvent Thread::signal_wait(int32_t signals, uint32_t millisec) {
return osSignalWait(signals, millisec);
osStatus Thread::wait(uint32_t millisec) {
return osDelay(millisec);
osStatus Thread::yield() {
return osThreadYield();
osThreadId Thread::gettid() {
return osThreadGetId();
void Thread::attach_idle_hook(void (*fptr)(void)) {
rtos_attach_idle_hook(fptr);
Thread::~Thread() {
terminate();
#ifdef __MBED_CMSIS_RTOS_CM
if (_dynamic_stack) {
void Thread::_thunk(const void * thread_ptr)
Thread t = (Thread)thread_ptr;
t->_task();
t->_mutex.lock();
t->_tid = (osThreadId)NULL;
t->_join_sem.release();
很明显只能传一个参数, 你传那么多肯定会编译错误,你看下别的demo怎么传其他参数,比如pthread创建线程的时候可以传一个指针进去。
晕哥,demo没有看到有传其他参数,这是一个RDA5981的sdk,不知怎么搞个
指针进去传进去
指针进去传进去
RDA5981 SDK 哪里有下载?有空我帮你看下.
指针进去传进去RDA5981 SDK 哪里有下载?有空我帮你看下.
先谢谢晕哥了,
链接:https://pan.baidu.com/s/1Ft6g4Z3FTFlckr7PIg-l2A 提取码:94m1 复制这段内容后打开百度网盘手机App,操作更方便哦
