电阻屏NS2009
tslib OK,ts_calibrate,ts_test可以正常运行。
littlevgl demo可以正常显示,但是,触摸 错误输出“ input input1: Poll touch data failed: ”
lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv); /Basic initialization/
evdev_init();
indev_drv.type = LV_INDEV_TYPE_POINTER; /See below./
indev_drv.read = evdev_read; /See below./
lv_indev_drv_register(&indev_drv); /Register the driver in LittlevGL/
/Handle LitlevGL tasks (tickless mode)/
while(1) {
lv_tick_inc(5);
lv_task_handler();
usleep(5000);
哪里配置还有问题
Mouse or touchpad as evdev interface (for Linux based systems)
#ifndef USE_EVDEV
#define USE_EVDEV 1
#if USE_EVDEV
#define EVDEV_NAME "/dev/input/event1" /You can use the "evtest" Linux tool to get the list of devices and test them/
#define EVDEV_SWAP_AXES 0 /Swap the x and y axes of the touchscreen/
#define EVDEV_SCALE 0 / Scale input, e.g. if touchscreen resolution does not match display resolution /
#if EVDEV_SCALE
#define EVDEV_SCALE_HOR_RES (800) / Horizontal resolution of touchscreen /
#define EVDEV_SCALE_VER_RES (480) / Vertical resolution of touchscreen /
#endif /EVDEV_SCALE/
#define EVDEV_CALIBRATE 0 /Scale and offset the touchscreen coordinates by using maximum and minimum values for each axis/
#if EVDEV_CALIBRATE
#define EVDEV_HOR_MIN 3800 /If EVDEV_XXX_MIN > EVDEV_XXX_MAX the XXX axis is automatically inverted/
#define EVDEV_HOR_MAX 200
#define EVDEV_VER_MIN 200
#define EVDEV_VER_MAX 3800
#endif /USE_EVDEV/
最近编辑记录 john78 (2018-12-07 14:37:14)
https://github.com/qq516333132/f1c100s_linux/blob/zero-4.13.y/drivers/input/touchscreen/ns2009.c
static void ns2009_ts_poll(struct input_polled_dev *dev)
struct ns2009_data *data = dev->private;
int ret;ret = ns2009_ts_report(data);
if (ret)
dev_err(&dev->input->dev, "Poll touch data failed: %d\n", ret);
没事没事, 只是 ns2009 驱动读到某次数据异常而已。
但是触摸不对啊,和画面对不上?
另外,这个怎么使用 tslib校准好的数据? /dev/input/event1--这个输出已经校准了吗?
这个需要怎么在LitlevGL中调用?
