typedefs.h文件
Copyright (c) 2012 The WebRTC project authors. All Rights Reserved.
Use of this source code is governed by a BSD-style license
that can be found in the LICENSE file in the root of the source
tree. An additional intellectual property rights grant can be found
in the file PATENTS. All contributing project authors may
be found in the AUTHORS file in the root of the source tree.
// This file contains platform-specific typedefs and defines.
// Much of it is derived from Chromium's build/build_config.h.
#ifndef WEBRTC_TYPEDEFS_H_
#define WEBRTC_TYPEDEFS_H_
// For access to standard POSIXish features, use WEBRTC_POSIX instead of a
// more specific macro.
#if defined(WEBRTC_MAC) || defined(WEBRTC_LINUX) || \
defined(WEBRTC_ANDROID)
#define WEBRTC_POSIX
// Processor architecture detection. For more info on what's defined, see:
// http://msdn.microsoft.com/en-us/library/b0084kay.aspx
// http://www.agner.org/optimize/calling_conventions.pdf
// or with gcc, run: "echo | gcc -E -dM -"
#if defined(_M_X64) || defined(__x86_64__)
#define WEBRTC_ARCH_X86_FAMILY
#define WEBRTC_ARCH_X86_64
#define WEBRTC_ARCH_64_BITS
#define WEBRTC_ARCH_LITTLE_ENDIAN
#elif defined(_M_IX86) || defined(__i386__)
#define WEBRTC_ARCH_32_BITS
#elif defined(__ARMEL__)
// TODO(ajm): We'd prefer to control platform defines here, but this is
// currently provided by the Android makefiles. Commented to avoid duplicate
// definition warnings.
//#define WEBRTC_ARCH_ARM
// TODO(ajm): Chromium uses the following two defines. Should we switch?
//#define WEBRTC_ARCH_ARM_FAMILY
//#define WEBRTC_ARCH_ARMEL
#elif defined(__MIPSEL__)
#else
#error Please add support for your architecture in typedefs.h
#if !(defined(WEBRTC_ARCH_LITTLE_ENDIAN) ^ defined(WEBRTC_ARCH_BIG_ENDIAN))
#error Define either WEBRTC_ARCH_LITTLE_ENDIAN or WEBRTC_ARCH_BIG_ENDIAN
#if defined(__SSE2__) || defined(_MSC_VER)
#define WEBRTC_USE_SSE2
#if !defined(_MSC_VER)
#include <stdint.h>
#else
// Define C99 equivalent types, since MSVC doesn't provide stdint.h.
typedef signed char int8_t;
typedef signed short int16_t;
typedef signed int int32_t;
typedef __int64 int64_t;
typedef unsigned char uint8_t;
typedef unsigned short uint16_t;
typedef unsigned int uint32_t;
typedef unsigned __int64 uint64_t;
// Borrowed from Chromium's base/compiler_specific.h.
// Annotate a virtual method indicating it must be overriding a virtual
// method in the parent class.
// Use like:
// virtual void foo() OVERRIDE;
#if defined(_MSC_VER)
#define OVERRIDE override
#elif defined(__clang__)
// Clang defaults to C++03 and warns about using override. Squelch that.
// Intentionally no push/pop here so all users of OVERRIDE ignore the warning
// too. This is like passing -Wno-c++11-extensions, except that GCC won't die
// (because it won't see this pragma).
#pragma clang diagnostic ignored "-Wc++11-extensions"
#elif defined(__GNUC__) && __cplusplus >= 201103 && \
(__GNUC__ 10000 + __GNUC_MINOR__ 100) >= 40700
// GCC 4.7 supports explicit virtual overrides when C++11 support is enabled.
#else
#define OVERRIDE
// Annotate a function indicating the caller must examine the return value.
// Use like:
// int foo() WARN_UNUSED_RESULT;
// TODO(ajm): Hack to avoid multiple definitions until the base/ of webrtc and
// libjingle are merged.
#if !defined(WARN_UNUSED_RESULT)
#if defined(__GNUC__)
#define WARN_UNUSED_RESULT __attribute__((warn_unused_result))
#else
#endif // WARN_UNUSED_RESULT
#endif // WEBRTC_TYPEDEFS_H_
报错信息:error Please add support for your architecture in typedefs.h
