楼主 #1 2019-02-25 17:55:16
刘少来了
已发帖子: 25
licheepi nano spi_flash启动时卡在 random: crng init done
按照官方文档一步步制作从 spi flash(16M)启动,最后卡在了random: crng init done,系统启动log如下,希望大神们帮帮忙
U-Boot 2018.01-05679-g013ca45-dirty (Feb 25 2019 - 16:03:42 +0800) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
Flattened Device Tree blob at 80c00000
Loading Device Tree to 80e5f000, end 80e640ee ... OK
[ 0.000000] Linux version 4.15.0-rc8-licheepi-nano+ (gsk@gsk-machine) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #4 Mon Feb 25 17:07:26 CST 2019
[ 0.000000] random: fast init done
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mtdblock3 rw rootfstype=jffs2
[ 0.000000] Memory: 22672K/32768K available (6144K kernel code, 237K rwdata, 1408K rodata, 1024K init, 246K bss, 10096K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc2800000 - 0xff800000 ( 976 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (7136 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 238 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 247 kB)
[ 0.000047] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000114] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000658] Console: colour dummy device 80x30
[ 0.000753] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070236] pid_max: default: 32768 minimum: 301
[ 0.070554] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070600] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072037] CPU: Testing write buffer coherency: ok
[ 0.073684] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.076243] devtmpfs: initialized
[ 0.083063] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.083133] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.083392] pinctrl core: initialized pinctrl subsystem
[ 0.085432] NET: Registered protocol family 16
[ 0.086900] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.088684] cpuidle: using governor menu
[ 0.115045] SCSI subsystem initialized
[ 0.115397] usbcore: registered new interface driver usbfs
[ 0.115544] usbcore: registered new interface driver hub
[ 0.115746] usbcore: registered new device driver usb
[ 0.116167] pps_core: LinuxPPS API ver. 1 registered
[ 0.116196] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.116256] PTP clock support registered
[ 0.116749] Advanced Linux Sound Architecture Driver Initialized.
[ 0.118266] clocksource: Switched to clocksource timer
[ 0.144929] NET: Registered protocol family 2
[ 0.146361] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.146442] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.146492] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.146780] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.146840] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.147322] NET: Registered protocol family 1
[ 0.148635] RPC: Registered named UNIX socket transport module.
[ 0.148678] RPC: Registered udp transport module.
[ 0.148695] RPC: Registered tcp transport module.
[ 0.148710] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.150905] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.152743] Initialise system trusted keyrings
[ 0.153293] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.170893] NFS: Registering the id_resolver key type
[ 0.170977] Key type id_resolver registered
[ 0.170999] Key type id_legacy registered
[ 0.171120] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.185626] Key type asymmetric registered
[ 0.185671] Asymmetric key parser 'x509' registered
[ 0.185883] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.185916] io scheduler noop registered
[ 0.185934] io scheduler deadline registered
[ 0.186705] io scheduler cfq registered (default)
[ 0.186740] io scheduler mq-deadline registered
[ 0.186758] io scheduler kyber registered
[ 0.187901] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.197593] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.369865] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.376631] console [ttyS0] disabled
[ 0.396891] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 24, base_baud = 6250000) is a 16550A
[ 0.870769] console [ttyS0] enabled
[ 0.881593] panel-simple panel: panel supply power not found, using dummy regulator
[ 0.891030] SCSI Media Changer driver v0.25
[ 0.896551] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.903208] ehci-platform: EHCI generic platform driver
[ 0.908774] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.914990] ohci-platform: OHCI generic platform driver
[ 0.920677] usbcore: registered new interface driver usb-storage
[ 0.927651] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 0.936718] i2c /dev entries driver
[ 0.998399] sunxi-mmc 1c0f000.mmc: base:0xcf63cb85 irq:20
[ 1.005805] usbcore: registered new interface driver usbhid
[ 1.011512] usbhid: USB HID core driver
[ 1.033531] NET: Registered protocol family 17
[ 1.038219] Key type dns_resolver registered
[ 1.044780] Loading compiled-in X.509 certificates
[ 1.060482] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc0739c38)
[ 1.069399] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0738f1c)
[ 1.077068] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.083787] [drm] No driver support for vblank timestamp query.
[ 1.099870] mmc0: queuing unknown CIS tuple 0x01 (3 bytes)
[ 1.107179] mmc0: queuing unknown CIS tuple 0x1a (5 bytes)
[ 1.110472] mmc0: queuing unknown CIS tuple 0x1b (8 bytes)
[ 1.113049] mmc0: queuing unknown CIS tuple 0x80 (1 bytes)
[ 1.113137] mmc0: queuing unknown CIS tuple 0x81 (1 bytes)
[ 1.113215] mmc0: queuing unknown CIS tuple 0x82 (1 bytes)
[ 1.113278] mmc0: new high speed SDIO card at address 0001
[ 1.137828] Console: switching to colour frame buffer device 60x34
[ 1.199632] sun4i-drm display-engine: fb0: frame buffer device
[ 1.206745] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.215971] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.227823] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.233793] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.243901] hub 1-0:1.0: USB hub found
[ 1.247853] hub 1-0:1.0: 1 port detected
[ 1.253535] using random self ethernet address
[ 1.258004] using random host ethernet address
[ 1.264335] usb0: HOST MAC 56:e3:00:0f:9a:57
[ 1.268908] usb0: MAC c6:02:fe:a8:80:44
[ 1.272877] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.280445] g_cdc gadget: g_cdc ready
[ 1.285118] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.302695] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.309515] ALSA device list:
[ 1.312498] #0: Loopback 1
[ 1.316253] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.325017] cfg80211: failed to load regulatory.db
[ 1.330499] Waiting for root device /dev/mtdblock3...
[ 203.198393] random: crng init done
#2 2019-02-25 18:35:47
jiangming1399
已发帖子: 113
Re: licheepi nano spi_flash启动时卡在 random: crng init done
https://whycan.cn/t_2179.html
看SPI-Flash支持的那一节
#3 2019-02-25 19:12:54
https://whycan.cn/t_2002.html#p13479
改成 root=31:01 试一试
楼主 #4 2019-02-26 09:12:19
刘少来了
已发帖子: 25
看SPI-Flash支持的那一节
谢谢了
楼主 #5 2019-02-26 09:14:18
刘少来了
已发帖子: 25
改成 root=31:01 试一试
这么改不行,我觉得应该是官网给的文件系统有问题,或者说内核哪里没有配置好,再去看看;)
#6 2019-03-05 00:24:47
小菜
已发帖子: 45
我今天也遇到了,除了更改跟MMC相关的东西外还有一个比较容易忽视的是“Fixed voltage regulator support”要选中。
Device Drivers ---> Voltage and Current Regulator Support ---> Fixed voltage regulator support;
Device Drivers ---> MMC/SD/SDIO card support ---> <*> HW reset support for eMMC
<*> Simple HW reset support for MMC
<*> MMC block device driver
(8) Number of minors per block device
刘少来了 wrote:
改成 root=31:01 试一试
楼主 #7 2019-03-05 09:04:55
刘少来了
已发帖子: 25
刘少来了 wrote:
改成 root=31:01 试一试
我之前出问题时这个已经配好了,我是参照 https://whycan.cn/t_2179.html 来改自己内核配置的,最后启动成功了
