楼主 #1 2018-07-17 18:05:25
已发帖子: 9,473
任性买了一片海豚派新的开发板和核心板
#2 2018-07-17 18:09:27
kaokao
已发帖子: 30
Re: 任性买了一片海豚派新的开发板和核心板
多少米入的,感觉这个比100S可玩性要高。
#3 2018-07-17 18:13:45
kaokao
已发帖子: 30
搜索了一下,279,我还是默默地折腾100S吧。
楼主 #4 2018-07-17 18:15:30
已发帖子: 9,473
为了挖坑,什么都试一下.
#5 2018-07-17 20:12:59
tom
已发帖子: 128
精神可嘉~~
我的红色海豚派,买来后都没有烧过一次程序。。。
楼主 #6 2018-07-17 22:49:09
已发帖子: 9,473
启动log:
HELLO! BOOT0 is starting!
get_ifm reg_val=7
===i2c gpio === 22777722
axp read fail, maybe no pmu
set pmu vol failed,maybe no pmu
DRAM DRIVE INFO: V0.7
DRAM Type = 2 (2:DDR2,3:DDR3,6:LPDDR2,7:LPDDR3)
DRAM CLK = 408 MHz
DRAM zq value: 000039bb
DRAM size = 64 MB
Succeed in reading Boot1 file head.
Jump to secend Boot.
[      0.092]
U-Boot 2011.09-rc1-00000-g79832e3-dirty (Jun 11 2018 - 23:00:05) Allwinner Technology
[      0.101]version: 1.1.0
[      0.108]pmbus:
ready
axp read error
probe axp20x failed
axp_probe fail,run clock=912
set power on vol to default
axp_set_power_supply_output dcdc2_vol = 1250
axp set dcdc2_vol to 1250 failed
axp_set_power_supply_output dcdc3_vol = 3300
axp set dcdc3_vol to 3300 failed
axp_set_power_supply_output aldo2_vol = 2500
axp set aldo2_vol to 2500 failed
axp_set_power_supply_output aldo3_vol = 3000
axp set aldo3_vol to 3000 failed
axp_set_power_supply_output ldo1_vol = 3300
axp set ldo1_vol to 3300 failed
axp_set_power_supply_output ldo2_vol = 3000
axp set ldo2_vol to 3000 failed
axp_set_power_supply_output ldo3_vol = 3000
axp set ldo3_vol to 3000 failed
[      0.175]DRAM:  64 MiB
[debug_jaosn]:use the clock in sys_config
OK
[      0.197]sunxi flash init ok
hello @flash_speed=1
env_relocate_spec storage_type = 3
In:    serial
Out:   serial
Err:   serial
WORK_MODE_BOOT
read bootlogo partition successful,start_block=0x75a0,rblock=0x100 ,ret=256
Use decode 2x2 sampling
sunxi_read_bootlogo: jpg convert argb
[      0.320]Hit any key to stop autoboot:  0
read boot or recovery all
try to read all
[      0.537]sunxi flash read :offset 4000, 3145728 bytes OK
## Booting kernel from Legacy Image at 40007fc0 ...
   Image Name:   Linux-3.4.39
   Data Size:    2533312 Bytes = 2.4 MiB
   Load Address: 40008000
   Entry Point:  40008000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
OK
[      0.591]
[    0.000000] Linux version 3.4.39 (harry@harry-virtual-machine) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #401 Sat Jul 14 21:31:19 CST 2018
[    0.000000] Machine: sun8i
[    0.000000] On node 0 totalpages: 16384
[    0.000000] free_area_init_node: node 0, pgdat c04f5ee4, node_mem_map c052b000
[    0.000000]   Normal zone: 128 pages used for memmap
[    0.000000]   Normal zone: 16256 pages, LIFO batch:3
[    0.000000] script_init enter!
[    0.000000] script_init exit!
[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mtdblock2 init=/linuxrc loglevel=8 partitions= mac_addr= uid=1234567890 kmemleak=on rootfstype=jffs2
[    0.000000] Memory: 29892k/29892k available, 35644k reserved, 0K highmem
[    0.000000]       .text : 0xc0008000 - 0xc0466000   (4472 kB)
[    0.000000]       .init : 0xc0466000 - 0xc0488000   ( 136 kB)
[    0.000000]       .data : 0xc0488000 - 0xc04f6600   ( 442 kB)
[    0.000000]        .bss : 0xc04f6624 - 0xc052ab24   ( 210 kB)
[    0.000000] NR_IRQS:544
[    0.000000] 524 ahb1 set parent pll_periph0d2
[    0.000162] Calibrating delay loop (skipped), value calculated using timer frequency.. 4800.00 BogoMIPS (lpj=24000000)
[    0.000185] pid_max: default: 32768 minimum: 301
[    0.000321] Mount-cache hash table entries: 512
[    0.000844] CPU: Testing write buffer coherency: ok
[    0.001098] Setting up static identity map for 0x40349148 - 0x403491a0
[    0.001748] devtmpfs: initialized
[    0.003646] pinctrl core: initialized pinctrl subsystem
[    0.003825] NET: Registered protocol family 16
[    0.004190] DMA: preallocated 128 KiB pool for atomic coherent allocations
[    0.004248] script_sysfs_init success
[    0.004281] sunxi_dump_init success
[    0.005070] gpiochip_add: registered GPIOs 0 to 223 on device: sunxi-pinctrl
[    0.005980] sunxi-pinctrl sunxi-pinctrl: initialized sunXi PIO driver
[    0.006631] tsc2003 device registered
[    0.006913] [sunxi-module]: [sunxi-module.0] probe success
[    0.006959] script config pll_isp to 360 Mhz
[    0.006991] Not Found clk pll_video in script
[    0.007006] script config pll_ve to 360 Mhz
[    0.007027] Not Found clk pll_periph0 in script
[    0.007036] Not Found clk pll_de in script
[    0.007043] sunxi_default_clk_init
[    0.007052] try to set pll6ahb1 to 200000000
[    0.007063] Error not get clk pll6ahb1
[    0.007075] Error not get clk pll6ahb1try to set ahb1 to 200000000
[    0.007097] try to set apb1 to 100000000
[    0.007385] ===fe3o4==== sunxi_root_procfs_attach ret:0
[    0.011054] bio: create slab <bio-0> at 0
[    0.011320] pwm module init!
[    0.012855] ion_mem.size = 30408704
[    0.013441] SCSI subsystem initialized
[    0.013669] usbcore: registered new interface driver usbfs
[    0.013742] usbcore: registered new interface driver hub
[    0.013889] usbcore: registered new device driver usb
[    0.014025] twi_chan_cfg()342 - [twi0] has no twi_speed!
[    0.014038] twi_chan_cfg()353 - [twi0] has no twi_regulator.
[    0.014050] twi_chan_cfg()342 - [twi1] has no twi_speed!
[    0.014060] twi_chan_cfg()353 - [twi1] has no twi_regulator.
[    0.014070] sunxi_i2c_adap_init()1563 - Sunxi I2C init channel 0
[    0.014211] ++sunxi_i2c_probe
[    0.014263] twi_request_gpio()406 - Pinctrl init 0 ... [twi0]
[    0.014373] twi_clk_write_reg()241 - twi_clk_write_reg: clk_n = 0, clk_m = 5
[    0.014514] sunxi_i2c_probe()1250 - I2C: i2c-0: sunxi I2C adapter
[    0.014533] sunxi_i2c_probe()1251 - TWI_CTL  0xf1c2ac0c: 0x00000040
[    0.014547] sunxi_i2c_probe()1252 - TWI_STAT 0xf1c2ac10: 0x000000f8
[    0.014561] sunxi_i2c_probe()1253 - TWI_CLK  0xf1c2ac14: 0x00000028
[    0.014575] sunxi_i2c_probe()1254 - TWI_SRST 0xf1c2ac18: 0x00000000
[    0.014588] sunxi_i2c_probe()1255 - TWI_EFR  0xf1c2ac1c: 0x00000000
[    0.014629] Linux video capture interface: v2.00
[    0.014817] Advanced Linux Sound Architecture Driver Version 1.0.25.
[    0.015715] cfg80211: Calling CRDA to update world regulatory domain
[    0.016700] Switching to clocksource arch_sys_counter
[    0.019959] NET: Registered protocol family 2
[    0.019959] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.020116] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[    0.020167] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    0.020197] TCP: Hash tables configured (established 2048 bind 2048)
[    0.020209] TCP: reno registered
[    0.020221] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.020243] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.020511] NET: Registered protocol family 1
[    0.020910] [pm]aw_pm_init!
[    0.020929] standby_mode = 1.
[    0.020937] wakeup src cnt is : 3.
[    0.020993] sunxi_reg_init enter
[    0.022681] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.022735] jffs2: version 2.2. (NAND) (SUMMARY)  漏 2001-2006 Red Hat, Inc.
[    0.022929] msgmni has been set to 58
[    0.023826] io scheduler noop registered
[    0.023840] io scheduler deadline registered
[    0.023914] io scheduler cfq registered (default)
[    0.023926] [DISP]disp_module_init
[    0.024385] cmdline,disp=
[    0.024931] disp_init_rotation_sw
[    0.024961] @@@rot-degree=0, scn_size[480,272]
[    0.025017] disp_rot_sw_set_manager,1209
[    0.025094] disp_fb_to_var:format = 0
[    0.025110] fb_para.width = 480,fb_para.height = 272,fb_para.buffer_num = 2
[    0.025126] gen_pool_alloc:nbits = 255,size = 1044480,order = 12
[    0.025138] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 30408704
[    0.025152] end_bit = 7424
[    0.028840] [DISP] disp_sys_gpio_set_value,line:374:OSAL_GPIO_DevWRITE_ONEPIN_DATA, hdl is NULL
[    0.029575] [DISP]disp_module_init finish
[    0.029869] sw_uart_get_devinfo()1503 - uart2 has no uart_regulator.
[    0.030279] uart2: ttyS0 at MMIO 0x1c28800 (irq = 34) is a SUNXI
[    0.030299] sw_uart_pm()890 - uart2 clk is already enable
[    0.030323] sw_console_setup()1233 - console setup baud 115200 parity n bits 8, flow n
[    0.222234] console [ttyS0] enabled
[    0.768842] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
[    0.776591] spi spi0: master is unqueued, this is deprecated
[    0.783054] m25p_probe()969 - Use the Dual Mode Read.
[    0.788763] NorFlash ID: 0xc22018 - 0xc220
[    0.793339] m25p80 spi0.0: found mx25l12805d, expected at25df641
[    0.800026] m25p80 spi0.0: mx25l12805d (16384 Kbytes)
[    0.807122] @@@[debug_jaosn]: Invalid partitions count: 4 9
[    0.813764] Creating 8 MTD partitions on "spi0.0":
[    0.819115] 0x000000000000-0x000000040000 : "uboot"
[    0.825691] 0x000000040000-0x000000340000 : "boot"
[    0.831928] 0x000000340000-0x000000e70000 : "system"
[    0.838300] 0x000000e70000-0x000000ef0000 : "cfg"
[    0.844447] 0x000000ef0000-0x000000f10000 : "boot_logo"
[    0.851210] 0x000000f10000-0x000000f30000 : "shutdown_logo"
[    0.858327] 0x000000f30000-0x000000f40000 : "env"
[    0.863624] [DISP] disp_lcd_pwm_enable,line:1022:pwm device hdl is NULL
[    0.871949] 0x000000f40000-0x000000f50000 : "private"
[    0.878824] priv->phy_ext = INT_PHY
[    0.883990] Failed to alloc md5
[    0.887553] eth0: Use random mac address
[    0.892025] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.919387] sunxi-ehci sunxi-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.928316] sunxi-ehci sunxi-ehci.1: new USB bus registered, assigned bus number 1
[    0.936840] sunxi-ehci sunxi-ehci.1: irq 104, io mem 0xf1c1a000
[    0.960032] sunxi-ehci sunxi-ehci.1: USB 0.0 started, EHCI 1.00
[    0.967313] hub 1-0:1.0: USB hub found
[    0.971605] hub 1-0:1.0: 1 port detected
[    0.976376] sunxi-ehci sunxi-ehci.1: remove, state 1
[    0.981934] usb usb1: USB disconnect, device number 1
[    1.282348] sunxi-ehci sunxi-ehci.1: USB bus 1 deregistered
[    1.298657] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.325629] sunxi-ohci sunxi-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
[    1.334171] sunxi-ohci sunxi-ohci.1: new USB bus registered, assigned bus number 1
[    1.342637] sunxi-ohci sunxi-ohci.1: irq 105, io mem 0xf1c1a400
[    1.404654] hub 1-0:1.0: USB hub found
[    1.408838] hub 1-0:1.0: 1 port detected
[    1.413673] sunxi-ohci sunxi-ohci.1: remove, state 1
[    1.419197] usb usb1: USB disconnect, device number 1
[    1.425430] sunxi-ohci sunxi-ohci.1: USB bus 1 deregistered
[    1.441752] Initializing USB Mass Storage driver...
[    1.447311] usbcore: registered new interface driver usb-storage
[    1.453999] USB Mass Storage support registered.
[    1.459430] file system registered
[    1.464827] android_usb gadget: Mass Storage Function, version: 2009/09/11
[    1.472513] android_usb gadget: Number of LUNs=1
[    1.477637]  lun0: LUN: removable file: (no medium)
[    1.483562] android_usb gadget: android_usb ready
[    1.488898] sunxikbd_script_init: key para not found, used default para.
[    1.496975] tsc2003_ts_init
[    1.500129] =====ctp_fetch_sysconfig_para=====.
[    1.505261] ctp_fetch_sysconfig_para: ctp_power_ldo script_get_item err.
[    1.512806] ctp_fetch_sysconfig_para: ctp_power_ldo_vol script_get_item err.
[    1.520741] ctp_fetch_sysconfig_para: ctp_power_io script_get_item err.
[    1.528175] script_get_item ctp_wakeup err
[    1.532735] ctp_irq gpio number is 36
[    1.536809] wakeup gpio_request is failed
[    1.541486] [RTC] WARNING: Rtc time will be wrong!!
[    1.547189] sunxi-rtc sunxi-rtc: rtc core: registered sunxi-rtc as rtc0
[    1.554754] sunxi cedar version 0.1
[    1.558754] [cedar]: install start!!!
[    1.563093] [cedar]: install end!!!
[    1.567017] sunxi_wdt_init_module: sunxi WatchDog Timer Driver v1.0
[    1.574185] sunxi_wdt_probe: devm_ioremap return wdt_reg 0xf1c20ca0, res->start 0x01c20ca0, res->end 0x01c20cbf
[    1.585388] sunxi_wdt_probe: initialized (g_timeout=16s, g_nowayout=0)
[    1.592847] wdt_enable, write reg 0xf1c20cb8 val 0x00000000
[    1.599033] wdt_set_tmout, write 0x000000b0 to mode reg 0xf1c20cb8, actual timeout 16 sec
[    1.608668] [mmc]: SD/MMC/SDIO Host Controller Driver(v1.114 2015-6-2 10:21) Compiled in Jul 14 2018 at 21:30:04
[    1.620051] [mmc]: get mmc0's sdc_power failed
[    1.624998] [mmc]: get mmc1's sdc_power failed
[    1.629933] [mmc]: MMC host used card: 0x3, boot card: 0x0, io_card 2
[    1.637946] [mmc]: sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.651148] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.663994] usbcore: registered new interface driver usbhid
[    1.670224] usbhid: USB HID core driver
[    1.675897] script_get_item return audio_pa_ctrl type err
[    1.682734] asoc: sndcodec <-> sunxi-codec mapping ok
[    1.690548] TCP: cubic registered
[    1.694240] NET: Registered protocol family 17
[    1.699380] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    1.707948] ThumbEE CPU extension supported.
[    1.712716] Registering SWP/SWPB emulation handler
[    1.719027] sunxi-rtc sunxi-rtc: hctosys: unable to read the hardware clock
[    1.728166] [wifi module_pm]: select module num is 6
[    1.733739] [wifi module_pm]: step [0] failed to fetch module_power0
[    1.740825] [wifi module_pm]: mod has no chip_en gpio
[    1.746428] [wifi module_pm]: failed to fetch lpo_use_apclk
[    1.753030] [wifi_pm]: wifi gpio init is OK !!
[    1.758028]
[    1.758032] *****Jul 14 2018 21:30:16 EAGLE DRIVER VER:75be56bfbaf7*****
[    1.758039]
[    1.768907] =======================================================
[    1.775892] ==== Launching Wi-Fi driver! (Powered by Dophin-PI) ====
[    1.782949] =======================================================
[    1.789907] Espressif ESP8089 SDIO WiFi driver (Powered by Dophin-PI, Ver2.25(01/22/2016),Drv: 2.26) init.
[    1.800642] [wifi_pm]: set wl_reg_on 1 !
[    1.905056] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.916264] [mmc]: sdc1 power_supply is null
[    1.940030] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    1.972350] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    1.981297] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    1.989428] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.002092] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.014176] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8,  RTO !!
[    2.022210] *******************Try sdio*******************
[    2.028609] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.054626] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    2.067813] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    2.077014] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    2.084047] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    2.094236] [mmc]: sdc1 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    2.104667] [mmc]: sdc1 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    2.115848] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    2.121991] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    2.128127] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    2.134244] mmc1: new high speed SDIO card at address 0001
[    2.140680] esp_sdio_dummy_probe enter
[    2.144997] *******************sdio init ok*******************
[    2.350024] esp_sdio_init power up OK
[    2.793594] esp_host:75be56bfbaf7
[    2.793602] esp_target: 2cefb7b78636 77 18204
[    2.793607]
[    2.803826] esp_readwrite_file: file /system/lib/modules/test_results filp_open error
[    2.812641] first normal exit
[    2.816028] esp_sdio_remove enter
[    2.819812] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    2.827980] sif_disable_irq release irq failed
[    2.833106] mmc1: card 0001 removed
[    2.837051] [mmc]: sdc1 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.847030] [mmc]: sdc1 power_supply is null
[    2.940091] ALSA device list:
[    2.943397]   #0: audiocodec
[    2.946791] [mmc]: sdc1 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    2.958106] [mmc]: sdc1 power_supply is null
[    2.980043] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.012377] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    3.021348] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 52,  RTO !!
[    3.029495] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.042289] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.054461] [mmc]: *** sunxi_mci_dump_errinfo(L826): smc 1 err, cmd 8,  RTO !!
[    3.062522] *******************Try sdio*******************
[    3.068922] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
[    3.094814] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[    3.108403] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    3.117742] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    3.124805] [mmc]: sdc1 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    3.135105] [mmc]: sdc1 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
[    3.145656] [mmc]: sdc1 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
[    3.157308] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    3.163625] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    3.169857] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    3.176071] mmc1: new high speed SDIO card at address 0001
[    3.561906] Wifi Efuse Mac => 18:fe:34:11:61:50
[    3.567016] esp_host:75be56bfbaf7
[    3.567022] esp_target: 2cefb7b78636 77 18204
[    3.567027]
[    3.579683] esp_sdio: initializing netlink
[    3.584502] *******************sdio init ok*******************
[    3.899575] VFS: Mounted root (jffs2 filesystem) on device 31:2.
[    3.906678] devtmpfs: mounted
[    3.910188] Freeing init memory: 136K
    XXXXX             XXX           XXX        XX                   XXXXXX    XXXX
     XX XX             XX            XX                              XX  XX    XX
     XX  XX  XXXXX     XX   XX XXX   XX XX    XXX   XX XXX           XX  XX    XX
     XX  XX XX   XX    XX    XX  XX  XXX XX    XX    XX  XX          XXXXX     XX
     XX  XX XX   XX    XX    XX  XX  XX  XX    XX    XX  XX          XX        XX
     XX XX  XX   XX    XX    XXXXX   XX  XX    XX    XX  XX          XX        XX
    XXXXX    XXXXX    XXXX   XX     XXX  XX   XXXX   XX  XX         XXXX      XXXX
                            XXXX
[    4.384689] misc fatfs initialized
[    4.414655] [VFE]cci probe start cci_sel = 0!
[    4.419535] [VFE]cci probe end cci_sel = 0!
[    4.424398] [VFE]cci_init end
[    4.451131] [VFE_DEV_CCI_DBG]cci init device
[    4.455915] [VFE_DEV_CCI_DBG]cci_subdev_init!
[    4.460799] [VFE_DEV_CCI_DBG]cci_dev_num_id = 1, name = ov2710_mipi, cci_subdev_init,sd pt=c19f31c0!
[    4.648448] [VFE]Welcome to Video Front End driver
[    4.654207] [VFE]pdev->id = 0
[    4.657501] [VFE]dev->mipi_sel = 0
[    4.661332] [VFE]dev->vip_sel = 0
[    4.665005] [VFE]dev->isp_sel = 0
[    4.674801] [VFE_WARN]vfe vpu clock is null
[    4.679474] gen_pool_alloc:nbits = 1,size = 4096,order = 12
[    4.685678] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 29364224
[    4.695296] end_bit = 7424
[    4.699618] gen_pool_alloc:nbits = 1,size = 4096,order = 12
[    4.705832] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 29360128
[    4.715413] end_bit = 7424
[    4.735134] [ISP] isp platform_id = 6!
[    4.739437] [VFE]vfe_init end
[    4.742782] [VFE]probe_work_handle start!
[    4.747251] [VFE]..........................vfe clk open!.......................
[    4.766268] dev->dev_qty = 1
[    4.769472] [VFE]v4l2 subdev register input_num = 0
[    4.774931] [VFE]vfe sensor detect start! input_num = 0
[    4.780766] [VFE]Find sensor name is "ov2710_mipi", i2c address is 6c, type is "RAW" !
[    4.789553] [VFE]Sub device register "ov2710_mipi" i2c_addr = 0x6c start!
[    4.797101] [VFE_DEV_CCI_DBG]try cci dev name =ov2710_mipi!
[    4.803293] [VFE_DEV_CCI_DBG]cci_drv->name = ov2710_mipi, check name = ov2710_mipi
[    4.811730] [VFE_DEV_CCI_DBG]cci_bus_match name matched!
[    4.817631] [VFE_DEV_CCI_DBG]sd = c19f31c0, cci_drv pt = bf0b02d0,id = 0,saddr = 36, name = ov2710_mipi
[    4.828067] [VFE]v4l2_device_register_subdev return 0
[    4.833682] [VFE]registered sensor subdev is OK!
[    4.838800] [VFE]Check sensor!
[    4.842191] [VFE]Sub device register "ov2710_mipi" is OK!
[    4.853858] [VFE]Check open /system/etc/hawkview/ov2710_mipi/isp_test_param.ini failed!
[    4.853875] Match isp cfg  start!
[    4.866567] [VFE]Match isp cfg ok
[    4.874209] [VFE]V4L2 device registered as video0
[    4.880084] [VFE]..........................vfe clk close!.......................
[    4.888810] [VFE]probe_work_handle end!
mknod: /dev/console: File exists
mknod: /dev/null: File exists
Processing /etc/profile... Done
/ # ++Camera test[    5.341070] [DISP] ready enter pm_runtime_get_sync, device0
[    5.374221] [VFE]vfe_open
[    5.377144] [VFE]..........................vfe clk open!.......................
[    5.385831] gen_pool_alloc:nbits = 1,size = 3584,order = 12
[    5.392068] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 29356032
[    5.401639] end_bit = 7424
[    5.404779] gen_pool_alloc:nbits = 1,size = 1536,order = 12
[    5.410999] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 29351936
[    5.420568] end_bit = 7424
[    5.423669] gen_pool_alloc:nbits = 3,size = 8448,order = 12
[    5.429865] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 29347840
[    5.439439] end_bit = 7424
[    5.442542] gen_pool_alloc:nbits = 3,size = 8448,order = 12
[    5.448725] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 29335552
[    5.458314] end_bit = 7424
[    5.461410] gen_pool_alloc:nbits = 3,size = 8448,order = 12
[    5.467605] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 29323264
[    5.477184] end_bit = 7424
[    5.480273] gen_pool_alloc:nbits = 3,size = 8448,order = 12
[    5.486456] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 29310976
[    5.496041] end_bit = 7424
[    5.499133] gen_pool_alloc:nbits = 3,size = 8448,order = 12
[    5.505341] chunk->start_addr = 0x42300000,chunk->end_addr = 0x43ffffffchunk->avail = 29298688
[    5.514917] end_bit = 7424
[    5.517999] [VFE]vfe_open ok
[    5.521600] [VFE]Set vfe core clk = 216000000, after Set vfe core clk = 180000000
[    5.542177] vfe_gpio_write:gpio_type = 2,status = 0
[    5.547610] os_gpio_write:set gpio 35 to 0
[    5.552175] os_gpio_write:set gpio 35 to 0
[    5.579967] vfe_gpio_write:gpio_type = 2,status = 1
[    5.585413] os_gpio_write:set gpio 35 to 1
[    5.589954] os_gpio_write:set gpio 35 to 1
[    5.594575] [VFE]mclk on
[    5.621732] [VFE CCI_0 ERR] Status error at addr_8bit = 6c, wr_flag = 1, val = 5c000a30
[    5.636051] [VFE CCI_0 ERR] Status error at addr_8bit = 6c, wr_flag = 1, val = 5c000a30
[    5.645428] [VFE CCI_0 ERR] Status error at addr_8bit = 6c, wr_flag = 1, val = 5c000a30
[    5.654793] [VFE CCI_0 ERR] Status error at addr_8bit = 6c, wr_flag = 1, val = 5c000a30
[    5.663714] [OV2710 Raw]error at sensor_detect
[    5.668641] [OV2710 Raw]chip found is not an target chip.
[    5.674639] [VFE_ERR]sensor initial error when selecting target device!
DP_StartDevice error![    5.682345] [VFE]vfe_close
DPCameraStart error = 1
把买的上一版本的摄像头和屏幕拿出来,仍然挺好用。
#7 2018-07-18 19:20:18
jlau
已发帖子: 215
谁整个S3的板来玩玩,全志V3+内置128M DDR3,性能、接口完胜V3S
楼主 #8 2018-07-18 19:49:36
已发帖子: 9,473
海豚派的S3开发板很快要推出了,
V3,V3s,S3共用一个die,
S3引出的引脚比较多,
多了一组DVP 摄像头, I2S,还内置128M ddr,
价格也贵不少。
#9 2018-07-18 21:16:48
v3s不会停产吧?还没玩转又来s3了。。。
楼主 #10 2018-07-18 21:20:43
已发帖子: 9,473
短期内不会停产,有一个做开发板的老外下一个约50k pcs的A20 订单复产。
#11 2018-07-18 22:20:19
kgp0213
已发帖子: 149
这个价格有点贵
#12 2018-07-19 07:56:20
lcfmax
已发帖子: 329
感觉V3S这种TQFP封装的,没必要做核心板
楼主 #13 2018-07-19 08:02:53
已发帖子: 9,473
做开发板的不能做一锤子买卖, 这个开发板封装了编解码器等,
然后在核心板上面挂了一个加密芯片,
他的SDK只能跑在他的核心板上面,就酱。
如果想在自己的板子跑他的视频编解码,也要买他的加密芯片。
#14 2018-07-19 09:35:37
然后在核心板上面挂了一个加密芯片,
你是说海豚派加密了,自己做板子用他的SDK跑不起来吗?
这样有点不敢买了
楼主 #15 2018-07-19 10:02:15
已发帖子: 9,473
对, 情况就是这样, 详情可以咨询一下他们店铺客服。
#16 2018-07-19 11:41:36
jlau
已发帖子: 215
海豚派的S3开发板很快要推出了,
V3,V3s,S3共用一个die,
S3引出的引脚比较多,
价格也贵不少。
询过价,好像5刀可以拿下
楼主 #17 2018-07-19 11:45:26
已发帖子: 9,473
那就是是贵一刀左右了,
S3 这种 BGA不太适合小公司和个人,
良品率怎么也赶不上螃蟹脚QFP封装,
1%的报废率也是很吓人的。
#18 2018-07-20 11:37:34
jlau
已发帖子: 215
那就是是贵一刀左右了,
良品率怎么也赶不上螃蟹脚QFP封装,
1%的报废率也是很吓人的。
晕哥老道
#19 2018-07-22 12:08:36
zhuacai
已发帖子: 234
/files/members/3/QQ20180717224459.jpeg
启动log:
get_ifm reg_val=7
DRAM CLK = 408 MHz
DRAM size = 64 MB
[      0.092]
[      0.108]pmbus:
ready
axp read error
probe axp20x failed
OK
In:    serial
Out:   serial
Err:   serial
WORK_MODE_BOOT
try to read all
OK
[      0.591]
[    1.758028]
[    1.758039]
[    2.793607]
[    3.567027]
                            XXXX
晕哥,这个什么时候写个入坑教程呀
楼主 #20 2018-07-22 12:13:46
已发帖子: 9,473
离成功不远了,改天整理一下。
用sunxi-fel 烧录,可以用lcd,摄像头等。
#21 2018-07-22 14:29:16
Mitko
已发帖子: 219
你会推荐这个模块还是Leechi Pi Zero? Leechi Pi Zero的价格上涨,最初为6美元,目前为11.70美元。
楼主 #22 2018-07-22 14:55:45
已发帖子: 9,473
推荐licheepi zero,售价升高是因为底板和核心板整合到一起了,据说可以私聊店主,问他要以前规格的核心板。
#23 2018-07-31 16:50:44
abc3240660
已发帖子: 100
前几天我也搞了一块
#24 2019-08-09 16:57:14
太一酱鸭
已发帖子: 154
启动log:
get_ifm reg_val=7
DRAM CLK = 408 MHz
DRAM size = 64 MB
[      0.092]
[      0.108]pmbus:
ready
axp read error
probe axp20x failed
OK
In:    serial
Out:   serial
Err:   serial
WORK_MODE_BOOT
try to read all
OK
[      0.591]
[    1.758028]
[    1.758039]
[    2.793607]
[    3.567027]
                            XXXX
一直错误搜索log,全搜到了晕哥这,关于这个摄像头的问题有解决吗晕哥
楼主 #25 2019-08-09 17:05:14
已发帖子: 9,473
摄像头检测没有通过?
感觉有问题
#26 2019-08-15 23:31:18
linhuaou
已发帖子: 35
核心板手册: dpc03_module_V1_2.pdf 这个打不开?
#27 2019-08-16 07:56:41
linhuaou
已发帖子: 35
今天打开了,昨天网络慢
楼主 #28 2019-08-16 08:28:13
已发帖子: 9,473
服务器在外面, 有时候晚上会比较慢, 因为歪国人也准备起床干活了。
#29 2020-10-10 10:41:31
嵌入式小弟
晕哥,请问一下esp8089在上电之后会敲入ifconfig -a,会出现wlan0,但是不断电重启之后,就没有wlan0,这可能是什么原因啊?
#30 2020-10-10 20:02:15
shawn.d
已发帖子: 164
可惜这板没得卖了
