楼主 #1 2018-11-18 14:01:54
605364021
已发帖子: 251
v3s开发板,想用按钮驱动产生中断实现开关led灯
看v3s的原理图,找不到按钮对应的引脚号.......
最近编辑记录 605364021 (2018-11-18 14:02:59)
楼主 #2 2018-11-18 22:24:21
605364021
已发帖子: 251
Re: v3s开发板,想用按钮驱动产生中断实现开关led灯
有人可以告诉一下,v3s板子的按钮时是哪个引脚?
#3 2018-11-19 09:45:53
已发帖子: 1,409
看了ilichee-zero的原理图。
四个按钮是adc按钮,通过电阻分压,接到了LRADC0管脚。
楼主 #4 2018-11-19 11:37:01
605364021
已发帖子: 251
Gentlepig wrote:
看了ilichee-zero的原理图。
谢谢
楼主 #5 2018-11-19 18:49:48
605364021
已发帖子: 251
v3s使用ADC按键,怎么用驱动实现检测按键按下?
#6 2018-11-19 23:33:48
awfans
已发帖子: 264
https://github.com/Lichee-Pi/linux/blob/zero-4.13.y/drivers/input/keyboard/sun4i-lradc-keys.c
 * Allwinner sun4i low res adc attached tablet keys driver
 * Copyright (C) 2014 Hans de Goede <hdegoede@redhat.com>
 * This program is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License as published by
 * the Free Software Foundation; either version 2 of the License, or
 * (at your option) any later version.
 * This program is distributed in the hope that it will be useful,
 * but WITHOUT ANY WARRANTY; without even the implied warranty of
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 * GNU General Public License for more details.
 * Allwinnner sunxi SoCs have a lradc which is specifically designed to have
 * various (tablet) keys (ie home, back, search, etc). attached to it using
 * a resistor network. This driver is for the keys on such boards.
 * There are 2 channels, currently this driver only supports channel 0 since
 * there are no boards known to use channel 1.
#include <linux/err.h>
#include <linux/init.h>
#include <linux/input.h>
#include <linux/interrupt.h>
#include <linux/io.h>
#include <linux/module.h>
#include <linux/of_platform.h>
#include <linux/platform_device.h>
#include <linux/regulator/consumer.h>
#include <linux/slab.h>
#define LRADC_CTRL		0x00
#define LRADC_INTC		0x04
#define LRADC_INTS		0x08
#define LRADC_DATA0		0x0c
#define LRADC_DATA1		0x10
/* LRADC_CTRL bits */
#define FIRST_CONVERT_DLY(x)	((x) << 24) /* 8 bits */
#define CHAN_SELECT(x)		((x) << 22) /* 2 bits */
#define CONTINUE_TIME_SEL(x)	((x) << 16) /* 4 bits */
#define KEY_MODE_SEL(x)		((x) << 12) /* 2 bits */
#define LEVELA_B_CNT(x)		((x) << 8)  /* 4 bits */
#define HOLD_EN(x)		((x) << 6)
#define LEVELB_VOL(x)		((x) << 4)  /* 2 bits */
#define SAMPLE_RATE(x)		((x) << 2)  /* 2 bits */
#define ENABLE(x)		((x) << 0)
/* LRADC_INTC and LRADC_INTS bits */
#define CHAN1_KEYUP_IRQ		BIT(12)
#define CHAN1_ALRDY_HOLD_IRQ	BIT(11)
#define CHAN1_HOLD_IRQ		BIT(10)
#define	CHAN1_KEYDOWN_IRQ	BIT(9)
#define CHAN1_DATA_IRQ		BIT(8)
#define CHAN0_KEYUP_IRQ		BIT(4)
#define CHAN0_ALRDY_HOLD_IRQ	BIT(3)
#define CHAN0_HOLD_IRQ		BIT(2)
#define	CHAN0_KEYDOWN_IRQ	BIT(1)
#define CHAN0_DATA_IRQ		BIT(0)
struct sun4i_lradc_keymap {
	u32 voltage;
	u32 keycode;
struct sun4i_lradc_data {
	struct device *dev;
	struct input_dev *input;
	void __iomem *base;
	struct regulator *vref_supply;
	struct sun4i_lradc_keymap *chan0_map;
	u32 chan0_map_count;
	u32 chan0_keycode;
	u32 vref;
static irqreturn_t sun4i_lradc_irq(int irq, void *dev_id)
	struct sun4i_lradc_data *lradc = dev_id;
	u32 i, ints, val, voltage, diff, keycode = 0, closest = 0xffffffff;
	ints  = readl(lradc->base + LRADC_INTS);
	 * lradc supports only one keypress at a time, release does not give
	 * any info as to which key was released, so we cache the keycode.
	if (ints & CHAN0_KEYUP_IRQ) {
		input_report_key(lradc->input, lradc->chan0_keycode, 0);
		lradc->chan0_keycode = 0;
	if ((ints & CHAN0_KEYDOWN_IRQ) && lradc->chan0_keycode == 0) {
		val = readl(lradc->base + LRADC_DATA0) & 0x3f;
		voltage = val * lradc->vref / 63;
		for (i = 0; i < lradc->chan0_map_count; i++) {
			diff = abs(lradc->chan0_map[i].voltage - voltage);
			if (diff < closest) {
				closest = diff;
				keycode = lradc->chan0_map[i].keycode;
		lradc->chan0_keycode = keycode;
		input_report_key(lradc->input, lradc->chan0_keycode, 1);
	input_sync(lradc->input);
	writel(ints, lradc->base + LRADC_INTS);
	return IRQ_HANDLED;
static int sun4i_lradc_open(struct input_dev *dev)
	struct sun4i_lradc_data *lradc = input_get_drvdata(dev);
	int error;
	error = regulator_enable(lradc->vref_supply);
	if (error)
		return error;
	/* lradc Vref internally is divided by 2/3 */
	lradc->vref = regulator_get_voltage(lradc->vref_supply) * 2 / 3;
	 * Set sample time to 4 ms / 250 Hz. Wait 2 * 4 ms for key to
	 * stabilize on press, wait (1 + 1) * 4 ms for key release
	writel(FIRST_CONVERT_DLY(2) | LEVELA_B_CNT(1) | HOLD_EN(1) |
		SAMPLE_RATE(0) | ENABLE(1), lradc->base + LRADC_CTRL);
	writel(CHAN0_KEYUP_IRQ | CHAN0_KEYDOWN_IRQ, lradc->base + LRADC_INTC);
static void sun4i_lradc_close(struct input_dev *dev)
	/* Disable lradc, leave other settings unchanged */
		SAMPLE_RATE(2), lradc->base + LRADC_CTRL);
	writel(0, lradc->base + LRADC_INTC);
	regulator_disable(lradc->vref_supply);
static int sun4i_lradc_load_dt_keymap(struct device *dev,
				      struct sun4i_lradc_data *lradc)
	struct device_node *np, *pp;
	int i;
	int error;
	np = dev->of_node;
	if (!np)
		return -EINVAL;
	lradc->chan0_map_count = of_get_child_count(np);
	if (lradc->chan0_map_count == 0) {
		dev_err(dev, "keymap is missing in device tree\n");
		return -EINVAL;
	lradc->chan0_map = devm_kmalloc_array(dev, lradc->chan0_map_count,
					      sizeof(struct sun4i_lradc_keymap),
					      GFP_KERNEL);
	if (!lradc->chan0_map)
		return -ENOMEM;
	i = 0;
	for_each_child_of_node(np, pp) {
		struct sun4i_lradc_keymap *map = &lradc->chan0_map[i];
		u32 channel;
		error = of_property_read_u32(pp, "channel", &channel);
		if (error || channel != 0) {
			dev_err(dev, "%s: Inval channel prop\n", pp->name);
			return -EINVAL;
		error = of_property_read_u32(pp, "voltage", &map->voltage);
		if (error) {
			dev_err(dev, "%s: Inval voltage prop\n", pp->name);
			return -EINVAL;
		error = of_property_read_u32(pp, "linux,code", &map->keycode);
		if (error) {
			dev_err(dev, "%s: Inval linux,code prop\n", pp->name);
			return -EINVAL;
		i++;
static int sun4i_lradc_probe(struct platform_device *pdev)
	struct sun4i_lradc_data *lradc;
	struct device *dev = &pdev->dev;
	int i;
	int error;
	lradc = devm_kzalloc(dev, sizeof(struct sun4i_lradc_data), GFP_KERNEL);
	if (!lradc)
		return -ENOMEM;
	error = sun4i_lradc_load_dt_keymap(dev, lradc);
	if (error)
		return error;
	lradc->vref_supply = devm_regulator_get(dev, "vref");
	if (IS_ERR(lradc->vref_supply))
		return PTR_ERR(lradc->vref_supply);
	lradc->dev = dev;
	lradc->input = devm_input_allocate_device(dev);
	if (!lradc->input)
		return -ENOMEM;
	lradc->input->name = pdev->name;
	lradc->input->phys = "sun4i_lradc/input0";
	lradc->input->open = sun4i_lradc_open;
	lradc->input->close = sun4i_lradc_close;
	lradc->input->id.bustype = BUS_HOST;
	lradc->input->id.vendor = 0x0001;
	lradc->input->id.product = 0x0001;
	lradc->input->id.version = 0x0100;
	__set_bit(EV_KEY, lradc->input->evbit);
		__set_bit(lradc->chan0_map[i].keycode, lradc->input->keybit);
	input_set_drvdata(lradc->input, lradc);
	lradc->base = devm_ioremap_resource(dev,
			      platform_get_resource(pdev, IORESOURCE_MEM, 0));
	if (IS_ERR(lradc->base))
		return PTR_ERR(lradc->base);
	error = devm_request_irq(dev, platform_get_irq(pdev, 0),
				 sun4i_lradc_irq, 0,
				 "sun4i-a10-lradc-keys", lradc);
	if (error)
		return error;
	error = input_register_device(lradc->input);
	if (error)
		return error;
static const struct of_device_id sun4i_lradc_of_match[] = {
	{ .compatible = "allwinner,sun4i-a10-lradc-keys", },
	{ /* sentinel */ }
MODULE_DEVICE_TABLE(of, sun4i_lradc_of_match);
static struct platform_driver sun4i_lradc_driver = {
	.driver = {
		.name	= "sun4i-a10-lradc-keys",
		.of_match_table = of_match_ptr(sun4i_lradc_of_match),
	.probe	= sun4i_lradc_probe,
module_platform_driver(sun4i_lradc_driver);
MODULE_DESCRIPTION("Allwinner sun4i low res adc attached tablet keys driver");
MODULE_AUTHOR("Hans de Goede <hdegoede@redhat.com>");
MODULE_LICENSE("GPL");
楼主 #7 2018-11-20 20:56:04
605364021
已发帖子: 251
v3s自带sun4i-lradc-keys.c驱动,但是我想做一个简单点的adc按键检测驱动,是需要依据自带的lradc驱动来改?
#8 2018-11-20 21:14:38
basicdev
已发帖子: 159
完全可以
楼主 #9 2018-11-20 22:07:00
605364021
已发帖子: 251
在已有sun4i-lradc-keys.c驱动情况下,怎么检测按键按下后出现了电压变化?
#10 2018-11-21 08:31:39
lilo
已发帖子: 215
简单点就这样:
cat /dev/input/eventX
楼主 #11 2018-11-21 09:36:08
605364021
已发帖子: 251
lilo wrote:
简单点就这样:
cat到的都是一串乱码
#12 2018-11-21 09:48:19
已发帖子: 9,473
605364021 wrote:
lilo wrote:
简单点就这样:
cat到的都是一串乱码
对,就是二进制数据,你用 evtest 可以获取直观数据
楼主 #13 2018-11-21 10:15:20
605364021
已发帖子: 251
我现在想做一个没有中断的按键驱动,但是我不知道怎么实现电压的区分来判断哪个按键按下
#14 2019-09-25 14:23:43
太一酱鸭
已发帖子: 154
bsp的没找到这个按键驱动
#15 2019-09-25 14:25:43
ffplay
已发帖子: 92
可能有,再仔细找找,实在没有就照着抄一次,有错改错。
#16 2019-09-25 15:11:48
太一酱鸭
已发帖子: 154
谢谢,我发现BSP应该是sunxi-keyboard.c
