购买链接: https://item.taobao.com/item.htm?id=591896289694
店铺链接: https://shop512436263.taobao.com
参考链接: 感谢华嵌HQEmbed赠送的 漂亮高颜值S3 开发板 (底板 + 核心板)
核心板原理图: core_s3_v01.pdf
底板原理图: hq_050ips_v01.pdf
2019-06-01 更新:
能跑BCM43438 WIFI 的固件下载: read_hq_s3_128m.7z
drivers/pinctrl/sunxi/pinctrl-sun8i-v3s.c 添加:
SUNXI_PIN(SUNXI_PINCTRL_PIN(B, 10),
SUNXI_FUNCTION(0x0, "gpio_in"),
SUNXI_FUNCTION(0x1, "gpio_out"),
SUNXI_FUNCTION(0x2, "jtag"), / JTAG /
SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 10)), / PB_EINT10 /
arch/arm/boot/dts/sun8i-v3s.dtsi
wifi_en_pin: wifi {
pins = "PB2";
function = "gpio_out";
};arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts
model = "Lichee Pi Zero with Dock";
compatible = "licheepi,licheepi-zero-dock", "licheepi,licheepi-zero",
"allwinner,sun8i-v3s";aliases {
ethernet0 = &emac;
};leds {
/ The LEDs use PG0~2 pins, which conflict with MMC1 /
status = "disbaled";
**wifi_reg_en: wifi_reg_en {
compatible = "mmc-pwrseq-simple";
pinctrl-names = "default";
pinctrl-0 = <&wifi_en_pin>;
reset-gpios = <&pio 1 2 GPIO_ACTIVE_LOW>; / PB2 /
};&mmc1 {
pinctrl-0 = <&mmc1_pins>;
vmmc-supply = <®_vcc3v3>;
vqmmc-supply = <®_vcc3v3>;
mmc-pwrseq = <&wifi_reg_en>;
bus-width = <4>;
non-removable;
status = "okay";brcmf: wifi@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac";
interrupt-parent = <&pio>;
interrupt-names = "host-wake";
interrupts = <1 10 IRQ_TYPE_LEVEL_LOW>; / PB10 / EINT10 /
hq_s3_v1_defconfig 配置文件:
# Linux/arm 4.13.16 Kernel Configuration
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_MIGHT_HAVE_PCI=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_RWSEM_XCHGADD_ALGORITHM=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_VECTORS_BASE=0xffff0000
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=2
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_EXTABLE_SORT=y
# General setup
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_CROSS_COMPILE=""
# CONFIG_COMPILE_TEST is not set
CONFIG_LOCALVERSION="-licheepi-zero"
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
# CONFIG_SYSVIPC is not set
# CONFIG_POSIX_MQUEUE is not set
CONFIG_CROSS_MEMORY_ATTACH=y
CONFIG_FHANDLE=y
# CONFIG_USELIB is not set
# CONFIG_AUDIT is not set
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_HANDLE_DOMAIN_IRQ=y
# CONFIG_IRQ_DOMAIN_DEBUG is not set
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
CONFIG_ARCH_CLOCKSOURCE_DATA=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# RCU Subsystem
CONFIG_TREE_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
# CONFIG_TASKS_RCU is not set
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
# CONFIG_BUILD_BIN2C is not set
# CONFIG_IKCONFIG is not set
CONFIG_LOG_BUF_SHIFT=17
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
CONFIG_GENERIC_SCHED_CLOCK=y
CONFIG_CGROUPS=y
# CONFIG_MEMCG is not set
# CONFIG_BLK_CGROUP is not set
# CONFIG_CGROUP_SCHED is not set
# CONFIG_CGROUP_PIDS is not set
# CONFIG_CGROUP_RDMA is not set
# CONFIG_CGROUP_FREEZER is not set
# CONFIG_CPUSETS is not set
# CONFIG_CGROUP_DEVICE is not set
# CONFIG_CGROUP_CPUACCT is not set
# CONFIG_CGROUP_PERF is not set
# CONFIG_CGROUP_DEBUG is not set
# CONFIG_SOCK_CGROUP_DATA is not set
# CONFIG_CHECKPOINT_RESTORE is not set
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
# CONFIG_USER_NS is not set
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_HAVE_UID16=y
CONFIG_BPF=y
# CONFIG_EXPERT is not set
CONFIG_UID16=y
CONFIG_MULTIUSER=y
# CONFIG_SGETMASK_SYSCALL is not set
CONFIG_SYSFS_SYSCALL=y
# CONFIG_SYSCTL_SYSCALL is not set
CONFIG_POSIX_TIMERS=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
# CONFIG_KALLSYMS_ABSOLUTE_PERCPU is not set
CONFIG_KALLSYMS_BASE_RELATIVE=y
CONFIG_PRINTK=y
CONFIG_PRINTK_NMI=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
# CONFIG_BPF_SYSCALL is not set
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_ADVISE_SYSCALLS=y
# CONFIG_USERFAULTFD is not set
CONFIG_MEMBARRIER=y
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# CONFIG_PC104 is not set
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# CONFIG_DEBUG_PERF_USE_VMALLOC is not set
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
CONFIG_COMPAT_BRK=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
CONFIG_SLUB_CPU_PARTIAL=y
# CONFIG_SYSTEM_DATA_VERIFICATION is not set
# CONFIG_PROFILING is not set
CONFIG_HAVE_OPROFILE=y
# CONFIG_KPROBES is not set
# CONFIG_JUMP_LABEL is not set
# CONFIG_UPROBES is not set
# CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_CLK=y
CONFIG_HAVE_DMA_API_DEBUG=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_HAVE_GCC_PLUGINS=y
# CONFIG_GCC_PLUGINS is not set
CONFIG_HAVE_CC_STACKPROTECTOR=y
# CONFIG_CC_STACKPROTECTOR is not set
CONFIG_CC_STACKPROTECTOR_NONE=y
# CONFIG_CC_STACKPROTECTOR_REGULAR is not set
# CONFIG_CC_STACKPROTECTOR_STRONG is not set
CONFIG_THIN_ARCHIVES=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=16
CONFIG_ARCH_MMAP_RND_BITS=8
# CONFIG_HAVE_ARCH_HASH is not set
# CONFIG_ISA_BUS_API is not set
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
# CONFIG_CPU_NO_EFFICIENT_FFS is not set
# CONFIG_HAVE_ARCH_VMAP_STACK is not set
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
# CONFIG_REFCOUNT_FULL is not set
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
CONFIG_HAVE_GENERIC_DMA_COHERENT=y
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
# CONFIG_MODULE_COMPRESS is not set
# CONFIG_TRIM_UNUSED_KSYMS is not set
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_LBDAF=y
CONFIG_BLK_SCSI_REQUEST=y
CONFIG_BLK_DEV_BSG=y
# CONFIG_BLK_DEV_BSGLIB is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_ZONED is not set
CONFIG_BLK_CMDLINE_PARSER=y
# CONFIG_BLK_WBT is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_EFI_PARTITION=y
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
CONFIG_IOSCHED_DEADLINE=y
CONFIG_IOSCHED_CFQ=y
# CONFIG_DEFAULT_DEADLINE is not set
CONFIG_DEFAULT_CFQ=y
# CONFIG_DEFAULT_NOOP is not set
CONFIG_DEFAULT_IOSCHED="cfq"
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_FREEZER=y
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EBSA110 is not set
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_NETX is not set
# CONFIG_ARCH_IOP13XX is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IOP33X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_KS8695 is not set
# CONFIG_ARCH_W90X900 is not set
# CONFIG_ARCH_LPC32XX is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_DAVINCI is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V6 is not set
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=y
# CONFIG_ARCH_MULTI_CPU_AUTO is not set
# CONFIG_ARCH_VIRT is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_ACTIONS is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_ARTPEC is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_BCM is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_DIGICOLOR is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_HISI is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_MEDIATEK is not set
# TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_OMAP3 is not set
# CONFIG_ARCH_OMAP4 is not set
# CONFIG_SOC_OMAP5 is not set
# CONFIG_SOC_AM33XX is not set
# CONFIG_SOC_AM43XX is not set
# CONFIG_SOC_DRA7XX is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_QCOM is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_SOCFPGA is not set
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_RENESAS is not set
CONFIG_ARCH_SUNXI=y
# CONFIG_MACH_SUN4I is not set
# CONFIG_MACH_SUN5I is not set
# CONFIG_MACH_SUN6I is not set
# CONFIG_MACH_SUN7I is not set
CONFIG_MACH_SUN8I=y
# CONFIG_MACH_SUN9I is not set
# CONFIG_ARCH_SIRF is not set
# CONFIG_ARCH_TANGO is not set
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_WM8850 is not set
# CONFIG_ARCH_ZX is not set
# CONFIG_ARCH_ZYNQ is not set
# Processor Type
CONFIG_CPU_V7=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
# CONFIG_ARM_LPAE is not set
# CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set
CONFIG_ARM_THUMB=y
# CONFIG_ARM_THUMBEE is not set
CONFIG_ARM_VIRT_EXT=y
CONFIG_SWP_EMULATE=y
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_KUSER_HELPERS=y
CONFIG_VDSO=y
CONFIG_OUTER_CACHE=y
CONFIG_OUTER_CACHE_SYNC=y
CONFIG_MIGHT_HAVE_CACHE_L2X0=y
CONFIG_CACHE_L2X0=y
# CONFIG_CACHE_L2X0_PMU is not set
# CONFIG_PL310_ERRATA_588369 is not set
# CONFIG_PL310_ERRATA_727915 is not set
# CONFIG_PL310_ERRATA_753970 is not set
# CONFIG_PL310_ERRATA_769419 is not set
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_ARM_HEAVY_MB=y
CONFIG_DEBUG_ALIGN_RODATA=y
CONFIG_MULTI_IRQ_HANDLER=y
# CONFIG_ARM_ERRATA_430973 is not set
CONFIG_ARM_ERRATA_643719=y
# CONFIG_ARM_ERRATA_720789 is not set
# CONFIG_ARM_ERRATA_754322 is not set
# CONFIG_ARM_ERRATA_754327 is not set
# CONFIG_ARM_ERRATA_764369 is not set
# CONFIG_ARM_ERRATA_775420 is not set
# CONFIG_ARM_ERRATA_798181 is not set
# CONFIG_ARM_ERRATA_773022 is not set
# CONFIG_ARM_ERRATA_818325_852422 is not set
# CONFIG_ARM_ERRATA_821420 is not set
# CONFIG_ARM_ERRATA_825619 is not set
# CONFIG_ARM_ERRATA_852421 is not set
# CONFIG_ARM_ERRATA_852423 is not set
# Bus support
# CONFIG_PCI is not set
# CONFIG_PCI_DOMAINS_GENERIC is not set
# CONFIG_PCI_SYSCALL is not set
# DesignWare PCI Core Support
# PCI Endpoint
# CONFIG_PCI_ENDPOINT is not set
# CONFIG_PCCARD is not set
# Kernel Features
CONFIG_HAVE_SMP=y
CONFIG_SMP=y
CONFIG_SMP_ON_UP=y
CONFIG_ARM_CPU_TOPOLOGY=y
# CONFIG_SCHED_MC is not set
# CONFIG_SCHED_SMT is not set
CONFIG_HAVE_ARM_ARCH_TIMER=y
# CONFIG_MCPM is not set
# CONFIG_BIG_LITTLE is not set
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_3G_OPT is not set
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_NR_CPUS=8
CONFIG_HOTPLUG_CPU=y
CONFIG_ARM_PSCI=y
CONFIG_ARCH_NR_GPIO=416
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
# CONFIG_HZ_200 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
# CONFIG_THUMB2_KERNEL is not set
CONFIG_ARM_PATCH_IDIV=y
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
# CONFIG_ARCH_SPARSEMEM_DEFAULT is not set
# CONFIG_ARCH_SELECT_MEMORY_MODEL is not set
CONFIG_HAVE_ARCH_PFN_VALID=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_CPU_SW_DOMAIN_PAN=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
# CONFIG_ARM_MODULE_PLTS is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_HAVE_MEMBLOCK=y
CONFIG_NO_BOOTMEM=y
# CONFIG_HAVE_BOOTMEM_INFO_NODE is not set
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
CONFIG_MIGRATION=y
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
# CONFIG_ARCH_WANTS_THP_SWAP is not set
# CONFIG_CLEANCACHE is not set
# CONFIG_FRONTSWAP is not set
# CONFIG_CMA is not set
# CONFIG_ZPOOL is not set
# CONFIG_ZBUD is not set
# CONFIG_ZSMALLOC is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
CONFIG_FRAME_VECTOR=y
# CONFIG_PERCPU_STATS is not set
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
# CONFIG_SECCOMP is not set
CONFIG_SWIOTLB=y
CONFIG_IOMMU_HELPER=y
# CONFIG_PARAVIRT is not set
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
# CONFIG_XEN is not set
# Boot options
CONFIG_USE_OF=y
CONFIG_ATAGS=y
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
CONFIG_ZBOOT_ROM_TEXT=0
CONFIG_ZBOOT_ROM_BSS=0
CONFIG_ARM_APPENDED_DTB=y
CONFIG_ARM_ATAG_DTB_COMPAT=y
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
# CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
CONFIG_CMDLINE=""
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CONFIG_EFI is not set
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
# CONFIG_CPU_FREQ_STAT is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
# CONFIG_CPU_FREQ_GOV_SCHEDUTIL is not set
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
# CONFIG_ARM_BIG_LITTLE_CPUFREQ is not set
# CONFIG_ARM_DB8500_CPUFREQ is not set
# CONFIG_ARM_KIRKWOOD_CPUFREQ is not set
# CONFIG_QORIQ_CPUFREQ is not set
# CPU Idle
# CONFIG_CPU_IDLE is not set
# CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
# CONFIG_KERNEL_MODE_NEON is not set
# Userspace binary formats
CONFIG_BINFMT_ELF=y
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
# CONFIG_BINFMT_FLAT is not set
# CONFIG_HAVE_AOUT is not set
# CONFIG_BINFMT_MISC is not set
CONFIG_COREDUMP=y
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_HIBERNATION is not set
CONFIG_PM_SLEEP=y
CONFIG_PM_SLEEP_SMP=y
# CONFIG_PM_AUTOSLEEP is not set
# CONFIG_PM_WAKELOCKS is not set
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
# CONFIG_APM_EMULATION is not set
CONFIG_PM_OPP=y
CONFIG_PM_CLK=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_CPU_PM=y
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
# CONFIG_UNIX_DIAG is not set
# CONFIG_TLS is not set
# CONFIG_XFRM_USER is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
# CONFIG_NET_IP_TUNNEL is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_NET_UDP_TUNNEL is not set
# CONFIG_NET_FOU is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
# CONFIG_INET_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_TRANSPORT is not set
# CONFIG_INET_XFRM_MODE_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_BEET is not set
# CONFIG_INET_DIAG is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NET_PTP_CLASSIFY=y
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
CONFIG_HAVE_NET_DSA=y
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
# CONFIG_BATMAN_ADV is not set
# CONFIG_OPENVSWITCH is not set
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_DIAG is not set
# CONFIG_MPLS is not set
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
# CONFIG_NET_L3_MASTER_DEV is not set
# CONFIG_NET_NCSI is not set
CONFIG_RPS=y
CONFIG_RFS_ACCEL=y
CONFIG_XPS=y
# CONFIG_CGROUP_NET_PRIO is not set
# CONFIG_CGROUP_NET_CLASSID is not set
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
# CONFIG_BPF_JIT is not set
CONFIG_NET_FLOW_LIMIT=y
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
# CONFIG_STREAM_PARSER is not set
CONFIG_WIRELESS=y
CONFIG_WIRELESS_EXT=y
CONFIG_WEXT_CORE=y
CONFIG_WEXT_PROC=y
CONFIG_WEXT_PRIV=y
CONFIG_CFG80211=y
# CONFIG_NL80211_TESTMODE is not set
# CONFIG_CFG80211_DEVELOPER_WARNINGS is not set
CONFIG_CFG80211_DEFAULT_PS=y
# CONFIG_CFG80211_DEBUGFS is not set
# CONFIG_CFG80211_INTERNAL_REGDB is not set
CONFIG_CFG80211_CRDA_SUPPORT=y
CONFIG_CFG80211_WEXT=y
# CONFIG_LIB80211 is not set
CONFIG_MAC80211=y
CONFIG_MAC80211_HAS_RC=y
CONFIG_MAC80211_RC_MINSTREL=y
CONFIG_MAC80211_RC_MINSTREL_HT=y
# CONFIG_MAC80211_RC_MINSTREL_VHT is not set
CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y
CONFIG_MAC80211_RC_DEFAULT="minstrel_ht"
# CONFIG_MAC80211_MESH is not set
CONFIG_MAC80211_LEDS=y
# CONFIG_MAC80211_DEBUGFS is not set
# CONFIG_MAC80211_MESSAGE_TRACING is not set
# CONFIG_MAC80211_DEBUG_MENU is not set
CONFIG_MAC80211_STA_HASH_MAX_SIZE=0
# CONFIG_WIMAX is not set
CONFIG_RFKILL=y
CONFIG_RFKILL_LEDS=y
CONFIG_RFKILL_INPUT=y
CONFIG_RFKILL_GPIO=y
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# CONFIG_NFC is not set
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
# CONFIG_DST_CACHE is not set
# CONFIG_GRO_CELLS is not set
# CONFIG_NET_DEVLINK is not set
CONFIG_MAY_USE_DEVLINK=y
CONFIG_HAVE_CBPF_JIT=y
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER=y
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=y
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER_FALLBACK is not set
CONFIG_WANT_DEV_COREDUMP=y
CONFIG_ALLOW_DEV_COREDUMP=y
CONFIG_DEV_COREDUMP=y
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_GENERIC_CPU_DEVICES is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
CONFIG_GENERIC_ARCH_TOPOLOGY=y
# Bus devices
# CONFIG_ARM_CCI400_PMU is not set
# CONFIG_ARM_CCI5xx_PMU is not set
# CONFIG_ARM_CCN is not set
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_SIMPLE_PM_BUS is not set
CONFIG_SUNXI_RSB=y
# CONFIG_VEXPRESS_CONFIG is not set
# CONFIG_CONNECTOR is not set
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AR7_PARTS is not set
# Partition parsers
# User Modules And Translation Layers
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PLATRAM is not set
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
CONFIG_MTD_M25P80=y
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
CONFIG_MTD_BLOCK2MTD=y
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# CONFIG_MTD_NAND is not set
# CONFIG_MTD_ONENAND is not set
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# CONFIG_MTD_LPDDR2_NVM is not set
CONFIG_MTD_SPI_NOR=y
# CONFIG_MTD_MT81xx_NOR is not set
CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y
# CONFIG_SPI_CADENCE_QUADSPI is not set
# CONFIG_MTD_UBI is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_NET=y
CONFIG_OF_MDIO=y
CONFIG_OF_RESERVED_MEM=y
# CONFIG_OF_OVERLAY is not set
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_DRBD is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_BLK_DEV_RBD is not set
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TARGET is not set
# Misc devices
# CONFIG_SENSORS_LIS3LV02D is not set
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_TI_DAC7512 is not set
# CONFIG_USB_SWITCH_FSA9480 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
# CONFIG_SRAM is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# Altera FPGA firmware download module
# CONFIG_ALTERA_STAPL is not set
# Intel MIC Bus Driver
# SCIF Bus Driver
# VOP Bus Driver
# Intel MIC Host Driver
# Intel MIC Card Driver
# SCIF Driver
# Intel MIC Coprocessor State Management (COSM) Drivers
# VOP Driver
# CONFIG_ECHO is not set
# CONFIG_CXL_BASE is not set
# CONFIG_CXL_AFU_DRIVER_OPS is not set
# CONFIG_CXL_LIB is not set
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_NETLINK is not set
# CONFIG_SCSI_MQ_DEFAULT is not set
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# CONFIG_SCSI_OSD_INITIATOR is not set
# CONFIG_ATA is not set
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
CONFIG_NETDEVICES=y
CONFIG_MII=y
CONFIG_NET_CORE=y
# CONFIG_BONDING is not set
# CONFIG_DUMMY is not set
# CONFIG_EQUALIZER is not set
# CONFIG_NET_TEAM is not set
# CONFIG_MACVLAN is not set
# CONFIG_VXLAN is not set
# CONFIG_MACSEC is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
# CONFIG_TUN is not set
# CONFIG_TUN_VNET_CROSS_LE is not set
# CONFIG_VETH is not set
# CONFIG_NLMON is not set
# CAIF transport drivers
# Distributed Switch Architecture drivers
CONFIG_ETHERNET=y
CONFIG_NET_VENDOR_ALACRITECH=y
CONFIG_NET_VENDOR_ALLWINNER=y
# CONFIG_SUN4I_EMAC is not set
# CONFIG_ALTERA_TSE is not set
CONFIG_NET_VENDOR_AMAZON=y
CONFIG_NET_VENDOR_AQUANTIA=y
# CONFIG_NET_VENDOR_ARC is not set
# CONFIG_NET_VENDOR_AURORA is not set
# CONFIG_NET_CADENCE is not set
# CONFIG_NET_VENDOR_BROADCOM is not set
# CONFIG_NET_VENDOR_CIRRUS is not set
# CONFIG_DM9000 is not set
# CONFIG_DNET is not set
CONFIG_NET_VENDOR_EZCHIP=y
# CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set
# CONFIG_NET_VENDOR_FARADAY is not set
CONFIG_NET_VENDOR_HISILICON=y
# CONFIG_HIX5HD2_GMAC is not set
# CONFIG_HISI_FEMAC is not set
# CONFIG_HIP04_ETH is not set
# CONFIG_HNS is not set
# CONFIG_HNS_DSAF is not set
# CONFIG_HNS_ENET is not set
# CONFIG_NET_VENDOR_INTEL is not set
# CONFIG_NET_VENDOR_MARVELL is not set
# CONFIG_NET_VENDOR_MICREL is not set
# CONFIG_NET_VENDOR_MICROCHIP is not set
# CONFIG_NET_VENDOR_NATSEMI is not set
CONFIG_NET_VENDOR_NETRONOME=y
# CONFIG_ETHOC is not set
CONFIG_NET_VENDOR_QUALCOMM=y
# CONFIG_QCA7000_SPI is not set
# CONFIG_QCOM_EMAC is not set
CONFIG_NET_VENDOR_RENESAS=y
CONFIG_NET_VENDOR_ROCKER=y
# CONFIG_NET_VENDOR_SAMSUNG is not set
# CONFIG_NET_VENDOR_SEEQ is not set
CONFIG_NET_VENDOR_SOLARFLARE=y
# CONFIG_NET_VENDOR_SMSC is not set
CONFIG_NET_VENDOR_STMICRO=y
CONFIG_STMMAC_ETH=y
CONFIG_STMMAC_PLATFORM=y
# CONFIG_DWMAC_DWC_QOS_ETH is not set
CONFIG_DWMAC_GENERIC=y
CONFIG_DWMAC_SUNXI=y
CONFIG_DWMAC_SUN8I=y
# CONFIG_NET_VENDOR_VIA is not set
# CONFIG_NET_VENDOR_WIZNET is not set
CONFIG_NET_VENDOR_SYNOPSYS=y
# CONFIG_DWC_XLGMAC is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
# CONFIG_MDIO_BCM_UNIMAC is not set
# CONFIG_MDIO_BITBANG is not set
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# CONFIG_MDIO_HISI_FEMAC is not set
# CONFIG_MDIO_SUN4I is not set
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
# CONFIG_LED_TRIGGER_PHY is not set
# MII PHY device drivers
# CONFIG_AMD_PHY is not set
# CONFIG_AQUANTIA_PHY is not set
# CONFIG_AT803X_PHY is not set
# CONFIG_BCM7XXX_PHY is not set
# CONFIG_BCM87XX_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_CORTINA_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_DP83848_PHY is not set
# CONFIG_DP83867_PHY is not set
CONFIG_FIXED_PHY=y
# CONFIG_ICPLUS_PHY is not set
# CONFIG_INTEL_XWAY_PHY is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_MARVELL_PHY is not set
# CONFIG_MARVELL_10G_PHY is not set
# CONFIG_MICREL_PHY is not set
# CONFIG_MICROCHIP_PHY is not set
# CONFIG_MICROSEMI_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_QSEMI_PHY is not set
# CONFIG_REALTEK_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_TERANETICS_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_XILINX_GMII2RGMII is not set
# CONFIG_MICREL_KS8995MA is not set
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
CONFIG_USB_NET_DRIVERS=y
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_RTL8152 is not set
# CONFIG_USB_LAN78XX is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_HSO is not set
# CONFIG_USB_IPHETH is not set
CONFIG_WLAN=y
# CONFIG_WLAN_VENDOR_ADMTEK is not set
# CONFIG_WLAN_VENDOR_ATH is not set
# CONFIG_WLAN_VENDOR_ATMEL is not set
CONFIG_WLAN_VENDOR_BROADCOM=y
CONFIG_B43=m
CONFIG_B43_BCMA=y
CONFIG_B43_SSB=y
CONFIG_B43_BUSES_BCMA_AND_SSB=y
# CONFIG_B43_BUSES_BCMA is not set
# CONFIG_B43_BUSES_SSB is not set
CONFIG_B43_SDIO=y
CONFIG_B43_BCMA_PIO=y
CONFIG_B43_PIO=y
CONFIG_B43_PHY_G=y
CONFIG_B43_PHY_N=y
CONFIG_B43_PHY_LP=y
CONFIG_B43_PHY_HT=y
CONFIG_B43_LEDS=y
CONFIG_B43_DEBUG=y
CONFIG_B43LEGACY=m
CONFIG_B43LEGACY_LEDS=y
CONFIG_B43LEGACY_DEBUG=y
CONFIG_B43LEGACY_DMA=y
CONFIG_B43LEGACY_PIO=y
CONFIG_B43LEGACY_DMA_AND_PIO_MODE=y
# CONFIG_B43LEGACY_DMA_MODE is not set
# CONFIG_B43LEGACY_PIO_MODE is not set
CONFIG_BRCMUTIL=m
CONFIG_BRCMSMAC=m
CONFIG_BRCMFMAC=m
CONFIG_BRCMFMAC_PROTO_BCDC=y
CONFIG_BRCMFMAC_SDIO=y
CONFIG_BRCMFMAC_USB=y
CONFIG_BRCM_TRACING=y
CONFIG_BRCMDBG=y
# CONFIG_WLAN_VENDOR_CISCO is not set
# CONFIG_WLAN_VENDOR_INTEL is not set
# CONFIG_WLAN_VENDOR_INTERSIL is not set
# CONFIG_WLAN_VENDOR_MARVELL is not set
# CONFIG_WLAN_VENDOR_MEDIATEK is not set
# CONFIG_WLAN_VENDOR_RALINK is not set
# CONFIG_WLAN_VENDOR_REALTEK is not set
# CONFIG_WLAN_VENDOR_RSI is not set
# CONFIG_WLAN_VENDOR_ST is not set
# CONFIG_WLAN_VENDOR_TI is not set
# CONFIG_WLAN_VENDOR_ZYDAS is not set
# CONFIG_WLAN_VENDOR_QUANTENNA is not set
# CONFIG_MAC80211_HWSIM is not set
# CONFIG_USB_NET_RNDIS_WLAN is not set
# Enable WiMAX (Networking options) to see the WiMAX drivers
# CONFIG_WAN is not set
# CONFIG_ISDN is not set
# CONFIG_NVM is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
# CONFIG_INPUT_FF_MEMLESS is not set
CONFIG_INPUT_POLLDEV=y
# CONFIG_INPUT_SPARSEKMAP is not set
# CONFIG_INPUT_MATRIXKMAP is not set
# Userland interfaces
CONFIG_INPUT_MOUSEDEV=y
CONFIG_INPUT_MOUSEDEV_PSAUX=y
CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024
CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768
CONFIG_INPUT_JOYDEV=y
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_GPIO is not set
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
CONFIG_KEYBOARD_SUN4I_LRADC=y
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN=y
CONFIG_TOUCHSCREEN_PROPERTIES=y
# CONFIG_TOUCHSCREEN_ADS7846 is not set
# CONFIG_TOUCHSCREEN_AD7877 is not set
# CONFIG_TOUCHSCREEN_AD7879 is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
# CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
# CONFIG_TOUCHSCREEN_DYNAPRO is not set
# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
# CONFIG_TOUCHSCREEN_EETI is not set
# CONFIG_TOUCHSCREEN_EGALAX is not set
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
# CONFIG_TOUCHSCREEN_FUJITSU is not set
# CONFIG_TOUCHSCREEN_GOODIX is not set
# CONFIG_TOUCHSCREEN_ILI210X is not set
# CONFIG_TOUCHSCREEN_GUNZE is not set
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
# CONFIG_TOUCHSCREEN_INEXIO is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_TOUCHSCREEN_PENMOUNT is not set
CONFIG_TOUCHSCREEN_EDT_FT5X06=y
CONFIG_TOUCHSCREEN_NS2009=y
# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
# CONFIG_TOUCHSCREEN_PIXCIR is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
# CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
# CONFIG_TOUCHSCREEN_TSC2004 is not set
# CONFIG_TOUCHSCREEN_TSC2005 is not set
# CONFIG_TOUCHSCREEN_TSC2007 is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
# CONFIG_TOUCHSCREEN_SILEAD is not set
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
# CONFIG_TOUCHSCREEN_SUN4I is not set
# CONFIG_TOUCHSCREEN_SUR40 is not set
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
# CONFIG_TOUCHSCREEN_TPS6507X is not set
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MMA8450 is not set
# CONFIG_INPUT_GP2A is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_TILT_POLLED is not set
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_KXTJ9 is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
CONFIG_INPUT_AXP20X_PEK=y
# CONFIG_INPUT_UINPUT is not set
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_IMS_PCU is not set
# CONFIG_INPUT_CMA3000 is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
# CONFIG_RMI4_CORE is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
# CONFIG_SERIO_SUN4I_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
CONFIG_VT_HW_CONSOLE_BINDING=y
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
CONFIG_DEVMEM=y
# CONFIG_DEVKMEM is not set
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_NR_UARTS=8
CONFIG_SERIAL_8250_RUNTIME_UARTS=8
# CONFIG_SERIAL_8250_EXTENDED is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_FSL=y
CONFIG_SERIAL_8250_DW=y
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_IFX6X60 is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
# CONFIG_SERIAL_DEV_BUS is not set
# CONFIG_HVC_DCC is not set
# CONFIG_IPMI_HANDLER is not set
# CONFIG_HW_RANDOM is not set
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_XILLYBUS is not set
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
# CONFIG_I2C_MUX is not set
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_EMEV2 is not set
# CONFIG_I2C_GPIO is not set
CONFIG_I2C_MV64XXX=y
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_PXA_PCI is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_PARPORT_LIGHT is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
CONFIG_SPI=y
# CONFIG_SPI_DEBUG is not set
CONFIG_SPI_MASTER=y
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
CONFIG_SPI_BITBANG=y
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_DESIGNWARE is not set
CONFIG_SPI_GPIO=y
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_PXA2XX_PCI is not set
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_SUN4I is not set
CONFIG_SPI_SUN6I=y
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# SPI Protocol Masters
# CONFIG_SPI_SPIDEV is not set
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
# CONFIG_PPS_CLIENT_LDISC is not set
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
CONFIG_PINCTRL=y
# Pin controllers
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_DEBUG_PINCTRL is not set
# CONFIG_PINCTRL_AMD is not set
# CONFIG_PINCTRL_MCP23S08 is not set
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
CONFIG_PINCTRL_SUNXI=y
# CONFIG_PINCTRL_SUN4I_A10 is not set
# CONFIG_PINCTRL_SUN5I is not set
# CONFIG_PINCTRL_SUN6I_A31 is not set
# CONFIG_PINCTRL_SUN6I_A31_R is not set
CONFIG_PINCTRL_SUN8I_A23=y
CONFIG_PINCTRL_SUN8I_A33=y
CONFIG_PINCTRL_SUN8I_A83T=y
CONFIG_PINCTRL_SUN8I_A83T_R=y
CONFIG_PINCTRL_SUN8I_A23_R=y
CONFIG_PINCTRL_SUN8I_H3=y
CONFIG_PINCTRL_SUN8I_H3_R=y
CONFIG_PINCTRL_SUN8I_V3S=y
# CONFIG_PINCTRL_SUN9I_A80 is not set
# CONFIG_PINCTRL_SUN9I_A80_R is not set
# CONFIG_PINCTRL_SUN50I_A64 is not set
# CONFIG_PINCTRL_SUN50I_A64_R is not set
# CONFIG_PINCTRL_SUN50I_H5 is not set
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_OF_GPIO=y
# CONFIG_DEBUG_GPIO is not set
CONFIG_GPIO_SYSFS=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_AXP209 is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_MOCKUP is not set
# CONFIG_GPIO_MPC8XXX is not set
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_SX150X is not set
# CONFIG_GPIO_TPIC2810 is not set
# MFD GPIO expanders
# CONFIG_HTC_EGPIO is not set
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# USB GPIO expanders
# CONFIG_W1 is not set
# CONFIG_POWER_AVS is not set
# CONFIG_POWER_RESET is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
# CONFIG_PDA_POWER is not set
# CONFIG_TEST_POWER is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_ISP1704 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LTC3651 is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_CHARGER_RT9455 is not set
CONFIG_HWMON=y
# CONFIG_HWMON_VID is not set
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7314 is not set
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7310 is not set
# CONFIG_SENSORS_ADT7410 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_ASPEED is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_DS620 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_FTSTEUTATES is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_G762 is not set
# CONFIG_SENSORS_GPIO_FAN is not set
# CONFIG_SENSORS_HIH6130 is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_JC42 is not set
# CONFIG_SENSORS_POWR1220 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LTC2945 is not set
# CONFIG_SENSORS_LTC2990 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4222 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4260 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX197 is not set
# CONFIG_SENSORS_MAX31722 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6642 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_MAX6697 is not set
# CONFIG_SENSORS_MAX31790 is not set
# CONFIG_SENSORS_MCP3021 is not set
# CONFIG_SENSORS_TC654 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LM95234 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_NTC_THERMISTOR is not set
# CONFIG_SENSORS_NCT6683 is not set
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_PMBUS is not set
# CONFIG_SENSORS_PWM_FAN is not set
# CONFIG_SENSORS_SHT15 is not set
# CONFIG_SENSORS_SHT21 is not set
# CONFIG_SENSORS_SHT3x is not set
# CONFIG_SENSORS_SHTC1 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH56XX_COMMON is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_STTS751 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_ADC128D818 is not set
# CONFIG_SENSORS_ADS1015 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_INA209 is not set
# CONFIG_SENSORS_INA2XX is not set
# CONFIG_SENSORS_INA3221 is not set
# CONFIG_SENSORS_TC74 is not set
# CONFIG_SENSORS_THMC50 is not set
# CONFIG_SENSORS_TMP102 is not set
# CONFIG_SENSORS_TMP103 is not set
# CONFIG_SENSORS_TMP108 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
CONFIG_THERMAL=y
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_HWMON=y
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set
CONFIG_CPU_THERMAL=y
# CONFIG_CLOCK_THERMAL is not set
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_QORIQ_THERMAL is not set
# ACPI INT340X thermal drivers
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
# CONFIG_WATCHDOG_SYSFS is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
CONFIG_SUNXI_WATCHDOG=y
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_MEN_A21_WDT is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
CONFIG_SSB=y
CONFIG_SSB_BLOCKIO=y
CONFIG_SSB_SDIOHOST_POSSIBLE=y
CONFIG_SSB_SDIOHOST=y
# CONFIG_SSB_DEBUG is not set
# CONFIG_SSB_DRIVER_GPIO is not set
CONFIG_BCMA_POSSIBLE=y
# Broadcom specific AMBA
CONFIG_BCMA=y
CONFIG_BCMA_BLOCKIO=y
# CONFIG_BCMA_HOST_SOC is not set
# CONFIG_BCMA_DRIVER_GMAC_CMN is not set
# CONFIG_BCMA_DRIVER_GPIO is not set
# CONFIG_BCMA_DEBUG is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_SUN4I_GPADC is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_AC100 is not set
CONFIG_MFD_AXP20X=y
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_AXP20X_RSB=y
# CONFIG_MFD_CROS_EC is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8XXX is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RTSX_USB is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_SMSC is not set
# CONFIG_ABX500_CORE is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SUN6I_PRCM=y
CONFIG_MFD_SYSCON=y
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
# CONFIG_REGULATOR_ANATOP is not set
CONFIG_REGULATOR_AXP20X=y
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
# CONFIG_REGULATOR_PWM is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
CONFIG_MEDIA_SUPPORT=y
# Multimedia core support
CONFIG_MEDIA_CAMERA_SUPPORT=y
# CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
# CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
# CONFIG_MEDIA_RADIO_SUPPORT is not set
# CONFIG_MEDIA_SDR_SUPPORT is not set
# CONFIG_MEDIA_RC_SUPPORT is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
# CONFIG_MEDIA_CONTROLLER is not set
CONFIG_VIDEO_DEV=y
CONFIG_VIDEO_V4L2=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
CONFIG_VIDEOBUF2_CORE=y
CONFIG_VIDEOBUF2_MEMOPS=y
CONFIG_VIDEOBUF2_VMALLOC=y
# CONFIG_TTPCI_EEPROM is not set
# Media drivers
CONFIG_MEDIA_USB_SUPPORT=y
# Webcam devices
CONFIG_USB_VIDEO_CLASS=y
CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y
# CONFIG_USB_GSPCA is not set
# CONFIG_USB_PWC is not set
# CONFIG_VIDEO_CPIA2 is not set
# CONFIG_USB_ZR364XX is not set
# CONFIG_USB_STKWEBCAM is not set
# CONFIG_USB_S2255 is not set
# CONFIG_VIDEO_USBTV is not set
# Webcam, TV (analog/digital) USB devices
# CONFIG_VIDEO_EM28XX is not set
# CONFIG_V4L_PLATFORM_DRIVERS is not set
# CONFIG_V4L_MEM2MEM_DRIVERS is not set
# CONFIG_V4L_TEST_DRIVERS is not set
# Supported MMC/SDIO adapters
# CONFIG_CYPRESS_FIRMWARE is not set
# Media ancillary drivers (tuners, sensors, i2c, spi, frontends)
# CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set
# I2C Encoders, decoders, sensors and other helper chips
# Audio decoders, processors and mixers
# CONFIG_VIDEO_TVAUDIO is not set
# CONFIG_VIDEO_TDA7432 is not set
# CONFIG_VIDEO_TDA9840 is not set
# CONFIG_VIDEO_TEA6415C is not set
# CONFIG_VIDEO_TEA6420 is not set
# CONFIG_VIDEO_MSP3400 is not set
# CONFIG_VIDEO_CS3308 is not set
# CONFIG_VIDEO_CS5345 is not set
# CONFIG_VIDEO_CS53L32A is not set
# CONFIG_VIDEO_TLV320AIC23B is not set
# CONFIG_VIDEO_UDA1342 is not set
# CONFIG_VIDEO_WM8775 is not set
# CONFIG_VIDEO_WM8739 is not set
# CONFIG_VIDEO_VP27SMPX is not set
# CONFIG_VIDEO_SONY_BTF_MPX is not set
# RDS decoders
# CONFIG_VIDEO_SAA6588 is not set
# Video decoders
# CONFIG_VIDEO_ADV7183 is not set
# CONFIG_VIDEO_BT819 is not set
# CONFIG_VIDEO_BT856 is not set
# CONFIG_VIDEO_BT866 is not set
# CONFIG_VIDEO_KS0127 is not set
# CONFIG_VIDEO_ML86V7667 is not set
# CONFIG_VIDEO_SAA7110 is not set
# CONFIG_VIDEO_SAA711X is not set
# CONFIG_VIDEO_TVP514X is not set
# CONFIG_VIDEO_TVP5150 is not set
# CONFIG_VIDEO_TVP7002 is not set
# CONFIG_VIDEO_TW2804 is not set
# CONFIG_VIDEO_TW9903 is not set
# CONFIG_VIDEO_TW9906 is not set
# CONFIG_VIDEO_VPX3220 is not set
# Video and audio decoders
# CONFIG_VIDEO_SAA717X is not set
# CONFIG_VIDEO_CX25840 is not set
# Video encoders
# CONFIG_VIDEO_SAA7127 is not set
# CONFIG_VIDEO_SAA7185 is not set
# CONFIG_VIDEO_ADV7170 is not set
# CONFIG_VIDEO_ADV7175 is not set
# CONFIG_VIDEO_ADV7343 is not set
# CONFIG_VIDEO_ADV7393 is not set
# CONFIG_VIDEO_AK881X is not set
# CONFIG_VIDEO_THS8200 is not set
# Camera sensor devices
# CONFIG_VIDEO_OV2640 is not set
# CONFIG_VIDEO_OV2659 is not set
# CONFIG_VIDEO_OV7640 is not set
# CONFIG_VIDEO_OV7670 is not set
# CONFIG_VIDEO_VS6624 is not set
# CONFIG_VIDEO_MT9M111 is not set
# CONFIG_VIDEO_MT9V011 is not set
# CONFIG_VIDEO_SR030PC30 is not set
# Flash devices
# Video improvement chips
# CONFIG_VIDEO_UPD64031A is not set
# CONFIG_VIDEO_UPD64083 is not set
# Audio/Video compression chips
# CONFIG_VIDEO_SAA6752HS is not set
# SDR tuner chips
# Miscellaneous helper chips
# CONFIG_VIDEO_THS7303 is not set
# CONFIG_VIDEO_M52790 is not set
# Sensors used on soc_camera driver
# SPI helper chips
# Customise DVB Frontends
# Tools to develop new frontends
# Graphics support
# CONFIG_IMX_IPUV3_CORE is not set
CONFIG_DRM=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DEBUG_MM is not set
# CONFIG_DRM_DEBUG_MM_SELFTEST is not set
CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_KMS_FB_HELPER=y
CONFIG_DRM_FBDEV_EMULATION=y
CONFIG_DRM_FBDEV_OVERALLOC=100
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# ACP (Audio CoProcessor) Configuration
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_EXYNOS is not set
# CONFIG_DRM_UDL is not set
# CONFIG_DRM_ARMADA is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
CONFIG_DRM_SUN4I=y
CONFIG_DRM_SUN4I_HDMI=y
CONFIG_DRM_SUN4I_BACKEND=y
CONFIG_DRM_SUN8I_MIXER=y
# CONFIG_DRM_OMAP is not set
# CONFIG_DRM_TILCDC is not set
# CONFIG_DRM_FSL_DCU is not set
# CONFIG_DRM_STM is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
CONFIG_DRM_DUMB_VGA_DAC=y
# CONFIG_DRM_LVDS_ENCODER is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_SIL_SII8620 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_I2C_ADV7511 is not set
# CONFIG_DRM_STI is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_MXSFB is not set
# CONFIG_DRM_TINYDRM is not set
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_LEGACY is not set
# CONFIG_DRM_LIB_RANDOM is not set
# Frame buffer Devices
CONFIG_FB=y
# CONFIG_FIRMWARE_EDID is not set
CONFIG_FB_CMDLINE=y
CONFIG_FB_NOTIFY=y
# CONFIG_FB_DDC is not set
# CONFIG_FB_BOOT_VESA_SUPPORT is not set
CONFIG_FB_CFB_FILLRECT=y
CONFIG_FB_CFB_COPYAREA=y
CONFIG_FB_CFB_IMAGEBLIT=y
# CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set
CONFIG_FB_SYS_FILLRECT=y
CONFIG_FB_SYS_COPYAREA=y
CONFIG_FB_SYS_IMAGEBLIT=y
# CONFIG_FB_PROVIDE_GET_FB_UNMAPPED_AREA is not set
# CONFIG_FB_FOREIGN_ENDIAN is not set
CONFIG_FB_SYS_FOPS=y
CONFIG_FB_DEFERRED_IO=y
# CONFIG_FB_SVGALIB is not set
# CONFIG_FB_MACMODES is not set
# CONFIG_FB_BACKLIGHT is not set
# CONFIG_FB_MODE_HELPERS is not set
# CONFIG_FB_TILEBLITTING is not set
# Frame buffer hardware drivers
# CONFIG_FB_OPENCORES is not set
# CONFIG_FB_S1D13XXX is not set
# CONFIG_FB_SMSCUFX is not set
# CONFIG_FB_UDL is not set
# CONFIG_FB_IBM_GXT4500 is not set
# CONFIG_FB_VIRTUAL is not set
# CONFIG_FB_METRONOME is not set
# CONFIG_FB_BROADSHEET is not set
# CONFIG_FB_AUO_K190X is not set
CONFIG_FB_SIMPLE=y
# CONFIG_FB_SSD1307 is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# CONFIG_VGASTATE is not set
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE=y
CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
# CONFIG_LOGO is not set
CONFIG_SOUND=y
# CONFIG_SOUND_OSS_CORE is not set
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_DMAENGINE_PCM=y
CONFIG_SND_RAWMIDI=m
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
# CONFIG_SND_OSSEMUL is not set
CONFIG_SND_PCM_TIMER=y
# CONFIG_SND_HRTIMER is not set
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# CONFIG_SND_SEQUENCER is not set
# CONFIG_SND_OPL3_LIB_SEQ is not set
# CONFIG_SND_OPL4_LIB_SEQ is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
# CONFIG_SND_ALOOP is not set
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
# HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_ARM=y
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
# CONFIG_SND_USB_AUDIO is not set
# CONFIG_SND_USB_UA101 is not set
# CONFIG_SND_USB_CAIAQ is not set
# CONFIG_SND_USB_6FIRE is not set
# CONFIG_SND_USB_HIFACE is not set
# CONFIG_SND_BCD2000 is not set
# CONFIG_SND_USB_POD is not set
# CONFIG_SND_USB_PODHD is not set
# CONFIG_SND_USB_TONEPORT is not set
# CONFIG_SND_USB_VARIAX is not set
CONFIG_SND_SOC=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# STMicroelectronics STM32 SOC audio support
# Allwinner SoC Audio support
CONFIG_SND_SUN4I_CODEC=y
# CONFIG_SND_SUN8I_CODEC is not set
CONFIG_SND_SUN8I_CODEC_ANALOG=y
# CONFIG_SND_SUN4I_I2S is not set
# CONFIG_SND_SUN4I_SPDIF is not set
# CONFIG_SND_SOC_XTFPGA_I2S is not set
# CONFIG_ZX_TDM is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CODEC drivers
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
# CONFIG_SND_SOC_ADAU7002 is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS4271_SPI is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_DIO2125 is not set
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_RT5677_SPI is not set
# CONFIG_SND_SOC_SGTL5000 is not set
# CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set
# CONFIG_SND_SOC_SPDIF is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
# CONFIG_SND_SOC_TLV320AIC3X is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
# CONFIG_SND_SOC_ZX_AUD96P22 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
# CONFIG_SND_SIMPLE_CARD is not set
# CONFIG_SND_SIMPLE_SCU_CARD is not set
# CONFIG_SND_AUDIO_GRAPH_CARD is not set
# CONFIG_SND_AUDIO_GRAPH_SCU_CARD is not set
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
CONFIG_HID_GENERIC=y
# Special HID drivers
CONFIG_HID_A4TECH=y
# CONFIG_HID_ACCUTOUCH is not set
# CONFIG_HID_ACRUX is not set
CONFIG_HID_APPLE=y
# CONFIG_HID_APPLEIR is not set
# CONFIG_HID_ASUS is not set
# CONFIG_HID_AUREAL is not set
CONFIG_HID_BELKIN=y
# CONFIG_HID_BETOP_FF is not set
CONFIG_HID_CHERRY=y
CONFIG_HID_CHICONY=y
# CONFIG_HID_CORSAIR is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CMEDIA is not set
CONFIG_HID_CYPRESS=y
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_ELO is not set
CONFIG_HID_EZKEY=y
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_GT683R is not set
# CONFIG_HID_KEYTOUCH is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_ICADE is not set
CONFIG_HID_ITE=y
# CONFIG_HID_TWINHAN is not set
CONFIG_HID_KENSINGTON=y
# CONFIG_HID_LCPOWER is not set
# CONFIG_HID_LED is not set
# CONFIG_HID_LENOVO is not set
CONFIG_HID_LOGITECH=y
# CONFIG_HID_LOGITECH_HIDPP is not set
# CONFIG_LOGITECH_FF is not set
# CONFIG_LOGIRUMBLEPAD2_FF is not set
# CONFIG_LOGIG940_FF is not set
# CONFIG_LOGIWHEELS_FF is not set
# CONFIG_HID_MAGICMOUSE is not set
# CONFIG_HID_MAYFLASH is not set
CONFIG_HID_MICROSOFT=y
CONFIG_HID_MONTEREY=y
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NTI is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PENMOUNT is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_RETRODE is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_RMI is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THINGM is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_WIIMOTE is not set
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# USB HID support
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
# CONFIG_USB_HIDDEV is not set
# I2C HID support
# CONFIG_I2C_HID is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG is not set
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
# CONFIG_USB_MON is not set
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
# CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED=y
CONFIG_USB_EHCI_HCD_PLATFORM=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1362_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=y
# CONFIG_USB_OHCI_HCD_SSB is not set
CONFIG_USB_OHCI_HCD_PLATFORM=y
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HCD_BCMA is not set
# CONFIG_USB_HCD_SSB is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
CONFIG_USB_ACM=y
# CONFIG_USB_PRINTER is not set
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
CONFIG_USB_STORAGE=y
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_REALTEK is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_ONETOUCH is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
# CONFIG_USB_STORAGE_ENE_UB6250 is not set
# CONFIG_USB_UAS is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USBIP_CORE is not set
CONFIG_USB_MUSB_HDRC=y
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_GADGET is not set
CONFIG_USB_MUSB_DUAL_ROLE=y
# Platform Glue Layer
CONFIG_USB_MUSB_SUNXI=y
# MUSB DMA mode
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_DWC3 is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
CONFIG_USB_SERIAL=y
CONFIG_USB_SERIAL_CONSOLE=y
CONFIG_USB_SERIAL_GENERIC=y
CONFIG_USB_SERIAL_SIMPLE=y
# CONFIG_USB_SERIAL_AIRCABLE is not set
# CONFIG_USB_SERIAL_ARK3116 is not set
# CONFIG_USB_SERIAL_BELKIN is not set
CONFIG_USB_SERIAL_CH341=y
# CONFIG_USB_SERIAL_WHITEHEAT is not set
# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
CONFIG_USB_SERIAL_CP210X=y
# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
# CONFIG_USB_SERIAL_EMPEG is not set
CONFIG_USB_SERIAL_FTDI_SIO=y
# CONFIG_USB_SERIAL_VISOR is not set
# CONFIG_USB_SERIAL_IPAQ is not set
# CONFIG_USB_SERIAL_IR is not set
# CONFIG_USB_SERIAL_EDGEPORT is not set
# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
# CONFIG_USB_SERIAL_F81232 is not set
# CONFIG_USB_SERIAL_F8153X is not set
# CONFIG_USB_SERIAL_GARMIN is not set
# CONFIG_USB_SERIAL_IPW is not set
# CONFIG_USB_SERIAL_IUU is not set
# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
# CONFIG_USB_SERIAL_KEYSPAN is not set
# CONFIG_USB_SERIAL_KLSI is not set
# CONFIG_USB_SERIAL_KOBIL_SCT is not set
# CONFIG_USB_SERIAL_MCT_U232 is not set
# CONFIG_USB_SERIAL_METRO is not set
# CONFIG_USB_SERIAL_MOS7720 is not set
# CONFIG_USB_SERIAL_MOS7840 is not set
# CONFIG_USB_SERIAL_MXUPORT is not set
# CONFIG_USB_SERIAL_NAVMAN is not set
CONFIG_USB_SERIAL_PL2303=y
# CONFIG_USB_SERIAL_OTI6858 is not set
# CONFIG_USB_SERIAL_QCAUX is not set
# CONFIG_USB_SERIAL_QUALCOMM is not set
# CONFIG_USB_SERIAL_SPCP8X5 is not set
# CONFIG_USB_SERIAL_SAFE is not set
# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
# CONFIG_USB_SERIAL_SYMBOL is not set
# CONFIG_USB_SERIAL_TI is not set
# CONFIG_USB_SERIAL_CYBERJACK is not set
# CONFIG_USB_SERIAL_XIRCOM is not set
# CONFIG_USB_SERIAL_OPTION is not set
# CONFIG_USB_SERIAL_OMNINET is not set
# CONFIG_USB_SERIAL_OPTICON is not set
# CONFIG_USB_SERIAL_XSENS_MT is not set
# CONFIG_USB_SERIAL_WISHBONE is not set
# CONFIG_USB_SERIAL_SSU100 is not set
# CONFIG_USB_SERIAL_QT2 is not set
# CONFIG_USB_SERIAL_UPD78F0730 is not set
# CONFIG_USB_SERIAL_DEBUG is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
# CONFIG_USB_EZUSB_FX2 is not set
# CONFIG_USB_HUB_USB251XB is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# USB Physical Layer drivers
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=y
# CONFIG_AM335X_PHY_USB is not set
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG is not set
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# CONFIG_U_SERIAL_CONSOLE is not set
# USB Peripheral Controller
# CONFIG_USB_FUSB300 is not set
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_DUMMY_HCD is not set
CONFIG_USB_LIBCOMPOSITE=m
CONFIG_USB_F_ACM=m
CONFIG_USB_F_SS_LB=m
CONFIG_USB_U_SERIAL=m
CONFIG_USB_U_ETHER=m
CONFIG_USB_U_AUDIO=m
CONFIG_USB_F_SERIAL=m
CONFIG_USB_F_OBEX=m
CONFIG_USB_F_NCM=m
CONFIG_USB_F_ECM=m
CONFIG_USB_F_SUBSET=m
CONFIG_USB_F_RNDIS=m
CONFIG_USB_F_MASS_STORAGE=m
CONFIG_USB_F_FS=m
CONFIG_USB_F_UAC2=m
CONFIG_USB_F_UVC=m
CONFIG_USB_F_MIDI=m
CONFIG_USB_F_HID=m
CONFIG_USB_F_PRINTER=m
# CONFIG_USB_CONFIGFS is not set
CONFIG_USB_ZERO=m
CONFIG_USB_AUDIO=m
# CONFIG_GADGET_UAC1 is not set
CONFIG_USB_ETH=m
CONFIG_USB_ETH_RNDIS=y
# CONFIG_USB_ETH_EEM is not set
CONFIG_USB_G_NCM=m
CONFIG_USB_GADGETFS=m
CONFIG_USB_FUNCTIONFS=m
# CONFIG_USB_FUNCTIONFS_ETH is not set
# CONFIG_USB_FUNCTIONFS_RNDIS is not set
CONFIG_USB_FUNCTIONFS_GENERIC=y
CONFIG_USB_MASS_STORAGE=m
CONFIG_USB_G_SERIAL=m
CONFIG_USB_MIDI_GADGET=m
CONFIG_USB_G_PRINTER=m
CONFIG_USB_CDC_COMPOSITE=m
CONFIG_USB_G_ACM_MS=m
CONFIG_USB_G_MULTI=m
CONFIG_USB_G_MULTI_RNDIS=y
# CONFIG_USB_G_MULTI_CDC is not set
CONFIG_USB_G_HID=m
CONFIG_USB_G_DBGP=m
# CONFIG_USB_G_DBGP_PRINTK is not set
CONFIG_USB_G_DBGP_SERIAL=y
CONFIG_USB_G_WEBCAM=m
# USB Power Delivery and Type-C drivers
# CONFIG_TYPEC_UCSI is not set
# CONFIG_USB_LED_TRIG is not set
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_UWB is not set
CONFIG_MMC=y
# CONFIG_MMC_DEBUG is not set
CONFIG_PWRSEQ_EMMC=y
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_SDHCI is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
CONFIG_MMC_SUNXI=y
# CONFIG_MMC_MTK is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3642 is not set
# CONFIG_LEDS_PCA9532 is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP5521 is not set
# CONFIG_LEDS_LP5523 is not set
# CONFIG_LEDS_LP5562 is not set
# CONFIG_LEDS_LP8501 is not set
# CONFIG_LEDS_LP8860 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_PCA963X is not set
# CONFIG_LEDS_DAC124S085 is not set
# CONFIG_LEDS_PWM is not set
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# CONFIG_LEDS_USER is not set
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
# CONFIG_LEDS_TRIGGER_TIMER is not set
# CONFIG_LEDS_TRIGGER_ONESHOT is not set
# CONFIG_LEDS_TRIGGER_MTD is not set
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
# CONFIG_LEDS_TRIGGER_CPU is not set
# CONFIG_LEDS_TRIGGER_GPIO is not set
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
# CONFIG_LEDS_TRIGGER_TRANSIENT is not set
# CONFIG_LEDS_TRIGGER_CAMERA is not set
# CONFIG_LEDS_TRIGGER_PANIC is not set
# CONFIG_ACCESSIBILITY is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
# CONFIG_RTC_INTF_SYSFS is not set
# CONFIG_RTC_INTF_PROC is not set
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABX80X is not set
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_HYM8563 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8523 is not set
# CONFIG_RTC_DRV_PCF85063 is not set
CONFIG_RTC_DRV_PCF8563=y
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8010 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# CONFIG_RTC_DRV_EM3027 is not set
# CONFIG_RTC_DRV_RV8803 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T93 is not set
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1302 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6916 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RX4581 is not set
# CONFIG_RTC_DRV_RX6110 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_PCF2127 is not set
# CONFIG_RTC_DRV_RV3029C2 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_SUN6I=y
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_SNVS is not set
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
# CONFIG_RTC_DRV_HID_SENSOR_TIME is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
CONFIG_DMA_SUN6I=y
# CONFIG_FSL_EDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# CONFIG_VIRT_DRIVERS is not set
# Virtio drivers
# CONFIG_VIRTIO_MMIO is not set
# Microsoft Hyper-V guest support
# CONFIG_HYPERV_TSCPAGE is not set
CONFIG_STAGING=y
# CONFIG_PRISM2_USB is not set
# CONFIG_COMEDI is not set
# CONFIG_RTLLIB is not set
CONFIG_RTL8723BS=m
# CONFIG_R8712U is not set
# CONFIG_R8188EU is not set
# CONFIG_VT6656 is not set
# Speakup console speech
# CONFIG_SPEAKUP is not set
# CONFIG_STAGING_MEDIA is not set
# Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_LNET is not set
# CONFIG_GS_FPGABOOT is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
# CONFIG_FB_TFT is not set
# CONFIG_WILC1000_SDIO is not set
# CONFIG_WILC1000_SPI is not set
# CONFIG_MOST is not set
# CONFIG_KS7010 is not set
# CONFIG_GREYBUS is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
# CONFIG_TYPEC_TCPM is not set
# CONFIG_GOLDFISH is not set
# CONFIG_CHROME_PLATFORMS is not set
CONFIG_CLKDEV_LOOKUP=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Common Clock Framework
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_CLK_QORIQ is not set
# CONFIG_COMMON_CLK_NXP is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_PXA is not set
# CONFIG_COMMON_CLK_PIC32 is not set
# CONFIG_COMMON_CLK_VC5 is not set
CONFIG_SUNXI_CCU=y
# CONFIG_SUN8I_A23_CCU is not set
# CONFIG_SUN8I_A33_CCU is not set
CONFIG_SUN8I_A83T_CCU=y
# CONFIG_SUN8I_H3_CCU is not set
CONFIG_SUN8I_V3S_CCU=y
CONFIG_SUN8I_DE2_CCU=y
CONFIG_SUN8I_R_CCU=y
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_SUN4I_TIMER=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
# CONFIG_ARM_TIMER_SP804 is not set
# CONFIG_ATMEL_PIT is not set
# CONFIG_SH_TIMER_CMT is not set
# CONFIG_SH_TIMER_MTU2 is not set
# CONFIG_SH_TIMER_TMU is not set
# CONFIG_EM_TIMER_STI is not set
# CONFIG_MAILBOX is not set
# CONFIG_IOMMU_SUPPORT is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# Rpmsg drivers
# SOC (System On Chip) specific Drivers
# Broadcom SoC drivers
# CONFIG_SOC_BRCMSTB is not set
# i.MX SoC drivers
CONFIG_SUNXI_SRAM=y
# CONFIG_SOC_TI is not set
# CONFIG_PM_DEVFREQ is not set
CONFIG_EXTCON=y
# Extcon Device Drivers
# CONFIG_EXTCON_AXP288 is not set
# CONFIG_EXTCON_GPIO is not set
# CONFIG_EXTCON_MAX3355 is not set
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
# CONFIG_EXTCON_USB_GPIO is not set
# CONFIG_MEMORY is not set
# CONFIG_IIO is not set
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_PCA9685 is not set
CONFIG_PWM_SUN4I=y
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
# CONFIG_IPACK_BUS is not set
CONFIG_ARCH_HAS_RESET_CONTROLLER=y
CONFIG_RESET_CONTROLLER=y
# CONFIG_RESET_ATH79 is not set
# CONFIG_RESET_BERLIN is not set
# CONFIG_RESET_GEMINI is not set
# CONFIG_RESET_IMX7 is not set
# CONFIG_RESET_LPC18XX is not set
# CONFIG_RESET_MESON is not set
# CONFIG_RESET_PISTACHIO is not set
# CONFIG_RESET_SOCFPGA is not set
# CONFIG_RESET_STM32 is not set
CONFIG_RESET_SUNXI=y
# CONFIG_RESET_TI_SYSCON is not set
# CONFIG_RESET_ZYNQ is not set
# CONFIG_RESET_TEGRA_BPMP is not set
# CONFIG_FMC is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
CONFIG_PHY_SUN4I_USB=y
# CONFIG_PHY_SUN9I_USB is not set
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
CONFIG_ARM_PMU=y
# CONFIG_RAS is not set
# Android
# CONFIG_ANDROID is not set
# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SUNXI_SID=y
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# FPGA Configuration Support
# CONFIG_FPGA is not set
# FSI support
# CONFIG_FSI is not set
# CONFIG_TEE is not set
# Firmware Drivers
CONFIG_ARM_PSCI_FW=y
# CONFIG_ARM_PSCI_CHECKER is not set
# CONFIG_FIRMWARE_MEMMAP is not set
# CONFIG_FW_CFG_SYSFS is not set
CONFIG_HAVE_ARM_SMCCC=y
# CONFIG_GOOGLE_FIRMWARE is not set
# Tegra firmware driver
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_USE_FOR_EXT2=y
# CONFIG_EXT4_FS_POSIX_ACL is not set
# CONFIG_EXT4_FS_SECURITY is not set
# CONFIG_EXT4_ENCRYPTION is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
CONFIG_MANDATORY_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
# CONFIG_QUOTA is not set
# CONFIG_QUOTACTL is not set
# CONFIG_AUTOFS4_FS is not set
# CONFIG_FUSE_FS is not set
# CONFIG_OVERLAY_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=y
# CONFIG_MSDOS_FS is not set
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_FAT_DEFAULT_UTF8 is not set
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
# CONFIG_TMPFS is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_CONFIGFS_FS=y
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_JFFS2_FS=y
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
CONFIG_JFFS2_FS_WBUF_VERIFY=y
CONFIG_JFFS2_SUMMARY=y
CONFIG_JFFS2_FS_XATTR=y
CONFIG_JFFS2_FS_POSIX_ACL=y
CONFIG_JFFS2_FS_SECURITY=y
CONFIG_JFFS2_COMPRESSION_OPTIONS=y
CONFIG_JFFS2_ZLIB=y
CONFIG_JFFS2_LZO=y
CONFIG_JFFS2_RTIME=y
CONFIG_JFFS2_RUBIN=y
# CONFIG_JFFS2_CMODE_NONE is not set
CONFIG_JFFS2_CMODE_PRIORITY=y
# CONFIG_JFFS2_CMODE_SIZE is not set
# CONFIG_JFFS2_CMODE_FAVOURLZO is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
# CONFIG_NFS_FS is not set
# CONFIG_NFSD is not set
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_NCP_FS is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="utf8"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
CONFIG_NLS_CODEPAGE_936=y
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
CONFIG_NLS_UTF8=y
# CONFIG_DLM is not set
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_DYNAMIC_DEBUG is not set
# Compile-time checks and compiler options
# CONFIG_DEBUG_INFO is not set
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_READABLE_ASM is not set
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_PAGE_OWNER is not set
CONFIG_DEBUG_FS=y
# CONFIG_HEADERS_CHECK is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set
# CONFIG_MAGIC_SYSRQ is not set
CONFIG_DEBUG_KERNEL=y
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_DEBUG_PAGEALLOC is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
# CONFIG_DEBUG_KMEMLEAK is not set
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_DEBUG_VM is not set
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
# CONFIG_DEBUG_VIRTUAL is not set
CONFIG_DEBUG_MEMORY_INIT=y
# CONFIG_DEBUG_PER_CPU_MAPS is not set
# CONFIG_DEBUG_HIGHMEM is not set
# CONFIG_DEBUG_SHIRQ is not set
# Debug Lockups and Hangs
# CONFIG_SOFTLOCKUP_DETECTOR is not set
# CONFIG_DETECT_HUNG_TASK is not set
# CONFIG_WQ_WATCHDOG is not set
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
CONFIG_SCHED_DEBUG=y
# CONFIG_SCHED_INFO is not set
# CONFIG_SCHEDSTATS is not set
# CONFIG_SCHED_STACK_END_CHECK is not set
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_ATOMIC_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_LOCK_TORTURE_TEST is not set
# CONFIG_WW_MUTEX_SELFTEST is not set
# CONFIG_STACKTRACE is not set
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# CONFIG_DEBUG_KOBJECT is not set
CONFIG_DEBUG_BUGVERBOSE=y
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_PI_LIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_DEBUG_NOTIFIERS is not set
# CONFIG_DEBUG_CREDENTIALS is not set
# RCU Debugging
# CONFIG_PROVE_RCU is not set
# CONFIG_TORTURE_TEST is not set
# CONFIG_RCU_PERF_TEST is not set
# CONFIG_RCU_TORTURE_TEST is not set
CONFIG_RCU_CPU_STALL_TIMEOUT=21
CONFIG_RCU_TRACE=y
# CONFIG_RCU_EQS_DEBUG is not set
# CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set
# CONFIG_NOTIFIER_ERROR_INJECTION is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_LATENCYTOP is not set
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACE_CLOCK=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
# Runtime Testing
# CONFIG_LKDTM is not set
# CONFIG_TEST_LIST_SORT is not set
# CONFIG_TEST_SORT is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_RBTREE_TEST is not set
# CONFIG_INTERVAL_TREE_TEST is not set
# CONFIG_PERCPU_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_HASH is not set
# CONFIG_DMA_API_DEBUG is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_MEMTEST is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
# CONFIG_ARCH_WANTS_UBSAN_NO_NULL is not set
# CONFIG_UBSAN is not set
CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
# CONFIG_STRICT_DEVMEM is not set
# CONFIG_ARM_PTDUMP is not set
CONFIG_ARM_UNWIND=y
# CONFIG_DEBUG_USER is not set
# CONFIG_DEBUG_LL is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
# CONFIG_DEBUG_UART_8250 is not set
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_CORESIGHT is not set
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_DEFAULT_SECURITY=""
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_RNG_DEFAULT=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_ACOMP2=y
# CONFIG_CRYPTO_RSA is not set
# CONFIG_CRYPTO_DH is not set
# CONFIG_CRYPTO_ECDH is not set
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_USER is not set
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
CONFIG_CRYPTO_GF128MUL=y
CONFIG_CRYPTO_NULL=y
CONFIG_CRYPTO_NULL2=y
# CONFIG_CRYPTO_PCRYPT is not set
CONFIG_CRYPTO_WORKQUEUE=y
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_MCRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
CONFIG_CRYPTO_CCM=y
CONFIG_CRYPTO_GCM=y
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
CONFIG_CRYPTO_SEQIV=y
CONFIG_CRYPTO_ECHAINIV=m
# Block modes
# CONFIG_CRYPTO_CBC is not set
CONFIG_CRYPTO_CTR=y
# CONFIG_CRYPTO_CTS is not set
# CONFIG_CRYPTO_ECB is not set
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# CONFIG_CRYPTO_KEYWRAP is not set
# Hash modes
CONFIG_CRYPTO_CMAC=y
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_CRC32 is not set
# CONFIG_CRYPTO_CRCT10DIF is not set
CONFIG_CRYPTO_GHASH=y
# CONFIG_CRYPTO_POLY1305 is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=y
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_SHA3 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=y
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
# CONFIG_CRYPTO_DEFLATE is not set
# CONFIG_CRYPTO_LZO is not set
# CONFIG_CRYPTO_842 is not set
# CONFIG_CRYPTO_LZ4 is not set
# CONFIG_CRYPTO_LZ4HC is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_DRBG_MENU=y
CONFIG_CRYPTO_DRBG_HMAC=y
# CONFIG_CRYPTO_DRBG_HASH is not set
# CONFIG_CRYPTO_DRBG_CTR is not set
CONFIG_CRYPTO_DRBG=y
CONFIG_CRYPTO_JITTERENTROPY=y
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API_DESC is not set
CONFIG_CRYPTO_DEV_SUN4I_SS=y
# Certificates for signature checking
# CONFIG_ARM_CRYPTO is not set
# CONFIG_BINARY_PRINTF is not set
# Library routines
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_RATIONAL=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_GENERIC_IO=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
# CONFIG_CRC_CCITT is not set
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC4 is not set
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
# CONFIG_CRC8 is not set
# CONFIG_AUDIT_ARCH_COMPAT_GENERIC is not set
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
# CONFIG_DMA_NOOP_OPS is not set
# CONFIG_DMA_VIRT_OPS is not set
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_NLATTR=y
CONFIG_CORDIC=y
# CONFIG_DDR is not set
# CONFIG_IRQ_POLL is not set
CONFIG_LIBFDT=y
CONFIG_FONT_SUPPORT=y
# CONFIG_FONTS is not set
CONFIG_FONT_8x8=y
CONFIG_FONT_8x16=y
# CONFIG_SG_SPLIT is not set
CONFIG_SG_POOL=y
CONFIG_ARCH_HAS_SG_CHAIN=y
CONFIG_SBITMAP=y
# CONFIG_VIRTUALIZATION is not set勾上 wireless 相关的协议和驱动
文件系统还需要两个固件:
/lib/firmware/brcm/brcmfmac43430-sdio.bin
/lib/firmware/brcm/brcmfmac43430-sdio.txt
https://github.com/armbian/firmware/tree/master/brcm
https://github.com/RPi-Distro/firmware-nonfree/blob/master/brcm/
下载地址:
https://raw.githubusercontent.com/armbian/firmware/master/brcm/brcmfmac43430-sdio.txt
https://raw.githubusercontent.com/armbian/firmware/master/brcm/brcmfmac43430-sdio.bin
wpa_supplicant /hotapd 使用方法可以参考esp8089: https://whycan.cn/t_2091.html#p19662
使用方法:
hostapd -d /etc/hostapd.conf
开热点, 显示很全的 loghostapd -B /etc/hostapd.conf
不显示 log, 后台运行wpa_supplicant -i wlan0 -D wext -c /etc/wpa_supplicant.conf -d
连接 路由器, 显示很全的 logwpa_supplicant -i wlan0 -D wext -c /etc/wpa_supplicant.conf -B
不显示 log, 后台运行
顶顶,晕哥威武,几下就弄好了,也找了个新的固件,bcm43438有 A0 A1的版本区别,固件是不通用的
@晕哥, 网上看到的,有些固件里面文件名后缀会标明a0 a1,我也试过几个
https://github.com/torvalds/linux/blob/master/drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c
https://github.com/torvalds/linux/blob/v4.13/drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c
BRCMF_FW_NVRAM_DEF(43430A0, "brcmfmac43430a0-sdio.bin", "brcmfmac43430a0-sdio.txt");
/ Note the names are not postfixed with a1 for backward compatibility /
BRCMF_FW_NVRAM_DEF(43430A1, "brcmfmac43430-sdio.bin", "brcmfmac43430-sdio.txt");
从代码来看, 这个brcmfmac43430-sdio.bin 应该是 A1 版本.
AP6212 稳定工作将近 24 小时了,
测试了从电脑一次性下载 11.6 G的文件, 耗时 1小时46分左右
11616.504723 / (13600+4560 + 37) = 1.833 MB/s = 14.664Mbps
测试环境 Windows10 + VMware + Ubuntu16.04 + Apache2 + 同一个路由器(电脑5G频段, AP6212 2.4G频段)
如果电脑用网线, 应该速度会更好一些.
ioctl[SIOCSIWENCODEEXT]: Invalid argument
上面这个问题修正:
wpa_supplicant -i wlan0 -D nl80211 -c /etc/wpa_supplicant.conf -B
坛主威武,搞得如此之深,片子是比较经典了,决定了只要不停产就一直用它
/files/members/3/2019-05-30_145548.png
/files/members/3/2019-05-30_145514.png
/files/members/3/2019-05-31_102544.png
hq_s3_v1_defconfig 配置文件:
# # Automatically generated file; DO NOT EDIT. # Linux/arm 4.13.16 Kernel Configuration # CONFIG_ARM=y CONFIG_ARM_HAS_SG_CHAIN=y CONFIG_MIGHT_HAVE_PCI=y CONFIG_SYS_SUPPORTS_APM_EMULATION=y CONFIG_HAVE_PROC_CPU=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_TRACE_IRQFLAGS_SUPPORT=y CONFIG_RWSEM_XCHGADD_ALGORITHM=y CONFIG_FIX_EARLYCON_MEM=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_NEED_DMA_MAP_STATE=y CONFIG_ARCH_SUPPORTS_UPROBES=y CONFIG_VECTORS_BASE=0xffff0000 CONFIG_ARM_PATCH_PHYS_VIRT=y CONFIG_GENERIC_BUG=y CONFIG_PGTABLE_LEVELS=2 CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" CONFIG_IRQ_WORK=y CONFIG_BUILDTIME_EXTABLE_SORT=y # # General setup # CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_CROSS_COMPILE="" # CONFIG_COMPILE_TEST is not set CONFIG_LOCALVERSION="-licheepi-zero" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_HAVE_KERNEL_GZIP=y CONFIG_HAVE_KERNEL_LZMA=y CONFIG_HAVE_KERNEL_XZ=y CONFIG_HAVE_KERNEL_LZO=y CONFIG_HAVE_KERNEL_LZ4=y CONFIG_KERNEL_GZIP=y # CONFIG_KERNEL_LZMA is not set # CONFIG_KERNEL_XZ is not set # CONFIG_KERNEL_LZO is not set # CONFIG_KERNEL_LZ4 is not set CONFIG_DEFAULT_HOSTNAME="(none)" CONFIG_SWAP=y # CONFIG_SYSVIPC is not set # CONFIG_POSIX_MQUEUE is not set CONFIG_CROSS_MEMORY_ATTACH=y CONFIG_FHANDLE=y # CONFIG_USELIB is not set # CONFIG_AUDIT is not set CONFIG_HAVE_ARCH_AUDITSYSCALL=y # # IRQ subsystem # CONFIG_GENERIC_IRQ_PROBE=y CONFIG_GENERIC_IRQ_SHOW=y CONFIG_GENERIC_IRQ_SHOW_LEVEL=y CONFIG_HARDIRQS_SW_RESEND=y CONFIG_GENERIC_IRQ_CHIP=y CONFIG_IRQ_DOMAIN=y CONFIG_IRQ_DOMAIN_HIERARCHY=y CONFIG_HANDLE_DOMAIN_IRQ=y # CONFIG_IRQ_DOMAIN_DEBUG is not set CONFIG_IRQ_FORCED_THREADING=y CONFIG_SPARSE_IRQ=y # CONFIG_GENERIC_IRQ_DEBUGFS is not set CONFIG_ARCH_CLOCKSOURCE_DATA=y CONFIG_GENERIC_TIME_VSYSCALL=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_ARCH_HAS_TICK_BROADCAST=y CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y # # Timers subsystem # CONFIG_TICK_ONESHOT=y CONFIG_NO_HZ_COMMON=y # CONFIG_HZ_PERIODIC is not set CONFIG_NO_HZ_IDLE=y # CONFIG_NO_HZ_FULL is not set CONFIG_NO_HZ=y CONFIG_HIGH_RES_TIMERS=y # # CPU/Task time and stats accounting # CONFIG_TICK_CPU_ACCOUNTING=y # CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set # CONFIG_IRQ_TIME_ACCOUNTING is not set # CONFIG_BSD_PROCESS_ACCT is not set # CONFIG_TASKSTATS is not set # # RCU Subsystem # CONFIG_TREE_RCU=y # CONFIG_RCU_EXPERT is not set CONFIG_SRCU=y CONFIG_TREE_SRCU=y # CONFIG_TASKS_RCU is not set CONFIG_RCU_STALL_COMMON=y CONFIG_RCU_NEED_SEGCBLIST=y # CONFIG_BUILD_BIN2C is not set # CONFIG_IKCONFIG is not set CONFIG_LOG_BUF_SHIFT=17 CONFIG_LOG_CPU_MAX_BUF_SHIFT=12 CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13 CONFIG_GENERIC_SCHED_CLOCK=y CONFIG_CGROUPS=y # CONFIG_MEMCG is not set # CONFIG_BLK_CGROUP is not set # CONFIG_CGROUP_SCHED is not set # CONFIG_CGROUP_PIDS is not set # CONFIG_CGROUP_RDMA is not set # CONFIG_CGROUP_FREEZER is not set # CONFIG_CPUSETS is not set # CONFIG_CGROUP_DEVICE is not set # CONFIG_CGROUP_CPUACCT is not set # CONFIG_CGROUP_PERF is not set # CONFIG_CGROUP_DEBUG is not set # CONFIG_SOCK_CGROUP_DATA is not set # CONFIG_CHECKPOINT_RESTORE is not set CONFIG_NAMESPACES=y CONFIG_UTS_NS=y # CONFIG_USER_NS is not set CONFIG_PID_NS=y CONFIG_NET_NS=y # CONFIG_SCHED_AUTOGROUP is not set # CONFIG_SYSFS_DEPRECATED is not set # CONFIG_RELAY is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y CONFIG_RD_XZ=y CONFIG_RD_LZO=y CONFIG_RD_LZ4=y CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_SYSCTL=y CONFIG_ANON_INODES=y CONFIG_HAVE_UID16=y CONFIG_BPF=y # CONFIG_EXPERT is not set CONFIG_UID16=y CONFIG_MULTIUSER=y # CONFIG_SGETMASK_SYSCALL is not set CONFIG_SYSFS_SYSCALL=y # CONFIG_SYSCTL_SYSCALL is not set CONFIG_POSIX_TIMERS=y CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_ALL is not set # CONFIG_KALLSYMS_ABSOLUTE_PERCPU is not set CONFIG_KALLSYMS_BASE_RELATIVE=y CONFIG_PRINTK=y CONFIG_PRINTK_NMI=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y # CONFIG_BPF_SYSCALL is not set CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_ADVISE_SYSCALLS=y # CONFIG_USERFAULTFD is not set CONFIG_MEMBARRIER=y # CONFIG_EMBEDDED is not set CONFIG_HAVE_PERF_EVENTS=y CONFIG_PERF_USE_VMALLOC=y # CONFIG_PC104 is not set # # Kernel Performance Events And Counters # CONFIG_PERF_EVENTS=y # CONFIG_DEBUG_PERF_USE_VMALLOC is not set CONFIG_VM_EVENT_COUNTERS=y CONFIG_SLUB_DEBUG=y CONFIG_COMPAT_BRK=y # CONFIG_SLAB is not set CONFIG_SLUB=y CONFIG_SLAB_MERGE_DEFAULT=y # CONFIG_SLAB_FREELIST_RANDOM is not set CONFIG_SLUB_CPU_PARTIAL=y # CONFIG_SYSTEM_DATA_VERIFICATION is not set # CONFIG_PROFILING is not set CONFIG_HAVE_OPROFILE=y # CONFIG_KPROBES is not set # CONFIG_JUMP_LABEL is not set # CONFIG_UPROBES is not set # CONFIG_HAVE_64BIT_ALIGNED_ACCESS is not set CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y CONFIG_ARCH_USE_BUILTIN_BSWAP=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_OPTPROBES=y CONFIG_HAVE_NMI=y CONFIG_HAVE_ARCH_TRACEHOOK=y CONFIG_HAVE_DMA_CONTIGUOUS=y CONFIG_GENERIC_SMP_IDLE_THREAD=y CONFIG_GENERIC_IDLE_POLL_SETUP=y CONFIG_ARCH_HAS_SET_MEMORY=y CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y CONFIG_HAVE_CLK=y CONFIG_HAVE_DMA_API_DEBUG=y CONFIG_HAVE_HW_BREAKPOINT=y CONFIG_HAVE_PERF_REGS=y CONFIG_HAVE_PERF_USER_STACK_DUMP=y CONFIG_HAVE_ARCH_JUMP_LABEL=y CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y CONFIG_HAVE_ARCH_SECCOMP_FILTER=y CONFIG_HAVE_GCC_PLUGINS=y # CONFIG_GCC_PLUGINS is not set CONFIG_HAVE_CC_STACKPROTECTOR=y # CONFIG_CC_STACKPROTECTOR is not set CONFIG_CC_STACKPROTECTOR_NONE=y # CONFIG_CC_STACKPROTECTOR_REGULAR is not set # CONFIG_CC_STACKPROTECTOR_STRONG is not set CONFIG_THIN_ARCHIVES=y CONFIG_HAVE_CONTEXT_TRACKING=y CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y CONFIG_HAVE_MOD_ARCH_SPECIFIC=y CONFIG_MODULES_USE_ELF_REL=y CONFIG_ARCH_HAS_ELF_RANDOMIZE=y CONFIG_HAVE_ARCH_MMAP_RND_BITS=y CONFIG_HAVE_EXIT_THREAD=y CONFIG_ARCH_MMAP_RND_BITS_MIN=8 CONFIG_ARCH_MMAP_RND_BITS_MAX=16 CONFIG_ARCH_MMAP_RND_BITS=8 # CONFIG_HAVE_ARCH_HASH is not set # CONFIG_ISA_BUS_API is not set CONFIG_CLONE_BACKWARDS=y CONFIG_OLD_SIGSUSPEND3=y CONFIG_OLD_SIGACTION=y # CONFIG_CPU_NO_EFFICIENT_FFS is not set # CONFIG_HAVE_ARCH_VMAP_STACK is not set CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y CONFIG_STRICT_KERNEL_RWX=y CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y CONFIG_STRICT_MODULE_RWX=y # CONFIG_REFCOUNT_FULL is not set # # GCOV-based kernel profiling # # CONFIG_GCOV_KERNEL is not set CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y CONFIG_HAVE_GENERIC_DMA_COHERENT=y CONFIG_SLABINFO=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y # CONFIG_MODULE_FORCE_LOAD is not set CONFIG_MODULE_UNLOAD=y # CONFIG_MODULE_FORCE_UNLOAD is not set # CONFIG_MODVERSIONS is not set # CONFIG_MODULE_SRCVERSION_ALL is not set # CONFIG_MODULE_SIG is not set # CONFIG_MODULE_COMPRESS is not set # CONFIG_TRIM_UNUSED_KSYMS is not set CONFIG_MODULES_TREE_LOOKUP=y CONFIG_BLOCK=y CONFIG_LBDAF=y CONFIG_BLK_SCSI_REQUEST=y CONFIG_BLK_DEV_BSG=y # CONFIG_BLK_DEV_BSGLIB is not set # CONFIG_BLK_DEV_INTEGRITY is not set # CONFIG_BLK_DEV_ZONED is not set CONFIG_BLK_CMDLINE_PARSER=y # CONFIG_BLK_WBT is not set CONFIG_BLK_DEBUG_FS=y # CONFIG_BLK_SED_OPAL is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y CONFIG_EFI_PARTITION=y # # IO Schedulers # CONFIG_IOSCHED_NOOP=y CONFIG_IOSCHED_DEADLINE=y CONFIG_IOSCHED_CFQ=y # CONFIG_DEFAULT_DEADLINE is not set CONFIG_DEFAULT_CFQ=y # CONFIG_DEFAULT_NOOP is not set CONFIG_DEFAULT_IOSCHED="cfq" CONFIG_MQ_IOSCHED_DEADLINE=y CONFIG_MQ_IOSCHED_KYBER=y # CONFIG_IOSCHED_BFQ is not set CONFIG_INLINE_SPIN_UNLOCK_IRQ=y CONFIG_INLINE_READ_UNLOCK=y CONFIG_INLINE_READ_UNLOCK_IRQ=y CONFIG_INLINE_WRITE_UNLOCK=y CONFIG_INLINE_WRITE_UNLOCK_IRQ=y CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y CONFIG_MUTEX_SPIN_ON_OWNER=y CONFIG_RWSEM_SPIN_ON_OWNER=y CONFIG_LOCK_SPIN_ON_OWNER=y CONFIG_FREEZER=y # # System Type # CONFIG_MMU=y CONFIG_ARCH_MULTIPLATFORM=y # CONFIG_ARCH_EBSA110 is not set # CONFIG_ARCH_EP93XX is not set # CONFIG_ARCH_FOOTBRIDGE is not set # CONFIG_ARCH_NETX is not set # CONFIG_ARCH_IOP13XX is not set # CONFIG_ARCH_IOP32X is not set # CONFIG_ARCH_IOP33X is not set # CONFIG_ARCH_IXP4XX is not set # CONFIG_ARCH_DOVE is not set # CONFIG_ARCH_KS8695 is not set # CONFIG_ARCH_W90X900 is not set # CONFIG_ARCH_LPC32XX is not set # CONFIG_ARCH_PXA is not set # CONFIG_ARCH_RPC is not set # CONFIG_ARCH_SA1100 is not set # CONFIG_ARCH_S3C24XX is not set # CONFIG_ARCH_DAVINCI is not set # CONFIG_ARCH_OMAP1 is not set # # Multiple platform selection # # # CPU Core family selection # # CONFIG_ARCH_MULTI_V6 is not set CONFIG_ARCH_MULTI_V7=y CONFIG_ARCH_MULTI_V6_V7=y # CONFIG_ARCH_MULTI_CPU_AUTO is not set # CONFIG_ARCH_VIRT is not set # CONFIG_ARCH_MVEBU is not set # CONFIG_ARCH_ACTIONS is not set # CONFIG_ARCH_ALPINE is not set # CONFIG_ARCH_ARTPEC is not set # CONFIG_ARCH_AT91 is not set # CONFIG_ARCH_BCM is not set # CONFIG_ARCH_BERLIN is not set # CONFIG_ARCH_DIGICOLOR is not set # CONFIG_ARCH_HIGHBANK is not set # CONFIG_ARCH_HISI is not set # CONFIG_ARCH_KEYSTONE is not set # CONFIG_ARCH_MESON is not set # CONFIG_ARCH_MXC is not set # CONFIG_ARCH_MEDIATEK is not set # # TI OMAP/AM/DM/DRA Family # # CONFIG_ARCH_OMAP3 is not set # CONFIG_ARCH_OMAP4 is not set # CONFIG_SOC_OMAP5 is not set # CONFIG_SOC_AM33XX is not set # CONFIG_SOC_AM43XX is not set # CONFIG_SOC_DRA7XX is not set # CONFIG_ARCH_MMP is not set # CONFIG_ARCH_QCOM is not set # CONFIG_ARCH_REALVIEW is not set # CONFIG_ARCH_ROCKCHIP is not set # CONFIG_ARCH_SOCFPGA is not set # CONFIG_PLAT_SPEAR is not set # CONFIG_ARCH_STI is not set # CONFIG_ARCH_S5PV210 is not set # CONFIG_ARCH_EXYNOS is not set # CONFIG_ARCH_RENESAS is not set CONFIG_ARCH_SUNXI=y # CONFIG_MACH_SUN4I is not set # CONFIG_MACH_SUN5I is not set # CONFIG_MACH_SUN6I is not set # CONFIG_MACH_SUN7I is not set CONFIG_MACH_SUN8I=y # CONFIG_MACH_SUN9I is not set # CONFIG_ARCH_SIRF is not set # CONFIG_ARCH_TANGO is not set # CONFIG_ARCH_TEGRA is not set # CONFIG_ARCH_UNIPHIER is not set # CONFIG_ARCH_U8500 is not set # CONFIG_ARCH_VEXPRESS is not set # CONFIG_ARCH_WM8850 is not set # CONFIG_ARCH_ZX is not set # CONFIG_ARCH_ZYNQ is not set # # Processor Type # CONFIG_CPU_V7=y CONFIG_CPU_THUMB_CAPABLE=y CONFIG_CPU_32v6K=y CONFIG_CPU_32v7=y CONFIG_CPU_ABRT_EV7=y CONFIG_CPU_PABRT_V7=y CONFIG_CPU_CACHE_V7=y CONFIG_CPU_CACHE_VIPT=y CONFIG_CPU_COPY_V6=y CONFIG_CPU_TLB_V7=y CONFIG_CPU_HAS_ASID=y CONFIG_CPU_CP15=y CONFIG_CPU_CP15_MMU=y # # Processor Features # # CONFIG_ARM_LPAE is not set # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set CONFIG_ARM_THUMB=y # CONFIG_ARM_THUMBEE is not set CONFIG_ARM_VIRT_EXT=y CONFIG_SWP_EMULATE=y # CONFIG_CPU_ICACHE_DISABLE is not set # CONFIG_CPU_BPREDICT_DISABLE is not set CONFIG_KUSER_HELPERS=y CONFIG_VDSO=y CONFIG_OUTER_CACHE=y CONFIG_OUTER_CACHE_SYNC=y CONFIG_MIGHT_HAVE_CACHE_L2X0=y CONFIG_CACHE_L2X0=y # CONFIG_CACHE_L2X0_PMU is not set # CONFIG_PL310_ERRATA_588369 is not set # CONFIG_PL310_ERRATA_727915 is not set # CONFIG_PL310_ERRATA_753970 is not set # CONFIG_PL310_ERRATA_769419 is not set CONFIG_ARM_L1_CACHE_SHIFT_6=y CONFIG_ARM_L1_CACHE_SHIFT=6 CONFIG_ARM_DMA_MEM_BUFFERABLE=y CONFIG_ARM_HEAVY_MB=y CONFIG_DEBUG_ALIGN_RODATA=y CONFIG_MULTI_IRQ_HANDLER=y # CONFIG_ARM_ERRATA_430973 is not set CONFIG_ARM_ERRATA_643719=y # CONFIG_ARM_ERRATA_720789 is not set # CONFIG_ARM_ERRATA_754322 is not set # CONFIG_ARM_ERRATA_754327 is not set # CONFIG_ARM_ERRATA_764369 is not set # CONFIG_ARM_ERRATA_775420 is not set # CONFIG_ARM_ERRATA_798181 is not set # CONFIG_ARM_ERRATA_773022 is not set # CONFIG_ARM_ERRATA_818325_852422 is not set # CONFIG_ARM_ERRATA_821420 is not set # CONFIG_ARM_ERRATA_825619 is not set # CONFIG_ARM_ERRATA_852421 is not set # CONFIG_ARM_ERRATA_852423 is not set # # Bus support # # CONFIG_PCI is not set # CONFIG_PCI_DOMAINS_GENERIC is not set # CONFIG_PCI_SYSCALL is not set # # DesignWare PCI Core Support # # # PCI Endpoint # # CONFIG_PCI_ENDPOINT is not set # CONFIG_PCCARD is not set # # Kernel Features # CONFIG_HAVE_SMP=y CONFIG_SMP=y CONFIG_SMP_ON_UP=y CONFIG_ARM_CPU_TOPOLOGY=y # CONFIG_SCHED_MC is not set # CONFIG_SCHED_SMT is not set CONFIG_HAVE_ARM_ARCH_TIMER=y # CONFIG_MCPM is not set # CONFIG_BIG_LITTLE is not set CONFIG_VMSPLIT_3G=y # CONFIG_VMSPLIT_3G_OPT is not set # CONFIG_VMSPLIT_2G is not set # CONFIG_VMSPLIT_1G is not set CONFIG_PAGE_OFFSET=0xC0000000 CONFIG_NR_CPUS=8 CONFIG_HOTPLUG_CPU=y CONFIG_ARM_PSCI=y CONFIG_ARCH_NR_GPIO=416 CONFIG_PREEMPT_NONE=y # CONFIG_PREEMPT_VOLUNTARY is not set # CONFIG_PREEMPT is not set CONFIG_HZ_FIXED=0 CONFIG_HZ_100=y # CONFIG_HZ_200 is not set # CONFIG_HZ_250 is not set # CONFIG_HZ_300 is not set # CONFIG_HZ_500 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=100 CONFIG_SCHED_HRTICK=y # CONFIG_THUMB2_KERNEL is not set CONFIG_ARM_PATCH_IDIV=y CONFIG_AEABI=y # CONFIG_OABI_COMPAT is not set # CONFIG_ARCH_SPARSEMEM_DEFAULT is not set # CONFIG_ARCH_SELECT_MEMORY_MODEL is not set CONFIG_HAVE_ARCH_PFN_VALID=y CONFIG_HIGHMEM=y CONFIG_HIGHPTE=y CONFIG_CPU_SW_DOMAIN_PAN=y CONFIG_HW_PERF_EVENTS=y CONFIG_ARCH_WANT_GENERAL_HUGETLB=y # CONFIG_ARM_MODULE_PLTS is not set CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_HAVE_MEMBLOCK=y CONFIG_NO_BOOTMEM=y # CONFIG_HAVE_BOOTMEM_INFO_NODE is not set CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_COMPACTION=y CONFIG_MIGRATION=y # CONFIG_PHYS_ADDR_T_64BIT is not set CONFIG_BOUNCE=y # CONFIG_KSM is not set CONFIG_DEFAULT_MMAP_MIN_ADDR=4096 # CONFIG_ARCH_WANTS_THP_SWAP is not set # CONFIG_CLEANCACHE is not set # CONFIG_FRONTSWAP is not set # CONFIG_CMA is not set # CONFIG_ZPOOL is not set # CONFIG_ZBUD is not set # CONFIG_ZSMALLOC is not set CONFIG_GENERIC_EARLY_IOREMAP=y # CONFIG_IDLE_PAGE_TRACKING is not set CONFIG_FRAME_VECTOR=y # CONFIG_PERCPU_STATS is not set CONFIG_FORCE_MAX_ZONEORDER=11 CONFIG_ALIGNMENT_TRAP=y # CONFIG_UACCESS_WITH_MEMCPY is not set # CONFIG_SECCOMP is not set CONFIG_SWIOTLB=y CONFIG_IOMMU_HELPER=y # CONFIG_PARAVIRT is not set # CONFIG_PARAVIRT_TIME_ACCOUNTING is not set # CONFIG_XEN is not set # # Boot options # CONFIG_USE_OF=y CONFIG_ATAGS=y # CONFIG_DEPRECATED_PARAM_STRUCT is not set CONFIG_ZBOOT_ROM_TEXT=0 CONFIG_ZBOOT_ROM_BSS=0 CONFIG_ARM_APPENDED_DTB=y CONFIG_ARM_ATAG_DTB_COMPAT=y CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y # CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set CONFIG_CMDLINE="" # CONFIG_KEXEC is not set # CONFIG_CRASH_DUMP is not set CONFIG_AUTO_ZRELADDR=y # CONFIG_EFI is not set # # CPU Power Management # # # CPU Frequency scaling # CONFIG_CPU_FREQ=y # CONFIG_CPU_FREQ_STAT is not set CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE=y # CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set # CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL is not set CONFIG_CPU_FREQ_GOV_PERFORMANCE=y # CONFIG_CPU_FREQ_GOV_POWERSAVE is not set # CONFIG_CPU_FREQ_GOV_USERSPACE is not set # CONFIG_CPU_FREQ_GOV_ONDEMAND is not set # CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set # CONFIG_CPU_FREQ_GOV_SCHEDUTIL is not set # # CPU frequency scaling drivers # CONFIG_CPUFREQ_DT=y CONFIG_CPUFREQ_DT_PLATDEV=y # CONFIG_ARM_BIG_LITTLE_CPUFREQ is not set # CONFIG_ARM_DB8500_CPUFREQ is not set # CONFIG_ARM_KIRKWOOD_CPUFREQ is not set # CONFIG_QORIQ_CPUFREQ is not set # # CPU Idle # # CONFIG_CPU_IDLE is not set # CONFIG_ARCH_NEEDS_CPU_IDLE_COUPLED is not set # # Floating point emulation # # # At least one emulation must be selected # CONFIG_VFP=y CONFIG_VFPv3=y CONFIG_NEON=y # CONFIG_KERNEL_MODE_NEON is not set # # Userspace binary formats # CONFIG_BINFMT_ELF=y CONFIG_ELFCORE=y CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y CONFIG_BINFMT_SCRIPT=y # CONFIG_BINFMT_FLAT is not set # CONFIG_HAVE_AOUT is not set # CONFIG_BINFMT_MISC is not set CONFIG_COREDUMP=y # # Power management options # CONFIG_SUSPEND=y CONFIG_SUSPEND_FREEZER=y # CONFIG_HIBERNATION is not set CONFIG_PM_SLEEP=y CONFIG_PM_SLEEP_SMP=y # CONFIG_PM_AUTOSLEEP is not set # CONFIG_PM_WAKELOCKS is not set CONFIG_PM=y # CONFIG_PM_DEBUG is not set # CONFIG_APM_EMULATION is not set CONFIG_PM_OPP=y CONFIG_PM_CLK=y # CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set CONFIG_CPU_PM=y CONFIG_ARCH_SUSPEND_POSSIBLE=y CONFIG_ARM_CPU_SUSPEND=y CONFIG_ARCH_HIBERNATION_POSSIBLE=y CONFIG_NET=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_DIAG is not set CONFIG_UNIX=y # CONFIG_UNIX_DIAG is not set # CONFIG_TLS is not set # CONFIG_XFRM_USER is not set # CONFIG_NET_KEY is not set CONFIG_INET=y # CONFIG_IP_MULTICAST is not set # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y # CONFIG_IP_PNP_RARP is not set # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE_DEMUX is not set # CONFIG_NET_IP_TUNNEL is not set # CONFIG_SYN_COOKIES is not set # CONFIG_NET_UDP_TUNNEL is not set # CONFIG_NET_FOU is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set # CONFIG_INET_XFRM_TUNNEL is not set # CONFIG_INET_TUNNEL is not set # CONFIG_INET_XFRM_MODE_TRANSPORT is not set # CONFIG_INET_XFRM_MODE_TUNNEL is not set # CONFIG_INET_XFRM_MODE_BEET is not set # CONFIG_INET_DIAG is not set # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set # CONFIG_IPV6 is not set # CONFIG_NETWORK_SECMARK is not set CONFIG_NET_PTP_CLASSIFY=y # CONFIG_NETWORK_PHY_TIMESTAMPING is not set # CONFIG_NETFILTER is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_RDS is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_L2TP is not set # CONFIG_BRIDGE is not set CONFIG_HAVE_NET_DSA=y # CONFIG_NET_DSA is not set # CONFIG_VLAN_8021Q is not set # CONFIG_DECNET is not set # CONFIG_LLC2 is not set # CONFIG_IPX is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_PHONET is not set # CONFIG_IEEE802154 is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set # CONFIG_BATMAN_ADV is not set # CONFIG_OPENVSWITCH is not set # CONFIG_VSOCKETS is not set # CONFIG_NETLINK_DIAG is not set # CONFIG_MPLS is not set # CONFIG_HSR is not set # CONFIG_NET_SWITCHDEV is not set # CONFIG_NET_L3_MASTER_DEV is not set # CONFIG_NET_NCSI is not set CONFIG_RPS=y CONFIG_RFS_ACCEL=y CONFIG_XPS=y # CONFIG_CGROUP_NET_PRIO is not set # CONFIG_CGROUP_NET_CLASSID is not set CONFIG_NET_RX_BUSY_POLL=y CONFIG_BQL=y # CONFIG_BPF_JIT is not set CONFIG_NET_FLOW_LIMIT=y # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_IRDA is not set # CONFIG_BT is not set # CONFIG_AF_RXRPC is not set # CONFIG_AF_KCM is not set # CONFIG_STREAM_PARSER is not set CONFIG_WIRELESS=y CONFIG_WIRELESS_EXT=y CONFIG_WEXT_CORE=y CONFIG_WEXT_PROC=y CONFIG_WEXT_PRIV=y CONFIG_CFG80211=y # CONFIG_NL80211_TESTMODE is not set # CONFIG_CFG80211_DEVELOPER_WARNINGS is not set CONFIG_CFG80211_DEFAULT_PS=y # CONFIG_CFG80211_DEBUGFS is not set # CONFIG_CFG80211_INTERNAL_REGDB is not set CONFIG_CFG80211_CRDA_SUPPORT=y CONFIG_CFG80211_WEXT=y # CONFIG_LIB80211 is not set CONFIG_MAC80211=y CONFIG_MAC80211_HAS_RC=y CONFIG_MAC80211_RC_MINSTREL=y CONFIG_MAC80211_RC_MINSTREL_HT=y # CONFIG_MAC80211_RC_MINSTREL_VHT is not set CONFIG_MAC80211_RC_DEFAULT_MINSTREL=y CONFIG_MAC80211_RC_DEFAULT="minstrel_ht" # CONFIG_MAC80211_MESH is not set CONFIG_MAC80211_LEDS=y # CONFIG_MAC80211_DEBUGFS is not set # CONFIG_MAC80211_MESSAGE_TRACING is not set # CONFIG_MAC80211_DEBUG_MENU is not set CONFIG_MAC80211_STA_HASH_MAX_SIZE=0 # CONFIG_WIMAX is not set CONFIG_RFKILL=y CONFIG_RFKILL_LEDS=y CONFIG_RFKILL_INPUT=y CONFIG_RFKILL_GPIO=y # CONFIG_NET_9P is not set # CONFIG_CAIF is not set # CONFIG_CEPH_LIB is not set # CONFIG_NFC is not set # CONFIG_PSAMPLE is not set # CONFIG_NET_IFE is not set # CONFIG_LWTUNNEL is not set # CONFIG_DST_CACHE is not set # CONFIG_GRO_CELLS is not set # CONFIG_NET_DEVLINK is not set CONFIG_MAY_USE_DEVLINK=y CONFIG_HAVE_CBPF_JIT=y # # Device Drivers # # # Generic Driver Options # CONFIG_UEVENT_HELPER=y CONFIG_UEVENT_HELPER_PATH="" CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=y CONFIG_FIRMWARE_IN_KERNEL=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_FW_LOADER_USER_HELPER_FALLBACK is not set CONFIG_WANT_DEV_COREDUMP=y CONFIG_ALLOW_DEV_COREDUMP=y CONFIG_DEV_COREDUMP=y # CONFIG_DEBUG_DRIVER is not set # CONFIG_DEBUG_DEVRES is not set # CONFIG_DEBUG_TEST_DRIVER_REMOVE is not set # CONFIG_TEST_ASYNC_DRIVER_PROBE is not set # CONFIG_SYS_HYPERVISOR is not set # CONFIG_GENERIC_CPU_DEVICES is not set CONFIG_GENERIC_CPU_AUTOPROBE=y CONFIG_REGMAP=y CONFIG_REGMAP_I2C=y CONFIG_REGMAP_SPI=y CONFIG_REGMAP_MMIO=y CONFIG_REGMAP_IRQ=y CONFIG_DMA_SHARED_BUFFER=y # CONFIG_DMA_FENCE_TRACE is not set CONFIG_GENERIC_ARCH_TOPOLOGY=y # # Bus devices # # CONFIG_ARM_CCI400_PMU is not set # CONFIG_ARM_CCI5xx_PMU is not set # CONFIG_ARM_CCN is not set # CONFIG_BRCMSTB_GISB_ARB is not set # CONFIG_SIMPLE_PM_BUS is not set CONFIG_SUNXI_RSB=y # CONFIG_VEXPRESS_CONFIG is not set # CONFIG_CONNECTOR is not set CONFIG_MTD=y # CONFIG_MTD_TESTS is not set # CONFIG_MTD_REDBOOT_PARTS is not set CONFIG_MTD_CMDLINE_PARTS=y # CONFIG_MTD_AFS_PARTS is not set CONFIG_MTD_OF_PARTS=y # CONFIG_MTD_AR7_PARTS is not set # # Partition parsers # # # User Modules And Translation Layers # CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y # CONFIG_FTL is not set # CONFIG_NFTL is not set # CONFIG_INFTL is not set # CONFIG_RFD_FTL is not set # CONFIG_SSFDC is not set # CONFIG_SM_FTL is not set # CONFIG_MTD_OOPS is not set # CONFIG_MTD_SWAP is not set # CONFIG_MTD_PARTITIONED_MASTER is not set # # RAM/ROM/Flash chip drivers # # CONFIG_MTD_CFI is not set # CONFIG_MTD_JEDECPROBE is not set CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y # CONFIG_MTD_MAP_BANK_WIDTH_8 is not set # CONFIG_MTD_MAP_BANK_WIDTH_16 is not set # CONFIG_MTD_MAP_BANK_WIDTH_32 is not set CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y # CONFIG_MTD_CFI_I4 is not set # CONFIG_MTD_CFI_I8 is not set # CONFIG_MTD_RAM is not set # CONFIG_MTD_ROM is not set # CONFIG_MTD_ABSENT is not set # # Mapping drivers for chip access # # CONFIG_MTD_COMPLEX_MAPPINGS is not set # CONFIG_MTD_PLATRAM is not set # # Self-contained MTD device drivers # # CONFIG_MTD_DATAFLASH is not set CONFIG_MTD_M25P80=y # CONFIG_MTD_MCHP23K256 is not set # CONFIG_MTD_SST25L is not set # CONFIG_MTD_SLRAM is not set # CONFIG_MTD_PHRAM is not set # CONFIG_MTD_MTDRAM is not set CONFIG_MTD_BLOCK2MTD=y # # Disk-On-Chip Device Drivers # # CONFIG_MTD_DOCG3 is not set # CONFIG_MTD_NAND is not set # CONFIG_MTD_ONENAND is not set # # LPDDR & LPDDR2 PCM memory drivers # # CONFIG_MTD_LPDDR is not set # CONFIG_MTD_LPDDR2_NVM is not set CONFIG_MTD_SPI_NOR=y # CONFIG_MTD_MT81xx_NOR is not set CONFIG_MTD_SPI_NOR_USE_4K_SECTORS=y # CONFIG_SPI_CADENCE_QUADSPI is not set # CONFIG_MTD_UBI is not set CONFIG_DTC=y CONFIG_OF=y # CONFIG_OF_UNITTEST is not set CONFIG_OF_FLATTREE=y CONFIG_OF_EARLY_FLATTREE=y CONFIG_OF_ADDRESS=y CONFIG_OF_IRQ=y CONFIG_OF_NET=y CONFIG_OF_MDIO=y CONFIG_OF_RESERVED_MEM=y # CONFIG_OF_OVERLAY is not set CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_NULL_BLK is not set # CONFIG_BLK_DEV_COW_COMMON is not set # CONFIG_BLK_DEV_LOOP is not set # CONFIG_BLK_DEV_DRBD is not set # CONFIG_BLK_DEV_NBD is not set # CONFIG_BLK_DEV_RAM is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_BLK_DEV_RBD is not set # CONFIG_NVME_FC is not set # CONFIG_NVME_TARGET is not set # # Misc devices # # CONFIG_SENSORS_LIS3LV02D is not set # CONFIG_AD525X_DPOT is not set # CONFIG_DUMMY_IRQ is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_APDS9802ALS is not set # CONFIG_ISL29003 is not set # CONFIG_ISL29020 is not set # CONFIG_SENSORS_TSL2550 is not set # CONFIG_SENSORS_BH1770 is not set # CONFIG_SENSORS_APDS990X is not set # CONFIG_HMC6352 is not set # CONFIG_DS1682 is not set # CONFIG_TI_DAC7512 is not set # CONFIG_USB_SWITCH_FSA9480 is not set # CONFIG_LATTICE_ECP3_CONFIG is not set # CONFIG_SRAM is not set # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_AT24 is not set # CONFIG_EEPROM_AT25 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_MAX6875 is not set # CONFIG_EEPROM_93CX6 is not set # CONFIG_EEPROM_93XX46 is not set # CONFIG_EEPROM_IDT_89HPESX is not set # # Texas Instruments shared transport line discipline # # CONFIG_TI_ST is not set # CONFIG_SENSORS_LIS3_SPI is not set # CONFIG_SENSORS_LIS3_I2C is not set # # Altera FPGA firmware download module # # CONFIG_ALTERA_STAPL is not set # # Intel MIC Bus Driver # # # SCIF Bus Driver # # # VOP Bus Driver # # # Intel MIC Host Driver # # # Intel MIC Card Driver # # # SCIF Driver # # # Intel MIC Coprocessor State Management (COSM) Drivers # # # VOP Driver # # CONFIG_ECHO is not set # CONFIG_CXL_BASE is not set # CONFIG_CXL_AFU_DRIVER_OPS is not set # CONFIG_CXL_LIB is not set # # SCSI device support # CONFIG_SCSI_MOD=y # CONFIG_RAID_ATTRS is not set CONFIG_SCSI=y CONFIG_SCSI_DMA=y # CONFIG_SCSI_NETLINK is not set # CONFIG_SCSI_MQ_DEFAULT is not set CONFIG_SCSI_PROC_FS=y # # SCSI support type (disk, tape, CD-ROM) # CONFIG_BLK_DEV_SD=y # CONFIG_CHR_DEV_ST is not set # CONFIG_CHR_DEV_OSST is not set # CONFIG_BLK_DEV_SR is not set # CONFIG_CHR_DEV_SG is not set # CONFIG_CHR_DEV_SCH is not set # CONFIG_SCSI_CONSTANTS is not set # CONFIG_SCSI_LOGGING is not set # CONFIG_SCSI_SCAN_ASYNC is not set # # SCSI Transports # # CONFIG_SCSI_SPI_ATTRS is not set # CONFIG_SCSI_FC_ATTRS is not set # CONFIG_SCSI_ISCSI_ATTRS is not set # CONFIG_SCSI_SAS_ATTRS is not set # CONFIG_SCSI_SAS_LIBSAS is not set # CONFIG_SCSI_SRP_ATTRS is not set CONFIG_SCSI_LOWLEVEL=y # CONFIG_ISCSI_TCP is not set # CONFIG_ISCSI_BOOT_SYSFS is not set # CONFIG_SCSI_UFSHCD is not set # CONFIG_SCSI_DEBUG is not set # CONFIG_SCSI_DH is not set # CONFIG_SCSI_OSD_INITIATOR is not set # CONFIG_ATA is not set # CONFIG_MD is not set # CONFIG_TARGET_CORE is not set CONFIG_NETDEVICES=y CONFIG_MII=y CONFIG_NET_CORE=y # CONFIG_BONDING is not set # CONFIG_DUMMY is not set # CONFIG_EQUALIZER is not set # CONFIG_NET_TEAM is not set # CONFIG_MACVLAN is not set # CONFIG_VXLAN is not set # CONFIG_MACSEC is not set # CONFIG_NETCONSOLE is not set # CONFIG_NETPOLL is not set # CONFIG_NET_POLL_CONTROLLER is not set # CONFIG_TUN is not set # CONFIG_TUN_VNET_CROSS_LE is not set # CONFIG_VETH is not set # CONFIG_NLMON is not set # # CAIF transport drivers # # # Distributed Switch Architecture drivers # CONFIG_ETHERNET=y CONFIG_NET_VENDOR_ALACRITECH=y CONFIG_NET_VENDOR_ALLWINNER=y # CONFIG_SUN4I_EMAC is not set # CONFIG_ALTERA_TSE is not set CONFIG_NET_VENDOR_AMAZON=y CONFIG_NET_VENDOR_AQUANTIA=y # CONFIG_NET_VENDOR_ARC is not set # CONFIG_NET_VENDOR_AURORA is not set # CONFIG_NET_CADENCE is not set # CONFIG_NET_VENDOR_BROADCOM is not set # CONFIG_NET_VENDOR_CIRRUS is not set # CONFIG_DM9000 is not set # CONFIG_DNET is not set CONFIG_NET_VENDOR_EZCHIP=y # CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set # CONFIG_NET_VENDOR_FARADAY is not set CONFIG_NET_VENDOR_HISILICON=y # CONFIG_HIX5HD2_GMAC is not set # CONFIG_HISI_FEMAC is not set # CONFIG_HIP04_ETH is not set # CONFIG_HNS is not set # CONFIG_HNS_DSAF is not set # CONFIG_HNS_ENET is not set # CONFIG_NET_VENDOR_INTEL is not set # CONFIG_NET_VENDOR_MARVELL is not set # CONFIG_NET_VENDOR_MICREL is not set # CONFIG_NET_VENDOR_MICROCHIP is not set # CONFIG_NET_VENDOR_NATSEMI is not set CONFIG_NET_VENDOR_NETRONOME=y # CONFIG_ETHOC is not set CONFIG_NET_VENDOR_QUALCOMM=y # CONFIG_QCA7000_SPI is not set # CONFIG_QCOM_EMAC is not set CONFIG_NET_VENDOR_RENESAS=y CONFIG_NET_VENDOR_ROCKER=y # CONFIG_NET_VENDOR_SAMSUNG is not set # CONFIG_NET_VENDOR_SEEQ is not set CONFIG_NET_VENDOR_SOLARFLARE=y # CONFIG_NET_VENDOR_SMSC is not set CONFIG_NET_VENDOR_STMICRO=y CONFIG_STMMAC_ETH=y CONFIG_STMMAC_PLATFORM=y # CONFIG_DWMAC_DWC_QOS_ETH is not set CONFIG_DWMAC_GENERIC=y CONFIG_DWMAC_SUNXI=y CONFIG_DWMAC_SUN8I=y # CONFIG_NET_VENDOR_VIA is not set # CONFIG_NET_VENDOR_WIZNET is not set CONFIG_NET_VENDOR_SYNOPSYS=y # CONFIG_DWC_XLGMAC is not set CONFIG_MDIO_DEVICE=y CONFIG_MDIO_BUS=y # CONFIG_MDIO_BCM_UNIMAC is not set # CONFIG_MDIO_BITBANG is not set # CONFIG_MDIO_BUS_MUX_GPIO is not set # CONFIG_MDIO_BUS_MUX_MMIOREG is not set # CONFIG_MDIO_HISI_FEMAC is not set # CONFIG_MDIO_SUN4I is not set CONFIG_PHYLIB=y CONFIG_SWPHY=y # CONFIG_LED_TRIGGER_PHY is not set # # MII PHY device drivers # # CONFIG_AMD_PHY is not set # CONFIG_AQUANTIA_PHY is not set # CONFIG_AT803X_PHY is not set # CONFIG_BCM7XXX_PHY is not set # CONFIG_BCM87XX_PHY is not set # CONFIG_BROADCOM_PHY is not set # CONFIG_CICADA_PHY is not set # CONFIG_CORTINA_PHY is not set # CONFIG_DAVICOM_PHY is not set # CONFIG_DP83848_PHY is not set # CONFIG_DP83867_PHY is not set CONFIG_FIXED_PHY=y # CONFIG_ICPLUS_PHY is not set # CONFIG_INTEL_XWAY_PHY is not set # CONFIG_LSI_ET1011C_PHY is not set # CONFIG_LXT_PHY is not set # CONFIG_MARVELL_PHY is not set # CONFIG_MARVELL_10G_PHY is not set # CONFIG_MICREL_PHY is not set # CONFIG_MICROCHIP_PHY is not set # CONFIG_MICROSEMI_PHY is not set # CONFIG_NATIONAL_PHY is not set # CONFIG_QSEMI_PHY is not set # CONFIG_REALTEK_PHY is not set # CONFIG_SMSC_PHY is not set # CONFIG_STE10XP is not set # CONFIG_TERANETICS_PHY is not set # CONFIG_VITESSE_PHY is not set # CONFIG_XILINX_GMII2RGMII is not set # CONFIG_MICREL_KS8995MA is not set # CONFIG_PPP is not set # CONFIG_SLIP is not set CONFIG_USB_NET_DRIVERS=y # CONFIG_USB_CATC is not set # CONFIG_USB_KAWETH is not set # CONFIG_USB_PEGASUS is not set # CONFIG_USB_RTL8150 is not set # CONFIG_USB_RTL8152 is not set # CONFIG_USB_LAN78XX is not set # CONFIG_USB_USBNET is not set # CONFIG_USB_HSO is not set # CONFIG_USB_IPHETH is not set CONFIG_WLAN=y # CONFIG_WLAN_VENDOR_ADMTEK is not set # CONFIG_WLAN_VENDOR_ATH is not set # CONFIG_WLAN_VENDOR_ATMEL is not set CONFIG_WLAN_VENDOR_BROADCOM=y CONFIG_B43=m CONFIG_B43_BCMA=y CONFIG_B43_SSB=y CONFIG_B43_BUSES_BCMA_AND_SSB=y # CONFIG_B43_BUSES_BCMA is not set # CONFIG_B43_BUSES_SSB is not set CONFIG_B43_SDIO=y CONFIG_B43_BCMA_PIO=y CONFIG_B43_PIO=y CONFIG_B43_PHY_G=y CONFIG_B43_PHY_N=y CONFIG_B43_PHY_LP=y CONFIG_B43_PHY_HT=y CONFIG_B43_LEDS=y CONFIG_B43_DEBUG=y CONFIG_B43LEGACY=m CONFIG_B43LEGACY_LEDS=y CONFIG_B43LEGACY_DEBUG=y CONFIG_B43LEGACY_DMA=y CONFIG_B43LEGACY_PIO=y CONFIG_B43LEGACY_DMA_AND_PIO_MODE=y # CONFIG_B43LEGACY_DMA_MODE is not set # CONFIG_B43LEGACY_PIO_MODE is not set CONFIG_BRCMUTIL=m CONFIG_BRCMSMAC=m CONFIG_BRCMFMAC=m CONFIG_BRCMFMAC_PROTO_BCDC=y CONFIG_BRCMFMAC_SDIO=y CONFIG_BRCMFMAC_USB=y CONFIG_BRCM_TRACING=y CONFIG_BRCMDBG=y # CONFIG_WLAN_VENDOR_CISCO is not set # CONFIG_WLAN_VENDOR_INTEL is not set # CONFIG_WLAN_VENDOR_INTERSIL is not set # CONFIG_WLAN_VENDOR_MARVELL is not set # CONFIG_WLAN_VENDOR_MEDIATEK is not set # CONFIG_WLAN_VENDOR_RALINK is not set # CONFIG_WLAN_VENDOR_REALTEK is not set # CONFIG_WLAN_VENDOR_RSI is not set # CONFIG_WLAN_VENDOR_ST is not set # CONFIG_WLAN_VENDOR_TI is not set # CONFIG_WLAN_VENDOR_ZYDAS is not set # CONFIG_WLAN_VENDOR_QUANTENNA is not set # CONFIG_MAC80211_HWSIM is not set # CONFIG_USB_NET_RNDIS_WLAN is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # CONFIG_WAN is not set # CONFIG_ISDN is not set # CONFIG_NVM is not set # # Input device support # CONFIG_INPUT=y CONFIG_INPUT_LEDS=y # CONFIG_INPUT_FF_MEMLESS is not set CONFIG_INPUT_POLLDEV=y # CONFIG_INPUT_SPARSEKMAP is not set # CONFIG_INPUT_MATRIXKMAP is not set # # Userland interfaces # CONFIG_INPUT_MOUSEDEV=y CONFIG_INPUT_MOUSEDEV_PSAUX=y CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024 CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768 CONFIG_INPUT_JOYDEV=y CONFIG_INPUT_EVDEV=y # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y # CONFIG_KEYBOARD_ADP5588 is not set # CONFIG_KEYBOARD_ADP5589 is not set CONFIG_KEYBOARD_ATKBD=y # CONFIG_KEYBOARD_QT1070 is not set # CONFIG_KEYBOARD_QT2160 is not set # CONFIG_KEYBOARD_DLINK_DIR685 is not set # CONFIG_KEYBOARD_LKKBD is not set # CONFIG_KEYBOARD_GPIO is not set # CONFIG_KEYBOARD_GPIO_POLLED is not set # CONFIG_KEYBOARD_TCA6416 is not set # CONFIG_KEYBOARD_TCA8418 is not set # CONFIG_KEYBOARD_MATRIX is not set # CONFIG_KEYBOARD_LM8323 is not set # CONFIG_KEYBOARD_LM8333 is not set # CONFIG_KEYBOARD_MAX7359 is not set # CONFIG_KEYBOARD_MCS is not set # CONFIG_KEYBOARD_MPR121 is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_OPENCORES is not set # CONFIG_KEYBOARD_SAMSUNG is not set # CONFIG_KEYBOARD_STOWAWAY is not set # CONFIG_KEYBOARD_SUNKBD is not set CONFIG_KEYBOARD_SUN4I_LRADC=y # CONFIG_KEYBOARD_OMAP4 is not set # CONFIG_KEYBOARD_TM2_TOUCHKEY is not set # CONFIG_KEYBOARD_XTKBD is not set # CONFIG_KEYBOARD_CAP11XX is not set # CONFIG_KEYBOARD_BCM is not set # CONFIG_INPUT_MOUSE is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set CONFIG_INPUT_TOUCHSCREEN=y CONFIG_TOUCHSCREEN_PROPERTIES=y # CONFIG_TOUCHSCREEN_ADS7846 is not set # CONFIG_TOUCHSCREEN_AD7877 is not set # CONFIG_TOUCHSCREEN_AD7879 is not set # CONFIG_TOUCHSCREEN_AR1021_I2C is not set # CONFIG_TOUCHSCREEN_ATMEL_MXT is not set # CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set # CONFIG_TOUCHSCREEN_BU21013 is not set # CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set # CONFIG_TOUCHSCREEN_CY8CTMG110 is not set # CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set # CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set # CONFIG_TOUCHSCREEN_DYNAPRO is not set # CONFIG_TOUCHSCREEN_HAMPSHIRE is not set # CONFIG_TOUCHSCREEN_EETI is not set # CONFIG_TOUCHSCREEN_EGALAX is not set # CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set # CONFIG_TOUCHSCREEN_FUJITSU is not set # CONFIG_TOUCHSCREEN_GOODIX is not set # CONFIG_TOUCHSCREEN_ILI210X is not set # CONFIG_TOUCHSCREEN_GUNZE is not set # CONFIG_TOUCHSCREEN_EKTF2127 is not set # CONFIG_TOUCHSCREEN_ELAN is not set # CONFIG_TOUCHSCREEN_ELO is not set # CONFIG_TOUCHSCREEN_WACOM_W8001 is not set # CONFIG_TOUCHSCREEN_WACOM_I2C is not set # CONFIG_TOUCHSCREEN_MAX11801 is not set # CONFIG_TOUCHSCREEN_MCS5000 is not set # CONFIG_TOUCHSCREEN_MMS114 is not set # CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set # CONFIG_TOUCHSCREEN_MTOUCH is not set # CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set # CONFIG_TOUCHSCREEN_INEXIO is not set # CONFIG_TOUCHSCREEN_MK712 is not set # CONFIG_TOUCHSCREEN_PENMOUNT is not set CONFIG_TOUCHSCREEN_EDT_FT5X06=y CONFIG_TOUCHSCREEN_NS2009=y # CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set # CONFIG_TOUCHSCREEN_TOUCHWIN is not set # CONFIG_TOUCHSCREEN_PIXCIR is not set # CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set # CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set # CONFIG_TOUCHSCREEN_TOUCHIT213 is not set # CONFIG_TOUCHSCREEN_TSC_SERIO is not set # CONFIG_TOUCHSCREEN_TSC2004 is not set # CONFIG_TOUCHSCREEN_TSC2005 is not set # CONFIG_TOUCHSCREEN_TSC2007 is not set # CONFIG_TOUCHSCREEN_RM_TS is not set # CONFIG_TOUCHSCREEN_SILEAD is not set # CONFIG_TOUCHSCREEN_SIS_I2C is not set # CONFIG_TOUCHSCREEN_ST1232 is not set # CONFIG_TOUCHSCREEN_STMFTS is not set # CONFIG_TOUCHSCREEN_SUN4I is not set # CONFIG_TOUCHSCREEN_SUR40 is not set # CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set # CONFIG_TOUCHSCREEN_SX8654 is not set # CONFIG_TOUCHSCREEN_TPS6507X is not set # CONFIG_TOUCHSCREEN_ZET6223 is not set # CONFIG_TOUCHSCREEN_ZFORCE is not set # CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set CONFIG_INPUT_MISC=y # CONFIG_INPUT_AD714X is not set # CONFIG_INPUT_ATMEL_CAPTOUCH is not set # CONFIG_INPUT_BMA150 is not set # CONFIG_INPUT_E3X0_BUTTON is not set # CONFIG_INPUT_MMA8450 is not set # CONFIG_INPUT_GP2A is not set # CONFIG_INPUT_GPIO_BEEPER is not set # CONFIG_INPUT_GPIO_TILT_POLLED is not set # CONFIG_INPUT_GPIO_DECODER is not set # CONFIG_INPUT_ATI_REMOTE2 is not set # CONFIG_INPUT_KEYSPAN_REMOTE is not set # CONFIG_INPUT_KXTJ9 is not set # CONFIG_INPUT_POWERMATE is not set # CONFIG_INPUT_YEALINK is not set # CONFIG_INPUT_CM109 is not set # CONFIG_INPUT_REGULATOR_HAPTIC is not set CONFIG_INPUT_AXP20X_PEK=y # CONFIG_INPUT_UINPUT is not set # CONFIG_INPUT_PCF8574 is not set # CONFIG_INPUT_PWM_BEEPER is not set # CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set # CONFIG_INPUT_ADXL34X is not set # CONFIG_INPUT_IMS_PCU is not set # CONFIG_INPUT_CMA3000 is not set # CONFIG_INPUT_DRV260X_HAPTICS is not set # CONFIG_INPUT_DRV2665_HAPTICS is not set # CONFIG_INPUT_DRV2667_HAPTICS is not set # CONFIG_RMI4_CORE is not set # # Hardware I/O ports # CONFIG_SERIO=y CONFIG_SERIO_SERPORT=y CONFIG_SERIO_LIBPS2=y # CONFIG_SERIO_RAW is not set # CONFIG_SERIO_ALTERA_PS2 is not set # CONFIG_SERIO_PS2MULT is not set # CONFIG_SERIO_ARC_PS2 is not set # CONFIG_SERIO_APBPS2 is not set # CONFIG_SERIO_SUN4I_PS2 is not set # CONFIG_USERIO is not set # CONFIG_GAMEPORT is not set # # Character devices # CONFIG_TTY=y CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_VT_CONSOLE_SLEEP=y CONFIG_HW_CONSOLE=y CONFIG_VT_HW_CONSOLE_BINDING=y CONFIG_UNIX98_PTYS=y CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=256 # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_N_GSM is not set # CONFIG_TRACE_SINK is not set CONFIG_DEVMEM=y # CONFIG_DEVKMEM is not set # # Serial drivers # CONFIG_SERIAL_EARLYCON=y CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y # CONFIG_SERIAL_8250_FINTEK is not set CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_DMA=y CONFIG_SERIAL_8250_NR_UARTS=8 CONFIG_SERIAL_8250_RUNTIME_UARTS=8 # CONFIG_SERIAL_8250_EXTENDED is not set # CONFIG_SERIAL_8250_ASPEED_VUART is not set CONFIG_SERIAL_8250_FSL=y CONFIG_SERIAL_8250_DW=y # CONFIG_SERIAL_8250_EM is not set # CONFIG_SERIAL_8250_RT288X is not set CONFIG_SERIAL_OF_PLATFORM=y # # Non-8250 serial port support # # CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set # CONFIG_SERIAL_MAX3100 is not set # CONFIG_SERIAL_MAX310X is not set # CONFIG_SERIAL_UARTLITE is not set CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_SCCNXP is not set # CONFIG_SERIAL_SC16IS7XX is not set # CONFIG_SERIAL_BCM63XX is not set # CONFIG_SERIAL_ALTERA_JTAGUART is not set # CONFIG_SERIAL_ALTERA_UART is not set # CONFIG_SERIAL_IFX6X60 is not set # CONFIG_SERIAL_XILINX_PS_UART is not set # CONFIG_SERIAL_ARC is not set # CONFIG_SERIAL_FSL_LPUART is not set # CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set # CONFIG_SERIAL_ST_ASC is not set # CONFIG_SERIAL_DEV_BUS is not set # CONFIG_HVC_DCC is not set # CONFIG_IPMI_HANDLER is not set # CONFIG_HW_RANDOM is not set # CONFIG_R3964 is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set # CONFIG_XILLYBUS is not set # # I2C support # CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_COMPAT=y CONFIG_I2C_CHARDEV=y # CONFIG_I2C_MUX is not set CONFIG_I2C_HELPER_AUTO=y CONFIG_I2C_ALGOBIT=y # # I2C Hardware Bus support # # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_CBUS_GPIO is not set # CONFIG_I2C_DESIGNWARE_PLATFORM is not set # CONFIG_I2C_EMEV2 is not set # CONFIG_I2C_GPIO is not set CONFIG_I2C_MV64XXX=y # CONFIG_I2C_OCORES is not set # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_PXA_PCI is not set # CONFIG_I2C_RK3X is not set # CONFIG_I2C_SIMTEC is not set # CONFIG_I2C_XILINX is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_DIOLAN_U2C is not set # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_ROBOTFUZZ_OSIF is not set # CONFIG_I2C_TAOS_EVM is not set # CONFIG_I2C_TINY_USB is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_STUB is not set # CONFIG_I2C_SLAVE is not set # CONFIG_I2C_DEBUG_CORE is not set # CONFIG_I2C_DEBUG_ALGO is not set # CONFIG_I2C_DEBUG_BUS is not set CONFIG_SPI=y # CONFIG_SPI_DEBUG is not set CONFIG_SPI_MASTER=y # # SPI Master Controller Drivers # # CONFIG_SPI_ALTERA is not set # CONFIG_SPI_AXI_SPI_ENGINE is not set CONFIG_SPI_BITBANG=y # CONFIG_SPI_CADENCE is not set # CONFIG_SPI_DESIGNWARE is not set CONFIG_SPI_GPIO=y # CONFIG_SPI_FSL_SPI is not set # CONFIG_SPI_OC_TINY is not set # CONFIG_SPI_PXA2XX_PCI is not set # CONFIG_SPI_ROCKCHIP is not set # CONFIG_SPI_SC18IS602 is not set # CONFIG_SPI_SUN4I is not set CONFIG_SPI_SUN6I=y # CONFIG_SPI_XCOMM is not set # CONFIG_SPI_XILINX is not set # CONFIG_SPI_ZYNQMP_GQSPI is not set # # SPI Protocol Masters # # CONFIG_SPI_SPIDEV is not set # CONFIG_SPI_LOOPBACK_TEST is not set # CONFIG_SPI_TLE62X0 is not set # CONFIG_SPI_SLAVE is not set # CONFIG_SPMI is not set # CONFIG_HSI is not set CONFIG_PPS=y # CONFIG_PPS_DEBUG is not set # # PPS clients support # # CONFIG_PPS_CLIENT_KTIMER is not set # CONFIG_PPS_CLIENT_LDISC is not set # CONFIG_PPS_CLIENT_GPIO is not set # # PPS generators support # # # PTP clock support # CONFIG_PTP_1588_CLOCK=y # # Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks. # CONFIG_PINCTRL=y # # Pin controllers # CONFIG_PINMUX=y CONFIG_PINCONF=y CONFIG_GENERIC_PINCONF=y # CONFIG_DEBUG_PINCTRL is not set # CONFIG_PINCTRL_AMD is not set # CONFIG_PINCTRL_MCP23S08 is not set # CONFIG_PINCTRL_SINGLE is not set # CONFIG_PINCTRL_SX150X is not set CONFIG_PINCTRL_SUNXI=y # CONFIG_PINCTRL_SUN4I_A10 is not set # CONFIG_PINCTRL_SUN5I is not set # CONFIG_PINCTRL_SUN6I_A31 is not set # CONFIG_PINCTRL_SUN6I_A31_R is not set CONFIG_PINCTRL_SUN8I_A23=y CONFIG_PINCTRL_SUN8I_A33=y CONFIG_PINCTRL_SUN8I_A83T=y CONFIG_PINCTRL_SUN8I_A83T_R=y CONFIG_PINCTRL_SUN8I_A23_R=y CONFIG_PINCTRL_SUN8I_H3=y CONFIG_PINCTRL_SUN8I_H3_R=y CONFIG_PINCTRL_SUN8I_V3S=y # CONFIG_PINCTRL_SUN9I_A80 is not set # CONFIG_PINCTRL_SUN9I_A80_R is not set # CONFIG_PINCTRL_SUN50I_A64 is not set # CONFIG_PINCTRL_SUN50I_A64_R is not set # CONFIG_PINCTRL_SUN50I_H5 is not set CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y CONFIG_GPIOLIB=y CONFIG_OF_GPIO=y # CONFIG_DEBUG_GPIO is not set CONFIG_GPIO_SYSFS=y # # Memory mapped GPIO drivers # # CONFIG_GPIO_74XX_MMIO is not set # CONFIG_GPIO_ALTERA is not set # CONFIG_GPIO_AXP209 is not set # CONFIG_GPIO_DWAPB is not set # CONFIG_GPIO_FTGPIO010 is not set # CONFIG_GPIO_GENERIC_PLATFORM is not set # CONFIG_GPIO_GRGPIO is not set # CONFIG_GPIO_MOCKUP is not set # CONFIG_GPIO_MPC8XXX is not set # CONFIG_GPIO_SYSCON is not set # CONFIG_GPIO_XILINX is not set # CONFIG_GPIO_ZEVIO is not set # # I2C GPIO expanders # # CONFIG_GPIO_ADP5588 is not set # CONFIG_GPIO_ADNP is not set # CONFIG_GPIO_MAX7300 is not set # CONFIG_GPIO_MAX732X is not set # CONFIG_GPIO_PCA953X is not set # CONFIG_GPIO_PCF857X is not set # CONFIG_GPIO_SX150X is not set # CONFIG_GPIO_TPIC2810 is not set # # MFD GPIO expanders # # CONFIG_HTC_EGPIO is not set # # SPI GPIO expanders # # CONFIG_GPIO_74X164 is not set # CONFIG_GPIO_MAX7301 is not set # CONFIG_GPIO_MC33880 is not set # CONFIG_GPIO_PISOSR is not set # CONFIG_GPIO_XRA1403 is not set # # USB GPIO expanders # # CONFIG_W1 is not set # CONFIG_POWER_AVS is not set # CONFIG_POWER_RESET is not set CONFIG_POWER_SUPPLY=y # CONFIG_POWER_SUPPLY_DEBUG is not set # CONFIG_PDA_POWER is not set # CONFIG_TEST_POWER is not set # CONFIG_BATTERY_DS2780 is not set # CONFIG_BATTERY_DS2781 is not set # CONFIG_BATTERY_DS2782 is not set # CONFIG_BATTERY_SBS is not set # CONFIG_CHARGER_SBS is not set # CONFIG_BATTERY_BQ27XXX is not set # CONFIG_BATTERY_MAX17040 is not set # CONFIG_BATTERY_MAX17042 is not set # CONFIG_CHARGER_ISP1704 is not set # CONFIG_CHARGER_MAX8903 is not set # CONFIG_CHARGER_LP8727 is not set # CONFIG_CHARGER_GPIO is not set # CONFIG_CHARGER_MANAGER is not set # CONFIG_CHARGER_LTC3651 is not set # CONFIG_CHARGER_DETECTOR_MAX14656 is not set # CONFIG_CHARGER_BQ2415X is not set # CONFIG_CHARGER_BQ24190 is not set # CONFIG_CHARGER_BQ24257 is not set # CONFIG_CHARGER_BQ24735 is not set # CONFIG_CHARGER_BQ25890 is not set # CONFIG_CHARGER_SMB347 is not set # CONFIG_BATTERY_GAUGE_LTC2941 is not set # CONFIG_CHARGER_RT9455 is not set CONFIG_HWMON=y # CONFIG_HWMON_VID is not set # CONFIG_HWMON_DEBUG_CHIP is not set # # Native drivers # # CONFIG_SENSORS_AD7314 is not set # CONFIG_SENSORS_AD7414 is not set # CONFIG_SENSORS_AD7418 is not set # CONFIG_SENSORS_ADM1021 is not set # CONFIG_SENSORS_ADM1025 is not set # CONFIG_SENSORS_ADM1026 is not set # CONFIG_SENSORS_ADM1029 is not set # CONFIG_SENSORS_ADM1031 is not set # CONFIG_SENSORS_ADM9240 is not set # CONFIG_SENSORS_ADT7310 is not set # CONFIG_SENSORS_ADT7410 is not set # CONFIG_SENSORS_ADT7411 is not set # CONFIG_SENSORS_ADT7462 is not set # CONFIG_SENSORS_ADT7470 is not set # CONFIG_SENSORS_ADT7475 is not set # CONFIG_SENSORS_ASC7621 is not set # CONFIG_SENSORS_ASPEED is not set # CONFIG_SENSORS_ATXP1 is not set # CONFIG_SENSORS_DS620 is not set # CONFIG_SENSORS_DS1621 is not set # CONFIG_SENSORS_F71805F is not set # CONFIG_SENSORS_F71882FG is not set # CONFIG_SENSORS_F75375S is not set # CONFIG_SENSORS_FTSTEUTATES is not set # CONFIG_SENSORS_GL518SM is not set # CONFIG_SENSORS_GL520SM is not set # CONFIG_SENSORS_G760A is not set # CONFIG_SENSORS_G762 is not set # CONFIG_SENSORS_GPIO_FAN is not set # CONFIG_SENSORS_HIH6130 is not set # CONFIG_SENSORS_IT87 is not set # CONFIG_SENSORS_JC42 is not set # CONFIG_SENSORS_POWR1220 is not set # CONFIG_SENSORS_LINEAGE is not set # CONFIG_SENSORS_LTC2945 is not set # CONFIG_SENSORS_LTC2990 is not set # CONFIG_SENSORS_LTC4151 is not set # CONFIG_SENSORS_LTC4215 is not set # CONFIG_SENSORS_LTC4222 is not set # CONFIG_SENSORS_LTC4245 is not set # CONFIG_SENSORS_LTC4260 is not set # CONFIG_SENSORS_LTC4261 is not set # CONFIG_SENSORS_MAX1111 is not set # CONFIG_SENSORS_MAX16065 is not set # CONFIG_SENSORS_MAX1619 is not set # CONFIG_SENSORS_MAX1668 is not set # CONFIG_SENSORS_MAX197 is not set # CONFIG_SENSORS_MAX31722 is not set # CONFIG_SENSORS_MAX6639 is not set # CONFIG_SENSORS_MAX6642 is not set # CONFIG_SENSORS_MAX6650 is not set # CONFIG_SENSORS_MAX6697 is not set # CONFIG_SENSORS_MAX31790 is not set # CONFIG_SENSORS_MCP3021 is not set # CONFIG_SENSORS_TC654 is not set # CONFIG_SENSORS_ADCXX is not set # CONFIG_SENSORS_LM63 is not set # CONFIG_SENSORS_LM70 is not set # CONFIG_SENSORS_LM73 is not set # CONFIG_SENSORS_LM75 is not set # CONFIG_SENSORS_LM77 is not set # CONFIG_SENSORS_LM78 is not set # CONFIG_SENSORS_LM80 is not set # CONFIG_SENSORS_LM83 is not set # CONFIG_SENSORS_LM85 is not set # CONFIG_SENSORS_LM87 is not set # CONFIG_SENSORS_LM90 is not set # CONFIG_SENSORS_LM92 is not set # CONFIG_SENSORS_LM93 is not set # CONFIG_SENSORS_LM95234 is not set # CONFIG_SENSORS_LM95241 is not set # CONFIG_SENSORS_LM95245 is not set # CONFIG_SENSORS_PC87360 is not set # CONFIG_SENSORS_PC87427 is not set # CONFIG_SENSORS_NTC_THERMISTOR is not set # CONFIG_SENSORS_NCT6683 is not set # CONFIG_SENSORS_NCT6775 is not set # CONFIG_SENSORS_NCT7802 is not set # CONFIG_SENSORS_NCT7904 is not set # CONFIG_SENSORS_PCF8591 is not set # CONFIG_PMBUS is not set # CONFIG_SENSORS_PWM_FAN is not set # CONFIG_SENSORS_SHT15 is not set # CONFIG_SENSORS_SHT21 is not set # CONFIG_SENSORS_SHT3x is not set # CONFIG_SENSORS_SHTC1 is not set # CONFIG_SENSORS_DME1737 is not set # CONFIG_SENSORS_EMC1403 is not set # CONFIG_SENSORS_EMC2103 is not set # CONFIG_SENSORS_EMC6W201 is not set # CONFIG_SENSORS_SMSC47M1 is not set # CONFIG_SENSORS_SMSC47M192 is not set # CONFIG_SENSORS_SMSC47B397 is not set # CONFIG_SENSORS_SCH56XX_COMMON is not set # CONFIG_SENSORS_SCH5627 is not set # CONFIG_SENSORS_SCH5636 is not set # CONFIG_SENSORS_STTS751 is not set # CONFIG_SENSORS_SMM665 is not set # CONFIG_SENSORS_ADC128D818 is not set # CONFIG_SENSORS_ADS1015 is not set # CONFIG_SENSORS_ADS7828 is not set # CONFIG_SENSORS_ADS7871 is not set # CONFIG_SENSORS_AMC6821 is not set # CONFIG_SENSORS_INA209 is not set # CONFIG_SENSORS_INA2XX is not set # CONFIG_SENSORS_INA3221 is not set # CONFIG_SENSORS_TC74 is not set # CONFIG_SENSORS_THMC50 is not set # CONFIG_SENSORS_TMP102 is not set # CONFIG_SENSORS_TMP103 is not set # CONFIG_SENSORS_TMP108 is not set # CONFIG_SENSORS_TMP401 is not set # CONFIG_SENSORS_TMP421 is not set # CONFIG_SENSORS_VT1211 is not set # CONFIG_SENSORS_W83781D is not set # CONFIG_SENSORS_W83791D is not set # CONFIG_SENSORS_W83792D is not set # CONFIG_SENSORS_W83793 is not set # CONFIG_SENSORS_W83795 is not set # CONFIG_SENSORS_W83L785TS is not set # CONFIG_SENSORS_W83L786NG is not set # CONFIG_SENSORS_W83627HF is not set # CONFIG_SENSORS_W83627EHF is not set CONFIG_THERMAL=y CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0 CONFIG_THERMAL_HWMON=y CONFIG_THERMAL_OF=y # CONFIG_THERMAL_WRITABLE_TRIPS is not set CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y # CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set # CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set # CONFIG_THERMAL_DEFAULT_GOV_POWER_ALLOCATOR is not set # CONFIG_THERMAL_GOV_FAIR_SHARE is not set CONFIG_THERMAL_GOV_STEP_WISE=y # CONFIG_THERMAL_GOV_BANG_BANG is not set # CONFIG_THERMAL_GOV_USER_SPACE is not set # CONFIG_THERMAL_GOV_POWER_ALLOCATOR is not set CONFIG_CPU_THERMAL=y # CONFIG_CLOCK_THERMAL is not set # CONFIG_THERMAL_EMULATION is not set # CONFIG_QORIQ_THERMAL is not set # # ACPI INT340X thermal drivers # CONFIG_WATCHDOG=y CONFIG_WATCHDOG_CORE=y # CONFIG_WATCHDOG_NOWAYOUT is not set CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y # CONFIG_WATCHDOG_SYSFS is not set # # Watchdog Device Drivers # # CONFIG_SOFT_WATCHDOG is not set # CONFIG_GPIO_WATCHDOG is not set # CONFIG_XILINX_WATCHDOG is not set # CONFIG_ZIIRAVE_WATCHDOG is not set # CONFIG_CADENCE_WATCHDOG is not set # CONFIG_DW_WATCHDOG is not set CONFIG_SUNXI_WATCHDOG=y # CONFIG_MAX63XX_WATCHDOG is not set # CONFIG_MEN_A21_WDT is not set # # USB-based Watchdog Cards # # CONFIG_USBPCWATCHDOG is not set # # Watchdog Pretimeout Governors # # CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set CONFIG_SSB_POSSIBLE=y # # Sonics Silicon Backplane # CONFIG_SSB=y CONFIG_SSB_BLOCKIO=y CONFIG_SSB_SDIOHOST_POSSIBLE=y CONFIG_SSB_SDIOHOST=y # CONFIG_SSB_DEBUG is not set # CONFIG_SSB_DRIVER_GPIO is not set CONFIG_BCMA_POSSIBLE=y # # Broadcom specific AMBA # CONFIG_BCMA=y CONFIG_BCMA_BLOCKIO=y # CONFIG_BCMA_HOST_SOC is not set # CONFIG_BCMA_DRIVER_GMAC_CMN is not set # CONFIG_BCMA_DRIVER_GPIO is not set # CONFIG_BCMA_DEBUG is not set # # Multifunction device drivers # CONFIG_MFD_CORE=y # CONFIG_MFD_ACT8945A is not set # CONFIG_MFD_SUN4I_GPADC is not set # CONFIG_MFD_AS3711 is not set # CONFIG_MFD_AS3722 is not set # CONFIG_PMIC_ADP5520 is not set # CONFIG_MFD_AAT2870_CORE is not set # CONFIG_MFD_ATMEL_FLEXCOM is not set # CONFIG_MFD_ATMEL_HLCDC is not set # CONFIG_MFD_BCM590XX is not set # CONFIG_MFD_AC100 is not set CONFIG_MFD_AXP20X=y CONFIG_MFD_AXP20X_I2C=y CONFIG_MFD_AXP20X_RSB=y # CONFIG_MFD_CROS_EC is not set # CONFIG_MFD_ASIC3 is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_DA9052_SPI is not set # CONFIG_MFD_DA9052_I2C is not set # CONFIG_MFD_DA9055 is not set # CONFIG_MFD_DA9062 is not set # CONFIG_MFD_DA9063 is not set # CONFIG_MFD_DA9150 is not set # CONFIG_MFD_DLN2 is not set # CONFIG_MFD_MC13XXX_SPI is not set # CONFIG_MFD_MC13XXX_I2C is not set # CONFIG_MFD_HI6421_PMIC is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_HTC_I2CPLD is not set # CONFIG_MFD_KEMPLD is not set # CONFIG_MFD_88PM800 is not set # CONFIG_MFD_88PM805 is not set # CONFIG_MFD_88PM860X is not set # CONFIG_MFD_MAX14577 is not set # CONFIG_MFD_MAX77620 is not set # CONFIG_MFD_MAX77686 is not set # CONFIG_MFD_MAX77693 is not set # CONFIG_MFD_MAX77843 is not set # CONFIG_MFD_MAX8907 is not set # CONFIG_MFD_MAX8925 is not set # CONFIG_MFD_MAX8997 is not set # CONFIG_MFD_MAX8998 is not set # CONFIG_MFD_MT6397 is not set # CONFIG_MFD_MENF21BMC is not set # CONFIG_EZX_PCAP is not set # CONFIG_MFD_CPCAP is not set # CONFIG_MFD_VIPERBOARD is not set # CONFIG_MFD_RETU is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_MFD_PM8XXX is not set # CONFIG_MFD_RT5033 is not set # CONFIG_MFD_RTSX_USB is not set # CONFIG_MFD_RC5T583 is not set # CONFIG_MFD_RK808 is not set # CONFIG_MFD_RN5T618 is not set # CONFIG_MFD_SEC_CORE is not set # CONFIG_MFD_SI476X_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_MFD_SKY81452 is not set # CONFIG_MFD_SMSC is not set # CONFIG_ABX500_CORE is not set # CONFIG_MFD_STMPE is not set CONFIG_MFD_SUN6I_PRCM=y CONFIG_MFD_SYSCON=y # CONFIG_MFD_TI_AM335X_TSCADC is not set # CONFIG_MFD_LP3943 is not set # CONFIG_MFD_LP8788 is not set # CONFIG_MFD_TI_LMU is not set # CONFIG_MFD_PALMAS is not set # CONFIG_TPS6105X is not set # CONFIG_TPS65010 is not set # CONFIG_TPS6507X is not set # CONFIG_MFD_TPS65086 is not set # CONFIG_MFD_TPS65090 is not set # CONFIG_MFD_TPS65217 is not set # CONFIG_MFD_TI_LP873X is not set # CONFIG_MFD_TI_LP87565 is not set # CONFIG_MFD_TPS65218 is not set # CONFIG_MFD_TPS6586X is not set # CONFIG_MFD_TPS65910 is not set # CONFIG_MFD_TPS65912_I2C is not set # CONFIG_MFD_TPS65912_SPI is not set # CONFIG_MFD_TPS80031 is not set # CONFIG_TWL4030_CORE is not set # CONFIG_TWL6040_CORE is not set # CONFIG_MFD_WL1273_CORE is not set # CONFIG_MFD_LM3533 is not set # CONFIG_MFD_TC3589X is not set # CONFIG_MFD_TMIO is not set # CONFIG_MFD_T7L66XB is not set # CONFIG_MFD_TC6387XB is not set # CONFIG_MFD_TC6393XB is not set # CONFIG_MFD_ARIZONA_I2C is not set # CONFIG_MFD_ARIZONA_SPI is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM831X_I2C is not set # CONFIG_MFD_WM831X_SPI is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_WM8994 is not set CONFIG_REGULATOR=y # CONFIG_REGULATOR_DEBUG is not set CONFIG_REGULATOR_FIXED_VOLTAGE=y # CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set # CONFIG_REGULATOR_USERSPACE_CONSUMER is not set # CONFIG_REGULATOR_ACT8865 is not set # CONFIG_REGULATOR_AD5398 is not set # CONFIG_REGULATOR_ANATOP is not set CONFIG_REGULATOR_AXP20X=y # CONFIG_REGULATOR_DA9210 is not set # CONFIG_REGULATOR_DA9211 is not set # CONFIG_REGULATOR_FAN53555 is not set CONFIG_REGULATOR_GPIO=y # CONFIG_REGULATOR_ISL9305 is not set # CONFIG_REGULATOR_ISL6271A is not set # CONFIG_REGULATOR_LP3971 is not set # CONFIG_REGULATOR_LP3972 is not set # CONFIG_REGULATOR_LP872X is not set # CONFIG_REGULATOR_LP8755 is not set # CONFIG_REGULATOR_LTC3589 is not set # CONFIG_REGULATOR_LTC3676 is not set # CONFIG_REGULATOR_MAX1586 is not set # CONFIG_REGULATOR_MAX8649 is not set # CONFIG_REGULATOR_MAX8660 is not set # CONFIG_REGULATOR_MAX8952 is not set # CONFIG_REGULATOR_MAX8973 is not set # CONFIG_REGULATOR_MT6311 is not set # CONFIG_REGULATOR_PFUZE100 is not set # CONFIG_REGULATOR_PV88060 is not set # CONFIG_REGULATOR_PV88080 is not set # CONFIG_REGULATOR_PV88090 is not set # CONFIG_REGULATOR_PWM is not set # CONFIG_REGULATOR_TPS51632 is not set # CONFIG_REGULATOR_TPS62360 is not set # CONFIG_REGULATOR_TPS65023 is not set # CONFIG_REGULATOR_TPS6507X is not set # CONFIG_REGULATOR_TPS65132 is not set # CONFIG_REGULATOR_TPS6524X is not set # CONFIG_REGULATOR_VCTRL is not set CONFIG_MEDIA_SUPPORT=y # # Multimedia core support # CONFIG_MEDIA_CAMERA_SUPPORT=y # CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set # CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set # CONFIG_MEDIA_RADIO_SUPPORT is not set # CONFIG_MEDIA_SDR_SUPPORT is not set # CONFIG_MEDIA_RC_SUPPORT is not set # CONFIG_MEDIA_CEC_SUPPORT is not set # CONFIG_MEDIA_CONTROLLER is not set CONFIG_VIDEO_DEV=y CONFIG_VIDEO_V4L2=y # CONFIG_VIDEO_ADV_DEBUG is not set # CONFIG_VIDEO_FIXED_MINOR_RANGES is not set CONFIG_VIDEOBUF2_CORE=y CONFIG_VIDEOBUF2_MEMOPS=y CONFIG_VIDEOBUF2_VMALLOC=y # CONFIG_TTPCI_EEPROM is not set # # Media drivers # CONFIG_MEDIA_USB_SUPPORT=y # # Webcam devices # CONFIG_USB_VIDEO_CLASS=y CONFIG_USB_VIDEO_CLASS_INPUT_EVDEV=y # CONFIG_USB_GSPCA is not set # CONFIG_USB_PWC is not set # CONFIG_VIDEO_CPIA2 is not set # CONFIG_USB_ZR364XX is not set # CONFIG_USB_STKWEBCAM is not set # CONFIG_USB_S2255 is not set # CONFIG_VIDEO_USBTV is not set # # Webcam, TV (analog/digital) USB devices # # CONFIG_VIDEO_EM28XX is not set # CONFIG_V4L_PLATFORM_DRIVERS is not set # CONFIG_V4L_MEM2MEM_DRIVERS is not set # CONFIG_V4L_TEST_DRIVERS is not set # # Supported MMC/SDIO adapters # # CONFIG_CYPRESS_FIRMWARE is not set # # Media ancillary drivers (tuners, sensors, i2c, spi, frontends) # # CONFIG_MEDIA_SUBDRV_AUTOSELECT is not set # # I2C Encoders, decoders, sensors and other helper chips # # # Audio decoders, processors and mixers # # CONFIG_VIDEO_TVAUDIO is not set # CONFIG_VIDEO_TDA7432 is not set # CONFIG_VIDEO_TDA9840 is not set # CONFIG_VIDEO_TEA6415C is not set # CONFIG_VIDEO_TEA6420 is not set # CONFIG_VIDEO_MSP3400 is not set # CONFIG_VIDEO_CS3308 is not set # CONFIG_VIDEO_CS5345 is not set # CONFIG_VIDEO_CS53L32A is not set # CONFIG_VIDEO_TLV320AIC23B is not set # CONFIG_VIDEO_UDA1342 is not set # CONFIG_VIDEO_WM8775 is not set # CONFIG_VIDEO_WM8739 is not set # CONFIG_VIDEO_VP27SMPX is not set # CONFIG_VIDEO_SONY_BTF_MPX is not set # # RDS decoders # # CONFIG_VIDEO_SAA6588 is not set # # Video decoders # # CONFIG_VIDEO_ADV7183 is not set # CONFIG_VIDEO_BT819 is not set # CONFIG_VIDEO_BT856 is not set # CONFIG_VIDEO_BT866 is not set # CONFIG_VIDEO_KS0127 is not set # CONFIG_VIDEO_ML86V7667 is not set # CONFIG_VIDEO_SAA7110 is not set # CONFIG_VIDEO_SAA711X is not set # CONFIG_VIDEO_TVP514X is not set # CONFIG_VIDEO_TVP5150 is not set # CONFIG_VIDEO_TVP7002 is not set # CONFIG_VIDEO_TW2804 is not set # CONFIG_VIDEO_TW9903 is not set # CONFIG_VIDEO_TW9906 is not set # CONFIG_VIDEO_VPX3220 is not set # # Video and audio decoders # # CONFIG_VIDEO_SAA717X is not set # CONFIG_VIDEO_CX25840 is not set # # Video encoders # # CONFIG_VIDEO_SAA7127 is not set # CONFIG_VIDEO_SAA7185 is not set # CONFIG_VIDEO_ADV7170 is not set # CONFIG_VIDEO_ADV7175 is not set # CONFIG_VIDEO_ADV7343 is not set # CONFIG_VIDEO_ADV7393 is not set # CONFIG_VIDEO_AK881X is not set # CONFIG_VIDEO_THS8200 is not set # # Camera sensor devices # # CONFIG_VIDEO_OV2640 is not set # CONFIG_VIDEO_OV2659 is not set # CONFIG_VIDEO_OV7640 is not set # CONFIG_VIDEO_OV7670 is not set # CONFIG_VIDEO_VS6624 is not set # CONFIG_VIDEO_MT9M111 is not set # CONFIG_VIDEO_MT9V011 is not set # CONFIG_VIDEO_SR030PC30 is not set # # Flash devices # # # Video improvement chips # # CONFIG_VIDEO_UPD64031A is not set # CONFIG_VIDEO_UPD64083 is not set # # Audio/Video compression chips # # CONFIG_VIDEO_SAA6752HS is not set # # SDR tuner chips # # # Miscellaneous helper chips # # CONFIG_VIDEO_THS7303 is not set # CONFIG_VIDEO_M52790 is not set # # Sensors used on soc_camera driver # # # SPI helper chips # # # Customise DVB Frontends # # # Tools to develop new frontends # # # Graphics support # # CONFIG_IMX_IPUV3_CORE is not set CONFIG_DRM=y # CONFIG_DRM_DP_AUX_CHARDEV is not set # CONFIG_DRM_DEBUG_MM is not set # CONFIG_DRM_DEBUG_MM_SELFTEST is not set CONFIG_DRM_KMS_HELPER=y CONFIG_DRM_KMS_FB_HELPER=y CONFIG_DRM_FBDEV_EMULATION=y CONFIG_DRM_FBDEV_OVERALLOC=100 # CONFIG_DRM_LOAD_EDID_FIRMWARE is not set CONFIG_DRM_GEM_CMA_HELPER=y CONFIG_DRM_KMS_CMA_HELPER=y # # I2C encoder or helper chips # # CONFIG_DRM_I2C_CH7006 is not set # CONFIG_DRM_I2C_SIL164 is not set # CONFIG_DRM_I2C_NXP_TDA998X is not set # CONFIG_DRM_HDLCD is not set # CONFIG_DRM_MALI_DISPLAY is not set # # ACP (Audio CoProcessor) Configuration # # CONFIG_DRM_VGEM is not set # CONFIG_DRM_EXYNOS is not set # CONFIG_DRM_UDL is not set # CONFIG_DRM_ARMADA is not set # CONFIG_DRM_RCAR_DW_HDMI is not set CONFIG_DRM_SUN4I=y CONFIG_DRM_SUN4I_HDMI=y CONFIG_DRM_SUN4I_BACKEND=y CONFIG_DRM_SUN8I_MIXER=y # CONFIG_DRM_OMAP is not set # CONFIG_DRM_TILCDC is not set # CONFIG_DRM_FSL_DCU is not set # CONFIG_DRM_STM is not set CONFIG_DRM_PANEL=y # # Display Panels # # CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set # CONFIG_DRM_PANEL_LG_LG4573 is not set # CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set CONFIG_DRM_BRIDGE=y CONFIG_DRM_PANEL_BRIDGE=y # # Display Interface Bridges # # CONFIG_DRM_ANALOGIX_ANX78XX is not set CONFIG_DRM_DUMB_VGA_DAC=y # CONFIG_DRM_LVDS_ENCODER is not set # CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set # CONFIG_DRM_NXP_PTN3460 is not set # CONFIG_DRM_PARADE_PS8622 is not set # CONFIG_DRM_SIL_SII8620 is not set # CONFIG_DRM_SII902X is not set # CONFIG_DRM_TOSHIBA_TC358767 is not set # CONFIG_DRM_TI_TFP410 is not set # CONFIG_DRM_I2C_ADV7511 is not set # CONFIG_DRM_STI is not set # CONFIG_DRM_ARCPGU is not set # CONFIG_DRM_MXSFB is not set # CONFIG_DRM_TINYDRM is not set # CONFIG_DRM_PL111 is not set # CONFIG_DRM_LEGACY is not set # CONFIG_DRM_LIB_RANDOM is not set # # Frame buffer Devices # CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set CONFIG_FB_CMDLINE=y CONFIG_FB_NOTIFY=y # CONFIG_FB_DDC is not set # CONFIG_FB_BOOT_VESA_SUPPORT is not set CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set CONFIG_FB_SYS_FILLRECT=y CONFIG_FB_SYS_COPYAREA=y CONFIG_FB_SYS_IMAGEBLIT=y # CONFIG_FB_PROVIDE_GET_FB_UNMAPPED_AREA is not set # CONFIG_FB_FOREIGN_ENDIAN is not set CONFIG_FB_SYS_FOPS=y CONFIG_FB_DEFERRED_IO=y # CONFIG_FB_SVGALIB is not set # CONFIG_FB_MACMODES is not set # CONFIG_FB_BACKLIGHT is not set # CONFIG_FB_MODE_HELPERS is not set # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_OPENCORES is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_SMSCUFX is not set # CONFIG_FB_UDL is not set # CONFIG_FB_IBM_GXT4500 is not set # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_BROADSHEET is not set # CONFIG_FB_AUO_K190X is not set CONFIG_FB_SIMPLE=y # CONFIG_FB_SSD1307 is not set # CONFIG_BACKLIGHT_LCD_SUPPORT is not set # CONFIG_VGASTATE is not set CONFIG_VIDEOMODE_HELPERS=y CONFIG_HDMI=y # # Console display driver support # CONFIG_DUMMY_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set # CONFIG_LOGO is not set CONFIG_SOUND=y # CONFIG_SOUND_OSS_CORE is not set CONFIG_SND=y CONFIG_SND_TIMER=y CONFIG_SND_PCM=y CONFIG_SND_DMAENGINE_PCM=y CONFIG_SND_RAWMIDI=m CONFIG_SND_JACK=y CONFIG_SND_JACK_INPUT_DEV=y # CONFIG_SND_OSSEMUL is not set CONFIG_SND_PCM_TIMER=y # CONFIG_SND_HRTIMER is not set # CONFIG_SND_DYNAMIC_MINORS is not set CONFIG_SND_SUPPORT_OLD_API=y CONFIG_SND_PROC_FS=y CONFIG_SND_VERBOSE_PROCFS=y # CONFIG_SND_VERBOSE_PRINTK is not set # CONFIG_SND_DEBUG is not set # CONFIG_SND_SEQUENCER is not set # CONFIG_SND_OPL3_LIB_SEQ is not set # CONFIG_SND_OPL4_LIB_SEQ is not set CONFIG_SND_DRIVERS=y # CONFIG_SND_DUMMY is not set # CONFIG_SND_ALOOP is not set # CONFIG_SND_MTPAV is not set # CONFIG_SND_SERIAL_U16550 is not set # CONFIG_SND_MPU401 is not set # # HD-Audio # CONFIG_SND_HDA_PREALLOC_SIZE=64 CONFIG_SND_ARM=y CONFIG_SND_SPI=y CONFIG_SND_USB=y # CONFIG_SND_USB_AUDIO is not set # CONFIG_SND_USB_UA101 is not set # CONFIG_SND_USB_CAIAQ is not set # CONFIG_SND_USB_6FIRE is not set # CONFIG_SND_USB_HIFACE is not set # CONFIG_SND_BCD2000 is not set # CONFIG_SND_USB_POD is not set # CONFIG_SND_USB_PODHD is not set # CONFIG_SND_USB_TONEPORT is not set # CONFIG_SND_USB_VARIAX is not set CONFIG_SND_SOC=y CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y # CONFIG_SND_SOC_AMD_ACP is not set # CONFIG_SND_ATMEL_SOC is not set # CONFIG_SND_DESIGNWARE_I2S is not set # # SoC Audio for Freescale CPUs # # # Common SoC Audio options for Freescale CPUs: # # CONFIG_SND_SOC_FSL_ASRC is not set # CONFIG_SND_SOC_FSL_SAI is not set # CONFIG_SND_SOC_FSL_SSI is not set # CONFIG_SND_SOC_FSL_SPDIF is not set # CONFIG_SND_SOC_FSL_ESAI is not set # CONFIG_SND_SOC_IMX_AUDMUX is not set # CONFIG_SND_I2S_HI6210_I2S is not set # CONFIG_SND_SOC_IMG is not set # # STMicroelectronics STM32 SOC audio support # # # Allwinner SoC Audio support # CONFIG_SND_SUN4I_CODEC=y # CONFIG_SND_SUN8I_CODEC is not set CONFIG_SND_SUN8I_CODEC_ANALOG=y # CONFIG_SND_SUN4I_I2S is not set # CONFIG_SND_SUN4I_SPDIF is not set # CONFIG_SND_SOC_XTFPGA_I2S is not set # CONFIG_ZX_TDM is not set CONFIG_SND_SOC_I2C_AND_SPI=y # # CODEC drivers # # CONFIG_SND_SOC_AC97_CODEC is not set # CONFIG_SND_SOC_ADAU1701 is not set # CONFIG_SND_SOC_ADAU1761_I2C is not set # CONFIG_SND_SOC_ADAU1761_SPI is not set # CONFIG_SND_SOC_ADAU7002 is not set # CONFIG_SND_SOC_AK4104 is not set # CONFIG_SND_SOC_AK4554 is not set # CONFIG_SND_SOC_AK4613 is not set # CONFIG_SND_SOC_AK4642 is not set # CONFIG_SND_SOC_AK5386 is not set # CONFIG_SND_SOC_ALC5623 is not set # CONFIG_SND_SOC_BT_SCO is not set # CONFIG_SND_SOC_CS35L32 is not set # CONFIG_SND_SOC_CS35L33 is not set # CONFIG_SND_SOC_CS35L34 is not set # CONFIG_SND_SOC_CS35L35 is not set # CONFIG_SND_SOC_CS42L42 is not set # CONFIG_SND_SOC_CS42L51_I2C is not set # CONFIG_SND_SOC_CS42L52 is not set # CONFIG_SND_SOC_CS42L56 is not set # CONFIG_SND_SOC_CS42L73 is not set # CONFIG_SND_SOC_CS4265 is not set # CONFIG_SND_SOC_CS4270 is not set # CONFIG_SND_SOC_CS4271_I2C is not set # CONFIG_SND_SOC_CS4271_SPI is not set # CONFIG_SND_SOC_CS42XX8_I2C is not set # CONFIG_SND_SOC_CS4349 is not set # CONFIG_SND_SOC_CS53L30 is not set # CONFIG_SND_SOC_DIO2125 is not set # CONFIG_SND_SOC_ES7134 is not set # CONFIG_SND_SOC_ES8316 is not set # CONFIG_SND_SOC_ES8328_I2C is not set # CONFIG_SND_SOC_ES8328_SPI is not set # CONFIG_SND_SOC_GTM601 is not set # CONFIG_SND_SOC_INNO_RK3036 is not set # CONFIG_SND_SOC_MAX98504 is not set # CONFIG_SND_SOC_MAX98927 is not set # CONFIG_SND_SOC_MAX9860 is not set # CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set # CONFIG_SND_SOC_PCM1681 is not set # CONFIG_SND_SOC_PCM179X_I2C is not set # CONFIG_SND_SOC_PCM179X_SPI is not set # CONFIG_SND_SOC_PCM3168A_I2C is not set # CONFIG_SND_SOC_PCM3168A_SPI is not set # CONFIG_SND_SOC_PCM512x_I2C is not set # CONFIG_SND_SOC_PCM512x_SPI is not set # CONFIG_SND_SOC_RT5616 is not set # CONFIG_SND_SOC_RT5631 is not set # CONFIG_SND_SOC_RT5677_SPI is not set # CONFIG_SND_SOC_SGTL5000 is not set # CONFIG_SND_SOC_SIRF_AUDIO_CODEC is not set # CONFIG_SND_SOC_SPDIF is not set # CONFIG_SND_SOC_SSM2602_SPI is not set # CONFIG_SND_SOC_SSM2602_I2C is not set # CONFIG_SND_SOC_SSM4567 is not set # CONFIG_SND_SOC_STA32X is not set # CONFIG_SND_SOC_STA350 is not set # CONFIG_SND_SOC_STI_SAS is not set # CONFIG_SND_SOC_TAS2552 is not set # CONFIG_SND_SOC_TAS5086 is not set # CONFIG_SND_SOC_TAS571X is not set # CONFIG_SND_SOC_TAS5720 is not set # CONFIG_SND_SOC_TFA9879 is not set # CONFIG_SND_SOC_TLV320AIC23_I2C is not set # CONFIG_SND_SOC_TLV320AIC23_SPI is not set # CONFIG_SND_SOC_TLV320AIC31XX is not set # CONFIG_SND_SOC_TLV320AIC3X is not set # CONFIG_SND_SOC_TS3A227E is not set # CONFIG_SND_SOC_WM8510 is not set # CONFIG_SND_SOC_WM8523 is not set # CONFIG_SND_SOC_WM8580 is not set # CONFIG_SND_SOC_WM8711 is not set # CONFIG_SND_SOC_WM8728 is not set # CONFIG_SND_SOC_WM8731 is not set # CONFIG_SND_SOC_WM8737 is not set # CONFIG_SND_SOC_WM8741 is not set # CONFIG_SND_SOC_WM8750 is not set # CONFIG_SND_SOC_WM8753 is not set # CONFIG_SND_SOC_WM8770 is not set # CONFIG_SND_SOC_WM8776 is not set # CONFIG_SND_SOC_WM8804_I2C is not set # CONFIG_SND_SOC_WM8804_SPI is not set # CONFIG_SND_SOC_WM8903 is not set # CONFIG_SND_SOC_WM8960 is not set # CONFIG_SND_SOC_WM8962 is not set # CONFIG_SND_SOC_WM8974 is not set # CONFIG_SND_SOC_WM8978 is not set # CONFIG_SND_SOC_WM8985 is not set # CONFIG_SND_SOC_ZX_AUD96P22 is not set # CONFIG_SND_SOC_NAU8540 is not set # CONFIG_SND_SOC_NAU8810 is not set # CONFIG_SND_SOC_NAU8824 is not set # CONFIG_SND_SOC_TPA6130A2 is not set # CONFIG_SND_SIMPLE_CARD is not set # CONFIG_SND_SIMPLE_SCU_CARD is not set # CONFIG_SND_AUDIO_GRAPH_CARD is not set # CONFIG_SND_AUDIO_GRAPH_SCU_CARD is not set # # HID support # CONFIG_HID=y # CONFIG_HID_BATTERY_STRENGTH is not set # CONFIG_HIDRAW is not set # CONFIG_UHID is not set CONFIG_HID_GENERIC=y # # Special HID drivers # CONFIG_HID_A4TECH=y # CONFIG_HID_ACCUTOUCH is not set # CONFIG_HID_ACRUX is not set CONFIG_HID_APPLE=y # CONFIG_HID_APPLEIR is not set # CONFIG_HID_ASUS is not set # CONFIG_HID_AUREAL is not set CONFIG_HID_BELKIN=y # CONFIG_HID_BETOP_FF is not set CONFIG_HID_CHERRY=y CONFIG_HID_CHICONY=y # CONFIG_HID_CORSAIR is not set # CONFIG_HID_PRODIKEYS is not set # CONFIG_HID_CMEDIA is not set CONFIG_HID_CYPRESS=y # CONFIG_HID_DRAGONRISE is not set # CONFIG_HID_EMS_FF is not set # CONFIG_HID_ELECOM is not set # CONFIG_HID_ELO is not set CONFIG_HID_EZKEY=y # CONFIG_HID_GEMBIRD is not set # CONFIG_HID_GFRM is not set # CONFIG_HID_HOLTEK is not set # CONFIG_HID_GT683R is not set # CONFIG_HID_KEYTOUCH is not set # CONFIG_HID_KYE is not set # CONFIG_HID_UCLOGIC is not set # CONFIG_HID_WALTOP is not set # CONFIG_HID_GYRATION is not set # CONFIG_HID_ICADE is not set CONFIG_HID_ITE=y # CONFIG_HID_TWINHAN is not set CONFIG_HID_KENSINGTON=y # CONFIG_HID_LCPOWER is not set # CONFIG_HID_LED is not set # CONFIG_HID_LENOVO is not set CONFIG_HID_LOGITECH=y # CONFIG_HID_LOGITECH_HIDPP is not set # CONFIG_LOGITECH_FF is not set # CONFIG_LOGIRUMBLEPAD2_FF is not set # CONFIG_LOGIG940_FF is not set # CONFIG_LOGIWHEELS_FF is not set # CONFIG_HID_MAGICMOUSE is not set # CONFIG_HID_MAYFLASH is not set CONFIG_HID_MICROSOFT=y CONFIG_HID_MONTEREY=y # CONFIG_HID_MULTITOUCH is not set # CONFIG_HID_NTI is not set # CONFIG_HID_NTRIG is not set # CONFIG_HID_ORTEK is not set # CONFIG_HID_PANTHERLORD is not set # CONFIG_HID_PENMOUNT is not set # CONFIG_HID_PETALYNX is not set # CONFIG_HID_PICOLCD is not set # CONFIG_HID_PLANTRONICS is not set # CONFIG_HID_PRIMAX is not set # CONFIG_HID_RETRODE is not set # CONFIG_HID_ROCCAT is not set # CONFIG_HID_SAITEK is not set # CONFIG_HID_SAMSUNG is not set # CONFIG_HID_SONY is not set # CONFIG_HID_SPEEDLINK is not set # CONFIG_HID_STEELSERIES is not set # CONFIG_HID_SUNPLUS is not set # CONFIG_HID_RMI is not set # CONFIG_HID_GREENASIA is not set # CONFIG_HID_SMARTJOYPLUS is not set # CONFIG_HID_TIVO is not set # CONFIG_HID_TOPSEED is not set # CONFIG_HID_THINGM is not set # CONFIG_HID_THRUSTMASTER is not set # CONFIG_HID_UDRAW_PS3 is not set # CONFIG_HID_WACOM is not set # CONFIG_HID_WIIMOTE is not set # CONFIG_HID_XINMO is not set # CONFIG_HID_ZEROPLUS is not set # CONFIG_HID_ZYDACRON is not set # CONFIG_HID_SENSOR_HUB is not set # CONFIG_HID_ALPS is not set # # USB HID support # CONFIG_USB_HID=y # CONFIG_HID_PID is not set # CONFIG_USB_HIDDEV is not set # # I2C HID support # # CONFIG_I2C_HID is not set CONFIG_USB_OHCI_LITTLE_ENDIAN=y CONFIG_USB_SUPPORT=y CONFIG_USB_COMMON=y CONFIG_USB_ARCH_HAS_HCD=y CONFIG_USB=y # CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set # # Miscellaneous USB options # CONFIG_USB_DEFAULT_PERSIST=y # CONFIG_USB_DYNAMIC_MINORS is not set # CONFIG_USB_OTG is not set # CONFIG_USB_OTG_WHITELIST is not set # CONFIG_USB_LEDS_TRIGGER_USBPORT is not set # CONFIG_USB_MON is not set # CONFIG_USB_WUSB_CBAF is not set # # USB Host Controller Drivers # # CONFIG_USB_C67X00_HCD is not set # CONFIG_USB_XHCI_HCD is not set CONFIG_USB_EHCI_HCD=y # CONFIG_USB_EHCI_ROOT_HUB_TT is not set CONFIG_USB_EHCI_TT_NEWSCHED=y CONFIG_USB_EHCI_HCD_PLATFORM=y # CONFIG_USB_OXU210HP_HCD is not set # CONFIG_USB_ISP116X_HCD is not set # CONFIG_USB_ISP1362_HCD is not set # CONFIG_USB_FOTG210_HCD is not set # CONFIG_USB_MAX3421_HCD is not set CONFIG_USB_OHCI_HCD=y # CONFIG_USB_OHCI_HCD_SSB is not set CONFIG_USB_OHCI_HCD_PLATFORM=y # CONFIG_USB_SL811_HCD is not set # CONFIG_USB_R8A66597_HCD is not set # CONFIG_USB_HCD_BCMA is not set # CONFIG_USB_HCD_SSB is not set # CONFIG_USB_HCD_TEST_MODE is not set # # USB Device Class drivers # CONFIG_USB_ACM=y # CONFIG_USB_PRINTER is not set # CONFIG_USB_WDM is not set # CONFIG_USB_TMC is not set # # NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may # # # also be needed; see USB_STORAGE Help for more info # CONFIG_USB_STORAGE=y # CONFIG_USB_STORAGE_DEBUG is not set # CONFIG_USB_STORAGE_REALTEK is not set # CONFIG_USB_STORAGE_DATAFAB is not set # CONFIG_USB_STORAGE_FREECOM is not set # CONFIG_USB_STORAGE_ISD200 is not set # CONFIG_USB_STORAGE_USBAT is not set # CONFIG_USB_STORAGE_SDDR09 is not set # CONFIG_USB_STORAGE_SDDR55 is not set # CONFIG_USB_STORAGE_JUMPSHOT is not set # CONFIG_USB_STORAGE_ALAUDA is not set # CONFIG_USB_STORAGE_ONETOUCH is not set # CONFIG_USB_STORAGE_KARMA is not set # CONFIG_USB_STORAGE_CYPRESS_ATACB is not set # CONFIG_USB_STORAGE_ENE_UB6250 is not set # CONFIG_USB_UAS is not set # # USB Imaging devices # # CONFIG_USB_MDC800 is not set # CONFIG_USB_MICROTEK is not set # CONFIG_USBIP_CORE is not set CONFIG_USB_MUSB_HDRC=y # CONFIG_USB_MUSB_HOST is not set # CONFIG_USB_MUSB_GADGET is not set CONFIG_USB_MUSB_DUAL_ROLE=y # # Platform Glue Layer # CONFIG_USB_MUSB_SUNXI=y # # MUSB DMA mode # # CONFIG_MUSB_PIO_ONLY is not set # CONFIG_USB_DWC3 is not set # CONFIG_USB_DWC2 is not set # CONFIG_USB_CHIPIDEA is not set # CONFIG_USB_ISP1760 is not set # # USB port drivers # CONFIG_USB_SERIAL=y CONFIG_USB_SERIAL_CONSOLE=y CONFIG_USB_SERIAL_GENERIC=y CONFIG_USB_SERIAL_SIMPLE=y # CONFIG_USB_SERIAL_AIRCABLE is not set # CONFIG_USB_SERIAL_ARK3116 is not set # CONFIG_USB_SERIAL_BELKIN is not set CONFIG_USB_SERIAL_CH341=y # CONFIG_USB_SERIAL_WHITEHEAT is not set # CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set CONFIG_USB_SERIAL_CP210X=y # CONFIG_USB_SERIAL_CYPRESS_M8 is not set # CONFIG_USB_SERIAL_EMPEG is not set CONFIG_USB_SERIAL_FTDI_SIO=y # CONFIG_USB_SERIAL_VISOR is not set # CONFIG_USB_SERIAL_IPAQ is not set # CONFIG_USB_SERIAL_IR is not set # CONFIG_USB_SERIAL_EDGEPORT is not set # CONFIG_USB_SERIAL_EDGEPORT_TI is not set # CONFIG_USB_SERIAL_F81232 is not set # CONFIG_USB_SERIAL_F8153X is not set # CONFIG_USB_SERIAL_GARMIN is not set # CONFIG_USB_SERIAL_IPW is not set # CONFIG_USB_SERIAL_IUU is not set # CONFIG_USB_SERIAL_KEYSPAN_PDA is not set # CONFIG_USB_SERIAL_KEYSPAN is not set # CONFIG_USB_SERIAL_KLSI is not set # CONFIG_USB_SERIAL_KOBIL_SCT is not set # CONFIG_USB_SERIAL_MCT_U232 is not set # CONFIG_USB_SERIAL_METRO is not set # CONFIG_USB_SERIAL_MOS7720 is not set # CONFIG_USB_SERIAL_MOS7840 is not set # CONFIG_USB_SERIAL_MXUPORT is not set # CONFIG_USB_SERIAL_NAVMAN is not set CONFIG_USB_SERIAL_PL2303=y # CONFIG_USB_SERIAL_OTI6858 is not set # CONFIG_USB_SERIAL_QCAUX is not set # CONFIG_USB_SERIAL_QUALCOMM is not set # CONFIG_USB_SERIAL_SPCP8X5 is not set # CONFIG_USB_SERIAL_SAFE is not set # CONFIG_USB_SERIAL_SIERRAWIRELESS is not set # CONFIG_USB_SERIAL_SYMBOL is not set # CONFIG_USB_SERIAL_TI is not set # CONFIG_USB_SERIAL_CYBERJACK is not set # CONFIG_USB_SERIAL_XIRCOM is not set # CONFIG_USB_SERIAL_OPTION is not set # CONFIG_USB_SERIAL_OMNINET is not set # CONFIG_USB_SERIAL_OPTICON is not set # CONFIG_USB_SERIAL_XSENS_MT is not set # CONFIG_USB_SERIAL_WISHBONE is not set # CONFIG_USB_SERIAL_SSU100 is not set # CONFIG_USB_SERIAL_QT2 is not set # CONFIG_USB_SERIAL_UPD78F0730 is not set # CONFIG_USB_SERIAL_DEBUG is not set # # USB Miscellaneous drivers # # CONFIG_USB_EMI62 is not set # CONFIG_USB_EMI26 is not set # CONFIG_USB_ADUTUX is not set # CONFIG_USB_SEVSEG is not set # CONFIG_USB_RIO500 is not set # CONFIG_USB_LEGOTOWER is not set # CONFIG_USB_LCD is not set # CONFIG_USB_CYPRESS_CY7C63 is not set # CONFIG_USB_CYTHERM is not set # CONFIG_USB_IDMOUSE is not set # CONFIG_USB_FTDI_ELAN is not set # CONFIG_USB_APPLEDISPLAY is not set # CONFIG_USB_SISUSBVGA is not set # CONFIG_USB_LD is not set # CONFIG_USB_TRANCEVIBRATOR is not set # CONFIG_USB_IOWARRIOR is not set # CONFIG_USB_TEST is not set # CONFIG_USB_EHSET_TEST_FIXTURE is not set # CONFIG_USB_ISIGHTFW is not set # CONFIG_USB_YUREX is not set # CONFIG_USB_EZUSB_FX2 is not set # CONFIG_USB_HUB_USB251XB is not set # CONFIG_USB_HSIC_USB3503 is not set # CONFIG_USB_HSIC_USB4604 is not set # CONFIG_USB_LINK_LAYER_TEST is not set # # USB Physical Layer drivers # CONFIG_USB_PHY=y CONFIG_NOP_USB_XCEIV=y # CONFIG_AM335X_PHY_USB is not set # CONFIG_USB_GPIO_VBUS is not set # CONFIG_USB_ISP1301 is not set # CONFIG_USB_ULPI is not set CONFIG_USB_GADGET=y # CONFIG_USB_GADGET_DEBUG is not set # CONFIG_USB_GADGET_DEBUG_FILES is not set # CONFIG_USB_GADGET_DEBUG_FS is not set CONFIG_USB_GADGET_VBUS_DRAW=2 CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2 # CONFIG_U_SERIAL_CONSOLE is not set # # USB Peripheral Controller # # CONFIG_USB_FUSB300 is not set # CONFIG_USB_FOTG210_UDC is not set # CONFIG_USB_GR_UDC is not set # CONFIG_USB_R8A66597 is not set # CONFIG_USB_PXA27X is not set # CONFIG_USB_MV_UDC is not set # CONFIG_USB_MV_U3D is not set # CONFIG_USB_SNP_UDC_PLAT is not set # CONFIG_USB_M66592 is not set # CONFIG_USB_BDC_UDC is not set # CONFIG_USB_NET2272 is not set # CONFIG_USB_GADGET_XILINX is not set # CONFIG_USB_DUMMY_HCD is not set CONFIG_USB_LIBCOMPOSITE=m CONFIG_USB_F_ACM=m CONFIG_USB_F_SS_LB=m CONFIG_USB_U_SERIAL=m CONFIG_USB_U_ETHER=m CONFIG_USB_U_AUDIO=m CONFIG_USB_F_SERIAL=m CONFIG_USB_F_OBEX=m CONFIG_USB_F_NCM=m CONFIG_USB_F_ECM=m CONFIG_USB_F_SUBSET=m CONFIG_USB_F_RNDIS=m CONFIG_USB_F_MASS_STORAGE=m CONFIG_USB_F_FS=m CONFIG_USB_F_UAC2=m CONFIG_USB_F_UVC=m CONFIG_USB_F_MIDI=m CONFIG_USB_F_HID=m CONFIG_USB_F_PRINTER=m # CONFIG_USB_CONFIGFS is not set CONFIG_USB_ZERO=m CONFIG_USB_AUDIO=m # CONFIG_GADGET_UAC1 is not set CONFIG_USB_ETH=m CONFIG_USB_ETH_RNDIS=y # CONFIG_USB_ETH_EEM is not set CONFIG_USB_G_NCM=m CONFIG_USB_GADGETFS=m CONFIG_USB_FUNCTIONFS=m # CONFIG_USB_FUNCTIONFS_ETH is not set # CONFIG_USB_FUNCTIONFS_RNDIS is not set CONFIG_USB_FUNCTIONFS_GENERIC=y CONFIG_USB_MASS_STORAGE=m CONFIG_USB_G_SERIAL=m CONFIG_USB_MIDI_GADGET=m CONFIG_USB_G_PRINTER=m CONFIG_USB_CDC_COMPOSITE=m CONFIG_USB_G_ACM_MS=m CONFIG_USB_G_MULTI=m CONFIG_USB_G_MULTI_RNDIS=y # CONFIG_USB_G_MULTI_CDC is not set CONFIG_USB_G_HID=m CONFIG_USB_G_DBGP=m # CONFIG_USB_G_DBGP_PRINTK is not set CONFIG_USB_G_DBGP_SERIAL=y CONFIG_USB_G_WEBCAM=m # # USB Power Delivery and Type-C drivers # # CONFIG_TYPEC_UCSI is not set # CONFIG_USB_LED_TRIG is not set # CONFIG_USB_ULPI_BUS is not set # CONFIG_UWB is not set CONFIG_MMC=y # CONFIG_MMC_DEBUG is not set CONFIG_PWRSEQ_EMMC=y CONFIG_PWRSEQ_SIMPLE=y CONFIG_MMC_BLOCK=y CONFIG_MMC_BLOCK_MINORS=8 # CONFIG_SDIO_UART is not set # CONFIG_MMC_TEST is not set # # MMC/SD/SDIO Host Controller Drivers # # CONFIG_MMC_SDHCI is not set # CONFIG_MMC_DW is not set # CONFIG_MMC_VUB300 is not set # CONFIG_MMC_USHC is not set # CONFIG_MMC_USDHI6ROL0 is not set CONFIG_MMC_SUNXI=y # CONFIG_MMC_MTK is not set # CONFIG_MEMSTICK is not set CONFIG_NEW_LEDS=y CONFIG_LEDS_CLASS=y # CONFIG_LEDS_CLASS_FLASH is not set # CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set # # LED drivers # # CONFIG_LEDS_BCM6328 is not set # CONFIG_LEDS_BCM6358 is not set # CONFIG_LEDS_LM3530 is not set # CONFIG_LEDS_LM3642 is not set # CONFIG_LEDS_PCA9532 is not set CONFIG_LEDS_GPIO=y # CONFIG_LEDS_LP3944 is not set # CONFIG_LEDS_LP3952 is not set # CONFIG_LEDS_LP5521 is not set # CONFIG_LEDS_LP5523 is not set # CONFIG_LEDS_LP5562 is not set # CONFIG_LEDS_LP8501 is not set # CONFIG_LEDS_LP8860 is not set # CONFIG_LEDS_PCA955X is not set # CONFIG_LEDS_PCA963X is not set # CONFIG_LEDS_DAC124S085 is not set # CONFIG_LEDS_PWM is not set # CONFIG_LEDS_REGULATOR is not set # CONFIG_LEDS_BD2802 is not set # CONFIG_LEDS_LT3593 is not set # CONFIG_LEDS_TCA6507 is not set # CONFIG_LEDS_TLC591XX is not set # CONFIG_LEDS_LM355x is not set # CONFIG_LEDS_IS31FL319X is not set # CONFIG_LEDS_IS31FL32XX is not set # # LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM) # # CONFIG_LEDS_BLINKM is not set # CONFIG_LEDS_SYSCON is not set # CONFIG_LEDS_USER is not set # # LED Triggers # CONFIG_LEDS_TRIGGERS=y # CONFIG_LEDS_TRIGGER_TIMER is not set # CONFIG_LEDS_TRIGGER_ONESHOT is not set # CONFIG_LEDS_TRIGGER_MTD is not set CONFIG_LEDS_TRIGGER_HEARTBEAT=y # CONFIG_LEDS_TRIGGER_BACKLIGHT is not set # CONFIG_LEDS_TRIGGER_CPU is not set # CONFIG_LEDS_TRIGGER_GPIO is not set CONFIG_LEDS_TRIGGER_DEFAULT_ON=y # # iptables trigger is under Netfilter config (LED target) # # CONFIG_LEDS_TRIGGER_TRANSIENT is not set # CONFIG_LEDS_TRIGGER_CAMERA is not set # CONFIG_LEDS_TRIGGER_PANIC is not set # CONFIG_ACCESSIBILITY is not set CONFIG_EDAC_ATOMIC_SCRUB=y CONFIG_EDAC_SUPPORT=y CONFIG_RTC_LIB=y CONFIG_RTC_CLASS=y CONFIG_RTC_HCTOSYS=y CONFIG_RTC_HCTOSYS_DEVICE="rtc0" CONFIG_RTC_SYSTOHC=y CONFIG_RTC_SYSTOHC_DEVICE="rtc0" # CONFIG_RTC_DEBUG is not set CONFIG_RTC_NVMEM=y # # RTC interfaces # # CONFIG_RTC_INTF_SYSFS is not set # CONFIG_RTC_INTF_PROC is not set CONFIG_RTC_INTF_DEV=y # CONFIG_RTC_INTF_DEV_UIE_EMUL is not set # CONFIG_RTC_DRV_TEST is not set # # I2C RTC drivers # # CONFIG_RTC_DRV_ABB5ZES3 is not set # CONFIG_RTC_DRV_ABX80X is not set # CONFIG_RTC_DRV_DS1307 is not set # CONFIG_RTC_DRV_DS1374 is not set # CONFIG_RTC_DRV_DS1672 is not set # CONFIG_RTC_DRV_HYM8563 is not set # CONFIG_RTC_DRV_MAX6900 is not set # CONFIG_RTC_DRV_RS5C372 is not set # CONFIG_RTC_DRV_ISL1208 is not set # CONFIG_RTC_DRV_ISL12022 is not set # CONFIG_RTC_DRV_X1205 is not set # CONFIG_RTC_DRV_PCF8523 is not set # CONFIG_RTC_DRV_PCF85063 is not set CONFIG_RTC_DRV_PCF8563=y # CONFIG_RTC_DRV_PCF8583 is not set # CONFIG_RTC_DRV_M41T80 is not set # CONFIG_RTC_DRV_BQ32K is not set # CONFIG_RTC_DRV_S35390A is not set # CONFIG_RTC_DRV_FM3130 is not set # CONFIG_RTC_DRV_RX8010 is not set # CONFIG_RTC_DRV_RX8581 is not set # CONFIG_RTC_DRV_RX8025 is not set # CONFIG_RTC_DRV_EM3027 is not set # CONFIG_RTC_DRV_RV8803 is not set # # SPI RTC drivers # # CONFIG_RTC_DRV_M41T93 is not set # CONFIG_RTC_DRV_M41T94 is not set # CONFIG_RTC_DRV_DS1302 is not set # CONFIG_RTC_DRV_DS1305 is not set # CONFIG_RTC_DRV_DS1343 is not set # CONFIG_RTC_DRV_DS1347 is not set # CONFIG_RTC_DRV_DS1390 is not set # CONFIG_RTC_DRV_MAX6916 is not set # CONFIG_RTC_DRV_R9701 is not set # CONFIG_RTC_DRV_RX4581 is not set # CONFIG_RTC_DRV_RX6110 is not set # CONFIG_RTC_DRV_RS5C348 is not set # CONFIG_RTC_DRV_MAX6902 is not set # CONFIG_RTC_DRV_PCF2123 is not set # CONFIG_RTC_DRV_MCP795 is not set CONFIG_RTC_I2C_AND_SPI=y # # SPI and I2C RTC drivers # # CONFIG_RTC_DRV_DS3232 is not set # CONFIG_RTC_DRV_PCF2127 is not set # CONFIG_RTC_DRV_RV3029C2 is not set # # Platform RTC drivers # # CONFIG_RTC_DRV_CMOS is not set # CONFIG_RTC_DRV_DS1286 is not set # CONFIG_RTC_DRV_DS1511 is not set # CONFIG_RTC_DRV_DS1553 is not set # CONFIG_RTC_DRV_DS1685_FAMILY is not set # CONFIG_RTC_DRV_DS1742 is not set # CONFIG_RTC_DRV_DS2404 is not set # CONFIG_RTC_DRV_STK17TA8 is not set # CONFIG_RTC_DRV_M48T86 is not set # CONFIG_RTC_DRV_M48T35 is not set # CONFIG_RTC_DRV_M48T59 is not set # CONFIG_RTC_DRV_MSM6242 is not set # CONFIG_RTC_DRV_BQ4802 is not set # CONFIG_RTC_DRV_RP5C01 is not set # CONFIG_RTC_DRV_V3020 is not set # CONFIG_RTC_DRV_ZYNQMP is not set # # on-CPU RTC drivers # CONFIG_RTC_DRV_SUN6I=y # CONFIG_RTC_DRV_FTRTC010 is not set # CONFIG_RTC_DRV_SNVS is not set # CONFIG_RTC_DRV_R7301 is not set # # HID Sensor RTC drivers # # CONFIG_RTC_DRV_HID_SENSOR_TIME is not set CONFIG_DMADEVICES=y # CONFIG_DMADEVICES_DEBUG is not set # # DMA Devices # CONFIG_DMA_ENGINE=y CONFIG_DMA_VIRTUAL_CHANNELS=y CONFIG_DMA_OF=y CONFIG_DMA_SUN6I=y # CONFIG_FSL_EDMA is not set # CONFIG_INTEL_IDMA64 is not set # CONFIG_NBPFAXI_DMA is not set # CONFIG_QCOM_HIDMA_MGMT is not set # CONFIG_QCOM_HIDMA is not set # CONFIG_DW_DMAC is not set # # DMA Clients # # CONFIG_ASYNC_TX_DMA is not set # CONFIG_DMATEST is not set # # DMABUF options # CONFIG_SYNC_FILE=y # CONFIG_SW_SYNC is not set # CONFIG_AUXDISPLAY is not set # CONFIG_UIO is not set # CONFIG_VIRT_DRIVERS is not set # # Virtio drivers # # CONFIG_VIRTIO_MMIO is not set # # Microsoft Hyper-V guest support # # CONFIG_HYPERV_TSCPAGE is not set CONFIG_STAGING=y # CONFIG_PRISM2_USB is not set # CONFIG_COMEDI is not set # CONFIG_RTLLIB is not set CONFIG_RTL8723BS=m # CONFIG_R8712U is not set # CONFIG_R8188EU is not set # CONFIG_VT6656 is not set # # Speakup console speech # # CONFIG_SPEAKUP is not set # CONFIG_STAGING_MEDIA is not set # # Android # # CONFIG_STAGING_BOARD is not set # CONFIG_LTE_GDM724X is not set # CONFIG_LNET is not set # CONFIG_GS_FPGABOOT is not set # CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set # CONFIG_FB_TFT is not set # CONFIG_WILC1000_SDIO is not set # CONFIG_WILC1000_SPI is not set # CONFIG_MOST is not set # CONFIG_KS7010 is not set # CONFIG_GREYBUS is not set # CONFIG_CRYPTO_DEV_CCREE is not set # # USB Power Delivery and Type-C drivers # # CONFIG_TYPEC_TCPM is not set # CONFIG_GOLDFISH is not set # CONFIG_CHROME_PLATFORMS is not set CONFIG_CLKDEV_LOOKUP=y CONFIG_HAVE_CLK_PREPARE=y CONFIG_COMMON_CLK=y # # Common Clock Framework # # CONFIG_COMMON_CLK_SI5351 is not set # CONFIG_COMMON_CLK_SI514 is not set # CONFIG_COMMON_CLK_SI570 is not set # CONFIG_COMMON_CLK_CDCE706 is not set # CONFIG_COMMON_CLK_CDCE925 is not set # CONFIG_COMMON_CLK_CS2000_CP is not set # CONFIG_CLK_QORIQ is not set # CONFIG_COMMON_CLK_NXP is not set # CONFIG_COMMON_CLK_PWM is not set # CONFIG_COMMON_CLK_PXA is not set # CONFIG_COMMON_CLK_PIC32 is not set # CONFIG_COMMON_CLK_VC5 is not set CONFIG_SUNXI_CCU=y # CONFIG_SUN8I_A23_CCU is not set # CONFIG_SUN8I_A33_CCU is not set CONFIG_SUN8I_A83T_CCU=y # CONFIG_SUN8I_H3_CCU is not set CONFIG_SUN8I_V3S_CCU=y CONFIG_SUN8I_DE2_CCU=y CONFIG_SUN8I_R_CCU=y # CONFIG_HWSPINLOCK is not set # # Clock Source drivers # CONFIG_TIMER_OF=y CONFIG_TIMER_PROBE=y CONFIG_CLKSRC_MMIO=y CONFIG_SUN4I_TIMER=y CONFIG_ARM_ARCH_TIMER=y CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y # CONFIG_ARM_TIMER_SP804 is not set # CONFIG_ATMEL_PIT is not set # CONFIG_SH_TIMER_CMT is not set # CONFIG_SH_TIMER_MTU2 is not set # CONFIG_SH_TIMER_TMU is not set # CONFIG_EM_TIMER_STI is not set # CONFIG_MAILBOX is not set # CONFIG_IOMMU_SUPPORT is not set # # Remoteproc drivers # # CONFIG_REMOTEPROC is not set # # Rpmsg drivers # # # SOC (System On Chip) specific Drivers # # # Broadcom SoC drivers # # CONFIG_SOC_BRCMSTB is not set # # i.MX SoC drivers # CONFIG_SUNXI_SRAM=y # CONFIG_SOC_TI is not set # CONFIG_PM_DEVFREQ is not set CONFIG_EXTCON=y # # Extcon Device Drivers # # CONFIG_EXTCON_AXP288 is not set # CONFIG_EXTCON_GPIO is not set # CONFIG_EXTCON_MAX3355 is not set # CONFIG_EXTCON_RT8973A is not set # CONFIG_EXTCON_SM5502 is not set # CONFIG_EXTCON_USB_GPIO is not set # CONFIG_MEMORY is not set # CONFIG_IIO is not set CONFIG_PWM=y CONFIG_PWM_SYSFS=y # CONFIG_PWM_FSL_FTM is not set # CONFIG_PWM_PCA9685 is not set CONFIG_PWM_SUN4I=y CONFIG_IRQCHIP=y CONFIG_ARM_GIC=y CONFIG_ARM_GIC_MAX_NR=1 # CONFIG_IPACK_BUS is not set CONFIG_ARCH_HAS_RESET_CONTROLLER=y CONFIG_RESET_CONTROLLER=y # CONFIG_RESET_ATH79 is not set # CONFIG_RESET_BERLIN is not set # CONFIG_RESET_GEMINI is not set # CONFIG_RESET_IMX7 is not set # CONFIG_RESET_LPC18XX is not set # CONFIG_RESET_MESON is not set # CONFIG_RESET_PISTACHIO is not set # CONFIG_RESET_SOCFPGA is not set # CONFIG_RESET_STM32 is not set CONFIG_RESET_SUNXI=y # CONFIG_RESET_TI_SYSCON is not set # CONFIG_RESET_ZYNQ is not set # CONFIG_RESET_TEGRA_BPMP is not set # CONFIG_FMC is not set # # PHY Subsystem # CONFIG_GENERIC_PHY=y CONFIG_PHY_SUN4I_USB=y # CONFIG_PHY_SUN9I_USB is not set # CONFIG_BCM_KONA_USB2_PHY is not set # CONFIG_PHY_PXA_28NM_HSIC is not set # CONFIG_PHY_PXA_28NM_USB2 is not set # CONFIG_POWERCAP is not set # CONFIG_MCB is not set # # Performance monitor support # CONFIG_ARM_PMU=y # CONFIG_RAS is not set # # Android # # CONFIG_ANDROID is not set # CONFIG_DAX is not set CONFIG_NVMEM=y CONFIG_NVMEM_SUNXI_SID=y # CONFIG_STM is not set # CONFIG_INTEL_TH is not set # # FPGA Configuration Support # # CONFIG_FPGA is not set # # FSI support # # CONFIG_FSI is not set # CONFIG_TEE is not set # # Firmware Drivers # CONFIG_ARM_PSCI_FW=y # CONFIG_ARM_PSCI_CHECKER is not set # CONFIG_FIRMWARE_MEMMAP is not set # CONFIG_FW_CFG_SYSFS is not set CONFIG_HAVE_ARM_SMCCC=y # CONFIG_GOOGLE_FIRMWARE is not set # # Tegra firmware driver # # # File systems # CONFIG_DCACHE_WORD_ACCESS=y # CONFIG_EXT2_FS is not set # CONFIG_EXT3_FS is not set CONFIG_EXT4_FS=y CONFIG_EXT4_USE_FOR_EXT2=y # CONFIG_EXT4_FS_POSIX_ACL is not set # CONFIG_EXT4_FS_SECURITY is not set # CONFIG_EXT4_ENCRYPTION is not set # CONFIG_EXT4_DEBUG is not set CONFIG_JBD2=y # CONFIG_JBD2_DEBUG is not set CONFIG_FS_MBCACHE=y # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_XFS_FS is not set # CONFIG_GFS2_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set # CONFIG_NILFS2_FS is not set # CONFIG_F2FS_FS is not set CONFIG_FS_POSIX_ACL=y CONFIG_EXPORTFS=y # CONFIG_EXPORTFS_BLOCK_OPS is not set CONFIG_FILE_LOCKING=y CONFIG_MANDATORY_FILE_LOCKING=y # CONFIG_FS_ENCRYPTION is not set CONFIG_FSNOTIFY=y CONFIG_DNOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_FANOTIFY is not set # CONFIG_QUOTA is not set # CONFIG_QUOTACTL is not set # CONFIG_AUTOFS4_FS is not set # CONFIG_FUSE_FS is not set # CONFIG_OVERLAY_FS is not set # # Caches # # CONFIG_FSCACHE is not set # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y # CONFIG_MSDOS_FS is not set CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_FAT_DEFAULT_UTF8 is not set # CONFIG_NTFS_FS is not set # # Pseudo filesystems # CONFIG_PROC_FS=y CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y # CONFIG_PROC_CHILDREN is not set CONFIG_KERNFS=y CONFIG_SYSFS=y # CONFIG_TMPFS is not set # CONFIG_HUGETLB_PAGE is not set CONFIG_CONFIGFS_FS=y CONFIG_MISC_FILESYSTEMS=y # CONFIG_ORANGEFS_FS is not set # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set CONFIG_JFFS2_FS=y CONFIG_JFFS2_FS_DEBUG=0 CONFIG_JFFS2_FS_WRITEBUFFER=y CONFIG_JFFS2_FS_WBUF_VERIFY=y CONFIG_JFFS2_SUMMARY=y CONFIG_JFFS2_FS_XATTR=y CONFIG_JFFS2_FS_POSIX_ACL=y CONFIG_JFFS2_FS_SECURITY=y CONFIG_JFFS2_COMPRESSION_OPTIONS=y CONFIG_JFFS2_ZLIB=y CONFIG_JFFS2_LZO=y CONFIG_JFFS2_RTIME=y CONFIG_JFFS2_RUBIN=y # CONFIG_JFFS2_CMODE_NONE is not set CONFIG_JFFS2_CMODE_PRIORITY=y # CONFIG_JFFS2_CMODE_SIZE is not set # CONFIG_JFFS2_CMODE_FAVOURLZO is not set # CONFIG_CRAMFS is not set # CONFIG_SQUASHFS is not set # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set # CONFIG_QNX6FS_FS is not set # CONFIG_ROMFS_FS is not set # CONFIG_PSTORE is not set # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set CONFIG_NETWORK_FILESYSTEMS=y # CONFIG_NFS_FS is not set # CONFIG_NFSD is not set # CONFIG_CEPH_FS is not set # CONFIG_CIFS is not set # CONFIG_NCP_FS is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set CONFIG_NLS=y CONFIG_NLS_DEFAULT="utf8" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set CONFIG_NLS_CODEPAGE_936=y # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set # CONFIG_NLS_ASCII is not set CONFIG_NLS_ISO8859_1=y # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set # CONFIG_NLS_MAC_ROMAN is not set # CONFIG_NLS_MAC_CELTIC is not set # CONFIG_NLS_MAC_CENTEURO is not set # CONFIG_NLS_MAC_CROATIAN is not set # CONFIG_NLS_MAC_CYRILLIC is not set # CONFIG_NLS_MAC_GAELIC is not set # CONFIG_NLS_MAC_GREEK is not set # CONFIG_NLS_MAC_ICELAND is not set # CONFIG_NLS_MAC_INUIT is not set # CONFIG_NLS_MAC_ROMANIAN is not set # CONFIG_NLS_MAC_TURKISH is not set CONFIG_NLS_UTF8=y # CONFIG_DLM is not set # # Kernel hacking # # # printk and dmesg options # CONFIG_PRINTK_TIME=y CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7 CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4 # CONFIG_BOOT_PRINTK_DELAY is not set # CONFIG_DYNAMIC_DEBUG is not set # # Compile-time checks and compiler options # # CONFIG_DEBUG_INFO is not set CONFIG_ENABLE_WARN_DEPRECATED=y CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=1024 # CONFIG_STRIP_ASM_SYMS is not set # CONFIG_READABLE_ASM is not set # CONFIG_UNUSED_SYMBOLS is not set # CONFIG_PAGE_OWNER is not set CONFIG_DEBUG_FS=y # CONFIG_HEADERS_CHECK is not set # CONFIG_DEBUG_SECTION_MISMATCH is not set CONFIG_SECTION_MISMATCH_WARN_ONLY=y # CONFIG_DEBUG_FORCE_WEAK_PER_CPU is not set # CONFIG_MAGIC_SYSRQ is not set CONFIG_DEBUG_KERNEL=y # # Memory Debugging # # CONFIG_PAGE_EXTENSION is not set # CONFIG_DEBUG_PAGEALLOC is not set # CONFIG_PAGE_POISONING is not set # CONFIG_DEBUG_RODATA_TEST is not set # CONFIG_DEBUG_OBJECTS is not set # CONFIG_SLUB_DEBUG_ON is not set # CONFIG_SLUB_STATS is not set CONFIG_HAVE_DEBUG_KMEMLEAK=y # CONFIG_DEBUG_KMEMLEAK is not set # CONFIG_DEBUG_STACK_USAGE is not set # CONFIG_DEBUG_VM is not set CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y # CONFIG_DEBUG_VIRTUAL is not set CONFIG_DEBUG_MEMORY_INIT=y # CONFIG_DEBUG_PER_CPU_MAPS is not set # CONFIG_DEBUG_HIGHMEM is not set # CONFIG_DEBUG_SHIRQ is not set # # Debug Lockups and Hangs # # CONFIG_SOFTLOCKUP_DETECTOR is not set # CONFIG_DETECT_HUNG_TASK is not set # CONFIG_WQ_WATCHDOG is not set # CONFIG_PANIC_ON_OOPS is not set CONFIG_PANIC_ON_OOPS_VALUE=0 CONFIG_PANIC_TIMEOUT=0 CONFIG_SCHED_DEBUG=y # CONFIG_SCHED_INFO is not set # CONFIG_SCHEDSTATS is not set # CONFIG_SCHED_STACK_END_CHECK is not set # CONFIG_DEBUG_TIMEKEEPING is not set # # Lock Debugging (spinlocks, mutexes, etc...) # # CONFIG_DEBUG_RT_MUTEXES is not set # CONFIG_DEBUG_SPINLOCK is not set # CONFIG_DEBUG_MUTEXES is not set # CONFIG_DEBUG_WW_MUTEX_SLOWPATH is not set # CONFIG_DEBUG_LOCK_ALLOC is not set # CONFIG_PROVE_LOCKING is not set # CONFIG_LOCK_STAT is not set # CONFIG_DEBUG_ATOMIC_SLEEP is not set # CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set # CONFIG_LOCK_TORTURE_TEST is not set # CONFIG_WW_MUTEX_SELFTEST is not set # CONFIG_STACKTRACE is not set # CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set # CONFIG_DEBUG_KOBJECT is not set CONFIG_DEBUG_BUGVERBOSE=y # CONFIG_DEBUG_LIST is not set # CONFIG_DEBUG_PI_LIST is not set # CONFIG_DEBUG_SG is not set # CONFIG_DEBUG_NOTIFIERS is not set # CONFIG_DEBUG_CREDENTIALS is not set # # RCU Debugging # # CONFIG_PROVE_RCU is not set # CONFIG_TORTURE_TEST is not set # CONFIG_RCU_PERF_TEST is not set # CONFIG_RCU_TORTURE_TEST is not set CONFIG_RCU_CPU_STALL_TIMEOUT=21 CONFIG_RCU_TRACE=y # CONFIG_RCU_EQS_DEBUG is not set # CONFIG_DEBUG_WQ_FORCE_RR_CPU is not set # CONFIG_DEBUG_BLOCK_EXT_DEVT is not set # CONFIG_CPU_HOTPLUG_STATE_CONTROL is not set # CONFIG_NOTIFIER_ERROR_INJECTION is not set # CONFIG_FAULT_INJECTION is not set # CONFIG_LATENCYTOP is not set CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_HAVE_SYSCALL_TRACEPOINTS=y CONFIG_HAVE_C_RECORDMCOUNT=y CONFIG_TRACE_CLOCK=y CONFIG_TRACING_SUPPORT=y # CONFIG_FTRACE is not set # # Runtime Testing # # CONFIG_LKDTM is not set # CONFIG_TEST_LIST_SORT is not set # CONFIG_TEST_SORT is not set # CONFIG_BACKTRACE_SELF_TEST is not set # CONFIG_RBTREE_TEST is not set # CONFIG_INTERVAL_TREE_TEST is not set # CONFIG_PERCPU_TEST is not set # CONFIG_ATOMIC64_SELFTEST is not set # CONFIG_TEST_HEXDUMP is not set # CONFIG_TEST_STRING_HELPERS is not set # CONFIG_TEST_KSTRTOX is not set # CONFIG_TEST_PRINTF is not set # CONFIG_TEST_BITMAP is not set # CONFIG_TEST_UUID is not set # CONFIG_TEST_RHASHTABLE is not set # CONFIG_TEST_HASH is not set # CONFIG_DMA_API_DEBUG is not set # CONFIG_TEST_LKM is not set # CONFIG_TEST_USER_COPY is not set # CONFIG_TEST_BPF is not set # CONFIG_TEST_FIRMWARE is not set # CONFIG_TEST_SYSCTL is not set # CONFIG_TEST_UDELAY is not set # CONFIG_MEMTEST is not set # CONFIG_TEST_STATIC_KEYS is not set # CONFIG_BUG_ON_DATA_CORRUPTION is not set # CONFIG_TEST_KMOD is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y # CONFIG_KGDB is not set # CONFIG_ARCH_WANTS_UBSAN_NO_NULL is not set # CONFIG_UBSAN is not set CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y # CONFIG_STRICT_DEVMEM is not set # CONFIG_ARM_PTDUMP is not set CONFIG_ARM_UNWIND=y # CONFIG_DEBUG_USER is not set # CONFIG_DEBUG_LL is not set CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S" # CONFIG_DEBUG_UART_8250 is not set CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h" # CONFIG_PID_IN_CONTEXTIDR is not set # CONFIG_CORESIGHT is not set # # Security options # # CONFIG_KEYS is not set # CONFIG_SECURITY_DMESG_RESTRICT is not set # CONFIG_SECURITY is not set # CONFIG_SECURITYFS is not set CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y # CONFIG_HARDENED_USERCOPY is not set # CONFIG_STATIC_USERMODEHELPER is not set CONFIG_DEFAULT_SECURITY_DAC=y CONFIG_DEFAULT_SECURITY="" CONFIG_CRYPTO=y # # Crypto core or helper # CONFIG_CRYPTO_ALGAPI=y CONFIG_CRYPTO_ALGAPI2=y CONFIG_CRYPTO_AEAD=y CONFIG_CRYPTO_AEAD2=y CONFIG_CRYPTO_BLKCIPHER=y CONFIG_CRYPTO_BLKCIPHER2=y CONFIG_CRYPTO_HASH=y CONFIG_CRYPTO_HASH2=y CONFIG_CRYPTO_RNG=y CONFIG_CRYPTO_RNG2=y CONFIG_CRYPTO_RNG_DEFAULT=y CONFIG_CRYPTO_AKCIPHER2=y CONFIG_CRYPTO_KPP2=y CONFIG_CRYPTO_ACOMP2=y # CONFIG_CRYPTO_RSA is not set # CONFIG_CRYPTO_DH is not set # CONFIG_CRYPTO_ECDH is not set CONFIG_CRYPTO_MANAGER=y CONFIG_CRYPTO_MANAGER2=y # CONFIG_CRYPTO_USER is not set CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y CONFIG_CRYPTO_GF128MUL=y CONFIG_CRYPTO_NULL=y CONFIG_CRYPTO_NULL2=y # CONFIG_CRYPTO_PCRYPT is not set CONFIG_CRYPTO_WORKQUEUE=y # CONFIG_CRYPTO_CRYPTD is not set # CONFIG_CRYPTO_MCRYPTD is not set # CONFIG_CRYPTO_AUTHENC is not set # CONFIG_CRYPTO_TEST is not set # # Authenticated Encryption with Associated Data # CONFIG_CRYPTO_CCM=y CONFIG_CRYPTO_GCM=y # CONFIG_CRYPTO_CHACHA20POLY1305 is not set CONFIG_CRYPTO_SEQIV=y CONFIG_CRYPTO_ECHAINIV=m # # Block modes # # CONFIG_CRYPTO_CBC is not set CONFIG_CRYPTO_CTR=y # CONFIG_CRYPTO_CTS is not set # CONFIG_CRYPTO_ECB is not set # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # CONFIG_CRYPTO_KEYWRAP is not set # # Hash modes # CONFIG_CRYPTO_CMAC=y CONFIG_CRYPTO_HMAC=y # CONFIG_CRYPTO_XCBC is not set # CONFIG_CRYPTO_VMAC is not set # # Digest # CONFIG_CRYPTO_CRC32C=y # CONFIG_CRYPTO_CRC32 is not set # CONFIG_CRYPTO_CRCT10DIF is not set CONFIG_CRYPTO_GHASH=y # CONFIG_CRYPTO_POLY1305 is not set # CONFIG_CRYPTO_MD4 is not set CONFIG_CRYPTO_MD5=y # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set CONFIG_CRYPTO_SHA1=y CONFIG_CRYPTO_SHA256=y # CONFIG_CRYPTO_SHA512 is not set # CONFIG_CRYPTO_SHA3 is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # CONFIG_CRYPTO_AES=y # CONFIG_CRYPTO_AES_TI is not set # CONFIG_CRYPTO_ANUBIS is not set CONFIG_CRYPTO_ARC4=y # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set CONFIG_CRYPTO_DES=y # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SALSA20 is not set # CONFIG_CRYPTO_CHACHA20 is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # # CONFIG_CRYPTO_DEFLATE is not set # CONFIG_CRYPTO_LZO is not set # CONFIG_CRYPTO_842 is not set # CONFIG_CRYPTO_LZ4 is not set # CONFIG_CRYPTO_LZ4HC is not set # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set CONFIG_CRYPTO_DRBG_MENU=y CONFIG_CRYPTO_DRBG_HMAC=y # CONFIG_CRYPTO_DRBG_HASH is not set # CONFIG_CRYPTO_DRBG_CTR is not set CONFIG_CRYPTO_DRBG=y CONFIG_CRYPTO_JITTERENTROPY=y # CONFIG_CRYPTO_USER_API_HASH is not set # CONFIG_CRYPTO_USER_API_SKCIPHER is not set # CONFIG_CRYPTO_USER_API_RNG is not set # CONFIG_CRYPTO_USER_API_AEAD is not set CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_FSL_CAAM_CRYPTO_API_DESC is not set CONFIG_CRYPTO_DEV_SUN4I_SS=y # # Certificates for signature checking # # CONFIG_ARM_CRYPTO is not set # CONFIG_BINARY_PRINTF is not set # # Library routines # CONFIG_BITREVERSE=y CONFIG_HAVE_ARCH_BITREVERSE=y CONFIG_RATIONAL=y CONFIG_GENERIC_STRNCPY_FROM_USER=y CONFIG_GENERIC_STRNLEN_USER=y CONFIG_GENERIC_NET_UTILS=y CONFIG_GENERIC_PCI_IOMAP=y CONFIG_GENERIC_IO=y CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y # CONFIG_CRC_CCITT is not set CONFIG_CRC16=y # CONFIG_CRC_T10DIF is not set # CONFIG_CRC_ITU_T is not set CONFIG_CRC32=y # CONFIG_CRC32_SELFTEST is not set CONFIG_CRC32_SLICEBY8=y # CONFIG_CRC32_SLICEBY4 is not set # CONFIG_CRC32_SARWATE is not set # CONFIG_CRC32_BIT is not set # CONFIG_CRC4 is not set # CONFIG_CRC7 is not set # CONFIG_LIBCRC32C is not set # CONFIG_CRC8 is not set # CONFIG_AUDIT_ARCH_COMPAT_GENERIC is not set # CONFIG_RANDOM32_SELFTEST is not set CONFIG_ZLIB_INFLATE=y CONFIG_ZLIB_DEFLATE=y CONFIG_LZO_COMPRESS=y CONFIG_LZO_DECOMPRESS=y CONFIG_LZ4_DECOMPRESS=y CONFIG_XZ_DEC=y CONFIG_XZ_DEC_X86=y CONFIG_XZ_DEC_POWERPC=y CONFIG_XZ_DEC_IA64=y CONFIG_XZ_DEC_ARM=y CONFIG_XZ_DEC_ARMTHUMB=y CONFIG_XZ_DEC_SPARC=y CONFIG_XZ_DEC_BCJ=y # CONFIG_XZ_DEC_TEST is not set CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_DECOMPRESS_XZ=y CONFIG_DECOMPRESS_LZO=y CONFIG_DECOMPRESS_LZ4=y CONFIG_GENERIC_ALLOCATOR=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT_MAP=y CONFIG_HAS_DMA=y # CONFIG_DMA_NOOP_OPS is not set # CONFIG_DMA_VIRT_OPS is not set CONFIG_CPU_RMAP=y CONFIG_DQL=y CONFIG_NLATTR=y CONFIG_CORDIC=y # CONFIG_DDR is not set # CONFIG_IRQ_POLL is not set CONFIG_LIBFDT=y CONFIG_FONT_SUPPORT=y # CONFIG_FONTS is not set CONFIG_FONT_8x8=y CONFIG_FONT_8x16=y # CONFIG_SG_SPLIT is not set CONFIG_SG_POOL=y CONFIG_ARCH_HAS_SG_CHAIN=y CONFIG_SBITMAP=y # CONFIG_VIRTUALIZATION is not set勾上 wireless 相关的协议和驱动
晕哥 linux-kernel 5.3.6版本中没有 这个选项该怎么办?
唯有爱与科技不可辜负。
知乎专栏:IAMLIUBO的神奇物联网之旅
博客园:IAMLIUBO
Gayhub: IAMLIUBO
文件系统还需要两个固件:
/lib/firmware/brcm/brcmfmac43430-sdio.bin
/lib/firmware/brcm/brcmfmac43430-sdio.txthttps://github.com/armbian/firmware/tree/master/brcm
https://github.com/RPi-Distro/firmware-nonfree/blob/master/brcm/下载地址:
https://raw.githubusercontent.com/armbian/firmware/master/brcm/brcmfmac43430-sdio.txt
https://raw.githubusercontent.com/armbian/firmware/master/brcm/brcmfmac43430-sdio.bin
还有这两个文件的具体作用是什么?只需要复制到文件系统的 /lib/firmware/brcm/ 文件下就可以吗?
这个ap6212具体是怎么被初始化的,感觉有点迷。。。
唯有爱与科技不可辜负。
博客园:IAMLIUBO
Gayhub: IAMLIUBO
晕哥,我刚使用BCM43438,这个在linux内核中只能用模块加载吗?感觉SDIO都没有初始化成功
MP157,基本上调试快结束了,不知道大佬有没有兴趣玩玩?
MP157 是啥, 怎么啥都没搜到.
飞翔工控 wrote:
MP157 是啥, 怎么啥都没搜到.
STM32MP157
跑Linux吗?
是的。不知道咋发图片
https://whycan.cn/t_588.html#p16351
/files/members/3/QQ20190313213317.png
这几天网络审查有点严,网速有点慢,要多给点耐心.
好,我上传下。
mokail wrote:
好,我上传下。
感谢楼主,跟着楼主步骤一步一步终于搞定ap6212驱动,连续跑了几天都没有断网。
Lnux5.x下面调试成功。总结一下经验:
遇到12、13信道无法连接的问题,导致路由器自动调频到12、13信道时无线掉线。
解决方法如下:
1.官网下载适用于5.x版本固件(含brcmfmac43430-sdio.bin和brcmfmac43430-sdio.clm_blob)更新到板子/lib/firmware/brcm/目录下
下载地址。https://community.cypress.com/docs/DOC-19375
2.修改对应的brcmfmac43430-sdio.txt nvram配置,将country设置为China。
将ccode=ALL修改为ccode=SRRC
购买链接: https://item.taobao.com/item.htm?id=591896289694
店铺链接: https://shop512436263.taobao.com
参考链接: 感谢华嵌HQEmbed赠送的 漂亮高颜值S3 开发板 (底板 + 核心板)
核心板原理图: core_s3_v01.pdf
底板原理图: hq_050ips_v01.pdf2019-06-01 更新:
能跑BCM43438 WIFI 的固件下载: read_hq_s3_128m.7z
