我用mkfs.jffs2制作根文件系统, 用sunxi-fel烧到指定的flash地址后,linux启动出现了下面的错误
[quote]
[ 0.982462] hub 1-0:1.0: USB hub found
[ 0.986400] hub 1-0:1.0: 1 port detected
[ 0.990907] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.997230] ohci-platform: OHCI generic platform driver
[ 1.002777] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.009527] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.017468] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[ 1.090404] hub 2-0:1.0: USB hub found
[ 1.094232] hub 2-0:1.0: 1 port detected
[ 1.101418] usbcore: registered new interface driver usb-storage
[ 1.108074] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.117639] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.126575] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.133368] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.138045] i2c /dev entries driver
[ 1.142917] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[ 1.152397] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.215374] sunxi-mmc 1c0f000.mmc: base:0xc4257000 irq:23
[ 1.221854] usbcore: registered new interface driver usbhid
[ 1.227512] usbhid: USB HID core driver
[ 1.232948] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.240997] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.248531] NET: Registered protocol family 17
[ 1.253147] Registering SWP/SWPB emulation handler
[ 1.265560] params->width = 0 000
[ 1.268933] params->width = 800 111
[ 1.272416] params->height = 0 111
[ 1.275864] params->height = 480 222
[ 1.279444] drivers/video/fbdev/simplefb.c.436: 22222222222222222
[ 1.285813] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0xc4400000
[ 1.296365] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[ 1.312531] Console: switching to colour frame buffer device 100x30
[ 1.324993] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[ 1.337744] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.349176] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.354944] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.364116] hub 3-0:1.0: USB hub found
[ 1.368090] hub 3-0:1.0: 1 port detected
[ 1.373107] using random self ethernet address
[ 1.377653] using random host ethernet address
[ 1.383120] usb0: HOST MAC 0e:ed:36:25:f7:7d
[ 1.387553] usb0: MAC c6:6a:cd:ea:66:d3
[ 1.391452] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.398974] g_cdc gadget: g_cdc ready
[ 1.405193] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.414837] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-03 20:45:52 UTC (247552)
[ 1.423517] vcc3v3: disabling
[ 1.426546] vcc5v0: disabling
[ 1.429513] ALSA device list:
[ 1.432477] #0: V3s Audio Codec
[ 1.541952] random: crng init done
[ 1.555398] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in b_idle (80, <SessEnd), retry #0, port1 00000100
[ 1.888644] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420000: 0x7808 instead
[ 1.898166] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420004: 0x0002 instead
[ 1.907649] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0042000c: 0x77e8 instead
[ 1.917128] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420010: 0x0003 instead
[ 1.926603] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420018: 0x7c94 instead
[ 1.936108] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0042001c: 0x0006 instead
[ 1.945591] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420030: 0x3f28 instead
[ 1.955056] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0042003c: 0x3f30 instead
[ 1.964532] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420040: 0x0001 instead
[ 1.974008] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00420048: 0x77a0 instead
[ 1.983480] jffs2: Further such events for this erase block will not be printed
[ 1.993278] jffs2: Empty flash at 0x00422d9c ends at 0x00422da0
[ 1.999738] jffs2: Empty flash at 0x00422db8 ends at 0x00422dc0
[ 2.009488] jffs2: Empty flash at 0x004281f0 ends at 0x004281f4
[ 2.015986] jffs2: Empty flash at 0x00428798 ends at 0x0042879c
[ 2.022431] jffs2: Empty flash at 0x004289b0 ends at 0x004289b4
[ 2.028362] jffs2: Empty flash at 0x004289b8 ends at 0x004289bc
[ 2.034894] jffs2: Empty flash at 0x00429540 ends at 0x00429548
[ 2.041344] jffs2: Empty flash at 0x00429588 ends at 0x0042958c
[ 2.047272] jffs2: Empty flash at 0x00429590 ends at 0x00429594
[ 2.053702] jffs2: Empty flash at 0x004295c4 ends at 0x004295c8
[ 2.062139] jffs2: Empty flash at 0x0042caf4 ends at 0x0042caf8
[ 2.068668] jffs2: Empty flash at 0x0042d468 ends at 0x0042d46c
[ 2.075790] jffs2: Empty flash at 0x0042e710 ends at 0x0042e714
[ 2.082429] jffs2: Empty flash at 0x0042f940 ends at 0x0042f944
[ 2.088380] jffs2: Empty flash at 0x0042f948 ends at 0x0042f94c
[ 2.094529] jffs2: Empty flash at 0x0042fa38 ends at 0x0042fa3c
[ 2.100459] jffs2: Empty flash at 0x0042fa40 ends at 0x0042fa44
[ 2.106597] jffs2: Empty flash at 0x0042fbbc ends at 0x0042fbc4
[ 2.112666] jffs2: Empty flash at 0x0042fd38 ends at 0x0042fd3c
[ 2.118726] jffs2: Empty flash at 0x0042fde4 ends at 0x0042fde8
[ 2.124806] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00430000: 0x7fdc instead
[ 2.134295] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00430004: 0x7fcc instead
[ 2.143773] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0043000c: 0xddc4 instead
[ 2.153266] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00430010: 0x01a4 instead
[ 2.162751] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00430014: 0xf31c instead
[ 2.172229] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00430018: 0xfe00 instead
[ 2.181704] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0043001c: 0xddd0 instead
[ 2.191179] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00430020: 0x0124 instead
[ 2.200653] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00430024: 0xf814 instead
[ 2.210127] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0043002c: 0x26e0 instead
[ 2.219599] jffs2: Further such events for this erase block will not be printed
[ 2.230648] jffs2: Empty flash at 0x00434a1c ends at 0x00434a20
[ 2.237120] jffs2: Empty flash at 0x00434c48 ends at 0x00434c4c
[ 2.244329] jffs2: Empty flash at 0x00436a94 ends at 0x00436a98
[ 2.251485] jffs2: Empty flash at 0x00438198 ends at 0x0043819c
[ 2.258702] jffs2: Empty flash at 0x00439f0c ends at 0x00439f10
[ 2.268352] jffs2: Empty flash at 0x0043f314 ends at 0x0043f32c
[ 2.274585] jffs2: Empty flash at 0x0043f870 ends at 0x0043f874
[ 2.282023] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00442040: 0x0600 instead
[ 2.291507] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00442044: 0xf730 instead
[ 2.300984] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00442048: 0x00fe instead
[ 2.310458] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0044204c: 0x87a0 instead
[ 2.319933] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00442050: 0x0753 instead
[ 2.329407] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00442054: 0x0134 instead
[ 2.338881] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00442058: 0x89b8 instead
[ 2.348355] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0044205c: 0x0753 instead
[ 2.357846] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00442060: 0x011a instead
[ 2.367339] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00442064: 0x941c instead
[ 2.376814] jffs2: Further such events for this erase block will not be printed
[ 2.387390] jffs2: Old JFFS2 bitmask found at 0x00446bb8
[ 2.392695] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 2.400895] jffs2: Empty flash at 0x004477dc ends at 0x00448000
[ 2.411965] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00450000: 0x1e70 instead
[ 2.421453] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00450004: 0x355e instead
[ 2.430929] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00450008: 0x5818 instead
[ 2.440404] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0045000c: 0x2332 instead
[ 2.449878] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00450010: 0x555f instead
[ 2.459353] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00450014: 0xef50 instead
[ 2.468827] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00450018: 0x9a5e instead
[ 2.478301] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0045001c: 0x3f87 instead
[ 2.487842] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00450020: 0x3fec instead
[ 2.497322] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00450024: 0x7c39 instead
[ 2.506795] jffs2: Further such events for this erase block will not be printed
[ 2.524798] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00460000: 0xc03e instead
[ 2.534298] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00460004: 0xd652 instead
[ 2.543778] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00460008: 0x47a8 instead
[ 2.553282] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0046000c: 0x1eaa instead
[ 2.562788] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00460010: 0x47b2 instead
[ 2.573345] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00460014: 0x92bc instead
[ 2.584882] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00460018: 0xb34f instead
[ 2.594383] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0046001c: 0x2c33 instead
[ 2.603876] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00460020: 0xcb2c instead
[ 2.613364] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00460024: 0xf8e3 instead
[ 2.622843] jffs2: Further such events for this erase block will not be printed
[ 2.642005] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00470000: 0x150c instead
[ 2.651504] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00470004: 0x2792 instead
[ 2.660985] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00470008: 0x43b2 instead
[ 2.670461] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0047000c: 0x5b79 instead
[ 2.679937] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00470010: 0xf69c instead
[ 2.689412] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00470014: 0xb493 instead
[ 2.698887] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00470018: 0x7ad9 instead
[ 2.708361] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0047001c: 0xb654 instead
[ 2.717835] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00470020: 0xba63 instead
[ 2.727310] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00470024: 0x9476 instead
[ 2.736781] jffs2: Further such events for this erase block will not be printed
[ 2.749260] jffs2: Old JFFS2 bitmask found at 0x00477418
[ 2.754565] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 2.767121] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00480000: 0x0eed instead
[ 2.776632] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00480004: 0xe3a4 instead
[ 2.786112] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00480008: 0xb1aa instead
[ 2.795589] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0048000c: 0xf18e instead
[ 2.805054] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00480010: 0x8c46 instead
[ 2.814530] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00480014: 0x4630 instead
[ 2.824005] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00480018: 0xc04d instead
[ 2.833479] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0048001c: 0x8631 instead
[ 2.842953] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00480020: 0xa38f instead
[ 2.852427] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00480024: 0xe018 instead
[ 2.861898] jffs2: Further such events for this erase block will not be printed
[ 2.879816] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00490000: 0xffe0 instead
[ 2.889322] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00490004: 0xd4f2 instead
[ 2.898803] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00490008: 0x8eaa instead
[ 2.908279] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0049000c: 0x5681 instead
[ 2.917756] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00490010: 0xc7b4 instead
[ 2.927230] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00490014: 0xd76b instead
[ 2.936704] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00490018: 0xf6fd instead
[ 2.946178] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0049001c: 0xaeb8 instead
[ 2.955652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00490020: 0x7b5d instead
[ 2.965117] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00490024: 0x6a95 instead
[ 2.974580] jffs2: Further such events for this erase block will not be printed
[ 2.992491] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a0000: 0x96f6 instead
[ 3.001982] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a0004: 0x9726 instead
[ 3.011460] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a0008: 0xc7f1 instead
[ 3.020936] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a000c: 0xa687 instead
[ 3.030411] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a0010: 0x6d6d instead
[ 3.039886] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a0014: 0xde87 instead
[ 3.049360] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a0018: 0x26cf instead
[ 3.058835] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a001c: 0x1fb4 instead
[ 3.068309] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a0020: 0xa8fd instead
[ 3.077783] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004a0024: 0xff91 instead
[ 3.087254] jffs2: Further such events for this erase block will not be printed
[ 3.105125] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b0000: 0x25bb instead
[ 3.114611] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b0004: 0xc682 instead
[ 3.124088] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b0008: 0x4aa4 instead
[ 3.133584] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b000c: 0x13ea instead
[ 3.143063] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b0010: 0x5f82 instead
[ 3.152554] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b0014: 0xd21e instead
[ 3.162032] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b0018: 0xab13 instead
[ 3.171507] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b001c: 0x7d54 instead
[ 3.180981] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b0020: 0x3695 instead
[ 3.190455] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004b0024: 0x1fa2 instead
[ 3.199932] jffs2: Further such events for this erase block will not be printed
[ 3.218023] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c0000: 0xc8c2 instead
[ 3.227556] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c0004: 0x56ec instead
[ 3.237061] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c0008: 0xc14a instead
[ 3.246541] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c000c: 0x70ce instead
[ 3.256017] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c0010: 0x04eb instead
[ 3.265492] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c0014: 0xae7c instead
[ 3.274957] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c0018: 0x62aa instead
[ 3.284432] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c001c: 0xca3c instead
[ 3.293906] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c0020: 0x13c4 instead
[ 3.303380] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004c0024: 0x3a86 instead
[ 3.312851] jffs2: Further such events for this erase block will not be printed
[ 3.330767] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d0000: 0x9b2d instead
[ 3.340254] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d0004: 0xcd03 instead
[ 3.349731] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d0008: 0x1758 instead
[ 3.359205] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d000c: 0xae36 instead
[ 3.368680] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d0010: 0x4ba8 instead
[ 3.378154] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d0014: 0x75fe instead
[ 3.387628] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d0018: 0x0945 instead
[ 3.397103] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d001c: 0xbcf6 instead
[ 3.406608] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d0020: 0x9f4f instead
[ 3.416089] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004d0024: 0xfbf7 instead
[ 3.425562] jffs2: Further such events for this erase block will not be printed
[ 3.443468] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e0000: 0xdace instead
[ 3.452956] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e0004: 0xb5f7 instead
[ 3.462434] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e0008: 0xe875 instead
[ 3.471910] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e000c: 0x2f5c instead
[ 3.481386] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e0010: 0xb79d instead
[ 3.490861] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e0014: 0x0170 instead
[ 3.500335] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e0018: 0xde61 instead
[ 3.509809] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e001c: 0xce15 instead
[ 3.519283] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e0020: 0xbe5c instead
[ 3.528757] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004e0024: 0xc42e instead
[ 3.538228] jffs2: Further such events for this erase block will not be printed
[ 3.556116] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f0000: 0x3863 instead
[ 3.565601] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f0004: 0x661a instead
[ 3.575067] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f0008: 0x2b45 instead
[ 3.584544] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f000c: 0xe794 instead
[ 3.594019] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f0010: 0x90f6 instead
[ 3.603493] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f0014: 0xa679 instead
[ 3.612968] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f0018: 0xf364 instead
[ 3.622460] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f001c: 0xd3a5 instead
[ 3.631938] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f0020: 0xdf6c instead
[ 3.641414] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x004f0024: 0x9d6f instead
[ 3.650885] jffs2: Further such events for this erase block will not be printed
[ 3.668791] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00500000: 0x3dc4 instead
[ 3.678278] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00500004: 0xd611 instead
[ 3.687816] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00500008: 0xe3de instead
[ 3.697297] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0050000c: 0xd4a6 instead
[ 3.706773] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00500010: 0xde24 instead
[ 3.716303] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00500014: 0x6621 instead
[ 3.725784] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00500018: 0x5319 instead
[ 3.735249] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0050001c: 0x7d7b instead
[ 3.744724] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00500020: 0x21c0 instead
[ 3.754221] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00500024: 0x9fd9 instead
[ 3.763708] jffs2: Further such events for this erase block will not be printed
[ 3.780791] jffs2: Old JFFS2 bitmask found at 0x00509db0
[ 3.786130] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 3.797428] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00510000: 0xfc1f instead
[ 3.807967] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00510004: 0xe214 instead
[ 3.817451] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00510008: 0xd4a2 instead
[ 3.826948] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0051000c: 0x5396 instead
[ 3.836427] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00510010: 0xdab2 instead
[ 3.845902] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00510014: 0x11b3 instead
[ 3.855378] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00510018: 0xf217 instead
[ 3.864842] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0051001c: 0xc3c5 instead
[ 3.874317] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00510020: 0x2b29 instead
[ 3.883791] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00510024: 0xbba7 instead
[ 3.893262] jffs2: Further such events for this erase block will not be printed
[ 3.911179] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00520000: 0xde7f instead
[ 3.920670] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00520004: 0xb0e9 instead
[ 3.930172] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00520008: 0xd81b instead
[ 3.939652] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0052000c: 0xd630 instead
[ 3.949128] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00520010: 0x89fd instead
[ 3.958602] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00520014: 0x9b95 instead
[ 3.968077] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00520018: 0x3f6e instead
[ 3.977551] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0052001c: 0x5b4b instead
[ 3.987025] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00520020: 0xfd14 instead
[ 3.996499] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00520024: 0x5ad4 instead
[ 4.005970] jffs2: Further such events for this erase block will not be printed
[ 4.023639] jffs2: Old JFFS2 bitmask found at 0x0052f5a4
[ 4.028961] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 4.036277] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00530000: 0xd8cb instead
[ 4.045764] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00530004: 0xb4d7 instead
[ 4.055230] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00530008: 0xaafa instead
[ 4.064708] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0053000c: 0x37cc instead
[ 4.074185] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00530010: 0x34ae instead
[ 4.083659] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00530014: 0x66df instead
[ 4.093156] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00530018: 0x3367 instead
[ 4.102628] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0053001c: 0x6c48 instead
[ 4.112104] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00530020: 0xf26b instead
[ 4.121578] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00530024: 0x3721 instead
[ 4.131049] jffs2: Further such events for this erase block will not be printed
[ 4.141526] jffs2: Old JFFS2 bitmask found at 0x005343e4
[ 4.146846] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 4.161309] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00540000: 0x1be2 instead
[ 4.170793] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00540004: 0x3bf8 instead
[ 4.180269] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00540008: 0xc75c instead
[ 4.189765] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0054000c: 0xbe00 instead
[ 4.199243] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00540010: 0x7a0c instead
[ 4.208718] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00540014: 0xc3ef instead
[ 4.218194] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00540018: 0xca8e instead
[ 4.227669] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0054001c: 0xb22b instead
[ 4.237143] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00540020: 0x1657 instead
[ 4.246633] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00540024: 0x8c27 instead
[ 4.256109] jffs2: Further such events for this erase block will not be printed
[ 4.274004] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00550000: 0x2947 instead
[ 4.283490] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00550004: 0x93b5 instead
[ 4.292967] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00550008: 0x11dc instead
[ 4.302442] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0055000c: 0xe06f instead
[ 4.311918] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00550010: 0xd612 instead
[ 4.321392] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00550014: 0x6460 instead
[ 4.330866] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00550018: 0x21de instead
[ 4.340340] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0055001c: 0xab5a instead
[ 4.349815] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00550020: 0x1607 instead
[ 4.359289] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00550024: 0xd31f instead
[ 4.368760] jffs2: Further such events for this erase block will not be printed
[ 4.385208] jffs2: Old JFFS2 bitmask found at 0x0055e084
[ 4.390528] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 4.399013] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00560000: 0xacbb instead
[ 4.408497] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00560004: 0x48fb instead
[ 4.417973] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00560008: 0x7ada instead
[ 4.427448] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0056000c: 0xaf5d instead
[ 4.436922] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00560010: 0x7b8b instead
[ 4.446414] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00560014: 0xaf70 instead
[ 4.455908] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00560018: 0xe781 instead
[ 4.465384] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0056001c: 0x6e95 instead
[ 4.474849] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00560020: 0xe91e instead
[ 4.484324] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00560024: 0xbead instead
[ 4.493797] jffs2: Further such events for this erase block will not be printed
[ 4.505596] jffs2: Old JFFS2 bitmask found at 0x00566424
[ 4.510902] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 4.524053] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00570000: 0x85a3 instead
[ 4.533537] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00570004: 0xa2b7 instead
[ 4.543013] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00570008: 0x2aab instead
[ 4.552489] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0057000c: 0xe620 instead
[ 4.561964] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00570010: 0x0780 instead
[ 4.571440] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00570014: 0x08e4 instead
[ 4.580914] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00570018: 0x8d42 instead
[ 4.590388] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0057001c: 0x44bd instead
[ 4.599862] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00570020: 0x4bb3 instead
[ 4.609336] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00570024: 0x7be6 instead
[ 4.618807] jffs2: Further such events for this erase block will not be printed
[ 4.636705] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00580000: 0xbbf2 instead
[ 4.646196] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00580004: 0x558c instead
[ 4.655673] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00580008: 0x388f instead
[ 4.665138] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0058000c: 0xded2 instead
[ 4.674633] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00580010: 0x303f instead
[ 4.684112] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00580014: 0x75b4 instead
[ 4.693589] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00580018: 0x1de5 instead
[ 4.703064] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0058001c: 0xdff1 instead
[ 4.712556] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00580020: 0x0f76 instead
[ 4.722033] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00580024: 0xfe8e instead
[ 4.731505] jffs2: Further such events for this erase block will not be printed
[ 4.749414] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00590000: 0xf0df instead
[ 4.758900] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00590004: 0xbf47 instead
[ 4.768377] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00590008: 0xf5c8 instead
[ 4.777851] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0059000c: 0xea86 instead
[ 4.787326] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00590010: 0x90c3 instead
[ 4.796800] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00590014: 0x3573 instead
[ 4.806275] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00590018: 0x548d instead
[ 4.815750] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0059001c: 0xdbdc instead
[ 4.825214] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00590020: 0x1e71 instead
[ 4.834688] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00590024: 0xe90d instead
[ 4.844159] jffs2: Further such events for this erase block will not be printed
[ 4.862049] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a0000: 0x0f3a instead
[ 4.871534] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a0004: 0xd083 instead
[ 4.881029] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a0008: 0x76f9 instead
[ 4.890566] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a000c: 0x1cbe instead
[ 4.900046] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a0010: 0x78d4 instead
[ 4.909522] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a0014: 0xd53e instead
[ 4.919054] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a0018: 0x190e instead
[ 4.928536] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a001c: 0xfe10 instead
[ 4.938012] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a0020: 0xc8a6 instead
[ 4.947509] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005a0024: 0x21fb instead
[ 4.956998] jffs2: Further such events for this erase block will not be printed
[ 4.978092] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b0000: 0x3f03 instead
[ 4.987613] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b0004: 0x804f instead
[ 4.997115] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b0008: 0x6939 instead
[ 5.006609] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b000c: 0x1f4f instead
[ 5.016104] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b0010: 0x896e instead
[ 5.025638] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b0014: 0x61fb instead
[ 5.036148] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b0018: 0xdf45 instead
[ 5.045632] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b001c: 0x94fc instead
[ 5.055097] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b0020: 0xe742 instead
[ 5.064573] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005b0024: 0x5e3f instead
[ 5.074045] jffs2: Further such events for this erase block will not be printed
[ 5.091980] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c0000: 0x0bd6 instead
[ 5.101469] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c0004: 0xdf12 instead
[ 5.110947] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c0008: 0xe5f0 instead
[ 5.120424] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c000c: 0xfc67 instead
[ 5.129921] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c0010: 0xb682 instead
[ 5.139401] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c0014: 0xa1ac instead
[ 5.148876] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c0018: 0xcbef instead
[ 5.158350] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c001c: 0x6871 instead
[ 5.167824] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c0020: 0xc3b4 instead
[ 5.177299] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x005c0024: 0x727d instead
[ 5.186770] jffs2: Further such events for this erase block will not be printed
[ 5.241105] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00608044: 0x0001 instead
[ 5.250592] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0060804c: 0x66c0 instead
[ 5.261994] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0060ad40: 0x8ad0 instead
[ 5.272002] jffs2: Empty flash at 0x0060ae0c ends at 0x0060ae10
[ 5.278058] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0060bcdc: 0xd73b instead
[ 5.287534] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0060bce0: 0x03e8 instead
[ 5.297026] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0060bcec: 0x0020 instead
[ 5.306504] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0060bcf4: 0xa120 instead
[ 5.315979] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0060bcfc: 0x000a instead
[ 5.325454] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0060bd0c: 0x4e20 instead
[ 5.334921] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0060bd3c: 0x0015 instead
[ 5.344392] jffs2: Further such events for this erase block will not be printed
[ 5.352821] jffs2: Empty flash at 0x0060c790 ends at 0x0060c798
[ 5.358751] jffs2: Empty flash at 0x0060c7ac ends at 0x0060c7b0
[ 5.365178] jffs2: Empty flash at 0x0060c7b4 ends at 0x0060c7b8
[ 5.372924] jffs2: Empty flash at 0x0060f378 ends at 0x0060f390
[ 5.378853] jffs2: Empty flash at 0x0060f394 ends at 0x0060f398
[ 5.385179] jffs2: Empty flash at 0x0060f39c ends at 0x0060f3a8
[ 5.391520] jffs2: Empty flash at 0x0060f3c0 ends at 0x0060f3d0
[ 5.397851] jffs2: Empty flash at 0x0060f3f0 ends at 0x0060f3f8
[ 5.404085] jffs2: Empty flash at 0x0060f82c ends at 0x0060f830
[ 5.410272] jffs2: Empty flash at 0x0060f968 ends at 0x0060f96c
[ 5.416444] jffs2: Empty flash at 0x0060f9b4 ends at 0x0060f9b8
[ 5.422552] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00610000: 0x0007 instead
[ 5.432036] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00610008: 0x29d8 instead
[ 5.441514] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0061000c: 0x20c8 instead
[ 5.450988] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00610010: 0x000b instead
[ 5.460463] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00610014: 0x0001 instead
[ 5.469937] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00610018: 0x2818 instead
[ 5.479411] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0061001c: 0x1f80 instead
[ 5.488906] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00610020: 0x0007 instead
[ 5.498387] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00610028: 0x2830 instead
[ 5.507879] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0061002c: 0x1f80 instead
[ 5.517354] jffs2: Further such events for this erase block will not be printed
[ 5.525753] jffs2: Empty flash at 0x0061045c ends at 0x00610460
[ 5.532920] jffs2: Empty flash at 0x00611e8c ends at 0x00611e90
[ 5.540036] jffs2: Empty flash at 0x00612fd4 ends at 0x00612fd8
[ 5.546484] jffs2: Empty flash at 0x00613014 ends at 0x00613018
[ 5.552915] jffs2: Empty flash at 0x00613054 ends at 0x00613058
[ 5.559361] jffs2: Empty flash at 0x00613094 ends at 0x00613098
[ 5.565814] jffs2: Empty flash at 0x006131c8 ends at 0x006131cc
[ 5.571726] jffs2: Empty flash at 0x006131d0 ends at 0x006131d4
[ 5.578211] jffs2: Empty flash at 0x00613698 ends at 0x0061369c
[ 5.584123] jffs2: Empty flash at 0x006136a0 ends at 0x006136a4
[ 5.590047] jffs2: Empty flash at 0x006136a8 ends at 0x006136ac
[ 5.596577] jffs2: Empty flash at 0x006140d4 ends at 0x006140d8
[ 5.603037] jffs2: Empty flash at 0x00614498 ends at 0x006144a0
[ 5.609553] jffs2: Empty flash at 0x00614d14 ends at 0x00614d1c
[ 5.616013] jffs2: Empty flash at 0x00614f38 ends at 0x00614f3c
[ 5.622460] jffs2: Empty flash at 0x00615170 ends at 0x00615174
[ 5.628930] jffs2: Empty flash at 0x00615498 ends at 0x0061549c
[ 5.635375] jffs2: Empty flash at 0x006154e0 ends at 0x006154e4
[ 5.641287] jffs2: Empty flash at 0x006154f0 ends at 0x006154f4
[ 5.647735] jffs2: Empty flash at 0x006155bc ends at 0x006155c0
[ 5.654300] jffs2: Empty flash at 0x00616560 ends at 0x00616564
[ 5.660798] jffs2: Empty flash at 0x00616b8c ends at 0x00616b90
[ 5.667936] jffs2: Empty flash at 0x00618034 ends at 0x00618038
[ 5.678702] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00620000: 0x7808 instead
[ 5.688187] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00620004: 0x0002 instead
[ 5.697664] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062000c: 0x77e8 instead
[ 5.707138] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00620010: 0x0003 instead
[ 5.716632] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00620018: 0x7c94 instead
[ 5.726110] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062001c: 0x0006 instead
[ 5.735587] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00620030: 0x3f28 instead
[ 5.745053] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0062003c: 0x3f30 instead
[ 5.754545] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00620040: 0x0001 instead
[ 5.764025] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00620048: 0x77a0 instead
[ 5.773498] jffs2: Further such events for this erase block will not be printed
[ 5.783270] jffs2: Empty flash at 0x00622d9c ends at 0x00622da0
[ 5.789719] jffs2: Empty flash at 0x00622db8 ends at 0x00622dc0
[ 5.799463] jffs2: Empty flash at 0x006281f0 ends at 0x006281f4
[ 5.805957] jffs2: Empty flash at 0x00628798 ends at 0x0062879c
[ 5.812402] jffs2: Empty flash at 0x006289b0 ends at 0x006289b4
[ 5.818328] jffs2: Empty flash at 0x006289b8 ends at 0x006289bc
[ 5.824860] jffs2: Empty flash at 0x00629540 ends at 0x00629548
[ 5.831306] jffs2: Empty flash at 0x00629588 ends at 0x0062958c
[ 5.837233] jffs2: Empty flash at 0x00629590 ends at 0x00629594
[ 5.843663] jffs2: Empty flash at 0x006295c4 ends at 0x006295c8
[ 5.852095] jffs2: Empty flash at 0x0062caf4 ends at 0x0062caf8
[ 5.858624] jffs2: Empty flash at 0x0062d468 ends at 0x0062d46c
[ 5.865742] jffs2: Empty flash at 0x0062e710 ends at 0x0062e714
[ 5.872382] jffs2: Empty flash at 0x0062f940 ends at 0x0062f944
[ 5.878308] jffs2: Empty flash at 0x0062f948 ends at 0x0062f94c
[ 5.884454] jffs2: Empty flash at 0x0062fa38 ends at 0x0062fa3c
[ 5.890380] jffs2: Empty flash at 0x0062fa40 ends at 0x0062fa44
[ 5.896497] jffs2: Empty flash at 0x0062fbbc ends at 0x0062fbc4
[ 5.902558] jffs2: Empty flash at 0x0062fd38 ends at 0x0062fd3c
[ 5.908612] jffs2: Empty flash at 0x0062fde4 ends at 0x0062fde8
[ 5.914690] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00630000: 0x7fdc instead
[ 5.924176] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00630004: 0x7fcc instead
[ 5.933672] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0063000c: 0xddc4 instead
[ 5.943150] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00630010: 0x01a4 instead
[ 5.952625] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00630014: 0xf31c instead
[ 5.962099] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00630018: 0xfe00 instead
[ 5.971573] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0063001c: 0xddd0 instead
[ 5.981047] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00630020: 0x0124 instead
[ 5.990521] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00630024: 0xf814 instead
[ 5.999995] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0063002c: 0x26e0 instead
[ 6.009472] jffs2: Further such events for this erase block will not be printed
[ 6.020533] jffs2: Empty flash at 0x00634a1c ends at 0x00634a20
[ 6.027002] jffs2: Empty flash at 0x00634c48 ends at 0x00634c4c
[ 6.034210] jffs2: Empty flash at 0x00636a94 ends at 0x00636a98
[ 6.041367] jffs2: Empty flash at 0x00638198 ends at 0x0063819c
[ 6.048583] jffs2: Empty flash at 0x00639f0c ends at 0x00639f10
[ 6.058231] jffs2: Empty flash at 0x0063f314 ends at 0x0063f32c
[ 6.064462] jffs2: Empty flash at 0x0063f870 ends at 0x0063f874
[ 6.071903] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00642040: 0x0600 instead
[ 6.081387] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00642044: 0xf730 instead
[ 6.090943] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00642048: 0x00fe instead
[ 6.100430] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0064204c: 0x87a0 instead
[ 6.109907] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00642050: 0x0753 instead
[ 6.119437] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00642054: 0x0134 instead
[ 6.128919] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00642058: 0x89b8 instead
[ 6.138416] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x0064205c: 0x0753 instead
[ 6.147914] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00642060: 0x011a instead
[ 6.157421] jffs2: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00642064: 0x941c instead
[ 6.166907] jffs2: Further such events for this erase block will not be printed
[ 6.178453] jffs2: Old JFFS2 bitmask found at 0x00646bb8
[ 6.183759] jffs2: You cannot use older JFFS2 filesystems with newer kernels
[ 6.203292] jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 6.220171] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[ 6.227171] devtmpfs: mounted
[ 6.231436] Freeing unused kernel memory: 1024K
mount: mounting proc on /proc failed: No such file or directory
mount: can't read '/proc/mounts': No such file or directory
mount: mounting tmpfs on /dev/shm failed: Invalid argument
mount: mounting tmpfs on /tmp failed: No such file or directory
mount: mounting tmpfs on /run failed: No such file or directory
mount: mounting sysfs on /sys failed: No such file or directory
--------------------------->rcS
[ 6.728708] jffs2: Write of 68 bytes at 0x0041b298 failed. returned -30, retlen 0
[ 6.736350] jffs2: Not marking the space at 0x0041b298 as dirty because the flash driver returned retlen zero
[ 6.746310] jffs2: Write of 68 bytes at 0x0041b298 failed. returned -30, retlen 0
[ 6.753781] jffs2: Not marking the space at 0x0041b298 as dirty because the flash driver returned retlen zero
/etc/init.d/rcS: line 27: /etc/init.d/S70initdir: not found
-/bin/sh: cd: line 20: can't cd to /mnt/data/app/
Sat Jan 3 20:45:57 UTC 1970
File update_ok not found!
oops! /mnt/data/app/Running not exists.
/mnt/udisk/FCZ740V3/force_update.txt is not exits. exit now.
[ 30.143475] jffs2: Erase at 0x004e0000 failed immediately: -EROFS. Is the sector locked?
[ 30.151584] jffs2: Erase at 0x004d0000 failed immediately: -EROFS. Is the sector locked?
[ 30.159678] jffs2: Erase at 0x004c0000 failed immediately: -EROFS. Is the sector locked?
[ 30.167770] jffs2: Erase at 0x004b0000 failed immediately: -EROFS. Is the sector locked?
[ 30.175859] jffs2: Erase at 0x004a0000 failed immediately: -EROFS. Is the sector locked?
[ 30.183938] jffs2: Erase at 0x00490000 failed immediately: -EROFS. Is the sector locked?
[ 30.192027] jffs2: Erase at 0x00480000 failed immediately: -EROFS. Is the sector locked?
[ 30.200150] jffs2: Erase at 0x00470000 failed immediately: -EROFS. Is the sector locked?
[ 30.208248] jffs2: Erase at 0x00460000 failed immediately: -EROFS. Is the sector locked?
[ 30.216339] jffs2: Erase at 0x00450000 failed immediately: -EROFS. Is the sector locked?
[ 30.224417] jffs2: Erase at 0x00440000 failed immediately: -EROFS. Is the sector locked?
[ 30.232507] jffs2: Erase at 0x00430000 failed immediately: -EROFS. Is the sector locked?
[ 30.240597] jffs2: Erase at 0x00420000 failed immediately: -EROFS. Is the sector locked?
[ 30.248687] jffs2: Erase at 0x00640000 failed immediately: -EROFS. Is the sector locked?
[ 30.256776] jffs2: Erase at 0x00630000 failed immediately: -EROFS. Is the sector locked?
[ 30.264855] jffs2: Erase at 0x00620000 failed immediately: -EROFS. Is the sector locked?
[ 30.272945] jffs2: Erase at 0x00610000 failed immediately: -EROFS. Is the sector locked?
[ 30.281035] jffs2: Erase at 0x00600000 failed immediately: -EROFS. Is the sector locked?
[ 30.289147] jffs2: Erase at 0x005f0000 failed immediately: -EROFS. Is the sector locked?
[ 30.297241] jffs2: Erase at 0x005e0000 failed immediately: -EROFS. Is the sector locked?
[ 30.305332] jffs2: Erase at 0x005d0000 failed immediately: -EROFS. Is the sector locked?
[ 30.313411] jffs2: Erase at 0x005c0000 failed immediately: -EROFS. Is the sector locked?
[ 30.321499] jffs2: Erase at 0x005b0000 failed immediately: -EROFS. Is the sector locked?
[ 30.329589] jffs2: Erase at 0x005a0000 failed immediately: -EROFS. Is the sector locked?
[ 30.337678] jffs2: Erase at 0x00590000 failed immediately: -EROFS. Is the sector locked?
[ 30.345767] jffs2: Erase at 0x00580000 failed immediately: -EROFS. Is the sector locked?
[ 30.353846] jffs2: Erase at 0x00570000 failed immediately: -EROFS. Is the sector locked?
[ 30.361935] jffs2: Erase at 0x00560000 failed immediately: -EROFS. Is the sector locked?
[ 30.370024] jffs2: Erase at 0x00550000 failed immediately: -EROFS. Is the sector locked?
[ 30.378113] jffs2: Erase at 0x00540000 failed immediately: -EROFS. Is the sector locked?
[ 30.386202] jffs2: Erase at 0x00530000 failed immediately: -EROFS. Is the sector locked?
[ 30.394279] jffs2: Erase at 0x00520000 failed immediately: -EROFS. Is the sector locked?
[ 30.402368] jffs2: Erase at 0x00510000 failed immediately: -EROFS. Is the sector locked?
[ 30.410456] jffs2: Erase at 0x00500000 failed immediately: -EROFS. Is the sector locked?
[ 30.418564] jffs2: Erase at 0x00050000 failed immediately: -EROFS. Is the sector locked?
[ 30.426668] jffs2: Erase at 0x00040000 failed immediately: -EROFS. Is the sector locked?
[ 30.434757] jffs2: Erase at 0x00030000 failed immediately: -EROFS. Is the sector locked?
[ 30.442856] jffs2: Erase at 0x00020000 failed immediately: -EROFS. Is the sector locked?
[ 30.450955] jffs2: Erase at 0x00010000 failed immediately: -EROFS. Is the sector locked?
[ 30.459086] jffs2: Erase at 0x00000000 failed immediately: -EROFS. Is the sector locked?
[ 30.467202] jffs2: Erase at 0x00060000 failed immediately: -EROFS. Is the sector locked?
[ 30.475304] jffs2: Erase at 0x00070000 failed immediately: -EROFS. Is the sector locked?
[ 30.483398] jffs2: Erase at 0x000d0000 failed immediately: -EROFS. Is the sector locked?
[ 30.491500] jffs2: Erase at 0x000c0000 failed immediately: -EROFS. Is the sector locked?
[ 30.499625] jffs2: Erase at 0x000b0000 failed immediately: -EROFS. Is the sector locked?
[ 30.507731] jffs2: Erase at 0x000a0000 failed immediately: -EROFS. Is the sector locked?
[ 30.515830] jffs2: Erase at 0x00090000 failed immediately: -EROFS. Is the sector locked?
[ 30.523917] jffs2: Erase at 0x00080000 failed immediately: -EROFS. Is the sector locked?
[ 30.532017] jffs2: Erase at 0x000e0000 failed immediately: -EROFS. Is the sector locked?
[ 30.545210] jffs2: Write of 1664 bytes at 0x0041b298 failed. returned -30, retlen 0
[ 30.552961] jffs2: Not marking the space at 0x0041b298 as dirty because the flash driver returned retlen zero
[ 30.562888] jffs2: Write of 1664 bytes at 0x0041b298 failed. returned -30, retlen 0
[ 30.570547] jffs2: Not marking the space at 0x0041b298 as dirty because the flash driver returned retlen zero
[ 30.580455] jffs2: Error writing new dnode: -30
[ 30.584987] jffs2: Error garbage collecting node at 00350000!
[ 30.590736] jffs2: No space for garbage collection. Aborting GC thread
[/quote]
bootcmd,bootargs分别是:
[quote]
bootcmd=sf probe 0 50000000; sf read 0x41000000 0x0F0000 0x10000; sf read 0x41010000 0x100000 0x600000; bootz 0x41010000 - 0x41000000
bootargs=console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:960k(uboot)ro,64k(dtb)ro,6M(kernel)ro,8M(rootfs)ro,-(appendfs) root=/dev/mtdblock3 rw rootfstype=jffs2 vt.global_cursor_default=0
[/quote]
请问这样有什么问题吗?
可以启动到shell, 显示/bin/busybox也正常, 就是不知道上面的错误是不是致命的?
看到这个了, 貌似 mkfs.jffs2太老??与kernel的驱动不匹配?
我重新下载了 mtd-utils 最新的源码,编译
wget http://git.infradead.org/mtd-utils.git/snapshot/6766178412934e29db12ff5e6663604c6e909c6e.tar.gz
tar xvf 6766178412934e29db12ff5e6663604c6e909c6e.tar.gz
cd mtd-utils-6766178/
./configure
./autogen.sh
sudo apt-get install liblzo2-dev
make -j2
生成了新的 mkfs.jffs2,
用这个命令产生4M的jffs2文件镜像
mtd-utils-6766178/mkfs.jffs2 -s 0x1000 -e 0x10000 -p 0x400000 -d rootfs_buildroot_lite/ -n -o jffs2.img
发现启动后基本正常。
更诡异的事情来了, 我就ubuntu14.04LTS 自带mkfs.jffs2建立4M的jffs2也搞定了,正常了.
那难道是mkfs.jffs2不能建立8M的jffs2文件,但是可以建立4M的jffs2文件?
ubuntu@ubuntu:$ mkfs.jffs2 -V
mkfs.jffs2: error!: revision 1.60hexing@ubuntu:$ mtd-utils-6766178/mkfs.jffs2 -V
mkfs.jffs2 (mtd-utils) 2.0.1
