楼主 #1 2019-11-15 22:12:42
awfans
已发帖子: 264
请问大家荔枝派网盘里面的 V3s TF卡 debian 桌面镜像有哪位朋友跑起来了?
我试了
lichee_zero-Debian-LXDE_800_alpha.dd
lichee_zero-mindX_alpha.dd
各种错误, 根本无法启动.
#2 2019-11-16 21:35:05
lalala
Re: 请问大家荔枝派网盘里面的 V3s TF卡 debian 桌面镜像有哪位朋友跑起来了?
我跑起来了,启动速度很快 lichee_zero-Debian-LXDE_800_alpha
楼主 #3 2019-11-16 21:42:50
awfans
已发帖子: 264
好, 我再换张卡试一下 lichee_zero-Debian-LXDE_800_alpha, 不明白再请教你.
楼主 #4 2019-11-16 22:39:34
awfans
已发帖子: 264
感谢二楼的 @lalala 朋友, 终于跑起来了, 默认账号是 root, 密码是 toortoor
楼主 #5 2019-11-16 22:55:31
awfans
已发帖子: 264
root@LicheePi:~# ps -Af
UID        PID  PPID  C STIME TTY          TIME CMD
root         1     0  0 08:05 ?        00:00:03 /sbin/init earlyprintk
root         2     0  0 08:05 ?        00:00:00 [kthreadd]
root         4     2  0 08:05 ?        00:00:00 [kworker/0:0H]
root         5     2  0 08:05 ?        00:00:00 [kworker/u2:0]
root         6     2  0 08:05 ?        00:00:00 [ksoftirqd/0]
root         7     2  0 08:05 ?        00:00:00 [rcu_sched]
root         8     2  0 08:05 ?        00:00:00 [rcu_bh]
root         9     2  0 08:05 ?        00:00:00 [migration/0]
root        10     2  0 08:05 ?        00:00:00 [lru-add-drain]
root        11     2  0 08:05 ?        00:00:00 [cpuhp/0]
root        12     2  0 08:05 ?        00:00:00 [kdevtmpfs]
root        13     2  0 08:05 ?        00:00:00 [netns]
root        14     2  0 08:05 ?        00:00:00 [oom_reaper]
root        15     2  0 08:05 ?        00:00:00 [writeback]
root        16     2  0 08:05 ?        00:00:00 [kcompactd0]
root        17     2  0 08:05 ?        00:00:00 [crypto]
root        18     2  0 08:05 ?        00:00:00 [bioset]
root        19     2  0 08:05 ?        00:00:00 [kblockd]
root        20     2  0 08:05 ?        00:00:00 [cfg80211]
root        22     2  0 08:05 ?        00:00:00 [watchdogd]
root        23     2  0 08:05 ?        00:00:00 [rpciod]
root        24     2  0 08:05 ?        00:00:00 [xprtiod]
root        25     2  0 08:05 ?        00:00:02 [kswapd0]
root        26     2  0 08:05 ?        00:00:00 [vmstat]
root        27     2  0 08:05 ?        00:00:00 [bioset]
root        28     2  0 08:05 ?        00:00:00 [nfsiod]
root        53     2  0 08:05 ?        00:00:00 [irq/23-sunxi-mm]
root        56     2  0 08:05 ?        00:00:00 [bioset]
root        57     2  0 08:05 ?        00:00:02 [mmcqd/0]
root        58     2  0 08:05 ?        00:00:00 [kworker/0:1H]
root        59     2  0 08:05 ?        00:00:00 [jbd2/mmcblk0p2-]
root        60     2  0 08:05 ?        00:00:00 [ext4-rsv-conver]
root        75     2  0 08:05 ?        00:00:00 [kworker/u2:1]
root        79     1  0 08:05 ?        00:00:00 /lib/systemd/systemd-journald
root        91     1  0 08:05 ?        00:00:00 /lib/systemd/systemd-udevd
root       217     1  0 08:06 ?        00:00:00 /usr/sbin/sshd -D
root       218     1  0 08:06 ?        00:00:00 /usr/sbin/NetworkManager --no-da
root       220     1  0 08:06 ?        00:00:00 /usr/sbin/ModemManager
root       223     1  0 08:06 ?        00:00:00 /usr/sbin/cron -f
root       225     1  0 08:06 ?        00:00:00 /lib/systemd/systemd-logind
message+   227     1  0 08:06 ?        00:00:00 /usr/bin/dbus-daemon --system --
root       237     1  0 08:06 ?        00:00:00 /usr/lib/policykit-1/polkitd --n
root       240     1  0 08:06 tty1     00:00:00 /sbin/agetty --noclear tty1 linu
root       244     1  0 08:06 ttyS0    00:00:00 /bin/login --
root       248     1  0 08:06 ?        00:00:00 /usr/sbin/lightdm
root       254   248  1 08:06 tty7     00:00:22 /usr/bin/X :0 -seat seat0 -auth
root       268   248  0 08:06 ?        00:00:00 lightdm --session-child 17 20
lightdm    272     1  0 08:06 ?        00:00:00 /lib/systemd/systemd --user
lightdm    275   272  0 08:06 ?        00:00:00 (sd-pam)
lightdm    278   268  1 08:06 ?        00:00:18 /usr/sbin/lightdm-gtk-greeter
root       285     1  0 08:06 ?        00:00:00 /lib/systemd/systemd --user
root       288   285  0 08:06 ?        00:00:00 (sd-pam)
root       293   244  0 08:06 ttyS0    00:00:00 -bash
root       298   248  0 08:06 ?        00:00:00 lightdm --session-child 13 20
root       303     2  0 08:16 ?        00:00:02 [kworker/0:2]
root       315     2  0 08:21 ?        00:00:00 [kworker/0:0]
root       316     2  0 08:26 ?        00:00:00 [kworker/0:1]
root       317   293  4 08:28 ttyS0    00:00:00 ps -Af
这个不知道怎么可以做到如此精简
root@LicheePi:~# df
Filesystem     1K-blocks   Used Available Use% Mounted on
/dev/root        1047676 906040     70368  93% /
devtmpfs           26812      0     26812   0% /dev
tmpfs              27324      0     27324   0% /dev/shm
tmpfs              27324   6668     20656  25% /run
tmpfs               5120      0      5120   0% /run/lock
tmpfs              27324      0     27324   0% /sys/fs/cgroup
/dev/mmcblk0p1     16334   4300     12034  27% /boot
tmpfs               5468      0      5468   0% /run/user/106
tmpfs               5468      0      5468   0% /run/user/0
楼主 #6 2019-11-17 16:18:28
awfans
已发帖子: 264
修改改这个文件 /etc/hostname 就可以把左上角的 LicheePi 改成你想要的名字了.
#7 2019-11-17 16:32:35
Jmhh247
已发帖子: 262
桌面能进去吗,我试了下进不去。(终端可以进)
看使用说明里有这句--“如果你需要测试桌面,请一定要挂载swap分区!!!!”
小白不知道怎么挂载swap分区,流下了没有技术的眼泪。。。
awfans wrote:
/files/members/713/QQ图片20191116223733.jpg
楼主 #8 2019-11-17 16:42:39
awfans
已发帖子: 264
lichee_zero-Debian-LXDE_800_alpha 烧这个固件默认就有桌面了, 不用手动 swap, 如何做到的,我还在研究中.
楼主 #9 2019-11-17 17:02:54
awfans
已发帖子: 264
#cat /etc/fstab:
/dev/mmcblk0p1 /boot vfat noatime 0 1
/dev/mmcblk0p2 / ext4 noatime 0 1
#/dev/mmcblk0p3 swap swap defaults 0 0
proc /proc proc defaults 0 0
root@licheepi:~# grep swap -r /etc/
/etc/init/networking.conf:    check_network_swap() {
/etc/init/networking.conf:        [ -e /proc/swaps ] || return 0
/etc/init/networking.conf:                log_warning_msg "not deconfiguring network interfaces: network swap still mounted."
/etc/init/networking.conf:        done < /proc/swaps
/etc/init.d/checkfs.sh:. /lib/init/swap-functions.sh
/etc/init.d/checkfs.sh:         # Execute swapon command again, in case there are lvm
/etc/init.d/checkfs.sh:         # or md swap partitions.  fsck can suck RAM.
/etc/init.d/checkfs.sh:         swaponagain 'lvm and md'
/etc/init.d/mountall.sh:. /lib/init/swap-functions.sh
/etc/init.d/mountall.sh:        # Execute swapon command again, in case we want to swap to
/etc/init.d/mountall.sh:        swaponagain 'swapfile'
/etc/init.d/mountall.sh:        # Remount tmpfs filesystems; with increased VM after swapon,
/etc/init.d/mountall.sh:        # mount a tmpfs on /tmp.  We can now also determine swap size
/etc/init.d/checkroot.sh:       # Activate the swap device(s) in /etc/fstab. This needs to be done
/etc/init.d/checkroot.sh:                       [ "$VERBOSE" = no ] || log_warning_msg "Not activating swap as requested via bootoption noswap."
/etc/init.d/checkroot.sh:                       if [ "$swap_on_lv" = yes ]
/etc/init.d/checkroot.sh:                               [ "$VERBOSE" = no ] || log_warning_msg "Not activating swap on logical volume."
/etc/init.d/checkroot.sh:                       elif [ "$swap_on_file" = yes ]
/etc/init.d/checkroot.sh:                               [ "$VERBOSE" = no ] || log_warning_msg "Not activating swap on swapfile."
/etc/init.d/checkroot.sh:                       log_action_begin_msg "Activating swap"
/etc/init.d/checkroot.sh:                       swapon -a -e >/dev/null 2>&1
/etc/init.d/checkroot.sh:                       log_daemon_msg "Activating swap"
/etc/init.d/checkroot.sh:                       swapon -a -v
/etc/init.d/checkroot.sh:       # If / is read-write or swap is enabled, this script have done
/etc/init.d/checkroot.sh:       swapon=false
/etc/init.d/checkroot.sh:       if [ -f /proc/swaps ] ; then
/etc/init.d/checkroot.sh:           if [ "$(cat /proc/swaps |grep -v ^Filename)" ] ; then
/etc/init.d/checkroot.sh:               swapon=true
/etc/init.d/checkroot.sh:       if [ true = "$rootrw" ] || [ true = "$swapon" ] ; then
/etc/init.d/umountfs:# Short-Description: Turn off swap and unmount all local file systems.
/etc/init.d/umountfs:   # swap, to avoid running out of memory if the tmpfs filesystems
/etc/init.d/umountfs:   # Deactivate swap
/etc/init.d/umountfs:           log_action_begin_msg "Deactivating swap"
/etc/init.d/umountfs:           swapoff -a >/dev/null
/etc/init.d/umountfs:           log_daemon_msg "Will now deactivate swap"
/etc/init.d/umountfs:           swapoff -a -v
/etc/init.d/networking:check_network_swap() {
/etc/init.d/networking:    [ -e /proc/swaps ] || return 0
/etc/init.d/networking:     log_warning_msg "not deconfiguring network interfaces: network swap still mounted."
/etc/init.d/networking:    done < /proc/swaps
/etc/init.d/networking: check_network_swap
/etc/fstab:#/dev/mmcblk0p3 swap swap defaults 0 0
/proc/swaps 这文件啥也没有:
root@licheepi:~# cat /proc/swaps
Filename
从上面看起来好像并没有启用 swap 文件.
楼主 #10 2019-11-17 17:35:43
awfans
已发帖子: 264
TF卡用的是晕哥同款金弓达32G: https://whycan.cn/t_3091.html#p26065
#11 2019-11-18 09:53:43
shaoxi2010
已发帖子: 399
跑debian桌面流畅不,有没有画面撕裂的现象呀?
#12 2019-11-18 13:12:56
Jmhh247
已发帖子: 262
我也能看到桌面,
问题是桌面只有个登陆框,我接了键盘,但是无法登陆进去,你能登陆桌面吗?
#13 2019-11-18 13:17:11
Jmhh247
已发帖子: 262
登陆桌面,我用的是root, 密码是 toortoor。
输入账号,点击输入密码框,就会重新载入桌面登陆框。。。我又测试先输入密码再输入账号,可以输入,但还是回到登陆框。
楼主 #14 2019-11-18 13:38:56
awfans
已发帖子: 264
公司和家里都没找到USB键盘, 所以没有来得及测试登陆呢。
楼主 #15 2019-11-18 21:15:43
awfans
已发帖子: 264
https://www.maketecheasier.com/enable-autologin-lightdm/
修改这个文件: /etc/lightdm/lightdm.conf
autologin-guest=false
autologin-user=root
autologin-user-timeout=0
就可以自动启动到桌面了
楼主 #16 2019-11-18 21:25:44
awfans
已发帖子: 264
太卡了, 卡成shit了.
楼主 #17 2019-11-18 22:21:14
awfans
已发帖子: 264
Debian GNU/Linux 8 awfans ttyS0
awfans login: [   15.660271] random: crng init done
[   25.520351] pcmanfm invoked oom-killer: gfp_mask=0x14200ca(GFP_HIGHUSER_MOVABLE), nodemask=0, order=0, oom_score_adj=0
[   25.531304] CPU: 0 PID: 311 Comm: pcmanfm Not tainted 4.10.2-licheepi-zero+ #15
[   25.538608] Hardware name: Allwinner sun8i Family
[   25.543348] [<c010e2fc>] (unwind_backtrace) from [<c010b098>] (show_stack+0x10/0x14)
[   25.551092] [<c010b098>] (show_stack) from [<c035abe4>] (dump_stack+0x84/0x98)
[   25.558318] [<c035abe4>] (dump_stack) from [<c01ee010>] (dump_header.constprop.4+0x6c/0x190)
[   25.566755] [<c01ee010>] (dump_header.constprop.4) from [<c01aca20>] (oom_kill_process+0x310/0x4fc)
[   25.575793] [<c01aca20>] (oom_kill_process) from [<c01acef4>] (out_of_memory+0xec/0x430)
[   25.583877] [<c01acef4>] (out_of_memory) from [<c01b13ac>] (__alloc_pages_nodemask+0xa64/0xa84)
[   25.592568] [<c01b13ac>] (__alloc_pages_nodemask) from [<c01d15b4>] (handle_mm_fault+0x718/0x9b0)
[   25.601437] [<c01d15b4>] (handle_mm_fault) from [<c0113cb4>] (do_page_fault+0x2b4/0x380)
[   25.609522] [<c0113cb4>] (do_page_fault) from [<c01012d8>] (do_DataAbort+0x3c/0xbc)
[   25.617171] [<c01012d8>] (do_DataAbort) from [<c010bedc>] (__dabt_usr+0x3c/0x40)
[   25.624556] Exception stack(0xc319dfb0 to 0xc319dff8)
[   25.629603] dfa0:                                     00000044 000000ff 00000044 b5ebe078
[   25.637772] dfc0: 0000007f b5396003 000000ff 0000033c b5b80000 b5b7e804 00001e00 000017fc
[   25.645938] dfe0: b6a29569 beeda4f0 b5ebc747 b5ebc748 80070030 ffffffff
[   25.652650] Mem-Info:
[   25.654946] active_anon:9777 inactive_anon:1043 isolated_anon:0
[   25.654946]  active_file:49 inactive_file:54 isolated_file:0
[   25.654946]  unevictable:0 dirty:0 writeback:0 unstable:0
[   25.654946]  slab_reclaimable:590 slab_unreclaimable:1281
[   25.654946]  mapped:139 shmem:1666 pagetables:221 bounce:0
[   25.654946]  free:229 free_pcp:4 free_cma:0
[   25.686918] Node 0 active_anon:39108kB inactive_anon:4172kB active_file:196kB inactive_file:216kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:556kB dirty:0kB writeback:0kB shmem:6664kB writeback_tmp:0kB unstable:0kB pages_scanned:1736 all_unreclaimable? yes
[   25.711157] Normal free:916kB min:924kB low:1152kB high:1380kB active_anon:39108kB inactive_anon:4172kB active_file:196kB inactive_file:216kB unevictable:0kB writepending:0kB present:64036kB managed:54652kB mlocked:0kB slab_reclaimable:2360kB slab_unreclaimable:5124kB kernel_stack:632kB pagetables:884kB bounce:0kB free_pcp:16kB local_pcp:16kB free_cma:0kB
[   25.742568] lowmem_reserve[]: 0 0 0
[   25.746075] Normal: 83*4kB (UE) 73*8kB (UE) 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 916kB
[   25.757229] 1773 total pagecache pages
[   25.760978] 0 pages in swap cache
[   25.764288] Swap cache stats: add 0, delete 0, find 0/0
[   25.769521] Free swap  = 0kB
[   25.772396] Total swap = 0kB
[   25.775287] 16009 pages RAM
[   25.778076] 0 pages HighMem/MovableOnly
[   25.781904] 2346 pages reserved
[   25.785053] [ pid ]   uid  tgid total_vm      rss nr_ptes nr_pmds swapents oom_score_adj name
[   25.793586] [   80]     0    80     1845      175       6       0        0             0 systemd-journal
[   25.803078] [   91]     0    91     2446      108       5       0        0         -1000 systemd-udevd
[   25.812390] [  217]     0   217     1635      115       8       0        0         -1000 sshd
[   25.820923] [  218]     0   218    12499      313      15       0        0             0 NetworkManager
[   25.830319] [  220]     0   220     9653      338      12       0        0             0 ModemManager
[   25.839543] [  221]     0   221      714       47       5       0        0             0 cron
[   25.848074] [  225]     0   225      774       66       4       0        0             0 systemd-logind
[   25.857471] [  227]   105   227     1177      111       6       0        0          -900 dbus-daemon
[   25.866609] [  237]     0   237     8394      139      10       0        0             0 polkitd
[   25.875399] [  239]     0   239      496       30       5       0        0             0 agetty
[   25.884087] [  244]     0   244      451       29       4       0        0             0 agetty
[   25.892793] [  249]     0   249    10405      133      12       0        0             0 lightdm
[   25.901583] [  255]     0   255     8148     1385      16       0        0             0 Xorg
[   25.910112] [  268]     0   268     6676      150      11       0        0             0 lightdm
[   25.918901] [  276]     0   276     1031      173       5       0        0             0 systemd
[   25.927690] [  279]     0   279     1570      346       5       0        0             0 (sd-pam)
[   25.936566] [  282]     0   282     6219      230      12       0        0             0 lxsession
[   25.945529] [  297]     0   297      728       49       4       0        0             0 ssh-agent
[   25.954478] [  306]     0   306     4222      377      12       0        0             0 openbox
[   25.963269] [  308]     0   308     6370      219      12       0        0             0 lxpolkit
[   25.972147] [  310]     0   310     9938      513      17       0        0             0 lxpanel
[   25.980935] [  311]     0   311     9087     4005      21       0        0             0 pcmanfm
[   25.989724] [  318]     0   318      728       49       5       0        0             0 ssh-agent
[   25.998688] [  322]     0   322     3527       65       6       0        0             0 menu-cached
[   26.007841] Out of memory: Kill process 311 (pcmanfm) score 285 or sacrifice child
[   26.015442] Killed process 311 (pcmanfm) total-vm:36348kB, anon-rss:16004kB, file-rss:16kB, shmem-rss:0kB
[   26.609096] oom_reaper: reaped process 311 (pcmanfm), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
发现一启动就出现爆内存错误.
然后我把TF卡插回电脑ubuntu, 用gparted添加一个128M swap分区,
修改 /etc/fstab
重新插入V3s启动:
[    3.546466] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    4.568043] Adding 131068k swap on /dev/mmcblk0p3.  Priority:-1 extents:1 across:131068k SS
[    4.637629] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
现在没有内存错误了.
楼主 #18 2019-11-18 22:23:17
awfans
已发帖子: 264
花了10分钟, 在荔枝派zero V3s 上面把 debian firefox 启动了
cpu占用率 100%
#19 2019-11-19 08:36:59
Jmhh247
已发帖子: 262
赞,太好了,晚上我也试试,
能详细说说T卡怎么--“用gparted添加一个128M swap分区”吗
awfans wrote:
现在没有内存错误了.
楼主 #20 2019-11-19 09:03:28
awfans
已发帖子: 264
@Jmhh247 记得按17楼修改 /etc/fstab 文件, 然后看Linux启动日志,有没有启用swap分区。
楼主 #21 2019-11-19 09:05:40
awfans
已发帖子: 264
https://www.raspberrypi.org/forums/viewtopic.php?t=120785
http://blog.davidou.org/archives/1018
现在我想把屏幕旋转 90/270度, 死活没搞定, 参考上面两个链接, 修改 /boot/config.txt
display_rotate=1
lcd_rotate=1
这两种设置都不行。
#22 2019-11-19 09:11:33
jimmy
已发帖子: 316
腾讯的QQ能跑吗,我不在乎时间,一个小时能加载起来我也能忍受。
#23 2019-11-19 09:41:48
Jmhh247
已发帖子: 262
awfans wrote:
/files/members/713/2019-11-19_085543.png
/files/members/713/2019-11-19_085624.png
多谢楼主!
题外话,我给ubuntu扩展硬盘容量也是用gparted,记得需要先建扩展分区,然后在扩展分区上建swap分区。
这个T卡的swap分区似乎是直接建立的,不需要扩展分区。
#24 2019-11-19 09:44:10
Jmhh247
已发帖子: 262
一个小。。。。。。时,比。。。闪电。。。还。。。。慢。。。。,大佬你想干啥
#25 2019-11-19 10:30:35
夏雨夜寐
已发帖子: 85
大佬想找个理由睡一觉……你看,我在等--它。启。。动。。。
#26 2019-11-19 21:03:37
Jmhh247
已发帖子: 262
可以进桌面了。
发现只有usb 网卡
root@LicheePi:~# ifconfig
          collisions:0 txqueuelen:1000
usb0      Link encap:Ethernet  HWaddr 8a:65:31:29:92:d0
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
root@LicheePi:~# ifconfig eth0 up
eth0: ERROR while getting interface flags: No such device
root@LicheePi:~#
#27 2019-11-19 21:19:45
已发帖子: 9,473
可能当时驱动不支持 ethernet
#28 2020-01-09 07:15:36
红白机
已发帖子: 133
好帖, debian要收藏.
#29 2021-07-28 11:07:25
skywalk00
已发帖子: 20
各位大侠好!能否给个镜像的下载地址,谢谢!
#30 2021-07-29 17:16:39
xiaoqianxiansheng
已发帖子: 35
  • 不通过:与技术无关
#31 2021-08-02 14:49:18
kangkoo
Sipeed官方下载地址:V3s的镜像
应该在这里。
#32 2021-08-06 09:09:22
skywalk00
已发帖子: 20
kangkoo wrote:
Sipeed官方下载地址:V3s的镜像
应该在这里。
非常感谢!我以前试过lichee_zero-test-Debian-LXDE.tar.bz2这个镜像,发现可以用,只是只可以看到登录框,输入账号和密码也不能进入,是不是储存卡的问题?我用的是金士顿16G内存卡。
#33 2022-03-07 21:57:26
regestday
你们都不卡吗?
#34 2022-03-08 08:12:03
鳝丝与螺丝
所在地: 苏州 初一的
regestday wrote:
你们都不卡吗?
应该是很卡的,我还没试过
#35 2022-05-26 04:55:56
forever_rainy
已发帖子: 21
我试过xfce桌面,不需要输入密码直接登录,不过手里只有240*280的st7789屏幕,显示不全,看起来很难受,操作起来卡顿很多,点开文件管理这种也是要卡顿的,不过也不是不能用。。。
