楼主 #1 2020-02-19 09:40:34
pythinker
已发帖子: 215
python3.7 使用 pip 命令已经不能安装 PyQt4 软件包了, 记录下载文件手动安装过程.
E:\Python37>E:\Python37\python.exe -m pip install PyQt4
Collecting PyQt4
  Could not find a version that satisfies the requirement PyQt4 (from versions:)
No matching distribution found for PyQt4
显示PyQt4 不在服务器上了, 安装 PyQt5 是正常的。
楼主 #2 2020-02-19 09:43:23
pythinker
已发帖子: 215
Re: python3.7 使用 pip 命令已经不能安装 PyQt4 软件包了, 记录下载文件手动安装过程.
打开 https://www.lfd.uci.edu/~gohlke/pythonlibs/
找到
PyQt4 (discontinued): a set of bindings for the Qt4 application framework.
Requires write access to the site-packages\PyQt4 folder to create qt.conf.
PyQt4‑4.11.4‑cp37‑cp37m‑win_amd64.whl
PyQt4‑4.11.4‑cp37‑cp37m‑win32.whl
PyQt4‑4.11.4‑cp36‑cp36m‑win_amd64.whl
PyQt4‑4.11.4‑cp36‑cp36m‑win32.whl
PyQt4‑4.11.4‑cp35‑cp35m‑win_amd64.whl
PyQt4‑4.11.4‑cp35‑cp35m‑win32.whl
PyQt4‑4.11.4‑cp34‑cp34m‑win_amd64.whl
PyQt4‑4.11.4‑cp34‑cp34m‑win32.whl
PyQt4‑4.11.4‑cp27‑cp27m‑win_amd64.whl
PyQt4‑4.11.4‑cp27‑cp27m‑win32.whl
我下载的是第一个: https://download.lfd.uci.edu/pythonlibs/s2jqpv5t/PyQt4-4.11.4-cp37-cp37m-win_amd64.whl
安装:
E:\Python37>E:\Python37\python.exe -m pip install D:\Downloads\PyQt4-4.11.4-cp37-cp37m-win_amd64.whl
Processing d:\downloads\pyqt4-4.11.4-cp37-cp37m-win_amd64.whl
Installing collected packages: PyQt4
Successfully installed PyQt4-4.11.4
楼主 #3 2020-02-19 09:56:23
pythinker
已发帖子: 215
来一个测试程序:
import sys
from PyQt4 import QtCore, QtGui
if __name__ == "__main__":
    app = QtGui.QApplication(sys.argv)
    label = QtGui.QLabel("Hello World")
    label.show()
    sys.exit(app.exec_())
楼主 #4 2020-02-19 10:12:21
pythinker
已发帖子: 215
import sys
from PyQt4 import QtGui
def main():
    w = QtGui.QWidget()
    w.resize(250, 150)
    w.move(300, 300)
    w.setWindowTitle('Simple')
    w.addWidget(label)
    w.show()
if __name__ == '__main__':
    main()
楼主 #5 2020-02-19 10:22:10
pythinker
已发帖子: 215
import sys
class Example(QtGui.QWidget):
    def __init__(self):
        super(Example, self).__init__()
        self.initUI()
    def initUI(self):
        QtGui.QToolTip.setFont(QtGui.QFont('SansSerif', 10))
        self.setToolTip('This is a <b>QWidget</b> widget')
        btn = QtGui.QPushButton('Button', self)
        btn.setToolTip('This is a <b>QPushButton</b> widget')
        btn.resize(btn.sizeHint())
        btn.move(50, 50)
        self.setGeometry(300, 300, 250, 150)
        self.setWindowTitle('Tooltips')
        self.show()
def main():
    ex = Example()
    main()
参考: http://zetcode.com/gui/pyqt4/firstprograms/
