楼主 #1 2020-01-14 22:25:07
haidao
分享一个tiny200 rtt+awtk 800x480 5寸电阻屏固件,跑的是awtk图表那个demo
固件下载: tiny200_rtt_awtk_800x480_w25q128_ns2009.rar
Copy Flash offset 1M to RAM 0x8000000 size:2508352
Copy Flash Ok!
Check Image Crc32:3055548643
Image OK, Goto 0x80000000 ...
- RT -     Thread Operating System
 / | \     4.0.2 build Jan 14 2020
 2006 - 2019 Copyright by rt-thread team
[SFUD] Find a Winbond flash chip. Size is 16777216 bytes.
[SFUD] W25Q128 flash device is initialize success.
clk_divider_set_rate 0 198000000 0
[I/I2C] I2C bus [i2c0] registered
periph_get_pll_clk:600000000
cpu_get_clk:408000000
ahb_get_clk:200000000
apb_get_clk:100000000
[D/FAL] (fal_flash_init:61) Flash device |                  W25Q128 | addr: 0x00000000 | len: 0x01000000 | blk_size: 0x00001000 |initialized finish.
[I/FAL] ==================== FAL partition table ====================
[I/FAL] | name     | flash_dev |   offset   |    length  |
[I/FAL] -------------------------------------------------------------
[I/FAL] | Littlefs | W25Q128   | 0x00600000 | 0x00a00000 |
[I/FAL] =============================================================
[I/FAL] RT-Thread Flash Abstraction Layer (V0.4.0) initialize success.
[I/FAL] The FAL MTD NOR device (Littlefs) created successfully
msh />[E/MMC] [err]:0x00000100,  RTO
[E/MMC] mmc cmd 5 err
[I/SDIO] SD card capacity 1931264 KB.
msh />ls
Directory /:
flash               <DIR>
mmc                 <DIR>
usb                 <DIR>
info.txt            41
msh />
msh />ls /mmc
Directory /mmc:
INFO.TXT            41
bcm.bin             80896
ip.bin              252176
f1c200              <DIR>
msh />ls /flash
Directory /flash:
ts_lib.dat          105
msh />
msh />ps
thread   pri  status      sp     stack size max used left tick  error
aw_lp      6  suspend 0x00000138 0x00000800    23%   0x00000014 000
awtk       7  suspend 0x00000100 0x00010000    14%   0x00000007 000
tshell    20  running 0x00000210 0x00002000    14%   0x00000002 000
mmcsd_de  22  suspend 0x0000009c 0x00000400    49%   0x00000005 000
tidle0    31  ready   0x00000050 0x00000100    34%   0x00000013 000
msh />free
total memory: 53512944
used memory : 3151892
maximum allocated memory: 3160312
msh />list_device
device           type         ref count
sd0      Block Device         1
Littlefs MTD Device           1
i2c0     I2C Bus              1
gpio     Miscellaneous Device 0
lcd      Graphic Device       0
W25Q128  Block Device         0
spi00    SPI Device           0
spi0     SPI Bus              0
uart2    Character Device     0
uart0    Character Device     2
msh />
msh />
上电后先进行屏幕校准,校准完成后自动运行awtk的图表demo, enjoy it !!!
最近编辑记录 haidao (2020-01-14 22:26:45)
楼主 #2 2020-01-15 11:27:07
haidao
Re: 分享一个tiny200 rtt+awtk 800x480 5寸电阻屏固件,跑的是awtk图表那个demo
补个靓照
#3 2020-01-15 11:54:36
已发帖子: 9,473
挺好看的, 感谢分享!
#4 2020-01-15 21:58:27
sea18c
坑网有你更精彩!
#5 2020-01-15 22:29:36
顶!
#6 2020-01-16 08:10:21
已发帖子: 9,473
感谢分享!
#7 2020-01-20 17:41:38
wlcccccc
感谢分享!
#8 2020-02-12 20:29:44
guzhengstar
已发帖子: 26
5寸480*272显示不全
#9 2020-02-12 20:30:32
guzhengstar
已发帖子: 26
不过固件整理挺好 刷机挺方便
#10 2020-03-05 11:24:15
SZYDXDL
楼主能否 描述一下 开发环境的配置,我想了解一下,谢谢!
#11 2020-03-05 16:33:59
ayuanshop
哇。。。。这是个好东西,,,要是有工程就更好啦。。。。
#12 2020-03-05 22:44:21
asd7893361
已发帖子: 34
谢谢分享!
#13 2020-03-05 23:18:46
asd7893361
已发帖子: 34
厉害了
#14 2020-03-06 22:08:22
polestar
真的很棒
您还可以发布源代码吗?
#15 2020-03-09 09:09:10
关注
#16 2020-04-23 17:38:07
kdtcf
了解一下AWTK,争取抛弃emwin
#17 2020-04-23 21:27:38
雷鹏
我触摸是 NS2009 怎么不能校准啊?
#18 2020-04-24 10:41:46
guzhengstar
已发帖子: 26
自己要移植校准库
#19 2020-04-24 16:03:19
雷鹏
要怎么移植啊
最近编辑记录 雷鹏 (2020-04-24 16:03:32)
#20 2020-04-27 11:06:02
在路上
厉害,关注中,要是有移植参考就好了
#21 2020-04-30 16:21:47
tesln
点赞, 感谢楼主分享宝贵资源,测试下我新买的Tiny200
#22 2020-05-09 13:41:05
苍狼青雯
已发帖子: 0
感谢楼主分享,新买的Tiny200,正好下载下来测试一下
#23 2020-05-09 15:42:43
gzc1017
正在学习全志F1C100S 正有用 谢谢
#24 2020-05-09 17:36:46
fengqwe
感谢楼主分享,烧写到Tiny200,可以正常运行
#25 2020-05-16 10:41:11
huangjian276310465
我也正在使用AWTK 整体感觉效果还不错,项目开发文档和测试用例也很丰富
#26 2020-05-16 16:54:07
tianyekpsexzxg
AWTK 整体感觉效果还可以,资料也丰富,有空试一下在100S上
#27 2020-05-18 23:51:57
zhiha258
提供源码吧
#28 2020-06-22 21:49:39
qmsolo2004
感谢分享!
#29 2020-06-24 09:28:58
namcoo
已发帖子: 0
界面很漂亮,,感谢分享。有空写到F1C200S 试试
#30 2020-07-07 08:37:08
逗倪豌儿
已发帖子: 23
楼主能否分享下固件的的源码,可以上传到git,共同学习下
Copy Flash Ok!
msh />ls
Directory /:
flash               <DIR>
mmc                 <DIR>
usb                 <DIR>
info.txt            41
msh />
msh />ls /mmc
Directory /mmc:
INFO.TXT            41
bcm.bin             80896
ip.bin              252176
f1c200              <DIR>
msh />ls /flash
Directory /flash:
ts_lib.dat          105
msh />
msh />ps
msh />free
msh />list_device
sd0      Block Device         1
i2c0     I2C Bus              1
spi00    SPI Device           0
spi0     SPI Bus              0
msh />
msh />
#31 2020-07-07 15:29:45
Bill123
已发帖子: 0
感谢分享!
#32 2020-07-07 16:13:45
chaoge131
#33 2020-08-05 14:21:40
逗倪豌儿
已发帖子: 23
你好,我移植awtk到f1c+rtthread上,编译的时候没有问题,链接的时候遇见问题
省略n行
CC build\AWTK\awtk-port\lcd_f1cxx.o
CC build\AWTK\awtk-port\main_loop_f1cxx.o
CC build\AWTK\awtk-port\platform.o
LINK rtthread.elf
Error in calling command:arm-none-eabi-g++
Exception: Invalid argument
scons: *** [rtthread.elf] Error 22
scons: building terminated because of errors.
还有个问题awtk-port里面的和f1c显示对接的那几个函数怎么写?
#34 2021-11-16 13:03:28
smiletiger
已发帖子: 127
非常不错,不知道有没有人移植touchgfx到f1c100s上
#35 2022-05-12 16:26:57
huangyubin
  • 不通过:其他
#38 2022-10-30 20:31:53
DEQ
已发帖子: 30
早点看到这个帖子就好了,我的NAND FLASH的问题还没改好
#39 2022-10-31 22:15:28
DEQ
已发帖子: 30
下到我的荔枝派了,触摸好像有问题偏差很大,图形图像显示的挺好的
最近编辑记录 DEQ (2022-10-31 22:16:45)
