今日翻出widora-neo开发板,试试编译主线openwrt,发现启动卡住,不能进入shell...
感觉是flash驱动的原因,不知有没大佬遇到类似情况
Widora by mango,V1.0.6
Board: Ralink APSoC DRAM: 128 MB
relocate_code Pointer at: 87fb4000
Software System Reset Occurred
flash manufacture id: ef, device id 40 18
find flash: W25Q128BV
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM component: 1024 Mbits DDR, width 16
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
Date:Aug 10 2016 Time:21:39:21
icache: sets:512, ways:4, linesz:32 ,total:65536
dcache: sets:256, ways:4, linesz:32 ,total:32768
##### The CPU freq = 575 MHZ ####
estimate memory size =128 Mbytes
RESET MT7628 PHY!!!!!!MT7688 gpio init : wled and wdt by mango
if you press the WPS button for more than 2 seconds will automatically enter the Update mode,more than 7 seconds enter gpio test mode
0
1
2
3
4
5
6
7
8
9
Continuing normal boot...
Please choose the operation:
1: Load system code to SDRAM via TFTP.
2: Load system code then write to Flash via TFTP.
3: Boot system code via Flash (default).
4: Entr boot command line interface.
5: Entr ALL LED test mode.
6: Entr Web failsafe mode.
7: Load Boot Loader code then write to Flash via Serial.
9: Load Boot Loader code then write to Flash via TFTP. 0
3: System Boot system code via Flash.
## Booting image at bc050000 ...
Image Name: MIPS OpenWrt Linux-4.14.169
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 1672728 Bytes = 1.6 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
No initrd
## Transferring control to Linux (at address 80000000) ...
## Giving linux memsize in MB, 128
[ 0.000000] Linux version 4.14.169 (root@ubuntu) (gcc version 8.3.0 (OpenWrt GCC 8.3.0 r12261-d1130ad)) #0 Fri Feb 21 21:35:12 2020
[ 0.000000] Board has DDR2
[ 0.000000] Analog PMU set to hw control
[ 0.000000] Digital PMU set to hw control
[ 0.000000] SoC Type: MediaTek MT7688 ver:1 eco:2
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
[ 0.000000] MIPS: machine is Widora-NEO (16M)
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] random: get_random_bytes called from start_kernel+0x98/0x4a0 with crng_init=0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32480
[ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00038f60
[ 0.000000] Readback ErrCtl register=00038f60
[ 0.000000] Memory: 123280K/131072K available (3918K kernel code, 182K rwdata, 896K rodata, 1204K init, 205K bss, 7792K reserved, 0K cma-reserved)
[ 0.000000] NR_IRQS: 256
[ 0.000000] intc: using register map from devicetree
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] timer_probe: no matching timers found
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
[ 0.000013] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[ 0.007536] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[ 0.073501] pid_max: default: 32768 minimum: 301
[ 0.078257] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.084614] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098253] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.107760] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.113749] pinctrl core: initialized pinctrl subsystem
[ 0.119878] NET: Registered protocol family 16
[ 0.154336] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.160018] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.165530] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.176052] clocksource: Switched to clocksource MIPS
[ 0.182260] NET: Registered protocol family 2
[ 0.187331] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.194024] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.200215] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.206481] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.212082] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.218522] NET: Registered protocol family 1
[ 0.226584] Crashlog allocated RAM at address 0x3f00000
[ 0.233417] workingset: timestamp_bits=14 max_order=15 bucket_order=1
[ 0.246962] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.252539] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.275421] io scheduler noop registered
[ 0.279223] io scheduler deadline registered (default)
[ 0.285019] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.292363] console [ttyS0] disabled
[ 0.295805] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.304586] console [ttyS0] enabled
[ 0.311590] bootconsole [early0] disabled
[ 0.320365] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.329979] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.340417] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.362775] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.367629] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.374069] Creating 4 MTD partitions on "spi0.0":
[ 0.378955] 0x000000000000-0x000000030000 : "u-boot"
[ 0.384960] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.391287] 0x000000040000-0x000000050000 : "factory"
[ 0.397413] 0x000000050000-0x000001000000 : "firmware"
[ 0.406738] 2 uimage-fw partitions found on MTD device firmware
[ 0.412753] Creating 2 MTD partitions on "firmware":
[ 0.417847] 0x000000000000-0x000000198658 : "kernel"
[ 0.423836] 0x000000198658-0x000000fb0000 : "rootfs"
[ 0.429762] mtd: device 5 (rootfs) set to be root filesystem
[ 0.437259] 1 squashfs-split partitions found on MTD device rootfs
[ 0.443536] Creating 1 MTD partitions on "rootfs":
[ 0.448458] 0x0000002379a8-0x000000e179a8 : "rootfs_data"
[ 0.455878] libphy: Fixed MDIO Bus: probed
[ 0.471525] rt3050-esw 10110000.esw: link changed 0x00
[ 0.478465] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[ 0.488783] NET: Registered protocol family 10
[ 0.497874] Segment Routing with IPv6
[ 0.501708] NET: Registered protocol family 17
[ 0.506362] 8021q: 802.1Q VLAN Support v1.8
[ 0.517645] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.531543] Freeing unused kernel memory: 1204K
[ 0.536170] This architecture does not have kernel memory protection.
[ 1.271959] init: Console is alive
[ 1.275663] init: - watchdog -
[ 2.236100] random: fast init done
[ 2.435398] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 2.565565] usbcore: registered new interface driver usbfs
[ 2.571328] usbcore: registered new interface driver hub
[ 2.576877] usbcore: registered new device driver usb
[ 2.588572] exFAT: Version 1.2.9
[ 2.601381] JFS: nTxBlock = 972, nTxLock = 7780
[ 2.614778] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.623366] ehci-platform: EHCI generic platform driver
[ 2.639085] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 2.645889] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 2.651217] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 2.657119] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 2.665272] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 2.696078] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 2.703517] hub 1-0:1.0: USB hub found
[ 2.707870] hub 1-0:1.0: 1 port detected
[ 2.715363] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.723531] ohci-platform: OHCI generic platform driver
[ 2.729193] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 2.736151] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 2.744271] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 2.821177] hub 2-0:1.0: USB hub found
[ 2.825502] hub 2-0:1.0: 1 port detected
[ 2.833088] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 2.851018] init: - preinit -
[ 4.055839] rt3050-esw 10110000.esw: link changed 0x00
Press the [f] key and hit [enter] to enter failsafe mode
Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
[ 8.248467] rt3050-esw 10110000.esw: link changed 0x01
[ 8.305860] mount_root: jffs2 not ready yet, using temporary tmpfs overlay
[ 8.345129] urandom-seed: Seed file not found (/etc/urandom.seed)
[ 8.479867] procd: - early -
[ 8.482907] procd: - watchdog -
[ 9.212368] procd: - watchdog -
[ 9.215915] procd: - ubus -
[ 9.318572] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.325816] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.332919] random: ubusd: uninitialized urandom read (4 bytes read)
[ 9.340544] procd: - init -
Please press Enter to activate this console.
[ 10.143120] kmodloader: loading kernel modules from /etc/modules.d/*
[ 10.217603] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 10.239857] Loading modules backported from Linux version v5.4-rc8-0-gaf42d3466bdc
[ 10.247614] Backport generated by backports.git v5.4-rc8-1-0-g368e8c51
[ 10.278981] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 10.304287] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[ 10.445472] xt_time: kernel timezone is -0000
[ 10.586690] mt76_wmac 10300000.wmac: ASIC revision: 76280001
[ 10.671518] urngd: v1.0.2 started.
[ 10.873865] random: crng init done
[ 10.877356] random: 7 urandom warning(s) missed due to ratelimiting
[ 11.628204] mt76_wmac 10300000.wmac: Firmware Version: 20151201
[ 11.634225] mt76_wmac 10300000.wmac: Build Time: 20151201183641
[ 11.676068] mt76_wmac 10300000.wmac: firmware init done
[ 11.891925] PPP generic driver version 2.4.2
[ 11.917182] NET: Registered protocol family 24
[ 11.932445] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 27.796972] rt3050-esw 10110000.esw: link changed 0x00
[ 29.836569] jffs2_scan_eraseblock(): End of filesystem marker found at 0x0
[ 29.843594] jffs2_build_filesystem(): unlocking the mtd device...
[ 29.856115] done.
[ 29.864342] jffs2_build_filesystem(): erasing all blocks after the end marker...
[ 29.864386] jffs2: Erase at 0x00bd0000 failed immediately: errno -22
[ 32.035467] rt3050-esw 10110000.esw: link changed 0x01
[ 34.348859] br-lan: port 1(eth0) entered blocking state
[ 34.354173] br-lan: port 1(eth0) entered disabled state
[ 34.359892] device eth0 entered promiscuous mode
[ 34.415166] br-lan: port 1(eth0) entered blocking state
[ 34.420547] br-lan: port 1(eth0) entered forwarding state
[ 34.426276] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 35.376187] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 89.749292] done.
[ 89.751299] jffs2: notice: (1082) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 89.914802] overlayfs: upper fs does not support tmpfile.离线
看着问题不大,看样子敲回车应该会激活命令交互
谢谢mango的回复。今天开电脑又试了试,是没问题的:D。。。估计是putty的原因,之前敲回车没反应
主要是widora官方的openwrt声卡驱动有点问题,准备试试主线的有没问题
openwrt(widora-neo)使用portaudio播放音频,出现多次调用postinit(),伴有杂音,偶尔会造成系统奔溃
终端软件的流控一定要关掉,其他没什么注意的了:)
跑是能跑起来了,但从U盘拷贝文件到本地,重启后,老是莫名奇妙的丢失文件,或者文件大小自己变小了...
感觉哪里没有设置对,导致文件系统有问题
启动log里面,kernel+rootfs分区好像不大对.正常来说应该从firmware分区的0x50000开始自动分区,但这里显示是从0x0开始。
[ 0.450902] 2 uimage-fw partitions found on MTD device firmware
[ 0.456916] Creating 2 MTD partitions on "firmware":
[ 0.462027] 0x000000000000-0x0000001baeb2 : "kernel"
[ 0.468108] 0x0000001baeb2-0x000000fb0000 : "rootfs"关于jffs2的log:
root@OpenWrt:/mnt/usb# dmesg | grep jffs2
[ 0.283821] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 9.198050] jffs2: notice: (453) jffs2_build_xattr_subsystem: complete building xattr subsystem, 6 of xdatum (3 unchecked, 3 orphan) and 10 of xref (3 dead, 0 orphan) found.
[ 9.215573] mount_root: switching to jffs2 overlay
[ 60.033694] jffs2: Erase at 0x00830000 failed immediately: errno -22
[ 60.333680] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f6f18. {ffff,ffff,ffffffff,ffffffff}
[ 60.347235] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f63fc. {ffff,ffff,ffffffff,ffffffff}
[ 60.361339] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f5784. {ffff,ffff,ffffffff,ffffffff}
[ 60.376280] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f4b70. {ffff,ffff,ffffffff,ffffffff}
[ 60.389267] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f3eec. {ffff,ffff,ffffffff,ffffffff}
[ 60.404380] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f3290. {ffff,ffff,ffffffff,ffffffff}
[ 60.417355] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f26b4. {ffff,ffff,ffffffff,ffffffff}
[ 60.432495] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f1b24. {ffff,ffff,ffffffff,ffffffff}
[ 60.445325] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f0f64. {ffff,ffff,ffffffff,ffffffff}
[ 60.460436] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f031c. {ffff,ffff,ffffffff,ffffffff}
[ 60.473391] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f000c. {ffff,ffff,ffffffff,ffffffff}
root@OpenWrt:/mnt/usb#完整的启动log:
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat 8054e050, node_mem_map 81000040
[ 0.000000] Normal zone: 288 pages used for memmap
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Writing ErrCtl register=00038f61
[ 0.000000] Readback ErrCtl register=00038f61
[ 0.000000] Memory: 122820K/131072K available (4290K kernel code, 193K rwdata, 952K rodata, 1212K init, 217K bss, 8252K reserved, 0K cma-reserved)
[ 0.000011] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
[ 0.007542] Calibrating delay loop... 385.84 BogoMIPS (lpj=1929216)
[ 0.073500] pid_max: default: 32768 minimum: 301
[ 0.078236] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.084586] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098213] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.107725] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.113713] pinctrl core: initialized pinctrl subsystem
[ 0.119822] NET: Registered protocol family 16
[ 0.157368] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.163027] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.168576] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.175450] Bluetooth: Core ver 2.22
[ 0.178933] NET: Registered protocol family 31
[ 0.183155] Bluetooth: HCI device and connection manager initialized
[ 0.189363] Bluetooth: HCI socket layer initialized
[ 0.194009] Bluetooth: L2CAP socket layer initialized
[ 0.198910] Bluetooth: SCO socket layer initialized
[ 0.207594] clocksource: Switched to clocksource MIPS
[ 0.213763] NET: Registered protocol family 2
[ 0.218810] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.225504] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.231691] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.237958] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.243558] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.249977] NET: Registered protocol family 1
[ 0.254156] PCI: CLS 0 bytes, default 32
[ 0.258021] Crashlog allocated RAM at address 0x3f00000
[ 0.264778] workingset: timestamp_bits=14 max_order=15 bucket_order=1
[ 0.278247] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.311618] jitterentropy: Initialization failed with host not compliant with requirements: 2
[ 0.320088] io scheduler noop registered
[ 0.323815] io scheduler deadline registered (default)
[ 0.329782] Serial: 8250/16550 driver, 3 ports, IRQ sharing disabled
[ 0.337086] console [ttyS0] disabled
[ 0.340599] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.349332] console [ttyS0] enabled
[ 0.356321] bootconsole [early0] disabled
[ 0.365090] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.374729] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.385203] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.407136] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.412005] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.418462] Creating 4 MTD partitions on "spi0.0":
[ 0.423334] 0x000000000000-0x000000030000 : "u-boot"
[ 0.429395] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.435633] 0x000000040000-0x000000050000 : "factory"
[ 0.441722] 0x000000050000-0x000001000000 : "firmware"
[ 0.473950] mtd: device 5 (rootfs) set to be root filesystem
[ 0.481382] 1 squashfs-split partitions found on MTD device rootfs
[ 0.487711] Creating 1 MTD partitions on "rootfs":
[ 0.492583] 0x0000005b514e-0x000000df514e : "rootfs_data"
[ 0.500001] libphy: Fixed MDIO Bus: probed
[ 0.514084] rt3050-esw 10110000.esw: link changed 0x00
[ 0.522879] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
[ 0.531993] Bluetooth: HCI UART driver ver 2.3
[ 0.536506] Bluetooth: HCI UART protocol H4 registered
[ 0.541763] Bluetooth: HCI UART protocol BCSP registered
[ 0.548395] NET: Registered protocol family 10
[ 0.557102] Segment Routing with IPv6
[ 0.561016] NET: Registered protocol family 17
[ 0.566147] Bluetooth: RFCOMM TTY layer initialized
[ 0.571185] Bluetooth: RFCOMM socket layer initialized
[ 0.576419] Bluetooth: RFCOMM ver 1.11
[ 0.580250] 8021q: 802.1Q VLAN Support v1.8
[ 0.590922] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.604822] Freeing unused kernel memory: 1212K
[ 0.609461] This architecture does not have kernel memory protection.
[ 1.419704] init: Console is alive
[ 1.423415] init: - watchdog -
[ 2.277605] random: fast init done
[ 3.228382] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[ 3.359943] usbcore: registered new interface driver usbfs
[ 3.365605] usbcore: registered new interface driver hub
[ 3.371205] usbcore: registered new device driver usb
[ 3.382899] exFAT: Version 1.2.9
[ 3.395979] JFS: nTxBlock = 969, nTxLock = 7752
[ 3.409573] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 3.425352] SCSI subsystem initialized
[ 3.435001] ehci-platform: EHCI generic platform driver
[ 3.450719] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 3.457522] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 3.462850] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 3.468728] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 3.476885] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 3.507616] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 3.515031] hub 1-0:1.0: USB hub found
[ 3.519350] hub 1-0:1.0: 1 port detected
[ 3.527051] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.535335] ohci-platform: OHCI generic platform driver
[ 3.541020] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 3.547992] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 3.556108] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 3.632721] hub 2-0:1.0: USB hub found
[ 3.637049] hub 2-0:1.0: 1 port detected
[ 3.644242] uhci_hcd: USB Universal Host Controller Interface driver
[ 3.657394] usbcore: registered new interface driver usb-storage
[ 3.664543] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 3.674351] init: - preinit -
[ 4.146742] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 4.429140] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 4.438292] random: procd: uninitialized urandom read (4 bytes read)
[ 4.453161] scsi host0: usb-storage 1-1:1.0
[ 4.828157] rt3050-esw 10110000.esw: link changed 0x00
[ 5.469352] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 1402 PQ: 0 ANSI: 6
[ 5.630657] sd 0:0:0:0: [sda] 15548416 512-byte logical blocks: (7.96 GB/7.41 GiB)
[ 5.640016] sd 0:0:0:0: [sda] Write Protect is off
[ 5.644891] sd 0:0:0:0: [sda] Mode Sense: 21 00 00 00
[ 5.646516] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 5.665188] sda: sda1
[ 5.673642] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 7.845728] rt3050-esw 10110000.esw: link changed 0x01
[ 9.263638] overlayfs: upper fs does not support tmpfile.
[ 9.274925] urandom-seed: Seeding with /etc/urandom.seed
[ 9.405787] procd: - early -
[ 9.408944] procd: - watchdog -
[ 10.173102] procd: - watchdog -
[ 10.176657] procd: - ubus -
[ 10.238277] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.245531] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.252634] random: ubusd: uninitialized urandom read (4 bytes read)
[ 10.260231] procd: - init -
[ 11.345862] kmodloader: loading kernel modules from /etc/modules.d/*
[ 11.494522] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 11.549686] i2c /dev entries driver
[ 11.557842] gdma-rt2880 10002800.gdma: revision: 3, channels: 16
[ 11.629652] i2c-mt7621 10000900.i2c: clock 100KHz, re-start not support
[ 11.655947] hidraw: raw HID events driver (C) Jiri Kosina
[ 11.679777] ralink-i2s 10000a00.i2s: mclk 480MHz
[ 11.738698] mt76x8-wm8960 sound: wm8960-hifi <-> 10000a00.i2s mapping ok
[ 11.785316] urngd: v1.0.2 started.
[ 11.873109] Loading modules backported from Linux version v5.4-rc8-0-gaf42d3466bdc
[ 11.880864] Backport generated by backports.git v5.4-rc8-1-0-g368e8c51
[ 11.922955] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 11.950883] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[ 12.103307] usbcore: registered new interface driver usbhid
[ 12.109039] usbhid: USB HID core driver
[ 12.130160] usbcore: registered new interface driver usblp
[ 12.153222] usbcore: registered new interface driver usbserial
[ 12.159328] usbcore: registered new interface driver usbserial_generic
[ 12.166026] usbserial: USB Serial support registered for generic
[ 12.189870] random: crng init done
[ 12.193336] random: 6 urandom warning(s) missed due to ratelimiting
[ 12.238624] xt_time: kernel timezone is -0000
[ 12.300637] usbcore: registered new interface driver ch341
[ 12.306307] usbserial: USB Serial support registered for ch341-uart
[ 12.330647] usbcore: registered new interface driver cp210x
[ 12.336391] usbserial: USB Serial support registered for cp210x
[ 12.481167] mt76_wmac 10300000.wmac: ASIC revision: 76280001
[ 13.589838] mt76_wmac 10300000.wmac: Firmware Version: 20151201
[ 13.595859] mt76_wmac 10300000.wmac: Build Time: 20151201183641
[ 13.637626] mt76_wmac 10300000.wmac: firmware init done
[ 13.817553] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 13.843004] usbcore: registered new interface driver pl2303
[ 13.848860] usbserial: USB Serial support registered for pl2303
[ 13.871789] PPP generic driver version 2.4.2
[ 13.889446] NET: Registered protocol family 24
[ 13.911954] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 19.972488] rt3050-esw 10110000.esw: link changed 0x00
[ 23.000948] rt3050-esw 10110000.esw: link changed 0x01
[ 25.788141] br-lan: port 1(eth0) entered blocking state
[ 25.793456] br-lan: port 1(eth0) entered disabled state
[ 25.799199] device eth0 entered promiscuous mode
[ 25.826896] br-lan: port 1(eth0) entered blocking state
[ 25.832275] br-lan: port 1(eth0) entered forwarding state
[ 25.838000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
[ 26.827759] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 29.128724] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 60.473391] jffs2: notice: (1433) jffs2_get_inode_nodes: Node header CRC failed at 0x7f000c. {ffff,ffff,ffffffff,ffffffff}离线
