[ 138.565093] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 138.583451] input input0: Poll touch data failed: -110
[ 140.725056] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 140.743392] input input0: Poll touch data failed: -110
[ 142.885015] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 142.903319] input input0: Poll touch data failed: -110
[ 145.044991] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 145.063361] input input0: Poll touch data failed: -110
[ 147.204992] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 147.223281] input input0: Poll touch data failed: -110
[ 149.364993] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 149.383260] input input0: Poll touch data failed: -110
[ 151.524986] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 151.543327] input input0: Poll touch data failed: -110
[ 153.684983] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 153.703151] input input0: Poll touch data failed: -110
[ 155.844985] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 155.863320] input input0: Poll touch data failed: -110
[ 158.005008] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 158.023374] input input0: Poll touch data failed: -110
[ 160.164987] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 160.183321] input input0: Poll touch data failed: -110
[ 162.325083] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 162.343434] input input0: Poll touch data failed: -110
^C[ 164.485012] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 164.503360] input input0: Poll touch data failed: -110
I2c加上拉电阻
nano pi没上拉电阻,要自己加
wupaul2001 wrote:
I2c加上拉电阻
是e11那吗
可以了 谢谢 晕哥~ 直接e11 e12 接上拉电阻就可以了
但是屏幕没有校准~
ts_calibrate
ts_test
晕哥 ts_lib 的链接有没 找了一圈没找到呢~
ts_calibrate
ts_test
哦哦 知道了 buildroot里面可以选
