楼主 #1 2018-04-13 00:59:42
sunwei
已发帖子: 77
spl 引导的编译脚本
(C) Copyright 2000-2011
Wolfgang Denk, DENX Software Engineering, wd@denx.de.
(C) Copyright 2011
Daniel Schwierzeck, daniel.schwierzeck@googlemail.com.
(C) Copyright 2011
Texas Instruments Incorporated - http://www.ti.com/
Aneesh V <aneesh@ti.com>
This file is released under the terms of GPL v2 and any later version.
See the file COPYING in the root directory of the source tree for details.
Based on top-level Makefile.
include $(SPLDIR)/config.mk
include $(TOPDIR)/include/autoconf.mk
include $(TOPDIR)/include/autoconf.mk.dep
CONFIG_SPL := y
export CONFIG_SPL
TOOLS_DIR := $(TOPDIR)/tools
#链接文件
BOOT0_LDSCRIPT := $(TOPDIR)/sunxi_spl/boot0/main/boot0.lds
We want the final binaries in this directory
obj := $(OBJTREE)/sunxi_spl/boot0/
BOOT0_HEAD := sunxi_spl/boot0/boot0_head.o
START := sunxi_spl/boot0/boot0_entry.o
LIBS-y += sunxi_spl/boot0/spl/libsource_spl.o
LIBS-y += sunxi_spl/boot0/main/libmain.o
LIBS-y += sunxi_spl/boot0/libs/libgeneric.o
#看文件目录的make文件
LIBS-y += sunxi_spl/spl/lib/libgeneric.o
#目录---u-boot-2014.07\arch\arm\cpu\arm926ejs\sunivw1p1\dram-----------------
LIBS-y += arch/$(ARCH)/cpu/$(CPU)/$(SOC)/dram/libdram.o
LIBS-$(CONFIG_SUNXI_CHIPID) += arch/$(ARCH)/cpu/$(CPU)/$(SOC)/dram/libchipid.o
LIBS := $(addprefix $(OBJTREE)/,$(sort $(LIBS-y)))
#可以不要nand闪存的设备库
LIBNAND-$(CONFIG_STORAGE_MEDIA_NAND) += sunxi_spl/boot0/load_nand/libloadnand.o
LIBNAND-$(CONFIG_STORAGE_MEDIA_NAND) += arch/$(ARCH)/cpu/$(CPU)/$(SOC)/nand/libnand.o
LIBNAND := $(addprefix $(OBJTREE)/,$(sort $(LIBNAND-y)))
#可以不要SD卡闪存的设备库
LIBMMC-$(CONFIG_STORAGE_MEDIA_MMC) += sunxi_spl/boot0/load_mmc/libloadmmc.o
LIBMMC-$(CONFIG_STORAGE_MEDIA_MMC) += arch/$(ARCH)/cpu/$(CPU)/$(SOC)/mmc/libmmc.o
LIBMMC := $(addprefix $(OBJTREE)/,$(sort $(LIBMMC-y)))
#这个需要
LIBSPINOR-$(CONFIG_STORAGE_MEDIA_SPINOR) += sunxi_spl/boot0/load_spinor/libloadspinor.o
LIBSPINOR-$(CONFIG_STORAGE_MEDIA_SPINOR) += arch/$(ARCH)/cpu/$(CPU)/$(SOC)/spinor/libspinor.o
LIBSPINOR := $(addprefix $(OBJTREE)/,$(sort $(LIBSPINOR-y)))
__LIBS := $(subst $(obj),,$(LIBS))
Special flags for CPP when processing the linker script.
Pass the version down so we can handle backwards compatibility
on the fly.
LDPPFLAGS += \
-include $(TOPDIR)/include/u-boot/u-boot.lds.h \
-DBOOT0ADDR=$(CONFIG_BOOT0_RUN_ADDR) \
$(shell $(LD) --version | \
sed -ne 's/GNU ld version \([0-9][0-9]\)\.\([0-9][0-9]\).*/-DLD_MAJOR=\1 -DLD_MINOR=\2/p')
ALL-$(CONFIG_STORAGE_MEDIA_NAND) += $(obj)boot0_nand.bin
ALL-$(CONFIG_STORAGE_MEDIA_MMC) += $(obj)boot0_sdcard.bin
ALL-$(CONFIG_STORAGE_MEDIA_SPINOR) += $(obj)boot0_spinor.bin
all: $(ALL-y)
$(obj)boot0_nand.bin: $(obj)boot0_nand.axf
@echo bootaddr is $(CONFIG_BOOT0_RUN_ADDR)
$(OBJCOPY) $(OBJCFLAGS) -O binary $< $@
$(obj)boot0_nand.axf: $(LIBS) $(LIBNAND) $(obj)boot0.lds
$(LD) $(LIBS) $(LIBNAND) $(PLATFORM_LIBGCC) $(LDFLAGS) -T$(obj)boot0.lds -o boot0_nand.axf -Map boot0_nand.map
$(obj)boot0_sdcard.bin: $(obj)boot0_sdcard.axf
$(obj)boot0_sdcard.axf: $(LIBS) $(LIBMMC) $(obj)boot0.lds
$(LD) $(LIBS) $(LIBMMC) $(PLATFORM_LIBGCC) $(LDFLAGS) -T$(obj)boot0.lds -o boot0_sdcard.axf -Map boot0_sdcard.map
$(obj)boot0_spinor.bin: $(obj)boot0_spinor.axf
$(obj)boot0_spinor.axf: $(LIBS) $(LIBSPINOR) $(obj)boot0.lds
$(LD) $(LIBS) $(LIBSPINOR) $(PLATFORM_LIBGCC) $(LDFLAGS) -T$(obj)boot0.lds -o boot0_spinor.axf -Map boot0_spinor.map
$(LIBS): depend
$(MAKE) -C $(SRCTREE)$(dir $(subst $(OBJTREE),,$@))
$(LIBNAND): depend
$(LIBMMC): depend
$(LIBSPINOR): depend
$(obj)boot0.lds: $(BOOT0_LDSCRIPT)
@$(CPP) $(ALL_CFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@
depend: .depend
defines $(obj).depend target
include $(SRCTREE)/rules.mk
sinclude .depend
楼主 #2 2018-04-13 01:01:07
sunwei
已发帖子: 77
Re: spl 引导的编译脚本
u-boot-2014.07\sunxi_spl\boot0\Makefile
#3 2018-04-15 17:39:39
kgp0213
已发帖子: 149
Re: spl 引导的编译脚本
大佬好像在深入f1c100s啊~
