楼主 #1 2020-04-30 14:30:07
已发帖子: 3,403
修改Linux驱动显示Winbond W25Q64/W25Q128/W25Q256/W25Q512等flash的唯一Id(Unique Id
原帖地址: http://vonger.cn/?p=931
楼主 #2 2020-04-30 14:30:38
已发帖子: 3,403
Re: 修改Linux驱动显示Winbond W25Q64/W25Q128/W25Q256/W25Q512等flash的唯一Id(Unique Id
修改后的代码: http://vonger.cn/upload/m25p80.c
 * MTD SPI driver for ST M25Pxx (and similar) serial flash chips
 * Author: Mike Lavender, mike@steroidmicros.com
 * Copyright (c) 2005, Intec Automation Inc.
 * Some parts are based on lart.c by Abraham Van Der Merwe
 * Cleaned up and generalized based on mtd_dataflash.c
 * This code is free software; you can redistribute it and/or modify
 * it under the terms of the GNU General Public License version 2 as
 * published by the Free Software Foundation.
#include <linux/init.h>
#include <linux/err.h>
#include <linux/errno.h>
#include <linux/module.h>
#include <linux/device.h>
#include <linux/interrupt.h>
#include <linux/mutex.h>
#include <linux/math64.h>
#include <linux/slab.h>
#include <linux/sched.h>
#include <linux/mod_devicetable.h>
#include <linux/mtd/cfi.h>
#include <linux/mtd/mtd.h>
#include <linux/mtd/partitions.h>
#include <linux/of_platform.h>
#include <linux/spi/spi.h>
#include <linux/spi/flash.h>
/* Flash opcodes. */
#define	OPCODE_WREN		0x06	/* Write enable */
#define	OPCODE_RDSR		0x05	/* Read status register */
#define	OPCODE_WRSR		0x01	/* Write status register 1 byte */
#define	OPCODE_NORM_READ	0x03	/* Read data bytes (low frequency) */
#define	OPCODE_FAST_READ	0x0b	/* Read data bytes (high frequency) */
#define	OPCODE_PP		0x02	/* Page program (up to 256 bytes) */
#define	OPCODE_BE_4K		0x20	/* Erase 4KiB block */
#define	OPCODE_BE_4K_PMC	0xd7	/* Erase 4KiB block on PMC chips */
#define	OPCODE_BE_32K		0x52	/* Erase 32KiB block */
#define	OPCODE_CHIP_ERASE	0xc7	/* Erase whole flash chip */
#define	OPCODE_SE		0xd8	/* Sector erase (usually 64KiB) */
#define	OPCODE_RDID		0x9f	/* Read JEDEC ID */
/* Used for SST flashes only. */
#define	OPCODE_BP		0x02	/* Byte program */
#define	OPCODE_WRDI		0x04	/* Write disable */
#define	OPCODE_AAI_WP		0xad	/* Auto address increment word program */
/* Used for Macronix flashes only. */
#define	OPCODE_EN4B		0xb7	/* Enter 4-byte mode */
#define	OPCODE_EX4B		0xe9	/* Exit 4-byte mode */
/* Used for Spansion flashes only. */
#define	OPCODE_BRWR		0x17	/* Bank register write */
/* Used for Winbond flashes only. */
#define OPCODE_WINBOND_ID    0x4b    /* Get flash unique id */
/* Status Register bits. */
#define	SR_WIP			1	/* Write in progress */
#define	SR_WEL			2	/* Write enable latch */
/* meaning of other SR_* bits may differ between vendors */
#define	SR_BP0			4	/* Block protect 0 */
#define	SR_BP1			8	/* Block protect 1 */
#define	SR_BP2			0x10	/* Block protect 2 */
#define	SR_SRWD			0x80	/* SR write protect */
/* Define max times to check status register before we give up. */
#define	MAX_READY_WAIT_JIFFIES	(40 * HZ)	/* M25P16 specs 40s max chip erase */
#define	MAX_CMD_SIZE		5
#define JEDEC_MFR(_jedec_id)	((_jedec_id) >> 16)
#ifdef CONFIG_M25PXX_PREFER_SMALL_SECTOR_ERASE
#define PREFER_SMALL_SECTOR_ERASE 1
#else
#define PREFER_SMALL_SECTOR_ERASE 0
struct m25p {
    struct spi_device	*spi;
    struct mutex		lock;
    struct mtd_info		mtd;
    u16			page_size;
    u16			addr_width;
    u8			erase_opcode;
    u8			*command;
    bool			fast_read;
static inline struct m25p *mtd_to_m25p(struct mtd_info *mtd)
    return container_of(mtd, struct m25p, mtd);
 * Internal helper functions
 * Read the status register, returning its value in the location
 * Return the status register value.
 * Returns negative if error occurred.
static int read_sr(struct m25p *flash)
    ssize_t retval;
    u8 code = OPCODE_RDSR;
    u8 val;
    retval = spi_write_then_read(flash->spi, &code, 1, &val, 1);
    if (retval < 0) {
        dev_err(&flash->spi->dev, "error %d reading SR\n",
                (int) retval);
        return retval;
    return val;
static int write_sr(struct m25p *flash, u8 val)
    flash->command[0] = OPCODE_WRSR;
    flash->command[1] = val;
    return spi_write(flash->spi, flash->command, 2);
 * Set write enable latch with Write Enable command.
static inline int write_enable(struct m25p *flash)
    u8	code = OPCODE_WREN;
    return spi_write_then_read(flash->spi, &code, 1, NULL, 0);
 * Send write disble instruction to the chip.
static inline int write_disable(struct m25p *flash)
    u8	code = OPCODE_WRDI;
 * Enable/disable 4-byte addressing mode.
static inline int set_4byte(struct m25p *flash, u32 jedec_id, int enable)
    switch (JEDEC_MFR(jedec_id)) {
    case CFI_MFR_MACRONIX:
    case 0xEF /* winbond */:
        flash->command[0] = enable ? OPCODE_EN4B : OPCODE_EX4B;
        return spi_write(flash->spi, flash->command, 1);
    default:
        /* Spansion style */
        flash->command[0] = OPCODE_BRWR;
        flash->command[1] = enable << 7;
 * Service routine to read status register until ready, or timeout occurs.
 * Returns non-zero if error.
static int wait_till_ready(struct m25p *flash)
    unsigned long deadline;
    int sr;
    deadline = jiffies + MAX_READY_WAIT_JIFFIES;
    do {
        if ((sr = read_sr(flash)) < 0)
            break;
        else if (!(sr & SR_WIP))
        cond_resched();
    } while (!time_after_eq(jiffies, deadline));
    return 1;
 * Erase the whole flash memory
 * Returns 0 if successful, non-zero otherwise.
static int erase_chip(struct m25p *flash)
    pr_debug("%s: %s %lldKiB\n", dev_name(&flash->spi->dev), __func__,
            (long long)(flash->mtd.size >> 10));
    /* Wait until finished previous write command. */
    if (wait_till_ready(flash))
        return 1;
    /* Send write enable, then erase commands. */
    write_enable(flash);
    /* Set up command buffer. */
    flash->command[0] = OPCODE_CHIP_ERASE;
static void m25p_addr2cmd(struct m25p *flash, unsigned int addr, u8 *cmd)
    /* opcode is in cmd[0] */
    cmd[1] = addr >> (flash->addr_width * 8 -  8);
    cmd[2] = addr >> (flash->addr_width * 8 - 16);
    cmd[3] = addr >> (flash->addr_width * 8 - 24);
    cmd[4] = addr >> (flash->addr_width * 8 - 32);
static int m25p_cmdsz(struct m25p *flash)
    return 1 + flash->addr_width;
 * Erase one sector of flash memory at offset ``offset'' which is any
 * address within the sector which should be erased.
static int erase_sector(struct m25p *flash, u32 offset)
    pr_debug("%s: %s %dKiB at 0x%08x\n", dev_name(&flash->spi->dev),
            __func__, flash->mtd.erasesize / 1024, offset);
        return 1;
    flash->command[0] = flash->erase_opcode;
    m25p_addr2cmd(flash, offset, flash->command);
    spi_write(flash->spi, flash->command, m25p_cmdsz(flash));
 * MTD implementation
 * Erase an address range on the flash chip.  The address range may extend
 * one or more erase sectors.  Return an error is there is a problem erasing.
static int m25p80_erase(struct mtd_info *mtd, struct erase_info *instr)
    struct m25p *flash = mtd_to_m25p(mtd);
    u32 addr,len;
    uint32_t rem;
    pr_debug("%s: %s at 0x%llx, len %lld\n", dev_name(&flash->spi->dev),
            __func__, (long long)instr->addr,
            (long long)instr->len);
    div_u64_rem(instr->len, mtd->erasesize, &rem);
    if (rem)
        return -EINVAL;
    addr = instr->addr;
    len = instr->len;
    mutex_lock(&flash->lock);
    /* whole-chip erase? */
    if (len == flash->mtd.size) {
        if (erase_chip(flash)) {
            instr->state = MTD_ERASE_FAILED;
            mutex_unlock(&flash->lock);
            return -EIO;
    /* REVISIT in some cases we could speed up erasing large regions
     * by using OPCODE_SE instead of OPCODE_BE_4K.  We may have set up
     * to use "small sector erase", but that's not always optimal.
    /* "sector"-at-a-time erase */
    } else {
        while (len) {
            if (erase_sector(flash, addr)) {
                return -EIO;
            addr += mtd->erasesize;
            len -= mtd->erasesize;
    instr->state = MTD_ERASE_DONE;
    mtd_erase_callback(instr);
 * Read an address range from the flash chip.  The address range
 * may be any size provided it is within the physical boundaries.
static int m25p80_read(struct mtd_info *mtd, loff_t from, size_t len,
    size_t *retlen, u_char *buf)
    struct spi_transfer t[2];
    struct spi_message m;
    uint8_t opcode;
    pr_debug("%s: %s from 0x%08x, len %zd\n", dev_name(&flash->spi->dev),
            __func__, (u32)from, len);
    spi_message_init(&m);
    memset(t, 0, (sizeof t));
    /* NOTE:
     * OPCODE_FAST_READ (if available) is faster.
     * Should add 1 byte DUMMY_BYTE.
    t[0].tx_buf = flash->command;
    t[0].len = m25p_cmdsz(flash) + (flash->fast_read ? 1 : 0);
    spi_message_add_tail(&t[0], &m);
    t[1].rx_buf = buf;
    t[1].len = len;
    spi_message_add_tail(&t[1], &m);
    /* Wait till previous write/erase is done. */
    if (wait_till_ready(flash)) {
        /* REVISIT status return?? */
        return 1;
    /* FIXME switch to OPCODE_FAST_READ.  It's required for higher
     * clocks; and at this writing, every chip this driver handles
     * supports that opcode.
    /* Set up the write data buffer. */
    opcode = flash->fast_read ? OPCODE_FAST_READ : OPCODE_NORM_READ;
    flash->command[0] = opcode;
    m25p_addr2cmd(flash, from, flash->command);
    spi_sync(flash->spi, &m);
    *retlen = m.actual_length - m25p_cmdsz(flash) -
static int m25p80_read_chunked(struct mtd_info *mtd, loff_t from, size_t len,
    uint8_t opcode;
    int idx = 0;
    t[0].len = m25p_cmdsz(flash);
    *retlen = 0;
    while (idx < len) {
        int rlen = (len - idx > 4) ? (4) : (len - idx);
        t[1].rx_buf = &buf[idx];
        t[1].len = rlen;
            return 1;
        opcode = OPCODE_NORM_READ;
        m25p_addr2cmd(flash, from + idx, flash->command);
        *retlen += m.actual_length - m25p_cmdsz(flash);
        idx += rlen;
 * Write an address range to the flash chip.  Data must be written in
 * FLASH_PAGESIZE chunks.  The address range may be any size provided
 * it is within the physical boundaries.
static int m25p80_write(struct mtd_info *mtd, loff_t to, size_t len,
    size_t *retlen, const u_char *buf)
    u32 page_offset, page_size;
    pr_debug("%s: %s to 0x%08x, len %zd\n", dev_name(&flash->spi->dev),
            __func__, (u32)to, len);
    t[1].tx_buf = buf;
        return 1;
    /* Set up the opcode in the write buffer. */
    flash->command[0] = OPCODE_PP;
    m25p_addr2cmd(flash, to, flash->command);
    page_offset = to & (flash->page_size - 1);
    /* do all the bytes fit onto one page? */
    if (page_offset + len <= flash->page_size) {
        t[1].len = len;
        *retlen = m.actual_length - m25p_cmdsz(flash);
    } else {
        u32 i;
        /* the size of data remaining on the first page */
        page_size = flash->page_size - page_offset;
        t[1].len = page_size;
        /* write everything in flash->page_size chunks */
        for (i = page_size; i < len; i += page_size) {
            page_size = len - i;
            if (page_size > flash->page_size)
                page_size = flash->page_size;
            /* write the next page to flash */
            m25p_addr2cmd(flash, to + i, flash->command);
            t[1].tx_buf = buf + i;
            wait_till_ready(flash);
static int m25p80_write_chunked(struct mtd_info *mtd, loff_t to, size_t len,
    struct spi_transfer t;
    u32 i, page_size;
    u8 tmp[8];
    memset(&t, 0, (sizeof t));
    t.tx_buf = tmp;
    t.len = 8;
    spi_message_add_tail(&t, &m);
        return 1;
    t.len = 4 + (to & 0x3);
    if (t.len == 4)
        t.len = 8;
    memcpy(tmp, flash->command, 4);
    memcpy(&tmp[4], buf, t.len - 4);
    page_size = t.len - 4;
        if (page_size > 4)
            page_size = 4;
        memcpy(&tmp[4], buf + i, page_size);
        t.len = 4 + page_size;
static int sst_write(struct mtd_info *mtd, loff_t to, size_t len,
    size_t actual;
    int cmd_sz, ret;
    t[1].tx_buf = buf;
    ret = wait_till_ready(flash);
    if (ret)
        goto time_out;
    actual = to % 2;
    /* Start write from odd address. */
    if (actual) {
        flash->command[0] = OPCODE_BP;
        /* write one byte. */
        t[1].len = 1;
        if (ret)
            goto time_out;
    to += actual;
    flash->command[0] = OPCODE_AAI_WP;
    /* Write out most of the data here. */
    cmd_sz = m25p_cmdsz(flash);
    for (; actual < len - 1; actual += 2) {
        t[0].len = cmd_sz;
        /* write two bytes. */
        t[1].len = 2;
        t[1].tx_buf = buf + actual;
        if (ret)
            goto time_out;
        *retlen += m.actual_length - cmd_sz;
        cmd_sz = 1;
        to += 2;
    write_disable(flash);
    if (ret)
        goto time_out;
    /* Write out trailing byte if it exists. */
    if (actual != len) {
        t[1].len = 1;
        if (ret)
            goto time_out;
time_out:
    return ret;
static int m25p80_lock(struct mtd_info *mtd, loff_t ofs, uint64_t len)
    uint32_t offset = ofs;
    uint8_t status_old, status_new;
    int res = 0;
    /* Wait until finished previous command */
        res = 1;
        goto err;
    status_old = read_sr(flash);
    if (offset < flash->mtd.size-(flash->mtd.size/2))
        status_new = status_old | SR_BP2 | SR_BP1 | SR_BP0;
    else if (offset < flash->mtd.size-(flash->mtd.size/4))
        status_new = (status_old & ~SR_BP0) | SR_BP2 | SR_BP1;
    else if (offset < flash->mtd.size-(flash->mtd.size/8))
        status_new = (status_old & ~SR_BP1) | SR_BP2 | SR_BP0;
    else if (offset < flash->mtd.size-(flash->mtd.size/16))
        status_new = (status_old & ~(SR_BP0|SR_BP1)) | SR_BP2;
    else if (offset < flash->mtd.size-(flash->mtd.size/32))
        status_new = (status_old & ~SR_BP2) | SR_BP1 | SR_BP0;
    else if (offset < flash->mtd.size-(flash->mtd.size/64))
        status_new = (status_old & ~(SR_BP2|SR_BP0)) | SR_BP1;
        status_new = (status_old & ~(SR_BP2|SR_BP1)) | SR_BP0;
    /* Only modify protection if it will not unlock other areas */
    if ((status_new&(SR_BP2|SR_BP1|SR_BP0)) >
                    (status_old&(SR_BP2|SR_BP1|SR_BP0))) {
        if (write_sr(flash, status_new) < 0) {
            res = 1;
            goto err;
err:	mutex_unlock(&flash->lock);
    return res;
static int m25p80_unlock(struct mtd_info *mtd, loff_t ofs, uint64_t len)
    int res = 0;
        res = 1;
        goto err;
    if (offset+len > flash->mtd.size-(flash->mtd.size/64))
        status_new = status_old & ~(SR_BP2|SR_BP1|SR_BP0);
    else if (offset+len > flash->mtd.size-(flash->mtd.size/32))
    else if (offset+len > flash->mtd.size-(flash->mtd.size/16))
    else if (offset+len > flash->mtd.size-(flash->mtd.size/8))
    else if (offset+len > flash->mtd.size-(flash->mtd.size/4))
    else if (offset+len > flash->mtd.size-(flash->mtd.size/2))
    /* Only modify protection if it will not lock other areas */
    if ((status_new&(SR_BP2|SR_BP1|SR_BP0)) <
            res = 1;
            goto err;
    return res;
 * SPI device driver setup and teardown
struct flash_info {
    /* JEDEC id zero means "no ID" (most older chips); otherwise it has
     * a high byte of zero plus three data bytes: the manufacturer id,
     * then a two byte device id.
    u32		jedec_id;
    u16             ext_id;
    /* The size listed here is what works with OPCODE_SE, which isn't
     * necessarily called a "sector" by the vendor.
    unsigned	sector_size;
    u16		n_sectors;
    u16		page_size;
    u16		addr_width;
    u16		flags;
#define	SECT_4K		0x01		/* OPCODE_BE_4K works uniformly */
#define	M25P_NO_ERASE	0x02		/* No erase command needed */
#define	SST_WRITE	0x04		/* use SST byte programming */
#define	SECT_4K_PMC	0x10		/* OPCODE_BE_4K_PMC works uniformly */
#define INFO(_jedec_id, _ext_id, _sector_size, _n_sectors, _flags)	\
    ((kernel_ulong_t)&(struct flash_info) {				\
        .jedec_id = (_jedec_id),				\
        .ext_id = (_ext_id),					\
        .sector_size = (_sector_size),				\
        .n_sectors = (_n_sectors),				\
        .page_size = 256,					\
        .flags = (_flags),					\
#define CAT25_INFO(_sector_size, _n_sectors, _page_size, _addr_width)	\
        .page_size = (_page_size),				\
        .addr_width = (_addr_width),				\
        .flags = M25P_NO_ERASE,					\
/* NOTE: double check command sets and memory organization when you add
 * more flash chips.  This current list focusses on newer chips, which
 * have been converging on command sets which including JEDEC ID.
static const struct spi_device_id m25p_ids[] = {
    /* Atmel -- some are (confusingly) marketed as "DataFlash" */
    { "at25fs010",  INFO(0x1f6601, 0, 32 * 1024,   4, SECT_4K) },
    { "at25fs040",  INFO(0x1f6604, 0, 64 * 1024,   8, SECT_4K) },
    { "at25df041a", INFO(0x1f4401, 0, 64 * 1024,   8, SECT_4K) },
    { "at25df321a", INFO(0x1f4701, 0, 64 * 1024,  64, SECT_4K) },
    { "at25df641",  INFO(0x1f4800, 0, 64 * 1024, 128, SECT_4K) },
    { "at26f004",   INFO(0x1f0400, 0, 64 * 1024,  8, SECT_4K) },
    { "at26df081a", INFO(0x1f4501, 0, 64 * 1024, 16, SECT_4K) },
    { "at26df161a", INFO(0x1f4601, 0, 64 * 1024, 32, SECT_4K) },
    { "at26df321",  INFO(0x1f4700, 0, 64 * 1024, 64, SECT_4K) },
    { "at45db081d", INFO(0x1f2500, 0, 64 * 1024, 16, SECT_4K) },
    /* EON -- en25xxx */
    { "en25f32", INFO(0x1c3116, 0, 64 * 1024,  64, SECT_4K) },
    { "en25p32", INFO(0x1c2016, 0, 64 * 1024,  64, 0) },
    { "en25q32b", INFO(0x1c3016, 0, 64 * 1024,  64, 0) },
    { "en25p64", INFO(0x1c2017, 0, 64 * 1024, 128, 0) },
    { "en25q64", INFO(0x1c3017, 0, 64 * 1024, 128, SECT_4K) },
    { "en25qh128", INFO(0x1c7018, 0, 64 * 1024, 256, 0) },
    { "en25qh256", INFO(0x1c7019, 0, 64 * 1024, 512, 0) },
    /* ESMT */
    { "f25l32pa", INFO(0x8c2016, 0, 64 * 1024, 64, SECT_4K) },
    /* Everspin */
    { "mr25h256", CAT25_INFO(  32 * 1024, 1, 256, 2) },
    /* GigaDevice */
    { "gd25q32", INFO(0xc84016, 0, 64 * 1024,  64, SECT_4K) },
    { "gd25q64", INFO(0xc84017, 0, 64 * 1024, 128, SECT_4K) },
    /* Intel/Numonyx -- xxxs33b */
    { "160s33b",  INFO(0x898911, 0, 64 * 1024,  32, 0) },
    { "320s33b",  INFO(0x898912, 0, 64 * 1024,  64, 0) },
    { "640s33b",  INFO(0x898913, 0, 64 * 1024, 128, 0) },
    /* Macronix */
    { "mx25l2005a",  INFO(0xc22012, 0, 64 * 1024,   4, SECT_4K) },
    { "mx25l4005a",  INFO(0xc22013, 0, 64 * 1024,   8, SECT_4K) },
    { "mx25l8005",   INFO(0xc22014, 0, 64 * 1024,  16, 0) },
    { "mx25l1606e",  INFO(0xc22015, 0, 64 * 1024,  32, SECT_4K) },
    { "mx25l3205d",  INFO(0xc22016, 0, 64 * 1024,  64, 0) },
    { "mx25l6405d",  INFO(0xc22017, 0, 64 * 1024, 128, 0) },
    { "mx25l12805d", INFO(0xc22018, 0, 64 * 1024, 256, 0) },
    { "mx25l12855e", INFO(0xc22618, 0, 64 * 1024, 256, 0) },
    { "mx25l25635e", INFO(0xc22019, 0, 64 * 1024, 512, 0) },
    { "mx25l25655e", INFO(0xc22619, 0, 64 * 1024, 512, 0) },
    { "mx66l51235l", INFO(0xc2201a, 0, 64 * 1024, 1024, 0) },
    /* Micron */
    { "n25q064",  INFO(0x20ba17, 0, 64 * 1024, 128, 0) },
    { "n25q128a11",  INFO(0x20bb18, 0, 64 * 1024, 256, 0) },
    { "n25q128a13",  INFO(0x20ba18, 0, 64 * 1024, 256, 0) },
    { "n25q256a", INFO(0x20ba19, 0, 64 * 1024, 512, SECT_4K) },
    /* PMC */
    { "pm25lv512", INFO(0, 0, 32 * 1024, 2, SECT_4K_PMC) },
    { "pm25lv010", INFO(0, 0, 32 * 1024, 4, SECT_4K_PMC) },
    { "pm25lq032", INFO(0x7f9d46, 0, 64 * 1024,  64, SECT_4K) },
    /* Spansion -- single (large) sector size only, at least
     * for the chips listed here (without boot sectors).
    { "s25sl032p",  INFO(0x010215, 0x4d00,  64 * 1024,  64, 0) },
    { "s25sl064p",  INFO(0x010216, 0x4d00,  64 * 1024, 128, 0) },
    { "s25fl256s0", INFO(0x010219, 0x4d00, 256 * 1024, 128, 0) },
    { "s25fl256s1", INFO(0x010219, 0x4d01,  64 * 1024, 512, 0) },
    { "s25fl512s",  INFO(0x010220, 0x4d00, 256 * 1024, 256, 0) },
    { "s70fl01gs",  INFO(0x010221, 0x4d00, 256 * 1024, 256, 0) },
    { "s25sl12800", INFO(0x012018, 0x0300, 256 * 1024,  64, 0) },
    { "s25sl12801", INFO(0x012018, 0x0301,  64 * 1024, 256, 0) },
    { "s25fl129p0", INFO(0x012018, 0x4d00, 256 * 1024,  64, 0) },
    { "s25fl129p1", INFO(0x012018, 0x4d01,  64 * 1024, 256, 0) },
    { "s25sl004a",  INFO(0x010212,      0,  64 * 1024,   8, 0) },
    { "s25sl008a",  INFO(0x010213,      0,  64 * 1024,  16, 0) },
    { "s25sl016a",  INFO(0x010214,      0,  64 * 1024,  32, 0) },
    { "s25sl032a",  INFO(0x010215,      0,  64 * 1024,  64, 0) },
    { "s25sl064a",  INFO(0x010216,      0,  64 * 1024, 128, 0) },
    { "s25fl016k",  INFO(0xef4015,      0,  64 * 1024,  32, SECT_4K) },
    { "s25fl064k",  INFO(0xef4017,      0,  64 * 1024, 128, SECT_4K) },
    /* SST -- large erase sizes are "overlays", "sectors" are 4K */
    { "sst25vf040b", INFO(0xbf258d, 0, 64 * 1024,  8, SECT_4K | SST_WRITE) },
    { "sst25vf080b", INFO(0xbf258e, 0, 64 * 1024, 16, SECT_4K | SST_WRITE) },
    { "sst25vf016b", INFO(0xbf2541, 0, 64 * 1024, 32, SECT_4K | SST_WRITE) },
    { "sst25vf032b", INFO(0xbf254a, 0, 64 * 1024, 64, SECT_4K | SST_WRITE) },
    { "sst25vf064c", INFO(0xbf254b, 0, 64 * 1024, 128, SECT_4K) },
    { "sst25wf512",  INFO(0xbf2501, 0, 64 * 1024,  1, SECT_4K | SST_WRITE) },
    { "sst25wf010",  INFO(0xbf2502, 0, 64 * 1024,  2, SECT_4K | SST_WRITE) },
    { "sst25wf020",  INFO(0xbf2503, 0, 64 * 1024,  4, SECT_4K | SST_WRITE) },
    { "sst25wf040",  INFO(0xbf2504, 0, 64 * 1024,  8, SECT_4K | SST_WRITE) },
    /* ST Microelectronics -- newer production may have feature updates */
    { "m25p05",  INFO(0x202010,  0,  32 * 1024,   2, 0) },
    { "m25p10",  INFO(0x202011,  0,  32 * 1024,   4, 0) },
    { "m25p20",  INFO(0x202012,  0,  64 * 1024,   4, 0) },
    { "m25p40",  INFO(0x202013,  0,  64 * 1024,   8, 0) },
    { "m25p80",  INFO(0x202014,  0,  64 * 1024,  16, 0) },
    { "m25p16",  INFO(0x202015,  0,  64 * 1024,  32, 0) },
    { "m25p32",  INFO(0x202016,  0,  64 * 1024,  64, 0) },
    { "m25p64",  INFO(0x202017,  0,  64 * 1024, 128, 0) },
    { "m25p128", INFO(0x202018,  0, 256 * 1024,  64, 0) },
    { "n25q032", INFO(0x20ba16,  0,  64 * 1024,  64, 0) },
    { "m25p05-nonjedec",  INFO(0, 0,  32 * 1024,   2, 0) },
    { "m25p10-nonjedec",  INFO(0, 0,  32 * 1024,   4, 0) },
    { "m25p20-nonjedec",  INFO(0, 0,  64 * 1024,   4, 0) },
    { "m25p40-nonjedec",  INFO(0, 0,  64 * 1024,   8, 0) },
    { "m25p80-nonjedec",  INFO(0, 0,  64 * 1024,  16, 0) },
    { "m25p16-nonjedec",  INFO(0, 0,  64 * 1024,  32, 0) },
    { "m25p32-nonjedec",  INFO(0, 0,  64 * 1024,  64, 0) },
    { "m25p64-nonjedec",  INFO(0, 0,  64 * 1024, 128, 0) },
    { "m25p128-nonjedec", INFO(0, 0, 256 * 1024,  64, 0) },
    { "m45pe10", INFO(0x204011,  0, 64 * 1024,    2, 0) },
    { "m45pe80", INFO(0x204014,  0, 64 * 1024,   16, 0) },
    { "m45pe16", INFO(0x204015,  0, 64 * 1024,   32, 0) },
    { "m25pe20", INFO(0x208012,  0, 64 * 1024,  4,       0) },
    { "m25pe80", INFO(0x208014,  0, 64 * 1024, 16,       0) },
    { "m25pe16", INFO(0x208015,  0, 64 * 1024, 32, SECT_4K) },
    { "m25px32",    INFO(0x207116,  0, 64 * 1024, 64, SECT_4K) },
    { "m25px32-s0", INFO(0x207316,  0, 64 * 1024, 64, SECT_4K) },
    { "m25px32-s1", INFO(0x206316,  0, 64 * 1024, 64, SECT_4K) },
    { "m25px64",    INFO(0x207117,  0, 64 * 1024, 128, 0) },
    /* Winbond -- w25x "blocks" are 64K, "sectors" are 4KiB */
    { "w25x05", INFO(0xef3010, 0, 64 * 1024,  1,  SECT_4K) },
    { "w25x10", INFO(0xef3011, 0, 64 * 1024,  2,  SECT_4K) },
    { "w25x20", INFO(0xef3012, 0, 64 * 1024,  4,  SECT_4K) },
    { "w25x40", INFO(0xef3013, 0, 64 * 1024,  8,  SECT_4K) },
    { "w25x80", INFO(0xef3014, 0, 64 * 1024,  16, SECT_4K) },
    { "w25x16", INFO(0xef3015, 0, 64 * 1024,  32, SECT_4K) },
    { "w25x32", INFO(0xef3016, 0, 64 * 1024,  64, SECT_4K) },
    { "w25q32", INFO(0xef4016, 0, 64 * 1024,  64, SECT_4K) },
    { "w25q32dw", INFO(0xef6016, 0, 64 * 1024,  64, SECT_4K) },
    { "w25x64", INFO(0xef3017, 0, 64 * 1024, 128, SECT_4K) },
    { "w25q64", INFO(0xef4017, 0, 64 * 1024, 128, SECT_4K) },
    { "w25q80", INFO(0xef5014, 0, 64 * 1024,  16, SECT_4K) },
    { "w25q80bl", INFO(0xef4014, 0, 64 * 1024,  16, SECT_4K) },
    { "w25q128", INFO(0xef4018, 0, 64 * 1024, 256, SECT_4K) },
    { "w25q256", INFO(0xef4019, 0, 64 * 1024, 512, SECT_4K) },
    /* Catalyst / On Semiconductor -- non-JEDEC */
    { "cat25c11", CAT25_INFO(  16, 8, 16, 1) },
    { "cat25c03", CAT25_INFO(  32, 8, 16, 2) },
    { "cat25c09", CAT25_INFO( 128, 8, 32, 2) },
    { "cat25c17", CAT25_INFO( 256, 8, 32, 2) },
    { "cat25128", CAT25_INFO(2048, 8, 64, 2) },
MODULE_DEVICE_TABLE(spi, m25p_ids);
/* flash unique id probe */
static int unique_id_prob(struct spi_device *spi, u8 *id)
    int			tmp;
    u8			code[5];
    code[0] = OPCODE_WINBOND_ID;
    tmp = spi_write_then_read(spi, &code, 5, id, 8);
    if (tmp < 0) {
        pr_debug("%s: error %d reading UNIQUE ID\n",
                dev_name(&spi->dev), tmp);
        return tmp;
static const struct spi_device_id *jedec_probe(struct spi_device *spi)
    int			tmp;
    u8			code = OPCODE_RDID;
    u8			id[5];
    u32			jedec;
    u16                     ext_jedec;
    struct flash_info	*info;
    /* JEDEC also defines an optional "extended device information"
     * string for after vendor-specific data, after the three bytes
     * we use here.  Supporting some chips might require using it.
    tmp = spi_write_then_read(spi, &code, 1, id, 5);
    if (tmp < 0) {
        pr_debug("%s: error %d reading JEDEC ID\n",
        return ERR_PTR(tmp);
    jedec = id[0];
    jedec = jedec << 8;
    jedec |= id[1];
    jedec = jedec << 8;
    jedec |= id[2];
    ext_jedec = id[3] << 8 | id[4];
    for (tmp = 0; tmp < ARRAY_SIZE(m25p_ids) - 1; tmp++) {
        info = (void *)m25p_ids[tmp].driver_data;
        if (info->jedec_id == jedec) {
            if (info->ext_id != 0 && info->ext_id != ext_jedec)
                continue;
            return &m25p_ids[tmp];
    dev_err(&spi->dev, "unrecognized JEDEC id %06x\n", jedec);
    return ERR_PTR(-ENODEV);
 * board specific setup should have ensured the SPI clock used here
 * matches what the READ command supports, at least until this driver
 * understands FAST_READ (for clocks over 25 MHz).
static int m25p_probe(struct spi_device *spi)
    const struct spi_device_id	*id = spi_get_device_id(spi);
    struct flash_platform_data	*data;
    struct m25p			*flash;
    unsigned			i;
    struct mtd_part_parser_data	ppdata;
    struct device_node __maybe_unused *np = spi->dev.of_node;
    const char __maybe_unused	*of_mtd_name = NULL;
#ifdef CONFIG_MTD_OF_PARTS
    if (!of_device_is_available(np))
        return -ENODEV;
    of_property_read_string(spi->dev.of_node,
                    "linux,mtd-name", &of_mtd_name);
    /* Platform data helps sort out which chip type we have, as
     * well as how this board partitions it.  If we don't have
     * a chip ID, try the JEDEC id commands; they'll work for most
     * newer chips, even if we don't recognize the particular chip.
    data = spi->dev.platform_data;
    if (data && data->type) {
        const struct spi_device_id *plat_id;
        for (i = 0; i < ARRAY_SIZE(m25p_ids) - 1; i++) {
            plat_id = &m25p_ids[i];
            if (strcmp(data->type, plat_id->name))
                continue;
            break;
        if (i < ARRAY_SIZE(m25p_ids) - 1)
            id = plat_id;
            dev_warn(&spi->dev, "unrecognized id %s\n", data->type);
    info = (void *)id->driver_data;
    if (info->jedec_id) {
        const struct spi_device_id *jid;
        jid = jedec_probe(spi);
        if (IS_ERR(jid)) {
            return PTR_ERR(jid);
        } else if (jid != id) {
             * JEDEC knows better, so overwrite platform ID. We
             * can't trust partitions any longer, but we'll let
             * mtd apply them anyway, since some partitions may be
             * marked read-only, and we don't want to lose that
             * information, even if it's not 100% accurate.
            dev_warn(&spi->dev, "found %s, expected %s\n",
                 jid->name, id->name);
            id = jid;
            info = (void *)jid->driver_data;
    /* show unique id in kernel debug log for w25q64 or w25q128. */
    if(info->jedec_id == 0xef4017 || info->jedec_id == 0xef4018) {
        u8 unique_id[8];
        if(!unique_id_prob(spi, unique_id)) {
            dev_warn(&spi->dev, "flash id: %02x%02x%02x%02x%02x%02x%02x%02x\n",
                    unique_id[7], unique_id[6], unique_id[5], unique_id[4],
                    unique_id[3], unique_id[2], unique_id[1], unique_id[0]);
        } else {
            dev_warn(&spi->dev, "failed to get flash unique id.\n");
    flash = kzalloc(sizeof *flash, GFP_KERNEL);
    if (!flash)
        return -ENOMEM;
    flash->command = kmalloc(MAX_CMD_SIZE + (flash->fast_read ? 1 : 0),
                    GFP_KERNEL);
    if (!flash->command) {
        kfree(flash);
        return -ENOMEM;
    flash->spi = spi;
    mutex_init(&flash->lock);
    dev_set_drvdata(&spi->dev, flash);
     * Atmel, SST and Intel/Numonyx serial flash tend to power
     * up with the software protection bits set
    if (JEDEC_MFR(info->jedec_id) == CFI_MFR_ATMEL ||
        JEDEC_MFR(info->jedec_id) == CFI_MFR_INTEL ||
        JEDEC_MFR(info->jedec_id) == CFI_MFR_SST) {
        write_sr(flash, 0);
    if (data && data->name)
        flash->mtd.name = data->name;
    else if (of_mtd_name)
        flash->mtd.name = of_mtd_name;
        flash->mtd.name = dev_name(&spi->dev);
    flash->mtd.type = MTD_NORFLASH;
    flash->mtd.writesize = 1;
    flash->mtd.flags = MTD_CAP_NORFLASH;
    flash->mtd.size = info->sector_size * info->n_sectors;
    flash->mtd._erase = m25p80_erase;
    flash->mtd._read = m25p80_read;
    /* flash protection support for STmicro chips */
    if (JEDEC_MFR(info->jedec_id) == CFI_MFR_ST) {
        flash->mtd._lock = m25p80_lock;
        flash->mtd._unlock = m25p80_unlock;
    /* sst flash chips use AAI word program */
    if (info->flags & SST_WRITE)
        flash->mtd._write = sst_write;
        flash->mtd._write = m25p80_write;
    /* prefer "small sector" erase if possible */
    if (PREFER_SMALL_SECTOR_ERASE && (info->flags & SECT_4K)) {
        flash->erase_opcode = OPCODE_BE_4K;
        flash->mtd.erasesize = 4096;
    } else if (info->flags & SECT_4K_PMC) {
        flash->erase_opcode = OPCODE_BE_4K_PMC;
    } else {
        flash->erase_opcode = OPCODE_SE;
        flash->mtd.erasesize = info->sector_size;
    if (info->flags & M25P_NO_ERASE)
        flash->mtd.flags |= MTD_NO_ERASE;
    ppdata.of_node = spi->dev.of_node;
    flash->mtd.dev.parent = &spi->dev;
    flash->page_size = info->page_size;
    flash->mtd.writebufsize = flash->page_size;
    flash->fast_read = false;
#ifdef CONFIG_OF
    if (np && of_property_read_bool(np, "m25p,fast-read"))
        flash->fast_read = true;
    if (np && of_property_read_bool(np, "m25p,chunked-io")) {
        dev_warn(&spi->dev, "using chunked io\n");
        flash->mtd._read = m25p80_read_chunked;
        flash->mtd._write = m25p80_write_chunked;
#ifdef CONFIG_M25PXX_USE_FAST_READ
    if (info->addr_width)
        flash->addr_width = info->addr_width;
    else {
        /* enable 4-byte addressing if the device exceeds 16MiB */
        if (flash->mtd.size > 0x1000000) {
            flash->addr_width = 4;
            set_4byte(flash, info->jedec_id, 1);
        } else
            flash->addr_width = 3;
    dev_info(&spi->dev, "%s (%lld Kbytes)\n", id->name,
            (long long)flash->mtd.size >> 10);
    pr_debug("mtd .name = %s, .size = 0x%llx (%lldMiB) "
            ".erasesize = 0x%.8x (%uKiB) .numeraseregions = %d\n",
        flash->mtd.name,
        (long long)flash->mtd.size, (long long)(flash->mtd.size >> 20),
        flash->mtd.erasesize, flash->mtd.erasesize / 1024,
        flash->mtd.numeraseregions);
    if (flash->mtd.numeraseregions)
        for (i = 0; i < flash->mtd.numeraseregions; i++)
            pr_debug("mtd.eraseregions[%d] = { .offset = 0x%llx, "
                ".erasesize = 0x%.8x (%uKiB), "
                ".numblocks = %d }\n",
                i, (long long)flash->mtd.eraseregions[i].offset,
                flash->mtd.eraseregions[i].erasesize,
                flash->mtd.eraseregions[i].erasesize / 1024,
                flash->mtd.eraseregions[i].numblocks);
    /* partitions should match sector boundaries; and it may be good to
     * use readonly partitions for writeprotected sectors (BP2..BP0).
    return mtd_device_parse_register(&flash->mtd, NULL, &ppdata,
            data ? data->parts : NULL,
            data ? data->nr_parts : 0);
static int m25p_remove(struct spi_device *spi)
    struct m25p	*flash = dev_get_drvdata(&spi->dev);
    int		status;
    /* Clean up MTD stuff. */
    status = mtd_device_unregister(&flash->mtd);
    if (status == 0) {
        kfree(flash->command);
        kfree(flash);
static struct spi_driver m25p80_driver = {
    .driver = {
        .name	= "m25p80",
        .owner	= THIS_MODULE,
    .id_table	= m25p_ids,
    .probe	= m25p_probe,
    .remove	= m25p_remove,
    /* REVISIT: many of these chips have deep power-down modes, which
     * should clearly be entered on suspend() to minimize power use.
     * And also when they're otherwise idle...
module_spi_driver(m25p80_driver);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Mike Lavender");
MODULE_DESCRIPTION("MTD SPI driver for ST M25Pxx flash chips");
楼主 #3 2020-04-30 14:32:23
已发帖子: 3,403
VoCore: SPI Flash Unique ID
SPI microSD is not done yet ? Just finish an easy driver patch.
This patch is used to get unique id from flash chip. That id is also VoCore Unique ID(unless you change the flash chip). It will be used to get back factory setting(include mac address, wifi parameter, etc.) If you change the flash partition “factory”(512 bytes) and want to change it back. That factory setting can be downloaded from this site by this VoCore Unique ID.
Download new driver file m25p80.c
diff the origin m25p80.c and my m25p80.c
64,66d63
< /* Used for Winbond flashes only. */
< #define OPCODE_WINBOND_ID    0x4b    /* Get flash unique id */
1001,1016d997
< /* flash unique id probe */
< static int unique_id_prob(struct spi_device *spi, u8 *id)
<     int			tmp;
<     u8			code[5];
<     code[0] = OPCODE_WINBOND_ID;
<     tmp = spi_write_then_read(spi, &code, 5, id, 8);
<     if (tmp < 0) {
<         pr_debug("%s: error %d reading UNIQUE ID\n",
<                 dev_name(&spi->dev), tmp);
<         return tmp;
<     return 0;
1125,1136d1105
<     /* show unique id in kernel debug log for w25q64 or w25q128. */
<     if(info->jedec_id == 0xef4017 || info->jedec_id == 0xef4018) {
<         u8 unique_id[8];
<         if(!unique_id_prob(spi, unique_id)) {
<             dev_warn(&spi->dev, "flash id: %02x%02x%02x%02x%02x%02x%02x%02x\n",
<                     unique_id[7], unique_id[6], unique_id[5], unique_id[4],
<                     unique_id[3], unique_id[2], unique_id[1], unique_id[0]);
<         } else {
<             dev_warn(&spi->dev, "failed to get flash unique id.\n");
Part of bootup log:
This is tested by using winbond flash, but from read other chip datasheet, this is supported too.
Now the openwrt is compiled under mac ? I do not have to use linux vm anymore. This makes the process a little faster. Thanks Markus Z for the tip, http://vocore.freshdesk.com/support/discussions/topics/1000033335
PS: there is a small bug in m25p80.c, jedec id of s25fl064k and w25q64 are same. w25q64(Winbond) jedec id is correct, so s25fl064k(Spansion) has a wrong id in the source. Is there anybody know its real jedec id? We should fix that little bug in linux kernel.
This entry was posted in VoCore on 2014-07-23.
#4 2020-05-02 20:09:53
staunchheart
已发帖子: 232
这个记录一下,后面用得到。
并不是所有的FLASH都有唯一ID的,
#5 2020-05-02 20:56:48
raspberryman
已发帖子: 503
staunchheart wrote:
这个记录一下,后面用得到。
并不是所有的FLASH都有唯一ID的,
Macronix/MXIC/宏旺的spi flash W25L64/W25L128/W25L256/W25L512 有 4K OPT区, 可以放密钥:
https://whycan.cn/t_4256.html
#6 2020-05-05 15:51:01
tianjjff
已发帖子: 129
好贴,收藏一下
