楼主 #1 2020-05-09 20:09:25
缥缈九哥
已发帖子: 93
9G-STM32 LwIP测试过程简介-缥缈九哥
9G-STM32 LwIP测试过程简介
一,准备STM32 LwIP软件包
1,在http://www.st.com/mcu/devicedocs-STM32F107RC-110.html
下载lwIP TCP/IP stack demonstration for STM32F107xx connectivity line microcontrollers软件包
an3102.zip
http://www.st.com/stonline/products/support/micro/files/an3102.zip
2,在http://www.st.com/mcu/devicedocs-STM32F107RC-110.html
下载lwIP TCP/IP stack demonstration for STM32F107xx connectivity line microcontrollers文档
16620.pdf
http://www.st.com/stonline/products/literature/an/16620.pdf
3,有关STM32F107VC-PKT的PCB和SCH和测试代码见下面连接:
http://www.freescaleic.org/yuanxihua/blog/10-01/183297_155bc.html
二,建立STM32 LwIP开发工程
1,把an3102.zip解压到D:\works形成工程文件夹:D:\works\STM32F107_ETH_LwIP_V1.0.0 ;
2,进入到目录D:\works\STM32F107_ETH_LwIP_V1.0.0\Project\EWARMv5,双击Project.eww打开工程;
3,在EWARM中的Project->make 编译通过整个项目。
三,修改STM32 LwIP开发工程
1,打开Project->Options ,在Category中选择Debugger的setup驱动用J-Link/J-Trace,在J-Link/J-Trace
中选择connection的SWD接口;
2,对STM32F107VC-PKT开发板加上5V的直流电源,把J-LINK用USB线连接到PC的USB口上,执行Project->Download and Debug
下载代码到板子后,执行Debug->Go 。
四,修改STM32 LwIP开发源码
1,在D:\works\STM32F107_ETH_LwIP_V1.0.0\Project\src\main.c 的53行后添加如下代码:
/ Output a message on Hyperterminal using printf function /
printf("\n\r\n\r\n\r\n\r");
printf("*** STM32F107VC-PKT V1.0 Build by yuanxihua@21cn.com on ("__DATE__ " - " __TIME__ ")\n\r");
printf("*** STM32F107VC-PKT V1.0 Rebooting ...\n\r");
2,在D:\works\STM32F107_ETH_LwIP_V1.0.0\Project\src\stm32f107.c 的包含头文件中添加:
#include "stdio.h"
在第30行选择用MII模式:
#define MII_MODE / MII mode for STM3210C-EVAL Board (MB784) (check jumpers setting) /
//#define RMII_MODE / RMII mode for STM3210C-EVAL Board (MB784) (check jumpers setting) /
在54行后添加:
USART_InitTypeDef USART_InitStructure;
在125行后添加:
/ Configure the com port /
/ USARTx configuration ------------------------------------------------------/
/* USARTx configured as follow:
  • BaudRate = 115200 baud
  • Word Length = 8 Bits
  • One Stop Bit
  • No parity
  • Hardware flow control disabled (RTS and CTS signals)
  • Receive and transmit enabled
    USART_InitStructure.USART_BaudRate = 115200;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No ;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
STM_EVAL_COMInit(COM1, &USART_InitStructure);
  • @brief Retargets the C library printf function to the USART.
  • @param None
  • @retval : None
    int fputc(int ch, FILE *f)
    / Write a character to the USART /
    USART_SendData(USART2, (uint8_t) ch);
/ Loop until the end of transmission /
while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET)
return ch;
  • @brief Get a key from the HyperTerminal
  • @param None
  • @retval : The Key Pressed
    int fgetc(FILE *f)
    / Waiting for user input /
    while ( USART_GetFlagStatus(USART2, USART_FLAG_RXNE) == RESET);
    return (uint8_t)USART2->DR;
在341-344行修改为:
/ ADC Channel10 config --------------------------------------------------------/
/ Relative to STM32F107VC-PKT Board /
/ Configure PC.00 (ADC Channel10) as analog input -------------------------/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
在375-376行修改为:
/ ADC1 regular channel10 configuration /
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_13Cycles5);
3,在D:\works\STM32F107_ETH_LwIP_V1.0.0\Project\src\netconf.c 中的119-121行和316-318行把
IP地址都修改如下:
IP4_ADDR(&ipaddr, 192, 168, 1, 8);
IP4_ADDR(&netmask, 255, 255, 255, 0);
IP4_ADDR(&gw, 192, 168, 1, 1);
4,在D:\works\STM32F107_ETH_LwIP_V1.0.0\Utilities\lwip-1.3.1\port\lwipopts.h中把
#define LWIP_DHCP 1
修改成:
#define LWIP_DHCP 0
5,在D:\works\STM32F107_ETH_LwIP_V1.0.0\Utilities\STM32_EVAL\STM3210C_EVAL\stm3210c_eval.h中把
#define LED1_GPIO_PIN GPIO_Pin_7
修改成:
#define LED1_GPIO_PIN GPIO_Pin_13
#define LED2_GPIO_PIN GPIO_Pin_13
修改成:
#define LED2_GPIO_PIN GPIO_Pin_14
#define LED3_GPIO_PIN GPIO_Pin_3
修改成:
#define LED3_GPIO_PIN GPIO_Pin_15
#define COMn 1
修改成
#define COMn 2
6,同样执行Project->Download and Debug 下载代码到板子后,执行Debug->Go 可以全速仿真运行。
五,演示STM32 LwIP开发工程
1,用交叉网线连接STM32F107VC-PKT到PC的网口,用交叉串口线连接RS232到PC的串口中,再对板子用5V上电
复位启动工作;
2,可以在串口终端上用115200 8N1的格式看到:
*** STM32F107VC-PKT V1.0 Build by yuanxihua@21cn.com on (Jan 12 2010 - 12:43:08)
3,在PC的IE浏览器中输入:http://192.168.1.8/ 回车刷新可以访问到板子,看到Home page主页:
STM32F107 Webserver Demo
Based on the lwIP TCP/IP stack
4,点击Led control从Home page切换LED控制,任意勾上或者去掉LED1-3,再按SEND,可以看到板子的LED相应的
被控制亮或者灭;
5,点击ADC status bar从Led control页面切换到ADC采集,旋转板子上的RV1,可以看到STM32F107 ADC status bar
上绿色的滚动条被ADC的输入电压控制增减;
6,在SecureCRT 5.1终端中可以以telnet协议访问192.168.1.8,端口就是23,连接上了会显示:
Hello. What is your name? ,输入字符串YUANXIHUA,马上会回复Hello YUANXIHUA
#2 2020-05-10 10:56:35
演技担当黄晓明
已发帖子: 189
Re: 9G-STM32 LwIP测试过程简介-缥缈九哥
九歌的教程 很详细
#3 2020-05-10 14:21:29
Lemi
敢问大神,你与新塘的缥缈九哥N3290x系列教程可是同一位,还是慕名冠名的?
#4 2020-05-10 15:21:31
已发帖子: 3,403
嗯,就是同一个 飘渺九哥 呢。
楼主 #5 2020-05-10 20:52:58
缥缈九哥
已发帖子: 93
是的,我就是缥缈九哥。以前推广过新唐M0,M4的。
#6 2020-05-11 09:37:30
真的是很烦
已发帖子: 162
真是久仰大名, 10几年前的时候, 就经常在虾坛看到这个名字
楼主 #7 2020-05-11 21:40:46
缥缈九哥
已发帖子: 93
大虾网那个是我。叫缥缈。
