楼主 #1 2020-05-09 21:58:34
缥缈九哥
已发帖子: 93
基于华芯微特SWM320的SPI接口的24位ADC的AD7124驱动开发--缥缈九哥
C文件
/* @file	ad7124.c															*/
/* @version	V1.00																*/
/* $author:	yuanxihua@21cn.com													*/
/* $Date: 	2019/03/04 02:54 $ 													*/
/* @brief 	SWM320RBT6 Series AD7124 Driver Sample Code							*/
/* @note																		*/
/* Copyright (C) 2010-2019 PM9GZY Technology Corp. All rights reserved.			*/
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "ad7124.h"
_________________________________________________
|	SWM320RBT6						AD7124		|
|	PP1		MISO1		<----		MISO		|
|	PP2		MOSI1		---->		MOSI		|
|	PP3		SCLK1		---->		SCLK		|
|	PP4		NSS1		---->		ANCS		|
|_______________________________________________|
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
#define AD7124_CS_L()		GPIO_ClrBit(GPIOP, PIN4)
#define AD7124_CS_H()		GPIO_SetBit(GPIOP, PIN4)
/* Private macro -------------------------------------------------------------*/
#define INVALID_VAL 		-1 /* Invalid argument */
#define COMM_ERR    		-2 /* Communication error on receive */
#define TIMEOUT     		-3 /* A timeout has occured */
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
void AD7124_Init(void);
void AD7124_Reset(void);
/* Private functions ---------------------------------------------------------*/
void SPI1Init(void)
	SPI_InitStructure SPI_initStruct;
	PORT_Init(PORTP, PIN1, FUNMUX1_SPI1_MISO, 1);
	PORT_Init(PORTP, PIN2, FUNMUX0_SPI1_MOSI, 0);
	PORT_Init(PORTP, PIN3, FUNMUX1_SPI1_SCLK, 0);
	GPIO_Init(GPIOP, PIN4, 1, 0, 0);AD7124_CS_H();//PORT_Init(PORTP, PIN4, FUNMUX0_SPI1_SSEL, 0);
	SPI_initStruct.clkDiv 		= SPI_CLKDIV_64;//0.52US
	SPI_initStruct.FrameFormat 	= SPI_FORMAT_SPI;
	SPI_initStruct.SampleEdge 	= SPI_FIRST_EDGE;
	SPI_initStruct.IdleLevel 	= SPI_LOW_LEVEL;
	SPI_initStruct.WordSize 	= 8;
	SPI_initStruct.Master 		= 1;
	SPI_initStruct.RXHFullIEn 	= 0;
	SPI_initStruct.TXEmptyIEn 	= 0;
	SPI_initStruct.TXCompleteIEn = 0;
	SPI_Init(SPI1, &SPI_initStruct);
	SPI_Open(SPI1);
	AD7124_Reset();
	AD7124_Init();
void AD7124_Read_Register(ad7124_reg_t *reg)
	uint8_t cmd=reg->addr+0x40,width=reg->size,admit=reg->rw;uint32_t val=0;
	if(!(admit&AD7124_RO)){return;}
	AD7124_CS_L();
	SPI_ReadWrite(SPI1,cmd);while(width--){val<<=8;val|=SPI_ReadWrite(SPI1,0x55)&0xff;}reg->value=val;
	AD7124_CS_H();
void AD7124_Write_Register(ad7124_reg_t *reg)
	uint8_t cmd=reg->addr+0x00,width=reg->size,admit=reg->rw;uint32_t val=reg->value;
	if(!(admit&AD7124_WO)){return;}
	AD7124_CS_L();
	SPI_ReadWrite(SPI1,cmd);while(width--){SPI_ReadWrite(SPI1,(val>>(width*8))&0xff);}
	AD7124_CS_H();
void AD7124_Reset(void){AD7124_CS_L();for(uint8_t i=0;i<8;i++){SPI_ReadWrite(SPI1,0xFF);}AD7124_CS_H();osDelay(10);}
void AD7124_Init(void){for(uint8_t i=AD7124_Status;i<AD7124_REG_END;i++){AD7124_Write_Register(&ad7124_regs[i]);}}
uint8_t AD7124_CRC8(uint8_t *buf, uint8_t len)
    uint8_t i,crc=0,MULA=AD7124_CRC8_POLYNOMIAL_REPRESENTATION;
    while(len--){for(i=0x80;i!=0;i>>=1){if(((crc&0x80)!=0)!=((*buf&i)!=0)){crc<<=1;crc^=MULA;}else{crc<<=1;}}buf++;}
    return crc;
void AD7124_Gain(void){}
uint8_t AD7124_Read(uint32_t *data)
	int32_t timeout=1000000;uint8_t total=0;
	uint8_t lastch=20;uint8_t nowch=20;
	while(1)
		while(--timeout)
			/* Read the value of the Status Register */
			AD7124_Read_Register(&ad7124_regs[AD7124_Status]);
			/* Check the RDY bit in the Status Register */
			if((ad7124_regs[AD7124_Status].value & AD7124_STATUS_REG_RDY)==0)
			{nowch = AD7124_STATUS_REG_CH_ACTIVE(ad7124_regs[AD7124_Status].value);break;}
		if(timeout<=0){printf("AD Conv Timeout!!!\n\r");return total;}
		if(lastch!=nowch)
			/* Read the value of the Data Register */
			AD7124_Read_Register(&ad7124_regs[AD7124_Data]);
			/* Get the read result */
			data[nowch] = ad7124_regs[AD7124_Data].value; data[nowch]&=0xFFFFFF;
			lastch=nowch;total++;
//			printf("AD7124_Read data[%d] = 0x%08x \n\r",nowch,data[nowch]);
		if(total>=4){break;}
	return total;
void AD7124_Test(void)
	uint32_t adc[4]={0};float val[4];
//	AD7124_CS_L(); SPI_ReadWrite(SPI1,0x55);AD7124_CS_H();
//	AD7124_Read_Register(&ad7124_regs[AD7124_ID]);
//	printf("AD7124_ID = 0x%02x \n\r",ad7124_regs[AD7124_ID].value);
//	AD7124_Read_Register(&ad7124_regs[AD7124_CHANNEL_0]);
//	printf("AD7124_CHANNEL_0 = 0x%08x \n\r",ad7124_regs[AD7124_CHANNEL_0].value);
//	ad7124_regs[AD7124_FILTER_0].value=0x555555;
//	AD7124_Write_Register(&ad7124_regs[AD7124_FILTER_0]);
//	AD7124_Read_Register(&ad7124_regs[AD7124_FILTER_0]);
//	printf("AD7124_FILTER_0 = 0x%08x \n\r",ad7124_regs[AD7124_FILTER_0].value);
//	for(uint8_t i=AD7124_Status;i<AD7124_REG_END;i++)
//		AD7124_Read_Register(&ad7124_regs[i]);
//		printf("ad7124_regs[0x%02x]=0x%08x \n\r",i,ad7124_regs[i].value);
	AD7124_Read(adc);
//	printf("ADC[0]=0x%08x,ADC[1]=0x%08x,ADC[2]=0x%08x,ADC[3]=0x%08x\n\r",adc[0],adc[1],adc[2],adc[3]);
	for(uint8_t i=0;i<4;i++)
		val[i]=adc[i];val[i]*=2.500;val[i]/=0xffffff;
	val[0]/=128;val[1]/=16;val[2]/=4;val[3]/=1;
//	printf("VAL[0]=%3.10f V\n\r",val[0]);
//	printf("VAL[1]=%3.10f V\n\r",val[1]);
//	printf("VAL[2]=%3.10f V\n\r",val[2]);
//	printf("VAL[3]=%3.10f V\n\r",val[3]);
//	val[0]*=1000;val[1]*=1000;val[2]*=1000;val[3]*=1000;
	printf("%3.10f,%3.10f,%3.10f,%3.10f\n\r",val[0],val[1],val[2],val[3]);
	OLED_Volute(val);
	osDelay(200);
H文件
#ifndef __AD7124_H__
#define __AD7124_H__
#define AD7124_CRC8_POLYNOMIAL_REPRESENTATION		0x07 	/* x8 + x2 + x + 1 */
#define AD7124_WO 1   /* Write */
#define	AD7124_RO 2   /* Read */
#define	AD7124_RW 3   /* Read and Write */
/* AD7124 Register Map */
#define AD7124_COMM_REG      0x00
#define AD7124_STATUS_REG    0x00
#define AD7124_ADC_CTRL_REG  0x01
#define AD7124_DATA_REG      0x02
#define AD7124_IO_CTRL1_REG  0x03
#define AD7124_IO_CTRL2_REG  0x04
#define AD7124_ID_REG        0x05
#define AD7124_ERR_REG       0x06
#define AD7124_ERREN_REG     0x07
#define AD7124_CH0_MAP_REG   0x09
#define AD7124_CH1_MAP_REG   0x0A
#define AD7124_CH2_MAP_REG   0x0B
#define AD7124_CH3_MAP_REG   0x0C
#define AD7124_CH4_MAP_REG   0x0D
#define AD7124_CH5_MAP_REG   0x0E
#define AD7124_CH6_MAP_REG   0x0F
#define AD7124_CH7_MAP_REG   0x10
#define AD7124_CH8_MAP_REG   0x11
#define AD7124_CH9_MAP_REG   0x12
#define AD7124_CH10_MAP_REG  0x13
#define AD7124_CH11_MAP_REG  0x14
#define AD7124_CH12_MAP_REG  0x15
#define AD7124_CH13_MAP_REG  0x16
#define AD7124_CH14_MAP_REG  0x17
#define AD7124_CH15_MAP_REG  0x18
#define AD7124_CFG0_REG      0x19
#define AD7124_CFG1_REG      0x1A
#define AD7124_CFG2_REG      0x1B
#define AD7124_CFG3_REG      0x1C
#define AD7124_CFG4_REG      0x1D
#define AD7124_CFG5_REG      0x1E
#define AD7124_CFG6_REG      0x1F
#define AD7124_CFG7_REG      0x20
#define AD7124_FILT0_REG     0x21
#define AD7124_FILT1_REG     0x22
#define AD7124_FILT2_REG     0x23
#define AD7124_FILT3_REG     0x24
#define AD7124_FILT4_REG     0x25
#define AD7124_FILT5_REG     0x26
#define AD7124_FILT6_REG     0x27
#define AD7124_FILT7_REG     0x28
#define AD7124_OFFS0_REG     0x29
#define AD7124_OFFS1_REG     0x2A
#define AD7124_OFFS2_REG     0x2B
#define AD7124_OFFS3_REG     0x2C
#define AD7124_OFFS4_REG     0x2D
#define AD7124_OFFS5_REG     0x2E
#define AD7124_OFFS6_REG     0x2F
#define AD7124_OFFS7_REG     0x30
#define AD7124_GAIN0_REG     0x31
#define AD7124_GAIN1_REG     0x32
#define AD7124_GAIN2_REG     0x33
#define AD7124_GAIN3_REG     0x34
#define AD7124_GAIN4_REG     0x35
#define AD7124_GAIN5_REG     0x36
#define AD7124_GAIN6_REG     0x37
#define AD7124_GAIN7_REG     0x38
/* Communication Register bits */
#define AD7124_COMM_REG_WEN    					(0 << 7)
#define AD7124_COMM_REG_WR     					(0 << 6)
#define AD7124_COMM_REG_RD     					(1 << 6)
#define AD7124_COMM_REG_RA(x)  					((x) & 0x3F)
/* Status Register bits */
#define AD7124_STATUS_REG_RDY          			(1 << 7)
#define AD7124_STATUS_REG_ERROR_FLAG   			(1 << 6)
#define AD7124_STATUS_REG_POR_FLAG     			(1 << 4)
#define AD7124_STATUS_REG_CH_ACTIVE(x) 			((x) & 0xF)
/* ADC_Control Register bits */
#define AD7124_ADC_CTRL_REG_DOUT_RDY_DEL   		(1 << 12)
#define AD7124_ADC_CTRL_REG_CONT_READ      		(1 << 11)
#define AD7124_ADC_CTRL_REG_DATA_STATUS    		(1 << 10)
#define AD7124_ADC_CTRL_REG_CS_EN          		(1 << 9)
#define AD7124_ADC_CTRL_REG_REF_EN         		(1 << 8)
#define AD7124_ADC_CTRL_REG_POWER_MODE(x)  		(((x) & 0x3) << 6)
#define AD7124_ADC_CTRL_REG_MODE(x)        		(((x) & 0xF) << 2)
#define AD7124_ADC_CTRL_REG_CLK_SEL(x))    		(((x) & 0x3) << 0)
/* IO_Control_1 Register bits */
#define AD7124_IO_CTRL1_REG_GPIO_DAT2     		(1 << 23)
#define AD7124_IO_CTRL1_REG_GPIO_DAT1     		(1 << 22)
#define AD7124_IO_CTRL1_REG_GPIO_CTRL2    		(1 << 19)
#define AD7124_IO_CTRL1_REG_GPIO_CTRL1    		(1 << 18)
#define AD7124_IO_CTRL1_REG_PDSW          		(1 << 15)
#define AD7124_IO_CTRL1_REG_IOUT1(x)      		(((x) & 0x7) << 11)
#define AD7124_IO_CTRL1_REG_IOUT0(x)      		(((x) & 0x7) << 8)
#define AD7124_IO_CTRL1_REG_IOUT_CH1(x)   		(((x) & 0xF) << 4)
#define AD7124_IO_CTRL1_REG_IOUT_CH0(x)   		(((x) & 0xF) << 0)
/*IO_Control_1 AD7124-8 specific bits */
#define AD7124_8_IO_CTRL1_REG_GPIO_DAT4 		(1 << 23)
#define AD7124_8_IO_CTRL1_REG_GPIO_DAT3     	(1 << 22)
#define AD7124_8_IO_CTRL1_REG_GPIO_DAT2     	(1 << 21)
#define AD7124_8_IO_CTRL1_REG_GPIO_DAT1     	(1 << 20)
#define AD7124_8_IO_CTRL1_REG_GPIO_CTRL4    	(1 << 19)
#define AD7124_8_IO_CTRL1_REG_GPIO_CTRL3    	(1 << 18)
#define AD7124_8_IO_CTRL1_REG_GPIO_CTRL2    	(1 << 17)
#define AD7124_8_IO_CTRL1_REG_GPIO_CTRL1    	(1 << 16)
/* IO_Control_2 Register bits */
#define AD7124_IO_CTRL2_REG_GPIO_VBIAS7   		(1 << 15)
#define AD7124_IO_CTRL2_REG_GPIO_VBIAS6   		(1 << 14)
#define AD7124_IO_CTRL2_REG_GPIO_VBIAS5   		(1 << 11)
#define AD7124_IO_CTRL2_REG_GPIO_VBIAS4   		(1 << 10)
#define AD7124_IO_CTRL2_REG_GPIO_VBIAS3   		(1 << 5)
#define AD7124_IO_CTRL2_REG_GPIO_VBIAS2   		(1 << 4)
#define AD7124_IO_CTRL2_REG_GPIO_VBIAS1   		(1 << 1)
#define AD7124_IO_CTRL2_REG_GPIO_VBIAS0   		(1 << 0)
/*IO_Control_2 AD7124-8 specific bits */
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS15  	(1 << 15)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS14  	(1 << 14)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS13  	(1 << 13)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS12  	(1 << 12)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS11  	(1 << 11)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS10  	(1 << 10)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS9   	(1 << 9)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS8   	(1 << 8)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS7   	(1 << 7)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS6   	(1 << 6)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS5   	(1 << 5)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS4   	(1 << 4)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS3   	(1 << 3)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS2   	(1 << 2)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS1   	(1 << 1)
#define AD7124_8_IO_CTRL2_REG_GPIO_VBIAS0   	(1 << 0)
/* ID Register bits */
#define AD7124_ID_REG_DEVICE_ID(x)   			(((x) & 0xF) << 4)
#define AD7124_ID_REG_SILICON_REV(x) 			(((x) & 0xF) << 0)
/* Error Register bits */
#define AD7124_ERR_REG_LDO_CAP_ERR        		(1 << 19)
#define AD7124_ERR_REG_ADC_CAL_ERR        		(1 << 18)
#define AD7124_ERR_REG_ADC_CONV_ERR       		(1 << 17)
#define AD7124_ERR_REG_ADC_SAT_ERR        		(1 << 16)
#define AD7124_ERR_REG_AINP_OV_ERR        		(1 << 15)
#define AD7124_ERR_REG_AINP_UV_ERR        		(1 << 14)
#define AD7124_ERR_REG_AINM_OV_ERR        		(1 << 13)
#define AD7124_ERR_REG_AINM_UV_ERR        		(1 << 12)
#define AD7124_ERR_REG_REF_DET_ERR        		(1 << 11)
#define AD7124_ERR_REG_DLDO_PSM_ERR       		(1 << 9)
#define AD7124_ERR_REG_ALDO_PSM_ERR       		(1 << 7)
#define AD7124_ERR_REG_SPI_IGNORE_ERR     		(1 << 6)
#define AD7124_ERR_REG_SPI_SLCK_CNT_ERR   		(1 << 5)
#define AD7124_ERR_REG_SPI_READ_ERR       		(1 << 4)
#define AD7124_ERR_REG_SPI_WRITE_ERR      		(1 << 3)
#define AD7124_ERR_REG_SPI_CRC_ERR        		(1 << 2)
#define AD7124_ERR_REG_MM_CRC_ERR         		(1 << 1)
/* Error_En Register bits */
#define AD7124_ERREN_REG_MCLK_CNT_EN           	(1 << 22)
#define AD7124_ERREN_REG_LDO_CAP_CHK_TEST_EN   	(1 << 21)
#define AD7124_ERREN_REG_LDO_CAP_CHK(x)        	(((x) & 0x3) << 19)
#define AD7124_ERREN_REG_ADC_CAL_ERR_EN        	(1 << 18)
#define AD7124_ERREN_REG_ADC_CONV_ERR_EN       	(1 << 17)
#define AD7124_ERREN_REG_ADC_SAT_ERR_EN        	(1 << 16)
#define AD7124_ERREN_REG_AINP_OV_ERR_EN        	(1 << 15)
#define AD7124_ERREN_REG_AINP_UV_ERR_EN       	(1 << 14)
#define AD7124_ERREN_REG_AINM_OV_ERR_EN       	(1 << 13)
#define AD7124_ERREN_REG_AINM_UV_ERR_EN        	(1 << 12)
#define AD7124_ERREN_REG_REF_DET_ERR_EN       	(1 << 11)
#define AD7124_ERREN_REG_DLDO_PSM_TRIP_TEST_EN 	(1 << 10)
#define AD7124_ERREN_REG_DLDO_PSM_ERR_ERR      	(1 << 9)
#define AD7124_ERREN_REG_ALDO_PSM_TRIP_TEST_EN 	(1 << 8)
#define AD7124_ERREN_REG_ALDO_PSM_ERR_EN       	(1 << 7)
#define AD7124_ERREN_REG_SPI_IGNORE_ERR_EN     	(1 << 6)
#define AD7124_ERREN_REG_SPI_SCLK_CNT_ERR_EN   	(1 << 5)
#define AD7124_ERREN_REG_SPI_READ_ERR_EN       	(1 << 4)
#define AD7124_ERREN_REG_SPI_WRITE_ERR_EN      	(1 << 3)
#define AD7124_ERREN_REG_SPI_CRC_ERR_EN        	(1 << 2)
#define AD7124_ERREN_REG_MM_CRC_ERR_EN         	(1 << 1)
/* Channel Registers 0-15 bits */
#define AD7124_CH_MAP_REG_CH_ENABLE    			(1 << 15)
#define AD7124_CH_MAP_REG_SETUP(x)     			(((x) & 0x7) << 12)
#define AD7124_CH_MAP_REG_AINP(x)      			(((x) & 0x1F) << 5)
#define AD7124_CH_MAP_REG_AINM(x)      			(((x) & 0x1F) << 0)
/* Configuration Registers 0-7 bits */
#define AD7124_CFG_REG_BIPOLAR     				(1 << 11)
#define AD7124_CFG_REG_BURNOUT(x)  				(((x) & 0x3) << 9)
#define AD7124_CFG_REG_REF_BUFP    				(1 << 8)
#define AD7124_CFG_REG_REF_BUFM    				(1 << 7)
#define AD7124_CFG_REG_AIN_BUFP    				(1 << 6)
#define AD7124_CFG_REG_AINN_BUFM   				(1 << 5)
#define AD7124_CFG_REG_REF_SEL(x)  				((x) & 0x3) << 3
#define AD7124_CFG_REG_PGA(x)      				(((x) & 0x7) << 0)
/* Filter Register 0-7 bits */
#define AD7124_FILT_REG_FILTER(x)         		(((x) & 0x7) << 21)
#define AD7124_FILT_REG_REJ60             		(1 << 20)
#define AD7124_FILT_REG_POST_FILTER(x)    		(((x) & 0x7) << 17)
#define AD7124_FILT_REG_SINGLE_CYCLE      		(1 << 16)
#define AD7124_FILT_REG_FS(x)             		(((x) & 0x7FF) << 0)
/*! Device register info */
typedef struct
	uint8_t addr;
	int32_t value;
	uint8_t size;
	uint8_t rw;
}ad7124_reg_t;
/*! Array holding the info for the ad7124 registers - address, initial value,
    size and access type. */
ad7124_reg_t ad7124_regs[] =
	{0x00,     0x00, 1, AD7124_RO}, /* AD7124_Status */
	//使能DATA_STATUS、REF_EN 和 FULL POWER的连续采样模式,禁止用DOUT_RDY_DEL、CONT_READ和CS_EN,内时钟CLK无输出
	{0x01,   0x0580, 2, AD7124_RW}, /* AD7124_ADC_Control */
	{0x02, 0x000000, 3, AD7124_RO}, /* AD7124_Data */
	//禁用IOUT0、IOUT1、不用PDSW低边桥开关
	{0x03, 0x000000, 3, AD7124_RW}, /* AD7124_IOCon1 */
	//禁用VBIAS0-VBIAS7
	{0x04,   0x0000, 2, AD7124_RW}, /* AD7124_IOCon2 */
	{0x05,     0x04, 1, AD7124_RO}, /* AD7124_ID */
	{0x06, 0x000000, 3, AD7124_RO}, /* AD7124_Error */
	//不用ERROR功能
	{0x07, 0x000000, 3, AD7124_RW}, /* AD7124_Error_En */
	{0x08,     0x00, 1, AD7124_RO}, /* AD7124_Mclk_Count */
	//使能通道0、选择Setup0配置组、输入脚分配AIN0->AINP,AIN1->AINM
	{0x09,   0x8001, 2, AD7124_RW}, /* AD7124_Channel_0 */
	//使能通道1、选择Setup1配置组、输入脚分配AIN2->AINP,AIN3->AINM
	{0x0A,   0x9043, 2, AD7124_RW}, /* AD7124_Channel_1 */
	//使能通道2、选择Setup2配置组、输入脚分配AIN4->AINP,AIN5->AINM
	{0x0B,   0xA085, 2, AD7124_RW}, /* AD7124_Channel_2 */
	//使能通道3、选择Setup3配置组、输入脚分配AIN6->AINP,AIN7->AINM
	{0x0C,   0xB0C7, 2, AD7124_RW}, /* AD7124_Channel_3 */
	{0x0D,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_4 */
	{0x0E,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_5 */
	{0x0F,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_6 */
	{0x10,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_7 */
	{0x11,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_8 */
	{0x12,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_9 */
	{0x13,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_10 */
	{0x14,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_11 */
	{0x15,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_12 */
	{0x16,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_13 */
	{0x17,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_14 */
	{0x18,   0x0000, 2, AD7124_RW}, /* AD7124_Channel_15 */
	//使能单极性、REF_BUF、AIN_BUF缓冲和REF_SEL内部基准、PGA=128
	{0x19,   0x01F7, 2, AD7124_RW}, /* AD7124_Config_0 */
	//使能单极性、REF_BUF、AIN_BUF缓冲和REF_SEL内部基准、PGA=16
	{0x1A,   0x01F4, 2, AD7124_RW}, /* AD7124_Config_1 */
	//使能单极性、REF_BUF、AIN_BUF缓冲和REF_SEL内部基准、PGA=4
	{0x1B,   0x01F2, 2, AD7124_RW}, /* AD7124_Config_2 */
	{0x1C,   0x01F0, 2, AD7124_RW}, /* AD7124_Config_3 */
	{0x1D,   0x09F0, 2, AD7124_RW}, /* AD7124_Config_4 */
	{0x1E,   0x09F0, 2, AD7124_RW}, /* AD7124_Config_5 */
	{0x1F,   0x09F0, 2, AD7124_RW}, /* AD7124_Config_6 */
	{0x20,   0x09F0, 2, AD7124_RW}, /* AD7124_Config_7 */
	{0x21, 0x160180, 3, AD7124_RW}, /* AD7124_Filter_0 */
	{0x22, 0x160180, 3, AD7124_RW}, /* AD7124_Filter_1 */
	{0x23, 0x160180, 3, AD7124_RW}, /* AD7124_Filter_2 */
	{0x24, 0x160180, 3, AD7124_RW}, /* AD7124_Filter_3 */
	{0x25, 0x160180, 3, AD7124_RW}, /* AD7124_Filter_4 */
	{0x26, 0x160180, 3, AD7124_RW}, /* AD7124_Filter_5 */
	{0x27, 0x160180, 3, AD7124_RW}, /* AD7124_Filter_6 */
	{0x28, 0x160180, 3, AD7124_RW}, /* AD7124_Filter_7 */
	{0x29, 0x800000, 3, AD7124_RW}, /* AD7124_Offset_0 */
	{0x2A, 0x800000, 3, AD7124_RW}, /* AD7124_Offset_1 */
	{0x2B, 0x800000, 3, AD7124_RW}, /* AD7124_Offset_2 */
	{0x2C, 0x800000, 3, AD7124_RW}, /* AD7124_Offset_3 */
	{0x2D, 0x800000, 3, AD7124_RW}, /* AD7124_Offset_4 */
	{0x2E, 0x800000, 3, AD7124_RW}, /* AD7124_Offset_5 */
	{0x2F, 0x800000, 3, AD7124_RW}, /* AD7124_Offset_6 */
	{0x30, 0x800000, 3, AD7124_RW}, /* AD7124_Offset_7 */
	//增益寄存器
	{0x31, 0x500000, 3, AD7124_RW}, /* AD7124_Gain_0 */
	//增益寄存器
	{0x32, 0x500000, 3, AD7124_RW}, /* AD7124_Gain_1 */
	//增益寄存器
	{0x33, 0x500000, 3, AD7124_RW}, /* AD7124_Gain_2 */
	//增益寄存器
	{0x34, 0x500000, 3, AD7124_RW}, /* AD7124_Gain_3 */
	{0x35, 0x500000, 3, AD7124_RW}, /* AD7124_Gain_4 */
	{0x36, 0x500000, 3, AD7124_RW}, /* AD7124_Gain_5 */
	{0x37, 0x500000, 3, AD7124_RW}, /* AD7124_Gain_6 */
	{0x38, 0x500000, 3, AD7124_RW}, /* AD7124_Gain_7 */
/*! AD7124 registers list*/
enum ad7124_registers
	AD7124_Status = 0x00,
	AD7124_ADC_CONTROL,
	AD7124_Data,
	AD7124_IOCONTROL_1,
	AD7124_IOCONTROL_2,
	AD7124_ID,
	AD7124_Error,
	AD7124_ERROR_EN,
	AD7124_MCLK_COUNT,
	AD7124_CHANNEL_0,
	AD7124_CHANNEL_1,
	AD7124_CHANNEL_2,
	AD7124_CHANNEL_3,
	AD7124_CHANNEL_4,
	AD7124_CHANNEL_5,
	AD7124_CHANNEL_6,
	AD7124_CHANNEL_7,
	AD7124_CHANNEL_8,
	AD7124_CHANNEL_9,
	AD7124_CHANNEL_10,
	AD7124_CHANNEL_11,
	AD7124_CHANNEL_12,
	AD7124_CHANNEL_13,
	AD7124_CHANNEL_14,
	AD7124_CHANNEL_15,
	AD7124_CONFIG_0,
	AD7124_CONFIG_1,
	AD7124_CONFIG_2,
	AD7124_CONFIG_3,
	AD7124_CONFIG_4,
	AD7124_CONFIG_5,
	AD7124_CONFIG_6,
	AD7124_CONFIG_7,
	AD7124_FILTER_0,
	AD7124_FILTER_1,
	AD7124_FILTER_2,
	AD7124_FILTER_3,
	AD7124_FILTER_4,
	AD7124_FILTER_5,
	AD7124_FILTER_6,
	AD7124_FILTER_7,
	AD7124_OFFSET_0,
	AD7124_OFFSET_1,
	AD7124_OFFSET_2,
	AD7124_OFFSET_3,
	AD7124_OFFSET_4,
	AD7124_OFFSET_5,
	AD7124_OFFSET_6,
	AD7124_OFFSET_7,
	AD7124_GAIN_0,
	AD7124_GAIN_1,
	AD7124_GAIN_2,
	AD7124_GAIN_3,
	AD7124_GAIN_4,
	AD7124_GAIN_5,
	AD7124_GAIN_6,
	AD7124_GAIN_7,
	AD7124_REG_END
#endif /* __AD7124_H__ */
最近编辑记录 缥缈九哥 (2020-05-09 23:20:39)
#2 2020-05-13 10:57:12
华芯微特
已发帖子: 168
Re: 基于华芯微特SWM320的SPI接口的24位ADC的AD7124驱动开发--缥缈九哥
谢谢九哥~~~
