我看了路由器 里面没有用完IP地址 但是我去ifconfig wlan0 up的时候就是报错出现
ifconfig: SIOCSIFFLAGS: Operation not permitted这样的
Could not set interface wlan0 flags (UP): Operation not permitted
nl80211: Could not set interface 'wlan0' UP
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=4 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Set mode ifindex 4 iftype 2 (STATION)
nl80211: Unsubscribe mgmt frames handle 0x889105e1 (mode change)
wlan0: Failed to initialize driver interface
Failed to add interface wlan0
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
Off-channel: Clear pending Action frame TX (pending_action_tx=(nil)
udhcpc: started, v1.29.2
udhcpc: sending discover
udhcpc: sendto: Network is down
但是用ifconfig -a 下面又有wlan0
eth0 Link encap:Ethernet HWaddr 02:01:46:EC:EC:AA
inet addr:192.168.0.10 Bcast:192.168.255.255 Mask:255.255.0.0
BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:38
lo Link encap:Local Loopback
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:4 errors:0 dropped:0 overruns:0 frame:0
TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:352 (352.0 B) TX bytes:352 (352.0 B)
usb0 Link encap:Ethernet HWaddr 82:9E:1C:3B:22:52
wlan0 Link encap:Ethernet HWaddr 00:E0:4C:B7:23:00
多点信息啊,加载驱动是什么情况。
有梦的地方 wrote:
多点信息啊,加载驱动是什么情况。
[ 14.695000] r8723bs: module is from the staging directory, the quality is unknown, you have been warned.
[ 14.712216] RTL8723BS: module init start
[ 14.716157] RTL8723BS: rtl8723bs v4.3.5.5_12290.20140916_BTCOEX20140507-4E40
[ 14.723295] RTL8723BS: rtl8723bs BT-Coex version = BTCOEX20140507-4E40
[ 14.743011] pnetdev = c30f7000
[ 17.062401] RTL8723BS: rtw_ndev_init(wlan0)
[ 17.138082] RTL8723BS: module init ret =0
和这个帖子是一样的情况 但是不知道 我要弄什么文件进去
https://whycan.cn/t_604_27.html
以前是可以的 上一次就是把路由器重启后 有可以了 ,
rtl8723bs_nic.bin这个文件我也有啊 在rtlwifi目录下有的
最近编辑记录 无情一刀 (2020-05-30 15:31:43)
哇酷小二 wrote:
这个问题感觉和路由器没有关系。
在/lib/firmware/rtlwifi文件下也有rtl8723bs_nic.bin这个文件
使用wifi如果是当前里面设置了密码错误,下一次启动的时候 就会是一直在连接导致程序不能执行和触摸
[ 173.980781] RTL8723BS: nolinked power save leave
[ 175.639335] RTL8723BS: nolinked power save enter
[ 180.860817] RTL8723BS: nolinked power save leave
[ 182.519460] RTL8723BS: nolinked power save enter
[ 187.740708] RTL8723BS: nolinked power save leave
[ 189.399334] RTL8723BS: nolinked power save enter
[ 194.620788] RTL8723BS: nolinked power save leave
[ 196.279352] RTL8723BS: nolinked power save enter
[ 201.500849] RTL8723BS: nolinked power save leave
[ 203.159462] RTL8723BS: nolinked power save enter
[ 208.380802] RTL8723BS: nolinked power save leave
[ 210.039339] RTL8723BS: nolinked power save enter
也就是当前热点没有开启的时候 会一直连接 导致 程序里面不会往下执行
哇酷小二 wrote:
udhcpc 进程塞住了,加 & 后台运行符号
是.conf里面的wifi名称没有开启,
哇酷小二 wrote:
没看懂
就是我的wpa_supplicant.conf文件的设置的wifi名称我没有开启 然后程序就会自动连接这个wpa_supplicant.conf里面wifi名称,导致一直处于连接 ,程序也没有往下执行,
哇酷小二 wrote:
命令行是啥?
system("ifconfig wlan0 up");
system("wpa_supplicant -B -d -i wlan0 -c /etc/wpa_supplicant.conf");
Delay_MSec(10);
system("udhcpc -i wlan0");
这里我就是开机启动自动连接去 ,
不知道什么弄成 连接多少次之后 没有成功就不连了
11楼你不看的么?
就是如果是开机启动自动连接时候,是否可以设置为连接多少次之后 ,就不连接了
哇酷小二 wrote:
shell脚本里面弄个计数器,满了就退出。
我在这里面加了这个country 不起作用,在脚本里面写没有连接成功的 不是很懂 ,麻烦你说的详细点哦哦
ctrl_interface_group=0
update_config=1
country=10
network={
ssid="iPhone7p"
psk="wo1003676315"
key_mgmt=WPA-PSK WPA-EAP IEEE8021X NONE
priority=5
看了不知道怎么去关联起来
请问楼主解决了吗。我现在是报同样的错误
