项目地址: https://github.com/lvgl/lv_port_linux_frame_buffer
递归克隆到本地:
git clone https://github.com/lvgl/lv_port_linux_frame_buffer.git
cd lv_port_linux_frame_buffer
git submodule update --init --recursive
上面速度太慢了, 本站下载: lv_port_linux_frame_buffer.tgz (消耗晕哥70M空间 ~~~)
md5校验码: 4f1d02832086dc1011c98e64c2abe08c
原子哥视频教程: https://www.bilibili.com/video/BV1ug4y1q7ha
这个视频教程基于LVGL6, 与最新的LVGL7接口又有很大变化, 但是仍然有很重要的参考价值.
最近编辑记录 明月照我沟渠 (2020-08-04 10:01:35)
感谢分享
QtCreator 编辑/编译
我觉得可以在windows下使用QT,虚拟机下总感觉卡卡的,也可能我电脑不行
我感觉速度还挺不错的, 至少比Eclipse快多了.
diff --git a/Makefile b/Makefile
index bb8e264..6bf149c 100644
--- a/Makefile
+++ b/Makefile
@@ -5,7 +5,7 @@ CC ?= gcc
LVGL_DIR_NAME ?= lvgl
LVGL_DIR ?= ${shell pwd}
CFLAGS ?= -O3 -g0 -I$(LVGL_DIR)/ -Wall -Wshadow -Wundef -Wmaybe-uninitialized -Wmissing-prototypes -Wno-discarded-qualifiers -Wall -Wextra -Wno-unused-function -Wundef -Wno-error=strict-prototypes -Wpointer-arith -fno-strict-aliasing -Wno-error=cpp -Wuninitialized -Wmaybe-uninitialized -Wno-unused-parameter -Wno-missing-field-initializers -Wtype-limits -Wsizeof-pointer-memaccess -Wno-format-nonliteral -Wno-cast-qual -Wunreachable-code -Wno-switch-default -Wno-switch-enum -Wreturn-type -Wmultichar -Wformat-security -Wno-ignored-qualifiers -Wno-error=pedantic -Wno-sign-compare -Wno-error=missing-prototypes -Wdouble-promotion -Wclobbered -Wdeprecated -Wempty-body -Wtype-limits -Wshift-negative-value -Wstack-usage=1024 -Wno-unused-value -Wno-unused-parameter -Wno-missing-field-initializers -Wuninitialized -Wmaybe-uninitialized -Wall -Wextra -Wno-unused-parameter -Wno-missing-field-initializers -Wtype-limits -Wsizeof-pointer-memaccess -Wno-format-nonliteral -Wpointer-arith -Wno-cast-qual -Wmissing-prototypes -Wunreachable-code -Wno-switch-default -Wswitch-enum -Wreturn-type -Wmultichar -Wno-discarded-qualifiers -Wformat-security -Wno-ignored-qualifiers -Wno-sign-compare
-LDFLAGS ?= -lSDL2 -lm
+LDFLAGS ?= -lSDL2 -lm -linput
BIN = demo
diff --git a/lv_conf.h b/lv_conf.h
index b31a820..e03cf82 100644
--- a/lv_conf.h
+++ b/lv_conf.h
@@ -20,8 +20,8 @@
/* Maximal horizontal and vertical resolution to support by the library.*/
-#define LV_HOR_RES_MAX (480)
-#define LV_VER_RES_MAX (320)
+#define LV_HOR_RES_MAX (800)
+#define LV_VER_RES_MAX (480)
/* Color depth:
* - 1: 1 byte per pixel
@@ -190,7 +190,7 @@ typedef void * lv_fs_drv_user_data_t;
#define LV_USE_USER_DATA 0
/*1: Show CPU usage and FPS count in the right bottom corner*/
-#define LV_USE_PERF_MONITOR 1
+#define LV_USE_PERF_MONITOR 0
* Image decoder and cache
diff --git a/lv_drivers b/lv_drivers
--- a/lv_drivers
+++ b/lv_drivers
@@ -1 +1 @@
-Subproject commit 4e26c37e7ba7518c4f48cabf31c53aeeace35b7d
+Subproject commit 4e26c37e7ba7518c4f48cabf31c53aeeace35b7d-dirty
diff --git a/lv_drv_conf.h b/lv_drv_conf.h
index 975c7b4..3e69dd3 100644
--- a/lv_drv_conf.h
+++ b/lv_drv_conf.h
@@ -310,22 +310,22 @@
* Touchscreen as libinput interface (for Linux based systems)
#ifndef USE_LIBINPUT
-# define USE_LIBINPUT 0
+# define USE_LIBINPUT 1
#if USE_LIBINPUT
-# define LIBINPUT_NAME "/dev/input/event0" /*You can use the "evtest" Linux tool to get the list of devices and test them*/
+# define LIBINPUT_NAME "/dev/input/event2" /*You can use the "evtest" Linux tool to get the list of devices and test them*/
#endif /*USE_LIBINPUT*/
* Mouse or touchpad as evdev interface (for Linux based systems)
#ifndef USE_EVDEV
-# define USE_EVDEV 0
+# define USE_EVDEV 1
#if USE_EVDEV
-# define EVDEV_NAME "/dev/input/event0" /*You can use the "evtest" Linux tool to get the list of devices and test them*/
+# define EVDEV_NAME "/dev/input/event2" /*You can use the "evtest" Linux tool to get the list of devices and test them*/
# define EVDEV_SWAP_AXES 0 /*Swap the x and y axes of the touchscreen*/
# define EVDEV_SCALE 0 /* Scale input, e.g. if touchscreen resolution does not match display resolution */
diff --git a/main.c b/main.c
index d286cc7..ea505b4 100644
--- a/main.c
+++ b/main.c
@@ -1,5 +1,6 @@
#include "lvgl/lvgl.h"
#include "lv_drivers/display/fbdev.h"
+#include "lv_drivers/indev/evdev.h"
#include "lv_examples/lv_examples.h"
#include <unistd.h>
#include <pthread.h>
@@ -30,6 +31,24 @@ int main(void)
disp_drv.flush_cb = fbdev_flush;
lv_disp_drv_register(&disp_drv);
+ /* Add the mouse (or touchpad) as input device
+ * Use the 'mouse' driver which reads the PC's mouse*/
+ evdev_init();
+ evdev_set_file("/dev/input/event2");
+ /* Set up touchpad input device interface */
+ lv_indev_drv_t indev_drv;
+ lv_indev_drv_init(&indev_drv);
+ indev_drv.type = LV_INDEV_TYPE_POINTER;
+ indev_drv.read_cb = evdev_read;
+ lv_indev_t *indev = lv_indev_drv_register(&indev_drv);
+ lv_obj_t *cursor_img = lv_img_create(lv_scr_act(), NULL);
+ lv_img_set_src(cursor_img, LV_SYMBOL_OK);
+ lv_indev_set_cursor(indev, cursor_img);
/*Create a Demo*/
lv_demo_widgets();按上面的patch, VMWARE + Ubuntu + LittleVGL + FrameBuffer支持鼠标了
给勤劳的楼主点个赞
我这里测试,光标移动不正常,一直都在左上角,移不动,系统是ubuntu 18.04.
明月照我沟渠 wrote:
这是虚拟机跑Linux?
达克罗德 wrote:
明月照我沟渠 wrote:
这是虚拟机跑Linux?
对的, 就是Ubuntu 18.04
学习了!
试了一下,输出提示成功,无任何画面出来
sudo ./demo
The framebuffer device was opened successfully.
800x600, 32bpp
The framebuffer device was mapped to memory successfully.
