楼主 #1 2020-08-08 12:36:37
小果果
已发帖子: 61
buildroot编译后出现奇怪的信息
echo "buildroot" > /home/xiaoguoguo/buildroot-2017.08/output/target/etc/hostname
/bin/sed -i -e '$a \127.0.1.1\tbuildroot' -e '/^127.0.1.1/d' /home/xiaoguoguo/buildroot-2017.08/output/target/etc/hosts
mkdir -p /home/xiaoguoguo/buildroot-2017.08/output/target/etc
echo "Welcome to Buildroot" > /home/xiaoguoguo/buildroot-2017.08/output/target/etc/issue
/bin/sed -i -e s,^root:[^:]*:,root::, /home/xiaoguoguo/buildroot-2017.08/output/target/etc/shadow
rm -f /home/xiaoguoguo/buildroot-2017.08/output/build/locales.nopurge
for i in C en_US locale-archive; do echo $i >> /home/xiaoguoguo/buildroot-2017.08/output/build/locales.nopurge; done
for dir in ; do for langdir in $dir/; do if [ -e "${langdir}" ]; then grep -qx "${langdir##/}" /home/xiaoguoguo/buildroot-2017.08/output/build/locales.nopurge || rm -rf $langdir; fi done; done
if [ -d /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/X11/locale ]; then for lang in C en_US; do if [ -f /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/X11/locale/$lang/XLC_LOCALE ]; then echo "$lang/XLC_LOCALE: $lang"; fi done > /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/X11/locale/locale.dir; fi
rm -rf /home/xiaoguoguo/buildroot-2017.08/output/target/usr/include /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/aclocal \
/home/xiaoguoguo/buildroot-2017.08/output/target/usr/lib/pkgconfig /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/pkgconfig \
/home/xiaoguoguo/buildroot-2017.08/output/target/usr/lib/cmake /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/cmake
find /home/xiaoguoguo/buildroot-2017.08/output/target/usr/{lib,share}/ -name '*.cmake' -print0 | xargs -0 rm -f
find /home/xiaoguoguo/buildroot-2017.08/output/target/lib/ /home/xiaoguoguo/buildroot-2017.08/output/target/usr/lib/ /home/xiaoguoguo/buildroot-2017.08/output/target/usr/libexec/ \
\( -name '.a' -o -name '.la' \) -print0 | xargs -0 rm -f
find: `/home/xiaoguoguo/buildroot-2017.08/output/target/usr/libexec/': 没有那个文件或目录
rm -rf /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/gdb
rm -rf /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/bash-completion
rm -rf /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/zsh
rm -rf /home/xiaoguoguo/buildroot-2017.08/output/target/usr/man /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/man
rm -rf /home/xiaoguoguo/buildroot-2017.08/output/target/usr/info /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/info
rm -rf /home/xiaoguoguo/buildroot-2017.08/output/target/usr/doc /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/doc
rm -rf /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share/gtk-doc
rmdir /home/xiaoguoguo/buildroot-2017.08/output/target/usr/share 2>/dev/null || true
find /home/xiaoguoguo/buildroot-2017.08/output/target -type f \( -perm /111 -o -name '.so' \) -not \( -name 'libpthread.so' -o -name 'ld-.so' -o -name '*.ko' \) -print0 | xargs -0 /home/xiaoguoguo/buildroot-2017.08/output/host/bin/arm-buildroot-linux-uclibcgnueabi-strip --remove-section=.comment --remove-section=.note 2>/dev/null || true
find /home/xiaoguoguo/buildroot-2017.08/output/target/lib/ -type f -name 'libpthread.so' | \
xargs -r /home/xiaoguoguo/buildroot-2017.08/output/host/bin/arm-buildroot-linux-uclibcgnueabi-strip --remove-section=.comment --remove-section=.note --strip-debug
find /home/xiaoguoguo/buildroot-2017.08/output/target/lib/ -type f -name 'ld-.so' | \
test -f /home/xiaoguoguo/buildroot-2017.08/output/target/etc/ld.so.conf && \
{ echo "ERROR: we shouldn't have a /etc/ld.so.conf file"; exit 1; } || true
test -d /home/xiaoguoguo/buildroot-2017.08/output/target/etc/ld.so.conf.d && \
{ echo "ERROR: we shouldn't have a /etc/ld.so.conf.d directory"; exit 1; } || true
echo "NAME=Buildroot"; \
echo "VERSION=2017.08"; \
echo "ID=buildroot"; \
echo "VERSION_ID=2017.08"; \
echo "PRETTY_NAME=\"Buildroot 2017.08\"" \
) > /home/xiaoguoguo/buildroot-2017.08/output/target/etc/os-release
每次编译都会出现,奇怪的是也不影响生成和使用。。。。。
