上面是命令行操作,
如果想要把 固件更新整合到自己的应用程序,
把下面的代码整进来即可:
https://git.busybox.net/busybox/tree/miscutils/flashcp.c
/* vi: set sw=4 ts=4: */
* busybox reimplementation of flashcp
* (C) 2009 Stefan Seyfried <seife@sphairon.com>
* Licensed under GPLv2, see file LICENSE in this source tree.
//config:config FLASHCP
//config: bool "flashcp (5.3 kb)"
//config: default n # doesn't build on Ubuntu 8.04
//config: help
//config: The flashcp binary, inspired by mtd-utils as of git head 5eceb74f7.
//config: This utility is used to copy images into a MTD device.
//applet:IF_FLASHCP(APPLET(flashcp, BB_DIR_USR_SBIN, BB_SUID_DROP))
/* not NOEXEC: if flash operation stalls, use less memory in "hung" process */
//kbuild:lib-$(CONFIG_FLASHCP) += flashcp.o
//usage:#define flashcp_trivial_usage
//usage: "-v FILE MTD_DEVICE"
//usage:#define flashcp_full_usage "\n\n"
//usage: "Copy an image to MTD device\n"
//usage: "\n -v Verbose"
#include "libbb.h"
#include <mtd/mtd-user.h>
/* If 1, simulates "flashing" by writing to existing regular file */
#define MTD_DEBUG 0
#define OPT_v (1 << 0)
#define BUFSIZE (4 * 1024)
static void progress(int mode, uoff_t count, uoff_t total)
uoff_t percent;
if (!option_mask32) //if (!(option_mask32 & OPT_v))
return;
percent = count * 100;
if (total)
percent = (unsigned) (percent / total);
printf("\r%s: %"OFF_FMT"u/%"OFF_FMT"u (%u%%) ",
(mode < 0) ? "Erasing block" : ((mode == 0) ? "Writing kb" : "Verifying kb"),
count, total, (unsigned)percent);
fflush_all();
static void progress_newline(void)
return;
bb_putchar('\n');
int flashcp_main(int argc, char **argv) MAIN_EXTERNALLY_VISIBLE;
int flashcp_main(int argc UNUSED_PARAM, char **argv)
int fd_f, fd_d; /* input file and mtd device file descriptors */
int i;
uoff_t erase_count;
struct mtd_info_user mtd;
struct erase_info_user e;
struct stat statb;
// const char *filename, *devicename;
RESERVE_CONFIG_UBUFFER(buf, BUFSIZE);
RESERVE_CONFIG_UBUFFER(buf2, BUFSIZE);
/*opts =*/ getopt32(argv, "^" "v" "\0" "=2"/*exactly 2 non-option args: file,dev*/);
argv += optind;
// filename = *argv++;
// devicename = *argv;
#define filename argv[0]
#define devicename argv[1]
/* open input file and mtd device and do sanity checks */
fd_f = xopen(filename, O_RDONLY);
fstat(fd_f, &statb);
fd_d = xopen(devicename, O_SYNC | O_RDWR);
#if !MTD_DEBUG
if (ioctl(fd_d, MEMGETINFO, &mtd) < 0) {
bb_error_msg_and_die("%s is not a MTD flash device", devicename);
if (statb.st_size > mtd.size) {
bb_error_msg_and_die("%s bigger than %s", filename, devicename);
#else
mtd.erasesize = 64 * 1024;
/* always erase a complete block */
erase_count = (uoff_t)(statb.st_size + mtd.erasesize - 1) / mtd.erasesize;
/* erase 1 block at a time to be able to give verbose output */
e.length = mtd.erasesize;
#if 0
/* (1) bloat
* (2) will it work for multi-gigabyte devices?
* (3) worse wrt error detection granularity
/* optimization: if not verbose, erase in one go */
if (!opts) { // if (!(opts & OPT_v))
e.length = mtd.erasesize * erase_count;
erase_count = 1;
e.start = 0;
for (i = 1; i <= erase_count; i++) {
progress(-1, i, erase_count);
#if !MTD_DEBUG
if (ioctl(fd_d, MEMERASE, &e) < 0) {
bb_perror_msg_and_die("erase error at 0x%llx on %s",
(long long)e.start, devicename);
#else
usleep(100*1000);
e.start += mtd.erasesize;
progress_newline();
/* doing this outer loop gives significantly smaller code
* than doing two separate loops for writing and verifying */
for (i = 0; i <= 1; i++) {
uoff_t done;
unsigned count;
xlseek(fd_f, 0, SEEK_SET);
xlseek(fd_d, 0, SEEK_SET);
done = 0;
count = BUFSIZE;
while (1) {
uoff_t rem;
progress(i, done / 1024, (uoff_t)statb.st_size / 1024);
rem = statb.st_size - done;
if (rem == 0)
break;
if (rem < BUFSIZE)
count = rem;
xread(fd_f, buf, count);
if (i == 0) {
int ret;
if (count < BUFSIZE)
memset((char*)buf + count, 0, BUFSIZE - count);
errno = 0;
ret = full_write(fd_d, buf, BUFSIZE);
if (ret != BUFSIZE) {
bb_perror_msg_and_die("write error at 0x%"OFF_FMT"x on %s, "
"write returned %d",
done, devicename, ret);
} else { /* i == 1 */
xread(fd_d, buf2, count);
if (memcmp(buf, buf2, count) != 0) {
bb_error_msg_and_die("verification mismatch at 0x%"OFF_FMT"x", done);
done += count;
progress_newline();
/* we won't come here if there was an error */
return EXIT_SUCCESS;
}离线
那么如果是SD Nand,该怎么操作呢?
谢谢
上面是命令行操作,
把下面的代码整进来即可:
/* vi: set sw=4 ts=4: */ /* * busybox reimplementation of flashcp * * (C) 2009 Stefan Seyfried <seife@sphairon.com> * * Licensed under GPLv2, see file LICENSE in this source tree. */ //config:config FLASHCP //config: bool "flashcp (5.3 kb)" //config: default n # doesn't build on Ubuntu 8.04 //config: help //config: The flashcp binary, inspired by mtd-utils as of git head 5eceb74f7. //config: This utility is used to copy images into a MTD device. //applet:IF_FLASHCP(APPLET(flashcp, BB_DIR_USR_SBIN, BB_SUID_DROP)) /* not NOEXEC: if flash operation stalls, use less memory in "hung" process */ //kbuild:lib-$(CONFIG_FLASHCP) += flashcp.o //usage:#define flashcp_trivial_usage //usage: "-v FILE MTD_DEVICE" //usage:#define flashcp_full_usage "\n\n" //usage: "Copy an image to MTD device\n" //usage: "\n -v Verbose" #include "libbb.h" #include <mtd/mtd-user.h> /* If 1, simulates "flashing" by writing to existing regular file */ #define MTD_DEBUG 0 #define OPT_v (1 << 0) #define BUFSIZE (4 * 1024) static void progress(int mode, uoff_t count, uoff_t total) { uoff_t percent; if (!option_mask32) //if (!(option_mask32 & OPT_v)) return; percent = count * 100; if (total) percent = (unsigned) (percent / total); printf("\r%s: %"OFF_FMT"u/%"OFF_FMT"u (%u%%) ", (mode < 0) ? "Erasing block" : ((mode == 0) ? "Writing kb" : "Verifying kb"), count, total, (unsigned)percent); fflush_all(); } static void progress_newline(void) { if (!option_mask32) //if (!(option_mask32 & OPT_v)) return; bb_putchar('\n'); } int flashcp_main(int argc, char **argv) MAIN_EXTERNALLY_VISIBLE; int flashcp_main(int argc UNUSED_PARAM, char **argv) { int fd_f, fd_d; /* input file and mtd device file descriptors */ int i; uoff_t erase_count; struct mtd_info_user mtd; struct erase_info_user e; struct stat statb; // const char *filename, *devicename; RESERVE_CONFIG_UBUFFER(buf, BUFSIZE); RESERVE_CONFIG_UBUFFER(buf2, BUFSIZE); /*opts =*/ getopt32(argv, "^" "v" "\0" "=2"/*exactly 2 non-option args: file,dev*/); argv += optind; // filename = *argv++; // devicename = *argv; #define filename argv[0] #define devicename argv[1] /* open input file and mtd device and do sanity checks */ fd_f = xopen(filename, O_RDONLY); fstat(fd_f, &statb); fd_d = xopen(devicename, O_SYNC | O_RDWR); #if !MTD_DEBUG if (ioctl(fd_d, MEMGETINFO, &mtd) < 0) { bb_error_msg_and_die("%s is not a MTD flash device", devicename); } if (statb.st_size > mtd.size) { bb_error_msg_and_die("%s bigger than %s", filename, devicename); } #else mtd.erasesize = 64 * 1024; #endif /* always erase a complete block */ erase_count = (uoff_t)(statb.st_size + mtd.erasesize - 1) / mtd.erasesize; /* erase 1 block at a time to be able to give verbose output */ e.length = mtd.erasesize; #if 0 /* (1) bloat * (2) will it work for multi-gigabyte devices? * (3) worse wrt error detection granularity */ /* optimization: if not verbose, erase in one go */ if (!opts) { // if (!(opts & OPT_v)) e.length = mtd.erasesize * erase_count; erase_count = 1; } #endif e.start = 0; for (i = 1; i <= erase_count; i++) { progress(-1, i, erase_count); #if !MTD_DEBUG if (ioctl(fd_d, MEMERASE, &e) < 0) { bb_perror_msg_and_die("erase error at 0x%llx on %s", (long long)e.start, devicename); } #else usleep(100*1000); #endif e.start += mtd.erasesize; } progress_newline(); /* doing this outer loop gives significantly smaller code * than doing two separate loops for writing and verifying */ for (i = 0; i <= 1; i++) { uoff_t done; unsigned count; xlseek(fd_f, 0, SEEK_SET); xlseek(fd_d, 0, SEEK_SET); done = 0; count = BUFSIZE; while (1) { uoff_t rem; progress(i, done / 1024, (uoff_t)statb.st_size / 1024); rem = statb.st_size - done; if (rem == 0) break; if (rem < BUFSIZE) count = rem; xread(fd_f, buf, count); if (i == 0) { int ret; if (count < BUFSIZE) memset((char*)buf + count, 0, BUFSIZE - count); errno = 0; ret = full_write(fd_d, buf, BUFSIZE); if (ret != BUFSIZE) { bb_perror_msg_and_die("write error at 0x%"OFF_FMT"x on %s, " "write returned %d", done, devicename, ret); } } else { /* i == 1 */ xread(fd_d, buf2, count); if (memcmp(buf, buf2, count) != 0) { bb_error_msg_and_die("verification mismatch at 0x%"OFF_FMT"x", done); } } done += count; } progress_newline(); } /* we won't come here if there was an error */ return EXIT_SUCCESS; }
SD NAND不就是 /dev/mmcblk* 么?直接 dd 命令操作不就可以吗?又不用擦除。
要写到代码里面呢?
好的,谢谢!
哇酷小二 wrote:
就是通用的io函数
c代码:
打开 open(/dev/mmcblk*)
写 write(/dev/mmcblk*)
关闭 close(/dev/mmcblk*)如果你需要校验,再读回就行: read(/dev/mmcblk*)
