项目地址: https://github.com/littlevgl/emscripten
演示地址: https://littlevgl.com/live-demo
演示地址: https://littlevgl.com/demo-basic
演示地址: https://littlevgl.com/demo-theme-night
演示地址: https://littlevgl.com/demo-theme-material
演示地址: https://littlevgl.com/demo-touchpadless
安装 Emscripten SDK
cd /opt
cd emsdk
git pull
./emsdk install latest
./emsdk activate latest
source ./emsdk_env.sh
下载emscripten项目源码编译:
cd /opt
cd emscripten
git submodule update --init --recursive
make
以下三个文件是编译生成:
lvgl.html
lvgl.js
lvgl.wasm
浏览器打开 lvgl.html
ubuntu 14.04 编译失败:
root@debugdump:/opt/emscripten# make
CC lvgl/lv_draw/lv_draw_line.c
emscripten:INFO: generating system asset: is_vanilla.txt... (this will be cached in "/root/.emscripten_cache/is_vanilla.txt" for subsequent builds)
/opt/emsdk/clang/e1.38.26_64bit/llc: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /opt/emsdk/clang/e1.38.26_64bit/llc)
/opt/emsdk/clang/e1.38.26_64bit/llc: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/emsdk/clang/e1.38.26_64bit/llc)
emscripten:INFO: - ok
/opt/emsdk/clang/e1.38.26_64bit/clang++: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.20' not found (required by /opt/emsdk/clang/e1.38.26_64bit/clang++)
/opt/emsdk/clang/e1.38.26_64bit/clang++: /usr/lib/x86_64-linux-gnu/libstdc++.so.6: version `GLIBCXX_3.4.21' not found (required by /opt/emsdk/clang/e1.38.26_64bit/clang++)
shared:ERROR: '/opt/emsdk/clang/e1.38.26_64bit/clang++ --version' failed (1)
make: *** [lvgl/lv_draw/lv_draw_line.o] Error 1
root@debugdump:/opt/emscripten# ls /usr/lib/x86_64-linux-gnu/libstdc++.so.6*
/usr/lib/x86_64-linux-gnu/libstdc++.so.6 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19
root@debugdump:/opt/emscripten# ls /usr/lib/x86_64-linux-gnu/libstdc++.so.6* -l
lrwxrwxrwx 1 root root 19 Feb 14 2018 /usr/lib/x86_64-linux-gnu/libstdc++.so.6 -> libstdc++.so.6.0.19
-rw-r--r-- 1 root root 979056 Feb 14 2018 /usr/lib/x86_64-linux-gnu/libstdc++.so.6.0.19
root@debugdump:/opt/emscripten#ubuntu 16.04 编译没有问题:
root@ubuntu:/opt/emscripten# make
shared:INFO: (Emscripten: Running sanity checks)
root:WARNING: retrieving port: sdl2 from https://github.com/emscripten-ports/SDL2/archive/version_17.zip
root:WARNING: unpacking port: sdl2
emscripten:INFO: generating port: sdl2.bc... (this will be cached in "/root/.emscripten_cache/asmjs/sdl2.bc" for subsequent builds)
CC lvgl/lv_draw/lv_draw_rbasic.c
CC lvgl/lv_draw/lv_draw_img.c
CC lvgl/lv_draw/lv_draw_arc.c
CC lvgl/lv_draw/lv_draw_rect.c
CC lvgl/lv_draw/lv_draw_triangle.c
CC lvgl/lv_draw/lv_draw.c
CC lvgl/lv_draw/lv_draw_label.c
CC lvgl/lv_draw/lv_draw_vbasic.c
CC lvgl/lv_fonts/lv_font_builtin.c
CC lvgl/lv_fonts/lv_font_dejavu_20.c
CC lvgl/lv_fonts/lv_font_dejavu_40.c
CC lvgl/lv_fonts/lv_font_dejavu_30_latin_sup.c
CC lvgl/lv_fonts/lv_font_dejavu_10_cyrillic.c
CC lvgl/lv_fonts/lv_font_monospace_8.c
CC lvgl/lv_fonts/lv_font_dejavu_10_latin_sup.c
CC lvgl/lv_fonts/lv_font_symbol_40.c
CC lvgl/lv_fonts/lv_font_symbol_10.c
CC lvgl/lv_fonts/lv_font_dejavu_10.c
CC lvgl/lv_fonts/lv_font_dejavu_40_cyrillic.c
CC lvgl/lv_fonts/lv_font_dejavu_20_cyrillic.c
CC lvgl/lv_fonts/lv_font_dejavu_30_cyrillic.c
CC lvgl/lv_fonts/lv_font_dejavu_20_latin_sup.c
CC lvgl/lv_fonts/lv_font_dejavu_40_latin_sup.c
CC lvgl/lv_fonts/lv_font_symbol_30.c
CC lvgl/lv_fonts/lv_font_symbol_20.c
CC lvgl/lv_fonts/lv_font_dejavu_30.c
CC lvgl/lv_objx/lv_cont.c
CC lvgl/lv_objx/lv_img.c
CC lvgl/lv_objx/lv_kb.c
CC lvgl/lv_objx/lv_table.c
CC lvgl/lv_objx/lv_roller.c
CC lvgl/lv_objx/lv_cb.c
CC lvgl/lv_objx/lv_led.c
CC lvgl/lv_objx/lv_calendar.c
CC lvgl/lv_objx/lv_gauge.c
CC lvgl/lv_objx/lv_page.c
CC lvgl/lv_objx/lv_list.c
CC lvgl/lv_objx/lv_bar.c
CC lvgl/lv_objx/lv_tabview.c
CC lvgl/lv_objx/lv_mbox.c
CC lvgl/lv_objx/lv_objx_templ.c
CC lvgl/lv_objx/lv_sw.c
CC lvgl/lv_objx/lv_label.c
CC lvgl/lv_objx/lv_slider.c
CC lvgl/lv_objx/lv_ddlist.c
CC lvgl/lv_objx/lv_imgbtn.c
CC lvgl/lv_objx/lv_line.c
CC lvgl/lv_objx/lv_chart.c
CC lvgl/lv_objx/lv_btnm.c
CC lvgl/lv_objx/lv_arc.c
CC lvgl/lv_objx/lv_preload.c
CC lvgl/lv_objx/lv_win.c
CC lvgl/lv_objx/lv_lmeter.c
CC lvgl/lv_objx/lv_btn.c
CC lvgl/lv_objx/lv_ta.c
CC lvgl/lv_misc/lv_log.c
CC lvgl/lv_misc/lv_fs.c
CC lvgl/lv_misc/lv_task.c
CC lvgl/lv_misc/lv_circ.c
CC lvgl/lv_misc/lv_anim.c
CC lvgl/lv_misc/lv_color.c
CC lvgl/lv_misc/lv_txt.c
CC lvgl/lv_misc/lv_math.c
CC lvgl/lv_misc/lv_mem.c
CC lvgl/lv_misc/lv_font.c
CC lvgl/lv_misc/lv_ll.c
CC lvgl/lv_misc/lv_area.c
CC lvgl/lv_misc/lv_templ.c
CC lvgl/lv_misc/lv_ufs.c
CC lvgl/lv_misc/lv_gc.c
CC lvgl/lv_hal/lv_hal_tick.c
CC lvgl/lv_hal/lv_hal_indev.c
CC lvgl/lv_hal/lv_hal_disp.c
CC lvgl/lv_themes/lv_theme_mono.c
CC lvgl/lv_themes/lv_theme_templ.c
CC lvgl/lv_themes/lv_theme_material.c
CC lvgl/lv_themes/lv_theme.c
CC lvgl/lv_themes/lv_theme_night.c
CC lvgl/lv_themes/lv_theme_zen.c
CC lvgl/lv_themes/lv_theme_nemo.c
CC lvgl/lv_themes/lv_theme_alien.c
CC lvgl/lv_themes/lv_theme_default.c
CC lvgl/lv_core/lv_group.c
CC lvgl/lv_core/lv_style.c
CC lvgl/lv_core/lv_indev.c
CC lvgl/lv_core/lv_vdb.c
CC lvgl/lv_core/lv_obj.c
CC lvgl/lv_core/lv_refr.c
CC lv_examples/lv_tests/lv_test_theme/lv_test_theme_1.c
CC lv_examples/lv_tests/lv_test_theme/lv_test_theme_2.c
CC lv_examples/lv_tests/lv_test_stress/lv_test_stress.c
CC lv_examples/lv_tests/lv_test_objx/lv_test_img/img_flower_icon.c
CC lv_examples/lv_tests/lv_test_objx/lv_test_arc/lv_test_arc.c
CC lv_examples/lv_tests/lv_test_group/lv_test_group.c
CC lv_examples/lv_apps/demo/demo.c
CC lv_examples/lv_apps/demo/img_bubble_pattern.c
CC lv_drivers/display/monitor.c
CC lv_drivers/indev/mouse.c
CC lv_drivers/indev/keyboard.c
CC lv_drivers/indev/mousewheel.c
CC main.c
CC mouse_cursor_icon.c
LINK lvgl.html
emscripten:INFO: generating system library: libdlmalloc.bc... (this will be cached in "/root/.emscripten_cache/asmjs/libdlmalloc.bc" for subsequent builds)
emscripten:INFO: generating system library: libgl.bc... (this will be cached in "/root/.emscripten_cache/asmjs/libgl.bc" for subsequent builds)
emscripten:INFO: generating system library: libc.bc... (this will be cached in "/root/.emscripten_cache/asmjs/libc.bc" for subsequent builds)
emscripten:INFO: generating system library: libcompiler_rt.a... (this will be cached in "/root/.emscripten_cache/asmjs/libcompiler_rt.a" for subsequent builds)
emscripten:INFO: generating system library: libc-wasm.bc... (this will be cached in "/root/.emscripten_cache/asmjs/libc-wasm.bc" for subsequent builds)
emscripten:INFO: generating system library: libc-extras.bc... (this will be cached in "/root/.emscripten_cache/asmjs/libc-extras.bc" for subsequent builds)
emscripten:INFO: generating system asset: generated_struct_info.json... (this will be cached in "/root/.emscripten_cache/asmjs/generated_struct_info.json" for subsequent builds)
root@ubuntu:/opt/emscripten#在线
真棒?,三星手机自带浏览器可以直接运行例子
可以说是很six了
编译好了lvgl.html、lvgl.js、lvgl.wasm三个文件也有了,但是filefox,Google Chrome,Ie都没有显示啊,只有空白
lvgl.html、lvgl.js、lvgl.wasm-----------哪有这个3个文件,我比较下
发现两个错误,不知道怎么处理了
wasm streaming compile failed: TypeError: Response has unsupported MIME type
falling back to ArrayBuffer instantiation
全屏或者大分辨率 canvas报错
大分辨率时出错,不显示
lvgl还是7.0的时候用过一会,好久没用了现在做的这么炫啦
web开发用vue不香吗
tocurd wrote:
web开发用vue不香吗
主要是为了可以使用同一套代码,省去多次开发的成本。
@晕哥 wrote:
下载emscripten项目源码编译:
cd /opt
git clone https://github.com/littlevgl/emscripten.git
cd emscripten
make
git clone emscripten.git 后,目录下没有Makefile, make不了
用README.md 的方法也报错:
root@lc-es-vm:/home/test/lv_web_emscripten/cmbuild# emcmake cmake ..
File "/home/test/emsdk/upstream/emscripten/emcmake.py", line 45
args.append(f'-DCMAKE_CROSSCOMPILING_EMULATOR={node_js}')
SyntaxError: invalid syntax
怎么处理?python 文件有语法错误?python 文件应没有问题的, 是哪个环境不对吗?
最近编辑记录 acom2024 (2024-01-29 17:11:38)
