楼主 #1 2020-09-16 09:56:46
olili
已发帖子: 19
请坑友门帮忙调一个4.3寸480x272的屏的驱动参数(用的mango-pi系统),或者推荐一款好用的屏
各位坑友好,最近折腾V3S的板子,要上一块4.3寸,分辨率480x272的触摸屏,型号为KD043WQTPA035-01,控制IC:ST7282,RGB接口,文档上的timing参数如下:
datasheet
datasheet
请问如何设置以下参数呢?(下面的是我设置的其中一套参数,但是会出现花屏的现象)
;lcd0 configuration
;lcd_if:               0:hv(sync+de); 1:8080; 2:ttl; 3:lvds; 4:dsi; 5:edp; 6:extend dsi
;lcd_x:                lcd horizontal resolution
;lcd_y:                lcd vertical resolution
;lcd_width:            width of lcd in mm
;lcd_height:           height of lcd in mm
;lcd_dclk_freq:        in MHZ unit
;lcd_pwm_freq:         in HZ unit
;lcd_pwm_pol:          lcd backlight PWM polarity
;lcd_pwm_max_limit     lcd backlight PWM max limit(<=255)
;lcd_hbp:              hsync back porch
;lcd_ht:               hsync total cycle
;lcd_vbp:              vsync back porch
;lcd_vt:               vysnc total cycle
;lcd_hspw:             hsync plus width
;lcd_vspw:             vysnc plus width
;lcd_lvds_if:          0:single link;  1:dual link
;lcd_lvds_colordepth:  0:8bit; 1:6bit
;lcd_lvds_mode:        0:NS mode; 1:JEIDA mode
;lcd_frm:              0:disable; 1:enable rgb666 dither; 2:enable rgb656 dither
;lcd_io_phase:         0:noraml; 1:intert phase(0~3bit: vsync phase; 4~7bit:hsync phase;
;                      8~11bit:dclk phase; 12~15bit:de phase)
;lcd_gamma_en          lcd gamma correction enable
;lcd_bright_curve_en   lcd bright curve correction enable
;lcd_cmap_en           lcd color map function enable
;deu_mode              0:smoll lcd screen; 1:large lcd screen(larger than 10inch)
;lcdgamma4iep:         Smart Backlight parameter, lcd gamma vale * 10;
;                      decrease it while lcd is not bright enough; increase while lcd is too bright
;smart_color           90:normal lcd screen 65:retina lcd screen(9.7inch)
[lcd0_para]
lcd_used            = 1
lcd_driver_name     = "vs043con08v0"
lcd_if              = 0
lcd_x               = 480
lcd_y               = 272
lcd_width           = 0
lcd_height          = 0
lcd_dclk_freq       = 9
lcd_pwm_used        = 1
lcd_pwm_ch          = 0
lcd_pwm_freq        = 50000
lcd_pwm_pol         = 1
lcd_pwm_max_limit   = 255
lcd_hbp             = 2
lcd_ht              = 525
lcd_hspw            = 41
lcd_vbp             = 2
lcd_vt              = 286
lcd_vspw            = 2
lcd_frm             = 0
lcd_hv_clk_phase    = 0
lcd_hv_sync_polarity = 0
lcd_gamma_en        = 0
lcd_bright_curve_en = 1
lcd_cmap_en         = 0
lcdgamma4iep        = 22
花屏实拍:
请坑友门帮我看看应该怎样设置正确的参数,或者推荐一款好用的屏也是极好的,谢谢!:)
#2 2020-09-16 10:40:45
拉轰的脚踏车
已发帖子: 288
Re: 请坑友门帮忙调一个4.3寸480x272的屏的驱动参数(用的mango-pi系统),或者推荐一款好用的屏
检查连接线问题, 是不是很长?有多长?
楼主 #3 2020-09-16 10:52:30
olili
已发帖子: 19
拉轰的脚踏车 wrote:
检查连接线问题, 是不是很长?有多长?
并不长,就是用的屏自带的排线。也不应该是板子的问题,有朋友同样板子接5寸的电容屏是OK的。
#4 2020-09-16 11:01:27
redstar
检查一下焊接,看有无短路断路,再不行de引脚中间串一个电阻,电阻值大小都调一下。
楼主 #5 2020-09-16 13:22:34
olili
已发帖子: 19
感谢各位坑友。可能是板子焊接的问题,我又换了一个上古时代的荔枝派zero,用的https://whycan.com/t_3400.html第20楼的固件,发现屏能跑起来,除了分辨率不对(固件是800x480的),屏背光有点闪,触摸没有以外都还挺好,请问分辨率在哪里改呢?
dtb内容如下:
/dts-v1/;
	#address-cells = <0x1>;
	#size-cells = <0x1>;
	interrupt-parent = <0x1>;
	model = "Lichee Pi Zero with Dock";
	compatible = "licheepi,licheepi-zero-dock", "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
	chosen {
		ranges;
		framebuffer@0 {
			compatible = "allwinner,simple-framebuffer", "simple-framebuffer";
			allwinner,pipeline = "de0-lcd0";
			clocks = <0x2 0x21 0x3 0x0 0x3 0x6 0x2 0x40>;
			status = "disabled";
	cpus {
		#size-cells = <0x0>;
		cpu@0 {
			compatible = "arm,cortex-a7";
			device_type = "cpu";
			reg = <0x0>;
			clocks = <0x2 0xe>;
	display-engine {
		compatible = "allwinner,sun8i-v3s-display-engine";
		allwinner,pipelines = <0x4>;
	timer {
		compatible = "arm,armv7-timer";
		interrupts = <0x1 0xd 0xf08 0x1 0xe 0xf08 0x1 0xb 0xf08 0x1 0xa 0xf08>;
	clocks {
		ranges;
		osc24M_clk {
			#clock-cells = <0x0>;
			compatible = "fixed-clock";
			clock-frequency = <0x16e3600>;
			linux,phandle = <0xc>;
			phandle = <0xc>;
		osc32k_clk {
			clock-frequency = <0x8000>;
			linux,phandle = <0xd>;
			phandle = <0xd>;
	soc {
		compatible = "simple-bus";
		ranges;
		clock@1000000 {
			compatible = "allwinner,sun8i-v3s-de2-clk";
			reg = <0x1000000 0x100000>;
			clocks = <0x2 0x3f 0x2 0x23>;
			clock-names = "mod", "bus";
			resets = <0x2 0x22>;
			#clock-cells = <0x1>;
			#reset-cells = <0x1>;
			linux,phandle = <0x3>;
			phandle = <0x3>;
		mixer@1100000 {
			compatible = "allwinner,sun8i-v3s-de2-mixer";
			reg = <0x1100000 0x100000>;
			clocks = <0x3 0x0 0x3 0x6>;
			clock-names = "bus", "mod";
			resets = <0x3 0x0>;
			assigned-clocks = <0x3 0x6>;
			assigned-clock-rates = <0x8f0d180>;
			linux,phandle = <0x4>;
			phandle = <0x4>;
			ports {
				port@1 {
					reg = <0x1>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x5>;
						linux,phandle = <0x6>;
						phandle = <0x6>;
		syscon@1c00000 {
			compatible = "allwinner,sun8i-v3s-system-controller", "syscon";
			reg = <0x1c00000 0x1000>;
			linux,phandle = <0x16>;
			phandle = <0x16>;
		lcd-controller@1c0c000 {
			compatible = "allwinner,sun8i-v3s-tcon";
			reg = <0x1c0c000 0x1000>;
			interrupts = <0x0 0x56 0x4>;
			clocks = <0x2 0x21 0x2 0x40>;
			clock-names = "ahb", "tcon-ch0";
			clock-output-names = "tcon-pixel-clock";
			resets = <0x2 0x1b>;
			reset-names = "lcd";
			ports {
				port@0 {
					reg = <0x0>;
					endpoint@0 {
						reg = <0x0>;
						remote-endpoint = <0x6>;
						linux,phandle = <0x5>;
						phandle = <0x5>;
				port@1 {
					reg = <0x1>;
		dma-controller@01c02000 {
			compatible = "allwinner,sun8i-v3s-dma";
			reg = <0x1c02000 0x1000>;
			interrupts = <0x0 0x32 0x4>;
			clocks = <0x2 0x15>;
			resets = <0x2 0x6>;
			#dma-cells = <0x1>;
			linux,phandle = <0x10>;
			phandle = <0x10>;
		mmc@01c0f000 {
			compatible = "allwinner,sun7i-a20-mmc";
			reg = <0x1c0f000 0x1000>;
			clocks = <0x2 0x16 0x2 0x2d 0x2 0x2f 0x2 0x2e>;
			clock-names = "ahb", "mmc", "output", "sample";
			resets = <0x2 0x7>;
			reset-names = "ahb";
			interrupts = <0x0 0x3c 0x4>;
			pinctrl-0 = <0x7>;
			pinctrl-names = "default";
			broken-cd;
			bus-width = <0x4>;
			vmmc-supply = <0x8>;
		mmc@01c10000 {
			reg = <0x1c10000 0x1000>;
			clocks = <0x2 0x17 0x2 0x30 0x2 0x32 0x2 0x31>;
			resets = <0x2 0x8>;
			interrupts = <0x0 0x3d 0x4>;
			pinctrl-0 = <0x9>;
			broken-cd;
			bus-width = <0x4>;
		mmc@01c11000 {
			reg = <0x1c11000 0x1000>;
			clocks = <0x2 0x18 0x2 0x33 0x2 0x35 0x2 0x34>;
			resets = <0x2 0x9>;
			interrupts = <0x0 0x3e 0x4>;
		usb@01c19000 {
			compatible = "allwinner,sun8i-h3-musb";
			reg = <0x1c19000 0x400>;
			clocks = <0x2 0x1d>;
			resets = <0x2 0x11>;
			interrupts = <0x0 0x47 0x4>;
			interrupt-names = "mc";
			phys = <0xa 0x0>;
			phy-names = "usb";
			extcon = <0xa 0x0>;
			dr_mode = "otg";
		phy@01c19400 {
			compatible = "allwinner,sun8i-v3s-usb-phy";
			reg = <0x1c19400 0x2c 0x1c1a800 0x4>;
			reg-names = "phy_ctrl", "pmu0";
			clocks = <0x2 0x38>;
			clock-names = "usb0_phy";
			resets = <0x2 0x0>;
			reset-names = "usb0_reset";
			#phy-cells = <0x1>;
			usb0_id_det-gpio = <0xb 0x5 0x6 0x0>;
			linux,phandle = <0xa>;
			phandle = <0xa>;
		usb@01c1a000 {
			compatible = "allwinner,sun8i-v3s-ehci", "generic-ehci";
			reg = <0x1c1a000 0x100>;
			interrupts = <0x0 0x48 0x4>;
			clocks = <0x2 0x1e 0x2 0x1f>;
			resets = <0x2 0x12 0x2 0x16>;
		usb@01c1a400 {
			compatible = "allwinner,sun8i-v3s-ohci", "generic-ohci";
			reg = <0x1c1a400 0x100>;
			interrupts = <0x0 0x49 0x4>;
			clocks = <0x2 0x1e 0x2 0x1f 0x2 0x39>;
		clock@01c20000 {
			compatible = "allwinner,sun8i-v3s-ccu";
			reg = <0x1c20000 0x400>;
			clocks = <0xc 0xd>;
			clock-names = "hosc", "losc";
			linux,phandle = <0x2>;
			phandle = <0x2>;
		rtc@01c20400 {
			compatible = "allwinner,sun6i-a31-rtc";
			reg = <0x1c20400 0x54>;
			interrupts = <0x0 0x28 0x4 0x0 0x29 0x4>;
		pinctrl@01c20800 {
			compatible = "allwinner,sun8i-v3s-pinctrl";
			reg = <0x1c20800 0x400>;
			interrupts = <0x0 0xf 0x4 0x0 0x11 0x4>;
			clocks = <0x2 0x25 0xc 0xd>;
			gpio-controller;
			#gpio-cells = <0x3>;
			interrupt-controller;
			#interrupt-cells = <0x3>;
			linux,phandle = <0xb>;
			phandle = <0xb>;
			i2c0 {
				pins = "PB6", "PB7";
				function = "i2c0";
				linux,phandle = <0x15>;
				phandle = <0x15>;
			uart0@0 {
				pins = "PB8", "PB9";
				function = "uart0";
				linux,phandle = <0x12>;
				phandle = <0x12>;
			uart1@0 {
				pins = "PE21", "PE22";
				function = "uart1";
				linux,phandle = <0x13>;
				phandle = <0x13>;
			uart2@0 {
				pins = "PB0", "PB1";
				function = "uart2";
				linux,phandle = <0x14>;
				phandle = <0x14>;
			lcd-rgb666-pe {
				pins = "PE0", "PE1", "PE2", "PE3", "PE4", "PE5", "PE6", "PE7", "PE8", "PE9", "PE10", "PE11", "PE12", "PE13", "PE14", "PE15", "PE16", "PE17", "PE18", "PE19", "PE23", "PE24";
				function = "lcd0";
			mmc0@0 {
				pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
				function = "mmc0";
				drive-strength = <0x1e>;
				bias-pull-up;
				linux,phandle = <0x7>;
				phandle = <0x7>;
			mmc1 {
				pins = "PG0", "PG1", "PG2", "PG3", "PG4", "PG5";
				function = "mmc1";
				bias-pull-up;
				linux,phandle = <0x9>;
				phandle = <0x9>;
			spi0 {
				function = "spi0";
				linux,phandle = <0x18>;
				phandle = <0x18>;
			pwm0 {
				pins = "PB4";
				function = "pwm0";
				linux,phandle = <0xe>;
				phandle = <0xe>;
			pwm1 {
				pins = "PB5";
				function = "pwm1";
		timer@01c20c00 {
			compatible = "allwinner,sun4i-a10-timer";
			reg = <0x1c20c00 0xa0>;
			interrupts = <0x0 0x12 0x4 0x0 0x13 0x4>;
			clocks = <0xc>;
		watchdog@01c20ca0 {
			reg = <0x1c20ca0 0x20>;
			interrupts = <0x0 0x19 0x4>;
		pwm@1c21400 {
			compatible = "allwinner,sun8i-v3s-pwm", "allwinner,sun7i-a20-pwm";
			reg = <0x1c21400 0x400>;
			clocks = <0xc>;
			#pwm-cells = <0x3>;
			pinctrl-0 = <0xe>;
			linux,phandle = <0x19>;
			phandle = <0x19>;
		lradc@1c22800 {
			compatible = "allwinner,sun4i-a10-lradc-keys";
			reg = <0x1c22800 0x400>;
			interrupts = <0x0 0x1e 0x4>;
			vref-supply = <0xf>;
			button@200 {
				label = "Volume Up";
				linux,code = <0x73>;
				channel = <0x0>;
				voltage = <0x30d40>;
			button@400 {
				label = "Volume Down";
				linux,code = <0x72>;
				channel = <0x0>;
				voltage = <0x61a80>;
			button@600 {
				label = "Select";
				linux,code = <0x161>;
				channel = <0x0>;
				voltage = <0x927c0>;
			button@800 {
				label = "Start";
				linux,code = <0x160>;
				channel = <0x0>;
				voltage = <0xc3500>;
		codec@01c22c00 {
			#sound-dai-cells = <0x0>;
			compatible = "allwinner,sun8i-v3s-codec";
			reg = <0x1c22c00 0x400>;
			interrupts = <0x0 0x1d 0x4>;
			clocks = <0x2 0x24 0x2 0x46>;
			clock-names = "apb", "codec";
			resets = <0x2 0x28>;
			dmas = <0x10 0xf 0x10 0xf>;
			dma-names = "rx", "tx";
			allwinner,codec-analog-controls = <0x11>;
			allwinner,audio-routing = "Headphone", "HP", "Headphone", "HPCOM", "MIC1", "Mic", "Mic", "HBIAS";
		codec-analog@01c23000 {
			compatible = "allwinner,sun8i-v3s-codec-analog";
			reg = <0x1c23000 0x4>;
			linux,phandle = <0x11>;
			phandle = <0x11>;
		serial@01c28000 {
			reg = <0x1c28000 0x400>;
			interrupts = <0x0 0x0 0x4>;
			reg-shift = <0x2>;
			reg-io-width = <0x4>;
			clocks = <0x2 0x28>;
			resets = <0x2 0x31>;
			pinctrl-0 = <0x12>;
		serial@01c28400 {
			reg = <0x1c28400 0x400>;
			interrupts = <0x0 0x1 0x4>;
			reg-shift = <0x2>;
			clocks = <0x2 0x29>;
			resets = <0x2 0x32>;
			pinctrl-0 = <0x13>;
		serial@01c28800 {
			reg = <0x1c28800 0x400>;
			interrupts = <0x0 0x2 0x4>;
			reg-shift = <0x2>;
			clocks = <0x2 0x2a>;
			resets = <0x2 0x33>;
			pinctrl-0 = <0x14>;
		i2c@01c2ac00 {
			compatible = "allwinner,sun6i-a31-i2c";
			reg = <0x1c2ac00 0x400>;
			interrupts = <0x0 0x6 0x4>;
			clocks = <0x2 0x26>;
			resets = <0x2 0x2e>;
			pinctrl-0 = <0x15>;
			tsc2007@48 {
				compatible = "ti,tsc2007";
				reg = <0x48>;
				interrupt-parent = <0xb>;
				interrupts = <0x1 0x2 0x2>;
				gpios = <0xb 0x1 0x2 0x0>;
				pendown-gpio = <0xb 0x1 0x2 0x0>;
				ti,x-plate-ohms = <0x294>;
				wakeup-source;
		i2c@01c2b000 {
			reg = <0x1c2b000 0x400>;
			interrupts = <0x0 0x7 0x4>;
			clocks = <0x2 0x27>;
			resets = <0x2 0x2f>;
		ethernet@1c30000 {
			compatible = "allwinner,sun8i-v3s-emac";
			syscon = <0x16>;
			reg = <0x1c30000 0x10000>;
			interrupts = <0x0 0x52 0x4>;
			interrupt-names = "macirq";
			resets = <0x2 0xc>;
			reset-names = "stmmaceth";
			clocks = <0x2 0x1a>;
			clock-names = "stmmaceth";
			phy-handle = <0x17>;
			phy-mode = "mii";
			mdio {
				ethernet-phy@1 {
					compatible = "ethernet-phy-ieee802.3-c22";
					reg = <0x1>;
					clocks = <0x2 0x2b>;
					resets = <0x2 0x27>;
					phy-is-integrated;
					linux,phandle = <0x17>;
					phandle = <0x17>;
		spi@1c68000 {
			compatible = "allwinner,sun8i-h3-spi";
			reg = <0x1c68000 0x1000>;
			interrupts = <0x0 0x41 0x4>;
			clocks = <0x2 0x1c 0x2 0x37>;
			clock-names = "ahb", "mod";
			pinctrl-0 = <0x18>;
			resets = <0x2 0xf>;
			mx25l25635e@0 {
				compatible = "jedec,spi-nor";
				reg = <0x0>;
				spi-max-frequency = <0x2faf080>;
		interrupt-controller@01c81000 {
			compatible = "arm,cortex-a7-gic", "arm,cortex-a15-gic";
			reg = <0x1c81000 0x1000 0x1c82000 0x1000 0x1c84000 0x2000 0x1c86000 0x2000>;
			interrupts = <0x1 0x9 0xf04>;
			linux,phandle = <0x1>;
			phandle = <0x1>;
	ahci-5v {
		regulator-name = "ahci-5v";
		regulator-min-microvolt = <0x4c4b40>;
		regulator-max-microvolt = <0x4c4b40>;
		regulator-boot-on;
		enable-active-high;
		gpio = <0xb 0x1 0x8 0x0>;
	usb0-vbus {
		regulator-name = "usb0-vbus";
		enable-active-high;
		gpio = <0xb 0x1 0x9 0x0>;
	usb1-vbus {
		regulator-name = "usb1-vbus";
		regulator-boot-on;
		enable-active-high;
		gpio = <0xb 0x7 0x6 0x0>;
	usb2-vbus {
		regulator-name = "usb2-vbus";
		regulator-boot-on;
		enable-active-high;
		gpio = <0xb 0x7 0x3 0x0>;
	vcc3v0 {
		regulator-name = "vcc3v0";
		regulator-min-microvolt = <0x2dc6c0>;
		regulator-max-microvolt = <0x2dc6c0>;
		linux,phandle = <0xf>;
		phandle = <0xf>;
	vcc3v3 {
		regulator-name = "vcc3v3";
		regulator-min-microvolt = <0x325aa0>;
		regulator-max-microvolt = <0x325aa0>;
		linux,phandle = <0x8>;
		phandle = <0x8>;
	vcc5v0 {
		regulator-name = "vcc5v0";
	aliases {
		serial0 = "/soc/serial@01c28000";
		ethernet0 = "/soc/ethernet@1c30000";
	leds {
		compatible = "gpio-leds";
		blue_led {
			label = "licheepi:blue:usr";
			gpios = <0xb 0x6 0x1 0x1>;
		green_led {
			label = "licheepi:green:usr";
			gpios = <0xb 0x6 0x0 0x1>;
			default-state = "on";
		red_led {
			label = "licheepi:red:usr";
			gpios = <0xb 0x6 0x2 0x1>;
	backlight {
		compatible = "pwm-backlight";
		pwms = <0x19 0x0 0xf4240 0x0>;
		brightness-levels = <0x0 0x1e 0x28 0x32 0x3c 0x46 0x64>;
		default-brightness-level = <0x6>;
#6 2020-09-16 13:44:15
已发帖子: 3,403
如果linux用simplefb驱动,那么在uboot改分辨率,本站有帖子。
楼主 #7 2020-09-16 16:27:47
olili
已发帖子: 19
非常感谢,已经正常驱动该LCD,接下来需要去掉电阻触摸屏。我看这个屏上的电阻板没有芯片,直接连过来的,应该是要使用荔枝派zero上面自带的电阻触摸控制芯片,那么这个应该如何配置呢,还望赐教,非常感谢!
