楼主 #1 2020-09-16 11:58:06
已发帖子: 1,409
ubuntu下安装cadence报错:bin/virtuoso: /bin/ksh: bad interpreter: No such fi
https://blog.csdn.net/szsfate/article/details/78076887
基本按这个教程来的,虽然教程是centos。
安装jvm,安装cadence,安装补丁,安装破解文件,运行后报错:
Desktop:~/cadence$ . .virtuoso
bash: /home/any/cadence/installs/INCISIVE151/kits/VerificationKit/env.sh: No such file or directory
bash: /home/any/cadence/installs/IC617/bin/virtuoso: /bin/ksh: bad interpreter: No such file or directory
第一个错误,搜了下incisive151,好像是cadence芯片验证的一个工具,我就没装这个,报错应该是正常的。
第二个错误,/home/any/cadence/installs/IC617/bin/virtuoso这个路径是正确的,也有这个文件,单位和会提示/bin/ksh错误?
楼主 #2 2020-09-16 12:48:21
已发帖子: 1,409
Re: ubuntu下安装cadence报错:bin/virtuoso: /bin/ksh: bad interpreter: No such fi
apt安装ksh tcsh解决。
终于有启动窗口了,可出现一些警告后就没有然后了...
COPYRIGHT © 1992-2015  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
          © 1992-2015  UNIX SYSTEMS Laboratories INC.,
                         Reproduced with permission.
This Cadence Design Systems program and online documentation are
proprietary/confidential information and may be disclosed/used only
as authorized in a license agreement controlling such use and disclosure.
          RESTRICTED RIGHTS NOTICE (SHORT FORM)
Use/reproduction/disclosure is subject to restriction
set forth at FAR 1252.227-19 or its equivalent.
Program:		@(#)$CDS: virtuoso version 6.1.7-64b 11/09/2015 12:45 (sjfnl165) $
Sub version:		sub-version  IC6.1.7-64b.78  (64-bit addresses)
Loading geView.cxt
Loading menuBuilder.cxt
Loading schView.cxt
Loading selectSv.cxt
Loading wireEdit.cxt
Loading pte2.cxt
Loading xlUI.cxt
Loading auCore.cxt
Loading vhdl.cxt
Loading seismic.cxt
Loading ci.cxt
Loading ams.cxt
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.04s.
Successfully checked out 'Virtuoso_MixedSignalOpt_Layout' license.
*WARNING* ddUpdateLibList: Did not find any 'cds.lib' file.
*WARNING* could not load font "-*-courier-medium-r-*-*-12-*", using font "fixed"
*WARNING* (GE-2181): The font (name,size): (courier,12) does not exist. Please verify its validity with 'xlsfonts' or with 'xfontsel'.
楼主 #3 2020-09-16 14:23:30
已发帖子: 1,409
按这个教程又重新安装一遍,主要是安装完后有几个终端窗口的选项,按这个教程来,上边的报错少了。
https://my.oschina.net/propagator/blog/3166272
楼主 #4 2020-09-16 14:48:53
已发帖子: 1,409
警告不影响使用。
安完了才发现,这个不是我想要的candence...
我想要的是candence是orcad+allegro,这个是virtuoso或者说是ic617。用途不一样的。掀桌...
#5 2020-09-16 14:54:59
孤星泪
已发帖子: 235
打酱油路过的吃瓜群众看到了楼主刚刚掀翻的桌子
