/usr # ./arecord -l
** List of CAPTURE Hardware Devices **
card 0: nuc970IIS [nuc970_IIS], device 0: IIS HiFi nau8822-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
/usr # ./arecord -D hw:0,0 -d 20 -f S16_LE -r 8000 tmp.wav
Recording WAVE 'tmp.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
/usr # ./aplay -l
** List of PLAYBACK Hardware Devices **
Subdevices: 1/1
播放录音没有一点声音
/usr # ./aplay -D hw:0,0 tmp.wav
Playing WAVE 'tmp.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
/usr #
是买的MCUZONE 的 MDK972 开发板?
晕哥,不是
晕哥,不是
晕哥,是不是声卡的问题
检查麦克风的电路是否对。
先打开MIC录音:
amixer set "Mic Bias" on
录音:
./oss_demo rec 44100 2 rec.wav
放音:
./oss_demo play 44100 2 *.wav
