楼主 #1 2017-11-11 17:11:58
daydayup
已发帖子: 343
Allwinner全志V3s板子用ns2009驱动电阻触摸屏,在荔枝派zero工作好好的软件,我的板子出这个错误:
[ 13.046734] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 13.053285] input input1: Poll touch data failed: -110
[ 15.206667] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 15.213230] input input1: Poll touch data failed: -110
[ 17.366664] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 17.373225] input input1: Poll touch data failed: -110
[ 19.526660] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 19.533223] input input1: Poll touch data failed: -110
[ 21.686660] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 21.693220] input input1: Poll touch data failed: -110
[ 23.846663] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 23.853220] input input1: Poll touch data failed: -110
#2 2017-11-14 14:19:34
沉鱼
已发帖子: 161
Re: Allwinner全志V3s板子用ns2009驱动电阻触摸屏,在荔枝派zero工作好好的软件,我的板子出这个错误:
硬件与荔枝派zero 一样?
I2C SCK/SDA 有没有上拉?
楼主 #3 2017-11-14 14:22:19
daydayup
已发帖子: 343
果然是没有上拉, 这坑挖大了。
我去飞线试一试。
楼主 #4 2017-11-14 14:24:49
daydayup
已发帖子: 343
飞线就好了,谢谢大神.
#5 2018-07-18 10:48:20
yangbo
请问一下,我不用触摸屏,如果关闭上面的错误提示,我是用buildroot编译的,在make menuconfig里面去掉了tslib,现在改怎么办?谁知道回复一下,谢谢
#6 2018-07-18 11:11:37
已发帖子: 9,473
在设备树里面删除 ns2009 即可
打开 arch/arm/boot/dts/sun8i-v3s-licheepi-zero.dts
删除:
&i2c0 {
ns2009: ns2009@48 {
compatible = "nsiway,ns2009";
reg = <0x48>;
重新编译出 dtb 文件, 烧录.
#7 2018-07-18 11:23:07
yangbo
谢谢了,
#8 2020-10-26 17:08:22
jkl
已发帖子: 269
请问一下,我现在遇到同样的问题,上拉也给安排上了,但是还是一样的错误,这是怎么回事?
89.440754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 91.520754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 93.600759] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 95.680755] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 97.760754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 99.840761] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 101.920755] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 104.000756] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 106.080762] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 108.160756] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 110.240753] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 112.320752] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 114.400754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 116.480753] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 118.560753] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 120.640759] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 122.720753] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 124.800754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 126.880759] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 128.960754] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 131.040755] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 133.120759] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 135.200755] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 137.280757] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
[ 139.361038] i2c i2c-0: mv64xxx: I2C bus locked, block: 1, time_left: 0
最近编辑记录 jkl (2020-10-26 17:14:20)
#9 2022-10-31 15:01:00
Chin
已发帖子: 61
@jkl
是不是上拉没起作用?
