新建新项目, 通过nuget安装sdl2
添加一个main.cpp文件, 文件内容 https://github.com/AlmasB/SDL2-Demo/blob/master/src/Main.cpp
#include <SDL.h>
#include <iostream>
const int SCREEN_WIDTH = 800;
const int SCREEN_HEIGHT = 600;
int main(int arc, char ** argv) {
if (SDL_Init( SDL_INIT_VIDEO ) < 0) {
std::cout << "SDL could not initialize! SDL_Error: " << SDL_GetError() << std::endl;
} else {
SDL_CreateWindow(
"SDL2 Demo",
SDL_WINDOWPOS_CENTERED, SDL_WINDOWPOS_CENTERED,
SCREEN_WIDTH, SCREEN_HEIGHT,
SDL_WINDOW_SHOWN
SDL_Delay(2000);
}main.cpp 添加内容:
#pragma comment(lib, "msvcrtd.lib")
#pragma comment(lib, "vcruntimed.lib")
#pragma comment(lib, "ucrtd.lib")
#pragma comment(linker, "/subsystem:\"windows\" /entry:\"SDL_main\"")F5 运行就出SDL2窗口了。
https://www.libsdl.org/release/SDL-1.2.15/docs/html/guidevideoopengl.html
VC++ 2017 工程下载: Project9_sdl2_simple_demo.7z
nuget太好用了, 不需要自己处理第三方库问题。
// To compile with gcc: (tested on Ubuntu 14.04 64bit):
// g++ sdl2_opengl.cpp -lSDL2 -lGL
// To compile with msvc: (tested on Windows 7 64bit)
// cl sdl2_opengl.cpp /I C:\sdl2path\include /link C:\path\SDL2.lib C:\path\SDL2main.lib /SUBSYSTEM:CONSOLE /NODEFAULTLIB:libcmtd.lib opengl32.lib
#include <stdio.h>
#include <stdint.h>
#include <assert.h>
#include <SDL2/SDL.h>
#include <SDL2/SDL_opengl.h>
#include <GL/gl.h>
typedef int32_t i32;
typedef uint32_t u32;
typedef int32_t b32;
#define WinWidth 1000
#define WinHeight 1000
int main (int ArgCount, char **Args)
u32 WindowFlags = SDL_WINDOW_OPENGL;
SDL_Window *Window = SDL_CreateWindow("OpenGL Test", 0, 0, WinWidth, WinHeight, WindowFlags);
assert(Window);
SDL_GLContext Context = SDL_GL_CreateContext(Window);
b32 Running = 1;
b32 FullScreen = 0;
while (Running)
SDL_Event Event;
while (SDL_PollEvent(&Event))
if (Event.type == SDL_KEYDOWN)
switch (Event.key.keysym.sym)
case SDLK_ESCAPE:
Running = 0;
break;
case 'f':
FullScreen = !FullScreen;
if (FullScreen)
SDL_SetWindowFullscreen(Window, WindowFlags | SDL_WINDOW_FULLSCREEN_DESKTOP);
SDL_SetWindowFullscreen(Window, WindowFlags);
break;
default:
break;
else if (Event.type == SDL_QUIT)
Running = 0;
glViewport(0, 0, WinWidth, WinHeight);
glClearColor(1.f, 0.f, 1.f, 0.f);
glClear(GL_COLOR_BUFFER_BIT);
SDL_GL_SwapWindow(Window);
}https://gist.github.com/jordandee/94b187bcc51df9528a2f
SDL2 & OpenGL Simple Demo
gcc -o test2 test2.c -lSDL2 -lGL
#include <stdio.h>
#include <stdint.h>
#include <assert.h>
#include <SDL.h>
#include <SDL_opengl.h>
#include <GL/gl.h>
#pragma comment(lib,"opengl32.lib")
#define WinWidth 640
#define WinHeight 480
int main(int ArgCount, char **Args)
assert(Window);
b32 Running = 1;
b32 FullScreen = 0;
while (Running)
SDL_Event Event;
case SDLK_ESCAPE:
Running = 0;
break;
case 'f':
if (FullScreen)
break;
default:
break;
Running = 0;
glViewport(0, 0, WinWidth/2, WinHeight/2);
glClearColor(1.f, 0.f, 0.f, 0.5f);
}VC++2017 工程下载: Project10_sdl2_opengl_simple_demo.7z
https://github.com/crust/sdl2-examples/blob/master/glcontext.cpp
#include <iostream>
#include <SDL.h>
using std::cout;
int main(int argc, char* argv[]) {
SDL_Init(SDL_INIT_VIDEO); // Init SDL2
// Create a window. Window mode MUST include SDL_WINDOW_OPENGL for use with OpenGL.
SDL_Window *window = SDL_CreateWindow(
"SDL2/OpenGL Demo", SDL_WINDOWPOS_UNDEFINED, SDL_WINDOWPOS_UNDEFINED, 640, 480, SDL_WINDOW_OPENGL | SDL_WINDOW_RESIZABLE
// Create an OpenGL context associated with the window.
SDL_GLContext glcontext = SDL_GL_CreateContext(window);
// Now, regular OpenGL functions ...
glMatrixMode(GL_PROJECTION | GL_MODELVIEW);
glLoadIdentity();
glOrtho(-320, 320, 240, -240, 0, 1);
// ... can be used alongside SDL2.
SDL_Event e;
float x = 0.0, y = 30.0;
SDL_PollEvent(&e);
while (e.type != SDL_KEYDOWN && e.type != SDL_QUIT) { // Enter main loop.
SDL_PollEvent(&e); // Check for events.
glClearColor(0, 0, 0, 1); // Draw with OpenGL.
glRotatef(10.0, 0.0, 0.0, 1.0);
// Note that the glBegin() ... glEnd() OpenGL style used below is actually
// obsolete, but it will do for example purposes. For more information, see
// SDL_GL_GetProcAddress() or find an OpenGL extension loading library.
glBegin(GL_TRIANGLES);
glColor3f(1.0, 0.0, 0.0); glVertex2f(x, y + 90.0);
glColor3f(0.0, 1.0, 0.0); glVertex2f(x + 90.0, y - 90.0);
glColor3f(0.0, 0.0, 1.0); glVertex2f(x - 90.0, y - 90.0);
glEnd();
SDL_GL_SwapWindow(window); // Swap the window/buffer to display the result.
SDL_Delay(100); // Pause briefly before moving on to the next cycle.
// Once finished with OpenGL functions, the SDL_GLContext can be deleted.
SDL_GL_DeleteContext(glcontext);
// Done! Close the window, clean-up and exit the program.
SDL_DestroyWindow(window);
SDL_Quit();
}离线
