下载下来的linux_frame_buffer 跑在V3S tina
跑起来没有支持png解码,图片啥的程序从单片机那边过来,都是bin啊啥的,ARGB8888 数据超大还占磁盘,很难受啊。
tina环境已经支持了libpng,这里边默认是调用了libpng里边的接口。
话不多说,上代码:
* @file lv_img_decoder.c
* INCLUDES
#include "lv_img_decoder.h"
#include "../lv_core/lv_debug.h"
#include "../lv_draw/lv_draw_img.h"
#include "../lv_misc/lv_ll.h"
#include "../lv_misc/lv_color.h"
#include "../lv_misc/lv_gc.h"
#if defined(LV_GC_INCLUDE)
#include LV_GC_INCLUDE
#endif /* LV_ENABLE_GC */
* DEFINES
#define CF_BUILT_IN_FIRST LV_IMG_CF_TRUE_COLOR
#define CF_BUILT_IN_LAST LV_IMG_CF_ALPHA_8BIT
#define USE_PNG 1
* TYPEDEFS
typedef struct
#if LV_USE_FILESYSTEM
lv_fs_file_t * f;
lv_color_t * palette;
lv_opa_t * opa;
} lv_img_decoder_built_in_data_t;
* STATIC PROTOTYPES
static lv_res_t lv_img_decoder_built_in_line_true_color(lv_img_decoder_dsc_t * dsc, lv_coord_t x, lv_coord_t y,
lv_coord_t len, uint8_t * buf);
static lv_res_t lv_img_decoder_built_in_line_alpha(lv_img_decoder_dsc_t * dsc, lv_coord_t x, lv_coord_t y,
static lv_res_t lv_img_decoder_built_in_line_indexed(lv_img_decoder_dsc_t * dsc, lv_coord_t x, lv_coord_t y,
* STATIC VARIABLES
* MACROS
* GLOBAL FUNCTIONS
* Initialize the image decoder module
void lv_img_decoder_init(void)
lv_ll_init(&LV_GC_ROOT(_lv_img_defoder_ll), sizeof(lv_img_decoder_t));
lv_img_decoder_t * decoder;
/*Create a decoder for the built in color format*/
decoder = lv_img_decoder_create();
if(decoder == NULL) {
LV_LOG_WARN("lv_img_decoder_init: out of memory");
LV_ASSERT_MEM(decoder);
return;
lv_img_decoder_set_info_cb(decoder, lv_img_decoder_built_in_info);
lv_img_decoder_set_open_cb(decoder, lv_img_decoder_built_in_open);
lv_img_decoder_set_read_line_cb(decoder, lv_img_decoder_built_in_read_line);
lv_img_decoder_set_close_cb(decoder, lv_img_decoder_built_in_close);
* Get information about an image.
* Try the created image decoder one by one. Once one is able to get info that info will be used.
* @param src the image source. E.g. file name or variable.
* @param header the image info will be stored here
* @return LV_RES_OK: success; LV_RES_INV: wasn't able to get info about the image
lv_res_t lv_img_decoder_get_info(const char * src, lv_img_header_t * header)
header->always_zero = 0;
lv_res_t res = LV_RES_INV;
lv_img_decoder_t * d;
LV_LL_READ(LV_GC_ROOT(_lv_img_defoder_ll), d)
res = LV_RES_INV;
if(d->info_cb) {
res = d->info_cb(d, src, header);
if(res == LV_RES_OK) break;
return res;
* Open an image.
* Try the created image decoder one by one. Once one is able to open the image that decoder is save in `dsc`
* @param dsc describe a decoding session. Simply a pointer to an `lv_img_decoder_dsc_t` variable.
* @param src the image source. Can be
* 1) File name: E.g. "S:folder/img1.png" (The drivers needs to registered via `lv_fs_add_drv()`)
* 2) Variable: Pointer to an `lv_img_dsc_t` variable
* 3) Symbol: E.g. `LV_SYMBOL_OK`
* @param style the style of the image
* @return LV_RES_OK: opened the image. `dsc->img_data` and `dsc->header` are set.
* LV_RES_INV: none of the registered image decoders were able to open the image.
lv_res_t lv_img_decoder_open(lv_img_decoder_dsc_t * dsc, const void * src, const lv_style_t * style)
dsc->style = style;
dsc->src_type = lv_img_src_get_type(src);
dsc->user_data = NULL;
if(dsc->src_type == LV_IMG_SRC_FILE) {
size_t fnlen = strlen(src);
dsc->src = lv_mem_alloc(fnlen + 1);
strcpy((char *)dsc->src, src);
} else {
dsc->src = src;
/*Info an Open callbacks are required*/
if(d->info_cb == NULL || d->open_cb == NULL) continue;
res = d->info_cb(d, src, &dsc->header);
if(res != LV_RES_OK) continue;
dsc->error_msg = NULL;
dsc->img_data = NULL;
dsc->decoder = d;
res = d->open_cb(d, dsc);
/*Opened successfully. It is a good decoder to for this image source*/
return res;
* Read a line from an opened image
* @param dsc pointer to `lv_img_decoder_dsc_t` used in `lv_img_decoder_open`
* @param x start X coordinate (from left)
* @param y start Y coordinate (from top)
* @param len number of pixels to read
* @param buf store the data here
* @return LV_RES_OK: success; LV_RES_INV: an error occurred
lv_res_t lv_img_decoder_read_line(lv_img_decoder_dsc_t * dsc, lv_coord_t x, lv_coord_t y, lv_coord_t len, uint8_t * buf)
if(dsc->decoder->read_line_cb) res = dsc->decoder->read_line_cb(dsc->decoder, dsc, x, y, len, buf);
return res;
* Close a decoding session
void lv_img_decoder_close(lv_img_decoder_dsc_t * dsc)
if(dsc->decoder) {
if(dsc->decoder->close_cb) dsc->decoder->close_cb(dsc->decoder, dsc);
lv_mem_free(dsc->src);
dsc->src = NULL;
* Create a new image decoder
* @return pointer to the new image decoder
lv_img_decoder_t * lv_img_decoder_create(void)
decoder = lv_ll_ins_head(&LV_GC_ROOT(_lv_img_defoder_ll));
if(decoder == NULL) return NULL;
memset(decoder, 0, sizeof(lv_img_decoder_t));
return decoder;
* Delete an image decoder
* @param decoder pointer to an image decoder
void lv_img_decoder_delete(lv_img_decoder_t * decoder)
lv_ll_rem(&LV_GC_ROOT(_lv_img_defoder_ll), decoder);
lv_mem_free(decoder);
* Set a callback to get information about the image
* @param info_cb a function to collect info about an image (fill an `lv_img_header_t` struct)
void lv_img_decoder_set_info_cb(lv_img_decoder_t * decoder, lv_img_decoder_info_f_t info_cb)
decoder->info_cb = info_cb;
* Set a callback to open an image
* @param open_cb a function to open an image
void lv_img_decoder_set_open_cb(lv_img_decoder_t * decoder, lv_img_decoder_open_f_t open_cb)
decoder->open_cb = open_cb;
* Set a callback to a decoded line of an image
* @param read_line_cb a function to read a line of an image
void lv_img_decoder_set_read_line_cb(lv_img_decoder_t * decoder, lv_img_decoder_read_line_f_t read_line_cb)
decoder->read_line_cb = read_line_cb;
* Set a callback to close a decoding session. E.g. close files and free other resources.
* @param close_cb a function to close a decoding session
void lv_img_decoder_set_close_cb(lv_img_decoder_t * decoder, lv_img_decoder_close_f_t close_cb)
decoder->close_cb = close_cb;
* Get info about a built-in image
* @param decoder the decoder where this function belongs
* @param src the image source: pointer to an `lv_img_dsc_t` variable, a file path or a symbol
* @param header store the image data here
* @return LV_RES_OK: the info is successfully stored in `header`; LV_RES_INV: unknown format or other error.
lv_res_t lv_img_decoder_built_in_info(lv_img_decoder_t * decoder, const void * src, lv_img_header_t * header)
(void)decoder; /*Unused*/
lv_img_src_t src_type = lv_img_src_get_type(src);
if(src_type == LV_IMG_SRC_VARIABLE) {
lv_img_cf_t cf = ((lv_img_dsc_t *)src)->header.cf;
if(cf < CF_BUILT_IN_FIRST || cf > CF_BUILT_IN_LAST) return LV_RES_INV;
header->w = ((lv_img_dsc_t *)src)->header.w;
header->h = ((lv_img_dsc_t *)src)->header.h;
header->cf = ((lv_img_dsc_t *)src)->header.cf;
else if(src_type == LV_IMG_SRC_FILE) {
lv_fs_file_t file;
lv_fs_res_t res;
uint32_t rn;
unsigned short readx = 0,ready = 0;
#if USE_PNG
if(fh_png_getsize(src,&readx,&ready) == 0)//libpng的接口
header->w = readx;
header->h = ready;
header->cf = LV_IMG_CF_RAW_ALPHA;
#else
res = lv_fs_open(&file, src, LV_FS_MODE_RD);
if(res == LV_FS_RES_OK) {
res = lv_fs_read(&file, header, sizeof(lv_img_header_t), &rn);
//very very important, here copy header , but this file now is png, not bin, so header should modify in pcfs_read
lv_fs_close(&file);
if(header->cf < CF_BUILT_IN_FIRST || header->cf > CF_BUILT_IN_LAST) return LV_RES_INV;
else if(src_type == LV_IMG_SRC_SYMBOL) {
/*The size depend on the font but it is unknown here. It should be handled outside of the
* function*/
header->w = 1;
header->h = 1;
/* Symbols always have transparent parts. Important because of cover check in the design
* function. The actual value doesn't matter because lv_draw_label will draw it*/
header->cf = LV_IMG_CF_ALPHA_1BIT;
} else {
LV_LOG_WARN("Image get info found unknown src type");
return LV_RES_INV;
return LV_RES_OK;
* Open a built in image
* @param dsc pointer to decoder descriptor. `src`, `style` are already initialized in it.
lv_res_t lv_img_decoder_built_in_open(lv_img_decoder_t * decoder, lv_img_decoder_dsc_t * dsc)
/*Open the file if it's a file*/
#if USE_PNG
/*Support only "*.bin" files*/
if(strcmp(lv_fs_get_ext(dsc->src), "png")) return LV_RES_INV;
// lv_fs_file_t f;
// lv_fs_res_t res = lv_fs_open(&f, dsc->src, LV_FS_MODE_RD);
// if(res != LV_FS_RES_OK) {
// LV_LOG_WARN("Built-in image decoder can't open the file");
// return LV_RES_INV;
/*If the file was open successfully save the file descriptor*/
// if(dsc->user_data == NULL) {
// dsc->user_data = lv_mem_alloc(sizeof(lv_img_decoder_built_in_data_t));
// LV_LOG_ERROR("img_decoder_built_in_open: out of memory");
// LV_ASSERT_MEM(dsc->user_data);
// memset(dsc->user_data, 0, sizeof(lv_img_decoder_built_in_data_t));
// lv_img_decoder_built_in_data_t * user_data = dsc->user_data;
// user_data->f = lv_mem_alloc(sizeof(f));
// if(user_data->f == NULL) {
// LV_ASSERT_MEM(user_data->f);
// memcpy(user_data->f, &f, sizeof(f));
#else
if(strcmp(lv_fs_get_ext(dsc->src), "bin")) return LV_RES_INV;
lv_fs_file_t f;
return LV_RES_INV;
#else
LV_LOG_WARN("Image built-in decoder cannot read file because LV_USE_FILESYSTEM = 0");
return LV_RES_INV;
lv_img_cf_t cf = dsc->header.cf;
/*Process true color formats*/
if(cf == LV_IMG_CF_TRUE_COLOR || cf == LV_IMG_CF_TRUE_COLOR_ALPHA || cf == LV_IMG_CF_TRUE_COLOR_CHROMA_KEYED) {
if(dsc->src_type == LV_IMG_SRC_VARIABLE) {
/* In case of uncompressed formats the image stored in the ROM/RAM.
* So simply give its pointer*/
dsc->img_data = ((lv_img_dsc_t *)dsc->src)->data;
return LV_RES_OK;
} else {
/*If it's a file it need to be read line by line later*/
return LV_RES_OK;
/*Process indexed images. Build a palette*/
else if(cf == LV_IMG_CF_INDEXED_1BIT || cf == LV_IMG_CF_INDEXED_2BIT || cf == LV_IMG_CF_INDEXED_4BIT ||
cf == LV_IMG_CF_INDEXED_8BIT) {
#if LV_IMG_CF_INDEXED
uint8_t px_size = lv_img_color_format_get_px_size(cf);
uint32_t palette_size = 1 << px_size;
/*Allocate the palette*/
user_data->palette = lv_mem_alloc(palette_size * sizeof(lv_color_t));
user_data->opa = lv_mem_alloc(palette_size * sizeof(lv_opa_t));
if(user_data->palette == NULL || user_data->opa == NULL) {
LV_ASSERT_MEM(user_data->palette);
LV_ASSERT_MEM(user_data->opa);
/*Read the palette from file*/
lv_fs_seek(user_data->f, 4); /*Skip the header*/
lv_color32_t cur_color;
uint32_t i;
for(i = 0; i < palette_size; i++) {
lv_fs_read(user_data->f, &cur_color, sizeof(lv_color32_t), NULL);
user_data->palette[i] = lv_color_make(cur_color.ch.red, cur_color.ch.green, cur_color.ch.blue);
user_data->opa[i] = cur_color.ch.alpha;
#else
LV_LOG_WARN("Image built-in decoder can read the palette because LV_USE_FILESYSTEM = 0");
return LV_RES_INV;
} else {
/*The palette begins in the beginning of the image data. Just point to it.*/
lv_color32_t * palette_p = (lv_color32_t *)((lv_img_dsc_t *)dsc->src)->data;
uint32_t i;
user_data->palette[i] = lv_color_make(palette_p[i].ch.red, palette_p[i].ch.green, palette_p[i].ch.blue);
user_data->opa[i] = palette_p[i].ch.alpha;
return LV_RES_OK;
#else
LV_LOG_WARN("Indexed (palette) images are not enabled in lv_conf.h. See LV_IMG_CF_INDEXED");
return LV_RES_INV;
/*Alpha indexed images. */
else if(cf == LV_IMG_CF_ALPHA_1BIT || cf == LV_IMG_CF_ALPHA_2BIT || cf == LV_IMG_CF_ALPHA_4BIT ||
cf == LV_IMG_CF_ALPHA_8BIT) {
#if LV_IMG_CF_ALPHA
return LV_RES_OK; /*Nothing to process*/
#else
LV_LOG_WARN("Alpha indexed images are not enabled in lv_conf.h. See LV_IMG_CF_ALPHA");
return LV_RES_INV;
#if USE_PNG
else if(cf == LV_IMG_CF_RAW_ALPHA)
// uint8_t *pbuf;
int file_size;
file_size = (dsc->header.w)*(dsc->header.h)*(LV_COLOR_DEPTH/8);
dsc->img_data = lv_mem_alloc(file_size);
fh_png_load(dsc->src,dsc->img_data,dsc->header.w,dsc->header.h);//libpng的接口
printf("lv_img_decoder_built_in_open fh_png_load src = %s file_size = %d \n",dsc->src,file_size);
return LV_RES_OK;
/*Unknown format. Can't decode it.*/
else {
/*Free the potentially allocated memories*/
lv_img_decoder_built_in_close(decoder, dsc);
LV_LOG_WARN("Image decoder open: unknown color format")
return LV_RES_INV;
* Decode `len` pixels starting from the given `x`, `y` coordinates and store them in `buf`.
* Required only if the "open" function can't return with the whole decoded pixel array.
* @param decoder pointer to the decoder the function associated with
* @param x start x coordinate
* @param y start y coordinate
* @param len number of pixels to decode
* @param buf a buffer to store the decoded pixels
* @return LV_RES_OK: ok; LV_RES_INV: failed
lv_res_t lv_img_decoder_built_in_read_line(lv_img_decoder_t * decoder, lv_img_decoder_dsc_t * dsc, lv_coord_t x,
if(dsc->header.cf == LV_IMG_CF_TRUE_COLOR || dsc->header.cf == LV_IMG_CF_TRUE_COLOR_ALPHA ||
dsc->header.cf == LV_IMG_CF_TRUE_COLOR_CHROMA_KEYED) {
/* For TRUE_COLOR images read line required only for files.
* For variables the image data was returned in `open`*/
res = lv_img_decoder_built_in_line_true_color(dsc, x, y, len, buf);
} else if(dsc->header.cf == LV_IMG_CF_ALPHA_1BIT || dsc->header.cf == LV_IMG_CF_ALPHA_2BIT ||
dsc->header.cf == LV_IMG_CF_ALPHA_4BIT || dsc->header.cf == LV_IMG_CF_ALPHA_8BIT) {
res = lv_img_decoder_built_in_line_alpha(dsc, x, y, len, buf);
} else if(dsc->header.cf == LV_IMG_CF_INDEXED_1BIT || dsc->header.cf == LV_IMG_CF_INDEXED_2BIT ||
dsc->header.cf == LV_IMG_CF_INDEXED_4BIT || dsc->header.cf == LV_IMG_CF_INDEXED_8BIT) {
res = lv_img_decoder_built_in_line_indexed(dsc, x, y, len, buf);
} else {
LV_LOG_WARN("Built-in image decoder read not supports the color format");
return LV_RES_INV;
return res;
* Close the pending decoding. Free resources etc.
void lv_img_decoder_built_in_close(lv_img_decoder_t * decoder, lv_img_decoder_dsc_t * dsc)
#if USE_PNG
if(dsc->img_data)
lv_mem_free(dsc->img_data);
if(user_data) {
if(user_data->f) {
lv_fs_close(user_data->f);
lv_mem_free(user_data->f);
if(user_data->palette) lv_mem_free(user_data->palette);
if(user_data->opa) lv_mem_free(user_data->opa);
lv_mem_free(user_data);
* STATIC FUNCTIONS
lv_fs_res_t res;
uint8_t px_size = lv_img_color_format_get_px_size(dsc->header.cf);
uint32_t pos = ((y * dsc->header.w + x) * px_size) >> 3;
pos += 4; /*Skip the header*/
res = lv_fs_seek(user_data->f, pos);
LV_LOG_WARN("Built-in image decoder seek failed");
return LV_RES_INV;
uint32_t btr = len * (px_size >> 3);
uint32_t br = 0;
lv_fs_read(user_data->f, buf, btr, &br);
if(res != LV_FS_RES_OK || btr != br) {
LV_LOG_WARN("Built-in image decoder read failed");
return LV_RES_INV;
return LV_RES_OK;
#else
return LV_RES_INV;
#if LV_IMG_CF_ALPHA
const lv_opa_t alpha1_opa_table[2] = {0, 255}; /*Opacity mapping with bpp = 1 (Just for compatibility)*/
const lv_opa_t alpha2_opa_table[4] = {0, 85, 170, 255}; /*Opacity mapping with bpp = 2*/
const lv_opa_t alpha4_opa_table[16] = {0, 17, 34, 51, /*Opacity mapping with bpp = 4*/
68, 85, 102, 119, 136, 153, 170, 187, 204, 221, 238, 255};
/*Simply fill the buffer with the color. Later only the alpha value will be modified.*/
lv_color_t bg_color = dsc->style->image.color;
lv_coord_t i;
for(i = 0; i < len; i++) {
#if LV_COLOR_DEPTH == 8 || LV_COLOR_DEPTH == 1
buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE] = bg_color.full;
#elif LV_COLOR_DEPTH == 16
/*Because of Alpha byte 16 bit color can start on odd address which can cause crash*/
buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE] = bg_color.full & 0xFF;
buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE + 1] = (bg_color.full >> 8) & 0xFF;
#elif LV_COLOR_DEPTH == 32
*((uint32_t *)&buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE]) = bg_color.full;
#else
#error "Invalid LV_COLOR_DEPTH. Check it in lv_conf.h"
const lv_opa_t * opa_table = NULL;
uint16_t mask = (1 << px_size) - 1; /*E.g. px_size = 2; mask = 0x03*/
lv_coord_t w = 0;
uint32_t ofs = 0;
int8_t pos = 0;
switch(dsc->header.cf) {
case LV_IMG_CF_ALPHA_1BIT:
w = (dsc->header.w >> 3); /*E.g. w = 20 -> w = 2 + 1*/
if(dsc->header.w & 0x7) w++;
ofs += w * y + (x >> 3); /*First pixel*/
pos = 7 - (x & 0x7);
opa_table = alpha1_opa_table;
break;
case LV_IMG_CF_ALPHA_2BIT:
w = (dsc->header.w >> 2); /*E.g. w = 13 -> w = 3 + 1 (bytes)*/
if(dsc->header.w & 0x3) w++;
ofs += w * y + (x >> 2); /*First pixel*/
pos = 6 - ((x & 0x3) * 2);
opa_table = alpha2_opa_table;
break;
case LV_IMG_CF_ALPHA_4BIT:
w = (dsc->header.w >> 1); /*E.g. w = 13 -> w = 6 + 1 (bytes)*/
if(dsc->header.w & 0x1) w++;
ofs += w * y + (x >> 1); /*First pixel*/
pos = 4 - ((x & 0x1) * 4);
opa_table = alpha4_opa_table;
break;
case LV_IMG_CF_ALPHA_8BIT:
w = dsc->header.w; /*E.g. x = 7 -> w = 7 (bytes)*/
ofs += w * y + x; /*First pixel*/
pos = 0;
break;
uint8_t fs_buf[LV_HOR_RES_MAX];
const uint8_t * data_tmp = NULL;
const lv_img_dsc_t * img_dsc = dsc->src;
data_tmp = img_dsc->data + ofs;
} else {
lv_fs_seek(user_data->f, ofs + 4); /*+4 to skip the header*/
lv_fs_read(user_data->f, fs_buf, w, NULL);
data_tmp = fs_buf;
#else
LV_LOG_WARN("Image built-in alpha line reader can't read file because LV_USE_FILESYSTEM = 0");
data_tmp = NULL; /*To avoid warnings*/
return LV_RES_INV;
uint8_t byte_act = 0;
uint8_t val_act;
val_act = (data_tmp[byte_act] & (mask << pos)) >> pos;
buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE + LV_IMG_PX_SIZE_ALPHA_BYTE - 1] =
dsc->header.cf == LV_IMG_CF_ALPHA_8BIT ? val_act : opa_table[val_act];
pos -= px_size;
if(pos < 0) {
pos = 8 - px_size;
data_tmp++;
return LV_RES_OK;
#else
LV_LOG_WARN("Image built-in alpha line reader failed because LV_IMG_CF_ALPHA is 0 in lv_conf.h");
return LV_RES_INV;
lv_coord_t w = 0;
int8_t pos = 0;
uint32_t ofs = 0;
case LV_IMG_CF_INDEXED_1BIT:
ofs += 8; /*Skip the palette*/
break;
case LV_IMG_CF_INDEXED_2BIT:
ofs += 16; /*Skip the palette*/
break;
case LV_IMG_CF_INDEXED_4BIT:
ofs += 64; /*Skip the palette*/
break;
case LV_IMG_CF_INDEXED_8BIT:
ofs += 1024; /*Skip the palette*/
pos = 0;
break;
} else {
data_tmp = fs_buf;
#else
LV_LOG_WARN("Image built-in indexed line reader can't read file because LV_USE_FILESYSTEM = 0");
return LV_RES_INV;
uint8_t val_act;
lv_coord_t i;
val_act = (*data_tmp & (mask << pos)) >> pos;
lv_color_t color = user_data->palette[val_act];
buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE] = color.full;
buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE] = color.full & 0xFF;
buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE + 1] = (color.full >> 8) & 0xFF;
*((uint32_t *)&buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE]) = color.full;
#else
buf[i * LV_IMG_PX_SIZE_ALPHA_BYTE + LV_IMG_PX_SIZE_ALPHA_BYTE - 1] = user_data->opa[val_act];
pos -= px_size;
if(pos < 0) {
pos = 8 - px_size;
data_tmp++;
return LV_RES_OK;
#else
LV_LOG_WARN("Image built-in indexed line reader failed because LV_IMG_CF_INDEXED is 0 in lv_conf.h");
return LV_RES_INV;
}注意看一下宏定义USE_PNG 下添加的代码,其实添加的东西很少。
主要3个处理:
1、返回图像的大小和类型
2、读取PNG的元数据(直接解出来后的)
3、关闭解码器的时候释放掉解出来的时候申请的内存
当前这个操作的情况下,可以直接在初始化的时候加入图片列表png文件:
形如:
lv_img_dsc_t *image;
image->header.cf = LV_IMG_CF_RAW_ALPHA;
image->header.always_zero = 0;
image->data = file_name;//file_name 就是png文件路径
能调用Png解码到内存显示后,可以调整:
lv_conf.h的
可以限制LVGL使用的内存大小,然后和cache配合使用,在下面:
lv_conf.h的
#define LV_IMG_CACHE_DEF_SIZE 5
可以约束调用解码显示到当前页面的缓冲图片源数量,减少访问图片源文件次数
完结,撒花~
最近编辑记录 TeveT (2021-01-23 18:30:02)
牛, 向楼主学习! Makefile 也要修改一下对吧?
这个一定要改的,不改就没拿到png的库接口
这个其实也挺好摸索的,lvgl的参考手册写得很清楚,就改这个文件
https://raw.githubusercontent.com/lvgl/lvgl/release/v6/src/lv_draw/lv_img_decoder.c
楼主干得漂亮, 顺便用beyond compare 对比了一下。
楼主厉害!正需要呢!!楼主威武!!!
试一下哈,ligpng可以用其他的png库替代,有就行,LVGL也有版本支持了png , lodepng
链接在这里:
https://github.com/lvgl/lv_lib_png
dgtg wrote:
楼主厉害!正需要呢!!楼主威武!!!
