https://v2as.com/article/478a8ec2-efa3-4bc4-86a0-90cbd90ad766
Tick的作用
操作系统,tick仿佛是人的脉搏,不停的向各个器官提供血液。 Tick在操作系统中,会进行调度,是分时调度最基础的组成部分。在学习Linux内核时,我只知道这个概念,却没能真正看到它是如何实现的。在经历了大约2个周的仔细阅读之后,终于能窥其全貌。
jiffies的更新。
kernel/time/timekeeping.c
void do_timer(unsigned long ticks)
jiffies_64 += ticks;
update_wall_time();
calc_global_load(ticks);
}kernel/time/tick-common.c
static void tick_periodic(int cpu)
if (tick_do_timer_cpu == cpu) {
write_seqlock(&jiffies_lock);
/* Keep track of the next tick event */
tick_next_period = ktime_add(tick_next_period, tick_period);
do_timer(1);
write_sequnlock(&jiffies_lock);
update_process_times(user_mode(get_irq_regs()));
profile_tick(CPU_PROFILING);
* Event handler for periodic ticks
void tick_handle_periodic(struct clock_event_device *dev)
int cpu = smp_processor_id();
ktime_t next;
tick_periodic(cpu);
if (dev->mode != CLOCK_EVT_MODE_ONESHOT)
return;
* Setup the next period for devices, which do not have
* periodic mode:
next = ktime_add(dev->next_event, tick_period);
for (;;) {
if (!clockevents_program_event(dev, next, false))
return;
* Have to be careful here. If we're in oneshot mode,
* before we call tick_periodic() in a loop, we need
* to be sure we're using a real hardware clocksource.
* Otherwise we could get trapped in an infinite
* loop, as the tick_periodic() increments jiffies,
* when then will increment time, posibly causing
* the loop to trigger again and again.
if (timekeeping_valid_for_hres())
tick_periodic(cpu);
next = ktime_add(next, tick_period);
}kernel/time/tick-broadcast.c
* Set the periodic handler depending on broadcast on/off
void tick_set_periodic_handler(struct clock_event_device *dev, int broadcast)
if (!broadcast)
dev->event_handler = tick_handle_periodic;
dev->event_handler = tick_handle_periodic_broadcast;
* Setup the device for a periodic tick
void tick_setup_periodic(struct clock_event_device *dev, int broadcast)
tick_set_periodic_handler(dev, broadcast);
/* Broadcast setup ? */
if (!tick_device_is_functional(dev))
return;
if ((dev->features & CLOCK_EVT_FEAT_PERIODIC) &&
!tick_broadcast_oneshot_active()) {
clockevents_set_mode(dev, CLOCK_EVT_MODE_PERIODIC);
} else {
unsigned long seq;
ktime_t next;
do {
seq = read_seqbegin(&jiffies_lock);
next = tick_next_period;
} while (read_seqretry(&jiffies_lock, seq));
clockevents_set_mode(dev, CLOCK_EVT_MODE_ONESHOT);
for (;;) {
return;
* Setup the tick device
static void tick_setup_device(struct tick_device *td,
struct clock_event_device *newdev, int cpu,
const struct cpumask *cpumask)
ktime_t next_event;
void (*handler)(struct clock_event_device *) = NULL;
if (tick_device_uses_broadcast(newdev, cpu))
return;
if (td->mode == TICKDEV_MODE_PERIODIC)
tick_setup_periodic(newdev, 0);
tick_setup_oneshot(newdev, handler, next_event);
* Check, if the new registered device should be used.
void tick_check_new_device(struct clock_event_device *newdev)
struct clock_event_device *curdev;
struct tick_device *td;
int cpu;
unsigned long flags;
clockevents_exchange_device(curdev, newdev);
tick_setup_device(td, newdev, cpu, cpumask_of(cpu));
if (newdev->features & CLOCK_EVT_FEAT_ONESHOT)
tick_oneshot_notify();
raw_spin_unlock_irqrestore(&tick_device_lock, flags);
return;
out_bc:
* Can the new device be used as a broadcast device ?
tick_install_broadcast_device(newdev);
}Tick的eventhandler是在clock_event_device的注册过程中设置的。
clock_event_device的注册继续沿着调用关系向下寻找。
kernel/time/clockevents.c
* clockevents_register_device - register a clock event device
* @dev: device to register
void clockevents_register_device(struct clock_event_device *dev)
BUG_ON(dev->mode != CLOCK_EVT_MODE_UNUSED);
if (!dev->cpumask) {
WARN_ON(num_possible_cpus() > 1);
dev->cpumask = cpumask_of(smp_processor_id());
raw_spin_lock_irqsave(&clockevents_lock, flags);
list_add(&dev->list, &clockevent_devices);
tick_check_new_device(dev);
clockevents_notify_released();
raw_spin_unlock_irqrestore(&clockevents_lock, flags);
void clockevents_config_and_register(struct clock_event_device *dev,
u32 freq, unsigned long min_delta,
unsigned long max_delta)
dev->min_delta_ticks = min_delta;
dev->max_delta_ticks = max_delta;
clockevents_config(dev, freq);
clockevents_register_device(dev);
}还是基于我相对熟悉的Arm作为例子。
drivers/clocksource/arm_arch_timer.c
static void __cpuinit __arch_timer_setup(unsigned type,
struct clock_event_device *clk)
clk->features = CLOCK_EVT_FEAT_ONESHOT;
if (type == ARCH_CP15_TIMER) {
clk->features |= CLOCK_EVT_FEAT_C3STOP;
clk->name = "arch_sys_timer";
clk->rating = 450;
clk->cpumask = cpumask_of(smp_processor_id());
if (arch_timer_use_virtual) {
clk->irq = arch_timer_ppi[VIRT_PPI];
clk->set_mode = arch_timer_set_mode_virt;
clk->set_next_event = arch_timer_set_next_event_virt;
} else {
clk->irq = arch_timer_ppi[PHYS_SECURE_PPI];
clk->set_mode = arch_timer_set_mode_phys;
clk->set_next_event = arch_timer_set_next_event_phys;
} else {
clk->features |= CLOCK_EVT_FEAT_DYNIRQ;
clk->name = "arch_mem_timer";
clk->rating = 400;
clk->cpumask = cpu_all_mask;
if (arch_timer_mem_use_virtual) {
clk->set_mode = arch_timer_set_mode_virt_mem;
arch_timer_set_next_event_virt_mem;
} else {
clk->set_mode = arch_timer_set_mode_phys_mem;
arch_timer_set_next_event_phys_mem;
clk->set_mode(CLOCK_EVT_MODE_SHUTDOWN, clk);
clockevents_config_and_register(clk, arch_timer_rate, 0xf, 0x7fffffff);
static int __cpuinit arch_timer_setup(struct clock_event_device *clk)
__arch_timer_setup(ARCH_CP15_TIMER, clk);
static int __init arch_timer_register(void)
int err;
int ppi;
arch_timer_evt = alloc_percpu(struct clock_event_device);
if (!arch_timer_evt) {
err = -ENOMEM;
goto out;
/* Immediately configure the timer on the boot CPU */
arch_timer_setup(this_cpu_ptr(arch_timer_evt));
out_unreg_notify:
unregister_cpu_notifier(&arch_timer_cpu_nb);
out_free_irq:
free_percpu_irq(arch_timer_ppi[VIRT_PPI], arch_timer_evt);
else {
free_percpu_irq(arch_timer_ppi[PHYS_SECURE_PPI],
arch_timer_evt);
if (arch_timer_ppi[PHYS_NONSECURE_PPI])
free_percpu_irq(arch_timer_ppi[PHYS_NONSECURE_PPI],
arch_timer_evt);
out_free:
free_percpu(arch_timer_evt);
out:
return err;
static void __init arch_timer_init(struct device_node *np)
int i;
if (arch_timers_present & ARCH_CP15_TIMER) {
pr_warn("arch_timer: multiple nodes in dt, skipping\n");
return;
arch_timers_present |= ARCH_CP15_TIMER;
for (i = PHYS_SECURE_PPI; i < MAX_TIMER_PPI; i++)
arch_timer_ppi[i] = irq_of_parse_and_map(np, i);
arch_timer_detect_rate(NULL, np);
* If HYP mode is available, we know that the physical timer
* has been configured to be accessible from PL1. Use it, so
* that a guest can use the virtual timer instead.
* If no interrupt provided for virtual timer, we'll have to
* stick to the physical timer. It'd better be accessible…
if (is_hyp_mode_available() || !arch_timer_ppi[VIRT_PPI]) {
arch_timer_use_virtual = false;
if (!arch_timer_ppi[PHYS_SECURE_PPI] ||
!arch_timer_ppi[PHYS_NONSECURE_PPI]) {
pr_warn("arch_timer: No interrupt available, giving up\n");
return;
arch_timer_register();
arch_timer_common_init();
CLOCKSOURCE_OF_DECLARE(armv7_arch_timer, "arm,armv7-timer", arch_timer_init);
CLOCKSOURCE_OF_DECLARE(armv8_arch_timer, "arm,armv8-timer", arch_timer_init);arch_timer_init对整个时钟进行设置。
#define CLOCKSOURCE_OF_DECLARE(name, compat, fn) \
static const struct of_device_id __clksrc_of_table_##name \
__used __section(__clksrc_of_table) \
= { .compatible = compat, \
.data = (fn == (clocksource_of_init_fn)NULL) ? fn : fn }
CLOCKSOURCE_OF_DECLARE生成一个表项。time_init
arch/arm64/kernel/time.c
void __init time_init(void)
u32 arch_timer_rate;
of_clk_init(NULL);
clocksource_of_init();
tick_setup_hrtimer_broadcast();
arch_timer_rate = arch_timer_get_rate();
if (!arch_timer_rate)
panic("Unable to initialise architected timer.\n");
/* Calibrate the delay loop directly */
lpj_fine = arch_timer_rate / HZ;
}drivers/clocksource/clksrc-of.c
void __init clocksource_of_init(void)
struct device_node *np;
const struct of_device_id *match;
clocksource_of_init_fn init_func;
for_each_matching_node_and_match(np, __clksrc_of_table, &match) {
init_func = match->data;
init_func(np);
}整个故事到了尾声, clocksource_of_init将遍历device tree所有的节点,如果找到和__clksrc_of_tablematch的, 就调用相应的函数。
device tree的一个Node:
timer {
compatible = "arm,armv8-timer";
interrupts = <0x1 0x2 0xff08 0x1 0x3 0xff08 0x1 0x4 0xff08 0x1 0x1 0xff08>;
clock-frequency = <0x124f800>;
};离线
