内核版本:zero-5.2.y
按照晕哥写的教程,一步一步操作。
https://whycan.com/t_576.html#p1579
内核启动log中显示如下:
[ 1.052704] fbtft_of_value: buswidth = 8
[ 1.056628] fbtft_of_value: debug = 0
[ 1.060326] fbtft_of_value: rotate = 270
[ 1.064244] fbtft_of_value: fps = 10
[ 1.068691] fb_ili9341 spi0.0: Failed to request reset-gpios GPIO:-2
[ 1.075218] fb_ili9341: probe of spi0.0 failed with error -2是不是zero-5.2.y的内核太新了,改了什么东西,导致按照上面的流程操作后,启动失败。
sun8i-v3.dtsi下的pio节点
pio: pinctrl@1c20800 {
compatible = "allwinner,sun8i-v3s-pinctrl";
reg = <0x01c20800 0x400>;
interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
gpio-controller;
#gpio-cells = <3>;
interrupt-controller;
#interrupt-cells = <3>;
emac_rgmii_pins: emac-rgmii-pins {
pins = "PD0", "PD1", "PD2", "PD3", "PD4",
"PD5", "PD7", "PD8", "PD9", "PD10",
"PD12", "PD13", "PD15", "PD16", "PD17";
function = "emac";
drive-strength = <40>;
i2c0_pins: i2c0-pins {
pins = "PB6", "PB7";
function = "i2c0";
pwm0_pins: pwm0 {
pins = "PB4";
function = "pwm0";
uart0_pb_pins: uart0-pb-pins {
pins = "PB8", "PB9";
function = "uart0";
lcd_rgb666_pins_a: lcd-rgb666-pe {
pins = "PE0", "PE1", "PE2", "PE3", "PE4", "PE5",
"PE6", "PE7", "PE8", "PE9", "PE10", "PE11",
"PE12", "PE13", "PE14", "PE15", "PE16", "PE17",
"PE18", "PE19", "PE23", "PE24";
function = "lcd";
mmc0_pins: mmc0-pins {
pins = "PF0", "PF1", "PF2", "PF3",
"PF4", "PF5";
function = "mmc0";
drive-strength = <30>;
bias-pull-up;
mmc1_pins: mmc1-pins {
pins = "PG0", "PG1", "PG2", "PG3",
"PG4", "PG5";
function = "mmc1";
bias-pull-up;
spi0_pins: spi0-pins {
function = "spi0";
pwm1_pins: pwm1 {
pins = "PB5";
function = "pwm1";
csi1_8bit: csi1-8bit@0 {
pins = "PE6","PE7","PE8","PE9","PE10","PE11","PE12","PE13","PE14","PE15";
bias-disable;
function = "csi";
csi1_clk: csi1-clk@0 {
pins = "PE0","PE2","PE3";
bias-disable;
function = "csi";
csi1_mclk: csi1-mclk@0 {
pins = "PE1";
bias-disable;
function = "csi";
i2c1_pins: i2c1 {
pins = "PE21", "PE22";
function = "i2c1";
};sun8i-v3s-licheepi-zero.dts下的spi节点
163 &spi0 {
164 status = "okay";
165 ili9341@0 {
166 compatible = "ilitek,ili9341";
167 reg = <0>;
168 spi-max-frequency = <15000000>;
169 rotate = <270>;
170 bgr;
171 fps = <10>;
172 buswidth = <8>;
173 reset-gpios = <&pio 1 7 GPIO_ACTIVE_LOW>;
174 dc-gpios = <&pio 1 5 GPIO_ACTIVE_LOW>;
175 debug = <0>;
176 };
177 };173 reset-gpios = <&pio 1 7 GPIO_ACTIVE_LOW>; 指的是PB7,是i2c0的SDA引脚,讲道理是可以获取到这个引脚的。配置教程上面也说了,SPI屏幕的复位引脚可以直接接电源的,所以不接PB7也可以。所以我不清楚为什么会获取dtb里面 reset 引脚发生错误
哇酷小二 wrote:
你的i2c0使能了吗?也是用pb7?
没动过i2c0的设备树代码。
在sun8i-v3s-licheepi-zero.dts中有i2c0这个节点
111 &i2c0 {
112 status = "okay";
113 ns2009: ns2009@48 {
114 compatible = "nsiway,ns2009";
115 reg = <0x48>;
116 };
117 };离线
哇酷小二 wrote:
当然要动啊,删除或者改
status = "disabled";
修改后还是报原来的错误。
[ 1.176248] fbtft_of_value: buswidth = 8
[ 1.180222] fbtft_of_value: debug = 0
[ 1.183881] fbtft_of_value: rotate = 270
[ 1.187798] fbtft_of_value: fps = 10
[ 1.192082] fb_ili9341 spi0.0: Failed to request reset-gpios GPIO:-2
[ 1.198681] fb_ili9341: probe of spi0.0 failed with error -2下面我重新贴下几个文件的相关代码。
sun8i-v3s-licheepi-zero.dts文件
183 &spi0 {
184 status = "okay";
185 ili9341@0 {
186 compatible = "ilitek,ili9341";
187 reg = <0>;
188 spi-max-frequency = <15000000>;
189 rotate = <270>;
190 bgr;
191 fps = <10>;
192 buswidth = <8>;
193 reset-gpios = <&pio 1 7 GPIO_ACTIVE_LOW>;
194 dc-gpios = <&pio 1 5 GPIO_ACTIVE_LOW>;
195 debug = <0>;
196 };
197 };sun8i-v3s.dtsi文件
521 i2c0: i2c@1c2ac00 {
522 compatible = "allwinner,sun6i-a31-i2c";
523 reg = <0x01c2ac00 0x400>;
524 interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
525 clocks = <&ccu CLK_BUS_I2C0>;
526 resets = <&ccu RST_BUS_I2C0>;
527 pinctrl-names = "default";
528 pinctrl-0 = <&i2c0_pins>;
529 status = "eabled";
530 #address-cells = <1>;
531 #size-cells = <0>;
532 };离线
哇酷小二 wrote:
当然要动啊,删除或者改
我刚刚在内核4.13.16版本上,按照教程一步步操作,发现没有遇到在5.2版本上的错误。
下面是运行成功的log,但是屏幕并没有亮起来。
[ 1.244305] fbtft_of_value: buswidth = 8
[ 1.248267] fbtft_of_value: debug = 0
[ 1.251925] fbtft_of_value: rotate = 270
[ 1.255841] fbtft_of_value: fps = 10
[ 1.304740] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.314784] mmc0: new high speed SDHC card at address 1234
[ 1.320956] mmcblk0: mmc0:1234 SA08G 7.21 GiB
[ 1.327049] mmcblk0: p1 p2
[ 1.609569] Console: switching to colour frame buffer device 40x30
[ 1.616454] graphics fb0: fb_ili9341 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=10, spi32766.0 at 15 MHz使用下面的命令,并没有发现屏幕出现变化
cat /dev/urandom > /dev/fb0
cat /dev/zero > /dev/fb0离线
哇酷小二 wrote:
没理由,只能怀疑你改错了文件,或者dtb没有起作用。
我百度了下那错误,找到这个帖子,但是我看不懂。晕哥可以看下它写的内容
https://blog.csdn.net/qulang000/article/details/114686525
按照里面的操作,修改bug引脚相关代码后,还是报同样的错误。
贴出你相关的几个完整设备树文件吧
阿黄 wrote:
贴出你相关的几个完整设备树文件吧
完整的设备树文件如下
sun8i-v3s.dtsi
* Copyright (C) 2016 Icenowy Zheng <icenowy@aosc.xyz>
* This file is dual-licensed: you can use it either under the terms
* of the GPL or the X11 license, at your option. Note that this dual
* licensing only applies to this file, and not this project as a
* whole.
* a) This file is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of the
* License, or (at your option) any later version.
* This file is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* Or, alternatively,
* b) Permission is hereby granted, free of charge, to any person
* obtaining a copy of this software and associated documentation
* files (the "Software"), to deal in the Software without
* restriction, including without limitation the rights to use,
* copy, modify, merge, publish, distribute, sublicense, and/or
* sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following
* conditions:
* The above copyright notice and this permission notice shall be
* included in all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
* EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
* OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
* NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
* HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
* WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
* OTHER DEALINGS IN THE SOFTWARE.
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include <dt-bindings/clock/sun8i-v3s-ccu.h>
#include <dt-bindings/reset/sun8i-v3s-ccu.h>
#size-cells = <1>;
interrupt-parent = <&gic>;
chosen {
#size-cells = <1>;
ranges;
//simplefb_lcd: framebuffer@0 {
// compatible = "allwinner,simple-framebuffer",
// "simple-framebuffer";
// allwinner,pipeline = "de0-lcd0";
// clocks = <&ccu CLK_BUS_TCON0>, <&display_clocks 0>,
// <&display_clocks 6>, <&ccu CLK_TCON0>;
// status = "disabled";
cpus {
#size-cells = <0>;
cpu@0 {
compatible = "arm,cortex-a7";
device_type = "cpu";
reg = <0>;
clocks = <&ccu CLK_CPU>;
de: display-engine {
compatible = "allwinner,sun8i-v3s-display-engine";
allwinner,pipelines = <&mixer0>;
timer {
compatible = "arm,armv7-timer";
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>;
clocks {
#size-cells = <1>;
ranges;
osc24M: osc24M_clk {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24000000>;
osc32k: osc32k_clk {
#clock-cells = <0>;
clock-frequency = <32768>;
soc {
compatible = "simple-bus";
#size-cells = <1>;
ranges;
display_clocks: clock@1000000 {
compatible = "allwinner,sun8i-v3s-de2-clk";
reg = <0x01000000 0x100000>;
clocks = <&ccu CLK_DE>,
<&ccu CLK_BUS_DE>;
clock-names = "mod",
"bus";
resets = <&ccu RST_BUS_DE>;
#clock-cells = <1>;
#reset-cells = <1>;
mixer0: mixer@1100000 {
compatible = "allwinner,sun8i-v3s-de2-mixer";
reg = <0x01100000 0x100000>;
clocks = <&display_clocks 0>,
<&display_clocks 6>;
clock-names = "bus",
"mod";
resets = <&display_clocks 0>;
assigned-clocks = <&display_clocks 6>;
assigned-clock-rates = <150000000>;
ports {
#size-cells = <0>;
mixer0_out: port@1 {
reg = <1>;
mixer0_out_tcon0: endpoint {
remote-endpoint = <&tcon0_in_mixer0>;
syscon: syscon@1c00000 {
compatible = "allwinner,sun8i-v3s-system-controller",
"syscon";
reg = <0x01c00000 0x1000>;
tcon0: lcd-controller@1c0c000 {
compatible = "allwinner,sun8i-v3s-tcon";
reg = <0x01c0c000 0x1000>;
interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>;
<&ccu CLK_TCON0>;
clock-names = "ahb",
"tcon-ch0";
clock-output-names = "tcon-pixel-clock";
#clock-cells = <0>;
resets = <&ccu RST_BUS_TCON0>;
reset-names = "lcd";
ports {
#size-cells = <0>;
tcon0_in: port@0 {
reg = <0>;
tcon0_in_mixer0: endpoint {
remote-endpoint = <&mixer0_out_tcon0>;
tcon0_out: port@1 {
#size-cells = <0>;
reg = <1>;
dma: dma-controller@01c02000 {
compatible = "allwinner,sun8i-v3s-dma";
reg = <0x01c02000 0x1000>;
interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ccu CLK_BUS_DMA>;
resets = <&ccu RST_BUS_DMA>;
#dma-cells = <1>;
mmc0: mmc@1c0f000 {
compatible = "allwinner,sun7i-a20-mmc";
reg = <0x01c0f000 0x1000>;
clocks = <&ccu CLK_BUS_MMC0>,
<&ccu CLK_MMC0>,
<&ccu CLK_MMC0_OUTPUT>,
<&ccu CLK_MMC0_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC0>;
reset-names = "ahb";
interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&mmc0_pins>;
#size-cells = <0>;
mmc1: mmc@1c10000 {
reg = <0x01c10000 0x1000>;
clocks = <&ccu CLK_BUS_MMC1>,
<&ccu CLK_MMC1>,
<&ccu CLK_MMC1_OUTPUT>,
<&ccu CLK_MMC1_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC1>;
interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&mmc1_pins>;
#size-cells = <0>;
mmc2: mmc@1c11000 {
reg = <0x01c11000 0x1000>;
clocks = <&ccu CLK_BUS_MMC2>,
<&ccu CLK_MMC2>,
<&ccu CLK_MMC2_OUTPUT>,
<&ccu CLK_MMC2_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC2>;
interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
usb_otg: usb@1c19000 {
compatible = "allwinner,sun8i-h3-musb";
reg = <0x01c19000 0x0400>;
clocks = <&ccu CLK_BUS_OTG>;
resets = <&ccu RST_BUS_OTG>;
interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "mc";
phys = <&usbphy 0>;
phy-names = "usb";
extcon = <&usbphy 0>;
usbphy: phy@1c19400 {
compatible = "allwinner,sun8i-v3s-usb-phy";
reg = <0x01c19400 0x2c>,
<0x01c1a800 0x4>;
reg-names = "phy_ctrl",
"pmu0";
clocks = <&ccu CLK_USB_PHY0>;
clock-names = "usb0_phy";
resets = <&ccu RST_USB_PHY0>;
reset-names = "usb0_reset";
#phy-cells = <1>;
ehci0: usb@01c1a000 {
compatible = "allwinner,sun8i-v3s-ehci", "generic-ehci";
reg = <0x01c1a000 0x100>;
interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>;
resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_BUS_OHCI0>;
ohci0: usb@01c1a400 {
compatible = "allwinner,sun8i-v3s-ohci", "generic-ohci";
reg = <0x01c1a400 0x100>;
interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ccu CLK_BUS_EHCI0>, <&ccu CLK_BUS_OHCI0>,
<&ccu CLK_USB_OHCI0>;
ccu: clock@1c20000 {
compatible = "allwinner,sun8i-v3s-ccu";
reg = <0x01c20000 0x400>;
clock-names = "hosc", "losc";
#clock-cells = <1>;
#reset-cells = <1>;
rtc: rtc@1c20400 {
compatible = "allwinner,sun6i-a31-rtc";
reg = <0x01c20400 0x54>;
interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
csi1: csi@1cb4000 {
compatible = "allwinner,sun8i-v3s-csi";
reg = <0x01cb4000 0x1000>;
interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ccu CLK_BUS_CSI>,
<&ccu CLK_CSI1_SCLK>,
<&ccu CLK_DRAM_CSI>;
clock-names = "bus", "mod", "ram";
resets = <&ccu RST_BUS_CSI>;
gpio-controller;
#gpio-cells = <3>;
function = "emac";
function = "i2c0";
pwm0_pins: pwm0 {
pins = "PB4";
function = "pwm0";
function = "uart0";
function = "lcd";
"PF4", "PF5";
function = "mmc0";
bias-pull-up;
"PG4", "PG5";
function = "mmc1";
bias-pull-up;
function = "spi0";
pwm1_pins: pwm1 {
pins = "PB5";
function = "pwm1";
bias-disable;
function = "csi";
bias-disable;
function = "csi";
pins = "PE1";
bias-disable;
function = "csi";
i2c1_pins: i2c1 {
function = "i2c1";
timer@1c20c00 {
compatible = "allwinner,sun4i-a10-timer";
reg = <0x01c20c00 0xa0>;
interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&osc24M>;
wdt0: watchdog@1c20ca0 {
reg = <0x01c20ca0 0x20>;
interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
pwm: pwm@1c21400 {
compatible = "allwinner,sun8i-v3s-pwm",
"allwinner,sun7i-a20-pwm";
reg = <0x01c21400 0x400>;
clocks = <&osc24M>;
#pwm-cells = <3>;
lradc: lradc@1c22800 {
compatible = "allwinner,sun4i-a10-lradc-keys";
reg = <0x01c22800 0x400>;
interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
codec: codec@01c22c00 {
#sound-dai-cells = <0>;
compatible = "allwinner,sun8i-v3s-codec";
reg = <0x01c22c00 0x400>;
interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ccu CLK_BUS_CODEC>, <&ccu CLK_AC_DIG>;
clock-names = "apb", "codec";
resets = <&ccu RST_BUS_CODEC>;
dmas = <&dma 15>, <&dma 15>;
dma-names = "rx", "tx";
allwinner,codec-analog-controls = <&codec_analog>;
codec_analog: codec-analog@01c23000 {
compatible = "allwinner,sun8i-v3s-codec-analog";
reg = <0x01c23000 0x4>;
uart0: serial@1c28000 {
reg = <0x01c28000 0x400>;
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>;
reg-io-width = <4>;
uart1: serial@1c28400 {
reg = <0x01c28400 0x400>;
interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>;
reg-io-width = <4>;
uart2: serial@1c28800 {
reg = <0x01c28800 0x400>;
interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
reg-shift = <2>;
reg-io-width = <4>;
i2c0: i2c@1c2ac00 {
#size-cells = <0>;
i2c1: i2c@1c2b000 {
reg = <0x01c2b000 0x400>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ccu CLK_BUS_I2C1>;
resets = <&ccu RST_BUS_I2C1>;
#size-cells = <0>;
emac: ethernet@1c30000 {
compatible = "allwinner,sun8i-h3-emac";
syscon = <&syscon>;
reg = <0x01c30000 0x10000>;
interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "macirq";
resets = <&ccu RST_BUS_EMAC>;
reset-names = "stmmaceth";
clocks = <&ccu CLK_BUS_EMAC>;
clock-names = "stmmaceth";
mdio: mdio {
#size-cells = <0>;
compatible = "snps,dwmac-mdio";
mdio-mux {
compatible = "allwinner,sun8i-h3-mdio-mux";
#size-cells = <0>;
mdio-parent-bus = <&mdio>;
/* Only one MDIO is usable at the time */
internal_mdio: mdio@1 {
compatible = "allwinner,sun8i-h3-mdio-internal";
reg = <1>;
#size-cells = <0>;
int_mii_phy: ethernet-phy@1 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <1>;
clocks = <&ccu CLK_BUS_EPHY>;
resets = <&ccu RST_BUS_EPHY>;
external_mdio: mdio@2 {
reg = <2>;
#size-cells = <0>;
spi0: spi@1c68000 {
compatible = "allwinner,sun8i-h3-spi";
reg = <0x01c68000 0x1000>;
interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>;
clock-names = "ahb", "mod";
pinctrl-0 = <&spi0_pins>;
resets = <&ccu RST_BUS_SPI0>;
status = "enabled";
#size-cells = <0>;
gic: interrupt-controller@1c81000 {
compatible = "arm,gic-400";
reg = <0x01c81000 0x1000>,
<0x01c82000 0x1000>,
<0x01c84000 0x2000>,
<0x01c86000 0x2000>;
interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
};sun8i-v3s-licheepi-zero.dts:
* whole.
* conditions:
/dts-v1/;
#include "sun8i-v3s.dtsi"
model = "Lichee Pi Zero";
compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
aliases {
serial0 = &uart0;
chosen {
pir{
label = "licheepi:blue:usr";
gpio-pir = <&pio 6 5 GPIO_ACTIVE_HIGH>; /* PG5 */
door_magnet{
gpio-door_magnet = <&pio 6 4 GPIO_ACTIVE_HIGH>; /* PG4 */
leds {
compatible = "gpio-leds";
blue_led {
gpios = <&pio 6 1 GPIO_ACTIVE_LOW>; /* PG1 */
green_led {
label = "licheepi:green:usr";
gpios = <&pio 6 0 GPIO_ACTIVE_LOW>; /* PG0 */
default-state = "on";
red_led {
label = "licheepi:red:usr";
gpios = <&pio 6 2 GPIO_ACTIVE_LOW>; /* PG2 */
door_key{
compatible = "door_key";
key-gpio = <&pio 6 3 GPIO_ACTIVE_LOW>;
lcd_key{
compatible = "lcd_key";
key-gpio = <&pio 6 2 GPIO_ACTIVE_LOW>;
&ehci0 {
&mmc0 {
broken-cd;
bus-width = <4>;
vmmc-supply = <®_vcc3v3>;
&i2c0 {
ns2009: ns2009@48 {
reg = <0x48>;
&ohci0 {
&uart0 {
pinctrl-0 = <&uart0_pb_pins>;
&usb_otg {
dr_mode = "otg";
&usbphy {
usb0_id_det-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>;
&csi1 {
pinctrl-0 = <&csi1_clk &csi1_8bit>;
port {
csi1_ep: endpoint {
remote-endpoint = <&ov2640_0>;
hsync-active = <0>;
vsync-active = <0>;
bus-width = <10>;
pclk-sample = <1>;
&i2c1 {
pinctrl-0 = <&i2c1_pins>;
ov2640: camera@30 {
compatible = "ovti,ov2640";
reg = <0x30>;
pinctrl-0 = <&csi1_mclk>;
clocks = <&ccu CLK_CSI1_MCLK>;
clock-names = "xvclk";
assigned-clocks = <&ccu CLK_CSI1_MCLK>;
assigned-clock-rates = <24000000>;
port {
ov2640_0: endpoint {
remote-endpoint = <&csi1_ep>;
bus-width = <10>;
&spi0 {
ili9341@0 {
reg = <0>;
rotate = <270>;
bgr;
fps = <10>;
buswidth = <8>;
debug = <0>;
};离线
&i2c0 {
status = "disable";
ns2009: ns2009@48 {
reg = <0x48>;
阿黄 wrote:
&i2c0 {
status = "disable";ns2009: ns2009@48 {
reg = <0x48>;
改了之后还是报下面的错误
[ 1.165724] fbtft_of_value: buswidth = 8
[ 1.169696] fbtft_of_value: debug = 0
[ 1.173355] fbtft_of_value: rotate = 270
[ 1.177272] fbtft_of_value: fps = 10
[ 1.181547] fb_ili9341 spi0.0: Failed to request reset-gpios GPIO:-2
[ 1.188150] fb_ili9341: probe of spi0.0 failed with error -2离线
都按这个改了?如果也改了,把of获取reset gpio那一段屏蔽起来,看看能不能获取dc gpio.
我在5.7改了fbtft-core.c 的 fbtft_request_one_gpio fbtft_reset 函数 能用 你可以试试
static int fbtft_request_one_gpio(struct fbtft_par *par,
const char *name, int index,
struct gpio_desc **gpiop)
struct device *dev = par->info->device;
struct device_node *node = dev->of_node;
int gpio, flags, ret = 0;
enum of_gpio_flags of_flags;
char gpio_names[32];
sprintf(gpio_names, "%s-gpios", name);
if (of_find_property(node, gpio_names, NULL)) {
gpio = of_get_named_gpio_flags(node, gpio_names, index, &of_flags);
if (gpio == -ENOENT)
if (gpio == -EPROBE_DEFER)
return gpio;
if (gpio < 0) {
dev_err(dev,
"failed to get '%s' from DT\n", gpio_names);
return gpio;
//active low translates to initially low
flags = (of_flags & OF_GPIO_ACTIVE_LOW) ? GPIOF_OUT_INIT_LOW :
GPIOF_OUT_INIT_HIGH;
ret = devm_gpio_request_one(dev, gpio, flags,
dev->driver->name);
if (ret) {
dev_err(dev,
"gpio_request_one('%s'=%d) failed with %d\n",
gpio_names, gpio, ret);
return ret;
*gpiop = gpio_to_desc(gpio);
fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' = GPIO%d\n",
__func__, gpio_names, gpio);
return ret;
static void fbtft_reset(struct fbtft_par *par)
if (!par->gpio.reset)
return;
fbtft_par_dbg(DEBUG_RESET, par, "%s()\n", __func__);
gpiod_set_value_cansleep(par->gpio.reset, 1);
usleep_range(20, 40);
gpiod_set_value_cansleep(par->gpio.reset, 0);
msleep(120);
msleep(10);
}离线
static int fbtft_request_one_gpio(struct fbtft_par *par, const char *name, int index, struct gpio_desc **gpiop) { struct device *dev = par->info->device; struct device_node *node = dev->of_node; int gpio, flags, ret = 0; enum of_gpio_flags of_flags; char gpio_names[32]; sprintf(gpio_names, "%s-gpios", name); if (of_find_property(node, gpio_names, NULL)) { gpio = of_get_named_gpio_flags(node, gpio_names, index, &of_flags); if (gpio == -ENOENT) return 0; if (gpio == -EPROBE_DEFER) return gpio; if (gpio < 0) { dev_err(dev, "failed to get '%s' from DT\n", gpio_names); return gpio; } //active low translates to initially low flags = (of_flags & OF_GPIO_ACTIVE_LOW) ? GPIOF_OUT_INIT_LOW : GPIOF_OUT_INIT_HIGH; ret = devm_gpio_request_one(dev, gpio, flags, dev->driver->name); if (ret) { dev_err(dev, "gpio_request_one('%s'=%d) failed with %d\n", gpio_names, gpio, ret); return ret; } *gpiop = gpio_to_desc(gpio); fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' = GPIO%d\n", __func__, gpio_names, gpio); } return ret; } static void fbtft_reset(struct fbtft_par *par) { if (!par->gpio.reset) return; fbtft_par_dbg(DEBUG_RESET, par, "%s()\n", __func__); gpiod_set_value_cansleep(par->gpio.reset, 1); usleep_range(20, 40); gpiod_set_value_cansleep(par->gpio.reset, 0); msleep(120); gpiod_set_value_cansleep(par->gpio.reset, 1); msleep(10); }
我按照你贴出来的代码修改后,编译内核的时候报下面的错误,我是不是需要在头文件那里添加什么呀?
CALL scripts/atomic/check-atomics.sh
CALL scripts/checksyscalls.sh
CHK include/generated/compile.h
CC drivers/staging/fbtft/fbtft-core.o
drivers/staging/fbtft/fbtft-core.c: In function ‘fbtft_request_one_gpio’:
drivers/staging/fbtft/fbtft-core.c:102:24: error: storage size of ‘of_flags’ isn’t known
drivers/staging/fbtft/fbtft-core.c:107:9: error: implicit declaration of function ‘of_get_named_gpio_flags’ [-Werror=implicit-function-declaration]
drivers/staging/fbtft/fbtft-core.c:119:29: error: ‘OF_GPIO_ACTIVE_LOW’ undeclared (first use in this function)
drivers/staging/fbtft/fbtft-core.c:119:29: note: each undeclared identifier is reported only once for each function it appears in
drivers/staging/fbtft/fbtft-core.c:119:51: error: ‘GPIOF_OUT_INIT_LOW’ undeclared (first use in this function)
drivers/staging/fbtft/fbtft-core.c:120:29: error: ‘GPIOF_OUT_INIT_HIGH’ undeclared (first use in this function)
drivers/staging/fbtft/fbtft-core.c:121:9: error: implicit declaration of function ‘devm_gpio_request_one’ [-Werror=implicit-function-declaration]
drivers/staging/fbtft/fbtft-core.c:102:24: warning: unused variable ‘of_flags’ [-Wunused-variable]
cc1: some warnings being treated as errors
scripts/Makefile.build:278: recipe for target 'drivers/staging/fbtft/fbtft-core.o' failed
make[3]: *** [drivers/staging/fbtft/fbtft-core.o] Error 1
scripts/Makefile.build:498: recipe for target 'drivers/staging/fbtft' failed
make[2]: *** [drivers/staging/fbtft] Error 2
make[2]: *** Waiting for unfinished jobs....
scripts/Makefile.build:498: recipe for target 'drivers/staging' failed
make[1]: *** [drivers/staging] Error 2
Makefile:1077: recipe for target 'drivers' failed
make: *** [drivers] Error 2离线
哇酷小二 wrote:
https://blog.csdn.net/qulang000/article/details/114686525都按这个改了?如果也改了,把of获取reset gpio那一段屏蔽起来,看看能不能获取dc gpio.
屏蔽掉reset引脚后,就报dc-gpio没找到哈哈哈
[ 1.165822] fbtft_of_value: buswidth = 8
[ 1.169792] fbtft_of_value: debug = 0
[ 1.173452] fbtft_of_value: rotate = 270
[ 1.177369] fbtft_of_value: fps = 10
[ 1.181647] fb_ili9341 spi0.0: Failed to request dc-gpios GPIO:-2
[ 1.187902] fb_ili9341: probe of spi0.0 failed with error -2离线
无痕 wrote:
static int fbtft_request_one_gpio(struct fbtft_par *par, const char *name, int index, struct gpio_desc **gpiop) { struct device *dev = par->info->device; struct device_node *node = dev->of_node; int gpio, flags, ret = 0; enum of_gpio_flags of_flags; char gpio_names[32]; sprintf(gpio_names, "%s-gpios", name); if (of_find_property(node, gpio_names, NULL)) { gpio = of_get_named_gpio_flags(node, gpio_names, index, &of_flags); if (gpio == -ENOENT) return 0; if (gpio == -EPROBE_DEFER) return gpio; if (gpio < 0) { dev_err(dev, "failed to get '%s' from DT\n", gpio_names); return gpio; } //active low translates to initially low flags = (of_flags & OF_GPIO_ACTIVE_LOW) ? GPIOF_OUT_INIT_LOW : GPIOF_OUT_INIT_HIGH; ret = devm_gpio_request_one(dev, gpio, flags, dev->driver->name); if (ret) { dev_err(dev, "gpio_request_one('%s'=%d) failed with %d\n", gpio_names, gpio, ret); return ret; } *gpiop = gpio_to_desc(gpio); fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' = GPIO%d\n", __func__, gpio_names, gpio); } return ret; } static void fbtft_reset(struct fbtft_par *par) { if (!par->gpio.reset) return; fbtft_par_dbg(DEBUG_RESET, par, "%s()\n", __func__); gpiod_set_value_cansleep(par->gpio.reset, 1); usleep_range(20, 40); gpiod_set_value_cansleep(par->gpio.reset, 0); msleep(120); gpiod_set_value_cansleep(par->gpio.reset, 1); msleep(10); }我按照你贴出来的代码修改后,编译内核的时候报下面的错误,我是不是需要在头文件那里添加什么呀?
CALL scripts/atomic/check-atomics.sh CALL scripts/checksyscalls.sh CHK include/generated/compile.h CC drivers/staging/fbtft/fbtft-core.o drivers/staging/fbtft/fbtft-core.c: In function ‘fbtft_request_one_gpio’: drivers/staging/fbtft/fbtft-core.c:102:24: error: storage size of ‘of_flags’ isn’t known enum of_gpio_flags of_flags; ^ drivers/staging/fbtft/fbtft-core.c:107:9: error: implicit declaration of function ‘of_get_named_gpio_flags’ [-Werror=implicit-function-declaration] gpio = of_get_named_gpio_flags(node, gpio_names, index, &of_flags); ^ drivers/staging/fbtft/fbtft-core.c:119:29: error: ‘OF_GPIO_ACTIVE_LOW’ undeclared (first use in this function) flags = (of_flags & OF_GPIO_ACTIVE_LOW) ? GPIOF_OUT_INIT_LOW : ^ drivers/staging/fbtft/fbtft-core.c:119:29: note: each undeclared identifier is reported only once for each function it appears in drivers/staging/fbtft/fbtft-core.c:119:51: error: ‘GPIOF_OUT_INIT_LOW’ undeclared (first use in this function) flags = (of_flags & OF_GPIO_ACTIVE_LOW) ? GPIOF_OUT_INIT_LOW : ^ drivers/staging/fbtft/fbtft-core.c:120:29: error: ‘GPIOF_OUT_INIT_HIGH’ undeclared (first use in this function) GPIOF_OUT_INIT_HIGH; ^ drivers/staging/fbtft/fbtft-core.c:121:9: error: implicit declaration of function ‘devm_gpio_request_one’ [-Werror=implicit-function-declaration] ret = devm_gpio_request_one(dev, gpio, flags, ^ drivers/staging/fbtft/fbtft-core.c:102:24: warning: unused variable ‘of_flags’ [-Wunused-variable] enum of_gpio_flags of_flags; ^ cc1: some warnings being treated as errors scripts/Makefile.build:278: recipe for target 'drivers/staging/fbtft/fbtft-core.o' failed make[3]: *** [drivers/staging/fbtft/fbtft-core.o] Error 1 scripts/Makefile.build:498: recipe for target 'drivers/staging/fbtft' failed make[2]: *** [drivers/staging/fbtft] Error 2 make[2]: *** Waiting for unfinished jobs.... scripts/Makefile.build:498: recipe for target 'drivers/staging' failed make[1]: *** [drivers/staging] Error 2 Makefile:1077: recipe for target 'drivers' failed make: *** [drivers] Error 2
在该文件添加下面这个头文件后,编译就不报错了
#include <linux/of_gpio.h>
reset GPIO能申请到了,但是dc引脚又出问题了,报下面的错误。
[ 1.165851] fbtft_of_value: buswidth = 8
[ 1.169818] fbtft_of_value: debug = 0
[ 1.173478] fbtft_of_value: rotate = 270
[ 1.177395] fbtft_of_value: fps = 10
[ 1.181682] @ pdata->display.buswidth = 8
[ 1.185755] @ par->gpio.dc = 0
[ 1.188882] fb_ili9341 spi0.0: Missing info about 'dc' gpio. Aborting.追log追到这里,原因是par->gpio.dc = 0导致下面的if条件成立。这问题奇奇怪怪的。
1173 if (pdata->display.buswidth != 9 && par->startbyte == 0 &&
1174 !par->gpio.dc) {
1175 printk ("@ pdata->display.buswidth = %d\n", pdata->display.buswidth);
1176 printk ("@ par->gpio.dc = %d\n", par->gpio.dc);
1177 dev_err(par->info->device,
1178 "Missing info about 'dc' gpio. Aborting.\n");
1179 return -EINVAL;
1180 }另外我今晚跟着教程走,在4.17的内核中能够成功驱动手上的屏幕,所以屏幕是正常的。
注意屏幕上的LED引脚要接3.3V
[ 1.165851] fbtft_of_value: buswidth = 8 [ 1.169818] fbtft_of_value: debug = 0 [ 1.173478] fbtft_of_value: rotate = 270 [ 1.177395] fbtft_of_value: fps = 10 [ 1.181682] @ pdata->display.buswidth = 8 [ 1.185755] @ par->gpio.dc = 0 [ 1.188882] fb_ili9341 spi0.0: Missing info about 'dc' gpio. Aborting.追log追到这里,原因是par->gpio.dc = 0导致下面的if条件成立。这问题奇奇怪怪的。
1173 if (pdata->display.buswidth != 9 && par->startbyte == 0 && 1174 !par->gpio.dc) { 1175 printk ("@ pdata->display.buswidth = %d\n", pdata->display.buswidth); 1176 printk ("@ par->gpio.dc = %d\n", par->gpio.dc); 1177 dev_err(par->info->device, 1178 "Missing info about 'dc' gpio. Aborting.\n"); 1179 return -EINVAL; 1180 }另外我今晚跟着教程走,在4.17的内核中能够成功驱动手上的屏幕,所以屏幕是正常的。
注意屏幕上的LED引脚要接3.3V
你这不明显是DC申请不到吗? 可以在 fbtft_request_one_gpio 添加点打印函数 看看?
注意屏幕上的LED引脚要接3.3V你这不明显是DC申请不到吗? 可以在 fbtft_request_one_gpio 添加点打印函数 看看?
如果dc申请不到的话,不应该是报类似下面的错误吗?
[ 1.181547] fb_ili9341 spi0.0: Failed to request reset-gpios GPIO:-2应该是报[ 1.181547] fb_ili9341 spi0.0: Failed to request dc-gpios GPIO:-2
我感觉不是dc申请不到哈。不过晚点,我会按照你说,把那个地方打印出来看看。
感谢大佬指点,按照你的指示,在fbtft_request_one_gpio加打印函数调试,发现问题,现在已经解决,屏幕已经点亮。
昨天调试后报下面这个错误,根据楼上大佬说的是IO没有申请成功,让我在fbtft_request_one_gpio加打印函数看看,我照做了(一定要勤动手),结果真的发现问题。
[ 1.188882] fb_ili9341 spi0.0: Missing info about 'dc' gpio. Aborting.fbtft_request_one_gpio加入打印函数后的代码,关键的打印函数在108行。
5 static int fbtft_request_one_gpio(struct fbtft_par *par,
76 const char *name, int index,
77 struct gpio_desc **gpiop)
78 {
79 /*
80 struct device *dev = par->info->device;
81 struct device_node *node = dev->of_node;
82 int ret = 0;
83
84 if (of_find_property(node, name, NULL)) {
85 *gpiop = devm_gpiod_get_index(dev, dev->driver->name, index,
86 GPIOD_OUT_HIGH);
87 if (IS_ERR(*gpiop)) {
88 ret = PTR_ERR(*gpiop);
89 dev_err(dev,
90 "Failed to request %s GPIO:%d\n", name, ret);
91 return ret;
92 }
93 fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' GPIO\n",
94 __func__, name);
95 }
96
97 return ret;
98 */
99
100 struct device *dev = par->info->device;
101 struct device_node *node = dev->of_node;
102 int gpio, flags, ret = 0;
103 enum of_gpio_flags of_flags;
104 char gpio_names[32];
106 sprintf(gpio_names, "%s-gpios", name);
108 printk("@ gpio_names = %s\n", gpio_names);
109 if (of_find_property(node, gpio_names, NULL)) {
110 gpio = of_get_named_gpio_flags(node, gpio_names, index, &of_flags);
111 printk ("@ gpio = %d | ENOENT = %d | EPROBE_DEFER = %d \n", gpio, ENOENT, EPROBE_DEFER);
112 if (gpio == -ENOENT)
113 return 0;
114 if (gpio == -EPROBE_DEFER)
115 return gpio;
116 if (gpio < 0) {
117 dev_err(dev,
118 "failed to get '%s' from DT\n", gpio_names);
119 return gpio;
120 }
121
122 //active low translates to initially low
123 flags = (of_flags & OF_GPIO_ACTIVE_LOW) ? GPIOF_OUT_INIT_LOW :
124 GPIOF_OUT_INIT_HIGH;
125 ret = devm_gpio_request_one(dev, gpio, flags,
126 dev->driver->name);
127 if (ret) {
128 dev_err(dev,
129 "gpio_request_one('%s'=%d) failed with %d\n",
130 gpio_names, gpio, ret);
131 return ret;
132 }
133
134 *gpiop = gpio_to_desc(gpio);
135 fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' = GPIO%d\n",
136 __func__, gpio_names, gpio);
137 }
138 return ret;
139 }内核启动后输出的如下内容
[ 1.173480] fbtft_of_value: rotate = 90
[ 1.177309] fbtft_of_value: fps = 30
[ 1.181541] @ gpio_names = reset-gpios-gpios
[ 1.185883] @ gpio_names = dc-gpios-gpios
[ 1.189960] @ gpio_names = rd-gpios-gpios
[ 1.193969] @ gpio_names = wr-gpios-gpios
[ 1.197999] @ gpio_names = cs-gpios-gpios
[ 1.202004] @ gpio_names = latch-gpios-gpios
[ 1.206267] @ gpio_names = db-gpios-gpios
[ 1.210286] @ gpio_names = led-gpios-gpios
[ 1.214377] @ gpio_names = aux-gpios-gpios
[ 1.218478] @ gpio_names = db-gpios-gpios
[ 1.222481] @ gpio_names = led-gpios-gpios
[ 1.226570] @ gpio_names = aux-gpios-gpios
[ 1.230668] @ gpio_names = db-gpios-gpios
[ 1.234671] @ gpio_names = led-gpios-gpios
[ 1.238770] @ gpio_names = aux-gpios-gpios
[ 1.242859] @ gpio_names = db-gpios-gpios
[ 1.246861] @ gpio_names = led-gpios-gpios
[ 1.250961] @ gpio_names = aux-gpios-gpios
[ 1.255049] @ gpio_names = db-gpios-gpios
[ 1.259062] @ gpio_names = led-gpios-gpios
[ 1.263151] @ gpio_names = aux-gpios-gpios
[ 1.267239] @ gpio_names = db-gpios-gpios
[ 1.271251] @ gpio_names = led-gpios-gpios
[ 1.275340] @ gpio_names = aux-gpios-gpios
[ 1.279440] @ gpio_names = db-gpios-gpios
[ 1.283443] @ gpio_names = led-gpios-gpios
[ 1.287531] @ gpio_names = aux-gpios-gpios
[ 1.291630] @ gpio_names = db-gpios-gpios
[ 1.295632] @ gpio_names = led-gpios-gpios
[ 1.299731] @ gpio_names = aux-gpios-gpios
[ 1.303821] @ gpio_names = db-gpios-gpios
[ 1.307823] @ gpio_names = led-gpios-gpios
[ 1.311921] @ gpio_names = aux-gpios-gpios
[ 1.316010] @ gpio_names = db-gpios-gpios
[ 1.320022] @ gpio_names = led-gpios-gpios
[ 1.324111] @ gpio_names = aux-gpios-gpios
[ 1.328210] @ gpio_names = db-gpios-gpios
[ 1.332213] @ gpio_names = led-gpios-gpios
[ 1.336302] @ gpio_names = aux-gpios-gpios
[ 1.340400] @ gpio_names = db-gpios-gpios
[ 1.344403] @ gpio_names = led-gpios-gpios
[ 1.348502] @ gpio_names = aux-gpios-gpios
[ 1.352591] @ gpio_names = db-gpios-gpios
[ 1.356593] @ gpio_names = led-gpios-gpios
[ 1.360693] @ gpio_names = aux-gpios-gpios
[ 1.364781] @ gpio_names = db-gpios-gpios
[ 1.368794] @ gpio_names = led-gpios-gpios
[ 1.372884] @ gpio_names = aux-gpios-gpios
[ 1.376973] @ gpio_names = db-gpios-gpios
[ 1.380985] @ gpio_names = led-gpios-gpios
[ 1.385065] @ gpio_names = aux-gpios-gpios
[ 1.389165] @ gpio_names = db-gpios-gpios
[ 1.393167] @ gpio_names = led-gpios-gpios
[ 1.397255] @ gpio_names = aux-gpios-gpios
[ 1.401356] @ pdata->display.buswidth = 8
[ 1.405358] @ par->gpio.dc = 0
[ 1.408425] fb_ili9341 spi0.0: Missing info about 'dc' gpio. Aborting. @xkt
[ 1.415483] fb_ili9341: probe of spi0.0 failed with error -22我是输出设备树中IO口的名称,发现reset和dc引脚的名称为:reset-gpios-gpios dc-gpios-gpios。跟设备树上的节点名称不一样,所以真如楼上大佬说的,是引脚没有申请成功!所以只需要把驱动和设备树的引脚名称修改为一致就好了。有多种修改方法。
大佬不敢当
我也是个小菜鸡
啥问题 ? 可以分享上来下,让大家学习下。
心情复杂 wrote:
大佬不敢当
我也是个小菜鸡
问题描述已经发在楼上了哈哈
最近编辑记录 无痕 (2021-04-28 23:36:22)
、、大佬们 如果配置spi屏 只有黑屏怎么办呀 spi总线需要上拉吗 还有是需要关闭内核的什么配置吗
哇酷小二 wrote:
有背光吗?
有背光 是黑色的 屏幕大小已经初始化了
用那个代码报错为cat: write error: No space left on device
报错以后 然后就从黑屏变成花屏了
最近编辑记录 酷酷酷 (2021-05-03 18:25:36)
哇酷小二 wrote:
那就可以用了,fbv,fbset都可以测试,在buildroot里面有。
但是为什么没有串口的输出呢 需在内核关掉什么东西吗
哇酷小二 wrote:
需要输出什么?
就是控制台的输出呀
哇酷小二 wrote:
酷酷酷 wrote:
哇酷小二 wrote:
需要输出什么?
就是控制台的输出呀
这个问题问得很好,可是我不知道怎么回答。
太难了吧 他们说是默认的hdmi是开着的 但是我不知道是不是这样子的
哇酷小二 wrote:
酷酷酷 wrote:
哇酷小二 wrote:
需要输出什么?
就是控制台的输出呀
老哥你那有编译好的fbv的库吗 这个太难编译了
我之前用5.2内核驱动ST7789也出现这个错误,网上没有找到相关的解答就换了4.13的内核,mark一下,回去试试
[ 1.165851] fbtft_of_value: buswidth = 8 [ 1.169818] fbtft_of_value: debug = 0 [ 1.173478] fbtft_of_value: rotate = 270 [ 1.177395] fbtft_of_value: fps = 10 [ 1.181682] @ pdata->display.buswidth = 8 [ 1.185755] @ par->gpio.dc = 0 [ 1.188882] fb_ili9341 spi0.0: Missing info about 'dc' gpio. Aborting.fbtft_request_one_gpio加入打印函数后的代码,关键的打印函数在108行。
5 static int fbtft_request_one_gpio(struct fbtft_par *par, 76 const char *name, int index, 77 struct gpio_desc **gpiop) 78 { 79 /* 80 struct device *dev = par->info->device; 81 struct device_node *node = dev->of_node; 82 int ret = 0; 83 84 if (of_find_property(node, name, NULL)) { 85 *gpiop = devm_gpiod_get_index(dev, dev->driver->name, index, 86 GPIOD_OUT_HIGH); 87 if (IS_ERR(*gpiop)) { 88 ret = PTR_ERR(*gpiop); 89 dev_err(dev, 90 "Failed to request %s GPIO:%d\n", name, ret); 91 return ret; 92 } 93 fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' GPIO\n", 94 __func__, name); 95 } 96 97 return ret; 98 */ 99 100 struct device *dev = par->info->device; 101 struct device_node *node = dev->of_node; 102 int gpio, flags, ret = 0; 103 enum of_gpio_flags of_flags; 104 char gpio_names[32]; 106 sprintf(gpio_names, "%s-gpios", name); 108 printk("@ gpio_names = %s\n", gpio_names); 109 if (of_find_property(node, gpio_names, NULL)) { 110 gpio = of_get_named_gpio_flags(node, gpio_names, index, &of_flags); 111 printk ("@ gpio = %d | ENOENT = %d | EPROBE_DEFER = %d \n", gpio, ENOENT, EPROBE_DEFER); 112 if (gpio == -ENOENT) 113 return 0; 114 if (gpio == -EPROBE_DEFER) 115 return gpio; 116 if (gpio < 0) { 117 dev_err(dev, 118 "failed to get '%s' from DT\n", gpio_names); 119 return gpio; 120 } 121 122 //active low translates to initially low 123 flags = (of_flags & OF_GPIO_ACTIVE_LOW) ? GPIOF_OUT_INIT_LOW : 124 GPIOF_OUT_INIT_HIGH; 125 ret = devm_gpio_request_one(dev, gpio, flags, 126 dev->driver->name); 127 if (ret) { 128 dev_err(dev, 129 "gpio_request_one('%s'=%d) failed with %d\n", 130 gpio_names, gpio, ret); 131 return ret; 132 } 133 134 *gpiop = gpio_to_desc(gpio); 135 fbtft_par_dbg(DEBUG_REQUEST_GPIOS, par, "%s: '%s' = GPIO%d\n", 136 __func__, gpio_names, gpio); 137 } 138 return ret; 139 }内核启动后输出的如下内容
[ 1.165851] fbtft_of_value: buswidth = 8 [ 1.169818] fbtft_of_value: debug = 0 [ 1.173480] fbtft_of_value: rotate = 90 [ 1.177309] fbtft_of_value: fps = 30 [ 1.181541] @ gpio_names = reset-gpios-gpios [ 1.185883] @ gpio_names = dc-gpios-gpios [ 1.189960] @ gpio_names = rd-gpios-gpios [ 1.193969] @ gpio_names = wr-gpios-gpios [ 1.197999] @ gpio_names = cs-gpios-gpios [ 1.202004] @ gpio_names = latch-gpios-gpios [ 1.206267] @ gpio_names = db-gpios-gpios [ 1.210286] @ gpio_names = led-gpios-gpios [ 1.214377] @ gpio_names = aux-gpios-gpios [ 1.218478] @ gpio_names = db-gpios-gpios [ 1.222481] @ gpio_names = led-gpios-gpios [ 1.226570] @ gpio_names = aux-gpios-gpios [ 1.230668] @ gpio_names = db-gpios-gpios [ 1.234671] @ gpio_names = led-gpios-gpios [ 1.238770] @ gpio_names = aux-gpios-gpios [ 1.242859] @ gpio_names = db-gpios-gpios [ 1.246861] @ gpio_names = led-gpios-gpios [ 1.250961] @ gpio_names = aux-gpios-gpios [ 1.255049] @ gpio_names = db-gpios-gpios [ 1.259062] @ gpio_names = led-gpios-gpios [ 1.263151] @ gpio_names = aux-gpios-gpios [ 1.267239] @ gpio_names = db-gpios-gpios [ 1.271251] @ gpio_names = led-gpios-gpios [ 1.275340] @ gpio_names = aux-gpios-gpios [ 1.279440] @ gpio_names = db-gpios-gpios [ 1.283443] @ gpio_names = led-gpios-gpios [ 1.287531] @ gpio_names = aux-gpios-gpios [ 1.291630] @ gpio_names = db-gpios-gpios [ 1.295632] @ gpio_names = led-gpios-gpios [ 1.299731] @ gpio_names = aux-gpios-gpios [ 1.303821] @ gpio_names = db-gpios-gpios [ 1.307823] @ gpio_names = led-gpios-gpios [ 1.311921] @ gpio_names = aux-gpios-gpios [ 1.316010] @ gpio_names = db-gpios-gpios [ 1.320022] @ gpio_names = led-gpios-gpios [ 1.324111] @ gpio_names = aux-gpios-gpios [ 1.328210] @ gpio_names = db-gpios-gpios [ 1.332213] @ gpio_names = led-gpios-gpios [ 1.336302] @ gpio_names = aux-gpios-gpios [ 1.340400] @ gpio_names = db-gpios-gpios [ 1.344403] @ gpio_names = led-gpios-gpios [ 1.348502] @ gpio_names = aux-gpios-gpios [ 1.352591] @ gpio_names = db-gpios-gpios [ 1.356593] @ gpio_names = led-gpios-gpios [ 1.360693] @ gpio_names = aux-gpios-gpios [ 1.364781] @ gpio_names = db-gpios-gpios [ 1.368794] @ gpio_names = led-gpios-gpios [ 1.372884] @ gpio_names = aux-gpios-gpios [ 1.376973] @ gpio_names = db-gpios-gpios [ 1.380985] @ gpio_names = led-gpios-gpios [ 1.385065] @ gpio_names = aux-gpios-gpios [ 1.389165] @ gpio_names = db-gpios-gpios [ 1.393167] @ gpio_names = led-gpios-gpios [ 1.397255] @ gpio_names = aux-gpios-gpios [ 1.401356] @ pdata->display.buswidth = 8 [ 1.405358] @ par->gpio.dc = 0 [ 1.408425] fb_ili9341 spi0.0: Missing info about 'dc' gpio. Aborting. @xkt [ 1.415483] fb_ili9341: probe of spi0.0 failed with error -22我是输出设备树中IO口的名称,发现reset和dc引脚的名称为:reset-gpios-gpios dc-gpios-gpios。跟设备树上的节点名称不一样,所以真如楼上大佬说的,是引脚没有申请成功!所以只需要把驱动和设备树的引脚名称修改为一致就好了。有多种修改方法。
大佬们,某宝上买了一款ili9341的屏幕240x320没有CS引脚,shell里面可以显示fb0但是屏幕是一片白色的?测试也没有反应,上电也没有打印信息,该怎么办?
请问这样是初始化成功了吗
我已经完成了每一步 为什么显示器不显示?
https://whycan.com/t_6413.html
U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Jul 31 2022 - 11:52:11 +0700) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SF: unrecognized JEDEC id bytes: 00, c2, 12
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
Net: No ethernet found.
No controllers found
reading zImage
4196800 bytes read in 232 ms (17.3 MiB/s)
12397 bytes read in 30 ms (403.3 KiB/s)
Loading Device Tree to 42df9000, end 42dff06c ... OK
[ 0.000000] Linux version 5.2.0-licheepi-zero (tevada@T420s) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #6 SMP Sun Jul 31 21:06:16 +07 2022
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 mtdparts=spi32766.0:1M(uboot),64k(dtb),4M(kernel),-(rootfs) rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 55044K/65536K available (6144K kernel code, 301K rwdata, 1684K rodata, 1024K init, 254K bss, 10492K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] random: get_random_bytes called from start_kernel+0x300/0x48c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000210] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000451] Console: colour dummy device 80x30
[ 0.000507] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000523] pid_max: default: 32768 minimum: 301
[ 0.000686] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000703] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001507] CPU: Testing write buffer coherency: ok
[ 0.002022] /cpus/cpu@0 missing clock-frequency property
[ 0.002048] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002815] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.003022] rcu: Hierarchical SRCU implementation.
[ 0.003567] smp: Bringing up secondary CPUs ...
[ 0.003586] smp: Brought up 1 node, 1 CPU
[ 0.003597] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003604] CPU: All CPU(s) started in SVC mode.
[ 0.004683] devtmpfs: initialized
[ 0.008173] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.008494] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008526] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.008770] pinctrl core: initialized pinctrl subsystem
[ 0.009804] NET: Registered protocol family 16
[ 0.010423] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.011687] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.011706] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.035081] SCSI subsystem initialized
[ 0.035244] usbcore: registered new interface driver usbfs
[ 0.035298] usbcore: registered new interface driver hub
[ 0.035418] usbcore: registered new device driver usb
[ 0.035651] mc: Linux media interface: v0.10
[ 0.035692] videodev: Linux video capture interface: v2.00
[ 0.035881] Advanced Linux Sound Architecture Driver Initialized.
[ 0.037188] clocksource: Switched to clocksource arch_sys_counter
[ 0.049291] NET: Registered protocol family 2
[ 0.050120] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.050160] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050185] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.050209] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.050354] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.050406] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.050700] NET: Registered protocol family 1
[ 0.052563] Initialise system trusted keyrings
[ 0.052935] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.090419] Key type asymmetric registered
[ 0.090441] Asymmetric key parser 'x509' registered
[ 0.090541] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.090553] io scheduler mq-deadline registered
[ 0.090560] io scheduler kyber registered
[ 0.091569] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.095297] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.164058] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.166389] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.167563] printk: console [ttyS0] disabled
[ 0.187847] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.702720] printk: console [ttyS0] enabled
[ 0.731672] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.742960] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.749580] ehci-platform: EHCI generic platform driver
[ 0.755100] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.760774] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.768731] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.797213] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.804423] hub 1-0:1.0: USB hub found
[ 0.808377] hub 1-0:1.0: 1 port detected
[ 0.812959] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.819279] ohci-platform: OHCI generic platform driver
[ 0.824817] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.831558] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.839555] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 0.912278] hub 2-0:1.0: USB hub found
[ 0.916125] hub 2-0:1.0: 1 port detected
[ 0.923471] usbcore: registered new interface driver usb-storage
[ 0.930748] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 0.940032] sun6i-rtc 1c20400.rtc: registered as rtc0
[ 0.945094] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.949816] i2c /dev entries driver
[ 0.954200] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 0.962886] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 0.999313] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.006575] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.041672] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[ 1.049759] usbcore: registered new interface driver usbhid
[ 1.055335] usbhid: USB HID core driver
[ 1.059383] fbtft_of_value: buswidth = 8
[ 1.063311] fbtft_of_value: debug = 0
[ 1.066969] fbtft_of_value: rotate = 90
[ 1.070841] fbtft_of_value: fps = 30
[ 1.084058] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.095947] mmc0: new high speed SD card at address e624
[ 1.103110] mmcblk0: mmc0:e624 SU02G 1.84 GiB
[ 1.108669] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[ 1.119178] mmcblk0: p1 p2
[ 1.125484] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[ 1.134200] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[ 1.141570] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[ 1.147100] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[ 1.152699] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[ 1.158256] mmc1: new high speed SDIO card at address 0001
[ 1.364748] random: fast init done
[ 1.400120] Console: switching to colour frame buffer device 40x30
[ 1.407009] graphics fb0: fb_ili9341 frame buffer, 320x240, 150 KiB video memory, 16 KiB buffer memory, fps=33, spi0.0 at 48 MHz
[ 1.420661] sun4i-codec 1c22c00.codec: ASoC: codec-analog@01c23000 not registered
[ 1.428304] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.435554] Initializing XFRM netlink socket
[ 1.439995] NET: Registered protocol family 17
[ 1.448384] Registering SWP/SWPB emulation handler
[ 1.464852] Loading compiled-in X.509 certificates
[ 1.480779] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.492236] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.498078] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.512457] random: crng init done
[ 1.519802] hub 3-0:1.0: USB hub found
[ 1.524108] hub 3-0:1.0: 1 port detected
[ 1.530974] debugfs: Directory '1c22c00.codec' with parent 'V3s Audio Codec' already present!
[ 1.539665] sun4i-codec 1c22c00.codec: ASoC: Failed to create component debugfs directory: -17
[ 1.549756] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.558304] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:05:48 UTC (348)
[ 1.566671] vcc5v0: disabling
[ 1.569728] ALSA device list:
[ 1.572699] #0: V3s Audio Codec
[ 1.615172] EXT4-fs (mmcblk0p2): recovery complete
[ 1.622057] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.630315] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.638526] devtmpfs: mounted
[ 1.642696] Freeing unused kernel memory: 1024K
[ 1.647461] Run /sbin/init as init process
[ 1.745748] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Saving random seed: OK
Starting network: OK
Welcome to Buildroot for the LicheePi Zero
licheepi-zero login: 最近编辑记录 tevada2010 (2022-07-31 22:23:13)
如何在 buildroot 中设置 fbv、fbset?
(V3s/V3x/S3/S3L/R11通吃)小智V3x开发板smallwitpi lite u-boot/linux/buildroot测试
https://whycan.com/t_7248.html
我在 buildroot 设置了 fbv,但图像仍然没有显示在屏幕上。
哇酷小二 wrote:
怎么执行的?
LCD 屏幕上不显示图像。
哇酷小二 wrote:
tevada2010 wrote:
哇酷小二 wrote:
怎么执行的?
LCD 屏幕上不显示图像。
你得执行才行,不执行怎么显示呢?
我以前做这个命令,现在可以显示了。
如果要显示引导映像,如下所示。 我该如何设置?
最近编辑记录 tevada2010 (2022-08-01 20:49:47)
@无痕
这个pio怎么配置啊,我原先设备树中没有这个配置
