很奇怪,设备树中配置了串口0、串口1、串口2,串口0和串口1都可以正常收发,串口2只能发送,无法接收到数据,接收引脚上有波形。
uart0_pins_a: uart-pins-pe {
pins = "PE0", "PE1";
function = "uart0";
uart1_pins_a: uart-pins-pd {
pins = "PD3", "PD4";
function = "uart1";
uart2_pins_a: uart2-pins-pd {
pins = "PD14", "PD13";
function = "uart2";
};经过排查,发现PD14脚的复用功能并未生效,PD14还是禁用的状态(0x7),将其设置为0x3之后就可以收到数据了。
# devmem 0x01c20870
0x77377677
devmem 0x01c20870 32 0x73377677设备树文件 suniv.dtsi
#include <dt-bindings/clock/suniv-ccu.h>
#include <dt-bindings/reset/suniv-ccu.h>
#address-cells = <1>;
#size-cells = <1>;
interrupt-parent = <&intc>;
clocks {
#size-cells = <1>;
ranges;
osc24M: clk-24M {
#clock-cells = <0>;
compatible = "fixed-clock";
clock-frequency = <24000000>;
osc32k: clk-32k {
#clock-cells = <0>;
clock-frequency = <32768>;
fake100M: clk-100M {
#clock-cells = <0>;
clock-frequency = <100000000>;
clock-output-names = "fake-100M";
cpus {
#address-cells = <0>;
#size-cells = <0>;
cpu {
device_type = "cpu";
de: display-engine {
compatible = "allwinner,suniv-display-engine";
allwinner,pipelines = <&fe0>;
status = "disabled";
soc {
compatible = "simple-bus";
#size-cells = <1>;
ranges;
sram-controller@1c00000 {
compatible = "allwinner,sun4i-a10-sram-controller";
reg = <0x01c00000 0x30>;
#size-cells = <1>;
ranges;
sram_d: sram@10000 {
compatible = "mmio-sram";
reg = <0x00010000 0x1000>;
#size-cells = <1>;
otg_sram: sram-section@0 {
reg = <0x0000 0x1000>;
spi0: spi@1c05000 {
"allwinner,sun8i-h3-spi";
reg = <0x01c05000 0x1000>;
interrupts = <10>;
clock-names = "ahb", "mod";
resets = <&ccu RST_BUS_SPI0>;
#size-cells = <0>;
spi1: spi@1c06000 {
reg = <0x01c06000 0x1000>;
interrupts = <11>;
clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
resets = <&ccu RST_BUS_SPI1>;
#size-cells = <0>;
tcon0: lcd-controller@1c0c000 {
compatible = "allwinner,suniv-tcon";
reg = <0x01c0c000 0x1000>;
interrupts = <29>;
clocks = <&ccu CLK_BUS_LCD>,
<&ccu CLK_TCON>,
<&osc24M>; /* Still unknown */
"tcon-ch0",
"tcon-ch1";
clock-output-names = "tcon-pixel-clock";
resets = <&ccu RST_BUS_LCD>;
reset-names = "lcd";
ports {
#size-cells = <0>;
tcon0_in: port@0 {
#size-cells = <0>;
reg = <0>;
tcon0_in_be0: endpoint@0 {
reg = <0>;
remote-endpoint = <&be0_out_tcon0>;
tcon0_out: port@1 {
#size-cells = <0>;
reg = <1>;
mmc0: mmc@1c0f000 {
compatible = "allwinner,suniv-mmc",
"allwinner,sun7i-a20-mmc";
reg = <0x01c0f000 0x1000>;
clocks = <&ccu CLK_BUS_MMC0>,
<&ccu CLK_MMC0>,
<&ccu CLK_MMC0_OUTPUT>,
<&ccu CLK_MMC0_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC0>;
reset-names = "ahb";
interrupts = <23>;
pinctrl-names = "default";
pinctrl-0 = <&mmc0_pins>;
#size-cells = <0>;
mmc1: mmc@1c10000 {
reg = <0x01c10000 0x1000>;
clocks = <&ccu CLK_BUS_MMC1>,
<&ccu CLK_MMC1>,
<&ccu CLK_MMC1_OUTPUT>,
<&ccu CLK_MMC1_SAMPLE>;
"mmc",
"output",
"sample";
resets = <&ccu RST_BUS_MMC1>;
interrupts = <24>;
#size-cells = <0>;
ccu: clock@1c20000 {
compatible = "allwinner,suniv-ccu";
reg = <0x01c20000 0x400>;
clock-names = "hosc", "losc";
#clock-cells = <1>;
#reset-cells = <1>;
compatible = "allwinner,suniv-ic";
reg = <0x01c20400 0x400>;
interrupt-controller;
#interrupt-cells = <1>;
pio: pinctrl@1c20800 {
compatible = "allwinner,suniv-pinctrl";
reg = <0x01c20800 0x400>;
gpio-controller;
#interrupt-cells = <3>;
#gpio-cells = <3>;
spi0_pins_a: spi0-pins-pc {
function = "spi0";
spi1_pins_a: spi1-pins-pc {
pins = "PE7", "PE8", "PE9", "PE10";
function = "spi1";
lcd_rgb666_pins: lcd-rgb666-pins {
pins = "PD0", "PD1", "PD2", "PD3", "PD4",
"PD5", "PD6", "PD7", "PD8", "PD9",
"PD10", "PD11", "PD12", "PD13", "PD14",
"PD15", "PD16", "PD17", "PD18", "PD19",
"PD20", "PD21";
function = "lcd";
function = "uart0";
function = "uart1";
function = "uart2";
mmc0_pins: mmc0-pins {
pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
function = "mmc0";
rtp_pins: rtp-pins {
pins = "PA0", "PA1", "PA2", "PA3";
function = "rtp";
i2c0_pins: i2c0 {
pins = "PE11", "PE12";
function = "i2c0";
i2c1_pins: i2c1 {
pins = "PD5", "PD6";
function = "i2c1";
spi_int: spi_int {
pins = "PE2";
function = "gpio_in";
timer@1c20c00 {
compatible = "allwinner,suniv-timer";
reg = <0x01c20c00 0x90>;
interrupts = <13>;
clocks = <&osc24M>;
wdt: watchdog@1c20ca0 {
reg = <0x01c20ca0 0x20>;
rtp: rtp@1c24800 {
compatible = "allwinner,sun4i-a10-ts";
reg = <0x01c24800 0x100>;
interrupts = <20>;
allwinner,ts-attached;
#thermal-sensor-cells = <0>;
pinctrl-0 = <&rtp_pins>;
uart0: serial@1c25000 {
reg = <0x01c25000 0x400>;
interrupts = <1>;
reg-shift = <2>;
reg-io-width = <4>;
uart1: serial@1c25400 {
reg = <0x01c25400 0x400>;
interrupts = <2>;
reg-shift = <2>;
reg-io-width = <4>;
uart2: serial@1c25800 {
reg = <0x01c25800 0x400>;
interrupts = <3>;
reg-shift = <2>;
reg-io-width = <4>;
i2c0: i2c@1C27000 {
compatible = "allwinner,sun6i-a31-i2c";
reg = <0x01C27000 0x400>;
interrupts = <7>;
clocks = <&ccu CLK_BUS_I2C0>;
resets = <&ccu RST_BUS_I2C0>;
pinctrl-0 = <&i2c0_pins>;
#size-cells = <0>;
i2c1: i2c@1C27400 {
reg = <0x01C27400 0x400>;
interrupts = <8>;
clocks = <&ccu CLK_BUS_I2C1>;
resets = <&ccu RST_BUS_I2C1>;
pinctrl-0 = <&i2c1_pins>;
#size-cells = <0>;
usb_otg: usb@1c13000 {
reg = <0x01c13000 0x0400>;
clocks = <&ccu CLK_BUS_OTG>;
resets = <&ccu RST_BUS_OTG>;
interrupts = <26>;
interrupt-names = "mc";
phys = <&usbphy 0>;
phy-names = "usb";
extcon = <&usbphy 0>;
usbphy: phy@1c13400 {
reg = <0x01c13400 0x10>;
reg-names = "phy_ctrl";
clocks = <&ccu CLK_USB_PHY0>;
clock-names = "usb0_phy";
resets = <&ccu RST_USB_PHY0>;
reset-names = "usb0_reset";
#phy-cells = <1>;
fe0: display-frontend@1e00000 {
compatible = "allwinner,suniv-display-frontend";
reg = <0x01e00000 0x20000>;
interrupts = <30>;
clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
<&ccu CLK_DRAM_DE_FE>;
clock-names = "ahb", "mod",
"ram";
resets = <&ccu RST_BUS_DE_FE>;
ports {
#size-cells = <0>;
fe0_out: port@1 {
#size-cells = <0>;
reg = <1>;
fe0_out_be0: endpoint@0 {
reg = <0>;
remote-endpoint = <&be0_in_fe0>;
be0: display-backend@1e60000 {
compatible = "allwinner,suniv-display-backend";
reg = <0x01e60000 0x10000>;
reg-names = "be";
interrupts = <31>;
clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
<&ccu CLK_DRAM_DE_BE>;
"ram";
resets = <&ccu RST_BUS_DE_BE>;
reset-names = "be";
assigned-clocks = <&ccu CLK_DE_BE>;
assigned-clock-rates = <300000000>;
ports {
#size-cells = <0>;
be0_in: port@0 {
#size-cells = <0>;
reg = <0>;
be0_in_fe0: endpoint@0 {
reg = <0>;
remote-endpoint = <&fe0_out_be0>;
be0_out: port@1 {
#size-cells = <0>;
reg = <1>;
be0_out_tcon0: endpoint@0 {
reg = <0>;
remote-endpoint = <&tcon0_in_be0>;
};设备树 sunxi-f1c100s-nano.dts
/dts-v1/;
#include "suniv-f1c100s.dtsi"
model = "Lichee Pi Nano";
compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s",
"allwinner,suniv";
aliases {
serial0 = &uart0;
spi0 = &spi0;
chosen {
reg_vcc3v3: vcc3v3 {
regulator-name = "vcc3v3";
&otg_sram {
&pio {
dm9051_default:dm9051_default{
dm9051_rst:dm9051_rst{
pins = "PE3";
dm9051_int:dm9051_int{
pins = "PE2";
/*&spi0 {
pinctrl-0 = <&spi0_pins_a>;
flash@0 {
#size-cells = <1>;
reg = <0>;
&spi0 {
flash: w25q128@0 {
#size-cells = <1>;
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "u-boot";
reg = <0x000000 0x70000>;
read-only;
partition@70000 {
label = "dtb";
reg = <0x70000 0x10000>;
read-only;
partition@80000 {
label = "kernel";
reg = <0x80000 0x400000>;
read-only;
partition@480000 {
label = "rootfs";
reg = <0x480000 0xB80000>;
&spi1 {
pinctrl-0 = <&spi1_pins_a>;
pinctrl-1 = <&spi1_pins_a>;
spi-max-frequency = <25000000>;
dm9051@0 {
compatible = "davicom,dm9051";
reg = <0>;
spi-max-frequency = <25000000>;/*<109000000>;*/
dm9051_rst = <&pio 4 3 GPIO_ACTIVE_HIGH>; /* PE3 */
&spi_int {
interrupt-parent = <&pio>;
interrupts = <39>; /* pe2 */
&i2c1 {
clock_frequency = <400000>;
rtc@51 {
compatible = "nxp,pcf8563";
reg = <0x51>;
&uart0 {
pinctrl-0 = <&uart0_pins_a>;
&uart1 {
pinctrl-0 = <&uart1_pins_a>;
&uart2 {
pinctrl-0 = <&uart2_pins_a>;
&usb_otg {
dr_mode = "otg";
&usbphy {
usb0_id_det-gpio = <&pio 3 10 GPIO_ACTIVE_HIGH>; /* PD10 */
};但是查了下设备树,唯一用到PD14的功能是rgb接口,但是并未启用。很奇怪为什么发送脚已经被正确设置了,接收脚却没有被正确设置复用。
LOG中有一句
[ 0.832283] 1c25400.serial: ttyS1 at MMIO 0x1c25400 (irq = 23, base_baud = 6250000) is a 16550A
[ 0.841925] suniv-pinctrl 1c20800.pinctrl: unsupported function uart2 on pin PD14[ 0.871149] 1c25800.serial: ttyS2 at MMIO 0x1c25800 (irq = 24, base_baud = 6250000) is a 16550A
[ 0.881947] SCSI Media Changer driver v0.25
回头查查pinctrl中是啥意思
pinctrl 是登记 soc 芯片上面所有引脚复用。
你先搜索一下哪个 pinctrl 文件参与了编译:
find . |grep pinctrl |grep \\.o$然后看下 D14 是不是没有注册复用UART功能, 只注册了GPIO。
查过了,
./drivers/pinctrl/sunxi/pinctrl-suniv.c 中 第 207行
SUNXI_PIN(SUNXI_PINCTRL_PIN(D, 14),
SUNXI_FUNCTION(0x0, "gpio_in"),
SUNXI_FUNCTION(0x1, "gpio_out"),
SUNXI_FUNCTION(0x2, "lcd"), /* D20 */
SUNXI_FUNCTION(0x3, "lvds1"), /* RX 这一行*/
SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 14)),应改为
SUNXI_FUNCTION(0x3, "uart2"), /* RX 这一行*/
SUNXI_FUNCTION_IRQ_BANK(0x6, 0, 14)),离线
那现在可以了吗?
没硬件可以测试,明天到公司测试一下,但看起来应该没啥问题
https://github.com/torvalds/linux/blob/master/drivers/pinctrl/sunxi/pinctrl-suniv-f1c100s.c
SUNXI_FUNCTION(0x3, "lvds1"), /* RX */果然是这个惊天bug
&spi1 {
dm9051@0 {
reg = <0>;
};厚脸求 "davicom,dm9051" 这个的驱动.
好大的bug
十分感谢 苦思冥想了好久 在这找到了答案
