楼主 # 2022-01-15 00:32:24
shaoxi2010
已发帖子: 399
F1C200 linux LVGL双缓冲支持
看到LVGL支持了DRM,按道理F1C200的驱动情况下也能支持双缓冲效果。
简单的测试了下,支持还是很可以的,看上去也就是CPU有点高。
对比了下CPU和top看到的存在较大的差异,可能计算方式不一样吧?
修改使用tslib的ts_uinput来校准输入,模拟为event1
修改使用libdrm的输出,输出双缓冲。
验证代码,应该要修改下Makefile的CFLAGS下的路径
https://github.com/shaoxi2010/lv_port_linux_frame_buffer
#1 2022-01-23 16:36:45
someluo
Re: F1C200 linux LVGL双缓冲支持
你好,我按照提示修改了Makefile,下载到F1C100S nano的TF卡手动执行,提示:
Welcome to Lichee Pi
Lichee login: root
Password:
ls
demosss goodix.ko littlevgl_demo
demoxx littlevgl_benchmark
./demosss
./demosss: line 1: syntax error: unexpected "("
Makefile修改的内容:
# Makefile
CC ?= /home/allenz3700/f1c100s/buildroot-2017.08/output/host/bin/arm-buildroot-linux-musleabi-gcc
LVGL_DIR_NAME ?= lvgl
LVGL_DIR ?= ${shell pwd}
CFLAGS ?= -O3 -g0 -I$(LVGL_DIR)/ -Wall -Wshadow -Wundef -Wmissing-prototypes -Wno-discarded-qualifiers -Wall -Wextra -Wno-unused-function -Wno-error=strict-prototypes -Wpointer-arith -fno-strict-aliasing -Wno-error=cpp -Wuninitialized -Wmaybe-uninitialized -Wno-unused-parameter -Wno-missing-field-initializers -Wtype-limits -Wsizeof-pointer-memaccess -Wno-format-nonliteral -Wno-cast-qual -Wunreachable-code -Wno-switch-default -Wreturn-type -Wmultichar -Wformat-security -Wno-ignored-qualifiers -Wno-error=pedantic -Wno-sign-compare -Wno-error=missing-prototypes -Wdouble-promotion -Wclobbered -Wdeprecated -Wempty-body -Wtype-limits -Wshift-negative-value -Wstack-usage=2048 -Wno-unused-value -Wno-unused-parameter -Wno-missing-field-initializers -Wuninitialized -Wmaybe-uninitialized -Wall -Wextra -Wno-unused-parameter -Wno-missing-field-initializers -Wtype-limits -Wsizeof-pointer-memaccess -Wno-format-nonliteral -Wpointer-arith -Wno-cast-qual -Wmissing-prototypes -Wunreachable-code -Wno-switch-default -Wreturn-type -Wmultichar -Wno-discarded-qualifiers -Wformat-security -Wno-ignored-qualifiers -Wno-sign-compare
CFLAGS += -I/home/allenz3700/f1c100s/buildroot-2017.08/output/host/arm-buildroot-linux-musleabi/sysroot/usr/include/drm
LDFLAGS ?= -lm -ldrm
BIN = demo
我是ST7701S 480x480的RGB屏+GT911触摸,有些迷茫,请教一下
楼主 #2 2022-01-23 20:24:03
shaoxi2010
已发帖子: 399
可能是编译没选对吧,看下二进制的架构信息吧
#3 2022-01-23 23:03:34
someluo
你好,总结下遇到了以下问题:
  1. CC ?= xxxxxx,可能我CC被赋值过,所以后面的arm工具链没有被用上,改成CC = arm-linux-xxx就好了。
  2. 然后我编译双缓存这个遇到了找不到drm文件的问题,我也尝试了apt install libdrm-dev,之后还是找不到,可能需要在kernel或rootfs里面cc出来?
  3. 我拉取lvgl的porting后,编译通过,并且还非得自己编译一套rootfs,终于可以运行了,之前不知道,也许必须要用相同的交叉工具链才能运行
#4 2022-01-27 01:43:59
someluo
还有个问题想请教,默认的lvgl配置的是16位色深,但是我的kernel好像总是32位RGBA的色深,显示出来就不对。我找了很多地方,改dts文件等,因为我的屏是86面板屏18位的。请问linux的framebuffer的色深 是如何配置成16bpp的呢?
楼主 #5 2022-01-27 11:06:46
shaoxi2010
已发帖子: 399
不同内核修改方法是不一样的,这个是4.19的修改方法, 将sun4i_frambuffer.c的32修改为16就行了。
我记得5.4应该是要修改panle属性还是什么来着,已经忘记了。
int sun4i_framebuffer_init(struct drm_device *drm)
	drm_mode_config_reset(drm);
	drm->mode_config.max_width = 8192;
	drm->mode_config.max_height = 8192;
	drm->mode_config.funcs = &sun4i_de_mode_config_funcs;
	drm->mode_config.helper_private = &sun4i_de_mode_config_helpers;
	return drm_fb_cma_fbdev_init(drm, 16, 0);
#6 2022-01-27 12:41:08
memory
已发帖子: 712
瞄了一下楼主的源码, 并没有发现启用 tslib,请问是怎么回事呢?
楼主 #7 2022-01-27 13:12:37
shaoxi2010
已发帖子: 399
因为用的是ts_uinput,会将原始坐标做一次tslib转换后再生成新的event设备为符合屏幕转换的点信息。
所以没有用tslib驱动,用的evdev驱动
#8 2022-01-27 13:21:28
memory
已发帖子: 712
https://github.com/libts/tslib/blob/master/tools/ts_uinput.c
是一个后台进程吗?
楼主 #9 2022-01-27 13:30:07
shaoxi2010
已发帖子: 399
恩,加个-d就是一个后台的daemon程序
#10 2022-01-27 14:57:26
拉轰的脚踏车
已发帖子: 288
https://www.kernel.org/doc/html/v4.12/input/uinput.html
uinput 是一个内核模块,可以模拟用户空间的输入设备。通过写入 /dev/uinput(或 /dev/input/uinput)设备,进程可以创建具有特定功能的虚拟输入设备。一旦创建了这个虚拟设备,进程就可以通过它发送事件,这些事件将被传递给用户空间和内核消费者。
这玩意真神奇!
楼主 #11 2022-01-27 16:16:49
shaoxi2010
已发帖子: 399
挺好用的,最开始是因为qt5的tslib驱动不支持旋转,然后就用了这个方案了。
#12 2022-02-22 23:03:35
小智跑腿
已发帖子: 78
https://stackoverflow.com/questions/9920561/how-to-enable-dev-input-uinput
CONFIG_INPUT_UINPUT: y/m
    Device Drivers --->
        Input Device Support --->
            Miscellaneous devices --->
                User level driver support
#13 2022-03-08 16:30:07
t123yh
楼主你好,你的代码可以跑起来。不过,同样的配置下,drm的fps明显不如fbdev,CPU占用率也会达到100%(fbdev占用率最高50%左右)。在lvgl论坛看到一个bug,不知道是否相关:https://forum.lvgl.io/t/drm-driver-is-slow/3479
最近编辑记录 t123yh (2022-03-08 16:30:29)
楼主 #14 2022-03-08 17:37:58
shaoxi2010
已发帖子: 399
lvgl的drm驱动实现我也不是很了解,看他们描述说的是VSYNC信号的同步等待引起的,
但是按理说应该不会引起CPU上升这么多,你可尝试改小usleep值看下呢降低任务延迟看看。
CPU的值你可以去top看看,lvgl的实际值确实要比top统计的高不少,不确定它的计算标准。
#15 2022-05-08 22:47:39
xfdr0805
已发帖子: 350
我在f1c200s上也试了,感觉比起framebuffer 帧率没有提高多少,在f1c100s上由于内存不够,第一次是可以执行的,再执行就申请不到内存了无法正常显示了
