V3S
CPU: 1008MHz
LCD: 800*480
With hardware floating point: 140 fps
With software floating point: 57 fps
v3s_tinygl_gears.7z
最近编辑记录 Ozelot (2021-11-02 19:38:38)
F1C100S
CPU: 576MHz
LCD: 800*480
22 fps
f1c_tinygl_gears.7z
最近编辑记录 Ozelot (2021-11-02 19:38:54)
V3S
LCD: 800*480
Sources: v3s_md2_soldier.7z
F1C100S
LCD: 800*480
Textured cube demo: cubetext.7z
Textured Cube的例子帧率有多少?
The frame rate depends on the size of the cube and varies from 35 to 11 fps. At the moment when the height of the cube is equal to half the height of the screen, we have 25 fps. Source code with frame rate output to the terminal here: TinyGl Textured Cube Demo
为啥V3S的cortex-a7帧率比我的cortex-a9都还要高,我也开了硬FPU
