系统正常启动,而且也正常登陆了
U-Boot 2018.01-05679-g013ca457fd-dirty (Mar 30 2022 - 12:14:24 -0400) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
reading zImage
4323432 bytes read in 226 ms (18.2 MiB/s)
14204 bytes read in 25 ms (554.7 KiB/s)
## Flattened Device Tree blob at 80c08000
Booting using the fdt blob at 0x80c08000
Loading Device Tree to 816f9000, end 816ff77b ... OK
[ 0.000000] Linux version 5.4.77 (book@100ask) (gcc version 7.5.0 (Buildroot 2020.02-gee85cab)) #10 Wed Mar 30 12:35:33 EDT 2022
[ 0.000000] OF: fdt: Machine model: Sipeed Lichee Nano
[ 0.000000] cma: Reserved 16 MiB at 0x83000000
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 37716K/65536K available (7168K kernel code, 248K rwdata, 1676K rodata, 1024K init, 227K bss, 11436K reserved, 16384K cma-reserved)
[ 0.000000] random: get_random_bytes called from start_kernel+0x254/0x444 with crng_init=0
[ 0.000047] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000132] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000819] Console: colour dummy device 80x30
[ 0.000913] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070250] pid_max: default: 32768 minimum: 301
[ 0.070759] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.070799] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.072655] CPU: Testing write buffer coherency: ok
[ 0.074567] Setting up static identity map for 0x80100000 - 0x80100058
[ 0.075770] devtmpfs: initialized
[ 0.085895] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.085954] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
[ 0.090017] pinctrl core: initialized pinctrl subsystem
[ 0.092657] NET: Registered protocol family 16
[ 0.095911] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.098011] cpuidle: using governor menu
[ 0.136755] SCSI subsystem initialized
[ 0.137115] usbcore: registered new interface driver usbfs
[ 0.137272] usbcore: registered new interface driver hub
[ 0.137454] usbcore: registered new device driver usb
[ 0.137912] mc: Linux media interface: v0.10
[ 0.138047] videodev: Linux video capture interface: v2.00
[ 0.138150] pps_core: LinuxPPS API ver. 1 registered
[ 0.138168] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.138226] PTP clock support registered
[ 0.139241] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[ 0.140355] Advanced Linux Sound Architecture Driver Initialized.
[ 0.142113] clocksource: Switched to clocksource timer
[ 0.171338] thermal_sys: Registered thermal governor 'step_wise'
[ 0.172096] NET: Registered protocol family 2
[ 0.173781] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[ 0.173860] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.173921] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.173969] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.174243] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.174306] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.174853] NET: Registered protocol family 1
[ 0.177169] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.178917] Initialise system trusted keyrings
[ 0.179478] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.200675] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.201261] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.293552] Key type asymmetric registered
[ 0.293591] Asymmetric key parser 'x509' registered
[ 0.293753] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.293783] io scheduler mq-deadline registered
[ 0.293802] io scheduler kyber registered
[ 0.296314] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.307893] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.308762] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 0.331851] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.338681] printk: console [ttyS0] disabled
[ 0.358998] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 27, base_baud = 6250000) is a 16550A
[ 0.791568] printk: console [ttyS0] enabled
[ 0.801135] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 0.821215] panel-simple panel: panel supply power not found, using dummy regulator
[ 0.830910] SCSI Media Changer driver v0.25
[ 0.836877] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.849891] spi-nor spi0.0: unrecognized JEDEC id bytes: ff ff ff ff ff ff
[ 0.857511] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.864159] ehci-platform: EHCI generic platform driver
[ 0.869783] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.876107] ohci-platform: OHCI generic platform driver
[ 0.881841] usbcore: registered new interface driver usb-storage
[ 0.889616] i2c /dev entries driver
[ 0.897805] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 0.936011] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 0.945514] usbcore: registered new interface driver usbhid
[ 0.951089] usbhid: USB HID core driver
[ 0.955371] sunxi-cedar 1c0e000.video-codec: sunxi cedar version 0.01alpha
[ 0.962697] sunxi-cedar 1c0e000.video-codec: cedar-ve the get irq is 20
[ 0.974575] debugfs: Directory '1c23c00.codec' with parent 'F1C100s Audio Codec' already present!
[ 0.988685] sun4i-codec 1c23c00.codec: Codec <-> 1c23c00.codec mapping ok
[ 1.005426] NET: Registered protocol family 17
[ 1.009981] Key type dns_resolver registered
[ 1.015387] Loading compiled-in X.509 certificates
[ 1.034939] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[ 1.046865] sun4i-drm soc:display-engine: bound 1e00000.display-frontend (ops 0xc083b040)
[ 1.055950] sun4i-drm soc:display-engine: bound 1e60000.display-backend (ops 0xc083a880)
[ 1.065598] sun4i-drm soc:display-engine: bound 1c0c000.lcd-controller (ops 0xc0839420)
[ 1.074248] sun4i-drm soc:display-engine: bound 1c0a000.tv-encoder (ops 0xc083a140)
[ 1.081931] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.088651] [drm] No driver support for vblank timestamp query.
[ 1.096832] [drm] Initialized sun4i-drm 1.0.0 20150629 for soc:display-engine on minor 0
[ 1.105887] [drm] kms: can't enable cloning when we probably wanted to.
[ 1.327596] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.329832] mmc0: new high speed SDHC card at address 59b4
[ 1.332482] mmcblk0: mmc0:59b4 USD 30.0 GiB
[ 1.356838] Console: switching to colour frame buffer device 100x30
[ 1.360071] mmcblk0: p1 p2
[ 1.414421] sun4i-drm soc:display-engine: fb0: sun4i-drmdrmfb frame buffer device
[ 1.423820] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.435963] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.441818] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.452528] hub 1-0:1.0: USB hub found
[ 1.456473] hub 1-0:1.0: 1 port detected
[ 1.463296] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 1.481004] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 1.487955] ALSA device list:
[ 1.490951] #0: F1C100s Audio Codec
[ 1.495294] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 1.504077] cfg80211: failed to load regulatory.db
[ 1.533386] random: fast init done
[ 1.614211] EXT4-fs (mmcblk0p2): recovery complete
[ 1.621159] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.629526] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.637227] devtmpfs: mounted
[ 1.647606] Freeing unused kernel memory: 1024K
[ 1.652380] Run /sbin/init as init process
[ 1.761309] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Starting logging: OK
Initializing random number generator... [ 2.104966] random: dd: uninitialized urandom read (512 bytes read)
done.
Starting network: OK
Welcome to Buildroot
buildroot login: root
Password:
#同时把设备树文件也贴出来
/dts-v1/;
#include "suniv-f1c100s.dtsi"
model = "Sipeed Lichee Nano";
compatible = "allwinner,suniv-f1c100s";
aliases {
serial0 = &uart0;
chosen {
#address-cells = <1>;
#size-cells = <1>;
ranges;
// simplefb_lcd: framebuffer-lcd0 {
// compatible = "allwinner,simple-framebuffer",
// "simple-framebuffer";
// allwinner,pipeline = "de_be0-lcd0";
// clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
// <&ccu CLK_DRAM_DE_BE>, <&ccu CLK_BUS_LCD>,
// <&ccu CLK_TCON>;
// status = "disabled";
panel: panel {
// compatible = "qiaodian,qd43003c0-40", "simple-panel";
compatible ="lg,lb070wv8","simple-panel";
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
panel_input: endpoint@0 {
reg = <0>;
reg_vcc3v3: vcc3v3 {
regulator-name = "vcc3v3";
&spi0 {
spi-nor@0 {
#size-cells = <1>;
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "u-boot";
reg = <0x000000 0x70000>;
read-only;
partition@1 {
label = "dtb";
reg = <0x70000 0x10000>;
read-only;
partition@2 {
label = "kernel";
reg = <0x80000 0x580000>;
read-only;
partition@3 {
label = "rom";
reg = <0x600000 0x700000>;
read-only;
partition@4 {
label = "overlay";
reg = <0xd00000 0x300000>;
spi-nand@0 {
#size-cells = <1>;
compatible = "spi-nand";
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "u-boot";
reg = <0x000000 0x80000>;
read-only;
partition@1 {
label = "dtb";
reg = <0x80000 0x20000>;
read-only;
partition@2 {
label = "kernel";
reg = <0x100000 0x700000>;
read-only;
partition@3 {
label = "rom";
reg = <0x800000 0x4000000>;
read-only;
partition@4 {
label = "overlay";
reg = <0x4800000 0x3000000>;
&uart0 {
pinctrl-names = "default";
pinctrl-0 = <&uart0_pe_pins>;
&uart1 {
pinctrl-0 = <&uart1_pa_pins>;
// status = "okay";
&mmc0 {
vmmc-supply= <®_vcc3v3>;
bus-width =<4>;
broken-cd;
// broken-cd;
&otg_sram {
&usb_otg {
dr_mode = "otg"; /* otg host peripheral */
&usbphy {
&cedar_ve {
&ion {
&de {
&fe0 {
&be0 {
&tve0 {
&tcon0 {
pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
tcon0_out_lcd: endpoint@0 {
reg = <0>;
&codec {
allwinner,audio-routing =
"Headphone", "HP",
"Headphone", "HPCOM",
"LINEIN", "Line In",
"FMINL", "Left FM In",
"FMINR", "Right FM In",
"MIC", "Mic";
&i2c0 {
pinctrl-0 = <&i2c0_pe_pins>;
rtp@48 {
compatible = "ti,tsc2007";
reg = <0x48>;
interrupt-parent = <&pio>;
interrupts = <4 12 IRQ_TYPE_EDGE_FALLING>;
gpios = <&pio 4 12 GPIO_ACTIVE_LOW>;
pendown-gpio = <&pio 4 12 GPIO_ACTIVE_LOW>;
ti,x-plate-ohms = <660>;
wakeup-source;
};按照NANO PI的操作方法,企鹅也显示出来了
但是怎么操作都没有办法让LCD再多显示点东西,所以就想求助大神们,有没有软件或者什么可以直接进行测试验证驱动是否OK?
因为我用以前的应用编译出来无法操作LCD,目前LCD还是一直停在企鹅界面,光标正常一直闪
最近编辑记录 s8824803 (2022-04-02 12:21:25)
哇酷小二 wrote:
要把日志显示到显示屏吗?
这样也可以确认驱动没有问题,如果可以显示的话,那基本上我就可以把精力放在应用程序上面了
这个应该是在make menuconfig图形界面中打开吧
s8824803 wrote:
哇酷小二 wrote:
要把日志显示到显示屏吗?
bootargs 修改 console=/dev/tty 或者 console=tty
荔枝派控制台信息直接输出到液晶屏而不是电脑串口
https://whycan.com/t_4201.html#p40155
打开fbconsole,console=tty就行了
到网上找一个/dev/fb0的纯色刷屏源码编译起来就可以测试了。
哇酷小二 wrote:
全志D1哪吒开发板 frambuffer 测试
https://bbs.aw-ol.com/topic/521/share/1
谢谢,我用这个上面的方式显示出来了,说明驱动是OK的,而且LCD也显示打印信息了
