a133使用nand flash启动,启动kernel报错NOT support panic nand,望大牛指导一下,多谢。
27 03:54:24 UTC 2021
[ 0.000000] Boot CPU: AArch64 Processor [410fd034]
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.105789] BOOTEVENT: 105.778415: ON
[ 0.357963] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
[ 0.361566] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
[ 0.605495] disp soc@03000000:disp1@1: unable to map de registers
[ 0.706686] [NAND]NOT support panic nand
[ 0.712729] [NAND]nand init start
[ 0.717139] [NE]rawnand not support chip 0: df df df df df df df df
[ 0.724209] [NE]no rawnand found!!!
[ 0.728258] [NE]rawnand_channel_init channel@0 chips init fail
[ 0.734863] [NE]nand_physic_init error -1
你这个有没有NAND哦,把日志打全嘛
有的,也只有nand flash,sd卡都没有插。
[101]BOOT0 commit : 7cc6792
[104]set pll start
[106]periph0 has been enabled
[109]set pll end
[111][pmu]: bus read error
[114]PMU: AXP803
[134]vaild para:1 select dram para0
[137]board init ok
[139]rtc[3] value = 0xb00f
[162]DRAM BOOT DRIVE INFO: V0.40
[165]the chip id is 0x1400
[168]the chip id is 0x1400
[170]the chip id is 0x1400
[173]the chip id is 0x1400
[176]the chip id is 0x1400
[178]chip id check OK
[181]DRAM_VCC set to 1500 mv
[184]DRAM CLK =672 MHZ
[186]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
[192]DRAM SIZE =1024 MBytes, para1 = 30fa, para2 = 4000000, dram_tpr13 = 7503
[200]dram_tpr11 = f0d0f0c,dram_tpr12 = 14141313
[209]DRAM simple test OK.
[211]dram size =1024
[214]chipid = 53001400
[216]nsi init ok 2020-4-7
[219]card no is 2
[221]sdcard 2 line count 8
[224][mmc]: mmc driver ver 2020-05-25 09:40-202007019516
[235][mmc]: Wrong media type 0x0
[238][mmc]: ***Try SD card 2***
[242][mmc]: mmc 2 cmd 8 timeout, err 100
[246][mmc]: mmc 2 cmd 8 err 100
[249][mmc]: mmc 2 send if cond failed
[253][mmc]: mmc 2 cmd 55 timeout, err 100
[257][mmc]: mmc 2 cmd 55 err 100
[261][mmc]: mmc 2 send app cmd failed
[264][mmc]: ***Try MMC card 2***
[290][mmc]: RMCA OK!
[292][mmc]: bias 4
[294][mmc]: mmc 2 bias 4
[298][mmc]: MMC 4.41
[300][mmc]: HSSDR52/SDR25 8 bit
[303][mmc]: 50000000 Hz
[305][mmc]: 14910 MB
[307][mmc]: ***SD/MMC 2 init OK!!!***
[363]Loading boot-pkg Succeed(index=0).
[367]Entry_name = u-boot
[374]Entry_name = monitor
[378]Entry_name = scp
[386]set arisc reset to de-assert state
[390]Entry_name = dtb
[393]tunning data addr:0x4a0003e8
[397]Jump to second Boot.
NOTICE: BL3-1: v1.0(debug):5c8d955
NOTICE: BL3-1: Built : 14:47:18, 2020-08-14
NOTICE: BL3-1 commit: 8
ERROR: Error initializing runtime service tspd_fast
NOTICE: BL3-1: Preparing for EL3 exit to normal world
NOTICE: BL3-1: Next image address = 0x4a000000
NOTICE: BL3-1: Next image spsr = 0x1d3
U-Boot 2018.05-g32d4b1a-dirty (Nov 05 2021 - 06:55:34 +0000) Allwinner Technology
[00.479]CPU: Allwinner Family
[00.482]Model: sun50iw10
I2C: ready
[00.606]DRAM: 1 GiB
[00.609]Relocation Offset is: 35f13000
[00.637]secure enable bit: 0
[00.642][ARISC ERROR] :get [allwinner,sunxi-hwspinlock] device node error
CACHE: Misaligned operation at range [7ffa72b8, 7ffa75d0]
[SCP] :sunxi-arisc driver begin startup 2
[SCP] :0x1
[SCP] :arisc version: []
[SCP] :arisc startup ready
[SCP] :arisc startup notify message feedback
[SCP] :send hard sync feedback message: 0x900200
[SCP] :sunxi-arisc driver v1.10 is starting
[00.677]PMU: AXP803
[00.680]PMU: AXP803
bias_name:pc_bias bias_vol:1800
[00.700]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=400Mhz
[00.707]drv_disp_init
request pwm success, pwm3:pwm3:0x300a000.
[LT8911EXB] : Lt8911exb_Resource_Init
[LT8911EXB] : vtotal = 1100, htotal = 2070, pixel_clk = 13662
[LT8911EXB] : get lt8911exb_power_io failed
[LT8911EXB] : Lt8911exb_Gpio_Init
[LT8911EXB] : Lt8911exb_Init
[00.760]drv_disp_init finish
[00.766]gic: sec monitor mode
[00.769]flash init start
[00.771]workmode = 0,storage type = 2
[00.774][mmc]: mmc driver ver uboot2018:2020-5-25 9:26:00-202007011433
[00.782][mmc]: get sdc_type fail and use default host:tm4.
[00.793][mmc]: SUNXI SDMMC Controller Version:0x50300
[00.817][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
[00.823]sunxi flash init ok
[00.827]Loading Environment from SUNXI_FLASH... OK
[00.846]Item0 (Map) magic is bad
[00.849]the secure storage item0 copy0 magic is bad
[00.863]Item0 (Map) magic is bad
[00.866]the secure storage item0 copy1 magic is bad
[00.870]Item0 (Map) magic is bad
[00.873]usb burn from boot
delay time 0
weak:otg_phy_config
[00.884]usb prepare ok
[01.103]usb sof ok
[01.105]usb probe ok
[01.107]usb setup ok
set address 0x3
set address 0x3 ok
[04.114]do_burn_from_boot usb : have no handshake
[04.118]boot_gui_init:start
[04.123]set disp.dev2_output_type fail. using defval=0
[LT8911EXB] : Lt8911exb_Set_Power_Enable
[LT8911EXB] : Lt8911exb_Reset
[04.339]boot_gui_init:finish
[04.354]soc ic_ver:0x0, qa_val:0x1, markid:0x53001400 dclk[0-9999]
[LT8911EXB] : Lt8911exb_Mipi_Convert_Edp_Init init start
[LT8911EXB] : Lt8911exb_Chipid_Check : chipid = 0x17-0x5-0xe0
[LT8911EXB] : Lt8911exb_Chipid_Check success
[LT8911EXB] : set pix mode 1920x1080
[LT8911EXB] : set bit mode 6 bit
[LT8911EXB] : set rate mode 2.7G
[LT8911EXB] : LT8911 tx pll locked
[LT8911EXB] : 0x2 small
[LT8911EXB] : H:0x0,M:0x1,L:0xa
[LT8911EXB] : DpcdValue = 0x0
[LT8911EXB] : Lt8911exb_Mipi_Convert_Edp_Init init success
3072054 bytes read in 725 ms (4 MiB/s)
compat:/soc/pwm3
[05.085]LCD open finish
[05.098][mmc]: no mmc-hs400-1_8v!
[05.101][mmc]: no mmc-hs200-1_8v!
[05.108]update dts
** Unrecognized filesystem type **
[05.118]load file(ULI/factory/snum.txt) error.
[05.132]load file(ULI/factory/mac.txt) error.
[05.145]load file(ULI/factory/wifi_mac.txt) error.
[05.159]load file(ULI/factory/bt_mac.txt) error.
[05.172]load file(ULI/factory/specialstr.txt) error.
[05.184]update part info
[05.211]update bootcmd
[05.721]Starting kernel ...
[05.723][mmc]: mmc exit start
[05.740][mmc]: mmc 2 exit ok
[ 0.000000] Linux version 4.9.170 (ubuntu@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #30 SMP PREEMPT Fri Nov 5 09:11:30 UTC 2021
[ 0.106593] BOOTEVENT: 106.585374: ON
[ 0.365442] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
[ 0.369046] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
[ 0.611538] disp soc@03000000:disp1@1: unable to map de registers
[ 黐 0.717036] [NAND]NOT support panic nand
[ 0.723031] [NAND]nand init start
[ 0.727327] [NE]rawnand not support chip 0: df df df df df df df df
[ 0.734589] [NE]no rawnand found!!!
[ 0.738628] [NE]rawnand_channel_init channel@0 chips init fail
[ 0.745209] [NE]nand_physic_init error -1
[ 0.751654] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
[ 0.758725] sunxi-wlan soc@03000000:wlan@0: get gpio power_en failed
[ 0.773094] sunxi-ehci 5200000.ehci1-controller: init_sunxi_hci is fail
[ 0.781861] sunxi-ohci 5200000.ohci1-controller: init_sunxi_hci is fail
[ 0.806986] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 0.813938] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 0.820537] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x19)
[ 0.833699] VE: get debugfs_mpp_root is NULL, please check mpp
[ 0.833699]
[ 0.841955] VE: sunxi ve debug register driver failed!
[ 0.841955]
[ 0.907507] sun50iw10p1-pinctrl pio: pin PC1 already requested by nand0; cannot claim for sdc2
[ 0.917301] sun50iw10p1-pinctrl pio: pin-65 (sdc2) status -22
[ 0.923816] sun50iw10p1-pinctrl pio: could not request pin 65 (PC1) from group PC1 on device pio
[ 0.933873] sunxi-mmc sdc2: Error applying setting, reverse things back
[ 0.980884] mmc:failed to get gpios
[ 1.037105] Audio: [soc_new_pcm] -> 2699
[ 1.041550] Audio: [soc_new_pcm] -> 2718
[ 1.046100] Audio: [soc_new_pcm] -> 2746
[ 1.053517] [audio] hp_detect_case: 0
[ 1.057807] [audio] noheadphonemic missing or it has headphonemic.
[ 1.094068] cpu cpu1: opp_list_debug_create_link: Failed to create link
[ 1.101598] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
[ 1.109192] cpu cpu2: opp_list_debug_create_link: Failed to create link
[ 1.116648] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
[ 1.124237] cpu cpu3: opp_list_debug_create_link: Failed to create link
[ 1.131700] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
[ 1.156680] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.163593] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.170117] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.185739] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.192641] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.199160] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.214758] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.221654] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.228228] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.243838] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.250738] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.257306] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.272898] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.279800] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.286368] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.300711] stk3x1x_i2c_write_data: i2c write fail, err=-70
[ 1.306947] stk3x1x_software_reset: software reset: write i2c error, ret=-5
[ 1.351865] Kernel init done
[ 2.085469] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
[ 2.091533] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
[ 2.097605] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
[ 2.103668] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RE !!
[ 11.462476] init: bool android::init::FirstStageMount::InitRequiredDevices(): partition(s) not found after polling timeout: boot, metadata, recovery, super, vbmeta, vbmeta_system, vbmeta_vendor
[ 11.482002] init: Failed to mount required partitions early ...
[ 11.513158] init: #00 pc 000a4048 /init (match+18784)
[ 11.518974] init: #01 pc 00000daa <anonymous:0015d000>
[ 11.526464] [NAND][NAND]shutdown end
[ 11.628067] reboot: Restarting system with command 'bootloader'离线
从日志上来看他就没有从nand启动,而是从emmc上启动的,你确定有nand?还是全志不支持这个nand?
而且init报错是没找到挂载吧,看上去也和NAND无关。
nandflash确定是有的,可以通过PhoenixSuit.exe下载img文件到nandflash,现在的日志也是上电从nandflash启动打印出来的。
uboot的nandflash配置是在sys_config.fex里面,kernel里面的nandflash配置是否有问题会导致这个问题?
仔细检查板子上,发现确认焊的是emmc,不是nand.不过现在kernel启动后报EXT4-fs (mmcblk0p11): VFS: Can't find ext4 filesystem错误
[05.719][mmc]: mmc exit start
[05.736][mmc]: mmc 2 exit ok
[ 0.000000] Linux version 4.9.170 (ubuntu@ubuntu) (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05) ) #36 SMP PREEMPT Tue Nov 9 08:16:30 UTC 2021
[ 0.105747] BOOTEVENT: 105.736332: ON
[ 0.358400] axp2101-regulator axp2101-regulator.0: Setting DCDC frequency for unsupported AXP variant
[ 0.362011] axp2101-regulator axp2101-regulator.0: Error setting dcdc frequency: -22
[ 0.591552] disp soc@03000000:disp1@1: unable to map de registers
[ 0.696631] [NAND][NE] Not found valid nand node on dts
[ 0.704358] sunxi-wlan soc@03000000:wlan@0: get gpio chip_en failed
[ 0.711479] sunxi-wlan soc@03000000:wlan@0: get gpio power_en failed
[ 0.725787] sunxi-ehci 5200000.ehci1-controller: init_sunxi_hci is fail
[ 0.734495] sunxi-ohci 5200000.ohci1-controller: init_sunxi_hci is fail
[ 0.760486] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 0.767438] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 0.774028] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x19)
[ 0.787169] VE: get debugfs_mpp_root is NULL, please check mpp
[ 0.787169]
[ 0.795447] VE: sunxi ve debug register driver failed!
[ 0.795447]
[ 0.863549] mmc:failed to get gpios
[ 0.940838] mmc:failed to get gpios
[ 0.988633] Audio: [soc_new_pcm] -> 2699
[ 0.993073] Audio: [soc_new_pcm] -> 2718
[ 0.997614] Audio: [soc_new_pcm] -> 2746
[ 1.005312] [audio] hp_detect_case: 0
[ 1.009456] [audio] noheadphonemic missing or it has headphonemic.
[ 1.045580] cpu cpu1: opp_list_debug_create_link: Failed to create link
[ 1.053119] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
[ 1.060709] cpu cpu2: opp_list_debug_create_link: Failed to create link
[ 1.068185] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
[ 1.075773] cpu cpu3: opp_list_debug_create_link: Failed to create link
[ 1.083226] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
[ 1.108159] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.115067] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.121634] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.137539] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.144438] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.150977] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.166914] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.173813] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.180345] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.196285] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.203183] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.209719] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.225645] twi_stop()524 - [i2c1] i2c state(0x0) isn't idle(0xf8)
[ 1.232545] sunxi_i2c_core_process()1751 - [i2c1] STOP failed!
[ 1.239077] sunxi_i2c_do_xfer()1950 - [i2c1] incomplete xfer (status: 0xff, dev addr: 0x48)
[ 1.253418] stk3x1x_i2c_write_data: i2c write fail, err=-70
[ 1.259651] stk3x1x_software_reset: software reset: write i2c error, ret=-5
[ 1.302942] Kernel init done
[ 1.344494] EXT4-fs (mmcblk0p11): VFS: Can't find ext4 filesystem
[ 1.372848] init: Top-level vbmeta is disabled, skip Hashtree setup for /system
[ 1.803259] selinux: avc: denied { set } for scontext=u:r:vendor_init:s0 tcontext=u:object_r:default_prop:s0 tclass=property_service permissive=0
[ 1.803259]
[ 1.819872] init: Do not have permissions to set 'ro.product.vendor.platform' to 'tablet' in property file '/vendor/build.prop': SELinux permission check failed
[ 1.836700] selinux: avc: denied { set } for scontext=u:r:vendor_init:s0 tcontext=u:object_r:dalvik_prop:s0 tclass=property_service permissive=0
[ 1.836700]
[ 1.980736] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RE !!
[ 1.986864] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RE !!
[ 1.992956] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RE !!
[ 1.999081] sunxi-mmc sdc1: smc 2 p1 err, cmd 5, RE !!最近编辑记录 kouten (2021-11-09 19:34:50)
emmc识别出来了吗 是不是emmc没焊好
看起来就像启动成功了一样,安卓这块不熟,是不是分区卷标这些不对
傻掉了,都uboot了肯定是emmc里读出来的哈
@kouten
从日志信息看, axp2101 和 axp803 互为马甲吗?
