楼主 #1 2017-10-07 21:53:38
落雁
已发帖子: 62
V3S荔枝派zero uboot 和 linux 使用 ethernet 步骤总结
参考网址:
https://www.kancloud.cn/lichee/lpi0/418672
https://www.kancloud.cn/lichee/lpi0/418673
https://www.kancloud.cn/lichee/lpi0/327886
https://www.kancloud.cn/lichee/lpi0/331844
  1. sudo apt-get install gcc-arm-linux-gnueabihf
  2. 下载编译Uboot
git clone https://github.com/Lichee-Pi/u-boot.git -b v3s-spi-experimental
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- LicheePi_Zero_800x480LCD_defconfig
make ARCH=arm menuconfig
time make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j4
  1. 下载编译Kernel
git clone https://github.com/Lichee-Pi/linux.git -b zero-4.13.y
cd linux
make ARCH=arm licheepi_zero_defconfig
make ARCH=arm menuconfig #add bluethooth, etc.
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j16
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j16 INSTALL_MOD_PATH=out modules
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- -j16 INSTALL_MOD_PATH=out modules_install
最近编辑记录 落雁 (2017-10-07 22:33:45)
楼主 #2 2017-10-07 22:49:24
落雁
已发帖子: 62
Re: V3S荔枝派zero uboot 和 linux 使用 ethernet 步骤总结
最近编辑记录 落雁 (2017-10-07 22:49:53)
#3 2017-10-08 08:00:47
尧哥
牛逼:) smile smile
#4 2017-10-20 09:38:51
sindy
已发帖子: 146
我是进来学习的
