[29]HELLO! BOOT0 is starting!
[32]BOOT0 commit : 5224261
[34]set pll start
[40]periph0 has been enabled
[43]set pll end
[45][pmu]: bus read error
[47]board init ok
[49]enable_jtag
[50]ZQ value = 0x30
[52]get_pmu_exist() = -1
[55]DRAM BOOT DRIVE INFO: V0.32
[58]DRAM CLK = 792 MHz
[60]DRAM Type = 3 (2:DDR2,3:DDR3)
[63]DRAMC read ODT off.
[66]DRAM ODT value: 0x42.
[68]ddr_efuse_type: 0xa
[70]mark_id: 0x60
[73]DRAM SIZE =128 M
[75]PLL_DDR_CTRL_REG:0xf8004100
[78]DRAM_CLK_REG:0xc0000000
[81][TIMING DEBUG] MR2= 0x18
[88]DRAM simple test OK.
[90]rtc standby flag is 0x0, super standby flag is 0x0
[95]dram size =128
[98]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
[103]block from 8 to 32
[231]Check is correct.
[233]dma 0x29c4c int is not used yet
[237]dma 0x29c4c int is free, you do not need to free it again
[242]Entry_name = u-boot
[250]Entry_name = optee
[254]Entry_name = dtb
[257]Jump to second Boot.
M/TC: OP-TEE version: 53fe17e2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #6 Fri Feb 18 08:54:51 UTC 2022 arm
[ 0.000000] Linux version 5.4.61 (bj26lkl@LinuxServer2) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #3 SMP PREEMPT Wed May 11 11:53:14 CST 2022
[ 0.000000] OF: fdt: Machine model: sun8iw20
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 3.341476] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 3.350713] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #3
[ 3.357325] Hardware name: Generic DT based system
[ 3.362693] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
[ 3.371349] [<c010a894>] (show_stack) from [<c063de30>] (dump_stack+0x7c/0x98)
[ 3.379428] [<c063de30>] (dump_stack) from [<c01197e8>] (panic+0x104/0x3dc)
[ 3.387209] [<c01197e8>] (panic) from [<c0a01294>] (mount_block_root+0x278/0x32c)
[ 3.395576] [<c0a01294>] (mount_block_root) from [<c0a01450>] (prepare_namespace+0x84/0x178)
[ 3.405004] [<c0a01450>] (prepare_namespace) from [<c065250c>] (kernel_init+0x8/0x10c)
[ 3.413850] [<c065250c>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 3.422309] Exception stack(0xc704dfb0 to 0xc704dff8)
[ 3.427949] dfa0: 00000000 00000000 00000000 00000000
[ 3.437091] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.446223] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 3.453622] CPU1: stopping
[ 3.456648] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #3
[ 3.463257] Hardware name: Generic DT based system
[ 3.468619] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
[ 3.477272] [<c010a894>] (show_stack) from [<c063de30>] (dump_stack+0x7c/0x98)
[ 3.485349] [<c063de30>] (dump_stack) from [<c010c690>] (handle_IPI+0xc0/0x168)
[ 3.493520] [<c010c690>] (handle_IPI) from [<c0321d18>] (gic_handle_irq+0x70/0x78)
[ 3.501987] [<c0321d18>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[ 3.510342] Exception stack(0xc7097f80 to 0xc7097fc8)
[ 3.515990] 7f80: 00009b54 c76c8534 00000000 c0114d00 00000002 c7096000 c0b03be8 c0b03c24
[ 3.525126] 7fa0: 4000406a 410fc075 00000000 00000000 c0b6e8b0 c7097fd0 c0107f90 c0107f94
[ 3.534265] 7fc0: 60000113 ffffffff
[ 3.538165] [<c01021cc>] (__irq_svc) from [<c0107f94>] (arch_cpu_idle+0x2c/0x38)
[ 3.546440] [<c0107f94>] (arch_cpu_idle) from [<c013e410>] (do_idle+0xb8/0x120)
[ 3.554607] [<c013e410>] (do_idle) from [<c013e714>] (cpu_startup_entry+0x18/0x1c)
[ 3.563071] [<c013e714>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
[ 3.570859] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
期待能得到大佬的回复
看上去是设备不存在的问题,改下env的log等级看看完整的打印吧
好嘞,感谢提议,我去试试
[34]set pll start
[43]set pll end
[47]board init ok
[49]enable_jtag
[50]ZQ value = 0x31
[70]mark_id: 0x60
[95]dram size =128
[236]dma 0x29c4c int is free, you do not need to free it again
[249]Entry_name = optee
[253]Entry_name = dtb
[256]Jump to second Boot.
[ 0.000000] Linux version 5.4.61 (bj26lkl@LinuxServer2) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #4 SMP PREEMPT Fri May 13 11:58:55 CST 2022
[ 0.000000] cma: Reserved 8 MiB at 0x47800000
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s30912 r8192 d22336 u61440
[ 0.000000] pcpu-alloc: s30912 r8192 d22336 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: ubi.mtd=sys earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=ubi0_5 rootfstype=ubifs,rw init=/init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:dsp0@ubi0_6:private@ubi0_7:UDISK@ubi0_8: cma=8M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-g2a24076(02/22/2022-02:02:08) disp_reserve=2457600,0x44909000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Memory: 99856K/131072K available (6144K kernel code, 398K rwdata, 2052K rodata, 1024K init, 156K bss, 23024K reserved, 8192K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
[ 0.000000] random: get_random_bytes called from start_kernel+0x24c/0x3cc with crng_init=0
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008009] Switching to timer-based delay loop, resolution 41ns
[ 0.014338] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.024217] Console: colour dummy device 80x30
[ 0.028693] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.039060] pid_max: default: 32768 minimum: 301
[ 0.044487] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.051814] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.062750] CPU: Testing write buffer coherency: ok
[ 0.068860] /cpus/cpu@0 missing clock-frequency property
[ 0.074234] /cpus/cpu@1 missing clock-frequency property
[ 0.079561] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.087008] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.093846] rcu: Hierarchical SRCU implementation.
[ 0.099870] smp: Bringing up secondary CPUs ...
[ 0.106619] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.106782] smp: Brought up 1 node, 2 CPUs
[ 0.116616] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.122814] CPU: All CPU(s) started in SVC mode.
[ 0.129798] devtmpfs: initialized
[ 0.300206] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.310030] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.319922] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.327249] pinctrl core: initialized pinctrl subsystem
[ 0.340086] NET: Registered protocol family 16
[ 0.347089] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.533617] rtc_ccu: sunxi ccu init OK
[ 0.551457] ccu: sunxi ccu init OK
[ 0.556670] r_ccu: sunxi ccu init OK
[ 0.773428] iommu: Default domain type: Translated
[ 0.779063] sunxi iommu: irq = 24
[ 0.792678] SCSI subsystem initialized
[ 0.798737] usbcore: registered new interface driver usbfs
[ 0.804818] usbcore: registered new interface driver hub
[ 0.810617] usbcore: registered new device driver usb
[ 0.833127] pwm module init!
[ 0.842222] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.851590] clocksource: Switched to clocksource arch_sys_counter
[ 0.928725] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
[ 1.022351] thermal_sys: Registered thermal governor 'step_wise'
[ 1.022357] thermal_sys: Registered thermal governor 'user_space'
[ 1.028383] thermal_sys: Registered thermal governor 'power_allocator'
[ 1.039668] NET: Registered protocol family 2
[ 1.054683] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.063181] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 1.070870] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 1.077954] TCP: Hash tables configured (established 1024 bind 1024)
[ 1.084775] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.091359] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.099113] NET: Registered protocol family 1
[ 1.108951] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
[ 1.120974] spi spi0: spi0 supply spi not found, using dummy regulator
[ 1.129761] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
[ 1.136153] sunxi_spi_resource_get()2189 - Failed to get sample mode
[ 1.142540] sunxi_spi_resource_get()2194 - Failed to get sample delay
[ 1.148981] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
[ 1.157393] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
[ 1.166799] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 44
[ 1.181963] Initialise system trusted keyrings
[ 1.186854] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 1.280895] ntfs: driver 2.1.32 [Flags: R/W].
[ 1.290695] NET: Registered protocol family 38
[ 1.295689] Key type asymmetric registered
[ 1.299801] Asymmetric key parser 'x509' registered
[ 1.305083] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 1.312522] io scheduler mq-deadline registered
[ 1.317049] io scheduler kyber registered
[ 1.321167] atomic64_test: passed
[ 1.335102] [DISP]disp_module_init
[ 1.340907] disp 5000000.disp: Adding to iommu group 0
[ 1.348941] [DISP] disp_init,line:2386:
[ 1.348947] smooth display screen:0 type:1 mode:4
[ 1.377190] display_fb_request,fb_id:0
[ 1.390114] disp_al_manager_apply ouput_type:1
[ 1.395894] [DISP] lcd_clk_config,line:735:
[ 1.395906] disp 0, clk: pll(364000000),clk(364000000),dclk(52000000) dsi_rate(364000000)
[ 1.395906] clk real:pll(360000000),clk(360000000),dclk(51428571) dsi_rate(0)
[ 1.401600] wait for new fb take effect
[ 1.416719] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
[ 1.463652] Freeing logo buffer memory: 2400K
[ 1.469826] [DISP]disp_module_init finish
[ 1.476667] sunxi_sid_init()551 - insmod ok
[ 1.487261] uart uart0: get regulator failed
[ 1.491621] uart uart0: uart0 supply uart not found, using dummy regulator
[ 1.500123] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 1.508015] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
[ 1.516002] printk: console [ttyS0] enabled
[ 1.524905] printk: bootconsole [earlycon0] disabled
[ 1.538538] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.550395] uart uart1: get regulator failed
[ 1.555264] uart uart1: uart1 supply uart not found, using dummy regulator
[ 1.564658] uart1: ttyS1 at MMIO 0x2500400 (irq = 35, base_baud = 1500000) is a SUNXI
[ 1.576644] uart uart2: get regulator failed
[ 1.581493] uart uart2: uart2 supply uart not found, using dummy regulator
[ 1.590879] uart2: ttyS2 at MMIO 0x2500800 (irq = 36, base_baud = 1500000) is a SUNXI
[ 1.602964] uart uart3: get regulator failed
[ 1.607779] uart uart3: uart3 supply uart not found, using dummy regulator
[ 1.617204] uart3: ttyS3 at MMIO 0x2500c00 (irq = 37, base_baud = 1500000) is a SUNXI
[ 1.629167] uart uart4: get regulator failed
[ 1.634035] uart uart4: uart4 supply uart not found, using dummy regulator
[ 1.643496] uart4: ttyS4 at MMIO 0x2501000 (irq = 38, base_baud = 1500000) is a SUNXI
[ 1.655529] uart uart5: get regulator failed
[ 1.660343] uart uart5: uart5 supply uart not found, using dummy regulator
[ 1.669858] uart5: ttyS5 at MMIO 0x2501400 (irq = 39, base_baud = 1500000) is a SUNXI
[ 1.682748] misc dump reg init
[ 1.697994] sunxi-spinand: AW SPINand MTD Layer Version: 2.0 20201228
[ 1.705316] sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.10 20200306
[ 1.713365] sunxi-spinand-phy: not detect any munufacture from id table
[ 1.720791] sunxi-spinand-phy: get spi-nand Model from fdt fail
[ 1.727469] sunxi-spinand-phy: get phy info from fdt fail
[ 1.733587] sunxi-spinand-phy: not detect munufacture from fdt
[ 1.740353] sunxi-spinand-phy: detect munufacture from id table: Winbond
[ 1.747893] sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
[ 1.754955] sunxi-spinand-phy: ========== arch info ==========
[ 1.761496] sunxi-spinand-phy: Model: W25N01GVZEIG
[ 1.768252] sunxi-spinand-phy: Munufacture: Winbond
[ 1.774521] sunxi-spinand-phy: DieCntPerChip: 1
[ 1.780184] sunxi-spinand-phy: BlkCntPerDie: 1024
[ 1.786157] sunxi-spinand-phy: PageCntPerBlk: 64
[ 1.791929] sunxi-spinand-phy: SectCntPerPage: 4
[ 1.797591] sunxi-spinand-phy: OobSizePerPage: 64
[ 1.803369] sunxi-spinand-phy: BadBlockFlag: 0x0
[ 1.809227] sunxi-spinand-phy: OperationOpt: 0x7
[ 1.815102] sunxi-spinand-phy: MaxEraseTimes: 65000
[ 1.821157] sunxi-spinand-phy: EccFlag: 0x0
[ 1.827026] sunxi-spinand-phy: EccType: 2
[ 1.832706] sunxi-spinand-phy: EccProtectedType: 3
[ 1.838369] sunxi-spinand-phy: ========================================
[ 1.845824] sunxi-spinand-phy:
[ 1.849343] sunxi-spinand-phy: ========== physical info ==========
[ 1.856298] sunxi-spinand-phy: TotalSize: 128 M
[ 1.861699] sunxi-spinand-phy: SectorSize: 512 B
[ 1.867072] sunxi-spinand-phy: PageSize: 2 K
[ 1.872267] sunxi-spinand-phy: BlockSize: 128 K
[ 1.877640] sunxi-spinand-phy: OOBSize: 64 B
[ 1.882924] sunxi-spinand-phy: ========================================
[ 1.890347] sunxi-spinand-phy:
[ 1.893877] sunxi-spinand-phy: ========== logical info ==========
[ 1.900717] sunxi-spinand-phy: TotalSize: 128 M
[ 1.906099] sunxi-spinand-phy: SectorSize: 512 B
[ 1.911469] sunxi-spinand-phy: PageSize: 4 K
[ 1.916663] sunxi-spinand-phy: BlockSize: 256 K
[ 1.922048] sunxi-spinand-phy: OOBSize: 128 B
[ 1.927419] sunxi-spinand-phy: ========================================
[ 1.934978] sunxi-spinand-phy: block lock register: 0x00
[ 1.941126] sunxi-spinand-phy: feature register: 0x19
[ 1.946931] sunxi-spinand-phy: sunxi physic nand init end
[ 1.957904] sunxipart: failed to parse sunxi_gpt!
[ 1.963239] Creating 4 MTD partitions on "sunxi_mtd_nand":
[ 1.969467] 0x000000000000-0x000000100000 : "boot0"
[ 1.980550] 0x000000100000-0x000000400000 : "uboot"
[ 1.989243] random: fast init done
[ 1.999464] 0x000000400000-0x000000500000 : "secure_storage"
[ 2.011302] 0x000000500000-0x000008000000 : "sys"
[ 2.301197] libphy: Fixed MDIO Bus: probed
[ 2.309375] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
[ 2.321169] sunxi gmac driver's version: 1.0.0
[ 2.327263] gmac-power0: NULL
[ 2.330595] gmac-power1: NULL
[ 2.333945] gmac-power2: NULL
[ 2.343425] Failed to alloc md5
[ 2.346964] eth0: Use random mac address
[ 2.352602] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.359937] sunxi-ehci: EHCI SUNXI driver
[ 2.365110] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.372148] sunxi-ohci: OHCI SUNXI driver
[ 2.378155] usbcore: registered new interface driver uas
[ 2.384675] usbcore: registered new interface driver usb-storage
[ 2.391924] usbcore: registered new interface driver ums-alauda
[ 2.398858] usbcore: registered new interface driver ums-cypress
[ 2.405893] usbcore: registered new interface driver ums-datafab
[ 2.412952] usbcore: registered new interface driver ums_eneub6250
[ 2.420163] usbcore: registered new interface driver ums-freecom
[ 2.427202] usbcore: registered new interface driver ums-isd200
[ 2.434128] usbcore: registered new interface driver ums-jumpshot
[ 2.441252] usbcore: registered new interface driver ums-karma
[ 2.448100] usbcore: registered new interface driver ums-onetouch
[ 2.455374] usbcore: registered new interface driver ums-realtek
[ 2.462424] usbcore: registered new interface driver ums-sddr09
[ 2.469362] usbcore: registered new interface driver ums-sddr55
[ 2.476319] usbcore: registered new interface driver ums-usbat
[ 2.486044] ts probe start
[ 2.488426] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input1
[ 2.501815] ts probe success
[ 2.502684] sunxi_gpadc_init,2137, success
[ 2.517578] sunxi-rtc 7090000.rtc: registered as rtc0
[ 2.523429] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T04:48:31 UTC (17311)
[ 2.532846] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 2.539128] i2c /dev entries driver
[ 2.543401] IR NEC protocol handler initialized
[ 2.548487] IR RC5(x/sz) protocol handler initialized
[ 2.555049] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
[ 2.567085] sunxi_ir_startup: get ir protocol failed
[ 2.567107] (NULL device *): deviceless supply not found, using dummy regulator
[ 2.581469] Registered IR keymap rc_map_sunxi
[ 2.587281] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 2.597125] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 2.609101] sunxi cedar version 1.1
[ 2.613702] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 2.620066] VE: sunxi_cedar_probe power-domain init!!!
[ 2.625862] VE: install start!!!
[ 2.625862]
[ 2.632612] VE: cedar-ve the get irq is 45
[ 2.632612]
[ 2.639924] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 2.639924]
[ 2.649247] VE: install end!!!
[ 2.649247]
[ 2.654343] VE: sunxi_cedar_probe
[ 2.662279] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 2.677970] usbcore: registered new interface driver usbhid
[ 2.684264] usbhid: USB HID core driver
[ 2.688569] exFAT: Version 1.3.0
[ 2.704482] NET: Registered protocol family 10
[ 2.717405] Segment Routing with IPv6
[ 2.721874] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.738495] NET: Registered protocol family 17
[ 2.743617] NET: Registered protocol family 15
[ 2.749505] Registering SWP/SWPB emulation handler
[ 2.757198] Loading compiled-in X.509 certificates
[ 2.768492] HDMI 2.0 driver init start!
[ 2.772929] boot_hdmi=false
[ 2.776177] ERROR: can not get hdmi_cts_compatibility
[ 2.781981] ERROR: pinctrl_get for HDMI2.0 DDC fail
[ 2.790077] HDMI2.0 module init end
[ 2.909529] sunxi-i2c sunxi-i2c1: sunxi-i2c1 supply twi not found, using dummy regulator
[ 2.923507] sunxi-i2c sunxi-i2c1: probe success
[ 2.938499] get ehci0-controller wakeup-source is fail.
[ 2.944800] sunxi ehci0-controller don't init wakeup source
[ 2.951089] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b82438, 0x:c8869000, irq_no:3b
[ 2.963146] [sunxi-ehci0]: Not init ehci0
[ 2.968571] get ohci0-controller wakeup-source is fail.
[ 2.974933] sunxi ohci0-controller don't init wakeup source
[ 2.981218] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b826c8
[ 2.990912] [sunxi-ohci0]: Not init ohci0
[ 2.996311] get ehci1-controller wakeup-source is fail.
[ 3.002609] sunxi ehci1-controller don't init wakeup source
[ 3.008896] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b82958, 0x:c8873000, irq_no:3d
[ 3.022417] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 3.037073] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 3.044541] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 3.055295] sunxi-ehci 4200000.ehci1-controller: irq 61, io mem 0x04200000
[ 3.091589] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 3.105366] hub 1-0:1.0: USB hub found
[ 3.109919] hub 1-0:1.0: 1 port detected
[ 3.118498] get ohci1-controller wakeup-source is fail.
[ 3.124912] sunxi ohci1-controller don't init wakeup source
[ 3.131173] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b82be8
[ 3.142298] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 3.155801] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 3.163230] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 3.173883] sunxi-ohci 4200400.ohci1-controller: irq 62, io mem 0x04200400
[ 3.261410] hub 2-0:1.0: USB hub found
[ 3.265944] hub 2-0:1.0: 1 port detected
[ 3.277230] ubi0: attaching mtd3
[ 3.699447] random: crng init done
[ 3.764456] ubi0: scanning is finished
[ 3.812627] ubi0: attached mtd3 (name "sys", size 123 MiB)
[ 3.818793] ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
[ 3.826597] ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
[ 3.834269] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 3.842106] ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
[ 3.848843] ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
[ 3.856974] ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
[ 3.866366] ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
[ 3.876741] ubi0: background thread "ubi_bgt0d" started, PID 985
[ 3.886121] get ctp_power is fail, -22
[ 3.890335] get ctp_power_ldo_vol is fail, -22
[ 3.897286] sunxi_ctp_startup: ctp_power_io is invalid.
[ 3.903650] get ctp_gesture_wakeup fail, no gesture wakeup
[ 3.909829] gt9xxnew_ts 1-0014: 1-0014 supply ctp not found, using dummy regulator
[ 4.081670] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.089829] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.097513] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.105653] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.113349] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.121481] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.129162] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.137295] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.145020] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.153156] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.160782] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[ 4.321570] <<-GTP-ERROR->> GTP i2c test failed time 1.
[ 4.351613] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.359744] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.367425] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.375573] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.383247] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.391385] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.399060] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.407196] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.414869] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.423008] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.430622] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[ 4.591571] <<-GTP-ERROR->> GTP i2c test failed time 2.
[ 4.621613] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.629752] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.637433] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.645564] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.653247] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.661376] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.669056] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.677187] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.684866] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.692998] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.700622] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[ 4.861569] <<-GTP-ERROR->> GTP i2c test failed time 3.
[ 4.891610] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.899755] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.907428] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.915570] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.923242] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.931379] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.939052] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.947189] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.954864] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 4.963000] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 4.970616] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[ 5.131572] <<-GTP-ERROR->> GTP i2c test failed time 4.
[ 5.161620] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 5.169751] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 5.177472] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 5.185603] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 5.193288] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 5.201418] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 5.209101] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 5.217234] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 5.224915] sunxi-i2c sunxi-i2c1: SLA+W has been transmitted; ACK not received
[ 5.233048] sunxi-i2c sunxi-i2c1: engine-mode: xfer failed(dev addr:0x14)
[ 5.240672] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
[ 5.401569] <<-GTP-ERROR->> GTP i2c test failed time 5.
[ 5.431567] I2C communication ERROR!
[ 5.431637] regulator-dummy: Underflow of regulator enable count
[ 5.443332] gt9xxnew_ts: probe of 1-0014 failed with error -1
[ 5.451266] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 5.465793] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 5.473943] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 5.483698] clk: Not disabling unused clocks
[ 5.488537] alloc_fd: slot 0 not NULL!
[ 5.493097] cfg80211: failed to load regulatory.db
[ 5.505175] VFS: Cannot open root device "ubi0_5" or unknown-block(0,0): error -19
[ 5.513769] Please append a correct "root=" boot option; here are the available partitions:
[ 5.523166] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 5.532442] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #4
[ 5.539078] Hardware name: Generic DT based system
[ 5.544471] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
[ 5.553164] [<c010a894>] (show_stack) from [<c063e170>] (dump_stack+0x7c/0x98)
[ 5.561272] [<c063e170>] (dump_stack) from [<c01197e8>] (panic+0x104/0x3dc)
[ 5.569087] [<c01197e8>] (panic) from [<c0a01294>] (mount_block_root+0x278/0x32c)
[ 5.577489] [<c0a01294>] (mount_block_root) from [<c0a01450>] (prepare_namespace+0x84/0x178)
[ 5.586965] [<c0a01450>] (prepare_namespace) from [<c065284c>] (kernel_init+0x8/0x10c)
[ 5.595851] [<c065284c>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 5.604342] Exception stack(0xc704dfb0 to 0xc704dff8)
[ 5.610008] dfa0: 00000000 00000000 00000000 00000000
[ 5.619187] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 5.628365] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 5.635791] CPU1: stopping
[ 5.638829] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #4
[ 5.645466] Hardware name: Generic DT based system
[ 5.650846] [<c010e2d8>] (unwind_backtrace) from [<c010a894>] (show_stack+0x10/0x14)
[ 5.659535] [<c010a894>] (show_stack) from [<c063e170>] (dump_stack+0x7c/0x98)
[ 5.667644] [<c063e170>] (dump_stack) from [<c010c690>] (handle_IPI+0xc0/0x168)
[ 5.675849] [<c010c690>] (handle_IPI) from [<c0321d18>] (gic_handle_irq+0x70/0x78)
[ 5.684349] [<c0321d18>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
[ 5.692744] Exception stack(0xc7097f80 to 0xc7097fc8)
[ 5.698413] 7f80: 0000acf0 c76c8534 00000000 c0114d00 00000002 c7096000 c0b03be8 c0b03c24
[ 5.707593] 7fa0: 4000406a 410fc075 00000000 00000000 c0b6e8b0 c7097fd0 c0107f90 c0107f94
[ 5.716766] 7fc0: 60000113 ffffffff
[ 5.720682] [<c01021cc>] (__irq_svc) from [<c0107f94>] (arch_cpu_idle+0x2c/0x38)
[ 5.728987] [<c0107f94>] (arch_cpu_idle) from [<c013e410>] (do_idle+0xb8/0x120)
[ 5.737194] [<c013e410>] (do_idle) from [<c013e714>] (cpu_startup_entry+0x18/0x1c)
[ 5.745691] [<c013e714>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
[ 5.753518] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---离线
哇酷小二 wrote:
对比没开Qt之前的日志,重点观察
好嘞,感谢感谢
有点怀疑你是不是没开什么选项,建议你先用带ramfs得系统启动,尝试手动挂载下看看缺少什么东西不。
OK,感谢感谢
好像是根文件系统的空间不够导致的
它支持QT?
为什么我的sdk编译的没有QT呢, 就算选上也不行, prebuilt的也不行. libgpu根本就编译不过去.
请问您是Tina SDK吗?
hxhlb wrote:
它支持QT?
请问您是Tina SDK吗?
我编的不是Tinade SDK,可以查看下qt编译的环境变量,可能路径会改动。
