├── 01_Common Document
│ ├── RK3588 Hardware Design Guide-V1.0.pdf
│ ├── RK3588 Methods for Processing Unused Pins_V1.0_20211228.xlsx
│ ├── RK3588 Power Consumption Test Report V1.0_20211230_CN .xlsx
│ ├── RK3588_Package_PinLength_V1.0_20211228_EN.xlsx
│ ├── RK3588_PinOut_V1.0_20211228.xlsx
│ ├── RKeMMCSupportList Ver1.63_20220112.pdf
│ ├── Rockchip RK3588 Datasheet V1.1-20220124.pdf
│ ├── Rockchip RK806 Datasheet V1.0 -20211020.pdf
│ ├── Rockchip_RK3588_EVB_User_Guide_V1.0_CN.pdf
│ ├── Rockchip_RK3588_EVB_User_Guide_V10_EN_0126.pdf
│ └── Rockchip RK860 Datasheet V1.2-20211011.pdf
├── 02_DDR Template
│ ├── 01_H1R6_V10_20211229
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R6_V10_20211229.DSN
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R6_V10_20211229.brd
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R6_V10_20211229.pcb
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R6_V10_20211229核心板设计重点说明.doc
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R6_V10_20211229阻抗叠层.xls
│ │ └── allegro.jrl
│ ├── 02_H1R0_V10_20211230
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230.DSN
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230.brd
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230.pcb
│ │ ├── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230核心板设计重点说明.doc
│ │ └── RK3588_Template_LP4XD200P232SD8_41R0X41R0_2133MHz_H1R0_V10_20211230阻抗叠层.xls
│ └── RK3588 DDR Template List.xlsx
├── 03_Product Line Branch_AIoT
│ ├── 01_Product Document
│ ├── 02_Key Device Specifications
│ │ ├── 315b_y31m_ddp_qdp_embedded_lpddr5.pdf
│ │ ├── AP6275P draft datasheet_V0.5_20200306.pdf
│ │ ├── ES8388 DS.pdf
│ │ ├── ESD73034D - Rev1.1.pdf
│ │ ├── IT6516BFN Datasheet v0.91.pdf
│ │ ├── LP4X_32Gb_A_200F_10x15_K4UBE3D4AA-MGCL_Rev1.1.pdf
│ │ ├── MP8759GD-Z.pdf
│ │ ├── Molex HDMI2.1 2086581061.pdf
│ │ ├── Molex TYPEC 2012670005.pdf
│ │ ├── PI6C557-03B.pdf
│ │ ├── PI6C557-05B.pdf
│ │ ├── RTL8111H(S)-CG_Datasheet_1.92.pdf
│ │ ├── RTL8211FS(I)(-VS)-CG_DataSheet_1.8.pdf
│ │ ├── SGM2019 REV.C.1_20160429.pdf
│ │ ├── SPI NOR_GD25LQ255E-Rev1.0.pdf
│ │ ├── SY6280 Rev0.3.pdf
│ │ ├── TFM201610ALC-TCA.pdf
│ │ └── TMS322512ALM.pdf
│ ├── 03_Reference Design
│ │ ├── 01_RK3588_AIoT_REF_SCH
│ │ │ ├── RK3588_AIOT_REF_SCH_V10_20211228-162.DSN
│ │ │ ├── RK3588_AIOT_REF_SCH_V10_20211228.DSN
│ │ │ └── RK3588_AIOT_REF_SCH_V10_20211228.pdf
│ │ └── 02_PCB_Library
│ │ ├── RK3588_RK3588S_RK806_RK860_pkg_allegro.zip
│ │ └── RK3588_RK3588S_RK806_RK860_pkg_pads.zip
│ └── RK3588_AIOT_Hardware Document Release Note and File List_V10_20211228_CN.xlsx
├── 04_Product Line Branch_NVR
│ │ ├── AN_SY6280.pdf
│ │ ├── AN_SY8113B.pdf
│ │ ├── ES8311 DS.pdf
│ │ ├── ETA3409-1uH.pdf
│ │ ├── FUSB302B.pdf
│ │ ├── IT6161_Datasheet_V0.88.pdf
│ │ ├── IT6516BFNCX Datasheet v0.91.pdf
│ │ ├── IT6563_FN_Datasheet_v0.92.pdf
│ │ ├── MP8759_r1.1.pdf
│ │ ├── PDS-16011 JMB575 Datasheet (Rev. 1.2).pdf
│ │ ├── PT5108-V3.01.pdf
│ │ ├── RTC IC HYM8563 Spec.pdf
│ │ ├── RTL8211F(D)(I)-CG_DataSheet_1.2.pdf
│ │ ├── SIT-SIT3232E.pdf
│ │ ├── SIT3485E-datasheet-V1.1.pdf
│ │ └── SY8089.pdf
│ ├── 04_Demo Reference Design
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228-162.DSN
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228.DSN
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228.pdf
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228_Modify_Notes_CN.pdf
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228_final_lint.brd
│ │ ├── RK_NVR_DEMO1_RK3588_LP4XD200P232SD8_V21_20211228_final_lint阻抗叠层.xls
│ │ ├── allegro.jrl
│ │ └── allegro.jrl,1
│ └── RK3588_NVR_Hardware Document Release Note and File List_V10_20211228_CN.xlsx
15 directories, 73 files链接: https://pan.baidu.com/s/1XReP0B0OttP62pBZKsXGRw
提取码:rv27
多谢,收藏了。前段时间正好预定了一个3588开发板
已下,感谢分享。
感谢楼主分享,已经下载,准备入手一个3588开发板;)
Do yo have SDK for RK3588?
软件SDK代理商这边有哈
Q969785651 wrote:
软件SDK代理商这边有哈
得有多大量才能有支持啊
范兴茂 wrote:
Q969785651 wrote:
软件SDK代理商这边有哈
得有多大量才能有支持啊
提到要量个人觉得把首先是产品市场定位、产品形态、产品品质,
只有达到这些产品才会有市场有量,有想法大家可以一起聊聊的
You should find a chip agent
为啥没东西了,目前3588原厂支持需要订单有量,基本只能用模组,没有原厂支持,国产的就是这点做的确实太差了
