楼主 # 2022-07-15 21:39:24
ncer
已发帖子: 39
v3s使用XR819 wifi芯片求助
板子上使用xr819,v3s 与 xr819的连接关系为:
PE23 - reset
PE24 - WIRQ
驱动使用 https://github.com/fifteenhex/xradio ,也成功编好了,到v3s insmod xr819.ko
然后在ifconfig -a 里并没有新增加一个网卡
目前有点束手无策,不知道从哪里下手
请大佬帮忙看看可能是什么地方有问题
kernel 版本是4.14
设备树为:
/dts-v1/;
#include "sun8i-v3s.dtsi"
	model = "Lichee Pi Zero";
	compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
	aliases {
		serial0 = &uart0;
		serial1 = &uart1;
		serial2 = &uart2;
		spi0 = 	  &spi0;
		ethernet1 = &xr819;
	chosen {
	pwrseq_wifi: pwrseq_wifi@0 {
		compatible = "mmc-pwrseq-simple";
		pinctrl-names = "default";
		pinctrl-0 = <&wifi_rst>;
		reset-gpios = <&pio 4 23 GPIO_ACTIVE_LOW>;
		post-power-on-delay-ms = <50>;
	leds {
		compatible = "gpio-leds";
		blue_led {
			label = "licheepi:blue:usr";
			gpios = <&pio 6 1 GPIO_ACTIVE_LOW>; /* PG1 */
		green_led {
			label = "licheepi:green:usr";
			gpios = <&pio 6 0 GPIO_ACTIVE_LOW>; /* PG0 */
			default-state = "on";
		red_led {
			label = "licheepi:red:usr";
			gpios = <&pio 6 2 GPIO_ACTIVE_LOW>; /* PG2 */
&ehci0 {
&mmc0 {
	pinctrl-0 = <&mmc0_pins_a>;
	broken-cd;
	bus-width = <4>;
	vmmc-supply = <&reg_vcc3v3>;
&mmc1 {
	pinctrl-0 = <&mmc1_pins>;
	vqmmc-supply = <&reg_vcc1v8>;
	mmc-pwrseq = <&pwrseq_wifi>;
	bus-width = <4>;
	max-frequency = <16000000>;
	non-removable;
	 * Explicitly define the sdio device, so that we can add an ethernet
	 * alias for it (which e.g. makes u-boot set a mac-address).
	xr819: sdio_wifi@1 {
		reg = <1>;
		compatible = "xradio,xr819";
		pinctrl-0 = <&wifi_wake>;
		interrupt-parent = <&pio>;
		interrupts = <4 24 IRQ_TYPE_EDGE_RISING>;
		interrupt-names = "host-wake";
		local-mac-address = [dc 44 6d c0 ff ee];
&i2c0 {
	ns2009: ns2009@48 {
		compatible = "nsiway,ns2009";
		reg = <0x48>;
&ohci0 {
&uart0 {
	pinctrl-0 = <&uart0_pins_a>;
&uart1 {
	pinctrl-0 = <&uart1_pins_a>;
&uart2 {
	pinctrl-0 = <&uart2_pins_a>;
&usb_otg {
	dr_mode = "otg";
&usbphy {
	usb0_id_det-gpio = <&pio 5 6 GPIO_ACTIVE_HIGH>;
&pio {
        spi0_cs_pins: spi0_cs_pins {
                pins = "PC2", "PB3","PE16","PE15";
                function = "gpio_out";
		wifi_wake: wifi_wake {
				pins = "PE24";
				function = "gpio_in";
		wifi_rst: wifi_rst {
				pins = "PE23";
&spi0 {
        status ="okay";
        pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
        cs-gpios = <&pio 2 2 GPIO_ACTIVE_HIGH>, <&pio 1 3 GPIO_ACTIVE_HIGH>,<&pio 4 16 GPIO_ACTIVE_HIGH>,<&pio 4 15 GPIO_ACTIVE_HIGH>;
        mx25l25635e:mx25l25635e@0 {
                compatible = "jedec,spi-nor";
                reg = <0x0>;
                #address-cells = <1>;
                #size-cells = <1>;
        spidev:	spidevxxx@1 {
                compatible = "rohm,dh2228fv";
                reg = <0x1>;
                spi-max-frequency = <5000000>;
		gowin: gowin@1{
                reg = <0x2>;
		fakegowin: gowin@2{
                reg = <0x3>;
&ccu {
	assigned-clocks = <&ccu 18>;
	assigned-clock-parents = <&ccu 9>;
	assigned-clock-rates = <60000000>;
#1 2022-07-15 21:46:52
已发帖子: 3,403
Re: v3s使用XR819 wifi芯片求助
可能需要固件, 看下日志.
楼主 #2 2022-07-15 21:58:33
ncer
已发帖子: 39
哇酷小二 wrote:
可能需要固件, 看下日志.
固件放到/lib/firmware 下面了,用的是这几个文件: https://github.com/armbian/firmware/tree/master/xr819
日志在这里,请晕哥帮忙看看
dmesg
[    0.000000] Linux version 4.14.14-licheepi-zero+ (ncer@ncer-CW65S) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #10 SMP Fri Jul 15 19:05:34 CST 2022
[    0.000000] On node 0 totalpages: 16384
[    0.000000] free_area_init_node: node 0, pgdat c0a46800, node_mem_map c3f7a000
[    0.000000]   Normal zone: 128 pages used for memmap
[    0.000000]   Normal zone: 16384 pages, LIFO batch:3
[    0.000000] percpu: Embedded 16 pages/cpu @c3f5d000 s33740 r8192 d23604 u65536
[    0.000000] pcpu-alloc: s33740 r8192 d23604 u65536 alloc=16*4096
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw  vt.global_cursor_default=0
[    0.000000] Memory: 55012K/65536K available (6144K kernel code, 285K rwdata, 1500K rodata, 1024K init, 263K bss, 10524K reserved, 0K cma-reserved, 0K highmem)
[    0.000000]       .data : 0xc0a00000 - 0xc0a47460   ( 286 kB)
[    0.000000]        .bss : 0xc0a4e754 - 0xc0a9036c   ( 264 kB)
[    0.000193] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000448] Console: colour dummy device 80x30
[    0.000485] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.000500] pid_max: default: 32768 minimum: 301
[    0.000635] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000651] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.001314] CPU: Testing write buffer coherency: ok
[    0.001701] /cpus/cpu@0 missing clock-frequency property
[    0.001725] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.002170] Setting up static identity map for 0x40100000 - 0x40100060
[    0.002347] Hierarchical SRCU implementation.
[    0.002857] smp: Bringing up secondary CPUs ...
[    0.002874] smp: Brought up 1 node, 1 CPU
[    0.002883] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.002889] CPU: All CPU(s) started in SVC mode.
[    0.003682] devtmpfs: initialized
[    0.007283] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.007576] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.007603] futex hash table entries: 256 (order: 2, 16384 bytes)
[    0.007784] pinctrl core: initialized pinctrl subsystem
[    0.008784] NET: Registered protocol family 16
[    0.009227] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.010400] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.010416] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.023246] SCSI subsystem initialized
[    0.023480] usbcore: registered new interface driver usbfs
[    0.023559] usbcore: registered new interface driver hub
[    0.023655] usbcore: registered new device driver usb
[    0.023890] pps_core: LinuxPPS API ver. 1 registered
[    0.023901] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.023922] PTP clock support registered
[    0.024110] Advanced Linux Sound Architecture Driver Initialized.
[    0.025756] clocksource: Switched to clocksource arch_sys_counter
[    0.034950] NET: Registered protocol family 2
[    0.035537] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.035575] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[    0.035600] TCP: Hash tables configured (established 1024 bind 1024)
[    0.035804] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    0.035851] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    0.036109] NET: Registered protocol family 1
[    0.036804] RPC: Registered named UNIX socket transport module.
[    0.036825] RPC: Registered udp transport module.
[    0.036830] RPC: Registered tcp transport module.
[    0.036836] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.038673] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.044382] NFS: Registering the id_resolver key type
[    0.044440] Key type id_resolver registered
[    0.044447] Key type id_legacy registered
[    0.048392] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.048415] io scheduler noop registered
[    0.048423] io scheduler deadline registered
[    0.048702] io scheduler cfq registered (default)
[    0.048714] io scheduler mq-deadline registered
[    0.048721] io scheduler kyber registered
[    0.049283] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.052633] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.114485] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.117599] console [ttyS0] disabled
[    0.137858] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 3750000) is a U6_16550A
[    0.722118] console [ttyS0] enabled
[    0.747181] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 37, base_baud = 3750000) is a U6_16550A
[    0.777790] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 38, base_baud = 3750000) is a U6_16550A
[    0.791535] m25p80 spi0.0: unrecognized JEDEC id bytes: ff, ff, ff
[    0.797969] m25p80: probe of spi0.0 failed with error -2
[    0.805386] libphy: Fixed MDIO Bus: probed
[    0.810219] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[    0.816185] dwmac-sun8i 1c30000.ethernet: No regulator found
[    0.821995] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[    0.928184] dwmac-sun8i 1c30000.ethernet: EMAC reset timeout
[    0.934011] dwmac-sun8i: probe of 1c30000.ethernet failed with error -12
[    0.941155] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.947830] ehci-platform: EHCI generic platform driver
[    0.953384] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.959135] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.967189] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[    0.995753] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    1.002981] hub 1-0:1.0: USB hub found
[    1.006981] hub 1-0:1.0: 1 port detected
[    1.011583] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.017984] ohci-platform: OHCI generic platform driver
[    1.023611] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    1.030436] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    1.038496] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[    1.110766] hub 2-0:1.0: USB hub found
[    1.114652] hub 2-0:1.0: 1 port detected
[    1.122382] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    1.132075] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[    1.141190] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[    1.148202] sun6i-rtc 1c20400.rtc: RTC enabled
[    1.152845] i2c /dev entries driver
[    1.157940] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input1
[    1.167022] IR NEC protocol handler initialized
[    1.171629] IR RC5(x/sz) protocol handler initialized
[    1.176837] IR RC6 protocol handler initialized
[    1.181434] IR JVC protocol handler initialized
[    1.186054] IR Sony protocol handler initialized
[    1.190736] IR SANYO protocol handler initialized
[    1.195503] IR Sharp protocol handler initialized
[    1.200285] IR MCE Keyboard/mouse protocol handler initialized
[    1.206209] IR XMP protocol handler initialized
[    1.211495] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    1.275794] sunxi-mmc 1c0f000.mmc: base:0xc4987000 irq:23
[    1.282352] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[    1.342759] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.354968] mmc0: new high speed SD card at address 1388
[    1.360977] mmcblk0: mmc0:1388 CS004 482 MiB
[    1.366944]  mmcblk0: p1 p2
[    1.415797] sunxi-mmc 1c10000.mmc: base:0xc498b000 irq:24
[    1.422233] usbcore: registered new interface driver usbhid
[    1.427978] usbhid: USB HID core driver
[    1.433495] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[    1.441664] sun4i-codec 1c22c00.codec: Failed to register our card
[    1.449372] NET: Registered protocol family 17
[    1.454018] Key type dns_resolver registered
[    1.458607] Registering SWP/SWPB emulation handler
[    1.472287] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.483906] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.489841] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    1.498979] hub 3-0:1.0: USB hub found
[    1.502906] hub 3-0:1.0: 1 port detected
[    1.508186] using random self ethernet address
[    1.512738] using random host ethernet address
[    1.518239] usb0: HOST MAC 5e:4d:a2:dc:75:bf
[    1.522677] usb0: MAC 8a:65:bb:48:f8:58
[    1.526715] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.534305] g_cdc gadget: g_cdc ready
[    1.540622] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[    1.549559] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 01:14:23 UTC (4463)
[    1.558213] vcc5v0: disabling
[    1.561235] ALSA device list:
[    1.564245]   #0: V3s Audio Codec
[    1.570602] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    1.580032] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    1.601151] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.609579] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.618453] devtmpfs: mounted
[    1.622656] Freeing unused kernel memory: 1024K
[    1.690545] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in b_idle (80, <SessEnd), retry #0, port1 00000100
[    1.754568] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[    1.995954] usb 1-1: new high-speed USB device number 2 using ehci-platform
[    2.064274] usbcore: registered new interface driver ath9k_htc
[    7.195764] usb 1-1: device descriptor read/64, error -110
[    7.538402] usb 1-1: ath9k_htc: Firmware ath9k_htc/htc_9271-1.4.0.fw requested
[    7.547848] usb 1-1: Direct firmware load for ath9k_htc/htc_9271-1.4.0.fw failed with error -2
[    7.556762] usb 1-1: ath9k_htc: Firmware htc_9271.fw requested
[    7.848887] usb 1-1: ath9k_htc: Transferred FW: htc_9271.fw, size: 50980
[    8.088394] ath9k_htc 1-1:1.0: ath9k_htc: HTC initialized with 33 credits
[   10.389013] ath9k_htc 1-1:1.0: ath9k_htc: FW Version: 1.3
[   10.394646] ath9k_htc 1-1:1.0: FW RMW support: Off
[   10.399565] ath: EEPROM regdomain: 0x60
[   10.399570] ath: EEPROM indicates we should expect a direct regpair map
[   10.399578] ath: Country alpha2 being used: 00
[   10.399581] ath: Regpair used: 0x60
[   10.405632] ieee80211 phy0: Atheros AR9271 Rev:1
[   14.328590] wlan0: authenticate with 3c:06:a7:89:f5:bc
[   14.625479] wlan0: send auth to 3c:06:a7:89:f5:bc (try 1/3)
[   14.724394] wlan0: authenticated
[   14.736192] wlan0: associate with 3c:06:a7:89:f5:bc (try 1/3)
[   14.786298] wlan0: RX AssocResp from 3c:06:a7:89:f5:bc (capab=0x1411 status=0 aid=2)
[   14.801663] wlan0: associated
[   14.923340] wlan0: Limiting TX power to 20 (20 - 0) dBm as advertised by 3c:06:a7:89:f5:bc
[   34.609873] xradio_wlan: loading out-of-tree module taints kernel.
[  121.107540] random: crng init done
#3 2022-07-15 22:04:23
已发帖子: 3,403
首先确认硬件有没有问题?
如果硬件没问题, 看下 dts 里面 该 sdc 有没有启用?
楼主 #4 2022-07-15 22:45:30
ncer
已发帖子: 39
哇酷小二 wrote:
首先确认硬件有没有问题?
硬件问题不太好确认是不是OK的,因为感觉外围电路比较简单就直接打板了,手头也没有成品的xr819模块来对比,头疼
原理图:
https://github.com/AutopilotPi/XR819_Module/blob/master/XR819.pdf
dts是启用的,启动日志下看到有
楼主 #5 2022-07-16 21:49:57
ncer
已发帖子: 39
仔细检查了一下,发现使用主板使用该模块的原理图符号画错了,导致信号线连接错误了,令人汗颜,只能另外打板测试了
#6 2022-07-30 09:11:08
computman
@ncer
硬件问题确认方法:
  1. 万用表测量供电是否正常
    2.wifi都有时钟的,需要看看时钟是否正常,和软件配置的时钟是否一致
  2. 如果要测试连接,可以看看接口上是否有对应的波形。
楼主 #7 2022-08-01 10:22:14
ncer
已发帖子: 39
computman wrote:
@ncer
硬件问题确认方法:
  1. 万用表测量供电是否正常
谢谢,学习了
#8 2022-12-20 09:59:33
zhangzhoulzl
请问XR819的外围硬件连接图可以分享下嘛
