楼主 # 2021-11-26 23:54:21
limb
关于USB驱动问题,请各位专家支持,看选择哪一个驱动?谢谢了!
按照官方文档完成刷机,但是开机时报如下驱动找不到,同时USB口不能用(插上鼠标、或者U盘,无法检测到)
insmod: can't insert '/config/modules/4.9.84/usb-common.ko': No such file or directory
insmod: can't insert '/config/modules/4.9.84/usbcore.ko': No such file oehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
在环境中搜到了一下,找到对应驱动文件如下,但我不清楚选择哪个驱动文件合适,请求支持,谢谢了!
./project/kbuild/4.9.84/i2m/configs/nvr/011A-cus/glibc/8.2.1/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/011A-fastboot/glibc/8.2.1/spinand/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/011A-fastboot/glibc/8.2.1/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/011A-fastboot/glibc/9.1.0/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/011A-fastboot/uclibc/4.9.4/spinand/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/011A-fastboot/uclibc/4.9.4/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/011A-8Mflash/uclibc/4.9.4/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/011A/glibc/9.1.0/spinand/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/011A/glibc/9.1.0/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/011A/glibc/4.8.3/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A-623/glibc/8.2.1/spinand/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A-623/glibc/8.2.1/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A-623/glibc/9.1.0/spinand/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A-623/glibc/9.1.0/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A/glibc/8.2.1/spinand/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A/glibc/8.2.1/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A/glibc/9.1.0/spinand/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A/glibc/9.1.0/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A/glibc/4.8.3/spinand/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A/glibc/4.8.3/nor/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A/uclibc/4.9.4/spinand/modules/usb-common.ko
./project/kbuild/4.9.84/i2m/configs/nvr/010A/uclibc/4.9.4/nor/modules/usb-common.ko
#1 2022-11-16 19:45:48
Blueskull
已发帖子: 458
Re: 关于USB驱动问题,请各位专家支持,看选择哪一个驱动?谢谢了!
驱动有没有打包到initramfs?
