楼主 # 2022-11-18 10:36:22
视觉℡
已发帖子: 43
F1C100S使用Tina改SPI NOR运行到Starting kernel..停止
运行日志:
[0]HELLO! BOOT0 is starting!
[2]boot0 commit : 80628dcde5dc4ecdc757a9e782c58d7cf1abf959
[60]dram size =32
[62]Reg pull reg_val=0x00000000,read=0x00000010
[66]Succeed in reading toc file head.
[69]The size of toc is 00054000.
[127]Reg pull reg_val=0x00000000,read=0x00000010
[136]Ready to disable icache.
[138]Jump to secend Boot.
U-Boot 2014.07 (Jul 31 2018 - 14:59:26) Allwinner Technology
uboot commit : 6604446f7bddb8fe53f2b993100929f92a5f4d6e
i2c_init: by cpux
[I2C-DEBUG]:i2c_set_clock() 354
[I2C-ERROR]:twi_send_clk_9pulse() 136 SDA is still Stuck Low, failed.
i2c_init ok
[0.187]pmbus: ready
axp: get node[/soc/pmu0] error
axp_probe error
[0.193]PMU: cpux 408 Mhz,AXI=408 Mhz
PLL6=600 Mhz,AHB1=200 Mhz, APB1=100Mhz
key value = 4294967295, fel_key = [256,426]
DRAM: 32 MiB
Relocation Offset is: 01581000
int sunxi_dma_init---
irq enable
workmode = 0,storage type = 3
[0.260]spinor: 0
flash size =0x8000 sectors
sunxi spinor is initing...int sunxi_dma_init---
irq enable
sunxi_dma_install_int ok
OK
spinor id:0x1840ef
spi_freq = 40000000
[0.278]sunxi flash init ok
spinor read: start 0x3e0, sector 0x20
used mbr [0], count = 8
spinor read: start 0x800, sector 0x200
env size is 256
env partition is too small!
can't enabled backup env functions
logo addr = 0x81f00000
spinor read: start 0x400, sector 0x400
sunxi_read_bootlogo: read bootlogo partition successful
do not find fastboot status flag
-total partitions:8-
-name- -start- -size-
bootlogo : 4000 80000
env : 84000 20000
boot : a4000 300000
rootfs : 3a4000 a00000
rootfs_data : da4000 80000
misc : e24000 10000
private : e34000 10000
UDISK : e44000 0
spinor read: start 0x7500, sector 0x4
disable nand error: FDT_ERR_BADPATH
error: update_fdt_dram_para : FDT_ERR_NOTFOUND
PowerBus = 0( 2:vBus 3:acBus other: not exist)
no battery exist
sunxi_bmp_logo_display
spinor read: start 0x900, sector 0x40
spinor read: start 0x940, sector 0x13e1
Booting kernel from Legacy Image at 80007fc0 ...
Image Name: ARM OpenWrt Linux-3.10.65
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2638096 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
XIP Kernel Image ... OK
reserving fdt memory region: addr=81000000 size=10000
Using Device Tree in place at 81000000, end 8100f29f
板子用的是荔枝派
修改教程是根据根据https://bbs.aw-ol.com/topic/1701/tina-linux-%E5%AD%98%E5%82%A8%E4%BB%8B%E8%B4%A8%E5%88%87%E6%8D%A2-emmc-spi-nand-spi-nor-sd-card-sd-nand/4?_=1668580535100
我修改串口配置了
sys_config.fex 文件
[target]
boot_clock = 408
storage_type = 3
burn_key = 0
[norflash]
size = 16
[uart_para]
uart_debug_port = 0
uart_debug_tx = port:PE1<5><1><default><default>
uart_debug_rx = port:PE0<5><1><default><default>
[uart0]
uart0_used = 1
uart0_port = 0
uart0_type = 2
uart0_tx = port:PE1<5><1><default><default>
uart0_rx = port:PE0<5><1><default><default>
[uart1]
uart1_used = 1
uart1_port = 1
uart1_type = 2
uart1_tx = port:PA2<5><1><default><default>
uart1_rx = port:PA3<5><1><default><default>
sys_partition_nor.fex文件
[partition_start]
[partition]
name = bootlogo
size = 1024
downloadfile = "bootlogo.fex"
user_type = 0x8000
[partition]
name = env
size = 256
downloadfile = "env.fex"
user_type = 0x8000
[partition]
name = boot
;size = 5120
size = 5600
downloadfile = "boot.fex"
user_type = 0x8000
[partition]
name = rootfs
;size = 1024
;size = 11520
size = 15648
downloadfile = "rootfs.fex"
user_type = 0x8000
[partition]
name = rootfs_data
size = 1024
user_type = 0x8000
;[partition]
; name = extend
; size = 8192
; downloadfile = "usr.fex"
; user_type = 0x8000
[partition]
name = misc
size = 128
user_type = 0x8000
[partition]
name = private
size = 128
user_type = 0x8000
[partition]
name = UDISK
user_type = 0x8100
别的文件没有修改
#1 2022-11-18 16:58:20
鱼尾
所在地: 杭州
已发帖子: 47
Re: F1C100S使用Tina改SPI NOR运行到Starting kernel..停止
你看看内核的串口配置
#2 2022-11-18 17:08:03
鱼尾
所在地: 杭州
已发帖子: 47
#内核修改
make kernel_menuconfig --->
	kernel hacking --->
		[*] Compile the kernel with debug info
		[*] Kernel low-level debugging functios (read help!)
		Kernel low-level debugging port (Kernel low-level debugging messages viasunXi UART0)
#3 2022-11-18 17:09:42
鱼尾
所在地: 杭州
已发帖子: 47
Kernel low-level debugging port (Kernel low-level debugging messages viasunXi UART0) 看看这个有没有改
楼主 #4 2022-11-18 17:47:46
视觉℡
已发帖子: 43
真是太感谢了,确实后面有输出了
#5 2022-11-19 09:45:54
鱼尾
所在地: 杭州
已发帖子: 47
哈哈,f1c100s我用过一段时间
