amixer -c 0 sset 'Headphone',0 100% unmute
amixer sset Headphone 31,31 (音量越大越快卡死)
mplayer /home/test.mp3
MPlayer interrupted by signal 11 in module: decode_audio
MPlayer crashed by bad usage of CPU/FPU/RAM.
Recompile MPlayer with --enable-debug and make a 'gdb' backtrace and
disassembly. Details in DOCS/HTML/en/bugreports_what.html#bugreports_crash.
MPlayer crashed. This shouldn't happen.
It can be a bug in the MPlayer code _or_ in your drivers _or_ in your
gcc version. If you think it's MPlayer's fault, please read
DOCS/HTML/en/bugreports.html and follow the instructions there. We can't and
won't help unless you provide this information when reporting a possible bug.
如果不使用RTL8723,貌似就没这个问题,不知道大家是否遇到过
是不是供电不足?
tianjjff wrote:
是不是供电不足?
电源是5V1A的,发现使用WIFI会导致内存占用率较高,只剩余8M,不知道是不是这个原因
