奔溃现场:
[ 4.556319] VFS: Mounted root (jffs2 filesystem) on device 31:4.
[ 4.563812] devtmpfs: mounted
[ 4.567967] Freeing unused kernel memory: 1024K
FATAL: kernel too old
[ 4.768232] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
[ 4.768232]
[ 4.777374] CPU: 0 PID: 1 Comm: linuxrc Not tainted 4.10.15-licheepi-zero-00962-g02a01d8 #18
[ 4.785797] Hardware name: Allwinner sun8i Family
[ 4.790537] [<c010e494>] (unwind_backtrace) from [<c010b230>] (show_stack+0x10/0x14)
[ 4.798281] [<c010b230>] (show_stack) from [<c0358368>] (dump_stack+0x84/0x98)
[ 4.805503] [<c0358368>] (dump_stack) from [<c01a7b84>] (panic+0xdc/0x248)
[ 4.812378] [<c01a7b84>] (panic) from [<c011e358>] (do_exit+0x9d0/0xa00)
[ 4.819074] [<c011e358>] (do_exit) from [<c011f4c4>] (do_group_exit+0x3c/0xd0)
[ 4.826290] [<c011f4c4>] (do_group_exit) from [<c011f568>] (__wake_up_parent+0x0/0x18)
[ 4.834204] Rebooting in 5 seconds..
全部 log:
U-Boot SPL 2017.01-rc2-00074-g3214598-dirty (Apr 10 2019 - 21:26:39)
DRAM: 64 MiB
Trying to boot from sunxi SPI
U-Boot 2017.01-rc2-00074-g3214598-dirty (Apr 10 2019 - 21:26:39 -0400) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
SF: Detected mx25l25635f with page size 256 Bytes, erase size 64 KiB, total 32 MiB
Setting up a 1024x600 lcd console (overscan 0x0)
dotclock: 48000kHz = 48000kHz: (1 * 3MHz * 96) / 6
In: serial@01c28800
Out: serial@01c28800
Err: serial@01c28800
DRAM: 64 MiB
In: serial@01c28800
Net: No ethernet found.
No controllers found
device 0 offset 0x110000, size 0x500000
SF: 5242880 bytes @ 0x110000 Read: OK
Loading Device Tree to 42df9000, end 42dff04f ... OK
[ 0.000000] Linux version 4.10.15-licheepi-zero-00962-g02a01d8 (root@test4) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.9) ) #18 SMP Mon Apr 15 21:11:46 EDT 2019
[ 0.000000] OF: fdt:Machine model: Lichee Pi Zero with Dock
[ 0.000000] percpu: Embedded 14 pages/cpu @c3d08000 s24780 r8192 d24372 u57344
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 15660
[ 0.000000] Kernel command line: console=ttyS2,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:992k(uboot)ro,32k(env)ro,64k(dtb)ro,5M(kernel)ro,-(rootfs) root=31:04 rw rootfstype=jffs2 init=/linuxrc vt.global_cursor_default=0
[ 0.000000] Memory: 51584K/63136K available (6144K kernel code, 310K rwdata, 2084K rodata, 1024K init, 273K bss, 11552K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc3da8000 ( 61 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0700000 (7136 kB)
[ 0.000000] .init : 0xc0a00000 - 0xc0b00000 (1024 kB)
[ 0.000000] .data : 0xc0b00000 - 0xc0b4d800 ( 310 kB)
[ 0.000000] .bss : 0xc0b4f000 - 0xc0b93714 ( 274 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU debugfs-based tracing is enabled.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000018] Switching to timer-based delay loop, resolution 41ns
[ 0.000184] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000426] Console: colour dummy device 80x30
[ 0.000461] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000475] pid_max: default: 32768 minimum: 301
[ 0.000608] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000619] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001314] CPU: Testing write buffer coherency: ok
[ 0.001725] /cpus/cpu@0 missing clock-frequency property
[ 0.001747] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002106] Setting up static identity map for 0x40100000 - 0x40100058
[ 0.002851] smp: Bringing up secondary CPUs ...
[ 0.002868] smp: Brought up 1 node, 1 CPU
[ 0.002878] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.002884] CPU: All CPU(s) started in SVC mode.
[ 0.003685] devtmpfs: initialized
[ 0.007353] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.007645] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.007675] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.007830] pinctrl core: initialized pinctrl subsystem
[ 0.008855] NET: Registered protocol family 16
[ 0.009402] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.010839] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.010858] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.025254] SCSI subsystem initialized
[ 0.025543] usbcore: registered new interface driver usbfs
[ 0.025606] usbcore: registered new interface driver hub
[ 0.025700] usbcore: registered new device driver usb
[ 0.025958] pps_core: LinuxPPS API ver. 1 registered
[ 0.025970] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.025993] PTP clock support registered
[ 0.026216] Advanced Linux Sound Architecture Driver Initialized.
[ 0.028069] clocksource: Switched to clocksource arch_sys_counter
[ 0.039051] NET: Registered protocol family 2
[ 0.039783] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.039814] TCP bind hash table entries: 1024 (order: 1, 8192 bytes)
[ 0.039838] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.039928] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.039974] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.040189] NET: Registered protocol family 1
[ 0.040785] RPC: Registered named UNIX socket transport module.
[ 0.040803] RPC: Registered udp transport module.
[ 0.040809] RPC: Registered tcp transport module.
[ 0.040814] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.043281] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.052036] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.052998] NFS: Registering the id_resolver key type
[ 0.053047] Key type id_resolver registered
[ 0.053056] Key type id_legacy registered
[ 0.053133] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.057617] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 0.057640] io scheduler noop registered
[ 0.057647] io scheduler deadline registered
[ 0.057823] io scheduler cfq registered (default)
[ 0.063028] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.130785] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.154457] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 36, base_baud = 1500000) is a U6_16550A
[ 0.176067] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 37, base_baud = 1500000) is a U6_16550A
[ 0.197637] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 38, base_baud = 1500000) is a U6_16550A
[ 0.795303] console [ttyS2] enabled
[ 0.799620] [drm] Initialized
[ 0.806027] m25p80 spi32766.0: mx25l25635e (32768 Kbytes)
[ 0.811555] 5 cmdlinepart partitions found on MTD device spi32766.0
[ 0.817815] Creating 5 MTD partitions on "spi32766.0":
[ 0.822982] 0x000000000000-0x0000000f8000 : "uboot"
[ 0.829473] 0x0000000f8000-0x000000100000 : "env"
[ 0.835597] 0x000000100000-0x000000110000 : "dtb"
[ 0.841844] 0x000000110000-0x000000610000 : "kernel"
[ 0.848367] 0x000000610000-0x000002000000 : "rootfs"
[ 0.855218] libphy: Fixed MDIO Bus: probed
[ 0.859973] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 0.865789] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 0.871584] dwmac-sun8i 1c30000.ethernet: Will use internal PHY
[ 0.877745] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 0.883459] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 0.890695] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 0.896348] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 0.903577] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 0.908549] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 0.915536] libphy: stmmac: probed
[ 0.920937] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.927473] ehci-platform: EHCI generic platform driver
[ 0.933122] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.938812] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.946726] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.978087] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.985336] hub 1-0:1.0: USB hub found
[ 0.989293] hub 1-0:1.0: 1 port detected
[ 0.993833] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.000152] ohci-platform: OHCI generic platform driver
[ 1.005680] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.012412] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.020392] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 1.093195] hub 2-0:1.0: USB hub found
[ 1.097026] hub 2-0:1.0: 1 port detected
[ 1.104234] usbcore: registered new interface driver usb-storage
[ 1.110928] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[ 1.120469] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
[ 1.129828] sun6i-rtc 1c20400.rtc: rtc core: registered rtc-sun6i as rtc0
[ 1.136626] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.141306] i2c /dev entries driver
[ 1.146248] Goodix-TS 0-005d: i2c test failed attempt 1: -6
[ 1.188202] Goodix-TS 0-005d: i2c test failed attempt 2: -6
[ 1.228094] Goodix-TS 0-005d: I2C communication failure: -6
[ 1.234501] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.298118] sunxi-mmc 1c0f000.mmc: base:0xc4335000 irq:23
[ 1.358091] sunxi-mmc 1c10000.mmc: base:0xc4339000 irq:24
[ 1.364548] usbcore: registered new interface driver usbhid
[ 1.370213] usbhid: USB HID core driver
[ 1.375726] sun4i-codec 1c22c00.codec: ASoC: /soc/codec-analog@01c23000 not registered
[ 1.383795] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.391732] NET: Registered protocol family 10
[ 1.398819] Segment Routing with IPv6
[ 1.402557] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.409447] NET: Registered protocol family 17
[ 1.413994] Key type dns_resolver registered
[ 1.418534] Registering SWP/SWPB emulation handler
[ 1.431875] usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.439830] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.445594] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.454915] hub 3-0:1.0: USB hub found
[ 1.458952] hub 3-0:1.0: 1 port detected
[ 1.463674] using random self ethernet address
[ 1.468230] using random host ethernet address
[ 1.475116] usb0: HOST MAC 32:cc:9f:3a:8e:c2
[ 1.479602] usb0: MAC 76:4d:08:27:02:20
[ 1.483487] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[ 1.491014] g_cdc gadget: g_cdc ready
[ 1.497358] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok
[ 1.508865] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01 00:03:12 UTC (192)
[ 1.517203] vcc5v0: disabling
[ 1.520267] ALSA device list:
[ 1.523236] #0: V3s Audio Codec
[ 1.528701] random: fast init done
[ 1.544273] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.557687] mmc1: new high speed SD card at address 0001
[ 1.571657] mmcblk1: mmc1:0001 00000 1.83 GiB
[ 1.580893] mmcblk1: p1 p2
[ 1.595109] random: crng init done
[ 4.538331] jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 4.768232]
[ 4.834204] Rebooting in 5 seconds..离线
接着进入 buildroot 目录一顿狂搜:
root@ubuntu:/opt/buildroot-2018.08.2# grep "kernel too old" -r .
Binary file ./output/target/lib/ld-2.27.so matches
Binary file ./output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/build/libc.a matches
Binary file ./output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/build/csu/libc-start.o matches
Binary file ./output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/build/elf/ld.so matches
Binary file ./output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/build/elf/sln matches
Binary file ./output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/build/elf/ldconfig matches
Binary file ./output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/build/elf/dl-allobjs.os matches
Binary file ./output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/build/elf/rtld.os matches
Binary file ./output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/build/elf/librtld.os matches
./output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/sysdeps/unix/sysv/linux/dl-osinfo.h: FATAL ("FATAL: kernel too old\n"); \
./output/build/linux-zero-4.13.y/Documentation/arm/kernel_user_helpers.txt: fprintf(stderr, "can't do atomic operations, kernel too old\n");
./output/build/linux-zero-4.13.y/Documentation/translations/zh_CN/arm/kernel_user_helpers.txt: fprintf(stderr, "can't do atomic operations, kernel too old\n");
./output/build/linux-zero-4.13.y/net/netfilter/xt_hashlimit.c: pr_info("Unknown mode mask %X, kernel too old?\n",
./output/build/linux-headers-zero-4.13.y/Documentation/arm/kernel_user_helpers.txt: fprintf(stderr, "can't do atomic operations, kernel too old\n");
./output/build/linux-headers-zero-4.13.y/Documentation/translations/zh_CN/arm/kernel_user_helpers.txt: fprintf(stderr, "can't do atomic operations, kernel too old\n");
./output/build/linux-headers-zero-4.13.y/net/netfilter/xt_hashlimit.c: pr_info("Unknown mode mask %X, kernel too old?\n",
Binary file ./output/images/rootfs.tar matches
Binary file ./output/host/arm-buildroot-linux-gnueabihf/sysroot/usr/lib/libc.a matches
Binary file ./output/host/arm-buildroot-linux-gnueabihf/sysroot/sbin/sln matches
Binary file ./output/host/arm-buildroot-linux-gnueabihf/sysroot/sbin/ldconfig matches
Binary file ./output/host/arm-buildroot-linux-gnueabihf/sysroot/lib/ld-2.27.so matches
./dl/linux/git/Documentation/arm/kernel_user_helpers.txt: fprintf(stderr, "can't do atomic operations, kernel too old\n");
./dl/linux/git/Documentation/translations/zh_CN/arm/kernel_user_helpers.txt: fprintf(stderr, "can't do atomic operations, kernel too old\n");
./dl/linux/git/net/netfilter/xt_hashlimit.c: pr_info("Unknown mode mask %X, kernel too old?\n",
最可疑就是这个 glibc 了 output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/sysdeps/unix/sysv/linux/dl-osinfo.h
打开 output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/sysdeps/unix/sysv/linux/dl-osinfo.h
#define DL_SYSDEP_OSCHECK(FATAL) \
do { \
/* Test whether the kernel is new enough. This test is only performed \
if the library is not compiled to run on all kernels. */ \
int version = _dl_discover_osversion (); \
if (__glibc_likely (version >= 0)) \
if (__builtin_expect (GLRO(dl_osversion) == 0, 1) \
|| GLRO(dl_osversion) > version) \
GLRO(dl_osversion) = version; \
/* Now we can test with the required version. */ \
if (__LINUX_KERNEL_VERSION > 0 && version < __LINUX_KERNEL_VERSION) \
/* Not sufficent. */ \
else if (__LINUX_KERNEL_VERSION > 0) \
FATAL ("FATAL: cannot determine kernel version\n"); \
} while (0)错误就是这里报出来的:
/ Now we can test with the required version. / \
/ Not sufficent. / \
打开配置文件 output/build/glibc-glibc-2.27-57-g6c99e37f6fb640a50a3113b2dbee5d5389843c1e/build/config.h
/* Linux specific: minimum supported kernel version. */
#define __LINUX_KERNEL_VERSION (4 * 65536 + 13 * 256 + 0)
/* Override abi-tags ABI version if necessary. */
#define __ABI_TAG_VERSION 4,13,0这下终于知道为什么了,
kernel忙活了半天, 满身大汉, 居然被人嘲笑"你不行了"
盘他
学习经验
/files/members/3/2019-04-17_080606.png
如果跑 Linux 4.10 系统, 建议用 buildroot 配置时候选 Linux 4.9.x kernel headers
如果选 Linux 4.10.x kernel headers 仍然可能出现一样的 kernel too old 错误然后宕机.
kernel 4.10, 头文件却要选 4.9.x 这有点说不通诶.
应该是最低要求的意思
get 新姿势
下面还有一个手动指定版本的选项(Manually specified Linux version)可以设置具体的小版本号。
刚刚看了一下, 确实有, 多谢指教 ^_^
又站在晕哥的肩膀上解决了更换glibc的问题
多年以后,有一位萌新吭哧吭哧的顺着搜索引擎又翻出来这篇帖子,我的版本号更激进,不过这个报错的确好奇怪,glibc选择5.10.x,kernel版本5.10.3
搜索引擎找到几篇文章,linux kernel 报错:FATAL: kernel too old -CSDN
按上述文章指导,file指令查看交叉编译时生成的libc,可以看到确实目标kernel版本号确实要高。"nterpreter /lib/ld-linux-armhf.so.3, for GNU/Linux 5.15.0"
看到这种内核log,我一定会在kernel疯狂找这个报错的,buildroot是在内核里吗,还是说这一行没有前面的时间,所以判定是应用程序打的吗
