楼主 # 2023-02-03 17:36:36
dykxjh
已发帖子: 189
F1C100S XBOOT 动态内存管理
F1C100S开发裸机,需要用到内存管理,于是
看了分块式内存管理源码,很容易理解。再来看Xboot的动态内存管理源码,发现很复杂。
以下是源码
 * malloc.c
#include <xconfigs.h>
#include <assert.h>
#include <spinlock.h>
#include <string.h>
#include <stdio.h>
#include <malloc.h>
#include <xboot/kobj.h>
#include <xboot/module.h>
 * Some macros.
#define tlsf_cast(t, exp)		((t)(exp))
#define tlsf_min(a, b)			((a) < (b) ? (a) : (b))
#define tlsf_max(a, b)			((a) > (b) ? (a) : (b))
#define tlsf_assert				assert
#define tlsf_insist(x)			{ tlsf_assert(x); if (!(x)) { status--; } }
#if defined(__ARM64__) || defined(__X64__) || (defined(__riscv) && (__riscv_xlen == 64))
# define TLSF_64BIT
#else
# undef TLSF_64BIT
 * Public constants
enum tlsf_public
	 * log2 of number of linear subdivisions of block sizes
	SL_INDEX_COUNT_LOG2 = 5,
 * Private constants
enum tlsf_private
#if defined(TLSF_64BIT)
	 * All allocation sizes and addresses are aligned to 16 bytes
	ALIGN_SIZE_LOG2 = 4,
#else
	 * All allocation sizes and addresses are aligned to 8 bytes
	ALIGN_SIZE_LOG2 = 3,
	ALIGN_SIZE = (1 << ALIGN_SIZE_LOG2),
	FL_INDEX_MAX = 32,
#else
	FL_INDEX_MAX = 30,
	SL_INDEX_COUNT = (1 << SL_INDEX_COUNT_LOG2),
	FL_INDEX_SHIFT = (SL_INDEX_COUNT_LOG2 + ALIGN_SIZE_LOG2),
	FL_INDEX_COUNT = (FL_INDEX_MAX - FL_INDEX_SHIFT + 1),
	SMALL_BLOCK_SIZE = (1 << FL_INDEX_SHIFT),
 * Block header structure
typedef struct block_header_t
	union
		 * Points to the previous physical block
		struct block_header_t * prev_phys_block;
		char align_data[ALIGN_SIZE];
	 * The size of this block, excluding the block header
	size_t size;
	 * Next and previous free blocks
	struct block_header_t * next_free;
	struct block_header_t * prev_free;
} block_header_t;
 * The TLSF control structure.
typedef struct control_t
	 * Empty lists point at this block to indicate they are free.
	block_header_t block_null;
	 * Bitmaps for free lists.
	unsigned int fl_bitmap;
	unsigned int sl_bitmap[FL_INDEX_COUNT];
	 * Head of free lists.
	block_header_t * blocks[FL_INDEX_COUNT][SL_INDEX_COUNT];
} control_t;
 * A type used for casting when doing pointer arithmetic.
typedef ptrdiff_t	tlsfptr_t;
 * Associated constants
static const size_t block_header_free_bit = 1 << 0;
static const size_t block_header_prev_free_bit = 1 << 1;
static const size_t block_header_overhead = sizeof(size_t);
static const size_t block_start_offset = offsetof(block_header_t, size) + sizeof(size_t);
static const size_t block_size_min = sizeof(block_header_t) - sizeof(block_header_t *);
static const size_t block_size_max = tlsf_cast(size_t, 1) << FL_INDEX_MAX;
#if defined(__riscv)
static int tlsf_fls_generic(unsigned int word)
	int bit = 32;
	if (!word) bit -= 1;
	if (!(word & 0xffff0000)) { word <<= 16; bit -= 16; }
	if (!(word & 0xff000000)) { word <<= 8; bit -= 8; }
	if (!(word & 0xf0000000)) { word <<= 4; bit -= 4; }
	if (!(word & 0xc0000000)) { word <<= 2; bit -= 2; }
	if (!(word & 0x80000000)) { word <<= 1; bit -= 1; }
	return bit;
static int tlsf_ffs(unsigned int word)
	return tlsf_fls_generic(word & (~word + 1)) - 1;
static int tlsf_fls(unsigned int word)
	return tlsf_fls_generic(word) - 1;
#else
	return __builtin_ffs(word) - 1;
	const int bit = word ? 32 - __builtin_clz(word) : 0;
	return bit - 1;
static int tlsf_fls_sizet(size_t size)
	int high = (int)(size >> 32);
	int bits = 0;
	if(high)
		bits = 32 + tlsf_fls(high);
		bits = tlsf_fls((int)size & 0xffffffff);
	return bits;
#else
#define tlsf_fls_sizet		tlsf_fls
static size_t block_get_size(const block_header_t * block)
	return block->size & ~(block_header_free_bit | block_header_prev_free_bit);
static void block_set_size(block_header_t * block, size_t size)
	const size_t oldsize = block->size;
	block->size = size | (oldsize & (block_header_free_bit | block_header_prev_free_bit));
static int block_is_last(const block_header_t * block)
	return (block_get_size(block) == 0);
static int block_is_free(const block_header_t * block)
	return tlsf_cast(int, block->size & block_header_free_bit);
static void block_set_free(block_header_t * block)
	block->size |= block_header_free_bit;
static void block_set_used(block_header_t * block)
	block->size &= ~block_header_free_bit;
static int block_is_prev_free(const block_header_t * block)
	return tlsf_cast(int, block->size & block_header_prev_free_bit);
static void block_set_prev_free(block_header_t * block)
	block->size |= block_header_prev_free_bit;
static void block_set_prev_used(block_header_t * block)
	block->size &= ~block_header_prev_free_bit;
static block_header_t * block_from_ptr(const void * ptr)
	return tlsf_cast(block_header_t *, tlsf_cast(unsigned char*, ptr) - block_start_offset);
static void * block_to_ptr(const block_header_t * block)
	return tlsf_cast(void *, tlsf_cast(unsigned char*, block) + block_start_offset);
static block_header_t * offset_to_block(const void * ptr, size_t size)
	return tlsf_cast(block_header_t *, tlsf_cast(tlsfptr_t, ptr) + size);
static block_header_t * block_prev(const block_header_t * block)
	return block->prev_phys_block;
static block_header_t * block_next(const block_header_t * block)
	block_header_t * next = offset_to_block(block_to_ptr(block), block_get_size(block) - block_header_overhead);
	tlsf_assert(!block_is_last(block));
	return next;
static block_header_t * block_link_next(block_header_t * block)
	block_header_t * next = block_next(block);
	next->prev_phys_block = block;
	return next;
static void block_mark_as_free(block_header_t * block)
	block_header_t * next = block_link_next(block);
	block_set_prev_free(next);
	block_set_free(block);
static void block_mark_as_used(block_header_t * block)
	block_set_prev_used(next);
	block_set_used(block);
static size_t align_up(size_t x, size_t align)
	tlsf_assert(0 == (align & (align - 1)) && "must align to a power of two");
	return (x + (align - 1)) & ~(align - 1);
static size_t align_down(size_t x, size_t align)
	return x - (x & (align - 1));
static void * align_ptr(const void * ptr, size_t align)
	const tlsfptr_t aligned = (tlsf_cast(tlsfptr_t, ptr) + (align - 1)) & ~(align - 1);
	return tlsf_cast(void*, aligned);
static size_t adjust_request_size(size_t size, size_t align)
	size_t adjust = 0;
	if(size)
		const size_t aligned = align_up(size, align);
		if(aligned < block_size_max)
			adjust = tlsf_max(aligned, block_size_min);
	return adjust;
static void mapping_insert(size_t size, int * fli, int * sli)
	int fl, sl;
	if(size < SMALL_BLOCK_SIZE)
		fl = 0;
		sl = tlsf_cast(int, size) / (SMALL_BLOCK_SIZE / SL_INDEX_COUNT);
		fl = tlsf_fls_sizet(size);
		sl = tlsf_cast(int, size >> (fl - SL_INDEX_COUNT_LOG2)) ^ (1 << SL_INDEX_COUNT_LOG2);
		fl -= (FL_INDEX_SHIFT - 1);
	*fli = fl;
	*sli = sl;
static void mapping_search(size_t size, int * fli, int * sli)
	if(size >= (1 << SL_INDEX_COUNT_LOG2))
		const size_t round = (1 << (tlsf_fls_sizet(size) - SL_INDEX_COUNT_LOG2)) - 1;
		size += round;
	mapping_insert(size, fli, sli);
static block_header_t * search_suitable_block(control_t * control, int * fli, int * sli)
	int fl = *fli;
	int sl = *sli;
	unsigned int sl_map = control->sl_bitmap[fl] & (~0U << sl);
	if(!sl_map)
		const unsigned int fl_map = control->fl_bitmap & (~0 << (fl + 1));
		if(!fl_map)
		fl = tlsf_ffs(fl_map);
		*fli = fl;
		sl_map = control->sl_bitmap[fl];
	tlsf_assert(sl_map && "internal error - second level bitmap is null");
	sl = tlsf_ffs(sl_map);
	*sli = sl;
	return control->blocks[fl][sl];
static void remove_free_block(control_t * control, block_header_t * block, int fl, int sl)
	block_header_t * prev = block->prev_free;
	block_header_t * next = block->next_free;
	tlsf_assert(prev && "prev_free field can not be null");
	tlsf_assert(next && "next_free field can not be null");
	next->prev_free = prev;
	prev->next_free = next;
	if(control->blocks[fl][sl] == block)
		control->blocks[fl][sl] = next;
		if(next == &control->block_null)
			control->sl_bitmap[fl] &= ~(1U << sl);
			if(!control->sl_bitmap[fl])
				control->fl_bitmap &= ~(1U << fl);
static void insert_free_block(control_t * control, block_header_t * block, int fl, int sl)
	block_header_t * current = control->blocks[fl][sl];
	tlsf_assert(current && "free list cannot have a null entry");
	tlsf_assert(block && "cannot insert a null entry into the free list");
	block->next_free = current;
	block->prev_free = &control->block_null;
	current->prev_free = block;
	tlsf_assert(block_to_ptr(block) == align_ptr(block_to_ptr(block), ALIGN_SIZE) && "block not aligned properly");
	control->blocks[fl][sl] = block;
	control->fl_bitmap |= (1U << fl);
	control->sl_bitmap[fl] |= (1U << sl);
static void block_remove(control_t * control, block_header_t * block)
	int fl, sl;
	mapping_insert(block_get_size(block), &fl, &sl);
	remove_free_block(control, block, fl, sl);
static void block_insert(control_t * control, block_header_t * block)
	int fl, sl;
	insert_free_block(control, block, fl, sl);
static int block_can_split(block_header_t * block, size_t size)
	return block_get_size(block) >= sizeof(block_header_t) + size;
static block_header_t * block_split(block_header_t * block, size_t size)
	block_header_t * remaining = offset_to_block(block_to_ptr(block), size - block_header_overhead);
	const size_t remain_size = block_get_size(block) - (size + ALIGN_SIZE);
	tlsf_assert(block_to_ptr(remaining) == align_ptr(block_to_ptr(remaining), ALIGN_SIZE) && "remaining block not aligned properly");
	tlsf_assert(block_get_size(block) == remain_size + size + ALIGN_SIZE);
	block_set_size(remaining, remain_size);
	tlsf_assert(block_get_size(remaining) >= block_size_min && "block split with invalid size");
	block_set_size(block, size);
	block_mark_as_free(remaining);
	return remaining;
static block_header_t * block_absorb(block_header_t * prev, block_header_t * block)
	tlsf_assert(!block_is_last(prev) && "previous block can't be last!");
	prev->size += block_get_size(block) + ALIGN_SIZE;
	block_link_next(prev);
	return prev;
static block_header_t * block_merge_prev(control_t * control, block_header_t * block)
	if(block_is_prev_free(block))
		block_header_t* prev = block_prev(block);
		tlsf_assert(prev && "prev physical block can't be null");
		tlsf_assert(block_is_free(prev) && "prev block is not free though marked as such");
		block_remove(control, prev);
		block = block_absorb(prev, block);
	return block;
static block_header_t * block_merge_next(control_t * control, block_header_t * block)
	block_header_t* next = block_next(block);
	tlsf_assert(next && "next physical block can't be null");
	if(block_is_free(next))
		tlsf_assert(!block_is_last(block) && "previous block can't be last!");
		block_remove(control, next);
		block = block_absorb(block, next);
	return block;
static void block_trim_free(control_t * control, block_header_t * block, size_t size)
	tlsf_assert(block_is_free(block) && "block must be free");
	if(block_can_split(block, size))
		block_header_t* remaining_block = block_split(block, size);
		block_set_prev_free(remaining_block);
		block_insert(control, remaining_block);
static void block_trim_used(control_t * control, block_header_t * block, size_t size)
	tlsf_assert(!block_is_free(block) && "block must be used");
		block_set_prev_used(remaining_block);
		remaining_block = block_merge_next(control, remaining_block);
static block_header_t * block_trim_free_leading(control_t * control, block_header_t * block, size_t size)
	block_header_t * remaining_block = block;
		remaining_block = block_split(block, size - ALIGN_SIZE);
		block_insert(control, block);
	return remaining_block;
static block_header_t * block_locate_free(control_t * control, size_t size)
	int fl = 0, sl = 0;
	block_header_t * block = 0;
	if(size)
		mapping_search(size, &fl, &sl);
		if(fl < FL_INDEX_COUNT)
			block = search_suitable_block(control, &fl, &sl);
	if(block)
		tlsf_assert(block_get_size(block) >= size);
	return block;
static void * block_prepare_used(control_t * control, block_header_t * block, size_t size)
	void * p = 0;
	if(block)
		block_trim_free(control, block, size);
		block_mark_as_used(block);
		p = block_to_ptr(block);
	return p;
static void control_construct(control_t * control)
	int i, j;
	control->block_null.next_free = &control->block_null;
	control->block_null.prev_free = &control->block_null;
	control->fl_bitmap = 0;
	for(i = 0; i < FL_INDEX_COUNT; ++i)
		control->sl_bitmap[i] = 0;
		for(j = 0; j < SL_INDEX_COUNT; ++j)
			control->blocks[i][j] = &control->block_null;
static inline void * tlsf_add_pool(void * tlsf, void * mem, size_t bytes)
	block_header_t * block;
	block_header_t * next;
	const size_t pool_bytes = align_down(bytes - block_header_overhead - ALIGN_SIZE, ALIGN_SIZE);
	if(((ptrdiff_t)mem % ALIGN_SIZE) != 0)
	if(pool_bytes < block_size_min || pool_bytes > block_size_max)
	block = offset_to_block(mem, -(tlsfptr_t)block_header_overhead);
	block_set_size(block, pool_bytes);
	block_set_prev_used(block);
	block_insert(tlsf_cast(control_t*, tlsf), block);
	block_set_size(next, 0);
	block_set_used(next);
	return mem;
static inline void tlsf_remove_pool(void * tlsf, void * mem)
	control_t * control = tlsf_cast(control_t *, tlsf);
	block_header_t * block = offset_to_block(mem, -(int)block_header_overhead);
	int fl = 0, sl = 0;
	tlsf_assert(block_is_free(block) && "block should be free");
	tlsf_assert(!block_is_free(block_next(block)) && "next block should not be free");
	tlsf_assert(block_get_size(block_next(block)) == 0 && "next block size should be zero");
static inline void * tlsf_create(void * mem)
	if(((tlsfptr_t)mem % ALIGN_SIZE) != 0)
	control_construct(tlsf_cast(control_t *, mem));
	return tlsf_cast(void *, mem);
static inline void * tlsf_create_with_pool(void * mem, size_t bytes)
	void * tlsf = tlsf_create(mem);
	tlsf_add_pool(tlsf, (char *)mem + align_up(sizeof(control_t), ALIGN_SIZE), bytes - align_up(sizeof(control_t), ALIGN_SIZE));
	return tlsf;
static inline void tlsf_destroy(void * mem)
	(void)mem;
static inline void * tlsf_get(void * mem)
	return tlsf_cast(void *, (char *)mem + align_up(sizeof(control_t), ALIGN_SIZE));
static inline void * tlsf_malloc(void * tlsf, size_t size)
	const size_t adjust = adjust_request_size(size, ALIGN_SIZE);
	block_header_t * block = block_locate_free(control, adjust);
	return block_prepare_used(control, block, adjust);
static inline void * tlsf_memalign(void * tlsf, size_t align, size_t size)
	const size_t gap_minimum = sizeof(block_header_t);
	const size_t size_with_gap = adjust_request_size(adjust + align + gap_minimum, align);
	const size_t aligned_size = (adjust && align > ALIGN_SIZE) ? size_with_gap : adjust;
	block_header_t* block = block_locate_free(control, aligned_size);
	tlsf_assert(sizeof(block_header_t) == block_size_min + block_header_overhead);
	if(block)
		void * ptr = block_to_ptr(block);
		void * aligned = align_ptr(ptr, align);
		size_t gap = tlsf_cast(size_t, tlsf_cast(tlsfptr_t, aligned) - tlsf_cast(tlsfptr_t, ptr));
		if(gap && (gap < gap_minimum))
			const size_t gap_remain = gap_minimum - gap;
			const size_t offset = tlsf_max(gap_remain, align);
			const void * next_aligned = tlsf_cast(void *, tlsf_cast(tlsfptr_t, aligned) + offset);
			aligned = align_ptr(next_aligned, align);
		if(gap)
			tlsf_assert(gap >= gap_minimum && "gap size too small");
			block = block_trim_free_leading(control, block, gap);
static inline void tlsf_free(void * tlsf, void * ptr)
	if(ptr)
		block_header_t * block = block_from_ptr(ptr);
		tlsf_assert(!block_is_free(block) && "block already marked as free");
		block_mark_as_free(block);
		block = block_merge_prev(control, block);
		block = block_merge_next(control, block);
static inline void * tlsf_realloc(void * tlsf, void * ptr, size_t size)
	void * p = 0;
	if(ptr && (size == 0))
		tlsf_free(tlsf, ptr);
	else if(!ptr)
		p = tlsf_malloc(tlsf, size);
		const size_t cursize = block_get_size(block);
		const size_t combined = cursize + block_get_size(next) + block_header_overhead;
		if((adjust > cursize) && (!block_is_free(next) || adjust > combined))
			if(p)
				const size_t minsize = tlsf_min(cursize, size);
				memcpy(p, ptr, minsize);
			if(adjust > cursize)
			block_trim_used(control, block, adjust);
			p = ptr;
	return p;
static inline void tlsf_info(void * tlsf, size_t * mused, size_t * mfree)
	block_header_t * block = offset_to_block(tlsf, -(int)block_header_overhead);
	*mused = 0;
	*mfree = 0;
	while(block && !block_is_last(block))
		if(block_is_free(block))
			*mfree += block_get_size(block);
			*mused += block_get_size(block);
		block = block_next(block);
void * mm_create(void * mem, size_t bytes)
	return tlsf_create_with_pool(mem, bytes);
void mm_destroy(void * mem)
	tlsf_destroy(mem);
void * mm_get(void * mem)
	return tlsf_get(mem);
void * mm_add_pool(void * mm, void * mem, size_t bytes)
	return tlsf_add_pool(mm, mem, bytes);
void mm_remove_pool(void * mm, void * mem)
	tlsf_remove_pool(mm, mem);
void * mm_malloc(void * mm, size_t size)
	return tlsf_malloc(mm, size);
void * mm_memalign(void * mm, size_t align, size_t size)
	return tlsf_memalign(mm, align, size);
void * mm_realloc(void * mm, void * ptr, size_t size)
	return tlsf_realloc(mm, ptr, size);
void mm_free(void * mm, void * ptr)
	tlsf_free(mm, ptr);
void mm_info(void * mm, size_t * mused, size_t * mfree)
	if(mused && mfree)
		tlsf_info(mm, mused, mfree);
static void * __heap_pool = NULL;
static spinlock_t __heap_lock = SPIN_LOCK_INIT();
static void * __malloc(size_t size)
	void * m;
	if(__heap_pool)
		spin_lock(&__heap_lock);
		m = tlsf_malloc(__heap_pool, size);
		spin_unlock(&__heap_lock);
		return m;
	return NULL;
extern __typeof(__malloc) malloc __attribute__((weak, alias("__malloc")));
static void * __memalign(size_t align, size_t size)
	void * m;
	if(__heap_pool)
		m = tlsf_memalign(__heap_pool, align, size);
		return m;
	return NULL;
extern __typeof(__memalign) memalign __attribute__((weak, alias("__memalign")));
static void * __realloc(void * ptr, size_t size)
	void * m;
	if(__heap_pool)
		m = tlsf_realloc(__heap_pool, ptr, size);
		return m;
	return NULL;
extern __typeof(__realloc) realloc __attribute__((weak, alias("__realloc")));
static void * __calloc(size_t nmemb, size_t size)
	void * m;
	if((m = malloc(nmemb * size)))
		memset(m, 0, nmemb * size);
	return m;
extern __typeof(__calloc) calloc __attribute__((weak, alias("__calloc")));
static void __free(void * ptr)
	if(__heap_pool)
		tlsf_free(__heap_pool, ptr);
extern __typeof(__free) free __attribute__((weak, alias("__free")));
static void __meminfo(size_t * mused, size_t * mfree)
	if(__heap_pool)
		if(mused && mfree)
			tlsf_info(mm_get(__heap_pool), mused, mfree);
extern __typeof(__meminfo) meminfo __attribute__((weak, alias("__meminfo")));
static struct kobj_t * search_class_memory_kobj(void)
	struct kobj_t * kclass = kobj_search_directory_with_create(kobj_get_root(), "class");
	return kobj_search_directory_with_create(kclass, "memory");
static ssize_t memory_read_meminfo(struct kobj_t * kobj, void * buf, size_t size)
	size_t mused = 0;
	size_t mfree = 0;
	char * p = buf;
	int len = 0;
	meminfo(&mused, &mfree);
	len += sprintf((char *)(p + len), " memory used: %ld\r\n", mused);
	len += sprintf((char *)(p + len), " memory free: %ld\r\n", mfree);
	return len;
void do_init_mem(void)
#ifndef __SANDBOX__
	extern unsigned char __heap_start[];
	extern unsigned char __heap_end[];
	spin_lock_init(&__heap_lock);
	__heap_pool = mm_create((void *)__heap_start, (size_t)(__heap_end - __heap_start));
	kobj_add_regular(search_class_memory_kobj(), "meminfo", memory_read_meminfo, NULL, NULL);
不知道优缺点如何,有没有xboot的大神出来介绍以下?
有没有执行效率和内存利用率都很高的内存管理系统?
#1 2023-02-03 21:20:37
海石生风
已发帖子: 786
Re: F1C100S XBOOT 动态内存管理
这是“TLSF内存分配算法”,可以查些资料来了解下。
TLSF算法“将动态内存的分配与回收时间复杂度都降到了O(1)时间复杂度,并且采用了Good-fit的分配策略保证系统运行时不会产生过多碎片。”
引至这里
最近编辑记录 海石生风 (2023-02-03 21:33:12)
楼主 #2 2023-02-04 09:06:36
dykxjh
已发帖子: 189
“TLSF内存分配算法”,有用的知识又增加了。
#3 2023-02-06 14:52:53
rayandy
已发帖子: 21
