我是按着大神的操作方法 文件是下载沉鱼版主的V3s_TFCard.7z
1) 删除TF卡所有分区
2) 将uboot写入到sd卡8k偏移处(必须8K偏移, brom龟腚的)。
sudo dd if=u-boot-sunxi-with-spl.bin of=/dev/sdX bs=1024 seek=8
3) 建立第一个分区,大小32M(可以随意填写), 格式FAT16, 把zImage, sun8i-v3s-licheepi-zero-dock.dtb拷贝到 这个分区
4) 建立第二个分区,用尽剩余空间,格式ext4, 把buildroot产生的rootfs.tar解压到该分区根目录
2出现的问题 就是就是屏幕一直在小企鹅页面 ,
3串口打印出下面的信息
U-Boot SPL 2017.01-rc2-00057-g32ab180-dirty (Sep 02 2018 - 19:25:33)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-00057-g32ab180-dirty (Sep 02 2018 - 19:25:33 -0700) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
dotclock: 33000kHz = 33000kHz: (1 3MHz 66) / 6
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
reading /sun8i-v3s-licheepi-zero.dtb
11134 bytes read in 25 ms (434.6 KiB/s)
USB is stopped. Please issue 'usb start' first.
No ethernet found.
missing environment variable: bootfile
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-sunxi
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
有两个办法解决:
参考第2步,修改 sun8i.h https://whycan.cn/t_561.html
#define CONFIG_BOOTCOMMAND "setenv bootm_boot_mode sec; " \
"load mmc 0:1 0x41000000 zImage; " \
"load mmc 0:1 0x41800000 sun8i-v3s-licheepi-zero-dock.dtb; " \
"bootz 0x41000000 - 0x41800000;"#define CONFIG_BOOTARGS "console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0"
重新编译u-boot, 拷贝bin到TF卡第一个分区
参考第4步, 生成 boot.scr https://whycan.cn/t_682.html
新建一个文件 boot.cmd
写入 :
setenv bootargs console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw
setenv machid 1029
load mmc 0:1 0x41000000 uImage
load mmc 0:1 0x41d00000 script.bin
bootm 0x41000000
保存
mkimage -C none -A arm -T script -d boot.cmd boot.scr
把boot.scr 文件拷贝到 TF卡第一个分区的根目录
二选一.
好的 谢谢晕哥
无情一刀 wrote:
好的 谢谢晕哥
不用谢,应该是我感谢你到这里发帖。
你说的刚才第一个办法是不是就是直接在里面加上
对,相当于代替手工输入启动命令。
你有没有手工输入过uboot命令,没有就敲进去试一试,直观感觉一下。
你刚才说的第一个方法将bin拷贝到第一分区 这个bin的名字是叫什么啊
无情一刀 wrote:
对,相当于代替手工输入启动命令。
不好意思,弄错了,是 u-boot-sunxi-with-spl.bin,
是 dd 命令写到 tf卡 8k 偏移,
不是拷贝到第一个分区。
1) 删除TF卡所有分区
Welcome to Buildroot
buildroot login:
屏幕上面没有显示出信息
这里我root 在串口上面根本就不会显示出来 ,就是你输入上root不会显示,就一直显示在这里了 ,其他的帖子里面说的默认账号是root 密码是空的
最近编辑记录 无情一刀 (2018-09-06 20:23:48)
buildroot的默认账号是root, 密码是空,
配置的话在buildroot menuconfig里面可能可以配置,
如果不行的话, 在V3s 的Linux终端执行 passwd,
重设root密码.
如果觉得登陆对话框碍事, 看看这个 我用buildroot产生的rootfs,每次启动都要登录,有什么办法可以去掉这个登录吗?
重设root密码.如果觉得登陆对话框碍事, 看看这个 我用buildroot产生的rootfs,每次启动都要登录,有什么办法可以去掉这个登录吗?
我这里是在输入 root 串口上也不显示出来,就是不管输入什么都不显示出来 ,这是正常的吗 ,就是因为没有配置buildroot menuconfig
不正常,检查你的硬件电路。
首先测试一下电脑串口自发自收是否正常,
再检查V3s串口输入是否开路。
我刚才测试用串口测试,没有用终端就是发送和接受没有问题,就是发送ASCLl的root过去没有问题,这样说吗硬件电脑电路没有问题 ,但是一到终端就是啥也输入不了
你确认 把串口线的 RX, TX 短路, 自发自收正常?
终端出现了三个 # 说明能输入吧?
我的串口短接了 首发都没有问题 至于出现#我是用串口发送ASCLL过去的root
如果我没猜错,你这个终端应该是比较简单的单片机用的串口终端,不能在右上角的输出窗口即时输入.
换putty,或者mobaxterm应该就没事了。
换了后是可以了 输入root 但是输入root后回车,就出现#了 然后这里就是一直# 了
换putty,或者mobaxterm应该就没事了。换了后是可以了 输入root 但是输入root后回车,就出现#了 然后这里就是一直# 了
对, 嵌入式linux就是酱紫, 你认为应该怎样?
然后你可以执行busybox命令了, ls, cd, pwd等
刚才测试了几次 只有一次可以输入root 当再一次上电重启的时候 就不能再输入了
你电脑端是什么串口线?
USB转TTL ? 什么型号的芯片? PL2303?
感觉还是硬件方面找原因.建议最好买 CP210X 系列的USB转TTL模块,比较稳定,性价比比较好.
嗯啊 为什么终端可以输入命令了 屏幕一直是黑的
现在开发板已经不是 PC 了, 不是你输入什么, 屏幕就会显示啥。
因为PC上的Windows或者Ubuntu帮你把什么都做好了,
现在要完全自己动手了。
你输入这个命令试一试:
cat /dev/urandom > /dev/fb0
或者
dd if=/dev/urandom of=/dev/fb0
然后再输入这个命令试一试:
cat /dev/zero > /dev/fb0
前提是你的屏幕背光要打开才有反应!
现在要完全自己动手了。你输入这个命令试一试:
或者
然后再输入这个命令试一试:
前提是你的屏幕背光要打开才有反应!
输入完了后 屏幕会有那种白灰点,但是后面会有一个告警 cat:write error:No space left on device 这里指的是哪个空间不足了
最近编辑记录 无情一刀 (2018-09-07 20:18:35)
这是非常正常的现象,
写随机数到显存当然是乱七八糟的。
好了,现在你已经操作入门了。cat:write error:No space left on device
这个是提示写满退出了。
再问你一个问题 如果是我要写入字符串了
这个问题讨论就比较宽了,
涉及到GUI,
随便找了几个链接给你:
https://whycan.cn/t_982.html
https://whycan.cn/t_1384.html
原理是: 给你一块空白的画布(framebuffer: /dev/fb0),
然后你用画笔(CPU控制逻辑)在上面这块画布上面创作。
