之前大概花半个下午写的小工具,类似树莓派的gpio命令。
源码和二进制都在 https://github.com/wuxx/f1c100s-gpio-tools
具体用法和树莓派的gpio命令类似,如下
root@f1c100s:~#gpio
usage: gpio help
gpio read [PA0|PA1...]
gpio write [PA0|PA1...]
gpio mode [PA0|PA1...] [in|out|...]
gpio readall
gpio dumpall
gpio info
-- github.com/wuxx/f1c100s-gpio-tools --root@f1c100s:~#gpio read PA0
PA0: 1root@f1c100s:~#gpio write PA0 0
PA0: 0
root@f1c100s:~#gpio mode PA0 inroot@f1c100s:~#gpio readall
value mode
PA:
PA0: 0 [in]
PA1: 0 [disabled]
PA2: 0 [out]
PA3: 1 [out]
PB:
PB3: 0 [disabled]
PC:
PC0: 0 [spi0_clk]
PC1: 0 [spi0_cs]
PC2: 0 [spi0_miso]
PC3: 0 [spi0_mosi]
PD:
PD0: 0 [lcd_d2]
PD1: 0 [lcd_d3]
PD2: 0 [lcd_d4]
PD3: 0 [lcd_d5]
PD4: 0 [lcd_d6]
PD5: 0 [lcd_d7]
PD6: 0 [lcd_d10]
PD7: 0 [lcd_d11]
PD8: 0 [lcd_d12]
PD9: 0 [lcd_d13]
PD10: 0 [lcd_d14]
PD11: 0 [lcd_d15]
PD12: 0 [lcd_d18]
PD13: 0 [lcd_d19]
PD14: 0 [lcd_d20]
PD15: 0 [lcd_d21]
PD16: 0 [lcd_d22]
PD17: 0 [lcd_d23]
PD18: 0 [lcd_clk]
PD19: 0 [lcd_de]
PD20: 0 [lcd_hsync]
PD21: 0 [lcd_vsync]
PE:
PE0: 0 [uart0_rx]
PE1: 0 [uart0_tx]
PE2: 0 [out]
PE3: 1 [out]
PE4: 1 [out]
PE5: 1 [in]
PE6: 1 [out]
PE7: 0 [disabled]
PE8: 0 [disabled]
PE9: 0 [disabled]
PE10: 1 [out]
PE11: 0 [twi0_sck]
PE12: 0 [twi0_sda]
PF:
PF0: 0 [sdc0_d1]
PF1: 0 [sdc0_d0]
PF2: 0 [sdc0_clk]
PF3: 0 [sdc0_cmd]
PF4: 0 [sdc0_d3]
PF5: 0 [sdc0_d2]root@f1c100s:~#gpio info
PA0: (in out tp_x1 reserved da_bclk uart1_rts spi1_cs disabled )
PA1: (in out tp_x2 reserved da_lrck uart1_cts spi1_miso disabled )
PA2: (in out tp_y1 pwm0 da_in uart1_rx spi1_clk disabled )
PA3: (in out tp_y2 ir_rx da_out uart1_tx spi1_miso disabled )
PB3: (in out ddr_ref_d ir_rx reserved reserved reserved disabled )
PC0: (reserved out spi0_clk sdc1_clk reserved reserved reserved disabled )
PC1: (in out spi0_cs sdc1_cmd reserved reserved reserved disabled )
PC2: (in out spi0_miso sdc1_d0 reserved reserved reserved disabled )
PC3: (in out spi0_mosi uart0_tx reserved reserved reserved disabled )
PD0: (in out lcd_d2 twi0_sda rsb_sda reserved eintd0 disabled )
PD1: (in out lcd_d3 uart1_rts reserved reserved eintd1 disabled )
PD2: (in out lcd_d4 uart1_cts reserved reserved eintd2 disabled )
PD3: (in out lcd_d5 uart1_rx reserved reserved eintd3 disabled )
PD4: (in out lcd_d6 uart1_tx reserved reserved eintd4 disabled )
PD5: (in out lcd_d7 twi1_sck reserved reserved eintd5 disabled )
PD6: (in out lcd_d10 twi1_sda reserved reserved eintd6 disabled )
PD7: (in out lcd_d11 da_mclk reserved reserved eintd7 disabled )
PD8: (in out lcd_d12 da_bclk reserved reserved eintd8 disabled )
PD9: (in out lcd_d13 da_lrck reserved reserved eintd9 disabled )
PD10: (in out lcd_d14 da_in reserved reserved eintd10 disabled )
PD11: (in out lcd_d15 da_out reserved reserved eintd11 disabled )
PD12: (in out lcd_d18 twi0_sck rsb_sck reserved eintd12 disabled )
PD13: (in out lcd_d19 uart2_tx rsb_sck reserved eintd13 disabled )
PD14: (in out lcd_d20 uart2_rx reserved reserved eintd14 disabled )
PD15: (in out lcd_d21 uart2_rts twi2_sck reserved eintd15 disabled )
PD16: (in out lcd_d22 uart2_cts twi2_sda reserved eintd16 disabled )
PD17: (in out lcd_d23 owa_out reserved reserved eintd17 disabled )
PD18: (in out lcd_clk spi0_cs reserved reserved eintd18 disabled )
PD19: (in out lcd_de spi0_mosi reserved reserved eintd19 disabled )
PD20: (in out lcd_hsync spi0_clk reserved reserved eintd20 disabled )
PD21: (in out lcd_vsync spi0_miso reserved reserved eintd21 disabled )
PE0: (in out csi_hsync lcd_d0 twi2_sck uart0_rx einte0 disabled )
PE1: (in out csi_vsync lcd_d1 twi2_sda uart0_tx einte1 disabled )
PE2: (in out csi_pclk lcd_d8 clk_out reserved einte2 disabled )
PE3: (in out csi_d0 lcd_d9 da_bclk rsb_sck einte3 disabled )
PE4: (in out csi_d1 lcd_d16 da_lrck rsb_sda einte4 disabled )
PE5: (in out csi_d2 lcd_d17 da_in reserved einte5 disabled )
PE6: (in out csi_d3 pwm1 da_out owa_out einte6 disabled )
PE7: (in out csi_d4 uart2_tx spi1_cs reserved einte7 disabled )
PE8: (in out csi_d5 uart2_rx spi1_mosi reserved einte8 disabled )
PE9: (in out csi_d6 uart2_rts spi1_clk reserved einte9 disabled )
PE10: (in out csi_d7 uart2_cts spi1_miso reserved einte10 disabled )
PE11: (in out clk_out twi0_sck ir_rx reserved einte11 disabled )
PE12: (in out da_mclk twi0_sda pwm0 reserved einte12 disabled )
PF0: (in out sdc0_d1 dbg_ms ir_rx reserved eintf0 disabled )
PF1: (in out sdc0_d0 dbg_di reserved reserved eintf1 disabled )
PF2: (in out sdc0_clk uart0_tx reserved reserved eintf2 disabled )
PF3: (in out sdc0_cmd dbg_do reserved reserved eintf3 disabled )
PF4: (in out sdc0_d3 uart0_tx reserved reserved eintf4 disabled )
PF5: (in out sdc0_d2 dbg_ck pwm1 reserved eintf5 disabled )root@f1c100s:~#gpio dumpall
PA:
GPIO_CFG0: 0x00001170
GPIO_CFG1: 0x00000000
GPIO_CFG2: 0x00000000
GPIO_CFG3: 0x00000000
GPIO_DATA: 0x00000008
GPIO_DRV0: 0x00000055
GPIO_DRV1: 0x00000000
GPIO_PUL0: 0x00000000
GPIO_PUL1: 0x00000000
PB:
GPIO_CFG0: 0x00007222
GPIO_DATA: 0x00000000
PC:
GPIO_CFG0: 0x00002222
GPIO_DRV0: 0x00000000
PD:
GPIO_CFG0: 0x22222222
GPIO_CFG1: 0x22222222
GPIO_CFG2: 0x00222222
GPIO_DRV0: 0x55555555
GPIO_DRV1: 0x00000555
PE:
GPIO_CFG0: 0x71011155
GPIO_CFG1: 0x00033177
GPIO_DATA: 0x00000478
GPIO_DRV0: 0x01555555
GPIO_PUL0: 0x00000004
PF:
GPIO_CFG0: 0x00222222
GPIO_DRV0: 0x00000aaa
GPIO_PUL0: 0x00000555
最近编辑记录 wuxx (2019-05-24 00:15:56)
这个好。支持支持!!:)
相当不错, 感谢分享!
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
/* author: wuxx */
enum GPIO_GROUP_E {
PA = 0,
PB = 1,
PC = 2,
PD = 3,
PE = 4,
PF = 5,
enum GPIO_MODE_E {
IN = 0,
OUT = 1,
#define GPIO_BASE (0x01C20800)
#define GPIO_CFG0(n) (GPIO_BASE + ((n) * 0x24) + 0x0)
#define GPIO_CFG1(n) (GPIO_BASE + ((n) * 0x24) + 0x4)
#define GPIO_CFG2(n) (GPIO_BASE + ((n) * 0x24) + 0x8)
#define GPIO_CFG3(n) (GPIO_BASE + ((n) * 0x24) + 0xC)
#define GPIO_DATA(n) (GPIO_BASE + ((n) * 0x24) + 0x10)
#define GPIO_DRV0(n) (GPIO_BASE + ((n) * 0x24) + 0x14)
#define GPIO_DRV1(n) (GPIO_BASE + ((n) * 0x24) + 0x18)
#define GPIO_PUL0(n) (GPIO_BASE + ((n) * 0x24) + 0x1C)
#define GPIO_PUL1(n) (GPIO_BASE + ((n) * 0x24) + 0x20)
#define MAKE_PID(group, index) (#group#index), ((group) << 5 | index)
#define get_bit(x, index) (((x) >> index) & 0x1)
typedef unsigned char u8;
typedef signed char s8;
typedef unsigned short u16;
typedef signed short s16;
typedef unsigned int u32;
typedef signed int s32;
/* pio */
/* 7 6 5 4 3 2 1 0 */
struct gpio_info {
char name[16]; /* PA, PB, PC, PD, PE, PF */
u8 pio;
u32 cfg_addr;
u32 cfg_off;
u32 mode; /* 3 bit */
char mode_desc[32];
/* 6 * 32 * 8 (PA-PF = 6, io0-io32, 8 mode) */
u32 gindex = 0;
struct gpio_info gi[2048];
/* ADD(PA, offset, mode, mode_desc)*/
void set_bit(unsigned int *x, unsigned int bit_index, unsigned int b)
unsigned int _x;
unsigned int bit_mask;
_x = *x;
if (get_bit(_x, bit_index) != b) {
if (b == 0) {
bit_mask = ~(0x1 << bit_index);
*x = (_x) & bit_mask;
} else { /* b == 1 */
bit_mask = (0x1 << bit_index);
*x = (_x) | bit_mask;
u32 writel(u32 addr, u32 data)
FILE *fp;
u32 value = 0;
char cmd[1024];
snprintf(cmd, sizeof(cmd), "devmem 0x%08x 32 0x%08x", addr, data);
fp = popen(cmd, "r");
if (fp == NULL) {
fprintf(stderr, "%s: popen(%s) fail!\n", __func__, cmd);
goto err;
err:
pclose(fp);
return value;
u32 readl(u32 addr)
FILE *fp;
u32 value = 0;
char cmd[1024];
char buf[32];
snprintf(cmd, sizeof(cmd), "devmem 0x%08x", addr);
if (fp == NULL) {
fread(buf, sizeof(char), sizeof(buf), fp);
sscanf(buf, "0x%x", &value);
err:
pclose(fp);
return value;
struct gpio_info * gi_get(char *name, char *mode)
u32 i;
for(i = 0; i < gindex; i++) {
if ((strcmp(gi[i].name, name) == 0)) {
if (mode == NULL) {
return &(gi[i]);
} else {
if (strcmp(gi[i].mode_desc, mode) == 0) {
return &(gi[i]);
return NULL;
char * gi_get_mode_desc(u8 pio, u32 mode)
u32 i;
if (gi[i].pio == pio && gi[i].mode == mode) {
return gi[i].mode_desc;
fprintf(stdout, "%s(0x%x, 0x%x) fail\n", __func__, pio, mode);
return NULL;
void gi_add(char *name, u8 pio, u32 cfg_addr, u32 offset, u32 mode, char *mode_desc)
if (gindex >= (sizeof(gi) / sizeof(gi[0]))) {
fprintf(stderr, "gindex overflow!\n");
exit(-1);
strncpy(gi[gindex].name, name, sizeof(gi[gindex].name));
gi[gindex].pio = pio;
gi[gindex].cfg_addr = cfg_addr;
gi[gindex].cfg_off = offset;
gi[gindex].mode = mode;
strncpy(gi[gindex].mode_desc, mode_desc, sizeof(gi[gindex].mode_desc));
gindex++;
void gi_init()
gi_add(MAKE_PID(PA, 0), GPIO_CFG0(PA), 0x0, 0, "in");
gi_add(MAKE_PID(PA, 0), GPIO_CFG0(PA), 0x0, 1, "out");
gi_add(MAKE_PID(PA, 0), GPIO_CFG0(PA), 0x0, 2, "tp_x1");
gi_add(MAKE_PID(PA, 0), GPIO_CFG0(PA), 0x0, 3, "reserved");
gi_add(MAKE_PID(PA, 0), GPIO_CFG0(PA), 0x0, 4, "da_bclk");
gi_add(MAKE_PID(PA, 0), GPIO_CFG0(PA), 0x0, 5, "uart1_rts");
gi_add(MAKE_PID(PA, 0), GPIO_CFG0(PA), 0x0, 6, "spi1_cs");
gi_add(MAKE_PID(PA, 0), GPIO_CFG0(PA), 0x0, 7, "disabled");
gi_add(MAKE_PID(PA, 1), GPIO_CFG0(PA), 0x4, 0, "in");
gi_add(MAKE_PID(PA, 1), GPIO_CFG0(PA), 0x4, 1, "out");
gi_add(MAKE_PID(PA, 1), GPIO_CFG0(PA), 0x4, 2, "tp_x2");
gi_add(MAKE_PID(PA, 1), GPIO_CFG0(PA), 0x4, 3, "reserved");
gi_add(MAKE_PID(PA, 1), GPIO_CFG0(PA), 0x4, 4, "da_lrck");
gi_add(MAKE_PID(PA, 1), GPIO_CFG0(PA), 0x4, 5, "uart1_cts");
gi_add(MAKE_PID(PA, 1), GPIO_CFG0(PA), 0x4, 6, "spi1_miso");
gi_add(MAKE_PID(PA, 1), GPIO_CFG0(PA), 0x4, 7, "disabled");
gi_add(MAKE_PID(PA, 2), GPIO_CFG0(PA), 0x8, 0, "in");
gi_add(MAKE_PID(PA, 2), GPIO_CFG0(PA), 0x8, 1, "out");
gi_add(MAKE_PID(PA, 2), GPIO_CFG0(PA), 0x8, 2, "tp_y1");
gi_add(MAKE_PID(PA, 2), GPIO_CFG0(PA), 0x8, 3, "pwm0");
gi_add(MAKE_PID(PA, 2), GPIO_CFG0(PA), 0x8, 4, "da_in");
gi_add(MAKE_PID(PA, 2), GPIO_CFG0(PA), 0x8, 5, "uart1_rx");
gi_add(MAKE_PID(PA, 2), GPIO_CFG0(PA), 0x8, 6, "spi1_clk");
gi_add(MAKE_PID(PA, 2), GPIO_CFG0(PA), 0x8, 7, "disabled");
gi_add(MAKE_PID(PA, 3), GPIO_CFG0(PA), 0xc, 0, "in");
gi_add(MAKE_PID(PA, 3), GPIO_CFG0(PA), 0xc, 1, "out");
gi_add(MAKE_PID(PA, 3), GPIO_CFG0(PA), 0xc, 2, "tp_y2");
gi_add(MAKE_PID(PA, 3), GPIO_CFG0(PA), 0xc, 3, "ir_rx");
gi_add(MAKE_PID(PA, 3), GPIO_CFG0(PA), 0xc, 4, "da_out");
gi_add(MAKE_PID(PA, 3), GPIO_CFG0(PA), 0xc, 5, "uart1_tx");
gi_add(MAKE_PID(PA, 3), GPIO_CFG0(PA), 0xc, 6, "spi1_miso");
gi_add(MAKE_PID(PA, 3), GPIO_CFG0(PA), 0xc, 7, "disabled");
gi_add(MAKE_PID(PB, 3), GPIO_CFG0(PB), 0xc, 0, "in");
gi_add(MAKE_PID(PB, 3), GPIO_CFG0(PB), 0xc, 1, "out");
gi_add(MAKE_PID(PB, 3), GPIO_CFG0(PB), 0xc, 2, "ddr_ref_d");
gi_add(MAKE_PID(PB, 3), GPIO_CFG0(PB), 0xc, 3, "ir_rx");
gi_add(MAKE_PID(PB, 3), GPIO_CFG0(PB), 0xc, 4, "reserved");
gi_add(MAKE_PID(PB, 3), GPIO_CFG0(PB), 0xc, 5, "reserved");
gi_add(MAKE_PID(PB, 3), GPIO_CFG0(PB), 0xc, 6, "reserved");
gi_add(MAKE_PID(PB, 3), GPIO_CFG0(PB), 0xc, 7, "disabled");
gi_add(MAKE_PID(PC, 0), GPIO_CFG0(PC), 0x0, 0, "reserved");
gi_add(MAKE_PID(PC, 0), GPIO_CFG0(PC), 0x0, 1, "out");
gi_add(MAKE_PID(PC, 0), GPIO_CFG0(PC), 0x0, 2, "spi0_clk");
gi_add(MAKE_PID(PC, 0), GPIO_CFG0(PC), 0x0, 3, "sdc1_clk");
gi_add(MAKE_PID(PC, 0), GPIO_CFG0(PC), 0x0, 4, "reserved");
gi_add(MAKE_PID(PC, 0), GPIO_CFG0(PC), 0x0, 5, "reserved");
gi_add(MAKE_PID(PC, 0), GPIO_CFG0(PC), 0x0, 6, "reserved");
gi_add(MAKE_PID(PC, 0), GPIO_CFG0(PC), 0x0, 7, "disabled");
gi_add(MAKE_PID(PC, 1), GPIO_CFG0(PC), 0x4, 0, "in");
gi_add(MAKE_PID(PC, 1), GPIO_CFG0(PC), 0x4, 1, "out");
gi_add(MAKE_PID(PC, 1), GPIO_CFG0(PC), 0x4, 2, "spi0_cs");
gi_add(MAKE_PID(PC, 1), GPIO_CFG0(PC), 0x4, 3, "sdc1_cmd");
gi_add(MAKE_PID(PC, 1), GPIO_CFG0(PC), 0x4, 4, "reserved");
gi_add(MAKE_PID(PC, 1), GPIO_CFG0(PC), 0x4, 5, "reserved");
gi_add(MAKE_PID(PC, 1), GPIO_CFG0(PC), 0x4, 6, "reserved");
gi_add(MAKE_PID(PC, 1), GPIO_CFG0(PC), 0x4, 7, "disabled");
gi_add(MAKE_PID(PC, 2), GPIO_CFG0(PC), 0x8, 0, "in");
gi_add(MAKE_PID(PC, 2), GPIO_CFG0(PC), 0x8, 1, "out");
gi_add(MAKE_PID(PC, 2), GPIO_CFG0(PC), 0x8, 2, "spi0_miso");
gi_add(MAKE_PID(PC, 2), GPIO_CFG0(PC), 0x8, 3, "sdc1_d0");
gi_add(MAKE_PID(PC, 2), GPIO_CFG0(PC), 0x8, 4, "reserved");
gi_add(MAKE_PID(PC, 2), GPIO_CFG0(PC), 0x8, 5, "reserved");
gi_add(MAKE_PID(PC, 2), GPIO_CFG0(PC), 0x8, 6, "reserved");
gi_add(MAKE_PID(PC, 2), GPIO_CFG0(PC), 0x8, 7, "disabled");
gi_add(MAKE_PID(PC, 3), GPIO_CFG0(PC), 0xc, 0, "in");
gi_add(MAKE_PID(PC, 3), GPIO_CFG0(PC), 0xc, 1, "out");
gi_add(MAKE_PID(PC, 3), GPIO_CFG0(PC), 0xc, 2, "spi0_mosi");
gi_add(MAKE_PID(PC, 3), GPIO_CFG0(PC), 0xc, 3, "uart0_tx");
gi_add(MAKE_PID(PC, 3), GPIO_CFG0(PC), 0xc, 4, "reserved");
gi_add(MAKE_PID(PC, 3), GPIO_CFG0(PC), 0xc, 5, "reserved");
gi_add(MAKE_PID(PC, 3), GPIO_CFG0(PC), 0xc, 6, "reserved");
gi_add(MAKE_PID(PC, 3), GPIO_CFG0(PC), 0xc, 7, "disabled");
gi_add(MAKE_PID(PD, 0), GPIO_CFG0(PD), 0x0, 0, "in");
gi_add(MAKE_PID(PD, 0), GPIO_CFG0(PD), 0x0, 1, "out");
gi_add(MAKE_PID(PD, 0), GPIO_CFG0(PD), 0x0, 2, "lcd_d2");
gi_add(MAKE_PID(PD, 0), GPIO_CFG0(PD), 0x0, 3, "twi0_sda");
gi_add(MAKE_PID(PD, 0), GPIO_CFG0(PD), 0x0, 4, "rsb_sda");
gi_add(MAKE_PID(PD, 0), GPIO_CFG0(PD), 0x0, 5, "reserved");
gi_add(MAKE_PID(PD, 0), GPIO_CFG0(PD), 0x0, 6, "eintd0");
gi_add(MAKE_PID(PD, 0), GPIO_CFG0(PD), 0x0, 7, "disabled");
gi_add(MAKE_PID(PD, 1), GPIO_CFG0(PD), 0x4, 0, "in");
gi_add(MAKE_PID(PD, 1), GPIO_CFG0(PD), 0x4, 1, "out");
gi_add(MAKE_PID(PD, 1), GPIO_CFG0(PD), 0x4, 2, "lcd_d3");
gi_add(MAKE_PID(PD, 1), GPIO_CFG0(PD), 0x4, 3, "uart1_rts");
gi_add(MAKE_PID(PD, 1), GPIO_CFG0(PD), 0x4, 4, "reserved");
gi_add(MAKE_PID(PD, 1), GPIO_CFG0(PD), 0x4, 5, "reserved");
gi_add(MAKE_PID(PD, 1), GPIO_CFG0(PD), 0x4, 6, "eintd1");
gi_add(MAKE_PID(PD, 1), GPIO_CFG0(PD), 0x4, 7, "disabled");
gi_add(MAKE_PID(PD, 2), GPIO_CFG0(PD), 0x8, 0, "in");
gi_add(MAKE_PID(PD, 2), GPIO_CFG0(PD), 0x8, 1, "out");
gi_add(MAKE_PID(PD, 2), GPIO_CFG0(PD), 0x8, 2, "lcd_d4");
gi_add(MAKE_PID(PD, 2), GPIO_CFG0(PD), 0x8, 3, "uart1_cts");
gi_add(MAKE_PID(PD, 2), GPIO_CFG0(PD), 0x8, 4, "reserved");
gi_add(MAKE_PID(PD, 2), GPIO_CFG0(PD), 0x8, 5, "reserved");
gi_add(MAKE_PID(PD, 2), GPIO_CFG0(PD), 0x8, 6, "eintd2");
gi_add(MAKE_PID(PD, 2), GPIO_CFG0(PD), 0x8, 7, "disabled");
gi_add(MAKE_PID(PD, 3), GPIO_CFG0(PD), 0xc, 0, "in");
gi_add(MAKE_PID(PD, 3), GPIO_CFG0(PD), 0xc, 1, "out");
gi_add(MAKE_PID(PD, 3), GPIO_CFG0(PD), 0xc, 2, "lcd_d5");
gi_add(MAKE_PID(PD, 3), GPIO_CFG0(PD), 0xc, 3, "uart1_rx");
gi_add(MAKE_PID(PD, 3), GPIO_CFG0(PD), 0xc, 4, "reserved");
gi_add(MAKE_PID(PD, 3), GPIO_CFG0(PD), 0xc, 5, "reserved");
gi_add(MAKE_PID(PD, 3), GPIO_CFG0(PD), 0xc, 6, "eintd3");
gi_add(MAKE_PID(PD, 3), GPIO_CFG0(PD), 0xc, 7, "disabled");
gi_add(MAKE_PID(PD, 4), GPIO_CFG0(PD), 0x10, 0, "in");
gi_add(MAKE_PID(PD, 4), GPIO_CFG0(PD), 0x10, 1, "out");
gi_add(MAKE_PID(PD, 4), GPIO_CFG0(PD), 0x10, 2, "lcd_d6");
gi_add(MAKE_PID(PD, 4), GPIO_CFG0(PD), 0x10, 3, "uart1_tx");
gi_add(MAKE_PID(PD, 4), GPIO_CFG0(PD), 0x10, 4, "reserved");
gi_add(MAKE_PID(PD, 4), GPIO_CFG0(PD), 0x10, 5, "reserved");
gi_add(MAKE_PID(PD, 4), GPIO_CFG0(PD), 0x10, 6, "eintd4");
gi_add(MAKE_PID(PD, 4), GPIO_CFG0(PD), 0x10, 7, "disabled");
gi_add(MAKE_PID(PD, 5), GPIO_CFG0(PD), 0x14, 0, "in");
gi_add(MAKE_PID(PD, 5), GPIO_CFG0(PD), 0x14, 1, "out");
gi_add(MAKE_PID(PD, 5), GPIO_CFG0(PD), 0x14, 2, "lcd_d7");
gi_add(MAKE_PID(PD, 5), GPIO_CFG0(PD), 0x14, 3, "twi1_sck");
gi_add(MAKE_PID(PD, 5), GPIO_CFG0(PD), 0x14, 4, "reserved");
gi_add(MAKE_PID(PD, 5), GPIO_CFG0(PD), 0x14, 5, "reserved");
gi_add(MAKE_PID(PD, 5), GPIO_CFG0(PD), 0x14, 6, "eintd5");
gi_add(MAKE_PID(PD, 5), GPIO_CFG0(PD), 0x14, 7, "disabled");
gi_add(MAKE_PID(PD, 6), GPIO_CFG0(PD), 0x18, 0, "in");
gi_add(MAKE_PID(PD, 6), GPIO_CFG0(PD), 0x18, 1, "out");
gi_add(MAKE_PID(PD, 6), GPIO_CFG0(PD), 0x18, 2, "lcd_d10");
gi_add(MAKE_PID(PD, 6), GPIO_CFG0(PD), 0x18, 3, "twi1_sda");
gi_add(MAKE_PID(PD, 6), GPIO_CFG0(PD), 0x18, 4, "reserved");
gi_add(MAKE_PID(PD, 6), GPIO_CFG0(PD), 0x18, 5, "reserved");
gi_add(MAKE_PID(PD, 6), GPIO_CFG0(PD), 0x18, 6, "eintd6");
gi_add(MAKE_PID(PD, 6), GPIO_CFG0(PD), 0x18, 7, "disabled");
gi_add(MAKE_PID(PD, 7), GPIO_CFG0(PD), 0x1c, 0, "in");
gi_add(MAKE_PID(PD, 7), GPIO_CFG0(PD), 0x1c, 1, "out");
gi_add(MAKE_PID(PD, 7), GPIO_CFG0(PD), 0x1c, 2, "lcd_d11");
gi_add(MAKE_PID(PD, 7), GPIO_CFG0(PD), 0x1c, 3, "da_mclk");
gi_add(MAKE_PID(PD, 7), GPIO_CFG0(PD), 0x1c, 4, "reserved");
gi_add(MAKE_PID(PD, 7), GPIO_CFG0(PD), 0x1c, 5, "reserved");
gi_add(MAKE_PID(PD, 7), GPIO_CFG0(PD), 0x1c, 6, "eintd7");
gi_add(MAKE_PID(PD, 7), GPIO_CFG0(PD), 0x1c, 7, "disabled");
gi_add(MAKE_PID(PD, 8), GPIO_CFG1(PD), 0x0, 0, "in");
gi_add(MAKE_PID(PD, 8), GPIO_CFG1(PD), 0x0, 1, "out");
gi_add(MAKE_PID(PD, 8), GPIO_CFG1(PD), 0x0, 2, "lcd_d12");
gi_add(MAKE_PID(PD, 8), GPIO_CFG1(PD), 0x0, 3, "da_bclk");
gi_add(MAKE_PID(PD, 8), GPIO_CFG1(PD), 0x0, 4, "reserved");
gi_add(MAKE_PID(PD, 8), GPIO_CFG1(PD), 0x0, 5, "reserved");
gi_add(MAKE_PID(PD, 8), GPIO_CFG1(PD), 0x0, 6, "eintd8");
gi_add(MAKE_PID(PD, 8), GPIO_CFG1(PD), 0x0, 7, "disabled");
gi_add(MAKE_PID(PD, 9), GPIO_CFG1(PD), 0x4, 0, "in");
gi_add(MAKE_PID(PD, 9), GPIO_CFG1(PD), 0x4, 1, "out");
gi_add(MAKE_PID(PD, 9), GPIO_CFG1(PD), 0x4, 2, "lcd_d13");
gi_add(MAKE_PID(PD, 9), GPIO_CFG1(PD), 0x4, 3, "da_lrck");
gi_add(MAKE_PID(PD, 9), GPIO_CFG1(PD), 0x4, 4, "reserved");
gi_add(MAKE_PID(PD, 9), GPIO_CFG1(PD), 0x4, 5, "reserved");
gi_add(MAKE_PID(PD, 9), GPIO_CFG1(PD), 0x4, 6, "eintd9");
gi_add(MAKE_PID(PD, 9), GPIO_CFG1(PD), 0x4, 7, "disabled");
gi_add(MAKE_PID(PD, 10), GPIO_CFG1(PD), 0x8, 0, "in");
gi_add(MAKE_PID(PD, 10), GPIO_CFG1(PD), 0x8, 1, "out");
gi_add(MAKE_PID(PD, 10), GPIO_CFG1(PD), 0x8, 2, "lcd_d14");
gi_add(MAKE_PID(PD, 10), GPIO_CFG1(PD), 0x8, 3, "da_in");
gi_add(MAKE_PID(PD, 10), GPIO_CFG1(PD), 0x8, 4, "reserved");
gi_add(MAKE_PID(PD, 10), GPIO_CFG1(PD), 0x8, 5, "reserved");
gi_add(MAKE_PID(PD, 10), GPIO_CFG1(PD), 0x8, 6, "eintd10");
gi_add(MAKE_PID(PD, 10), GPIO_CFG1(PD), 0x8, 7, "disabled");
gi_add(MAKE_PID(PD, 11), GPIO_CFG1(PD), 0xc, 0, "in");
gi_add(MAKE_PID(PD, 11), GPIO_CFG1(PD), 0xc, 1, "out");
gi_add(MAKE_PID(PD, 11), GPIO_CFG1(PD), 0xc, 2, "lcd_d15");
gi_add(MAKE_PID(PD, 11), GPIO_CFG1(PD), 0xc, 3, "da_out");
gi_add(MAKE_PID(PD, 11), GPIO_CFG1(PD), 0xc, 4, "reserved");
gi_add(MAKE_PID(PD, 11), GPIO_CFG1(PD), 0xc, 5, "reserved");
gi_add(MAKE_PID(PD, 11), GPIO_CFG1(PD), 0xc, 6, "eintd11");
gi_add(MAKE_PID(PD, 11), GPIO_CFG1(PD), 0xc, 7, "disabled");
gi_add(MAKE_PID(PD, 12), GPIO_CFG1(PD), 0x10, 0, "in");
gi_add(MAKE_PID(PD, 12), GPIO_CFG1(PD), 0x10, 1, "out");
gi_add(MAKE_PID(PD, 12), GPIO_CFG1(PD), 0x10, 2, "lcd_d18");
gi_add(MAKE_PID(PD, 12), GPIO_CFG1(PD), 0x10, 3, "twi0_sck");
gi_add(MAKE_PID(PD, 12), GPIO_CFG1(PD), 0x10, 4, "rsb_sck");
gi_add(MAKE_PID(PD, 12), GPIO_CFG1(PD), 0x10, 5, "reserved");
gi_add(MAKE_PID(PD, 12), GPIO_CFG1(PD), 0x10, 6, "eintd12");
gi_add(MAKE_PID(PD, 12), GPIO_CFG1(PD), 0x10, 7, "disabled");
gi_add(MAKE_PID(PD, 13), GPIO_CFG1(PD), 0x14, 0, "in");
gi_add(MAKE_PID(PD, 13), GPIO_CFG1(PD), 0x14, 1, "out");
gi_add(MAKE_PID(PD, 13), GPIO_CFG1(PD), 0x14, 2, "lcd_d19");
gi_add(MAKE_PID(PD, 13), GPIO_CFG1(PD), 0x14, 3, "uart2_tx");
gi_add(MAKE_PID(PD, 13), GPIO_CFG1(PD), 0x14, 4, "rsb_sck");
gi_add(MAKE_PID(PD, 13), GPIO_CFG1(PD), 0x14, 5, "reserved");
gi_add(MAKE_PID(PD, 13), GPIO_CFG1(PD), 0x14, 6, "eintd13");
gi_add(MAKE_PID(PD, 13), GPIO_CFG1(PD), 0x14, 7, "disabled");
gi_add(MAKE_PID(PD, 14), GPIO_CFG1(PD), 0x18, 0, "in");
gi_add(MAKE_PID(PD, 14), GPIO_CFG1(PD), 0x18, 1, "out");
gi_add(MAKE_PID(PD, 14), GPIO_CFG1(PD), 0x18, 2, "lcd_d20");
gi_add(MAKE_PID(PD, 14), GPIO_CFG1(PD), 0x18, 3, "uart2_rx");
gi_add(MAKE_PID(PD, 14), GPIO_CFG1(PD), 0x18, 4, "reserved");
gi_add(MAKE_PID(PD, 14), GPIO_CFG1(PD), 0x18, 5, "reserved");
gi_add(MAKE_PID(PD, 14), GPIO_CFG1(PD), 0x18, 6, "eintd14");
gi_add(MAKE_PID(PD, 14), GPIO_CFG1(PD), 0x18, 7, "disabled");
gi_add(MAKE_PID(PD, 15), GPIO_CFG1(PD), 0x1c, 0, "in");
gi_add(MAKE_PID(PD, 15), GPIO_CFG1(PD), 0x1c, 1, "out");
gi_add(MAKE_PID(PD, 15), GPIO_CFG1(PD), 0x1c, 2, "lcd_d21");
gi_add(MAKE_PID(PD, 15), GPIO_CFG1(PD), 0x1c, 3, "uart2_rts");
gi_add(MAKE_PID(PD, 15), GPIO_CFG1(PD), 0x1c, 4, "twi2_sck");
gi_add(MAKE_PID(PD, 15), GPIO_CFG1(PD), 0x1c, 5, "reserved");
gi_add(MAKE_PID(PD, 15), GPIO_CFG1(PD), 0x1c, 6, "eintd15");
gi_add(MAKE_PID(PD, 15), GPIO_CFG1(PD), 0x1c, 7, "disabled");
gi_add(MAKE_PID(PD, 16), GPIO_CFG2(PD), 0x0, 0, "in");
gi_add(MAKE_PID(PD, 16), GPIO_CFG2(PD), 0x0, 1, "out");
gi_add(MAKE_PID(PD, 16), GPIO_CFG2(PD), 0x0, 2, "lcd_d22");
gi_add(MAKE_PID(PD, 16), GPIO_CFG2(PD), 0x0, 3, "uart2_cts");
gi_add(MAKE_PID(PD, 16), GPIO_CFG2(PD), 0x0, 4, "twi2_sda");
gi_add(MAKE_PID(PD, 16), GPIO_CFG2(PD), 0x0, 5, "reserved");
gi_add(MAKE_PID(PD, 16), GPIO_CFG2(PD), 0x0, 6, "eintd16");
gi_add(MAKE_PID(PD, 16), GPIO_CFG2(PD), 0x0, 7, "disabled");
gi_add(MAKE_PID(PD, 17), GPIO_CFG2(PD), 0x4, 0, "in");
gi_add(MAKE_PID(PD, 17), GPIO_CFG2(PD), 0x4, 1, "out");
gi_add(MAKE_PID(PD, 17), GPIO_CFG2(PD), 0x4, 2, "lcd_d23");
gi_add(MAKE_PID(PD, 17), GPIO_CFG2(PD), 0x4, 3, "owa_out");
gi_add(MAKE_PID(PD, 17), GPIO_CFG2(PD), 0x4, 4, "reserved");
gi_add(MAKE_PID(PD, 17), GPIO_CFG2(PD), 0x4, 5, "reserved");
gi_add(MAKE_PID(PD, 17), GPIO_CFG2(PD), 0x4, 6, "eintd17");
gi_add(MAKE_PID(PD, 17), GPIO_CFG2(PD), 0x4, 7, "disabled");
gi_add(MAKE_PID(PD, 18), GPIO_CFG2(PD), 0x8, 0, "in");
gi_add(MAKE_PID(PD, 18), GPIO_CFG2(PD), 0x8, 1, "out");
gi_add(MAKE_PID(PD, 18), GPIO_CFG2(PD), 0x8, 2, "lcd_clk");
gi_add(MAKE_PID(PD, 18), GPIO_CFG2(PD), 0x8, 3, "spi0_cs");
gi_add(MAKE_PID(PD, 18), GPIO_CFG2(PD), 0x8, 4, "reserved");
gi_add(MAKE_PID(PD, 18), GPIO_CFG2(PD), 0x8, 5, "reserved");
gi_add(MAKE_PID(PD, 18), GPIO_CFG2(PD), 0x8, 6, "eintd18");
gi_add(MAKE_PID(PD, 18), GPIO_CFG2(PD), 0x8, 7, "disabled");
gi_add(MAKE_PID(PD, 19), GPIO_CFG2(PD), 0xc, 0, "in");
gi_add(MAKE_PID(PD, 19), GPIO_CFG2(PD), 0xc, 1, "out");
gi_add(MAKE_PID(PD, 19), GPIO_CFG2(PD), 0xc, 2, "lcd_de");
gi_add(MAKE_PID(PD, 19), GPIO_CFG2(PD), 0xc, 3, "spi0_mosi");
gi_add(MAKE_PID(PD, 19), GPIO_CFG2(PD), 0xc, 4, "reserved");
gi_add(MAKE_PID(PD, 19), GPIO_CFG2(PD), 0xc, 5, "reserved");
gi_add(MAKE_PID(PD, 19), GPIO_CFG2(PD), 0xc, 6, "eintd19");
gi_add(MAKE_PID(PD, 19), GPIO_CFG2(PD), 0xc, 7, "disabled");
gi_add(MAKE_PID(PD, 20), GPIO_CFG2(PD), 0x10, 0, "in");
gi_add(MAKE_PID(PD, 20), GPIO_CFG2(PD), 0x10, 1, "out");
gi_add(MAKE_PID(PD, 20), GPIO_CFG2(PD), 0x10, 2, "lcd_hsync");
gi_add(MAKE_PID(PD, 20), GPIO_CFG2(PD), 0x10, 3, "spi0_clk");
gi_add(MAKE_PID(PD, 20), GPIO_CFG2(PD), 0x10, 4, "reserved");
gi_add(MAKE_PID(PD, 20), GPIO_CFG2(PD), 0x10, 5, "reserved");
gi_add(MAKE_PID(PD, 20), GPIO_CFG2(PD), 0x10, 6, "eintd20");
gi_add(MAKE_PID(PD, 20), GPIO_CFG2(PD), 0x10, 7, "disabled");
gi_add(MAKE_PID(PD, 21), GPIO_CFG2(PD), 0x14, 0, "in");
gi_add(MAKE_PID(PD, 21), GPIO_CFG2(PD), 0x14, 1, "out");
gi_add(MAKE_PID(PD, 21), GPIO_CFG2(PD), 0x14, 2, "lcd_vsync");
gi_add(MAKE_PID(PD, 21), GPIO_CFG2(PD), 0x14, 3, "spi0_miso");
gi_add(MAKE_PID(PD, 21), GPIO_CFG2(PD), 0x14, 4, "reserved");
gi_add(MAKE_PID(PD, 21), GPIO_CFG2(PD), 0x14, 5, "reserved");
gi_add(MAKE_PID(PD, 21), GPIO_CFG2(PD), 0x14, 6, "eintd21");
gi_add(MAKE_PID(PD, 21), GPIO_CFG2(PD), 0x14, 7, "disabled");
gi_add(MAKE_PID(PE, 0), GPIO_CFG0(PE), 0x0, 0, "in");
gi_add(MAKE_PID(PE, 0), GPIO_CFG0(PE), 0x0, 1, "out");
gi_add(MAKE_PID(PE, 0), GPIO_CFG0(PE), 0x0, 2, "csi_hsync");
gi_add(MAKE_PID(PE, 0), GPIO_CFG0(PE), 0x0, 3, "lcd_d0");
gi_add(MAKE_PID(PE, 0), GPIO_CFG0(PE), 0x0, 4, "twi2_sck");
gi_add(MAKE_PID(PE, 0), GPIO_CFG0(PE), 0x0, 5, "uart0_rx");
gi_add(MAKE_PID(PE, 0), GPIO_CFG0(PE), 0x0, 6, "einte0");
gi_add(MAKE_PID(PE, 0), GPIO_CFG0(PE), 0x0, 7, "disabled");
gi_add(MAKE_PID(PE, 1), GPIO_CFG0(PE), 0x4, 0, "in");
gi_add(MAKE_PID(PE, 1), GPIO_CFG0(PE), 0x4, 1, "out");
gi_add(MAKE_PID(PE, 1), GPIO_CFG0(PE), 0x4, 2, "csi_vsync");
gi_add(MAKE_PID(PE, 1), GPIO_CFG0(PE), 0x4, 3, "lcd_d1");
gi_add(MAKE_PID(PE, 1), GPIO_CFG0(PE), 0x4, 4, "twi2_sda");
gi_add(MAKE_PID(PE, 1), GPIO_CFG0(PE), 0x4, 5, "uart0_tx");
gi_add(MAKE_PID(PE, 1), GPIO_CFG0(PE), 0x4, 6, "einte1");
gi_add(MAKE_PID(PE, 1), GPIO_CFG0(PE), 0x4, 7, "disabled");
gi_add(MAKE_PID(PE, 2), GPIO_CFG0(PE), 0x8, 0, "in");
gi_add(MAKE_PID(PE, 2), GPIO_CFG0(PE), 0x8, 1, "out");
gi_add(MAKE_PID(PE, 2), GPIO_CFG0(PE), 0x8, 2, "csi_pclk");
gi_add(MAKE_PID(PE, 2), GPIO_CFG0(PE), 0x8, 3, "lcd_d8");
gi_add(MAKE_PID(PE, 2), GPIO_CFG0(PE), 0x8, 4, "clk_out");
gi_add(MAKE_PID(PE, 2), GPIO_CFG0(PE), 0x8, 5, "reserved");
gi_add(MAKE_PID(PE, 2), GPIO_CFG0(PE), 0x8, 6, "einte2");
gi_add(MAKE_PID(PE, 2), GPIO_CFG0(PE), 0x8, 7, "disabled");
gi_add(MAKE_PID(PE, 3), GPIO_CFG0(PE), 0xc, 0, "in");
gi_add(MAKE_PID(PE, 3), GPIO_CFG0(PE), 0xc, 1, "out");
gi_add(MAKE_PID(PE, 3), GPIO_CFG0(PE), 0xc, 2, "csi_d0");
gi_add(MAKE_PID(PE, 3), GPIO_CFG0(PE), 0xc, 3, "lcd_d9");
gi_add(MAKE_PID(PE, 3), GPIO_CFG0(PE), 0xc, 4, "da_bclk");
gi_add(MAKE_PID(PE, 3), GPIO_CFG0(PE), 0xc, 5, "rsb_sck");
gi_add(MAKE_PID(PE, 3), GPIO_CFG0(PE), 0xc, 6, "einte3");
gi_add(MAKE_PID(PE, 3), GPIO_CFG0(PE), 0xc, 7, "disabled");
gi_add(MAKE_PID(PE, 4), GPIO_CFG0(PE), 0x10, 0, "in");
gi_add(MAKE_PID(PE, 4), GPIO_CFG0(PE), 0x10, 1, "out");
gi_add(MAKE_PID(PE, 4), GPIO_CFG0(PE), 0x10, 2, "csi_d1");
gi_add(MAKE_PID(PE, 4), GPIO_CFG0(PE), 0x10, 3, "lcd_d16");
gi_add(MAKE_PID(PE, 4), GPIO_CFG0(PE), 0x10, 4, "da_lrck");
gi_add(MAKE_PID(PE, 4), GPIO_CFG0(PE), 0x10, 5, "rsb_sda");
gi_add(MAKE_PID(PE, 4), GPIO_CFG0(PE), 0x10, 6, "einte4");
gi_add(MAKE_PID(PE, 4), GPIO_CFG0(PE), 0x10, 7, "disabled");
gi_add(MAKE_PID(PE, 5), GPIO_CFG0(PE), 0x14, 0, "in");
gi_add(MAKE_PID(PE, 5), GPIO_CFG0(PE), 0x14, 1, "out");
gi_add(MAKE_PID(PE, 5), GPIO_CFG0(PE), 0x14, 2, "csi_d2");
gi_add(MAKE_PID(PE, 5), GPIO_CFG0(PE), 0x14, 3, "lcd_d17");
gi_add(MAKE_PID(PE, 5), GPIO_CFG0(PE), 0x14, 4, "da_in");
gi_add(MAKE_PID(PE, 5), GPIO_CFG0(PE), 0x14, 5, "reserved");
gi_add(MAKE_PID(PE, 5), GPIO_CFG0(PE), 0x14, 6, "einte5");
gi_add(MAKE_PID(PE, 5), GPIO_CFG0(PE), 0x14, 7, "disabled");
gi_add(MAKE_PID(PE, 6), GPIO_CFG0(PE), 0x18, 0, "in");
gi_add(MAKE_PID(PE, 6), GPIO_CFG0(PE), 0x18, 1, "out");
gi_add(MAKE_PID(PE, 6), GPIO_CFG0(PE), 0x18, 2, "csi_d3");
gi_add(MAKE_PID(PE, 6), GPIO_CFG0(PE), 0x18, 3, "pwm1");
gi_add(MAKE_PID(PE, 6), GPIO_CFG0(PE), 0x18, 4, "da_out");
gi_add(MAKE_PID(PE, 6), GPIO_CFG0(PE), 0x18, 5, "owa_out");
gi_add(MAKE_PID(PE, 6), GPIO_CFG0(PE), 0x18, 6, "einte6");
gi_add(MAKE_PID(PE, 6), GPIO_CFG0(PE), 0x18, 7, "disabled");
gi_add(MAKE_PID(PE, 7), GPIO_CFG0(PE), 0x1c, 0, "in");
gi_add(MAKE_PID(PE, 7), GPIO_CFG0(PE), 0x1c, 1, "out");
gi_add(MAKE_PID(PE, 7), GPIO_CFG0(PE), 0x1c, 2, "csi_d4");
gi_add(MAKE_PID(PE, 7), GPIO_CFG0(PE), 0x1c, 3, "uart2_tx");
gi_add(MAKE_PID(PE, 7), GPIO_CFG0(PE), 0x1c, 4, "spi1_cs");
gi_add(MAKE_PID(PE, 7), GPIO_CFG0(PE), 0x1c, 5, "reserved");
gi_add(MAKE_PID(PE, 7), GPIO_CFG0(PE), 0x1c, 6, "einte7");
gi_add(MAKE_PID(PE, 7), GPIO_CFG0(PE), 0x1c, 7, "disabled");
gi_add(MAKE_PID(PE, 8), GPIO_CFG1(PE), 0x0, 0, "in");
gi_add(MAKE_PID(PE, 8), GPIO_CFG1(PE), 0x0, 1, "out");
gi_add(MAKE_PID(PE, 8), GPIO_CFG1(PE), 0x0, 2, "csi_d5");
gi_add(MAKE_PID(PE, 8), GPIO_CFG1(PE), 0x0, 3, "uart2_rx");
gi_add(MAKE_PID(PE, 8), GPIO_CFG1(PE), 0x0, 4, "spi1_mosi");
gi_add(MAKE_PID(PE, 8), GPIO_CFG1(PE), 0x0, 5, "reserved");
gi_add(MAKE_PID(PE, 8), GPIO_CFG1(PE), 0x0, 6, "einte8");
gi_add(MAKE_PID(PE, 8), GPIO_CFG1(PE), 0x0, 7, "disabled");
gi_add(MAKE_PID(PE, 9), GPIO_CFG1(PE), 0x4, 0, "in");
gi_add(MAKE_PID(PE, 9), GPIO_CFG1(PE), 0x4, 1, "out");
gi_add(MAKE_PID(PE, 9), GPIO_CFG1(PE), 0x4, 2, "csi_d6");
gi_add(MAKE_PID(PE, 9), GPIO_CFG1(PE), 0x4, 3, "uart2_rts");
gi_add(MAKE_PID(PE, 9), GPIO_CFG1(PE), 0x4, 4, "spi1_clk");
gi_add(MAKE_PID(PE, 9), GPIO_CFG1(PE), 0x4, 5, "reserved");
gi_add(MAKE_PID(PE, 9), GPIO_CFG1(PE), 0x4, 6, "einte9");
gi_add(MAKE_PID(PE, 9), GPIO_CFG1(PE), 0x4, 7, "disabled");
gi_add(MAKE_PID(PE, 10), GPIO_CFG1(PE), 0x8, 0, "in");
gi_add(MAKE_PID(PE, 10), GPIO_CFG1(PE), 0x8, 1, "out");
gi_add(MAKE_PID(PE, 10), GPIO_CFG1(PE), 0x8, 2, "csi_d7");
gi_add(MAKE_PID(PE, 10), GPIO_CFG1(PE), 0x8, 3, "uart2_cts");
gi_add(MAKE_PID(PE, 10), GPIO_CFG1(PE), 0x8, 4, "spi1_miso");
gi_add(MAKE_PID(PE, 10), GPIO_CFG1(PE), 0x8, 5, "reserved");
gi_add(MAKE_PID(PE, 10), GPIO_CFG1(PE), 0x8, 6, "einte10");
gi_add(MAKE_PID(PE, 10), GPIO_CFG1(PE), 0x8, 7, "disabled");
gi_add(MAKE_PID(PE, 11), GPIO_CFG1(PE), 0xc, 0, "in");
gi_add(MAKE_PID(PE, 11), GPIO_CFG1(PE), 0xc, 1, "out");
gi_add(MAKE_PID(PE, 11), GPIO_CFG1(PE), 0xc, 2, "clk_out");
gi_add(MAKE_PID(PE, 11), GPIO_CFG1(PE), 0xc, 3, "twi0_sck");
gi_add(MAKE_PID(PE, 11), GPIO_CFG1(PE), 0xc, 4, "ir_rx");
gi_add(MAKE_PID(PE, 11), GPIO_CFG1(PE), 0xc, 5, "reserved");
gi_add(MAKE_PID(PE, 11), GPIO_CFG1(PE), 0xc, 6, "einte11");
gi_add(MAKE_PID(PE, 11), GPIO_CFG1(PE), 0xc, 7, "disabled");
gi_add(MAKE_PID(PE, 12), GPIO_CFG1(PE), 0x10, 0, "in");
gi_add(MAKE_PID(PE, 12), GPIO_CFG1(PE), 0x10, 1, "out");
gi_add(MAKE_PID(PE, 12), GPIO_CFG1(PE), 0x10, 2, "da_mclk");
gi_add(MAKE_PID(PE, 12), GPIO_CFG1(PE), 0x10, 3, "twi0_sda");
gi_add(MAKE_PID(PE, 12), GPIO_CFG1(PE), 0x10, 4, "pwm0");
gi_add(MAKE_PID(PE, 12), GPIO_CFG1(PE), 0x10, 5, "reserved");
gi_add(MAKE_PID(PE, 12), GPIO_CFG1(PE), 0x10, 6, "einte12");
gi_add(MAKE_PID(PE, 12), GPIO_CFG1(PE), 0x10, 7, "disabled");
gi_add(MAKE_PID(PF, 0), GPIO_CFG0(PF), 0x0, 0, "in");
gi_add(MAKE_PID(PF, 0), GPIO_CFG0(PF), 0x0, 1, "out");
gi_add(MAKE_PID(PF, 0), GPIO_CFG0(PF), 0x0, 2, "sdc0_d1");
gi_add(MAKE_PID(PF, 0), GPIO_CFG0(PF), 0x0, 3, "dbg_ms");
gi_add(MAKE_PID(PF, 0), GPIO_CFG0(PF), 0x0, 4, "ir_rx");
gi_add(MAKE_PID(PF, 0), GPIO_CFG0(PF), 0x0, 5, "reserved");
gi_add(MAKE_PID(PF, 0), GPIO_CFG0(PF), 0x0, 6, "eintf0");
gi_add(MAKE_PID(PF, 0), GPIO_CFG0(PF), 0x0, 7, "disabled");
gi_add(MAKE_PID(PF, 1), GPIO_CFG0(PF), 0x4, 0, "in");
gi_add(MAKE_PID(PF, 1), GPIO_CFG0(PF), 0x4, 1, "out");
gi_add(MAKE_PID(PF, 1), GPIO_CFG0(PF), 0x4, 2, "sdc0_d0");
gi_add(MAKE_PID(PF, 1), GPIO_CFG0(PF), 0x4, 3, "dbg_di");
gi_add(MAKE_PID(PF, 1), GPIO_CFG0(PF), 0x4, 4, "reserved");
gi_add(MAKE_PID(PF, 1), GPIO_CFG0(PF), 0x4, 5, "reserved");
gi_add(MAKE_PID(PF, 1), GPIO_CFG0(PF), 0x4, 6, "eintf1");
gi_add(MAKE_PID(PF, 1), GPIO_CFG0(PF), 0x4, 7, "disabled");
gi_add(MAKE_PID(PF, 2), GPIO_CFG0(PF), 0x8, 0, "in");
gi_add(MAKE_PID(PF, 2), GPIO_CFG0(PF), 0x8, 1, "out");
gi_add(MAKE_PID(PF, 2), GPIO_CFG0(PF), 0x8, 2, "sdc0_clk");
gi_add(MAKE_PID(PF, 2), GPIO_CFG0(PF), 0x8, 3, "uart0_tx");
gi_add(MAKE_PID(PF, 2), GPIO_CFG0(PF), 0x8, 4, "reserved");
gi_add(MAKE_PID(PF, 2), GPIO_CFG0(PF), 0x8, 5, "reserved");
gi_add(MAKE_PID(PF, 2), GPIO_CFG0(PF), 0x8, 6, "eintf2");
gi_add(MAKE_PID(PF, 2), GPIO_CFG0(PF), 0x8, 7, "disabled");
gi_add(MAKE_PID(PF, 3), GPIO_CFG0(PF), 0xc, 0, "in");
gi_add(MAKE_PID(PF, 3), GPIO_CFG0(PF), 0xc, 1, "out");
gi_add(MAKE_PID(PF, 3), GPIO_CFG0(PF), 0xc, 2, "sdc0_cmd");
gi_add(MAKE_PID(PF, 3), GPIO_CFG0(PF), 0xc, 3, "dbg_do");
gi_add(MAKE_PID(PF, 3), GPIO_CFG0(PF), 0xc, 4, "reserved");
gi_add(MAKE_PID(PF, 3), GPIO_CFG0(PF), 0xc, 5, "reserved");
gi_add(MAKE_PID(PF, 3), GPIO_CFG0(PF), 0xc, 6, "eintf3");
gi_add(MAKE_PID(PF, 3), GPIO_CFG0(PF), 0xc, 7, "disabled");
gi_add(MAKE_PID(PF, 4), GPIO_CFG0(PF), 0x10, 0, "in");
gi_add(MAKE_PID(PF, 4), GPIO_CFG0(PF), 0x10, 1, "out");
gi_add(MAKE_PID(PF, 4), GPIO_CFG0(PF), 0x10, 2, "sdc0_d3");
gi_add(MAKE_PID(PF, 4), GPIO_CFG0(PF), 0x10, 3, "uart0_tx");
gi_add(MAKE_PID(PF, 4), GPIO_CFG0(PF), 0x10, 4, "reserved");
gi_add(MAKE_PID(PF, 4), GPIO_CFG0(PF), 0x10, 5, "reserved");
gi_add(MAKE_PID(PF, 4), GPIO_CFG0(PF), 0x10, 6, "eintf4");
gi_add(MAKE_PID(PF, 4), GPIO_CFG0(PF), 0x10, 7, "disabled");
gi_add(MAKE_PID(PF, 5), GPIO_CFG0(PF), 0x14, 0, "in");
gi_add(MAKE_PID(PF, 5), GPIO_CFG0(PF), 0x14, 1, "out");
gi_add(MAKE_PID(PF, 5), GPIO_CFG0(PF), 0x14, 2, "sdc0_d2");
gi_add(MAKE_PID(PF, 5), GPIO_CFG0(PF), 0x14, 3, "dbg_ck");
gi_add(MAKE_PID(PF, 5), GPIO_CFG0(PF), 0x14, 4, "pwm1");
gi_add(MAKE_PID(PF, 5), GPIO_CFG0(PF), 0x14, 5, "reserved");
gi_add(MAKE_PID(PF, 5), GPIO_CFG0(PF), 0x14, 6, "eintf5");
gi_add(MAKE_PID(PF, 5), GPIO_CFG0(PF), 0x14, 7, "disabled");
void usage(char *program_name)
fprintf(stdout, "usage: %s help \n", program_name);
fprintf(stdout, " %s read [PA0|PA1...] \n", program_name);
fprintf(stdout, " %s write [PA0|PA1...] \n", program_name);
fprintf(stdout, " %s mode [PA0|PA1...] [in|out|...]\n", program_name);
fprintf(stdout, " %s readall\n", program_name);
fprintf(stdout, " %s dumpall\n", program_name);
fprintf(stdout, " %s info\n", program_name);
fprintf(stdout, "-- github.com/wuxx/f1c100s-gpio-tools --\n");
exit(0);
void dump_gpio_info()
u32 i;
u32 group, index;
u32 cfg_value, cfg_mask;
u32 dvalue;
u32 current_group = PA;
u32 current_index = 0;
u32 mode = 0;
u32 b = 0;
fprintf(stdout, "\tvalue\tmode\n");
fprintf(stdout, "PA:\n");
for(i = 0; i < gindex; i = i + 8) {
group = gi[i].pio >> 5;
index = gi[i].pio & 0x1f;
if (group != current_group) {
fprintf(stdout, "P%c:\n", 'A' + group);
current_group = group;
fprintf(stdout, "P%c%d:", 'A' + group, index);
cfg_value = readl(gi[i].cfg_addr);
mode = (cfg_value >> gi[i].cfg_off) & 0x7;
dvalue = readl(GPIO_DATA(group));
b = get_bit(dvalue, index);
fprintf(stdout, "\t%d\t[%s]\n", b, gi_get_mode_desc(gi[i].pio, mode));
void dump_gpio_mode()
u32 i, x;
u32 group, index;
fprintf(stdout, "P%c%d:\t(", 'A' + group, index);
for(x = 0; x < 8; x++) {
fprintf(stdout, "%s ", gi[i + x].mode_desc);
fprintf(stdout, ")\n");
void dump_reg(u32 pio)
fprintf(stdout, "GPIO_CFG0: 0x%08x\n", readl(GPIO_CFG0(pio)));
fprintf(stdout, "GPIO_CFG1: 0x%08x\n", readl(GPIO_CFG1(pio)));
fprintf(stdout, "GPIO_CFG2: 0x%08x\n", readl(GPIO_CFG2(pio)));
fprintf(stdout, "GPIO_CFG3: 0x%08x\n", readl(GPIO_CFG3(pio)));
fprintf(stdout, "GPIO_DATA: 0x%08x\n", readl(GPIO_DATA(pio)));
fprintf(stdout, "GPIO_DRV0: 0x%08x\n", readl(GPIO_DRV0(pio)));
fprintf(stdout, "GPIO_DRV1: 0x%08x\n", readl(GPIO_DRV1(pio)));
fprintf(stdout, "GPIO_PUL0: 0x%08x\n", readl(GPIO_PUL0(pio)));
fprintf(stdout, "GPIO_PUL1: 0x%08x\n", readl(GPIO_PUL1(pio)));
void dump_gpio_reg()
dump_reg(PA);
fprintf(stdout, "PB:\n");
dump_reg(PB);
fprintf(stdout, "PC:\n");
dump_reg(PC);
fprintf(stdout, "PD:\n");
dump_reg(PD);
fprintf(stdout, "PE:\n");
dump_reg(PE);
fprintf(stdout, "PF:\n");
dump_reg(PF);
int main(int argc, char **argv)
u32 group, index;
u32 dvalue, b;
char *m;
struct gpio_info *pgi;
if (argc == 1) {
usage(argv[0]);
gi_init();
if (strcmp("read", argv[1]) == 0) {
/* e.g. gpio read PA0 */
if(argc != 3) {
fprintf(stderr, "%s read pio, e.g. %s read PA0\n", argv[0], argv[0]);
exit(-1);
pgi = gi_get(argv[2], NULL);
if (pgi == NULL) {
fprintf(stderr, "gi_get(%s) fail!\n", argv[2]);
exit(-1);
group = pgi->pio >> 5; /* high 3 bit */
index = pgi->pio & 0x1f; /* low 5 bit */
fprintf(stdout, "%s: %d\n", argv[2], get_bit(dvalue, index));
} else if (strcmp("write", argv[1]) == 0) {
/* e.g. gpio write PA0 1 */
if (argc != 4) {
fprintf(stderr, "%s write pio [0|1], e.g. %s write PA 1\n", argv[0], argv[0]);
exit(-1);
b = atoi(argv[3]);
if (pgi == NULL) {
exit(-1);
cfg_value = readl(pgi->cfg_addr);
cfg_mask = 0x7 << pgi->cfg_off;
cfg_value = cfg_value & (~cfg_mask);
cfg_value = cfg_value | OUT << pgi->cfg_off;
writel(pgi->cfg_addr, cfg_value);
set_bit(&dvalue, index, b);
writel(GPIO_DATA(group), dvalue);
} else if (strcmp("mode", argv[1]) == 0) {
/* e.g. gpio mode PA0 in|out|... */
if (argc != 4) {
fprintf(stderr, "%s mode pio [in|out|...], e.g. %s mode PA in\n", argv[0], argv[0]);
exit(-1);
m = argv[3];
pgi = gi_get(argv[2], m);
if (pgi == NULL) {
fprintf(stderr, "gi_get(%s, %s) fail!\n", argv[2], m);
exit(-1);
cfg_value = cfg_value | pgi->mode << pgi->cfg_off;
} else if (strcmp("readall", argv[1]) == 0) {
dump_gpio_info();
} else if (strcmp("dumpall", argv[1]) == 0) {
dump_gpio_reg();
} else if (strcmp("info", argv[1]) == 0) {
dump_gpio_mode();
} else {
fprintf(stderr, "unknown cmd [%s]\n", argv[1]);
usage(argv[0]);
}离线
不错 感谢分享
具体用法和树莓派的gpio命令类似,如下root@f1c100s:~#gpio
usage: gpio help
gpio readall
gpio dumpall
gpio info
PA0: 0
value mode
PA:
PA0: 0 [in]
PA1: 0 [disabled]
PA2: 0 [out]
PA3: 1 [out]
PB:
PB3: 0 [disabled]
PC:
PC0: 0 [spi0_clk]
PC1: 0 [spi0_cs]
PC2: 0 [spi0_miso]
PC3: 0 [spi0_mosi]
PD:
PD0: 0 [lcd_d2]
PD1: 0 [lcd_d3]
PD2: 0 [lcd_d4]
PD3: 0 [lcd_d5]
PD4: 0 [lcd_d6]
PD5: 0 [lcd_d7]
PD6: 0 [lcd_d10]
PD7: 0 [lcd_d11]
PD8: 0 [lcd_d12]
PD9: 0 [lcd_d13]
PD10: 0 [lcd_d14]
PD11: 0 [lcd_d15]
PD12: 0 [lcd_d18]
PD13: 0 [lcd_d19]
PD14: 0 [lcd_d20]
PD15: 0 [lcd_d21]
PD16: 0 [lcd_d22]
PD17: 0 [lcd_d23]
PD18: 0 [lcd_clk]
PD19: 0 [lcd_de]
PD20: 0 [lcd_hsync]
PD21: 0 [lcd_vsync]
PE:
PE0: 0 [uart0_rx]
PE1: 0 [uart0_tx]
PE2: 0 [out]
PE3: 1 [out]
PE4: 1 [out]
PE5: 1 [in]
PE6: 1 [out]
PE7: 0 [disabled]
PE8: 0 [disabled]
PE9: 0 [disabled]
PE10: 1 [out]
PE11: 0 [twi0_sck]
PE12: 0 [twi0_sda]
PF:
PF0: 0 [sdc0_d1]
PF1: 0 [sdc0_d0]
PF2: 0 [sdc0_clk]
PF3: 0 [sdc0_cmd]
PF4: 0 [sdc0_d3]
PA:
PB:
PC:
PD:
PE:
PF:
感谢分享,很有用。大神能不能打包一个f1c100s的带所有常用外设驱动的spi-flash镜像,我等小白刚买的licheepi开发板官方镜像外设只有gpio能用,编译内核对于新手太复杂了,得慢慢学,有个可用的镜像就好了
竟然有如此神器,多谢楼主!
赞赞
我也才开始学,看的b站的视频,还有荔枝派zero的文档学,向大佬学习
感谢楼主,看起来挺有用的,源码和二进制文件一块给了,方便许多
调试方便多了, 收下备用
有这个就比较方便了,非常感谢,收下了
居然还有这么好的东西,感谢分享
这玩意有没有v3s版本的
F1C200S不太适配,会出现sh: 1: devmem: not found的错误
F1C200s还能用么,Linux5.4的内核
大佬,具体怎么用啊?怎么给添加到板子上呢?小白一个
看代码是用devmem实现的,这种方法如果能带一个config参数表,就能适配到别的Soc上了,现在看只能f1c100s/f1c200s用。
