刚刚开机,没有swap:
|_ _||_| ___ _ _ | | |_| ___ _ _ _ _
| | _ | || | | |__ | || || | ||_'_|
| | | || | || _ | |_____||_||_|_||___||_,_|
|_| |_||_|_||_|_| Tina is Based on OpenWrt!
Tina Linux (5.0, r0-6ada511)
nodev debugfs
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# free
total used free shared buff/cache available
Mem: 233780 15596 210488 0 7696 211804
Swap: 0 0 0
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#编译一个没有护栏的测试程序,每次动态申请1M内存,第二个参数是申请次数:
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <unistd.h>
void main(int argc, char* argv[])
static int count = 0;
int times = atoi(argv[1]);
for(int i =0; i<times; i++)
void* ptr = malloc(1*1024*1024);
if(ptr == NULL)
printf("malloc error");
memset(ptr, 0, 1*1024*1024);
printf("malloc ok, count=%3d\n", count++);
while (1)
printf("sleep\n");
usleep(1000*1000);
}申请大约200M内存的时候挂了:
root@TinaLinux:/#
Mem: 233780 15788 204344 5948 13648 205664
Swap: 0 0 0
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# chmod +x /tmp/test && /tmp/test 206
malloc ok, count=0
malloc ok, count=1
malloc ok, count=197
malloc ok, count=198
malloc ok, count=199
malloc ok, count=200
[ 167.228684] test invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE|0x1000000), order=0, oom_score_adj=0
[ 167.240249] CPU: 1 PID: 1296 Comm: test Not tainted 5.4.61 #1
[ 167.246694] Hardware name: Generic DT based system
[ 167.252092] [<c010e318>] (unwind_backtrace) from [<c010a8dc>] (show_stack+0x10/0x14)
[ 167.260798] [<c010a8dc>] (show_stack) from [<c0785f90>] (dump_stack+0x7c/0x98)
[ 167.260815] [<c0785f90>] (dump_stack) from [<c0195914>] (dump_header+0x54/0x270)
[ 167.277204] [<c0195914>] (dump_header) from [<c0195d88>] (oom_kill_process+0x78/0x2bc)
[ 167.286088] [<c0195d88>] (oom_kill_process) from [<c019676c>] (out_of_memory+0x318/0x384)
[ 167.295270] [<c019676c>] (out_of_memory) from [<c01c82e4>] (__alloc_pages_nodemask+0x758/0x9b0)
[ 167.305037] [<c01c82e4>] (__alloc_pages_nodemask) from [<c01b37ac>] (alloc_zeroed_user_highpage_movable+0x14/0x3c)
[ 167.316657] [<c01b37ac>] (alloc_zeroed_user_highpage_movable) from [<c01b6264>] (handle_mm_fault+0x214/0x7c0)
[ 167.327787] [<c01b6264>] (handle_mm_fault) from [<c010f1ac>] (do_page_fault+0x13c/0x29c)
[ 167.336872] [<c010f1ac>] (do_page_fault) from [<c010f468>] (do_DataAbort+0x34/0xb4)
[ 167.345468] [<c010f468>] (do_DataAbort) from [<c010255c>] (__dabt_usr+0x3c/0x40)
[ 167.353768] Exception stack(0xce1fffb0 to 0xce1ffff8)
[ 167.359436] ffa0: aa452008 00000000 00006000 aa54c000
[ 167.368612] ffc0: 00010bd4 00010c68 00000000 00010134 00000000 00010134 00079470 bea9cb84
[ 167.377793] ffe0: 00000000 bea9cb68 000104fc 00027908 20070010 ffffffff
[ 167.385280] Mem-Info:
[ 167.387840] active_anon:52056 inactive_anon:1486 isolated_anon:0
[ 167.387840] active_file:9 inactive_file:9 isolated_file:0
[ 167.387840] unevictable:0 dirty:0 writeback:0 unstable:0
[ 167.387840] slab_reclaimable:562 slab_unreclaimable:2552
[ 167.387840] mapped:88 shmem:1487 pagetables:139 bounce:0
[ 167.387840] free:478 free_pcp:103 free_cma:0
[ 167.423747] Node 0 active_anon:208224kB inactive_anon:5944kB active_file:36kB inactive_file:36kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:352kB dirty:0kB writeback:0kB shmem:5948kB writeback_tmp:0kB unstable:0kB all_unreclaimable? yes
[ 167.423767] Normal free:1912kB min:1916kB low:2392kB high:2868kB active_anon:208224kB inactive_anon:5944kB active_file:36kB inactive_file:36kB unevictable:0kB writepending:0kB present:254400kB managed:233780kB mlocked:0kB kernel_stack:560kB pagetables:556kB bounce:0kB free_pcp:412kB local_pcp:112kB free_cma:0kB
[ 167.479940] lowmem_reserve[]: 0 0
[ 167.479952] Normal: 14*4kB (UM) 12*8kB (UM) 2*16kB (UE) 0*32kB 1*64kB (M) 1*128kB (M) 2*256kB (ME) 0*512kB 1*1024kB (M) 0*2048kB 0*4096kB = 1912kB
[ 167.498408] Free pages count per migrate typeat order: 0 1 2 3 4 5 6 7 8 9 10
[ 167.511744] zone Normal, type Unmovable 13 11 1 0 0 0 0 0 0 0 0
[ 167.524168] zone Normal, type Movable 1 1 0 0 1 1 1 0 1 0 0
[ 167.536584] zone Normal, type Reclaimable 0 0 1 0 0 0 1 0 0 0 0
[ 167.549007] zone Normal, type CMA 0 0 0 0 0 0 0 0 0 0 0
[ 167.561421] zone Normal, type HighAtomic 0 0 0 0 0 0 0 0 0 0 0
[ 167.573839] zone Normal, type Isolate 0 0 0 0 0 0 0 0 0 0 0
[ 167.586255] 1501 total pagecache pages
[ 167.590458] 0 pages in swap cache
[ 167.594173] Swap cache stats: add 0, delete 0, find 0/0
[ 167.600066] Free swap = 0kB
[ 167.603293] Total swap = 0kB
[ 167.606533] 63600 pages RAM
[ 167.609661] 0 pages HighMem/MovableOnly
[ 167.613957] 5155 pages reserved
[ 167.617487] 2048 pages cma reserved
[ 167.621396] Tasks state (memory values in pages):
[ 167.626678] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
[ 167.636364] [ 1211] 0 1211 9461 49 18432 0 0 adbd
[ 167.645462] [ 1254] 0 1254 782 31 10240 0 0 sh
[ 167.645472] [ 1255] 0 1255 751 27 10240 0 0 init
[ 167.663433] [ 1256] 0 1256 751 27 10240 0 0 init
[ 167.672521] [ 1257] 0 1257 751 27 10240 0 0 init
[ 167.681611] [ 1296] 0 1296 52073 51958 215040 0 0 test
[ 167.690698] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),task=test,pid=1296,uid=0
[ 167.699814] Out of memory: Killed process 1296 (test) total-vm:208292kB, anon-rss:207480kB, file-rss:0kB, shmem-rss:352kB, UID:0 pgtables:210kB oom_score_adj:0
[ 167.766642] oom_reaper: reaped process 1296 (test), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Killed
root@TinaLinux:/#下面开启交换分区:
mkswap /dev/by-name/swapper && swapon /dev/by-name/swapper 开启完成:
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/# mkswap /dev/by-name/swapper && swapon /dev/by-name/swapper
Setting up swapspace version 1, size = 536866816 bytes
[ 317.944647] Adding 524284k swap on /dev/by-name/swapper. Priority:-2 extents:1 across:524284k SS
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#测试申请700M,系统正常:
malloc ok, count=0
malloc ok, count=1
malloc ok, count=691
malloc ok, count=692
malloc ok, count=693
malloc ok, count=694
malloc ok, count=695
malloc ok, count=696
malloc ok, count=697
malloc ok, count=698
malloc ok, count=699
sleep
sleep
sleepfree命令看下内存占用:
Mem: 233780 221724 6532 92 5524 6400
Swap: 524284 524284 0申请703M的时候,OOM炸了:
root@TinaLinux:/#
root@TinaLinux:/# chmod +x /tmp/test && /tmp/test 720
malloc ok, count=0
malloc ok, count=1
malloc ok, count=701
malloc ok, count=702
[24017.015074] test invoked oom-killer: gfp_mask=0x1100cca(GFP_HIGHUSER_MOVABLE|0x1000000), order=0, oom_score_adj=0
[24017.026721] CPU: 1 PID: 1412 Comm: test Not tainted 5.4.61 #1
[24017.033176] Hardware name: Generic DT based system
[24017.033206] [<c010e318>] (unwind_backtrace) from [<c010a8dc>] (show_stack+0x10/0x14)
[24017.033221] [<c010a8dc>] (show_stack) from [<c0785f90>] (dump_stack+0x7c/0x98)
[24017.033237] [<c0785f90>] (dump_stack) from [<c0195914>] (dump_header+0x54/0x270)
[24017.033250] [<c0195914>] (dump_header) from [<c0195d88>] (oom_kill_process+0x78/0x2bc)
[24017.033262] [<c0195d88>] (oom_kill_process) from [<c019676c>] (out_of_memory+0x318/0x384)
[24017.033277] [<c019676c>] (out_of_memory) from [<c01c82e4>] (__alloc_pages_nodemask+0x758/0x9b0)
[24017.033292] [<c01c82e4>] (__alloc_pages_nodemask) from [<c01b37ac>] (alloc_zeroed_user_highpage_movable+0x14/0x3c)
[24017.033305] [<c01b37ac>] (alloc_zeroed_user_highpage_movable) from [<c01b6264>] (handle_mm_fault+0x214/0x7c0)
[24017.033318] [<c01b6264>] (handle_mm_fault) from [<c010f1ac>] (do_page_fault+0x13c/0x29c)
[24017.033332] [<c010f1ac>] (do_page_fault) from [<c010f468>] (do_DataAbort+0x34/0xb4)
[24017.033344] [<c010f468>] (do_DataAbort) from [<c010255c>] (__dabt_usr+0x3c/0x40)
[24017.033349] Exception stack(0xce22ffb0 to 0xce22fff8)
[24017.033358] ffa0: 8ac74008 00000000 00007000 8ad6d000
[24017.033368] ffc0: 00010bd4 00010c68 00000000 00010134 00000000 00010134 00079470 beef1b84
[24017.033377] ffe0: 00000000 beef1b68 000104fc 00027908 20070010 ffffffff
[24017.033381] Mem-Info:
[24017.033398] active_anon:25811 inactive_anon:25853 isolated_anon:0
[24017.033398] active_file:6 inactive_file:4 isolated_file:0
[24017.033398] unevictable:0 dirty:0 writeback:127 unstable:0
[24017.033398] slab_reclaimable:628 slab_unreclaimable:3241
[24017.033398] mapped:19 shmem:19 pagetables:399 bounce:0
[24017.033398] free:1366 free_pcp:0 free_cma:0
[24017.033412] Node 0 active_anon:103244kB inactive_anon:103412kB active_file:24kB inactive_file:16kB unevictable:0kB isolated(anon):0kB isolated(file):0kB map ped:76kB dirty:0kB writeback:508kB shmem:76kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[24017.033428] Normal free:5464kB min:1916kB low:2392kB high:2868kB active_anon:103300kB inactive_anon:103328kB active_file:24kB inactive_file:16kB unevictable :0kB writepending:488kB present:254400kB managed:233780kB mlocked:0kB kernel_stack:536kB pagetables:1596kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB
[24017.033431] lowmem_reserve[]: 0 0
[24017.033438] Normal: 199*4kB (UME) 141*8kB (UME) 85*16kB (UME) 37*32kB (ME) 16*64kB (ME) 1*128kB (M) 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 5620kB
[24017.033474] Free pages count per migrate typeat order: 0 1 2 3 4 5 6 7 8 9 10
[24017.033496] zone Normal, type Unmovable 61 34 8 0 0 0 0 0 0 0 0
[24017.033531] zone Normal, type Movable 98 82 60 25 13 1 0 0 0 0 0
[24017.033580] zone Normal, type Reclaimable 40 25 17 12 3 0 0 0 0 0 0
[24017.033612] zone Normal, type CMA 0 0 0 0 0 0 0 0 0 0 0
[24017.033632] zone Normal, type HighAtomic 0 0 0 0 0 0 0 0 0 0 0
[24017.033652] zone Normal, type Isolate 0 0 0 0 0 0 0 0 0 0 0
[24017.033671] 178 total pagecache pages
[24017.033678] 146 pages in swap cache
[24017.033683] Swap cache stats: add 424365, delete 424256, find 343/587
[24017.033686] Free swap = 0kB
[24017.033689] Total swap = 524284kB
[24017.033693] 63600 pages RAM
[24017.033696] 0 pages HighMem/MovableOnly
[24017.033699] 5155 pages reserved
[24017.033702] 2048 pages cma reserved
[24017.033705] Tasks state (memory values in pages):
[24017.033708] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
[24017.033730] [ 1211] 0 1211 11510 0 24576 77 0 adbd
[24017.033738] [ 1254] 0 1254 782 0 10240 36 0 sh
[24017.033747] [ 1255] 0 1255 751 0 10240 27 0 init
[24017.033755] [ 1256] 0 1256 751 0 10240 27 0 init
[24017.033764] [ 1257] 0 1257 751 0 10240 27 0 init
[24017.033772] [ 1277] 0 1277 782 0 10240 40 0 sh
[24017.033781] [ 1412] 0 1412 181087 51492 731136 129420 0 test
[24017.033787] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),task=test,pid=1412,uid=0
[24017.033813] Out of memory: Killed process 1412 (test) total-vm:724348kB, anon-rss:205892kB, file-rss:0kB, shmem-rss:76kB, UID:0 pgtables:714kB oom_score_adj :0
[24017.260905] oom_reaper: reaped process 1412 (test), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Killed
root@TinaLinux:/#
root@TinaLinux:/#
root@TinaLinux:/#离线
请教晕哥,你演示的无护栏测试代码中,已经判断了指针是否为NULL,这个做法是应用程序普遍的处理方式;即便这样应用还是会被杀。
那如何编写有护栏的应用呢?要求即便内存oom发生,应用程序也不会被杀。是通过signal()函数实现吗?请教晕哥。
[img]/files/members/3/5O@X4S@HO$9~ETD[77K`I)O.png[/img]
malloc ok, count=146
malloc ok, count=147
malloc ok, count=148
malloc ok, count=149
malloc ok, count=150
malloc ok, count=151
malloc ok, count=152
malloc ok, count=153
[ 216.137338] mem_test invoked oom-killer: gfp_mask=0x24200ca(GFP_HIGHUSER_MOVABLE), nodemask=0, order=0, oom_score_adj=0
[ 216.150768] CPU: 0 PID: 1703 Comm: mem_test Not tainted 4.9.118 #183
[ 216.164815] Hardware name: sun8iw8
[ 216.168650] [<c010c7cc>] (unwind_backtrace) from [<c010a6f4>] (show_stack+0x10/0x14)
[ 216.179140] [<c010a6f4>] (show_stack) from [<c01da458>] (dump_header.constprop.3+0x64/0x1ac)
[ 216.190381] [<c01da458>] (dump_header.constprop.3) from [<c01975a4>] (oom_kill_process+0xec/0x4a8)
[ 216.208704] [<c01975a4>] (oom_kill_process) from [<c0197e28>] (out_of_memory+0x348/0x3f0)
[ 216.217901] [<c0197e28>] (out_of_memory) from [<c019c0ec>] (__alloc_pages_nodemask+0x950/0xa28)
[ 216.234830] [<c019c0ec>] (__alloc_pages_nodemask) from [<c01ba94c>] (handle_mm_fault+0x140/0xb70)
[ 216.245960] [<c01ba94c>] (handle_mm_fault) from [<c010ec34>] (do_page_fault+0x210/0x2a8)
[ 216.256745] [<c010ec34>] (do_page_fault) from [<c01012d4>] (do_DataAbort+0x38/0xb8)
[ 216.271863] [<c01012d4>] (do_DataAbort) from [<c010b39c>] (__dabt_usr+0x3c/0x40)
[ 216.281845] Exception stack(0xc2393fb0 to 0xc2393ff8)
[ 216.294763] 3fa0: ad371010 00006b7f ad448028 00007fff
[ 216.304956] 3fc0: 00000000 00000000 00000000 00000000 00000001 00000000 00000020 beda4e34
[ 216.316019] 3fe0: ad37101c beda4df0 00000000 b6f72774 20000010 ffffffff
[ 216.330038] [ pid ] uid tgid total_vm rss nr_ptes nr_pmds swapents oom_score_adj name
[ 216.341363] [ 720] 0 720 330 1 4 0 6 0 syslogd
[ 216.359483] [ 724] 0 724 329 1 4 0 6 0 klogd
[ 216.369134] [ 736] 0 736 333 1 5 0 13 0 mdev
[ 216.383525] [ 780] 0 780 1657 11 7 0 754 0 haveged
[ 216.395798] [ 786] 1001 786 331 0 4 0 18 0 dbus-daemon
[ 216.407732] [ 792] 0 792 1110 27 6 0 81 0 ntpd
[ 216.424769] [ 805] 0 805 223 1 4 0 9 0 dropbear
[ 216.435459] [ 808] 0 808 168315 19 8 0 211 0 allxbee
[ 216.446949] [ 812] 0 812 167906 32 7 0 313 0 iotWatchdog
[ 216.464755] [ 952] 0 952 332 1 4 0 10 0 sh
[ 216.474740] [ 1616] 0 1616 329 1 3 0 6 0 udhcpc
[ 216.486136] [ 1703] 0 1703 40009 8503 82 0 31313 0 mem_test
[ 216.502559] Out of memory: Kill process 1703 (mem_test) score 836 or sacrifice child
[ 216.512924] Killed process 1703 (mem_test) total-vm:160036kB, anon-rss:33956kB, file-rss:56kB, shmem-rss:0kB
[ 216.602368] oom_reaper: reaped process 1703 (mem_test), now anon-rss:4kB, file-rss:0kB, shmem-rss:0kB
Killed
# bg
-sh: bg: No current job
# free
Mem: 53960 12648 21936 8 19376 37272
Swap: 131068 5320 125748
#V3s可以申请到153M 内存
@晕哥
原来如此,那我理解错了。
我以为“护栏”指的是:某种防范措施,能实现发生OOM时应用不被杀,而仅仅是malloc返回NULL。
请教晕哥,在C100外挂8MB nor flash的平台上也可以开启SWAP吗?
